[PATCH 0/7] riscv: Correctly handle IPIs already pending upon boot
On the K210, the prior stage bootloader does not clear IPIs. This presents a problem, because U-Boot up until this point assumes (with one exception) that IPIs are cleared when it starts. This series attempts to fix this in a robust manner, and fix several concurrency bugs I noticed while fixing these other areas. Heinrich previously submitted a patch addressing part of this problem in [1].
[1] https://patchwork.ozlabs.org/project/uboot/patch/20200811035648.3284-1-xypro...
Sean Anderson (7): Revert "riscv: Clear pending interrupts before enabling IPIs" riscv: Match memory barriers between send_ipi_many and handle_ipi riscv: Use NULL as a sentinel value for smp_call_function riscv: Clear pending IPIs on initialization riscv: Add fence to available_harts_lock riscv: Ensure gp is NULL or points to valid data riscv: Add some comments to start.S
arch/riscv/cpu/cpu.c | 18 ++++++++++++++ arch/riscv/cpu/start.S | 47 +++++++++++++++++++++++++++++-------- arch/riscv/lib/interrupts.c | 3 ++- arch/riscv/lib/smp.c | 26 +++++++++++++++++--- 4 files changed, 80 insertions(+), 14 deletions(-)
Clearing MIP doesn't do anything. Whoops. The following commits should tackle this problem in a more robust manner.
This reverts commit 9472630337e7c4ac442066b5a752aaa8c3b4d4a6.
Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/riscv/cpu/start.S | 2 -- 1 file changed, 2 deletions(-)
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index bf9fdf369b..e3222b1ea7 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -65,8 +65,6 @@ _start: #else li t0, SIE_SSIE #endif - /* Clear any pending IPIs */ - csrc MODE_PREFIX(ip), t0 csrs MODE_PREFIX(ie), t0 #endif
Hi Sean
I still not catch your points about that this commit 947263033 really help to fix pending IPIs not clean problem on k210 platform at that time, but you just said it do nothing and remove it here currently.
Thanks, Rick
#endif
-- 2.28.0
On 9/9/20 3:50 AM, Rick Chen wrote:
Hi Sean
After refactoring the original smp patch to remove the null check, I neglected to re-test with a debug uart enabled. Without doing that test, it is impossible to catch the pending IPI bug. The secondary hart will crash before the serial driver is initialized. I didn't do that test at the time, because I was mostly worried about the secondary hart corrupting the device tree and causing the boot to fail. That failure mode was fixed by 40686c394. So I saw that and thought that the pending IPI issue was solved as well.
--Sean
#endif
-- 2.28.0
Hi Sean
Hi Sean
Can you describe more clearly why with a debug uart enabled will trigger the pending IPI bug ?
And why the pending IPI be raised and not clear before jump to U-Boot ?
Why the csrc MODE_PREFIX(ip), t0 don't help to fix this bug ?
Thanks, Rick
--Sean
#endif
-- 2.28.0
On 9/10/20 2:39 AM, Rick Chen wrote:
Hi Sean
Hi Sean
It doesn't trigger the bug, it always happens. However, if there is no debug uart nothing gets printed, because it occurs before the serial driver is initialized.
I don't know. Presumably the boot rom raises it to signal to jump to U-Boot and never clears it.
The problem is that MSIP in MIP is not necessarily writable.
Each lower privilege level has a separate software interrupt-pending bit (HSIP, SSIP, USIP), which can be both read and written by CSR accesses from code running on the local hart at the associated or any higher privilege level. The machine-level MSIP bits are written by accesses to memory- mapped control registers, which are used by remote harts to provide machine-mode interprocessor interrupts. Interprocessor interrupts for lower privilege levels are implemented through ABI, SBI or HBI calls to the AEE, SEE or HEE respectively, which might ultimately result in a machine- mode write to the receiving hart’s MSIP bit. A hart can write its own MSIP bit using the same memory-mapped control register.
Contrast for example with SSIP in SIP
Three types of interrupts are defined: software interrupts, timer interrupts, and external interrupts. A supervisor-level software interrupt is triggered on the current hart by writing 1 to its supervisor software interrupt-pending (SSIP) bit in the sip register. A pending supervisor-level software interrupt can be cleared by writing 0 to the SSIP bit in sip. Supervisor-level software interrupts are disabled when the SSIE bit in the sie register is clear.
I originally added this at your suggestion, but I never ended up testing it separately from the IPI cleanup patch.
