[U-Boot] [PATCH v4][Net] Convert CS8900 Ethernet driver to CONFIG_NET_MULTI API
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c
Signed-off-by: Ben Warren biggerbadderben@gmail.com Tested-by: Wolfgang Denk wd@denx.de Acked-by: Wolfgang Denk wd@denx.de ---
v4: Changed 8-bit accesses to use volatile keyword (change made by wd@denx.de) v3: Added accessor macros to ensure proper bus access v2: Fixed typo: CS8900_BUS32 -> CONFIG_CS8900_BUS32 Added more descriptive printf in cs8900_init as suggested by Wolfgang Initialize 'priv' data structure in cs8900_initialize()
board/altera/dk1c20/dk1c20.c | 12 ++ board/altera/dk1s10/dk1s10.c | 12 ++ board/armadillo/armadillo.c | 12 ++ board/csb226/csb226.c | 12 ++ board/ep7312/ep7312.c | 12 ++ board/freescale/mx31ads/mx31ads.c | 12 ++ board/impa7/impa7.c | 12 ++ board/lart/lart.c | 12 ++ board/mpl/vcma9/cmd_vcma9.c | 28 +++-- board/mpl/vcma9/vcma9.c | 12 ++ board/mx1ads/mx1ads.c | 12 ++ board/samsung/smdk2400/smdk2400.c | 12 ++ board/samsung/smdk2410/smdk2410.c | 12 ++ board/samsung/smdk6400/smdk6400.c | 12 ++ board/sbc2410x/sbc2410x.c | 12 ++ board/ssv/adnpesc1/adnpesc1.c | 12 ++ board/trab/trab.c | 12 ++ drivers/net/Makefile | 2 +- drivers/net/cs8900.c | 276 ++++++++++++++++++++++--------------- drivers/net/cs8900.h | 41 ++++--- include/configs/ADNPESC1.h | 14 +- include/configs/DK1C20.h | 14 +- include/configs/DK1S10.h | 14 +- include/configs/VCMA9.h | 7 +- include/configs/armadillo.h | 9 +- include/configs/csb226.h | 7 +- include/configs/ep7312.h | 9 +- include/configs/impa7.h | 7 +- include/configs/lart.h | 7 +- include/configs/mx1ads.h | 7 +- include/configs/mx31ads.h | 7 +- include/configs/sbc2410x.h | 7 +- include/configs/smdk2400.h | 7 +- include/configs/smdk2410.h | 7 +- include/configs/smdk6400.h | 7 +- include/configs/trab.h | 7 +- include/netdev.h | 1 + lib_arm/board.c | 9 -- 38 files changed, 476 insertions(+), 210 deletions(-)
diff --git a/board/altera/dk1c20/dk1c20.c b/board/altera/dk1c20/dk1c20.c index 11c19b7..0bcaa4f 100644 --- a/board/altera/dk1c20/dk1c20.c +++ b/board/altera/dk1c20/dk1c20.c @@ -25,6 +25,7 @@ */
#include <common.h> +#include <netdev.h> #include <nios-io.h> #if defined(CONFIG_SEVENSEG) #include "../common/sevenseg.h" @@ -79,3 +80,14 @@ int ide_preinit (void) return 0; } #endif + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/altera/dk1s10/dk1s10.c b/board/altera/dk1s10/dk1s10.c index 64d591e..fb96501 100644 --- a/board/altera/dk1s10/dk1s10.c +++ b/board/altera/dk1s10/dk1s10.c @@ -22,6 +22,7 @@ */
#include <common.h> +#include <netdev.h> #if defined(CONFIG_SEVENSEG) #include "../common/sevenseg.h" #endif @@ -58,3 +59,14 @@ phys_size_t initdram (int board_type) { return (0); } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/armadillo/armadillo.c b/board/armadillo/armadillo.c index ca5bd1d..a825144 100644 --- a/board/armadillo/armadillo.c +++ b/board/armadillo/armadillo.c @@ -26,6 +26,7 @@ */
#include <common.h> +#include <netdev.h> #include <clps7111.h>
DECLARE_GLOBAL_DATA_PTR; @@ -58,3 +59,14 @@ int dram_init (void)
return (0); } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/csb226/csb226.c b/board/csb226/csb226.c index 80caf8b..0a6c13d 100644 --- a/board/csb226/csb226.c +++ b/board/csb226/csb226.c @@ -24,6 +24,7 @@ */
#include <common.h> +#include <netdev.h> #include <asm/arch/pxa-regs.h>
DECLARE_GLOBAL_DATA_PTR; @@ -151,3 +152,14 @@ void show_boot_progress (int status)
return; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/ep7312/ep7312.c b/board/ep7312/ep7312.c index 6968a5d..8ed14ad 100644 --- a/board/ep7312/ep7312.c +++ b/board/ep7312/ep7312.c @@ -23,6 +23,7 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -52,3 +53,14 @@ int dram_init (void)
return (0); } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/freescale/mx31ads/mx31ads.c b/board/freescale/mx31ads/mx31ads.c index c24c47c..bc25c6d 100644 --- a/board/freescale/mx31ads/mx31ads.c +++ b/board/freescale/mx31ads/mx31ads.c @@ -21,6 +21,7 @@ */
#include <common.h> +#include <netdev.h> #include <asm/io.h> #include <asm/arch/mx31.h> #include <asm/arch/mx31-regs.h> @@ -104,3 +105,14 @@ int checkboard (void) printf("Board: MX31ADS\n"); return 0; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/impa7/impa7.c b/board/impa7/impa7.c index 3230dd4..205b1b3 100644 --- a/board/impa7/impa7.c +++ b/board/impa7/impa7.c @@ -23,6 +23,7 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -57,3 +58,14 @@ int dram_init (void)
