[U-Boot] [PATCH v2 6/8] arm: Move SYS_FSL_SRDS_* and SYS_HAS_SERDES to Kconfig
Move these options to Kconfig and clean up existing uses.
Signed-off-by: York Sun york.sun@nxp.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
arch/arm/cpu/armv7/ls102xa/Kconfig | 11 +++++++++++ arch/arm/cpu/armv8/fsl-layerscape/Kconfig | 16 ++++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 5 ----- arch/arm/include/asm/arch-ls102xa/config.h | 2 -- include/configs/ls1012a_common.h | 2 -- include/configs/ls1021aqds.h | 2 -- include/configs/ls1021atwr.h | 2 -- include/configs/ls1043a_common.h | 3 --- include/configs/ls1043aqds.h | 2 -- include/configs/ls1046a_common.h | 3 --- include/configs/ls1046aqds.h | 2 -- include/configs/ls2080a_common.h | 3 --- 12 files changed, 27 insertions(+), 26 deletions(-)
diff --git a/arch/arm/cpu/armv7/ls102xa/Kconfig b/arch/arm/cpu/armv7/ls102xa/Kconfig index 88983f4..17f1975 100644 --- a/arch/arm/cpu/armv7/ls102xa/Kconfig +++ b/arch/arm/cpu/armv7/ls102xa/Kconfig @@ -1,6 +1,8 @@ config ARCH_LS1021A bool select SYS_FSL_ERRATUM_A010315 + select SYS_FSL_SRDS_1 + select SYS_HAS_SERDES
menu "LS102xA architecture" depends on ARCH_LS1021A @@ -23,6 +25,15 @@ config MAX_CPUS config SYS_FSL_ERRATUM_A010315 bool "Workaround for PCIe erratum A010315"
+config SYS_FSL_SRDS_1 + bool + +config SYS_FSL_SRDS_2 + bool + +config SYS_HAS_SERDES + bool + config SYS_FSL_IFC_BANK_COUNT int "Maximum banks of Integrated flash controller" depends on ARCH_LS1021A diff --git a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig index f683a14..66e509e 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/Kconfig +++ b/arch/arm/cpu/armv8/fsl-layerscape/Kconfig @@ -12,16 +12,23 @@ config ARCH_LS1043A config ARCH_LS1046A bool select FSL_LSCH2 + select SYS_FSL_SRDS_2
config ARCH_LS2080A bool select FSL_LSCH3 + select SYS_FSL_HAS_DP_DDR + select SYS_FSL_SRDS_2
config FSL_LSCH2 bool + select SYS_FSL_SRDS_1 + select SYS_HAS_SERDES
config FSL_LSCH3 bool + select SYS_FSL_SRDS_1 + select SYS_HAS_SERDES
menu "Layerscape architecture" depends on FSL_LSCH2 || FSL_LSCH3 @@ -60,4 +67,13 @@ config SYS_FSL_IFC_BANK_COUNT config SYS_FSL_HAS_DP_DDR bool
+config SYS_FSL_SRDS_1 + bool + +config SYS_FSL_SRDS_2 + bool + +config SYS_HAS_SERDES + bool + endmenu diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index 6ee75cb..3039e72 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -32,8 +32,6 @@ #ifdef CONFIG_LS2080A #define CONFIG_SYS_FSL_CLUSTER_CLOCKS { 1, 1, 4, 4 } #define SRDS_MAX_LANES 8 -#define CONFIG_SYS_FSL_SRDS_1 -#define CONFIG_SYS_FSL_SRDS_2 #define CONFIG_SYS_PAGE_SIZE 0x10000 #ifndef L1_CACHE_BYTES #define L1_CACHE_SHIFT 6 @@ -162,8 +160,6 @@ #define CONFIG_SYS_FSL_PEX_LUT_BE #define CONFIG_SYS_FSL_SEC_BE
-#define CONFIG_SYS_FSL_SRDS_1 - /* SoC related */ #ifdef CONFIG_LS1043A #define CONFIG_SYS_FMAN_V3 @@ -212,7 +208,6 @@ #define CONFIG_SYS_DDR_BLOCK1_SIZE ((phys_size_t)2 << 30) #define CONFIG_MAX_MEM_MAPPED CONFIG_SYS_DDR_BLOCK1_SIZE
-#define CONFIG_SYS_FSL_SRDS_2 #define CONFIG_SYS_FSL_IFC_BE #define CONFIG_SYS_FSL_SFP_VER_3_2 #define CONFIG_SYS_FSL_SNVS_LE diff --git a/arch/arm/include/asm/arch-ls102xa/config.h b/arch/arm/include/asm/arch-ls102xa/config.h index 70cc703..dfcb546 100644 --- a/arch/arm/include/asm/arch-ls102xa/config.h +++ b/arch/arm/include/asm/arch-ls102xa/config.h @@ -120,8 +120,6 @@