--Sean
Hi Sean,
Which following commits?
Did you mean the clearing MIP.MSIP actually does nothing, but the following commit is the correct fix?
commit 40686c394e533fec765fe237936e353c84e73fff Author: Sean Anderson seanga2@gmail.com Date: Wed Jun 24 06:41:18 2020 -0400
riscv: Clean up IPI initialization code
The previous IPI code initialized the device whenever the first call was made to a riscv_*_ipi function. This made it difficult to determine when the IPI device was initialized. This patch introduces a new function riscv_init_ipi. It is called once during arch_cpu_init_dm. In SPL, it is called in spl_invoke_opensbi. Before this point, no riscv_*_ipi functions should be called.
Signed-off-by: Sean Anderson seanga2@gmail.com Reviewed-by: Rick Chen rick@andestech.com
#endif
Regards, Bin
On 9/11/20 3:38 AM, Bin Meng wrote:
Hi Sean,
Yes, but we also need
[PATCH 3/7] riscv: Use NULL as a sentinel value for smp_call_function
so the secondary harts know not to take any IPIs not raised by U-Boot.
riscv: Clean up IPI initialization code The previous IPI code initialized the device whenever the first call was made to a riscv_*_ipi function. This made it difficult to determine when the IPI device was initialized. This patch introduces a new function riscv_init_ipi. It is called once during arch_cpu_init_dm. In SPL, it is called in spl_invoke_opensbi. Before this point, no riscv_*_ipi functions should be called. Signed-off-by: Sean Anderson <seanga2@gmail.com> Reviewed-by: Rick Chen <rick@andestech.com>
#endif
--Sean
Hi Sean,
Is MIP.MSIP read-only on K210?
#endif
Regards, Bin
Hi Sean,
I think so. See [1] where only ssip, stip, and seip are written (and new_mip is not otherwise used). The spec doesn't require MIP.MSIP to be writable at all.
--Sean
[1] https://github.com/chipsalliance/rocket-chip/blob/master/src/main/scala/rock...
HI Sean
Hi Sean,
Since clear mip will not affect anything in K210 and it is writable for other RISC-V platforms. I will prefer to keep this instruction stay here for standard startup initialization.
Thanks, Rick
--Sean
On 9/13/20 11:10 PM, Rick Chen wrote:
HI Sean
Hi Sean,
Does it do anything for other RISC-V platforms? I checked the manuals for the Sifive fu540 and fe310 and the Nuclei Bumblebee (the core Gigadevice's GD32VF103 series), and none of them do anything with writes to MIP. Does Andes do anything with writes in their cores? At the very least I think the comment should be changed so as not to mislead readers.
I would prefer not to, since the rest of this series should handle the original intent of this commit in a much more robust manner.
--Sean
Without a matching barrier on the write side, the barrier in handle_ipi does nothing. It was entirely possible for the boot hart to write to addr, arg0, and arg1 *after* sending the IPI, because there was no barrier on the sending side.
Fixes: 90ae28143700bae4edd23930a7772899ad259058 Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/riscv/lib/smp.c | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index ac22136314..ab6d8bd7fa 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -54,6 +54,8 @@ static int send_ipi_many(struct ipi_data *ipi, int wait) gd->arch.ipi[reg].arg0 = ipi->arg0; gd->arch.ipi[reg].arg1 = ipi->arg1;
+ __smp_mb(); + ret = riscv_send_ipi(reg); if (ret) { pr_err("Cannot send IPI to hart %d\n", reg);
nits: wrong format of Fixes tag
__smp_mb();
Reviewed-by: Bin Meng bin.meng@windriver.com
Regards, Bin
Some IPIs may already be pending when U-Boot is started. This could be a problem if a secondary hart tries to handle an IPI before the boot hart has initialized the IPI device.
This commit uses NULL as a sentinel for secondary harts so they know when the IPI is initialized, and it is safe to use the IPI API. The smp addr parameter is initialized to NULL by board_init_f_init_reserve. Before this, secondary harts wait in wait_for_gd_init.
