[PATCH v2 0/2] Fix device removal order for Apple dart iommu
Starting with v2024.10 dev_iommu_dma_unmap calls during device removal trigger a NULL pointer dereference in the Apple dart iommu driver. The iommu device is removed before its user. The sparsely used DM_FLAG_VITAL flag is intended to describe this dependency. Add it to the driver.
Adding this flag is unfortunately not enough since the boot routines except the arm one simply remove all drivers. Add and use a new function which calls dm_remove_devioce_flags(DM_REMOVE_ACTIVE_ALL | DM_REMOVE_NON_VITAL); dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); to ensure this order dependency is head consistently.
Signed-off-by: Janne Grunau j@jannau.net --- Changes in v2: - added Mark's Ab: for Patch 1 - add dm_remove_device_active() and replace existing dm_remove_device_flags(DM_REMOVE_ACTIVE_ALL) with it (ignoring test code) - Link to v1: https://lore.kernel.org/r/20241031-iommu_apple_dart_ordering-v1-0-8a6877946d...
--- Janne Grunau (2): iommu: apple: Mark device with DM_FLAG_VITAL dm: Add dm_remove_devices_active() for ordered device removal
arch/arm/lib/bootm.c | 7 +++--- arch/riscv/lib/bootm.c | 2 +- arch/x86/lib/bootm.c | 2 +- drivers/core/root.c | 7 ++++++ drivers/iommu/apple_dart.c | 2 +- include/dm/root.h | 10 +++++++++ lib/efi_loader/efi_boottime.c | 2 +- test/dm/core.c | 50 +++++++++++++++++++++++++++++++++++++++++++ 8 files changed, 74 insertions(+), 8 deletions(-) --- base-commit: cca05617a8f585f3a98a8fa82f75cc68a530d771 change-id: 20241031-iommu_apple_dart_ordering-558e62671512
Avoids NULL pointer dereferences in apple_dart_unmap when the iommu device is removed before its user. U-boot's device model does not track dependencies between devices. Observed on a M1 Ultra Mac Studio with v2024.10.
Acked-by: Mark Kettenis kettenis@openbsd.org Signed-off-by: Janne Grunau j@jannau.net --- drivers/iommu/apple_dart.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/iommu/apple_dart.c b/drivers/iommu/apple_dart.c index 3e9e7819e517b8fe62b9e429b7a8ca3eca29741d..bfd4ad2010547de34d67f48e9b58295429ca8d3c 100644 --- a/drivers/iommu/apple_dart.c +++ b/drivers/iommu/apple_dart.c @@ -322,5 +322,5 @@ U_BOOT_DRIVER(apple_dart) = { .ops = &apple_dart_ops, .probe = apple_dart_probe, .remove = apple_dart_remove, - .flags = DM_FLAG_OS_PREPARE + .flags = DM_FLAG_OS_PREPARE | DM_FLAG_VITAL };
This replaces dm_remove_devices_flags() calls in all boot implementations to ensure non vital devices are consistently removed first. All boot implementation except arch/arm/lib/bootm.c currently just call dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL). This can result in crashes when dependencies between devices exists. The driver model's design document describes DM_FLAG_VITAL as "indicates that the device is 'vital' to the operation of other devices". Device removal at boot should follow this.
Instead of adding dm_remove_devices_flags() with (DM_REMOVE_ACTIVE_ALL | DM_REMOVE_NON_VITAL) everywhere add dm_remove_devices_active() which does this.
Fixes a NULL pointer deref in the apple dart IOMMU driver during EFI boot. The xhci-pci (driver which depends on the IOMMU to work) removes its mapping on removal. This explodes when the IOMMU device was removed first.
dm_remove_devices_flags() is kept since it is used for testing of device_remove() calls in dm.
Signed-off-by: Janne Grunau j@jannau.net --- arch/arm/lib/bootm.c | 7 +++--- arch/riscv/lib/bootm.c | 2 +- arch/x86/lib/bootm.c | 2 +- drivers/core/root.c | 7 ++++++ include/dm/root.h | 10 +++++++++ lib/efi_loader/efi_boottime.c | 2 +- test/dm/core.c | 50 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 73 insertions(+), 7 deletions(-)
diff --git a/arch/arm/lib/bootm.c b/arch/arm/lib/bootm.c index 192c120a7d2ebe8a2c57f92b424c1699fd8e0e35..974cbfe8400eafb180e99039b4f1a61d52c898b8 100644 --- a/arch/arm/lib/bootm.c +++ b/arch/arm/lib/bootm.c @@ -73,11 +73,10 @@ static void announce_and_cleanup(int fake) * Call remove function of all devices with a removal flag set. * This may be useful for last-stage operations, like cancelling * of DMA operation or releasing device internal buffers. + * dm_remove_devices_active() ensures that vital devices are removed in + * a second round. */ - dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL | DM_REMOVE_NON_VITAL); - - /* Remove all active vital devices next */ - dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + dm_remove_devices_active();
