[U-Boot] [PATCH 2/2] spi: cadence_spi_apb: fix using bouncebuf with writeback dcache
The last two commits on this file have added bounce buffer handling to indirect read and write transfers. However, these are cpu-only transfers and bouncebuf seems to be written for dma transfers only (it invalidates the dcache in bouncebuf_stop, which throws away data copied by the cpu that are still in cache only).
The last two commits resulted in reading random data on mach-socfpga.
By using the new flag GEN_BB_NODMA, cadence_qspi is fixed on that platform (although the 'Sync DT bindings with Linux' patches from Jason Rush are still needed to make it work).
Signed-off-by: Simon Goldschmidt sgoldschmidt@de.pepperl-fuchs.com --- drivers/spi/cadence_qspi_apb.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/spi/cadence_qspi_apb.c b/drivers/spi/cadence_qspi_apb.c index 7d335519b0..a3e1c84758 100644 --- a/drivers/spi/cadence_qspi_apb.c +++ b/drivers/spi/cadence_qspi_apb.c @@ -645,7 +645,7 @@ int cadence_qspi_apb_indirect_read_execute(struct cadence_spi_platdata *plat, writel(CQSPI_REG_INDIRECTRD_START, plat->regbase + CQSPI_REG_INDIRECTRD);
- ret = bounce_buffer_start(&bb, (void *)rxbuf, n_rx, GEN_BB_WRITE); + ret = bounce_buffer_start(&bb, (void *)rxbuf, n_rx, GEN_BB_WRITE|GEN_BB_NODMA); if (ret) return ret; bb_rxbuf = bb.bounce_buffer; @@ -743,7 +743,7 @@ int cadence_qspi_apb_indirect_write_execute(struct cadence_spi_platdata *plat, * Handle non-4-byte aligned accesses via bounce buffer to * avoid data abort. */ - ret = bounce_buffer_start(&bb, (void *)txbuf, n_tx, GEN_BB_READ); + ret = bounce_buffer_start(&bb, (void *)txbuf, n_tx, GEN_BB_READ|GEN_BB_NODMA); if (ret) return ret; bb_txbuf = bb.bounce_buffer;
Goldschmidt Simon