This imposes a minor restriction because harts may no longer jump to NULL. However, given that the RISC-V debug device is likely to be located at 0x400, it is unlikely for any RISC-V implementation to have usable ram located at 0x0.
arch/riscv/lib/smp.c | 26 ++++++++++++++++++++++---- 1 file changed, 22 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/lib/smp.c b/arch/riscv/lib/smp.c index ab6d8bd7fa..8c25755330 100644 --- a/arch/riscv/lib/smp.c +++ b/arch/riscv/lib/smp.c @@ -18,6 +18,12 @@ static int send_ipi_many(struct ipi_data *ipi, int wait) u32 reg; int ret, pending;
+ /* NULL is used as a sentinel value */ + if (!ipi->addr) { + pr_err("smp_function cannot be set to 0x0\n"); + return -EINVAL; + } + cpus = ofnode_path("/cpus"); if (!ofnode_valid(cpus)) { pr_err("Can't find cpus node!\n"); @@ -50,11 +56,16 @@ static int send_ipi_many(struct ipi_data *ipi, int wait) continue; #endif
- gd->arch.ipi[reg].addr = ipi->addr; gd->arch.ipi[reg].arg0 = ipi->arg0; gd->arch.ipi[reg].arg1 = ipi->arg1;
- __smp_mb(); + /* + * Ensure addr only becomes non-NULL when arg0 and arg1 are + * valid. An IPI may already be pending on other harts, so we + * need a way to signal that the IPI device has been + * initialized, and that it is ok to call the function. + */ + __smp_store_release(&gd->arch.ipi[reg].addr, ipi->addr);
ret = riscv_send_ipi(reg); if (ret) { @@ -83,9 +94,16 @@ void handle_ipi(ulong hart) if (hart >= CONFIG_NR_CPUS) return;
- __smp_mb(); + smp_function = (void (*)(ulong, ulong, ulong)) + __smp_load_acquire(&gd->arch.ipi[hart].addr); + /* + * If the function is NULL, then U-Boot has not requested the IPI. The + * IPI device may not be initialized, so all we can do is wait for + * U-Boot to initialize it and send an IPI + */ + if (!smp_function) + return;
- smp_function = (void (*)(ulong, ulong, ulong))gd->arch.ipi[hart].addr; invalidate_icache_all();
Hi Sean
The ram location of AE350 is at 0x0.
if (!ipi->addr) {
return -EINVAL;
This conflict with memory configurations of AE350. Please check about doc\board\AndesTech\ax25-ae350.rst, and you can find BBL is configured as zero address on AE350 platform.
__smp_mb();
It is too tricky and hack by using zero address to be a signal for the other pending harts waiting the IPI device been initialized.
__smp_mb();
if (!smp_function)
return;
It will boot BBL+Kernel payload fail here on AE350 platforms with this check.
Thanks, Rick
smp_function = (void (*)(ulong, ulong, ulong))gd->arch.ipi[hart].addr; invalidate_icache_all(); /*
-- 2.28.0
Hi Sean
Hi Sean
if (!ipi->addr) {
return -EINVAL;
__smp_mb();
Why do you add this in [PATCH 2/7] but remove it in [PATCH 3/7] ?
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
On 9/9/20 5:01 AM, Rick Chen wrote:
Hi Sean
Hi Sean
Huh. Does it not have a debug device?
if (!ipi->addr) {
return -EINVAL;
Ok, that is a strange choice because any accidental NULL-pointer dereference turns into code modification. In the next revision, I will add an arch.ipi[reg].valid variable for the same prupose, instead of re-using addr.
__smp_mb();
Because conceptually, patch 2 is independent of this patch. It is still a bug even if this patch is not applied. I think by making this change over two patches, it is more obvious why the barrier was added, and then weakened, as opposed to if I made the change in one patch.
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
Hi Sean
Hi Sean
Wouldn't it make sense to use an odd value (e.g. (void *)-1UL) instead NULL as sentinal value? RISC-V code addresses are always even.
Best regards
Heinrich
if (!ipi->addr) {
return -EINVAL;
__smp_mb();
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
Hi Sean
Hi Sean
Well, the advantage of NULL is that it gets set when gd gets initialized, so we don't have to do anything else. On the K210, we are effectively already using it as a sentinel value for this reason (except then we jump to it and crash).
To implement your suggestion, we would have to add something like
void riscv_early_ipi_init(void) { int i;
for (i = 0; i < CONFIG_NR_CPUS; i++) gd->arch.ipi[i].addr = -1; }
and call that after board_init_f_init_reserve but before releasing available_harts_lock.
--Sean
Best regards
Heinrich
if (!ipi->addr) {
return -EINVAL;
__smp_mb();
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
Hi Sean
Hi Sean
Hi Sean
No, our debug device is not in here.
if (!ipi->addr) {
return -EINVAL;
__smp_mb();
OK. Thanks for explanations.
