[U-Boot] [PATCH v2] ARM: mvebu: add support for Allied Telesis x530
From: Chris Packham chris.packham@alliedtelesis.co.nz
This is a range of stackable network switches. The SoC is Armada-385 and there are a number of variants with differing network port configurations. The DP variants are intended for a harsher operating environment so they use a different i2c mux and fit industrial-temp parts.
Signed-off-by: Chris Packham judge.packham@gmail.com --- This needs http://patchwork.ozlabs.org/patch/1010285/
Changes in v2: - drop RFC, use armada-385-atl to prefix dts file names
arch/arm/dts/Makefile | 4 +- arch/arm/dts/armada-385-atl-x530-u-boot.dtsi | 13 + arch/arm/dts/armada-385-atl-x530.dts | 50 ++++ arch/arm/dts/armada-385-atl-x530.dtsi | 266 +++++++++++++++++++ arch/arm/dts/armada-385-atl-x530DP.dts | 51 ++++ arch/arm/dts/armada-385-atl-x530DP.dtsi | 149 +++++++++++ arch/arm/mach-mvebu/Kconfig | 7 + board/alliedtelesis/common/gpio_hog.c | 36 +++ board/alliedtelesis/common/gpio_hog.h | 13 + board/alliedtelesis/x530/MAINTAINERS | 12 + board/alliedtelesis/x530/Makefile | 9 + board/alliedtelesis/x530/kwbimage.cfg | 12 + board/alliedtelesis/x530/x530.c | 161 +++++++++++ configs/x530_defconfig | 71 +++++ include/configs/x530.h | 134 ++++++++++ 15 files changed, 987 insertions(+), 1 deletion(-) create mode 100644 arch/arm/dts/armada-385-atl-x530-u-boot.dtsi create mode 100644 arch/arm/dts/armada-385-atl-x530.dts create mode 100644 arch/arm/dts/armada-385-atl-x530.dtsi create mode 100644 arch/arm/dts/armada-385-atl-x530DP.dts create mode 100644 arch/arm/dts/armada-385-atl-x530DP.dtsi create mode 100644 board/alliedtelesis/common/gpio_hog.c create mode 100644 board/alliedtelesis/common/gpio_hog.h create mode 100644 board/alliedtelesis/x530/MAINTAINERS create mode 100644 board/alliedtelesis/x530/Makefile create mode 100644 board/alliedtelesis/x530/kwbimage.cfg create mode 100644 board/alliedtelesis/x530/x530.c create mode 100644 configs/x530_defconfig create mode 100644 include/configs/x530.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dda4e594914b..9b9a35b44a75 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -109,7 +109,9 @@ dtb-$(CONFIG_ARCH_MVEBU) += \ armada-xp-maxbcm.dtb \ armada-xp-synology-ds414.dtb \ armada-xp-theadorable.dtb \ - armada-38x-controlcenterdc.dtb + armada-38x-controlcenterdc.dtb \ + armada-385-atl-x530.dtb \ + armada-385-atl-x530DP.dtb
dtb-$(CONFIG_ARCH_UNIPHIER_LD11) += \ uniphier-ld11-global.dtb \ diff --git a/arch/arm/dts/armada-385-atl-x530-u-boot.dtsi b/arch/arm/dts/armada-385-atl-x530-u-boot.dtsi new file mode 100644 index 000000000000..7074a73537fa --- /dev/null +++ b/arch/arm/dts/armada-385-atl-x530-u-boot.dtsi @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0 + +&spi1 { + u-boot,dm-pre-reloc; + + spi-flash@0 { + u-boot,dm-pre-reloc; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; +}; diff --git a/arch/arm/dts/armada-385-atl-x530.dts b/arch/arm/dts/armada-385-atl-x530.dts new file mode 100644 index 000000000000..0ebaa8bb344c --- /dev/null +++ b/arch/arm/dts/armada-385-atl-x530.dts @@ -0,0 +1,50 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "armada-385-atl-x530.dtsi" +#include "armada-385-atl-x530-u-boot.dtsi" + +/ { + model = "Allied Telesis x530"; + compatible = "alliedtelesis,x530", "marvell,armada385", "marvell,armada380"; + + nand-protect { + compatible = "atl,nand-protect"; + protect-gpio = <&gpio1 11 GPIO_ACTIVE_HIGH>; + }; + + usb-enable { + compatible = "atl,usb-enable"; + enable-gpio = <&gpio0 19 GPIO_ACTIVE_HIGH>; + }; + + boot-board { + compatible = "atl,boot-board"; + present-gpio = <&gpio0 24 GPIO_ACTIVE_HIGH>; + override-gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + }; + + phy-reset { + compatible = "atl,phy-reset"; + reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>, + <&gpio1 21 GPIO_ACTIVE_HIGH>; + }; + + led-enable { + compatible = "atl,led-enable"; + enable-gpio = <&gpio1 17 GPIO_ACTIVE_HIGH>; + }; + + led_7seg { + compatible = "atl,of-led-7seg"; + segment-gpios = < + &led_7seg_gpio 0 0 + &led_7seg_gpio 1 0 + &led_7seg_gpio 2 0 + &led_7seg_gpio 3 0 + &led_7seg_gpio 4 0 + &led_7seg_gpio 5 0 + &led_7seg_gpio 6 0 + &led_7seg_gpio 7 0>; + }; +}; diff --git a/arch/arm/dts/armada-385-atl-x530.dtsi b/arch/arm/dts/armada-385-atl-x530.dtsi new file mode 100644 index 000000000000..09a04bdcca13 --- /dev/null +++ b/arch/arm/dts/armada-385-atl-x530.dtsi @@ -0,0 +1,266 @@ +// SPDX-License-Identifier: GPL-2.0 + +#include <dt-bindings/gpio/gpio.h> +#include "armada-385.dtsi" + +/ { + model = "Allied Telesis x530"; + compatible = "alliedtelesis,x530", "marvell,armada385", "marvell,armada380"; + + chosen { + stdout-path = "serial0:115200n8"; + bootargs = "console=ttyS0,115200 earlyprintk"; + }; + + aliases { + spi1 = &spi1; + i2c0 = &i2c0; + }; + + memory { + device_type = "memory"; + reg = <0 0x00000000 0 0x40000000>; /* 1 GB */ + }; + + soc { + ranges = <MBUS_ID(0xf0, 0x01) 0 0xf1000000 0x100000 + MBUS_ID(0x01, 0x3d) 0 0xf4800000 0x80000 + MBUS_ID(0x01, 0x1d) 0 0xfff00000 0x100000>; + + pcie-mem-aperture = <0xa0000000 0x40000000>; + }; + + eco-button-interrupt { + compatible = "atl,eco-button-interrupt"; + eco-button-gpio = <&gpio0 14 GPIO_ACTIVE_LOW>; + }; + + board-reset { + compatible = "atl,phy_reset"; + /* Physical board layout of reset pin is active-low but for the + * current driver we have to set it to active-high here. + */ + phy-reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>, + <&gpio1 21 GPIO_ACTIVE_HIGH>; + }; + + phy-int { + compatible = "linux,uio-pdrv-genirq"; + interrupt-parent = <&gpio0>; + interrupts = <6 IRQ_TYPE_EDGE_BOTH>; + }; + + led-enable { + compatible = "atl,led-enable"; + led-enable-gpios = <&gpio1 17 GPIO_ACTIVE_LOW>; + }; + + led_7seg { + compatible = "atl,of-led-7seg"; + segment-gpios = < + &led_7seg_gpio 0 0 + &led_7seg_gpio 1 0 + &led_7seg_gpio 2 0 + &led_7seg_gpio 3 0 + &led_7seg_gpio 4 0 + &led_7seg_gpio 5 0 + &led_7seg_gpio 6 0 + &led_7seg_gpio 7 0>; + }; + + poe { + compatible = "atl,periph-poe"; + poe-reset-gpio = <&gpio0 15 GPIO_ACTIVE_HIGH>; + interrupt-parent = <&gpio0>; + interrupts = <20 IRQ_TYPE_EDGE_BOTH>; + }; +}; + +&pciec { + status = "okay"; +}; + +&pcie1 { + status = "okay"; +}; + +&devbus_cs1 { + compatible = "marvell,mvebu-devbus"; + status = "okay"; + + devbus,bus-width = <8>; + devbus,turn-off-ps = <60000>; + devbus,badr-skew-ps = <0>; + devbus,acc-first-ps = <124000>; + devbus,acc-next-ps = <248000>; + devbus,rd-setup-ps = <0>; + devbus,rd-hold-ps = <0>; + + /* Write parameters */ + devbus,sync-enable = <0>; + devbus,wr-high-ps = <60000>; + devbus,wr-low-ps = <60000>; + devbus,ale-wr-ps = <60000>; + + nvs@0 { + status = "okay"; + + compatible = "mtd-ram"; + reg = <0 0x00080000>; + bank-width = <1>; + label = "nvs"; + }; +}; + +&gpio0 { + poe-disable { + gpio-hog; + gpios = <16 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "poe-disable"; + }; +}; + +&gpio1 { + poe-mezz-reset { + gpio-hog; + gpios = <15 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "poe-mezz-reset"; + }; +}; + +&i2c0 { + clock-frequency = <100000>; + status = "okay"; + + mux@71 { + #address-cells = <1>; + #size-cells = <0>; + compatible = "nxp,pca9544"; + reg = <0x71>; + i2c-mux-idle-disconnect; + + i2c@0 { /* POE devices MUX */ + #address-cells = <1>; + #size-cells = <0>; + reg = <0>; + }; + + i2c@1 { + #address-cells = <1>; + #size-cells = <0>; + reg = <1>; + + rng@3b { + compatible = "maxim,ds2476"; + reg = <0x3b>; + }; + + hwmon@2e { + compatible = "adi,adt7476"; + reg = <0x2e>; + }; + + hwmon@2d { + compatible = "adi,adt7476"; + reg = <0x2d>; + }; + + }; + + i2c@2 { + #address-cells = <1>; + #size-cells = <0>; + reg = <2>; + + rtc@68 { + compatible = "dallas,ds1340"; + reg = <0x68>; + }; + }; + + i2c@3 { + #address-cells = <1>; + #size-cells = <0>; + reg = <3>; + + led_7seg_gpio: gpio@20 { + compatible = "nxp,pca9554"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x20>; + }; + + sfpgpio: gpio@27 { /* I2C to GPIO */ + compatible = "nxp,pca9555"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x27>; + interrupt-parent = <&gpio0>; + interrupts = <13 IRQ_TYPE_LEVEL_LOW>; + }; + + sfpmux: mux@77 { /* SFP I2C MUX */ + #address-cells = <1>; + #size-cells = <0>; + compatible = "nxp,pca9544"; + reg = <0x77>; + i2c-mux-idle-disconnect; + }; + }; + }; +}; + +&spi1 { + status = "okay"; + + spi-flash@0 { + #address-cells = <1>; + #size-cells = <1>; + compatible = "jedec,spi-nor"; + reg = <0>; /* Chip select 0 */ + spi-max-frequency = <50000000>; + m25p,fast-read; + + partition@u-boot { + reg = <0x00000000 0x00100000>; + label = "u-boot"; + }; + partition@u-boot-env { + reg = <0x00100000 0x00040000>; + label = "u-boot-env"; + }; + partition@unused { + reg = <0x00140000 0x00e80000>; + label = "unused"; + }; + partition@idprom { + reg = <0x00fc0000 0x00040000>; + label = "idprom"; + }; + }; +}; + +&uart0 { + pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + status = "okay"; +}; + +&usb0 { + status = "okay"; +}; + +&refclk { + clock-frequency = <25000000>; +}; + +&nand_controller { /* 256 MB */ + status = "okay"; + num-cs = <1>; + nand-ecc-strength = <4>; + nand-ecc-step-size = <512>; + marvell,nand-enable-arbiter; + nand-on-flash-bbt; +}; diff --git a/arch/arm/dts/armada-385-atl-x530DP.dts b/arch/arm/dts/armada-385-atl-x530DP.dts new file mode 100644 index 000000000000..2d38bf50b986 --- /dev/null +++ b/arch/arm/dts/armada-385-atl-x530DP.dts @@ -0,0 +1,51 @@ +// SPDX-License-Identifier: GPL-2.0 +/dts-v1/; + +#include "armada-385-atl-x530.dtsi" +#include "armada-385-atl-x530-u-boot.dtsi" +#include "armada-385-atl-x530DP.dtsi" + +/ { + model = "Allied Telesis x530DP"; + compatible = "alliedtelesis,x530DP", "alliedtelesis,x530", "marvell,armada385", "marvell,armada380"; + + nand-protect { + compatible = "atl,nand-protect"; + protect-gpio = <&gpio1 11 GPIO_ACTIVE_HIGH>; + }; + + usb-enable { + compatible = "atl,usb-enable"; + enable-gpio = <&gpio0 19 GPIO_ACTIVE_HIGH>; + }; + + boot-board { + compatible = "atl,boot-board"; + present-gpio = <&gpio0 24 GPIO_ACTIVE_HIGH>; + override-gpio = <&gpio1 14 GPIO_ACTIVE_HIGH>; + }; + + phy-reset { + compatible = "atl,phy-reset"; + reset-gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>, + <&gpio1 21 GPIO_ACTIVE_HIGH>; + }; + + led-enable { + compatible = "atl,led-enable"; + enable-gpio = <&gpio1 17 GPIO_ACTIVE_HIGH>; + }; + + led_7seg { + compatible = "atl,of-led-7seg"; + segment-gpios = < + &led_7seg_gpio 0 0 + &led_7seg_gpio 1 0 + &led_7seg_gpio 2 0 + &led_7seg_gpio 3 0 + &led_7seg_gpio 4 0 + &led_7seg_gpio 5 0 + &led_7seg_gpio 6 0 + &led_7seg_gpio 7 0>; + }; +}; diff --git a/arch/arm/dts/armada-385-atl-x530DP.dtsi b/arch/arm/dts/armada-385-atl-x530DP.dtsi new file mode 100644 index 000000000000..977eb4ee54fe --- /dev/null +++ b/arch/arm/dts/armada-385-atl-x530DP.dtsi @@ -0,0 +1,149 @@ +// SPDX-License-Identifier: GPL-2.0 + +&i2c0 { + mux@71 { + compatible = "nxp,pca9548"; + + i2c@1 { + hwmon@2c { + compatible = "ti,lm87"; + reg = <0x2c>; + }; + + hwmon@2d { + compatible = "ti,lm87"; + reg = <0x2d>; + }; + + hwmon@2e { + pwm-polarity = <1>; + }; + }; + + psu_a_adapter: i2c@4 { + #address-cells = <1>; + #size-cells = <0>; + reg = <4>; + }; + + psu_b_adapter: i2c@5 { + #address-cells = <1>; + #size-cells = <0>; + reg = <5>; + }; + + i2c@6 { + #address-cells = <1>; + #size-cells = <0>; + reg = <6>; + + misc_gpio: gpio@26 { + compatible = "nxp,pca9555"; + gpio-controller; + #gpio-cells = <2>; + reg = <0x26>; + interrupt-parent = <&gpio0>; + interrupts = <5 IRQ_TYPE_LEVEL_LOW>; + status = "okay"; + interrupt-controller; + #interrupt-cells = <2>; + + psu_bank2 { + gpio-hog; + gpios = <0 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "psu-bank2"; + }; + }; + }; + }; +}; + +/ { + psu_slot_a { + compatible = "atl,dts-overlay-gpio-psu-slot"; + slot-name = "PSU Bay A"; + board-index = <1>; + present-gpio = <&misc_gpio 1 GPIO_ACTIVE_LOW>; + output-ok-gpio = <&gpio1 16 GPIO_ACTIVE_HIGH>; + interrupt-parent = <&misc_gpio>; + interrupts = <1 IRQ_TYPE_EDGE_BOTH>; + overlay = <&psu_a_overlay>; + }; + + psu_slot_b { + compatible = "atl,dts-overlay-gpio-psu-slot"; + slot-name = "PSU Bay B"; + board-index = <2>; + present-gpio = <&misc_gpio 2 GPIO_ACTIVE_LOW>; + output-ok-gpio = <&gpio1 22 GPIO_ACTIVE_HIGH>; + interrupt-parent = <&misc_gpio>; + interrupts = <2 IRQ_TYPE_EDGE_BOTH>; + overlay = <&psu_b_overlay>; + }; + + fan_slot_a { + compatible = "atl,fan05-slot"; + slot-name = "Fan Bay A"; + board-index = <3>; + present-gpio = <&misc_gpio 3 GPIO_ACTIVE_LOW>; + fault-gpio = <&misc_gpio 11 GPIO_ACTIVE_LOW>; + interrupt-parent = <&misc_gpio>; + interrupts = <3 IRQ_TYPE_EDGE_BOTH>; + overlay = <&fan_a_overlay>; + }; +}; + +/ { + psu_a_overlay: psu_a { + fragment@0 { + target = <&psu_a_adapter>; + __overlay__ { + #address-cells = <1>; + #size-cells = <0>; + + psu@51 { + compatible = "atl,atl-pwr-gen2"; + reg = <0x51>; + board-index = <1>; + }; + }; + }; + }; +}; + +/ { + psu_b_overlay: psu_b { + fragment@0 { + target = <&psu_b_adapter>; + __overlay__ { + #address-cells = <1>; + #size-cells = <0>; + + psu@51 { + compatible = "atl,atl-pwr-gen2"; + reg = <0x51>; + board-index = <2>; + }; + }; + }; + }; +}; + +/ { + fan_a_overlay:fan_a { + fragment@1 { + target-path = "/"; + __overlay__ { + fan@1 { + compatible = "atl,fan05"; + board-index = <3>; + module-id-gpios = + <&misc_gpio 4 GPIO_ACTIVE_HIGH>, + <&misc_gpio 5 GPIO_ACTIVE_HIGH>, + <&misc_gpio 6 GPIO_ACTIVE_HIGH>; + }; + }; + }; + }; +}; diff --git a/arch/arm/mach-mvebu/Kconfig b/arch/arm/mach-mvebu/Kconfig index d1f71338ac2a..7dda04e0e34e 100644 --- a/arch/arm/mach-mvebu/Kconfig +++ b/arch/arm/mach-mvebu/Kconfig @@ -132,6 +132,10 @@ config TARGET_CONTROLCENTERDC bool "Support CONTROLCENTERDC" select 88F6820
+config TARGET_X530 + bool "Support Allied Telesis x530" + select 88F6820 + endchoice
config SYS_BOARD @@ -149,6 +153,7 @@ config SYS_BOARD default "maxbcm" if TARGET_MAXBCM default "theadorable" if TARGET_THEADORABLE default "a38x" if TARGET_CONTROLCENTERDC + default "x530" if TARGET_X530
config SYS_CONFIG_NAME default "clearfog" if TARGET_CLEARFOG @@ -165,6 +170,7 @@ config SYS_CONFIG_NAME default "turris_omnia" if TARGET_TURRIS_OMNIA default "turris_mox" if TARGET_TURRIS_MOX default "controlcenterdc" if TARGET_CONTROLCENTERDC + default "x530" if TARGET_X530
config SYS_VENDOR default "Marvell" if TARGET_DB_MV784MP_GP @@ -179,6 +185,7 @@ config SYS_VENDOR default "CZ.NIC" if TARGET_TURRIS_OMNIA default "CZ.NIC" if TARGET_TURRIS_MOX default "gdsys" if TARGET_CONTROLCENTERDC + default "alliedtelesis" if TARGET_X530
config SYS_SOC default "mvebu" diff --git a/board/alliedtelesis/common/gpio_hog.c b/board/alliedtelesis/common/gpio_hog.c new file mode 100644 index 000000000000..1f87b3ac1b72 --- /dev/null +++ b/board/alliedtelesis/common/gpio_hog.c @@ -0,0 +1,36 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2018 Allied Telesis Labs + */ + +#include <common.h> +#include <dm.h> +#include <asm/gpio.h> + +DECLARE_GLOBAL_DATA_PTR; + +int gpio_hog_list(struct gpio_desc *gpiod, int max_count, + const char *node_name, const char *gpio_name, int value) +{ + int node; + int count; + int i; + + node = fdt_node_offset_by_compatible(gd->fdt_blob, 0, node_name); + if (node < 0) + return -ENODEV; + + if (!dm_gpio_is_valid(gpiod)) { + count = + gpio_request_list_by_name_nodev(offset_to_ofnode(node), + gpio_name, gpiod, max_count, + GPIOD_IS_OUT); + if (count < 0) + return count; + + for (i = 0; i < count; i++) + dm_gpio_set_value(&gpiod[i], value); + } + + return 