[U-Boot] Pull request - net
Wolfgang,
The following changes since commit 311c19ccb5783a1de71fd5042eeadfbe9688f597: Wolfgang Denk (1): Merge branch 'master' of git://git.denx.de/u-boot-ppc4xx
git://git.denx.de/u-boot-net.git master
Ben Warren (2): Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI API Add information about return values of xxx_eth_register() in documentation
James Clough (1): net: Fix problem with 405EZ ethernet interrupt
Mike Frysinger (2): net: add random_port() prototype document network driver framework
Prafulla Wadaskar (2): net: phy: mv88e61xx.c : fixed build warning net: kirkwood_egiga.c: fixed build warning
board/altera/ep1c20/ep1c20.c | 12 + board/altera/ep1s10/ep1s10.c | 12 + board/altera/ep1s40/ep1s40.c | 12 + board/armltd/integrator/integrator.c | 13 +- board/armltd/versatile/versatile.c | 12 + board/bf533-ezkit/bf533-ezkit.c | 8 + board/bf533-stamp/bf533-stamp.c | 8 + board/bf538f-ezkit/bf538f-ezkit.c | 8 + board/bf561-ezkit/bf561-ezkit.c | 8 + board/blackstamp/blackstamp.c | 8 + board/cerf250/cerf250.c | 12 + board/cm-bf533/cm-bf533.c | 8 + board/cm-bf561/cm-bf561.c | 8 + board/cradle/cradle.c | 12 + board/delta/delta.c | 12 + board/dnp1110/dnp1110.c | 12 + board/gaisler/gr_cpci_ax2000/gr_cpci_ax2000.c | 12 + board/gaisler/gr_ep2s60/gr_ep2s60.c | 12 + board/innokom/innokom.c | 12 + board/logodl/logodl.c | 12 + board/lpd7a40x/lpd7a40x.c | 12 + board/ms7722se/ms7722se.c | 12 + board/netstar/eeprom.c | 57 ++-- board/netstar/netstar.c | 12 + board/psyent/pk1c20/pk1c20.c | 12 + board/pxa255_idp/pxa_idp.c | 12 + board/renesas/MigoR/migo_r.c | 12 + board/st/nhk8815/nhk8815.c | 12 + board/voiceblue/eeprom.c | 57 ++-- board/voiceblue/voiceblue.c | 12 + board/xaeniax/xaeniax.c | 12 + board/xm250/xm250.c | 12 + board/xsengine/xsengine.c | 12 + board/zylonite/zylonite.c | 12 + doc/README.drivers.eth | 182 ++++++++ drivers/net/4xx_enet.c | 9 + drivers/net/Makefile | 2 +- drivers/net/kirkwood_egiga.c | 4 +- drivers/net/phy/mv88e61xx.c | 4 +- drivers/net/smc91111.c | 611 +++++++++---------------- drivers/net/smc91111.h | 192 ++++---- examples/standalone/smc91111_eeprom.c | 102 +++-- include/configs/EP1C20.h | 3 +- include/configs/EP1S10.h | 3 +- include/configs/EP1S40.h | 3 +- include/configs/MigoR.h | 3 +- include/configs/PK1C20.h | 3 +- include/configs/bf533-ezkit.h | 8 +- include/configs/bf533-stamp.h | 8 +- include/configs/bf538f-ezkit.h | 3 +- include/configs/bf561-ezkit.h | 3 +- include/configs/blackstamp.h | 7 +- include/configs/cerf250.h | 3 +- include/configs/cm-bf533.h | 3 +- include/configs/cm-bf561.h | 3 +- include/configs/cradle.h | 3 +- include/configs/dnp1110.h | 3 +- include/configs/gr_cpci_ax2000.h | 3 +- include/configs/gr_ep2s60.h | 3 +- include/configs/innokom.h | 3 +- include/configs/integratorcp.h | 3 +- include/configs/logodl.h | 3 +- include/configs/lpd7a400-10.h | 3 +- include/configs/lpd7a404-10.h | 3 +- include/configs/ms7722se.h | 3 +- include/configs/netstar.h | 3 +- include/configs/nhk8815.h | 3 +- include/configs/pxa255_idp.h | 3 +- include/configs/versatile.h | 3 +- include/configs/voiceblue.h | 3 +- include/configs/xaeniax.h | 3 +- include/configs/xm250.h | 3 +- include/configs/xsengine.h | 3 +- include/configs/zylonite.h | 2 +- include/net.h | 3 + include/netdev.h | 1 + 76 files changed, 1048 insertions(+), 642 deletions(-) create mode 100644 doc/README.drivers.eth
Dear Ben Warren,
In message 4AC99FF1.3040008@gmail.com you wrote:
Wolfgang,
Applied, thanks.
Ben Warren