return (0); } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/lart/lart.c b/board/lart/lart.c index 8d534c8..a0b459f 100644 --- a/board/lart/lart.c +++ b/board/lart/lart.c @@ -23,6 +23,7 @@ */
@@ -62,3 +63,14 @@ int dram_init (void)
return (0); } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/mpl/vcma9/cmd_vcma9.c b/board/mpl/vcma9/cmd_vcma9.c index 0160774..0ee9595 100644 --- a/board/mpl/vcma9/cmd_vcma9.c +++ b/board/mpl/vcma9/cmd_vcma9.c @@ -31,7 +31,7 @@ #include "vcma9.h" #include "../common/common_util.h"
-#if defined(CONFIG_DRIVER_CS8900) +#if defined(CONFIG_CS8900) #include <../drivers/net/cs8900.h>
static uchar cs8900_chksum(ushort data) @@ -56,25 +56,33 @@ extern int do_mplcommon(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]);
int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { + struct eth_device *dev; + char cs8900_name[10]; if (strcmp(argv[1], "info") == 0) { print_vcma9_info(); return 0; } -#if defined(CONFIG_DRIVER_CS8900) +#if defined(CONFIG_CS8900) if (strcmp(argv[1], "cs8900") == 0) { + sprintf(cs8900_name, "%s-0", CS8900_DRIVERNAME); + dev = eth_get_dev_by_name(cs8900_name); + if (!dev) { + printf("Couldn't find CS8900 driver"); + return 0; + } if (strcmp(argv[2], "read") == 0) { uchar addr; ushort data;
addr = simple_strtoul(argv[3], NULL, 16); - cs8900_e2prom_read(addr, &data); + cs8900_e2prom_read(dev, addr, &data); printf("0x%2.2X: 0x%4.4X\n", addr, data); } else if (strcmp(argv[2], "write") == 0) { uchar addr; ushort data;
addr = simple_strtoul(argv[3], NULL, 16); data = simple_strtoul(argv[4], NULL, 16); - cs8900_e2prom_write(addr, data); + cs8900_e2prom_write(dev, addr, data); } else if (strcmp(argv[2], "setaddr") == 0) { uchar addr, i, csum; ushort data; uchar ethaddr[6]; @@ -83,22 +91,22 @@ int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) if (eth_getenv_enetaddr("ethaddr", ethaddr)) { addr = 1; data = 0x2158; - cs8900_e2prom_write(addr, data); + cs8900_e2prom_write(dev, addr, data); csum = cs8900_chksum(data); addr++; for (i = 0; i < 6; i+=2) { data = ethaddr[i+1] << 8 | ethaddr[i]; - cs8900_e2prom_write(addr, data); + cs8900_e2prom_write(dev, addr, data); csum += cs8900_chksum(data); addr++; } /* calculate header link byte */ data = 0xA100 | (addr * 2); - cs8900_e2prom_write(0, data); + cs8900_e2prom_write(dev, 0, data); csum += cs8900_chksum(data); /* write checksum word */ - cs8900_e2prom_write(addr, (0 - csum) << 8); + cs8900_e2prom_write(dev, addr, (0 - csum) << 8); } else { puts("\nplease defined 'ethaddr'\n"); } @@ -106,12 +114,12 @@ int do_vcma9(cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) uchar addr = 0, endaddr, csum; ushort data;
puts("Dump of CS8900 config device: "); - cs8900_e2prom_read(addr, &data); + cs8900_e2prom_read(dev, addr, &data); if ((data & 0xE000) == 0xA000) { endaddr = (data & 0x00FF) / 2; csum = cs8900_chksum(data); for (addr = 1; addr <= endaddr; addr++) { - cs8900_e2prom_read(addr, &data); + cs8900_e2prom_read(dev, addr, &data); printf("\n0x%2.2X: 0x%4.4X", addr, data); csum += cs8900_chksum(data); } diff --git a/board/mpl/vcma9/vcma9.c b/board/mpl/vcma9/vcma9.c index 2b3fad2..3216d63 100644 --- a/board/mpl/vcma9/vcma9.c +++ b/board/mpl/vcma9/vcma9.c @@ -26,6 +26,7 @@ */
#include <common.h> +#include <netdev.h> #include <s3c2410.h> #include <stdio_dev.h> #include <i2c.h> @@ -349,3 +350,14 @@ void print_vcma9_info(void) Show_VCMA9_Info(s, &s[6]); } } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/mx1ads/mx1ads.c b/board/mx1ads/mx1ads.c index ba152e2..f8ce210 100644 --- a/board/mx1ads/mx1ads.c +++ b/board/mx1ads/mx1ads.c @@ -24,6 +24,7 @@ */
#include <common.h> +#include <netdev.h> /*#include <mc9328.h>*/ #include <asm/arch/imx-regs.h>
@@ -167,3 +168,14 @@ int dram_init (void)
return 0; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/samsung/smdk2400/smdk2400.c b/board/samsung/smdk2400/smdk2400.c index 0b82070..2c47063 100644 --- a/board/samsung/smdk2400/smdk2400.c +++ b/board/samsung/smdk2400/smdk2400.c @@ -26,6 +26,7 @@ */
#include <common.h> +#include <netdev.h> #include <s3c2400.h>