0; +} diff --git a/board/alliedtelesis/common/gpio_hog.h b/board/alliedtelesis/common/gpio_hog.h new file mode 100644 index 000000000000..edb744313186 --- /dev/null +++ b/board/alliedtelesis/common/gpio_hog.h @@ -0,0 +1,13 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2017 Allied Telesis Labs + */ + +int gpio_hog_list(struct gpio_desc *gpiod, int max_count, const char *node_name, + const char *gpio_name, int value); + +static inline int gpio_hog(struct gpio_desc *gpiod, const char *node_name, + const char *gpio_name, int value) +{ + return gpio_hog_list(gpiod, 1, node_name, gpio_name, value); +} diff --git a/board/alliedtelesis/x530/MAINTAINERS b/board/alliedtelesis/x530/MAINTAINERS new file mode 100644 index 000000000000..8d2d7271b92c --- /dev/null +++ b/board/alliedtelesis/x530/MAINTAINERS @@ -0,0 +1,12 @@ +x530 BOARD +M: Chris Packham chris.packham@alliedtelesis.co.nz +S: Maintained +F: board/alliedtelesis/x530/ +F: board/alliedtelesis/common/gpio_hog.c +F: board/alliedtelesis/common/gpio_hog.h +F: arch/arm/dts/armada-385-atl-x530.dts +F: arch/arm/dts/armada-385-atl-x530.dtsi +F: arch/arm/dts/armada-385-atl-x530DP.dts +F: arch/arm/dts/armada-385-atl-x530DP.dtsi +F: include/configs/x530.h +F: configs/x530_defconfig diff --git a/board/alliedtelesis/x530/Makefile b/board/alliedtelesis/x530/Makefile new file mode 100644 index 000000000000..97de1d463fe8 --- /dev/null +++ b/board/alliedtelesis/x530/Makefile @@ -0,0 +1,9 @@ +# SPDX-License-Identifier: GPL-2.0+ +# +# Copyright (C) 2017 Allied Telesis Labs +# + +obj-y := $(BOARD).o +ifndef CONFIG_SPL_BUILD +obj-y += ../common/gpio_hog.o +endif diff --git a/board/alliedtelesis/x530/kwbimage.cfg b/board/alliedtelesis/x530/kwbimage.cfg new file mode 100644 index 000000000000..f58d388825e7 --- /dev/null +++ b/board/alliedtelesis/x530/kwbimage.cfg @@ -0,0 +1,12 @@ +# +# Copyright (C) 2017 Allied Telesis Labs +# + +# Armada XP uses version 1 image format +VERSION 1 + +# Boot Media configurations +BOOT_FROM spi + +# Binary Header (bin_hdr) with DDR3 training code +BINARY spl/u-boot-spl-dtb.bin 0000005b 00000068 diff --git a/board/alliedtelesis/x530/x530.c b/board/alliedtelesis/x530/x530.c new file mode 100644 index 000000000000..b34ae5134547 --- /dev/null +++ b/board/alliedtelesis/x530/x530.c @@ -0,0 +1,161 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Copyright (C) 2017 Allied Telesis Labs + */ + +#include <common.h> +#include <command.h> +#include <dm.h> +#include <i2c.h> +#include <asm/gpio.h> +#include <linux/mbus.h> +#include <linux/io.h> +#include <asm/arch/cpu.h> +#include <asm/arch/soc.h> +#include "../common/gpio_hog.h" + +#include "../drivers/ddr/marvell/a38x/ddr3_init.h" +#include <../serdes/a38x/high_speed_env_spec.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define MVEBU_DEV_BUS_BASE (MVEBU_REGISTER(0x10400)) + +#define CONFIG_NVS_LOCATION 0xf4800000 +#define CONFIG_NVS_SIZE (512 << 10) + +static struct serdes_map board_serdes_map[] = { + {PEX0, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, + {DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {PEX1, SERDES_SPEED_5_GBPS, PEX_ROOT_COMPLEX_X1, 0, 0}, + {DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0}, + {DEFAULT_SERDES, SERDES_SPEED_5_GBPS, SERDES_DEFAULT_MODE, 0, 0} +}; + +int hws_board_topology_load(struct serdes_map **serdes_map_array, u8 *count) +{ + *serdes_map_array = board_serdes_map; + *count = ARRAY_SIZE(board_serdes_map); + return 0; +} + +/* + * Define the DDR layout / topology here in the board file. This will + * be used by the DDR3 init code in the SPL U-Boot version to configure + * the DDR3 controller. + */ +static struct mv_ddr_topology_map board_topology_map = { + DEBUG_LEVEL_ERROR, + 0x1, /* active interfaces */ + /* cs_mask, mirror, dqs_swap, ck_swap X PUPs */ + { { { {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0}, + {0x1, 