cleanup_before_linux(); } diff --git a/arch/riscv/lib/bootm.c b/arch/riscv/lib/bootm.c index 82502972eec5148b8a36b45eef412a3ec2adb48c..76c610bcee03034cb34d850dbbdbe83cfd75cbd3 100644 --- a/arch/riscv/lib/bootm.c +++ b/arch/riscv/lib/bootm.c @@ -57,7 +57,7 @@ static void announce_and_cleanup(int fake) * This may be useful for last-stage operations, like cancelling * of DMA operation or releasing device internal buffers. */ - dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + dm_remove_devices_active();
cleanup_before_linux(); } diff --git a/arch/x86/lib/bootm.c b/arch/x86/lib/bootm.c index 55f581836dfa6ea76f2b6ba63709544757d3bd52..0f79a5d54959fd50ffaadfefb3f7fedb841699c9 100644 --- a/arch/x86/lib/bootm.c +++ b/arch/x86/lib/bootm.c @@ -49,7 +49,7 @@ void bootm_announce_and_cleanup(void) * This may be useful for last-stage operations, like cancelling * of DMA operation or releasing device internal buffers. */ - dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + dm_remove_devices_active(); }
#if defined(CONFIG_OF_LIBFDT) && !defined(CONFIG_OF_NO_KERNEL) diff --git a/drivers/core/root.c b/drivers/core/root.c index 7a714f5478a9f3953b33de0e0ca78fe95db569f3..c7fb58285ca21ecb8c659ec9f3c203819056abec 100644 --- a/drivers/core/root.c +++ b/drivers/core/root.c @@ -147,6 +147,13 @@ int dm_remove_devices_flags(uint flags)
return 0; } + +void dm_remove_devices_active(void) +{ + /* Remove non-vital devices first */ + device_remove(dm_root(), DM_REMOVE_ACTIVE_ALL | DM_REMOVE_NON_VITAL); + device_remove(dm_root(), DM_REMOVE_ACTIVE_ALL); +} #endif
int dm_scan_plat(bool pre_reloc_only) diff --git a/include/dm/root.h b/include/dm/root.h index b2f30a842f515d70982ec8af7599a86d12002176..5651b868c8b88267d0b7fd7564d53fb519140b76 100644 --- a/include/dm/root.h +++ b/include/dm/root.h @@ -167,8 +167,18 @@ int dm_uninit(void); * Return: 0 if OK, -ve on error */ int dm_remove_devices_flags(uint flags); + +/** + * dm_remove_devices_active - Call remove function of all active drivers heeding + * device dependencies as far as know, i.e. removing + * devices marked with DM_FLAG_VITAL last. + * + * All active devices will be removed + */ +void dm_remove_devices_active(void); #else static inline int dm_remove_devices_flags(uint flags) { return 0; } +static inline void dm_remove_devices_active(void) { } #endif
/** diff --git a/lib/efi_loader/efi_boottime.c b/lib/efi_loader/efi_boottime.c index 4f52284b4c653c252b0ed6c0c87da8901448d4b4..080e7f78ae37a45d1e83566806b1fe2582160f2c 100644 --- a/lib/efi_loader/efi_boottime.c +++ b/lib/efi_loader/efi_boottime.c @@ -2234,7 +2234,7 @@ static efi_status_t EFIAPI efi_exit_boot_services(efi_handle_t image_handle, if (IS_ENABLED(CONFIG_USB_DEVICE)) udc_disconnect(); board_quiesce_devices(); - dm_remove_devices_flags(DM_REMOVE_ACTIVE_ALL); + dm_remove_devices_active(); }
/* Patch out unsupported runtime function */ diff --git a/test/dm/core.c b/test/dm/core.c index 7371d3ff42695b4eabaf8ff4b31e4197b3a0c8f8..c59ffc6f61126cad3f7b22b5bd66a5126824be8e 100644 --- a/test/dm/core.c +++ b/test/dm/core.c @@ -999,6 +999,56 @@ static int dm_test_remove_vital(struct unit_test_state *uts) } DM_TEST(dm_test_remove_vital, 0);
+/* Test removal of 'active' devices */ +static int dm_test_remove_active(struct unit_test_state *uts) +{ + struct udevice *normal, *dma, *vital, *dma_vital; + + /* Skip the behaviour in test_post_probe() */ + uts->skip_post_probe = 1; + + ut_assertok(device_bind_by_name(uts->root, false, &driver_info_manual, + &normal)); + ut_assertnonnull(normal); + + ut_assertok(device_bind_by_name(uts->root, false, &driver_info_act_dma, + &dma)); + ut_assertnonnull(dma); + + ut_assertok(device_bind_by_name(uts->root, false, + &driver_info_vital_clk, &vital)); + ut_assertnonnull(vital); + + ut_assertok(device_bind_by_name(uts->root, false, + &driver_info_act_dma_vital_clk, + &dma_vital)); + ut_assertnonnull(dma_vital); + + /* Probe the devices */ + ut_assertok(device_probe(normal)); + ut_assertok(device_probe(dma)); + ut_assertok(device_probe(vital)); + ut_assertok(device_probe(dma_vital)); + + /* Check that devices are active right now */ + ut_asserteq(true, device_active(normal)); + ut_asserteq(true, device_active(dma)); + ut_asserteq(true, device_active(vital)); + ut_asserteq(true, device_active(dma_vital)); + + /* Remove active devices in an ordered way */ + dm_remove_devices_active(); + + /* Check that all devices are inactive right now */ + ut_asserteq(true, device_active(normal)); + ut_asserteq(false, device_active(dma)); + ut_asserteq(true, device_active(vital)); + ut_asserteq(false, device_active(dma_vital)); + + return 0; +} +DM_TEST(dm_test_remove_active, 0); + static int dm_test_uclass_before_ready(struct unit_test_state *uts) { struct uclass *uc;
Janne Grunau via B4 Relay