DECLARE_GLOBAL_DATA_PTR; @@ -110,3 +111,14 @@ static int key_pressed(void) return rc; } #endif /* CONFIG_MODEM_SUPPORT */ + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/samsung/smdk2410/smdk2410.c b/board/samsung/smdk2410/smdk2410.c index 802348d..25c38e6 100644 --- a/board/samsung/smdk2410/smdk2410.c +++ b/board/samsung/smdk2410/smdk2410.c @@ -26,6 +26,7 @@ */
DECLARE_GLOBAL_DATA_PTR; @@ -121,3 +122,14 @@ int dram_init (void)
return 0; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/samsung/smdk6400/smdk6400.c b/board/samsung/smdk6400/smdk6400.c index 52cd174..561c0c8 100644 --- a/board/samsung/smdk6400/smdk6400.c +++ b/board/samsung/smdk6400/smdk6400.c @@ -29,6 +29,7 @@ */
#include <common.h> +#include <netdev.h> #include <s3c6400.h>
/* ------------------------------------------------------------------------- */ @@ -117,3 +118,14 @@ ulong board_flash_get_legacy (ulong base, int banknum, flash_info_t *info) } else return 0; } + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/sbc2410x/sbc2410x.c b/board/sbc2410x/sbc2410x.c index 6c894a3..6276850 100644 --- a/board/sbc2410x/sbc2410x.c +++ b/board/sbc2410x/sbc2410x.c @@ -29,6 +29,7 @@ */
#if defined(CONFIG_CMD_NAND) @@ -178,3 +179,14 @@ void nand_init(void) printf ("%4lu MB\n", nand_probe((ulong)nand) >> 20); } #endif + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/ssv/adnpesc1/adnpesc1.c b/board/ssv/adnpesc1/adnpesc1.c index 9d32741..72810d0 100644 --- a/board/ssv/adnpesc1/adnpesc1.c +++ b/board/ssv/adnpesc1/adnpesc1.c @@ -22,6 +22,7 @@ */
#include <common.h> +#include <netdev.h> #include <nios-io.h> #include <spi.h>
@@ -100,3 +101,14 @@ int post_hotkeys_pressed(void) return 0; /* No hotkeys supported */ } #endif /* CONFIG_POST */ + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/board/trab/trab.c b/board/trab/trab.c index ddf6abf..2dccd87 100644 --- a/board/trab/trab.c +++ b/board/trab/trab.c @@ -24,6 +24,7 @@ /* #define DEBUG */
#include <common.h> +#include <netdev.h> #include <malloc.h> #include <s3c2400.h> #include <command.h> @@ -420,3 +421,14 @@ static void tsc2000_set_brightness(void) tsc2000_write(0, 0xb, br & 0xff); } #endif + +#ifdef CONFIG_CMD_NET +int board_eth_init(bd_t *bis) +{ + int rc = 0; +#ifdef CONFIG_CS8900 + rc = cs8900_initialize(0, CONFIG_CS8900_BASE); +#endif + return rc; +} +#endif diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 34b56d8..6758557 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -30,7 +30,7 @@ COBJS-$(CONFIG_PPC4xx_EMAC) += 4xx_enet.o COBJS-$(CONFIG_DRIVER_AX88180) += ax88180.o COBJS-$(CONFIG_BCM570x) += bcm570x.o bcm570x_autoneg.o 5701rls.o COBJS-$(CONFIG_BFIN_MAC) += bfin_mac.o -COBJS-$(CONFIG_DRIVER_CS8900) += cs8900.o +COBJS-$(CONFIG_CS8900) += cs8900.o COBJS-$(CONFIG_TULIP) += dc2114x.o COBJS-$(CONFIG_DRIVER_DM9000) += dm9000x.o COBJS-$(CONFIG_DNET) += dnet.o diff --git a/drivers/net/cs8900.c b/drivers/net/cs8900.c index 5e2b3b0..587f7f6 100644 --- a/drivers/net/cs8900.c +++ b/drivers/net/cs8900.c @@ -1,6 +1,9 @@ /* * Cirrus Logic CS8900A Ethernet * + * (C) 2009 Ben Warren , biggerbadderben@gmail.com + * Converted to use CONFIG_NET_MULTI API + * * (C) 2003 Wolfgang Denk, wd@denx.de * Extension to synchronize ethaddr environment variable * against value in EEPROM @@ -38,220 +41,229 @@
#include <common.h> #include <command.h> -#include "cs8900.h" +#include <asm/io.h> #include <net.h> +#include <malloc.h> +#include "cs8900.h"
#undef DEBUG
/* packet page register access functions */
-#ifdef CS8900_BUS32 +#ifdef CONFIG_CS8900_BUS32 + +#define REG_WRITE(v, a) writel((v),(a)) +#define REG_READ(a) readl((a)) + /* we don't need 16 bit initialisation on 32 bit bus */ #define get_reg_init_bus(x) get_reg((x)) + #else -static unsigned short get_reg_init_bus (int regno) -{ - /* force 16 bit busmode */ - volatile unsigned char c;
- c = CS8900_BUS16_0; - c = CS8900_BUS16_1; - c = CS8900_BUS16_0; - c = CS8900_BUS16_1; - c = CS8900_BUS16_0; +#define REG_WRITE(v, a) writew((v),(a)) +#define REG_READ(a) readw((a))
- CS8900_PPTR = regno; - return CS8900_PDATA; +static u16 get_reg_init_bus(struct eth_device *dev, int regno) +{ + /* force 16 bit busmode */ + volatile u8 c; + struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); + uint8_t volatile * const iob = (uint8_t volatile * const)dev->iobase; + + c = readb(iob); + c = readb(iob + 1); + c = readb(iob); + c = readb(iob + 1); + c = readb(iob); + + REG_WRITE(regno, &priv->regs->pptr); + return REG_READ(&priv->regs->pdata); } #endif