0, 0, 0} }, + SPEED_BIN_DDR_1866M, /* speed_bin */ + MV_DDR_DEV_WIDTH_16BIT, /* sdram device width */ + MV_DDR_DIE_CAP_4GBIT, /* die capacity */ + MV_DDR_FREQ_933, /* frequency */ + 0, 0, /* cas_l cas_wl */ + MV_DDR_TEMP_LOW, /* temperature */ + MV_DDR_TIM_2T} }, /* timing */ + BUS_MASK_32BIT_ECC, /* subphys mask */ + MV_DDR_CFG_DEFAULT, /* ddr configuration data source */ + { {0} }, /* raw spd data */ + {0} /* timing parameters */ +}; + +struct mv_ddr_topology_map *mv_ddr_topology_map_get(void) +{ + /* Return the board topology as defined in the board code */ + return &board_topology_map; +} + +int board_early_init_f(void) +{ + /* Configure MPP */ + writel(0x00001111, MVEBU_MPP_BASE + 0x00); + writel(0x00000000, MVEBU_MPP_BASE + 0x04); + writel(0x55000000, MVEBU_MPP_BASE + 0x08); + writel(0x55550550, MVEBU_MPP_BASE + 0x0c); + writel(0x55555555, MVEBU_MPP_BASE + 0x10); + writel(0x00100565, MVEBU_MPP_BASE + 0x14); + writel(0x40000000, MVEBU_MPP_BASE + 0x18); + writel(0x00004444, MVEBU_MPP_BASE + 0x1c); + + return 0; +} + +int board_init(void) +{ + /* address of boot parameters */ + gd->bd->bi_boot_params = mvebu_sdram_bar(0) + 0x100; + + /* window for NVS */ + mbus_dt_setup_win(&mbus_state, CONFIG_NVS_LOCATION, CONFIG_NVS_SIZE, + CPU_TARGET_DEVICEBUS_BOOTROM_SPI, CPU_ATTR_DEV_CS1); + + /* DEV_READYn is not needed for NVS, ignore it when accessing CS1 */ + writel(0x00004001, MVEBU_DEV_BUS_BASE + 0xc8); + + return 0; +} + +static int led_7seg_init(unsigned int segments) +{ + int node; + int ret; + int i; + struct gpio_desc desc[8]; + + node = fdt_node_offset_by_compatible(gd->fdt_blob, 0, + "atl,of-led-7seg"); + if (node < 0) + return -ENODEV; + + ret = gpio_request_list_by_name_nodev(offset_to_ofnode(node), + "segment-gpios", desc, + ARRAY_SIZE(desc), GPIOD_IS_OUT); + if (ret < 0) + return ret; + + for (i = 0; i < ARRAY_SIZE(desc); i++) { + ret = dm_gpio_set_value(&desc[i], !(segments & BIT(i))); + if (ret) + return ret; + } + + return 0; +} + +#ifdef CONFIG_MISC_INIT_R +int misc_init_r(void) +{ + static struct gpio_desc usb_en = {}, nand_wp = {}, phy_reset[2] = {}, + led_en = {}; + + gpio_hog(&usb_en, "atl,usb-enable", "enable-gpio", 1); + gpio_hog(&nand_wp, "atl,nand-protect", "protect-gpio", 1); + gpio_hog_list(phy_reset, ARRAY_SIZE(phy_reset), "atl,phy-reset", "reset-gpio", 0); + gpio_hog(&led_en, "atl,led-enable", "enable-gpio", 1); + +#ifdef MTDPARTS_MTDOOPS + env_set("mtdoops", MTDPARTS_MTDOOPS); +#endif + + led_7seg_init(0xff); + + return 0; +} +#endif + +#ifdef CONFIG_DISPLAY_BOARDINFO +int checkboard(void) +{ + puts("Board: " CONFIG_SYS_BOARD "\n"); + + return 0; +} +#endif diff --git a/configs/x530_defconfig b/configs/x530_defconfig new file mode 100644 index 000000000000..22482f8d39be --- /dev/null +++ b/configs/x530_defconfig @@ -0,0 +1,71 @@ +CONFIG_ARM=y +CONFIG_ARCH_MVEBU=y +CONFIG_SYS_TEXT_BASE=0x00800000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_TARGET_X530=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL=y +CONFIG_DEBUG_UART_BASE=0xd0012000 +CONFIG_DEBUG_UART_CLOCK=250000000 +CONFIG_SPL_SPI_FLASH_SUPPORT=y +CONFIG_SPL_SPI_SUPPORT=y +CONFIG_DEBUG_UART=y +CONFIG_NR_DRAM_BANKS=2 +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_SILENT_CONSOLE=y +CONFIG_SILENT_U_BOOT_ONLY=y +CONFIG_SILENT_CONSOLE_UPDATE_ON_RELOC=y +CONFIG_MISC_INIT_R=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_FLASH is not set +CONFIG_CMD_GPIO=y +CONFIG_CMD_I2C=y +CONFIG_CMD_SF=y +CONFIG_CMD_SPI=y +CONFIG_CMD_USB=y +# CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y +CONFIG_CMD_TFTPPUT=y +CONFIG_CMD_MII=y +CONFIG_CMD_PING=y +CONFIG_CMD_CACHE=y +CONFIG_CMD_TIME=y +CONFIG_CMD_EXT2=y +CONFIG_CMD_EXT4=y +CONFIG_CMD_FAT=y +CONFIG_CMD_FS_GENERIC=y +CONFIG_DEFAULT_DEVICE_TREE="armada-385-atl-x530" +CONFIG_ENV_IS_IN_SPI_FLASH=y +CONFIG_SPL_OF_TRANSLATE=y +CONFIG_BLK=y +CONFIG_DM_GPIO=y +CONFIG_DM_I2C=y +CONFIG_SYS_I2C_MVTWSI=y +CONFIG_I2C_MUX=y +CONFIG_I2C_MUX_PCA954x=y +CONFIG_MISC=y +# CONFIG_MMC is not set +CONFIG_NAND=y +CONFIG_NAND_PXA3XX=y +CONFIG_SPI_FLASH=y +CONFIG_SPI_FLASH_BAR=y +CONFIG_SPI_FLASH_MACRONIX=y +CONFIG_SPI_FLASH_STMICRO=y +CONFIG_SPI_FLASH_SST=y +CONFIG_MTD_UBI=y +CONFIG_PCI=y +CONFIG_DM_RTC=y +CONFIG_RTC_DS1307=y +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_SYS_NS16550=y +CONFIG_KIRKWOOD_SPI=y +CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_STORAGE=y +CONFIG_USB_HOST_ETHER=y +CONFIG_USB_ETHER_ASIX=y +CONFIG_USB_ETHER_ASIX88179=y diff --git a/include/configs/x530.h b/include/configs/x530.h new file mode 100644 index 000000000000..a1ef301d35e0 --- /dev/null +++ b/include/configs/x530.h @@ -0,0 +1,134 @@ +/* SPDX-License-Identifier: GPL-2.0+ */ +/* + * Copyright (C) 2018 Allied Telesis Labs + */ + +#ifndef _CONFIG_X530_H +#define _CONFIG_X530_H + +/* + * High Level Configuration Options (easy to change) + */ + +#define CONFIG_DISPLAY_BOARDINFO_LATE + +#define CONFIG_SYS_TCLK 250000000 /* 250MHz */ + +/* + * NS16550 Configuration + */ +#define CONFIG_SYS_NS16550_SERIAL +#define CONFIG_SYS_NS16550_CLK CONFIG_SYS_TCLK +#if !defined(CONFIG_DM_SERIAL) +#define CONFIG_SYS_NS16550_REG_SIZE (-4) +#define CONFIG_SYS_NS16550_COM1 MV_UART_CONSOLE_BASE +#endif + +/* + * Serial Port configuration + * The following definitions let you select what serial you want to use + * for your console driver. + */ + +#define CONFIG_CONS_INDEX 1 /*Console on UART0 */ + +/* + * Commands configuration + */ +#define CONFIG_CMD_PCI + +/* NAND */ +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_MAX_NAND_DEVICE 1 + +#define BBT_CUSTOM_SCAN +#define BBT_CUSTOM_SCAN_PAGE 0 +#define BBT_CUSTOM_SCAN_POSITION 2048 + +/* SPI NOR flash default params, used by sf commands */ +#define CONFIG_SF_DEFAULT_BUS 1 +#define CONFIG_SF_DEFAULT_SPEED 50000000 +#define CONFIG_SF_DEFAULT_MODE SPI_MODE_3 + +#define MTDIDS_DEFAULT "nand0=nand" +#define MTDPARTS_DEFAULT "mtdparts=nand:240M(user),8M(errlog),8M(nand-bbt)" +#define MTDPARTS_MTDOOPS "errlog" + +/* Partition support */ + +/* Additional FS support/configuration */ + +/* USB/EHCI configuration */ +#define CONFIG_EHCI_IS_TDI + +/* Environment in SPI NOR flash */ +#define CONFIG_ENV_SPI_BUS CONFIG_SF_DEFAULT_BUS +#define CONFIG_ENV_SPI_MODE CONFIG_SF_DEFAULT_MODE +#define CONFIG_ENV_OFFSET (1 << 20) /* 1MiB in */ +#define CONFIG_ENV_SIZE (64 << 10) /* 64KiB */ +#define CONFIG_ENV_SECT_SIZE (256 << 10) /* 256KiB sectors */ +#define CONFIG_ENV_ADDR CONFIG_ENV_OFFSET + +#define CONFIG_PHY_MARVELL /* there is a marvell phy */ +#define PHY_ANEG_TIMEOUT 8000 /* PHY needs a longer aneg time */ + +/* PCIe support */ +#ifndef CONFIG_SPL_BUILD +#define CONFIG_PCI_MVEBU +#define CONFIG_PCI_SCAN_SHOW +#endif + +/* NAND */ +#define CONFIG_SYS_NAND_USE_FLASH_BBT +#define CONFIG_SYS_NAND_ONFI_DETECTION +#define CONFIG_CMD_UBI +#define CONFIG_CMD_UBIFS +#define CONFIG_LZO +#define CONFIG_MTD_DEVICE +#define CONFIG_CMD_MTDPARTS + +#define CONFIG_SYS_MALLOC_LEN (4 << 20) + +#include <asm/arch/config.h> + +/* + * Other required minimal configurations + */ +#define CONFIG_ARCH_CPU_INIT /* call arch_cpu_init() */ +#define CONFIG_SYS_RESET_ADDRESS 0xffff0000 /* Rst Vector Adr */ + +#define CONFIG_SYS_ALT_MEMTEST + +/* Keep device tree and initrd in low memory so the kernel can access them */ +#define CONFIG_EXTRA_ENV_SETTINGS \ + "fdt_high=0x10000000\0" \ + "initrd_high=0x10000000\0" + +#define CONFIG_SYS_LOAD_ADDR 0x1000000 +#define CONFIG_UBI_PART user +#define CONFIG_UBIFS_VOLUME user + +/* SPL */ + +/* Defines for SPL */ +#define CONFIG_SPL_SIZE (140 << 10) +#define CONFIG_SPL_TEXT_BASE 0x40000030 +#define CONFIG_SPL_MAX_SIZE (CONFIG_SPL_SIZE - 0x0030) + +#define CONFIG_SPL_BSS_START_ADDR (0x40000000 + CONFIG_SPL_SIZE) +#define CONFIG_SPL_BSS_MAX_SIZE (16 << 10) + +#ifdef CONFIG_SPL_BUILD +#define CONFIG_SYS_MALLOC_SIMPLE +#endif + +#define CONFIG_SPL_STACK (0x40000000 + ((192 - 16) << 10)) +#define CONFIG_SPL_BOOTROM_SAVE (CONFIG_SPL_STACK + 4) + +/* SPL related SPI defines */ +#define CONFIG_SPL_SPI_LOAD +#define CONFIG_SYS_SPI_U_BOOT_OFFS 0x24000 +#define CONFIG_SYS_U_BOOT_OFFS CONFIG_SYS_SPI_U_BOOT_OFFS + +#endif /* _CONFIG_X530_H */
