[U-Boot] [PATCH v2 00/28] Add and update drivers for MediaTek MT76x8 SoCs
This patch series have the following changes:
- Add pinctrl(both pinmux and pinconf) driver, reset controller driver and clock driver for mt7628. - Add mt7628 platform to mtk-sd driver. - Modify mt7628's ethernet & usb phy driver to take advantages from the new drivers. - Update mt7621-spi driver with a new transfer method. - Enable fifo, disable flow control, and enable non-DM implementation for mtk hsuart driver. - Enanble the new drivers for currently existed mt7628 boards.
Changes of v2: - Change clock gateing driver to a more 'generic' driver which supports output clock rates of CPU/SYS_BUS/peripherals. - mt7621-spi now uses accurate sys_freq from clock driver. - Make PHY link detection optional via DT. - Select essential drivers in Kconfig instead of setting in defconfig files.
Weijie Gao (28): serial: serial_mtk: enable FIFO and disable flow control serial: serial_mtk: add non-DM version for SPL dts: mtmips: move uart property clock-frequency into mt7628an.dtsi dts: mtmips: enable high-speed UART support for mt7628 clk: add clock driver for MediaTek MT76x8 platform dts: mtmips: add clock node for mt7628 spi: mt7621-spi: use clock frequency from clk driver spi: mt7621-spi: remove data cache and rewrite its xfer function spi: mt7621-spi: restore default register value after each xfer pinctrl: add support for MediaTek MT7628 dts: mtmips: add pinctrl node for mt7628 dts: mtmips: add default pinctrl for uart nodes reset: add reset controller driver for MediaTek MIPS platform dts: mtmips: update reset controller node for mt7628 phy: mt76x8-usb-phy: add slew rate calibration and remove non-mt7628 part net: mt7628-eth: remove hardcoded gpio settings and regmap-based phy reset net: mt7628-eth: make phy link up detection optional via DT net: mt7628-eth: free rx descriptor on receiving failure net: mt7628-eth: add support to isolate LAN/WAN ports dts: mtmips: enable eth port0 led and link poll functions for all boards mmc: mtk-sd: add support for MediaTek MT7620/MT7628 SoCs mmc: mtk-sd: add a dts property cd-active-high for builtin-cd mode dts: mtmips: add mmc related nodes for mt7628an.dtsi dts: mtmips: add default pinctrl for gardena-smart-gateway-mt7688 dts: mtmips: add default pinctrl to eth nodes for all boards mips: mtmips: change baudrate table for all boards mips: mtmips: select essential drivers in Kconfig configs: mtmips: remove configs which are selected in Kconfig or useless
arch/mips/Kconfig | 6 + .../mips/dts/gardena-smart-gateway-mt7688.dts | 19 +- arch/mips/dts/linkit-smart-7688.dts | 16 +- arch/mips/dts/mt7628a.dtsi | 246 +++++++- arch/mips/mach-mtmips/Kconfig | 2 + ...gardena-smart-gateway-mt7688-ram_defconfig | 7 - .../gardena-smart-gateway-mt7688_defconfig | 7 - configs/linkit-smart-7688-ram_defconfig | 7 - configs/linkit-smart-7688_defconfig | 7 - drivers/clk/Makefile | 1 + drivers/clk/mtmips/Makefile | 3 + drivers/clk/mtmips/clk-mt7628.c | 158 +++++ drivers/mmc/Kconfig | 2 +- drivers/mmc/mtk-sd.c | 32 +- drivers/net/Kconfig | 1 + drivers/net/mt7628-eth.c | 135 ++-- drivers/phy/Kconfig | 2 + drivers/phy/mt76x8-usb-phy.c | 225 +++++-- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/mtmips/Kconfig | 13 + drivers/pinctrl/mtmips/Makefile | 7 + drivers/pinctrl/mtmips/pinctrl-mt7628.c | 585 ++++++++++++++++++ .../pinctrl/mtmips/pinctrl-mtmips-common.c | 87 +++ .../pinctrl/mtmips/pinctrl-mtmips-common.h | 53 ++ drivers/reset/Kconfig | 7 + drivers/reset/Makefile | 1 + drivers/reset/reset-mtmips.c | 82 +++ drivers/serial/serial.c | 2 + drivers/serial/serial_mtk.c | 223 ++++++- drivers/spi/mt7621_spi.c | 247 ++++---- .../configs/gardena-smart-gateway-mt7688.h | 2 +- include/configs/linkit-smart-7688.h | 2 +- include/dt-bindings/clock/mt7628-clk.h | 37 ++ include/dt-bindings/reset/mt7628-reset.h | 36 ++ 35 files changed, 1933 insertions(+), 329 deletions(-) create mode 100644 drivers/clk/mtmips/Makefile create mode 100644 drivers/clk/mtmips/clk-mt7628.c create mode 100644 drivers/pinctrl/mtmips/Kconfig create mode 100644 drivers/pinctrl/mtmips/Makefile create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7628.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mtmips-common.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mtmips-common.h create mode 100644 drivers/reset/reset-mtmips.c create mode 100644 include/dt-bindings/clock/mt7628-clk.h create mode 100644 include/dt-bindings/reset/mt7628-reset.h
This patch adds codes to enable FIFO and disable flow control taken from ns16550 driver.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/serial/serial_mtk.c | 21 +++++++++++++++++++++ 1 file changed, 21 insertions(+)
diff --git a/drivers/serial/serial_mtk.c b/drivers/serial/serial_mtk.c index bce1be8227..11892a8740 100644 --- a/drivers/serial/serial_mtk.c +++ b/drivers/serial/serial_mtk.c @@ -46,6 +46,22 @@ struct mtk_serial_regs {
#define UART_LSR_DR 0x01 /* Data ready */ #define UART_LSR_THRE 0x20 /* Xmit holding register empty */ +#define UART_LSR_TEMT 0x40 /* Xmitter empty */ + +#define UART_MCR_DTR 0x01 /* DTR */ +#define UART_MCR_RTS 0x02 /* RTS */ + +#define UART_FCR_FIFO_EN 0x01 /* Fifo enable */ +#define UART_FCR_RXSR 0x02 /* Receiver soft reset */ +#define UART_FCR_TXSR 0x04 /* Transmitter soft reset */ + +#define UART_MCRVAL (UART_MCR_DTR | \ + UART_MCR_RTS) + +/* Clear & enable FIFOs */ +#define UART_FCRVAL (UART_FCR_FIFO_EN | \ + UART_FCR_RXSR | \ + UART_FCR_TXSR)
/* the data is correct if the real baud is within 3%. */ #define BAUD_ALLOW_MAX(baud) ((baud) + (baud) * 3 / 100) @@ -175,6 +191,9 @@ static int mtk_serial_probe(struct udevice *dev) /* Disable interrupt */ writel(0, &priv->regs->ier);
+ writel(UART_MCRVAL, &priv->regs->mcr); + writel(UART_FCRVAL, &priv->regs->fcr); + return 0; }
@@ -248,6 +267,8 @@ static inline void _debug_uart_init(void) priv.clock = CONFIG_DEBUG_UART_CLOCK;
writel(0, &priv.regs->ier); + writel(UART_MCRVAL, &priv.regs->mcr); + writel(UART_FCRVAL, &priv.regs->fcr);
_mtk_serial_setbrg(&priv, CONFIG_BAUDRATE); }
This patch adds non-DM version for mtk hsuart driver and makes it compatible with ns16550a driver in configuration. This is needed in SPL with CONFIG_SPL_DM disabled for reducing size.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/serial/serial.c | 2 + drivers/serial/serial_mtk.c | 202 +++++++++++++++++++++++++++++++++--- 2 files changed, 187 insertions(+), 17 deletions(-)
diff --git a/drivers/serial/serial.c b/drivers/serial/serial.c index b907508dbe..bf5f39215d 100644 --- a/drivers/serial/serial.c +++ b/drivers/serial/serial.c @@ -124,6 +124,7 @@ serial_initfunc(ns16550_serial_initialize); serial_initfunc(pl01x_serial_initialize); serial_initfunc(pxa_serial_initialize); serial_initfunc(sh_serial_initialize); +serial_initfunc(mtk_serial_initialize);