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
Hi Sean
Hi Sean
Hi Sean
if (!ipi->addr) {
return -EINVAL;
Adding arch.ipi[reg].valid instead of re-using addr is OK for me.
Thanks, Rick
__smp_mb();
Thanks, Rick
__smp_mb();
if (!smp_function)
return;
Thanks, Rick
-- 2.28.0
Hi Bin,
There is a series of follow-up discussion on this patch that you might miss reading.
This current patch will cause AE350 to fail booting,
so maybe we should wait until Sean's next patch comes up to consider a reviewed-by tag.
Leo
Hi Leo,
Hi Bin,
Do we know why AE350 fails to boot with this patch?
If some big changes are reworked in newer patches, I believe author should remove the tag and re-request the review.
Regards, Bin
Hi, Bin On Mon, Sep 14, 2020 at 10:07:57AM +0800, Bin Meng wrote:
Hi Leo,
Hi Bin,
When booting with bootm command, boot hart will use smp_call_function(addr, arg0, arg1) to tell other harts to jump to "addr", and other hart will use handle_ipi() to get the "addr".
The address of bbl+kernel payload when booting with AE350 is at 0x0, so the "addr" would be 0x0 that other harts have to jump to.
With this patch
these two code snippets would cause u-boot to hang and thus fail the booting process.
Oh I see! Thanks for the explanation.
Regards, Bin
Best, Leo
Hi Leo,
Hi Leo,
Hi Bin,
Thanks for the info! It's weird that AE350 has set the kernel boot entry at address 0.
With this patch
if (!ipi->addr) {
return -EINVAL;
if (!smp_function)
return;
Regards, Bin
Per Leo's comments, I will not include this tag in the next revision, as it uses a different mechanism to accomplish this behavior.
--Sean
Even though we no longer call smp_function if an IPI was not sent by U-Boot, we still need to clear any IPIs which were pending from the execution environment. Otherwise, secondary harts will busy-wait in secondary_hart_loop, instead of relaxing.
arch/riscv/cpu/cpu.c | 18 ++++++++++++++++++ 1 file changed, 18 insertions(+)
diff --git a/arch/riscv/cpu/cpu.c b/arch/riscv/cpu/cpu.c index bfa2d4a426..ad94744c0f 100644 --- a/arch/riscv/cpu/cpu.c +++ b/arch/riscv/cpu/cpu.c @@ -72,6 +72,15 @@ static int riscv_cpu_probe(void) return 0; }
+/* + * This is called on secondary harts just after the IPI is init'd. Currently + * there's nothing to do, since we just need to clear any existing IPIs, and + * that is handled by the sending of an ipi itself. + */ +void riscv_ipi_init_secondary_hart(ulong hart, ulong arg0, ulong arg1) +{ +} + int arch_cpu_init_dm(void) { int ret; @@ -111,6 +120,15 @@ int arch_cpu_init_dm(void) ret = riscv_init_ipi(); if (ret) return ret; + + /* + * Clear all pending IPIs on secondary harts. We don't do anything on + * the boot hart, since we never send an IPI to ourselves, and no + * interrupts are enabled + */ + ret = smp_call_function((ulong)riscv_ipi_init_secondary_hart, 0, 0, 0); + if (ret) + return ret; #endif
Without these fences, it is perfectly valid for an out-of-order core to re-order memory accesses to outside of the available_harts_lock critical section.
arch/riscv/cpu/start.S | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index e3222b1ea7..ad18e746b6 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -126,12 +126,12 @@ call_board_init_f_0: #ifndef CONFIG_XIP la t0, available_harts_lock fence rw, w - amoswap.w zero, zero, 0(t0) + amoswap.w.rl zero, zero, 0(t0)
wait_for_gd_init: la t0, available_harts_lock li t1, 1 -1: amoswap.w t1, t1, 0(t0) +1: amoswap.w.aq t1, t1, 0(t0) fence r, rw bnez t1, 1b
@@ -143,7 +143,7 @@ wait_for_gd_init: SREG t2, GD_AVAILABLE_HARTS(gp)
/* * Continue on hart lottery winner, others branch to
Hi Sean
fence rw, w can also be removed.
fence r, rw can also be removed.
bnez t1, 1b
fence rw, w
Thanks, Rick
amoswap.w.rl zero, zero, 0(t0) /* * Continue on hart lottery winner, others branch to
-- 2.28.0
On 9/9/20 11:26 PM, Rick Chen wrote:
Hi Sean
Hmm. Actually, upon reading the spec I noticed this paragraph
To help implement multiprocessor synchronization, the AMOs optionally provide release consistency semantics. If the aq bit is set, then no later memory operations in this RISC-V hart can be observed to take place before the AMO. Conversely, if the rl bit is set, then other RISC-V harts will not observe the AMO before memory accesses preceding the AMO in this RISC-V hart. Setting both the aq and the rl bit on an AMO makes the sequence sequentially consistent, meaning that it cannot be reordered with earlier or later memory operations from the same hart.