(adding Stefan who I managed to drop from the Cc list)
Changes in v2:
+&spi1 {
spi-flash@0 {
+&uart0 {
nand-protect {
usb-enable {
boot-board {
phy-reset {
led-enable {
led_7seg {
segment-gpios = <
&led_7seg_gpio 0 0
&led_7seg_gpio 1 0
&led_7seg_gpio 2 0
&led_7seg_gpio 3 0
&led_7seg_gpio 4 0
&led_7seg_gpio 5 0
&led_7seg_gpio 6 0
chosen {
aliases {
spi1 = &spi1;
i2c0 = &i2c0;
memory {
soc {
board-reset {
phy-int {
led-enable {
led_7seg {
segment-gpios = <
&led_7seg_gpio 0 0
&led_7seg_gpio 1 0
&led_7seg_gpio 2 0
&led_7seg_gpio 3 0
&led_7seg_gpio 4 0
&led_7seg_gpio 5 0
&led_7seg_gpio 6 0
poe {
+&pciec {
status = "okay";
+&pcie1 {
status = "okay";
+&devbus_cs1 {
status = "okay";
nvs@0 {
status = "okay";
bank-width = <1>;
label = "nvs";
+&gpio0 {
poe-disable {
gpio-hog;
output-high;
+&gpio1 {
poe-mezz-reset {
gpio-hog;
output-high;
+&i2c0 {
status = "okay";
mux@71 {
#size-cells = <0>;
reg = <0x71>;
#size-cells = <0>;
reg = <0>;
i2c@1 {
#size-cells = <0>;
reg = <1>;
rng@3b {
reg = <0x3b>;
hwmon@2e {
reg = <0x2e>;
hwmon@2d {
reg = <0x2d>;
i2c@2 {
#size-cells = <0>;
reg = <2>;
rtc@68 {
reg = <0x68>;
i2c@3 {
#size-cells = <0>;
reg = <3>;
gpio-controller;
#gpio-cells = <2>;
reg = <0x20>;
gpio-controller;
#gpio-cells = <2>;
reg = <0x27>;
#size-cells = <0>;
reg = <0x77>;
+&spi1 {
status = "okay";
spi-flash@0 {
#size-cells = <1>;
m25p,fast-read;
partition@u-boot {
label = "u-boot";
partition@unused {
label = "unused";
partition@idprom {
label = "idprom";
+&uart0 {
status = "okay";
+&usb0 {
status = "okay";
+&refclk {
status = "okay";
num-cs = <1>;
nand-on-flash-bbt;
nand-protect {
usb-enable {
boot-board {
phy-reset {
led-enable {
led_7seg {
segment-gpios = <
&led_7seg_gpio 0 0
&led_7seg_gpio 1 0
&led_7seg_gpio 2 0
&led_7seg_gpio 3 0
&led_7seg_gpio 4 0
&led_7seg_gpio 5 0
&led_7seg_gpio 6 0
+&i2c0 {
mux@71 {
i2c@1 {
hwmon@2c {
reg = <0x2c>;
hwmon@2d {
reg = <0x2d>;
hwmon@2e {
pwm-polarity = <1>;
#size-cells = <0>;
reg = <4>;
#size-cells = <0>;
reg = <5>;
i2c@6 {
#size-cells = <0>;
reg = <6>;
gpio-controller;
#gpio-cells = <2>;
reg = <0x26>;
status = "okay";
psu_bank2 {
gpio-hog;
output-high;
psu_slot_a {
board-index = <1>;
psu_slot_b {
board-index = <2>;
fan_slot_a {
board-index = <3>;
fragment@0 {
__overlay__ {
#size-cells = <0>;
psu@51 {
reg = <0x51>;
board-index = <1>;
fragment@0 {
__overlay__ {
#size-cells = <0>;
psu@51 {
reg = <0x51>;
board-index = <2>;
fragment@1 {
target-path = "/";
__overlay__ {
fan@1 {
board-index = <3>;
module-id-gpios =
+config TARGET_X530
select 88F6820
endchoice
- Copyright (C) 2018 Allied Telesis Labs
int node;
int count;
int i;
if (node < 0)
return -ENODEV;
count =
GPIOD_IS_OUT);
if (count < 0)
return count;
- Copyright (C) 2017 Allied Telesis Labs
- Define the DDR layout / topology here in the board file. This will
- be used by the DDR3 init code in the SPL U-Boot version to configure
- the DDR3 controller.
DEBUG_LEVEL_ERROR,
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0},
{0x1, 0, 0, 0} },
/* Configure MPP */
int node;
int ret;
int i;
"atl,of-led-7seg");
if (node < 0)
return -ENODEV;
if (ret < 0)
return ret;
if (ret)
return ret;
led_en = {};
+} +#endif
- High Level Configuration Options (easy to change)
- NS16550 Configuration
- Serial Port configuration
- The following definitions let you select what serial you want to use
- for your console driver.
- Commands configuration
- Other required minimal configurations
+/* SPL */
2.20.1
Changes in v2:
Applied to u-boot-marvell/master
Thanks, Stefan
Chris Packham
Stefan Roese
