[PATCH v3] board:pm9261 - Remove network support
The network support is removed because there is no DM for Davicom DM9000.
Signed-off-by: Ilko Iliev iliev@ronetix.at --- board/ronetix/pm9261/pm9261.c | 54 ----------------------------------- configs/pm9261_defconfig | 4 +-- include/configs/pm9261.h | 9 ------ 3 files changed, 2 insertions(+), 65 deletions(-)
diff --git a/board/ronetix/pm9261/pm9261.c b/board/ronetix/pm9261/pm9261.c index 5be2c5e192..fe52c7c176 100644 --- a/board/ronetix/pm9261/pm9261.c +++ b/board/ronetix/pm9261/pm9261.c @@ -20,10 +20,6 @@ #include <asm/arch/at91_matrix.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> -#if defined(CONFIG_RESET_PHY_R) && defined(CONFIG_DRIVER_DM9000) -#include <net.h> -#endif -#include <netdev.h> #include <asm/mach-types.h>
DECLARE_GLOBAL_DATA_PTR; @@ -80,36 +76,6 @@ static void pm9261_nand_hw_init(void) } #endif
- -#ifdef CONFIG_DRIVER_DM9000 -static void pm9261_dm9000_hw_init(void) -{ - struct at91_smc *smc = (struct at91_smc *)ATMEL_BASE_SMC; - - /* Configure SMC CS2 for DM9000 */ - writel(AT91_SMC_SETUP_NWE(2) | AT91_SMC_SETUP_NCS_WR(0) | - AT91_SMC_SETUP_NRD(2) | AT91_SMC_SETUP_NCS_RD(0), - &smc->cs[2].setup); - - writel(AT91_SMC_PULSE_NWE(4) | AT91_SMC_PULSE_NCS_WR(8) | - AT91_SMC_PULSE_NRD(4) | AT91_SMC_PULSE_NCS_RD(8), - &smc->cs[2].pulse); - - writel(AT91_SMC_CYCLE_NWE(16) | AT91_SMC_CYCLE_NRD(16), - &smc->cs[2].cycle); - - writel(AT91_SMC_MODE_RM_NRD | AT91_SMC_MODE_WM_NWE | - AT91_SMC_MODE_EXNW_DISABLE | - AT91_SMC_MODE_BAT | AT91_SMC_MODE_DBW_16 | - AT91_SMC_MODE_TDF_CYCLE(1), - &smc->cs[2].mode); - - /* Configure Interrupt pin as input, no pull-up */ - at91_periph_clk_enable(ATMEL_ID_PIOA); - at91_set_pio_input(AT91_PIO_PORTA, 24, 0); -} -#endif - int board_early_init_f(void) { return 0; @@ -132,13 +98,6 @@ int board_init(void) return 0; }
-#ifdef CONFIG_DRIVER_DM9000 -int board_eth_init(struct bd_info *bis) -{ - return dm9000_initialize(bis); -} -#endif - int dram_init(void) { /* dram_init must store complete ramsize in gd->ram_size */ @@ -155,19 +114,6 @@ int dram_init_banksize(void) return 0; }
-#ifdef CONFIG_RESET_PHY_R -void reset_phy(void) -{ -#ifdef CONFIG_DRIVER_DM9000 - /* - * Initialize ethernet HW addr prior to starting Linux, - * needed for nfsroot - */ - eth_init(); -#endif -} -#endif - #ifdef CONFIG_DISPLAY_BOARDINFO int checkboard (void) { diff --git a/configs/pm9261_defconfig b/configs/pm9261_defconfig index e0a2ae18c6..b27fc8dbc1 100644 --- a/configs/pm9261_defconfig +++ b/configs/pm9261_defconfig @@ -25,8 +25,6 @@ CONFIG_SYS_PROMPT="pm9261> " CONFIG_CMD_NAND=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set -CONFIG_CMD_DHCP=y -CONFIG_CMD_PING=y CONFIG_CMD_CACHE=y CONFIG_MTDIDS_DEFAULT="nor0=physmap-flash.0,nand0=nand" CONFIG_MTDPARTS_DEFAULT="mtdparts=physmap-flash.0:256k(u-boot)ro,64k(u-boot-env)ro,1408k(kernel),-(rootfs);nand:-(nand)" @@ -34,6 +32,7 @@ CONFIG_OF_CONTROL=y CONFIG_ENV_OVERWRITE=y CONFIG_ENV_IS_IN_FLASH=y CONFIG_ENV_ADDR=0x10040000 +# CONFIG_NET is not set CONFIG_DM=y CONFIG_BLK=y CONFIG_CLK=y @@ -62,3 +61,4 @@ CONFIG_USB_STORAGE=y CONFIG_DM_VIDEO=y # CONFIG_VIDEO_BPP32 is not set CONFIG_LCD=y +CONFIG_REGEX=y diff --git a/include/configs/pm9261.h b/include/configs/pm9261.h index 2cc47d1237..382d19a241 100644 --- a/include/configs/pm9261.h +++ b/include/configs/pm9261.h @@ -173,15 +173,6 @@ #define CONFIG_SYS_MAX_FLASH_SECT 256 #define CONFIG_SYS_MAX_FLASH_BANKS 1
-/* Ethernet */ -#define CONFIG_DRIVER_DM9000 1 -#define CONFIG_DM9000_BASE 0x30000000 -#define DM9000_IO CONFIG_DM9000_BASE -#define DM9000_DATA (CONFIG_DM9000_BASE + 4) -#define CONFIG_DM9000_USE_16BIT 1 -#define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_RESET_PHY_R 1 - /* USB */ #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_PLLB -- 2.25.1
Applied with minor commit message change to u-boot-atmel/next, thanks !
Eugen.Hristev@microchip.com
Ilko Iliev