The key word being optionally. However, I could not find any information on how to detect if this option is enabled. Perhaps a separate fence was used to prevent having to try and detect this feature?
bnez t1, 1b
fence rw, w
Thanks, Rick
-- 2.28.0
The commit message should be reworded, because current codes do nothing wrong as "fence" instruction is used. What was done in this patch is using .aq / .rl to replace "fence".
Regards, Bin
This allows code to use a construct like `if (gd & gd->...) { ... }` when accessing the global data pointer. Without this change, it was possible for a very early trap to cause _exit_trap to read arbitrary memory. This could cause a second trap, preventing show_regs from being printed.
Fixes: 7c6ca03eaed0035ca6676e9bc7f5f1dfcaae7e8f Signed-off-by: Sean Anderson seanga2@gmail.com ---
arch/riscv/cpu/start.S | 20 +++++++++++++++++--- arch/riscv/lib/interrupts.c | 3 ++- 2 files changed, 19 insertions(+), 4 deletions(-)
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index ad18e746b6..59d3d7bbf4 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -47,6 +47,13 @@ _start: mv tp, a0 mv s1, a1
+ /* + * Set the global data pointer to a known value in case we get a very + * early trap. The global data pointer will be set its actual value only + * after it has been initialized. + */ + mv gp, zero + la t0, trap_entry csrw MODE_PREFIX(tvec), t0
@@ -85,10 +92,10 @@ call_board_init_f_0: jal board_init_f_alloc_reserve
/* - * Set global data pointer here for all harts, uninitialized at this - * point. + * Save global data pointer for later. We don't set it here because it + * is not initialized yet. */ - mv gp, a0 + mv s0, a0
/* setup stack */ #if CONFIG_IS_ENABLED(SMP) @@ -135,6 +142,13 @@ wait_for_gd_init: fence r, rw bnez t1, 1b
+ /* + * Set the global data pointer only when gd_t has been initialized. + * This was already set by arch_setup_gd on the boot hart, but all other + * harts' global data pointers gets set here. + */ + mv gp, s0 + /* register available harts in the available_harts mask */ li t1, 1 sll t1, t1, tp diff --git a/arch/riscv/lib/interrupts.c b/arch/riscv/lib/interrupts.c index cd47e64487..ad870e98d8 100644 --- a/arch/riscv/lib/interrupts.c +++ b/arch/riscv/lib/interrupts.c @@ -78,7 +78,8 @@ static void _exit_trap(ulong code, ulong epc, ulong tval, struct pt_regs *regs)
printf("EPC: " REG_FMT " RA: " REG_FMT " TVAL: " REG_FMT "\n", epc, regs->ra, tval); - if (gd->flags & GD_FLG_RELOC) + /* Print relocation adjustments, but only if gd is initialized */ + if (gd && gd->flags & GD_FLG_RELOC) printf("EPC: " REG_FMT " RA: " REG_FMT " reloc adjusted\n\n", epc - gd->reloc_off, regs->ra - gd->reloc_off);
nits: wrong fixes tag format
mv gp, zero
* point.
mv gp, a0
mv s0, a0 /* setup stack */
mv gp, s0
This is currently in the #ifndef CONFIG_XIP block. Should consider the #else branch?
Regards, Bin
mv gp, zero
* point.
mv gp, a0
mv gp, s0
gp is set by arch_setup_gd in board_init_f_init_reserve on the boot hart. Setting it here is only necessary for secondary harts.
Regards, Bin
mv gp, zero
* point.
mv gp, a0
mv gp, s0
Ok, I see what you mean. I guess I can set gp just before XIP jumps to secondary_hart_loop. Doing it that way is still vulnerable to pending IPIs, but not all cores should have that problem. Perhaps that limitation should be documented somewhere? In any case, I don't have an XIP core to test on (and there isn't a CI configuration either).
