[U-Boot-Users] [PATCH 2/8] mpc83xx: Remove cache config from config.h
clean up the cache config from configs.h of board
Signed-off-by: Dave Liu daveliu@freescale.com --- include/configs/MPC8313ERDB.h | 5 ----- include/configs/MPC8323ERDB.h | 9 --------- include/configs/MPC832XEMDS.h | 9 --------- include/configs/MPC8349EMDS.h | 7 ------- include/configs/MPC8349ITX.h | 9 --------- include/configs/MPC8360EMDS.h | 9 --------- include/configs/MPC837XEMDS.h | 9 --------- include/configs/TQM834x.h | 9 --------- include/configs/sbc8349.h | 7 ------- 9 files changed, 0 insertions(+), 73 deletions(-)
diff --git a/include/configs/MPC8313ERDB.h b/include/configs/MPC8313ERDB.h index 7bc4e27..455bbe0 100644 --- a/include/configs/MPC8313ERDB.h +++ b/include/configs/MPC8313ERDB.h @@ -386,11 +386,6 @@ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
-/* Cache Configuration */ -#define CFG_DCACHE_SIZE 16384 -#define CFG_CACHELINE_SIZE 32 -#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ - #define CFG_RCWH_PCIHOST 0x80000000 /* PCIHOST */
#ifdef CFG_66MHZ diff --git a/include/configs/MPC8323ERDB.h b/include/configs/MPC8323ERDB.h index 564de02..7831a2f 100644 --- a/include/configs/MPC8323ERDB.h +++ b/include/configs/MPC8323ERDB.h @@ -423,15 +423,6 @@ #define CFG_HID2 HID2_HBE
/* - * Cache Config - */ -#define CFG_DCACHE_SIZE 16384 -#define CFG_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value */ -#endif - -/* * MMU Setup */
diff --git a/include/configs/MPC832XEMDS.h b/include/configs/MPC832XEMDS.h index a48b311..1bbd0f9 100644 --- a/include/configs/MPC832XEMDS.h +++ b/include/configs/MPC832XEMDS.h @@ -482,15 +482,6 @@ #define CFG_HID2 HID2_HBE
diff --git a/include/configs/MPC8349EMDS.h b/include/configs/MPC8349EMDS.h index 03409bb..437a9a5 100644 --- a/include/configs/MPC8349EMDS.h +++ b/include/configs/MPC8349EMDS.h @@ -527,13 +527,6 @@ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
-/* Cache Configuration */ -#define CFG_DCACHE_SIZE 32768 -#define CFG_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ -#endif - #define CFG_RCWH_PCIHOST 0x80000000 /* PCIHOST */
#if 1 /*528/264*/ diff --git a/include/configs/MPC8349ITX.h b/include/configs/MPC8349ITX.h index 49dc0de..48c2736 100644 --- a/include/configs/MPC8349ITX.h +++ b/include/configs/MPC8349ITX.h @@ -487,15 +487,6 @@ boards, we say we have two, but don't display a message if we find only one. */ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
-/* - * Cache Configuration - */ -#define CFG_DCACHE_SIZE 32768 -#define CFG_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /* log2 of the above value */ -#endif - #define CFG_HRCW_LOW (\ HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ HRCWL_DDR_TO_SCB_CLK_1X1 |\ diff --git a/include/configs/MPC8360EMDS.h b/include/configs/MPC8360EMDS.h index fedb8a9..1a50741 100644 --- a/include/configs/MPC8360EMDS.h +++ b/include/configs/MPC8360EMDS.h @@ -512,15 +512,6 @@ #define CFG_HID2 HID2_HBE
/* - * Cache Config - */ -#define CFG_DCACHE_SIZE 32768 -#define CFG_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value */ -#endif - -/* * MMU Setup */
diff --git a/include/configs/MPC837XEMDS.h b/include/configs/MPC837XEMDS.h index 0958e6b..46fc239 100644 --- a/include/configs/MPC837XEMDS.h +++ b/include/configs/MPC837XEMDS.h @@ -459,15 +459,6 @@ #define CFG_HID2 HID2_HBE
diff --git a/include/configs/TQM834x.h b/include/configs/TQM834x.h index 0147252..8ef3f09 100644 --- a/include/configs/TQM834x.h +++ b/include/configs/TQM834x.h @@ -378,15 +378,6 @@ extern int tqm834x_num_flash_banks; */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
-/* - * Cache Configuration - */ -#define CFG_DCACHE_SIZE 32768 -#define CFG_CACHELINE_SIZE 32 -#if defined(CONFIG_CMD_KGDB) -#define CFG_CACHELINE_SHIFT 5 /*log base 2 of the above value*/ -#endif - #define CFG_HRCW_LOW (\ HRCWL_LCL_BUS_TO_SCB_CLK_1X1 |\ HRCWL_DDR_TO_SCB_CLK_1X1 |\ diff --git a/include/configs/sbc8349.h b/include/configs/sbc8349.h index 9efe3c4..4cc4ff1 100644 --- a/include/configs/sbc8349.h +++ b/include/configs/sbc8349.h @@ -490,13 +490,6 @@ */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux*/
#if 1 /*528/264*/
Dave Liu