#define DCU_LAYER_MAX_NUM 16
-#define CONFIG_SYS_FSL_SRDS_1 - #ifdef CONFIG_LS102XA #define CONFIG_SYS_FSL_IFC_BANK_COUNT 8 #define CONFIG_NUM_DDR_CONTROLLERS 1 diff --git a/include/configs/ls1012a_common.h b/include/configs/ls1012a_common.h index 1056755..ced8ead 100644 --- a/include/configs/ls1012a_common.h +++ b/include/configs/ls1012a_common.h @@ -10,8 +10,6 @@ #define CONFIG_FSL_LAYERSCAPE #define CONFIG_GICV2
-#define CONFIG_SYS_HAS_SERDES - #include <asm/arch/config.h> #define CONFIG_SYS_NO_FLASH
diff --git a/include/configs/ls1021aqds.h b/include/configs/ls1021aqds.h index 0d72e69..5ff3db6 100644 --- a/include/configs/ls1021aqds.h +++ b/include/configs/ls1021aqds.h @@ -143,8 +143,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
-#define CONFIG_SYS_HAS_SERDES - #define CONFIG_FSL_CAAM /* Enable CAAM */
#if !defined(CONFIG_SD_BOOT) && !defined(CONFIG_NAND_BOOT) && \ diff --git a/include/configs/ls1021atwr.h b/include/configs/ls1021atwr.h index e5ac50e..67b43c6 100644 --- a/include/configs/ls1021atwr.h +++ b/include/configs/ls1021atwr.h @@ -170,8 +170,6 @@ #define CONFIG_SYS_DDR_SDRAM_BASE 0x80000000UL #define CONFIG_SYS_SDRAM_BASE CONFIG_SYS_DDR_SDRAM_BASE
#if !defined(CONFIG_SD_BOOT) && !defined(CONFIG_NAND_BOOT) && \ diff --git a/include/configs/ls1043a_common.h b/include/configs/ls1043a_common.h index ac86c08..3a85b6a 100644 --- a/include/configs/ls1043a_common.h +++ b/include/configs/ls1043a_common.h @@ -15,9 +15,6 @@ #define CONFIG_GICV2
#include <asm/arch/config.h> -#ifdef CONFIG_SYS_FSL_SRDS_1 -#define CONFIG_SYS_HAS_SERDES -#endif
/* Link Definitions */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) diff --git a/include/configs/ls1043aqds.h b/include/configs/ls1043aqds.h index a80e33d..b18fcc0 100644 --- a/include/configs/ls1043aqds.h +++ b/include/configs/ls1043aqds.h @@ -52,8 +52,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
-#define CONFIG_SYS_HAS_SERDES - #ifdef CONFIG_SYS_DPAA_FMAN #define CONFIG_FMAN_ENET #define CONFIG_PHYLIB diff --git a/include/configs/ls1046a_common.h b/include/configs/ls1046a_common.h index ec6c908..c4bbd56 100644 --- a/include/configs/ls1046a_common.h +++ b/include/configs/ls1046a_common.h @@ -14,9 +14,6 @@ #define CONFIG_GICV2
/* Link Definitions */ #define CONFIG_SYS_INIT_SP_ADDR (CONFIG_SYS_FSL_OCRAM_BASE + 0xfff0) diff --git a/include/configs/ls1046aqds.h b/include/configs/ls1046aqds.h index 2e5c2f1..d1adf3f 100644 --- a/include/configs/ls1046aqds.h +++ b/include/configs/ls1046aqds.h @@ -49,8 +49,6 @@ unsigned long get_board_ddr_clk(void); #define CONFIG_MEM_INIT_VALUE 0xdeadbeef #endif
-#define CONFIG_SYS_HAS_SERDES - /* DSPI */ #ifdef CONFIG_FSL_DSPI #define CONFIG_SPI_FLASH_STMICRO /* cs0 */ diff --git a/include/configs/ls2080a_common.h b/include/configs/ls2080a_common.h index d9eea09..187aee1 100644 --- a/include/configs/ls2080a_common.h +++ b/include/configs/ls2080a_common.h @@ -15,9 +15,6 @@
#include <asm/arch/ls2080a_stream_id.h> #include <asm/arch/config.h> -#if (defined(CONFIG_SYS_FSL_SRDS_1) || defined(CONFIG_SYS_FSL_SRDS_2)) -#define CONFIG_SYS_HAS_SERDES -#endif
York Sun