-static unsigned short get_reg (int regno) +static u16 get_reg(struct eth_device *dev, int regno) { - CS8900_PPTR = regno; - return CS8900_PDATA; + struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); + REG_WRITE(regno, &priv->regs->pptr); + return REG_READ(&priv->regs->pdata); }
-static void put_reg (int regno, unsigned short val) +static void put_reg(struct eth_device *dev, int regno, u16 val) { - CS8900_PPTR = regno; - CS8900_PDATA = val; + struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); + REG_WRITE(regno, &priv->regs->pptr); + REG_WRITE(val, &priv->regs->pdata); }
-static void eth_reset (void) +static void cs8900_reset(struct eth_device *dev) { int tmo; - unsigned short us; + u16 us;
/* reset NIC */ - put_reg (PP_SelfCTL, get_reg (PP_SelfCTL) | PP_SelfCTL_Reset); + put_reg(dev, PP_SelfCTL, get_reg(dev, PP_SelfCTL) | PP_SelfCTL_Reset);
/* wait for 200ms */ - udelay (200000); + udelay(200000); /* Wait until the chip is reset */
- tmo = get_timer (0) + 1 * CONFIG_SYS_HZ; - while ((((us = get_reg_init_bus (PP_SelfSTAT)) & PP_SelfSTAT_InitD) == 0) - && tmo < get_timer (0)) + tmo = get_timer(0) + 1 * CONFIG_SYS_HZ; + while ((((us = get_reg_init_bus(dev, PP_SelfSTAT)) & + PP_SelfSTAT_InitD) == 0) && tmo < get_timer(0)) /*NOP*/; }
-static void eth_reginit (void) +static void cs8900_reginit(struct eth_device *dev) { /* receive only error free packets addressed to this card */ - put_reg (PP_RxCTL, PP_RxCTL_IA | PP_RxCTL_Broadcast | PP_RxCTL_RxOK); + put_reg(dev, PP_RxCTL, + PP_RxCTL_IA | PP_RxCTL_Broadcast | PP_RxCTL_RxOK); /* do not generate any interrupts on receive operations */ - put_reg (PP_RxCFG, 0); + put_reg(dev, PP_RxCFG, 0); /* do not generate any interrupts on transmit operations */ - put_reg (PP_TxCFG, 0); + put_reg(dev, PP_TxCFG, 0); /* do not generate any interrupts on buffer operations */ - put_reg (PP_BufCFG, 0); + put_reg(dev, PP_BufCFG, 0); /* enable transmitter/receiver mode */ - put_reg (PP_LineCTL, PP_LineCTL_Rx | PP_LineCTL_Tx); + put_reg(dev, PP_LineCTL, PP_LineCTL_Rx | PP_LineCTL_Tx); }
-void cs8900_get_enetaddr (void) +void cs8900_get_enetaddr(struct eth_device *dev) { int i; - uchar enetaddr[6]; - - /* if the env is setup, then bail */ - if (eth_getenv_enetaddr("ethaddr", enetaddr)) - return;
/* verify chip id */ - if (get_reg_init_bus (PP_ChipID) != 0x630e) + if (get_reg_init_bus(dev, PP_ChipID) != 0x630e) return; - eth_reset (); - if ((get_reg (PP_SelfSTAT) & (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) == - (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) { + cs8900_reset(dev); + if ((get_reg(dev, PP_SelfSTAT) & + (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) == + (PP_SelfSTAT_EEPROM | PP_SelfSTAT_EEPROM_OK)) {
/* Load the MAC from EEPROM */ - for (i = 0; i < 6 / 2; i++) { - unsigned int Addr; + for (i = 0; i < 3; i++) { + u32 Addr;
- Addr = get_reg (PP_IA + i * 2); - enetaddr[i * 2] = Addr & 0xFF; - enetaddr[i * 2 + 1] = Addr >> 8; + Addr = get_reg(dev, PP_IA + i * 2); + dev->enetaddr[i * 2] = Addr & 0xFF; + dev->enetaddr[i * 2 + 1] = Addr >> 8; } - - eth_setenv_enetaddr("ethaddr", enetaddr); - debug("### Set environment from HW MAC addr = "%pM"\n", enetaddr); } }
-void eth_halt (void) +void cs8900_halt(struct eth_device *dev) { /* disable transmitter/receiver mode */ - put_reg (PP_LineCTL, 0); + put_reg(dev, PP_LineCTL, 0);
/* "shutdown" to show ChipID or kernel wouldn't find he cs8900 ... */ - get_reg_init_bus (PP_ChipID); + get_reg_init_bus(dev, PP_ChipID); }
-int eth_init (bd_t * bd) +static int cs8900_init(struct eth_device *dev, bd_t * bd) { - uchar enetaddr[6]; + uchar *enetaddr = dev->enetaddr; + u16 id;
/* verify chip id */ - if (get_reg_init_bus (PP_ChipID) != 0x630e) { - printf ("CS8900 Ethernet chip not found?!\n"); - return 0; + id = get_reg_init_bus(dev, PP_ChipID); + if (id != 0x630e) { + printf ("CS8900 Ethernet chip not found: " + "ID=0x%04x instead 0x%04x\n", id, 0x630e); + return 1; }
- eth_reset (); + cs8900_reset (dev); /* set the ethernet address */ - eth_getenv_enetaddr("ethaddr", enetaddr); - put_reg (PP_IA + 0, enetaddr[0] | (enetaddr[1] << 8)); - put_reg (PP_IA + 2, enetaddr[2] | (enetaddr[3] << 8)); - put_reg (PP_IA + 4, enetaddr[4] | (enetaddr[5] << 8)); + put_reg(dev, PP_IA + 0, enetaddr[0] | (enetaddr[1] << 8)); + put_reg(dev, PP_IA + 2, enetaddr[2] | (enetaddr[3] << 8)); + put_reg(dev, PP_IA + 4, enetaddr[4] | (enetaddr[5] << 8));