/** * serial_register() - Register serial driver with serial driver core @@ -177,6 +178,7 @@ void serial_initialize(void) pl01x_serial_initialize(); pxa_serial_initialize(); sh_serial_initialize(); + mtk_serial_initialize();
serial_assign(default_serial_console()->name); } diff --git a/drivers/serial/serial_mtk.c b/drivers/serial/serial_mtk.c index 11892a8740..18530a4fd1 100644 --- a/drivers/serial/serial_mtk.c +++ b/drivers/serial/serial_mtk.c @@ -140,6 +140,37 @@ static void _mtk_serial_setbrg(struct mtk_serial_priv *priv, int baud) } }
+static int _mtk_serial_putc(struct mtk_serial_priv *priv, const char ch) +{ + if (!(readl(&priv->regs->lsr) & UART_LSR_THRE)) + return -EAGAIN; + + writel(ch, &priv->regs->thr); + + if (ch == '\n') + WATCHDOG_RESET(); + + return 0; +} + +static int _mtk_serial_getc(struct mtk_serial_priv *priv) +{ + if (!(readl(&priv->regs->lsr) & UART_LSR_DR)) + return -EAGAIN; + + return readl(&priv->regs->rbr); +} + +static int _mtk_serial_pending(struct mtk_serial_priv *priv, bool input) +{ + if (input) + return (readl(&priv->regs->lsr) & UART_LSR_DR) ? 1 : 0; + else + return (readl(&priv->regs->lsr) & UART_LSR_THRE) ? 0 : 1; +} + +#if defined(CONFIG_DM_SERIAL) && \ + (!defined(CONFIG_SPL_BUILD) || defined(CONFIG_SPL_DM)) static int mtk_serial_setbrg(struct udevice *dev, int baudrate) { struct mtk_serial_priv *priv = dev_get_priv(dev); @@ -153,35 +184,21 @@ static int mtk_serial_putc(struct udevice *dev, const char ch) { struct mtk_serial_priv *priv = dev_get_priv(dev);
- if (!(readl(&priv->regs->lsr) & UART_LSR_THRE)) - return -EAGAIN; - - writel(ch, &priv->regs->thr); - - if (ch == '\n') - WATCHDOG_RESET(); - - return 0; + return _mtk_serial_putc(priv, ch); }
static int mtk_serial_getc(struct udevice *dev) { struct mtk_serial_priv *priv = dev_get_priv(dev);
- if (!(readl(&priv->regs->lsr) & UART_LSR_DR)) - return -EAGAIN; - - return readl(&priv->regs->rbr); + return _mtk_serial_getc(priv); }
static int mtk_serial_pending(struct udevice *dev, bool input) { struct mtk_serial_priv *priv = dev_get_priv(dev);
- if (input) - return (readl(&priv->regs->lsr) & UART_LSR_DR) ? 1 : 0; - else - return (readl(&priv->regs->lsr) & UART_LSR_THRE) ? 0 : 1; + return _mtk_serial_pending(priv, input); }
static int mtk_serial_probe(struct udevice *dev) @@ -254,6 +271,157 @@ U_BOOT_DRIVER(serial_mtk) = { .ops = &mtk_serial_ops, .flags = DM_FLAG_PRE_RELOC, }; +#else + +DECLARE_GLOBAL_DATA_PTR; + +#define DECLARE_HSUART_PRIV(port) \ + static struct mtk_serial_priv mtk_hsuart##port = { \ + .regs = (struct mtk_serial_regs *)CONFIG_SYS_NS16550_COM##port, \ + .clock = CONFIG_SYS_NS16550_CLK \ +}; + +#define DECLARE_HSUART_FUNCTIONS(port) \ + static int mtk_serial##port##_init(void) \ + { \ + writel(0, &mtk_hsuart##port.regs->ier); \ + writel(UART_MCRVAL, &mtk_hsuart##port.regs->mcr); \ + writel(UART_FCRVAL, &mtk_hsuart##port.regs->fcr); \ + _mtk_serial_setbrg(&mtk_hsuart##port, gd->baudrate); \ + return 0 ; \ + } \ + static void mtk_serial##port##_setbrg(void) \ + { \ + _mtk_serial_setbrg(&mtk_hsuart##port, gd->baudrate); \ + } \ + static int mtk_serial##port##_getc(void) \ + { \ + int err; \ + do { \ + err = _mtk_serial_getc(&mtk_hsuart##port); \ + if (err == -EAGAIN) \ + WATCHDOG_RESET(); \ + } while (err == -EAGAIN); \ + return err >= 0 ? err : 0; \ + } \ + static int mtk_serial##port##_tstc(void) \ + { \ + return _mtk_serial_pending(&mtk_hsuart##port, true); \ + } \ + static void mtk_serial##port##_putc(const char c) \ + { \ + int err; \ + if (c == '\n') \ + mtk_serial##port##_putc('\r'); \ + do { \ + err = _mtk_serial_putc(&mtk_hsuart##port, c); \ + } while (err == -EAGAIN); \ + } \ + static void mtk_serial##port##_puts(const char *s) \ + { \ + while (*s) { \ + mtk_serial##port##_putc(*s++); \ + } \ + } + +/* Serial device descriptor */ +#define INIT_HSUART_STRUCTURE(port, __name) { \ + .name = __name, \ + .start = mtk_serial##port##_init, \ + .stop = NULL, \ + .setbrg = mtk_serial##port##_setbrg, \ + .getc = mtk_serial##port##_getc, \ + .tstc = mtk_serial##port##_tstc, \ + .putc = mtk_serial##port##_putc, \ + .puts = mtk_serial##port##_puts, \ +} + +#define DECLARE_HSUART(port, __name) \ + DECLARE_HSUART_PRIV(port); \ + DECLARE_HSUART_FUNCTIONS(port); \ + struct serial_device mtk_hsuart##port##_device = \ + INIT_HSUART_STRUCTURE(port, __name); + +#if !defined(CONFIG_CONS_INDEX) +#elif (CONFIG_CONS_INDEX < 1) || (CONFIG_CONS_INDEX > 6) +#error "Invalid console index value." +#endif + +#if CONFIG_CONS_INDEX == 1 && !defined(CONFIG_SYS_NS16550_COM1) +#error "Console port 1 defined but not configured." +#elif CONFIG_CONS_INDEX == 2 && !defined(CONFIG_SYS_NS16550_COM2) +#error "Console port 2 defined but not configured." +#elif CONFIG_CONS_INDEX == 3 && !defined(CONFIG_SYS_NS16550_COM3) +#error "Console port 3 defined but not configured." +#elif CONFIG_CONS_INDEX == 4 && !defined(CONFIG_SYS_NS16550_COM4) +#error "Console port 4 defined but not configured." +#elif CONFIG_CONS_INDEX == 5 && !defined(CONFIG_SYS_NS16550_COM5) +#error "Console port 5 defined but not configured." +#elif CONFIG_CONS_INDEX == 6 && !defined(CONFIG_SYS_NS16550_COM6) +#error "Console port 6 defined but not configured." +#endif + +#if defined(CONFIG_SYS_NS16550_COM1) +DECLARE_HSUART(1, "mtk-hsuart0"); +#endif +#if defined(CONFIG_SYS_NS16550_COM2) +DECLARE_HSUART(2, "mtk-hsuart1"); +#endif +#if defined(CONFIG_SYS_NS16550_COM3) +DECLARE_HSUART(3, "mtk-hsuart2"); +#endif +#if defined(CONFIG_SYS_NS16550_COM4) +DECLARE_HSUART(4, "mtk-hsuart3"); +#endif +#if defined(CONFIG_SYS_NS16550_COM5) +DECLARE_HSUART(5, "mtk-hsuart4"); +#endif +#if defined(CONFIG_SYS_NS16550_COM6) +DECLARE_HSUART(6, "mtk-hsuart5"); +#endif + +__weak struct serial_device *default_serial_console(void) +{ +#if CONFIG_CONS_INDEX == 1 + return &mtk_hsuart1_device; +#elif CONFIG_CONS_INDEX == 2 + return &mtk_hsuart2_device; +#elif CONFIG_CONS_INDEX == 3 + return &mtk_hsuart3_device; +#elif CONFIG_CONS_INDEX == 4 + return &mtk_hsuart4_device; +#elif CONFIG_CONS_INDEX == 5 + return &mtk_hsuart5_device; +#elif CONFIG_CONS_INDEX == 6 + return &mtk_hsuart6_device; +#else +#error "Bad CONFIG_CONS_INDEX." +#endif +} + +void mtk_serial_initialize(void) +{ +#if defined(CONFIG_SYS_NS16550_COM1) + serial_register(&mtk_hsuart1_device); +#endif +#if defined(CONFIG_SYS_NS16550_COM2) + serial_register(&mtk_hsuart2_device); +#endif +#if defined(CONFIG_SYS_NS16550_COM3) + serial_register(&mtk_hsuart3_device); +#endif +#if defined(CONFIG_SYS_NS16550_COM4) + serial_register(&mtk_hsuart4_device); +#endif +#if defined(CONFIG_SYS_NS16550_COM5) + serial_register(&mtk_hsuart5_device); +#endif +#if defined(CONFIG_SYS_NS16550_COM6) + serial_register(&mtk_hsuart6_device); +#endif +} + +#endif
#ifdef CONFIG_DEBUG_UART_MTK