--Sean
Regards, Bin
This adds comments regarding the ordering and purpose of certain instructions as I understand them.
arch/riscv/cpu/start.S | 19 +++++++++++++++++-- 1 file changed, 17 insertions(+), 2 deletions(-)
diff --git a/arch/riscv/cpu/start.S b/arch/riscv/cpu/start.S index 59d3d7bbf4..c659c6df53 100644 --- a/arch/riscv/cpu/start.S +++ b/arch/riscv/cpu/start.S @@ -43,7 +43,10 @@ _start: csrr a0, CSR_MHARTID #endif
- /* save hart id and dtb pointer */ + /* + * Save hart id and dtb pointer. The thread pointer register is not + * modified by C code, and may be used in trap handlers. + */ mv tp, a0 mv s1, a1
@@ -54,10 +57,18 @@ _start: */ mv gp, zero
+ /* + * Set the trap handler. This must happen after initializing tp and gp + * because the handler may use these registers. + */ la t0, trap_entry csrw MODE_PREFIX(tvec), t0
- /* mask all interrupts */ + /* + * Mask all interrupts. Interrupts are disabled globally (in m/sstatus) + * for U-Boot, but we will need to read m/sip to determine if we get an + * IPI + */ csrw MODE_PREFIX(ie), zero
#if CONFIG_IS_ENABLED(SMP) @@ -407,6 +418,10 @@ secondary_hart_relocate: mv gp, a2 #endif
+/* + * Interrupts are disabled globally, but they can still be read from m/sip. The + * wfi function will wake us up if we get an IPI, even if we do not trap. + */ secondary_hart_loop: wfi
U-Boot does not use tp register in C code.
* IPI
- Interrupts are disabled globally, but they can still be read from m/sip. The
- wfi function will wake us up if we get an IPI, even if we do not trap.
Regards, Bin
Hi Sean
It sounds like that the bootloader does not deal with SMP flow well and jump to u-boot-spl, right ?
I have a question that why not try to fix the prior stage bootloader to clear IPIs correctly?
Actually I have encounter a similar SMP issue like you. Our prior stage bootloader will jump to u-boot-spl with the incorrect mstatus and result in the SMP working abnormal in u-boot-spl.
I mean this is an individual case, not a general case. If we try to cover any errors which come from any prior stage bootloaders, the SMP flow will become more and more complicated and hard to debug.
That is why it does not need implement SMP flow in U-Boot proper with SBI v0.2 HSM extension.
Thanks, Rick
-- 2.28.0
On 9/8/20 10:02 PM, Rick Chen wrote:
Hi Sean
Because it is a ROM :)
Perhaps we should just clear MIE then? I originally had a patch in this series which moved the handle_ipi code into handle_trap, and got rid of the manual checks on the interrupt. Something like
secondary_hart_loop: wfi j secondary_hart_loop
Of course as part of that we would need to explicitly enable and disable interrupts. Perhaps not the worst idea, but I didn't include it here because I figure the current system work OK, even if it is not what one might expect.
Of course, if a prior bootloader doesn't hold up its end of the contract, we can be left with some awful bugs to fix. U-Boot is generally not too bad to debug, but I've had an awful time whenever some concurrency sneaks into the mix. I think it's much better to confine the (necessary) complexity to as few files as possible, so that the rest of the code can be ignorant. I think part of that is verifying that we have everything in a known state, so that when we see something unexpected, we can handle it/panic/whatever instead of silently getting a bug.
--Sean
Hi Sean
Err, perhaps I should clarify. When I say "prior stage bootloader," I mean that in the general sense of "anything which comes before U-Boot," and not to refer specifically to SPL or TPL. For the k210, this is something akin to the ZSBL on an fu540.
--Sean
Hi Sean
Hi Sean
Is it a mask ROM or flash ROM ?
It sounds like an error handling and the errors come from the prior stage bootloader. Without U-Boot, does Kernel handle this kind of IPIs not clean unexpected errors ?
Thanks, Rick
--Sean
On 9/10/20 3:08 AM, Rick Chen wrote:
Hi Sean
Hi Sean
I don't know, it's not documented. From what I can tell, it's controlled by the OTP device. However, I haven't thoroughly investigated it.
Well, software interrupts are disabled on each hart until riscv_intc_init is called (and enables soft irqs). This prevents the handler from being called before ipi_data is initialized. After that, handle_IPI can be called, but if ops == 0 (e.g. the IPI wasn't signaled by Linux), then it just goes to done.
--Sean
participants (5)
Bin Meng
Leo Liang
Rick Chen
Sean Anderson