- eth_reginit (); + cs8900_reginit(dev); return 0; }
/* Get a data block via Ethernet */ -int eth_rx (void) +static int cs8900_recv(struct eth_device *dev) { int i; - unsigned short rxlen; - unsigned short *addr; - unsigned short status; + u16 rxlen; + u16 *addr; + u16 status;
- status = get_reg (PP_RER); + struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv); + + status = get_reg(dev, PP_RER);
if ((status & PP_RER_RxOK) == 0) return 0;
- status = CS8900_RTDATA; /* stat */ - rxlen = CS8900_RTDATA; /* len */ + status = REG_READ(&priv->regs->rtdata); + rxlen = REG_READ(&priv->regs->rtdata);
-#ifdef DEBUG if (rxlen > PKTSIZE_ALIGN + PKTALIGN) - printf ("packet too big!\n"); -#endif - for (addr = (unsigned short *) NetRxPackets[0], i = rxlen >> 1; i > 0; + debug("packet too big!\n"); + for (addr = (u16 *) NetRxPackets[0], i = rxlen >> 1; i > 0; i--) - *addr++ = CS8900_RTDATA; + *addr++ = REG_READ(&priv->regs->rtdata); if (rxlen & 1) - *addr++ = CS8900_RTDATA; + *addr++ = REG_READ(&priv->regs->rtdata);
/* Pass the packet up to the protocol layers. */ NetReceive (NetRxPackets[0], rxlen); - return rxlen; }
/* Send a data block via Ethernet. */ -int eth_send (volatile void *packet, int length) +static int cs8900_send(struct eth_device *dev, + volatile void *packet, int length) { - volatile unsigned short *addr; + volatile u16 *addr; int tmo; - unsigned short s; + u16 s; + struct cs8900_priv *priv = (struct cs8900_priv *)(dev->priv);
retry: /* initiate a transmit sequence */ - CS8900_TxCMD = PP_TxCmd_TxStart_Full; - CS8900_TxLEN = length; + REG_WRITE(PP_TxCmd_TxStart_Full, &priv->regs->txcmd); + REG_WRITE(length, &priv->regs->txlen);
/* Test to see if the chip has allocated memory for the packet */ - if ((get_reg (PP_BusSTAT) & PP_BusSTAT_TxRDY) == 0) { + if ((get_reg(dev, PP_BusSTAT) & PP_BusSTAT_TxRDY) == 0) { /* Oops... this should not happen! */ -#ifdef DEBUG - printf ("cs: unable to send packet; retrying...\n"); -#endif - for (tmo = get_timer (0) + 5 * CONFIG_SYS_HZ; get_timer (0) < tmo;) + debug("cs: unable to send packet; retrying...\n"); + for (tmo = get_timer(0) + 5 * CONFIG_SYS_HZ; + get_timer(0) < tmo;) /*NOP*/; - eth_reset (); - eth_reginit (); + cs8900_reset(dev); + cs8900_reginit(dev); goto retry; }
/* Write the contents of the packet */ /* assume even number of bytes */ for (addr = packet; length > 0; length -= 2) - CS8900_RTDATA = *addr++; + REG_WRITE(*addr++, &priv->regs->rtdata);
/* wait for transfer to succeed */ - tmo = get_timer (0) + 5 * CONFIG_SYS_HZ; - while ((s = get_reg (PP_TER) & ~0x1F) == 0) { - if (get_timer (0) >= tmo) + tmo = get_timer(0) + 5 * CONFIG_SYS_HZ; + while ((s = get_reg(dev, PP_TER) & ~0x1F) == 0) { + if (get_timer(0) >= tmo) break; }
/* nothing */ ; - if ((s & (PP_TER_CRS | PP_TER_TxOK)) != PP_TER_TxOK) { -#ifdef DEBUG - printf ("\ntransmission error %#x\n", s); -#endif + if((s & (PP_TER_CRS | PP_TER_TxOK)) != PP_TER_TxOK) { + debug("\ntransmission error %#x\n", s); }
return 0; }
-static void cs8900_e2prom_ready(void) +static void cs8900_e2prom_ready(struct eth_device *dev) { - while (get_reg(PP_SelfSTAT) & SI_BUSY) + while (get_reg(dev, PP_SelfSTAT) & SI_BUSY) ; }
@@ -259,12 +271,13 @@ static void cs8900_e2prom_ready(void) /* read a 16-bit word out of the EEPROM */ /***********************************************************/
-int cs8900_e2prom_read(unsigned char addr, unsigned short *value) +int cs8900_e2prom_read(struct eth_device *dev, + u8 addr, u16 *value) { - cs8900_e2prom_ready(); - put_reg(PP_EECMD, EEPROM_READ_CMD | addr); - cs8900_e2prom_ready(); - *value = get_reg(PP_EEData); + cs8900_e2prom_ready(dev); + put_reg(dev, PP_EECMD, EEPROM_READ_CMD | addr); + cs8900_e2prom_ready(dev); + *value = get_reg(dev, PP_EEData);
return 0; } @@ -274,16 +287,51 @@ int cs8900_e2prom_read(unsigned char addr, unsigned short *value) /* write a 16-bit word into the EEPROM */ /***********************************************************/
-int cs8900_e2prom_write(unsigned char addr, unsigned short value) +int cs8900_e2prom_write(struct eth_device *dev, u8 addr, u16 value) +{ + cs8900_e2prom_ready(dev); + put_reg(dev, PP_EECMD, EEPROM_WRITE_EN); + cs8900_e2prom_ready(dev); + put_reg(dev, PP_EEData, value); + put_reg(dev, PP_EECMD, EEPROM_WRITE_CMD | addr); + cs8900_e2prom_ready(dev); + put_reg(dev, PP_EECMD, EEPROM_WRITE_DIS); + cs8900_e2prom_ready(dev); + + return 0; +} + +int cs8900_initialize(u8 dev_num, int base_addr) { - cs8900_e2prom_ready(); - put_reg(PP_EECMD, EEPROM_WRITE_EN); - cs8900_e2prom_ready(); - put_reg(PP_EEData, value); - put_reg(PP_EECMD, EEPROM_WRITE_CMD | addr); - cs8900_e2prom_ready(); - put_reg(PP_EECMD, EEPROM_WRITE_DIS); - cs8900_e2prom_ready(); + struct eth_device *dev; + struct cs8900_priv *priv; + + dev = malloc(sizeof(*dev)); + if (!dev) { + free(dev); + return 0; + } + memset(dev, 0, sizeof(*dev)); + + priv = malloc(sizeof(*priv)); + if (!priv) { + free(priv); + return 0; + } + memset(priv, 0, sizeof(*priv)); + priv->regs = (struct cs8900_regs *)base_addr; + + /* Load MAC address from EEPROM */ + cs8900_get_enetaddr(dev); + + dev->iobase = base_addr; + dev->priv = priv; + dev->init = cs8900_init; + dev->halt = cs8900_halt; + dev->send = cs8900_send; + dev->recv = cs8900_recv; + sprintf(dev->name, "%s-%hu", CS8900_DRIVERNAME, dev_num);
+ eth_register(dev); return 0; } diff --git a/drivers/net/cs8900.h b/drivers/net/cs8900.h index f9c32dd..23c5cb0 100644 --- a/drivers/net/cs8900.h +++ b/drivers/net/cs8900.h @@ -1,6 +1,11 @@ +#ifndef CS8900_H +#define CS8900_H /* * Cirrus Logic CS8900A Ethernet * + * (C) 2009 Ben Warren , biggerbadderben@gmail.com + * Converted to use CONFIG_NET_MULTI API + * * (C) Copyright 2002 * Sysgo Real-Time Solutions, GmbH <www.elinos.com> * Marius Groeger mgroeger@sysgo.de @@ -35,33 +40,34 @@ #include <asm/types.h> #include <config.h>
-#ifdef CONFIG_DRIVER_CS8900 - +#define CS8900_DRIVERNAME "CS8900" /* although the registers are 16 bit, they are 32-bit aligned on the EDB7111. so we have to read them as 32-bit registers and ignore the upper 16-bits. i'm not sure if this holds for the EDB7211. */
-#ifdef CS8900_BUS16 +#ifdef CONFIG_CS8900_BUS16 /* 16 bit aligned registers, 16 bit wide */ #define CS8900_REG u16 - #define CS8900_OFF 0x02 - #define CS8900_BUS16_0 *(volatile u8 *)(CS8900_BASE+0x00) - #define CS8900_BUS16_1 *(volatile u8 *)(CS8900_BASE+0x01) -#elif defined(CS8900_BUS32) +#elif defined(CONFIG_CS8900_BUS32) /* 32 bit aligned registers, 16 bit wide (we ignore upper 16 bits) */ #define CS8900_REG u32 - #define CS8900_OFF 0x04 #else #error unknown bussize ... #endif
-#define CS8900_RTDATA *(volatile CS8900_REG *)(CS8900_BASE+0x00*CS8900_OFF) -#define CS8900_TxCMD *(volatile CS8900_REG *)(CS8900_BASE+0x02*CS8900_OFF) -#define CS8900_TxLEN *(volatile CS8900_REG *)(CS8900_BASE+0x03*CS8900_OFF) -#define CS8900_ISQ *(volatile CS8900_REG *)(CS8900_BASE+0x04*CS8900_OFF) -#define CS8900_PPTR *(volatile CS8900_REG *)(CS8900_BASE+0x05*CS8900_OFF) -#define CS8900_PDATA *(volatile CS8900_REG *)(CS8900_BASE+0x06*CS8900_OFF) +struct cs8900_regs { + CS8900_REG rtdata; + CS8900_REG pad0; + CS8900_REG txcmd; + CS8900_REG txlen; + CS8900_REG isq; + CS8900_REG pptr; + CS8900_REG pdata; +};
+struct cs8900_priv { + struct cs8900_regs *regs; +};
#define ISQ_RxEvent 0x04 #define ISQ_TxEvent 0x08 @@ -251,7 +257,8 @@ #define EEPROM_READ_CMD 0x0200 #define EEPROM_ERASE_CMD 0x0300
-extern int cs8900_e2prom_read(uchar, ushort *); -extern int cs8900_e2prom_write(uchar, ushort); +/* Exported functions */ +int cs8900_e2prom_read(struct eth_device *dev, uchar, ushort *); +int cs8900_e2prom_write(struct eth_device *dev, uchar, ushort);
-#endif /* CONFIG_DRIVER_CS8900 */ +#endif /* CS8900_H */ diff --git a/include/configs/ADNPESC1.h b/include/configs/ADNPESC1.h index b8afc17..2d4fc77 100644 --- a/include/configs/ADNPESC1.h +++ b/include/configs/ADNPESC1.h @@ -426,15 +426,17 @@ /********************************************/ /* !!! CS8900 is __not__ tested on NIOS !!! */ /********************************************/ -#define CONFIG_DRIVER_CS8900 /* Using CS8900 */ -#define CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + CONFIG_SYS_NIOS_CPU_LAN0_OFFS) +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* Using CS8900 */ +#define CONFIG_CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + \ + CONFIG_SYS_NIOS_CPU_LAN0_OFFS)
#if (CONFIG_SYS_NIOS_CPU_LAN0_BUSW == 32) -#undef CS8900_BUS16 -#define CS8900_BUS32 1 +#undef CONFIG_CS8900_BUS16 +#define CONFIG_CS8900_BUS32 #else /* no */ -#define CS8900_BUS16 1 -#undef CS8900_BUS32 +#define CONFIG_CS8900_BUS16 +#undef CONFIG_CS8900_BUS32 #endif
#else diff --git a/include/configs/DK1C20.h b/include/configs/DK1C20.h index 45ff2f7..cdc488b 100644 --- a/include/configs/DK1C20.h +++ b/include/configs/DK1C20.h @@ -232,15 +232,17 @@ /********************************************/ /* !!! CS8900 is __not__ tested on NIOS !!! */ /********************************************/ -#define CONFIG_DRIVER_CS8900 /* Using CS8900 */ -#define CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + CONFIG_SYS_NIOS_CPU_LAN0_OFFS) +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* Using CS8900 */ +#define CONFIG_CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + \ + CONFIG_SYS_NIOS_CPU_LAN0_OFFS)
#else diff --git a/include/configs/DK1S10.h b/include/configs/DK1S10.h index ae567a3..6e78861 100644 --- a/include/configs/DK1S10.h +++ b/include/configs/DK1S10.h @@ -249,15 +249,17 @@ /********************************************/ /* !!! CS8900 is __not__ tested on NIOS !!! */ /********************************************/ -#define CONFIG_DRIVER_CS8900 /* Using CS8900 */ -#define CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + CONFIG_SYS_NIOS_CPU_LAN0_OFFS) +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* Using CS8900 */ +#define CONFIG_CS8900_BASE (CONFIG_SYS_NIOS_CPU_LAN0_BASE + \ + CONFIG_SYS_NIOS_CPU_LAN0_OFFS)
#else diff --git a/include/configs/VCMA9.h b/include/configs/VCMA9.h index 6051480..618b7f0 100644 --- a/include/configs/VCMA9.h +++ b/include/configs/VCMA9.h @@ -108,9 +108,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x20000300 -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x20000300 +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
#define CONFIG_DRIVER_S3C24X0_I2C 1 /* we use the buildin I2C controller */
diff --git a/include/configs/armadillo.h b/include/configs/armadillo.h index f7eec27..49ea3a1 100644 --- a/include/configs/armadillo.h +++ b/include/configs/armadillo.h @@ -56,10 +56,11 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x20000300 /* armadillo board */ -#define CS8900_BUS16 1 -#undef CS8900_BUS32 +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x20000300 /* armadillo board */ +#define CONFIG_CS8900_BUS16 +#undef CONFIG_CS8900_BUS32
/* * select serial console configuration diff --git a/include/configs/csb226.h b/include/configs/csb226.h index 12bab47..0661d65 100644 --- a/include/configs/csb226.h +++ b/include/configs/csb226.h @@ -150,9 +150,10 @@ /* * Network chip */ -#define CONFIG_DRIVER_CS8900 1 -#define CS8900_BUS32 1 -#define CS8900_BASE 0x08000000 +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 +#define CONFIG_CS8900_BUS32 +#define CONFIG_CS8900_BASE 0x08000000
/* * Stack sizes diff --git a/include/configs/ep7312.h b/include/configs/ep7312.h index 630fff3..e151faa 100644 --- a/include/configs/ep7312.h +++ b/include/configs/ep7312.h @@ -47,10 +47,11 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x20000000 -#define CS8900_BUS16 1 -#undef CS8900_BUS32 +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x20000000 +#define CONFIG_CS8900_BUS16 +#undef CONFIG_CS8900_BUS32
/* * select serial console configuration diff --git a/include/configs/impa7.h b/include/configs/impa7.h index c7001cc..fdfa022 100644 --- a/include/configs/impa7.h +++ b/include/configs/impa7.h @@ -47,9 +47,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x20000000 -#define CS8900_BUS32 1 +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x20000000 +#define CONFIG_CS8900_BUS32
/* * select serial console configuration diff --git a/include/configs/lart.h b/include/configs/lart.h index 5d6d460..2d3b369 100644 --- a/include/configs/lart.h +++ b/include/configs/lart.h @@ -47,9 +47,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x20008300 -#define CS8900_BUS16 1 +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x20008300 +#define CONFIG_CS8900_BUS16
/* * select serial console configuration diff --git a/include/configs/mx1ads.h b/include/configs/mx1ads.h index 12e567b..b2ffd3e 100644 --- a/include/configs/mx1ads.h +++ b/include/configs/mx1ads.h @@ -66,9 +66,10 @@ /* * CS8900 Ethernet drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x15000300 -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x15000300 +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
/* * select serial console configuration diff --git a/include/configs/mx31ads.h b/include/configs/mx31ads.h index 363ea1b..ec1c905 100644 --- a/include/configs/mx31ads.h +++ b/include/configs/mx31ads.h @@ -109,9 +109,10 @@ "cp.b ${loadaddr} ${uboot_addr} ${filesize}; " \ "setenv filesize; saveenv\0"
-#define CONFIG_DRIVER_CS8900 1 -#define CS8900_BASE 0xb4020300 -#define CS8900_BUS16 1 /* follow the Linux driver */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 +#define CONFIG_CS8900_BASE 0xb4020300 +#define CONFIG_CS8900_BUS16 1 /* follow the Linux driver */
/* * The MX31ADS board seems to have a hardware "peculiarity" confirmed under diff --git a/include/configs/sbc2410x.h b/include/configs/sbc2410x.h index f3dc7fe..f2ea926 100644 --- a/include/configs/sbc2410x.h +++ b/include/configs/sbc2410x.h @@ -63,9 +63,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x19000300 -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x19000300 +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
/* * select serial console configuration diff --git a/include/configs/smdk2400.h b/include/configs/smdk2400.h index b712db4..c234177 100644 --- a/include/configs/smdk2400.h +++ b/include/configs/smdk2400.h @@ -56,9 +56,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x07000300 /* agrees with WIN CE PA */ -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x07000300 /* agrees with WIN CE PA */ +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
/* * select serial console configuration diff --git a/include/configs/smdk2410.h b/include/configs/smdk2410.h index a473278..d340098 100644 --- a/include/configs/smdk2410.h +++ b/include/configs/smdk2410.h @@ -53,9 +53,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x19000300 -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x19000300 +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
/* * select serial console configuration diff --git a/include/configs/smdk6400.h b/include/configs/smdk6400.h index ddc8e71..f6e1221 100644 --- a/include/configs/smdk6400.h +++ b/include/configs/smdk6400.h @@ -74,9 +74,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x18800300 -#define CS8900_BUS16 1 /* follow the Linux driver */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x18800300 +#define CONFIG_CS8900_BUS16 /* follow the Linux driver */
/* * select serial console configuration diff --git a/include/configs/trab.h b/include/configs/trab.h index 7687ee6..43c191b 100644 --- a/include/configs/trab.h +++ b/include/configs/trab.h @@ -99,9 +99,10 @@ /* * Hardware drivers */ -#define CONFIG_DRIVER_CS8900 1 /* we have a CS8900 on-board */ -#define CS8900_BASE 0x07000300 /* agrees with WIN CE PA */ -#define CS8900_BUS16 1 /* the Linux driver does accesses as shorts */ +#define CONFIG_NET_MULTI +#define CONFIG_CS8900 /* we have a CS8900 on-board */ +#define CONFIG_CS8900_BASE 0x07000300 /* agrees with WIN CE PA */ +#define CONFIG_CS8900_BUS16 /* the Linux driver does accesses as shorts */
diff --git a/include/netdev.h b/include/netdev.h index 3e66586..95d79a6 100644 --- a/include/netdev.h +++ b/include/netdev.h @@ -43,6 +43,7 @@ int cpu_eth_init(bd_t *bis); /* Driver initialization prototypes */ int au1x00_enet_initialize(bd_t*); int bfin_EMAC_initialize(bd_t *bis); +int cs8900_initialize(u8 dev_num, int base_addr); int dc21x4x_initialize(bd_t *bis); int davinci_emac_initialize(void); int dnet_eth_initialize(int id, void *regs, unsigned int phy_addr); diff --git a/lib_arm/board.c b/lib_arm/board.c index a44d308..fa87d51 100644 --- a/lib_arm/board.c +++ b/lib_arm/board.c @@ -73,10 +73,6 @@ extern void dataflash_print_info(void); const char version_string[] = U_BOOT_VERSION" (" U_BOOT_DATE " - " U_BOOT_TIME ")"CONFIG_IDENT_STRING;
-#ifdef CONFIG_DRIVER_CS8900 -extern void cs8900_get_enetaddr (void); -#endif - #ifdef CONFIG_DRIVER_RTL8019 extern void rtl8019_get_enetaddr (uchar * addr); #endif @@ -423,11 +419,6 @@ extern void davinci_eth_set_mac_addr (const u_int8_t *addr); } #endif
-#ifdef CONFIG_DRIVER_CS8900 - /* XXX: this needs to be moved to board init */ - cs8900_get_enetaddr (); -#endif - #if defined(CONFIG_DRIVER_SMC91111) || defined (CONFIG_DRIVER_LAN91C96) /* XXX: this needs to be moved to board init */ if (getenv ("ethaddr")) {
Applied to net/next
regards, Ben
Ben Warren