The UART of MT7628 has fixed 40MHz input clock so there is no need to put clock-frequency in every dts files. Just put it into the common dtsi file.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 1 - arch/mips/dts/linkit-smart-7688.dts | 1 - arch/mips/dts/mt7628a.dtsi | 6 ++++++ 3 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts index eedde89dfd..95675a3947 100644 --- a/arch/mips/dts/gardena-smart-gateway-mt7688.dts +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -87,7 +87,6 @@
&uart0 { status = "okay"; - clock-frequency = <40000000>; };
&spi0 { diff --git a/arch/mips/dts/linkit-smart-7688.dts b/arch/mips/dts/linkit-smart-7688.dts index bb10402174..935315743c 100644 --- a/arch/mips/dts/linkit-smart-7688.dts +++ b/arch/mips/dts/linkit-smart-7688.dts @@ -28,7 +28,6 @@
&uart2 { status = "okay"; - clock-frequency = <40000000>; };
&spi0 { diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 1e7d0a6ec5..6bc0722b07 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -127,6 +127,8 @@ compatible = "ns16550a"; reg = <0xc00 0x100>;
+ clock-frequency = <40000000>; + resets = <&resetc 12>; reset-names = "uart0";
@@ -140,6 +142,8 @@ compatible = "ns16550a"; reg = <0xd00 0x100>;
+ clock-frequency = <40000000>; + resets = <&resetc 19>; reset-names = "uart1";
@@ -153,6 +157,8 @@ compatible = "ns16550a"; reg = <0xe00 0x100>;
+ clock-frequency = <40000000>; + resets = <&resetc 20>; reset-names = "uart2";
All three UARTs of mt7628 are actually MediaTek's high-speed UARTs which support baudrate up to 921600. The high-speed UART is compatible with ns16550 when baudrate <= 115200.
Add compatible string to dtsi file so u-boot can use it when serial_mtk driver is built in.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/mt7628a.dtsi | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 6bc0722b07..e9241a0737 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -124,7 +124,7 @@ };
uart0: uartlite@c00 { - compatible = "ns16550a"; + compatible = "mediatek,hsuart", "ns16550a"; reg = <0xc00 0x100>;
clock-frequency = <40000000>; @@ -139,7 +139,7 @@ };
uart1: uart1@d00 { - compatible = "ns16550a"; + compatible = "mediatek,hsuart", "ns16550a"; reg = <0xd00 0x100>;
clock-frequency = <40000000>; @@ -154,7 +154,7 @@ };
uart2: uart2@e00 { - compatible = "ns16550a"; + compatible = "mediatek,hsuart", "ns16550a"; reg = <0xe00 0x100>;
This patch adds a clock driver for MediaTek MT7628/7688 SoC. It provides clock gate control as well as getting clock frequency for CPU/SYS/XTAL and some peripherals.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Changed to a more generic clock driver rather than a gateing only driver. Now supports output clock rate of some devices which may be used in DT. --- drivers/clk/Makefile | 1 + drivers/clk/mtmips/Makefile | 3 + drivers/clk/mtmips/clk-mt7628.c | 158 +++++++++++++++++++++++++ include/dt-bindings/clock/mt7628-clk.h | 37 ++++++ 4 files changed, 199 insertions(+) create mode 100644 drivers/clk/mtmips/Makefile create mode 100644 drivers/clk/mtmips/clk-mt7628.c create mode 100644 include/dt-bindings/clock/mt7628-clk.h
diff --git a/drivers/clk/Makefile b/drivers/clk/Makefile index 68aabe1ca9..6a86894084 100644 --- a/drivers/clk/Makefile +++ b/drivers/clk/Makefile @@ -16,6 +16,7 @@ obj-y += imx/ obj-y += tegra/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_MEDIATEK) += mediatek/ +obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ obj-$(CONFIG_ARCH_MESON) += meson/ obj-$(CONFIG_ARCH_ROCKCHIP) += rockchip/ obj-$(CONFIG_ARCH_SOCFPGA) += altera/ diff --git a/drivers/clk/mtmips/Makefile b/drivers/clk/mtmips/Makefile new file mode 100644 index 0000000000..e1938418da --- /dev/null +++ b/drivers/clk/mtmips/Makefile @@ -0,0 +1,3 @@ +# SPDX-License-Identifier: GPL-2.0 + +obj-$(CONFIG_SOC_MT7628) += clk-mt7628.o diff --git a/drivers/clk/mtmips/clk-mt7628.c b/drivers/clk/mtmips/clk-mt7628.c new file mode 100644 index 0000000000..35780de8c4 --- /dev/null +++ b/drivers/clk/mtmips/clk-mt7628.c @@ -0,0 +1,158 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <clk-uclass.h> +#include <dm.h> +#include <dt-bindings/clock/mt7628-clk.h> +#include <linux/bitops.h> +#include <linux/io.h> + +/* SYSCFG0 */ +#define XTAL_40M_SEL BIT(6) + +/* CLKCFG0 */ +#define CLKCFG0_REG 0x0 +#define PERI_CLK_FROM_XTAL_SEL BIT(4) +#define CPU_PLL_FROM_BBP BIT(1) +#define CPU_PLL_FROM_XTAL BIT(0) + +/* CLKCFG1 */ +#define CLKCFG1_REG 0x4 + +#define CLK_SRC_CPU -1 +#define CLK_SRC_CPU_D2 -2 +#define CLK_SRC_SYS -3 +#define CLK_SRC_XTAL -4 +#define CLK_SRC_PERI -5 + +struct mt7628_clk_priv { + void __iomem *base; + int cpu_clk; + int sys_clk; + int xtal_clk; +}; + +static const int mt7628_clks[] = { + [CLK_SYS] = CLK_SRC_SYS, + [CLK_CPU] = CLK_SRC_CPU, + [CLK_XTAL] = CLK_SRC_XTAL, + [CLK_PWM] = CLK_SRC_PERI, + [CLK_MIPS_CNT] = CLK_SRC_CPU_D2, + [CLK_UART2] = CLK_SRC_PERI, + [CLK_UART1] = CLK_SRC_PERI, + [CLK_UART0] = CLK_SRC_PERI, + [CLK_SPI] = CLK_SRC_SYS, + [CLK_I2C] = CLK_SRC_PERI, +}; + +static ulong mt7628_clk_get_rate(struct clk *clk) +{ + struct mt7628_clk_priv *priv = dev_get_priv(clk->dev); + u32 val; + + if (clk->id >= ARRAY_SIZE(mt7628_clks)) + return 0; + + switch (mt7628_clks[clk->id]) { + case CLK_SRC_CPU: + return priv->cpu_clk; + case CLK_SRC_CPU_D2: + return priv->cpu_clk / 2; + case CLK_SRC_SYS: + return priv->sys_clk; + case CLK_SRC_XTAL: + return priv->xtal_clk; + case CLK_SRC_PERI: + val = readl(priv->base + CLKCFG0_REG); + if (val & PERI_CLK_FROM_XTAL_SEL) + return priv->xtal_clk; + else + return 40000000; + default: + return mt7628_clks[clk->id]; + } +} + +static int mt7628_clk_enable(struct clk *clk) +{ + struct mt7628_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id > 31) + return -1; + + setbits_32(priv->base + CLKCFG1_REG, BIT(clk->id)); + + return 0; +} + +static int mt7628_clk_disable(struct clk *clk) +{ + struct mt7628_clk_priv *priv = dev_get_priv(clk->dev); + + if (clk->id > 31) + return -1; + + clrbits_32(priv->base + CLKCFG1_REG, BIT(clk->id)); + + return 0; +} + +const struct clk_ops mt7628_clk_ops = { + .enable = mt7628_clk_enable, + .disable = mt7628_clk_disable, + .get_rate = mt7628_clk_get_rate, +}; + +static int mt7628_clk_probe(struct udevice *dev) +{ + struct mt7628_clk_priv *priv = dev_get_priv(dev); + void __iomem *syscfg_base; + u32 val; + + priv->base = (void __iomem *)dev_remap_addr_index(dev, 0); + if (!priv->base) + return -EINVAL; + + syscfg_base = (void __iomem *)dev_remap_addr_index(dev, 1); + if (!syscfg_base) + return -EINVAL; + + val = readl(syscfg_base); + if (val & XTAL_40M_SEL) + priv->xtal_clk = 40000000; + else + priv->xtal_clk = 25000000; + + val = readl(priv->base + CLKCFG0_REG); + if (val & CPU_PLL_FROM_BBP) + priv->cpu_clk = 480000000; + else if (val & CPU_PLL_FROM_XTAL) + priv->cpu_clk = priv->xtal_clk; + else if (priv->xtal_clk == 40000000) + priv->cpu_clk = 580000000; /* (xtal_freq / 2) * 29 */ + else + priv->cpu_clk = 575000000; /* xtal_freq * 23 */ + + priv->sys_clk = priv->cpu_clk / 3; + + return 0; +} + +static const struct udevice_id mt7628_clk_ids[] = { + { .compatible = "mediatek,mt7628-clk" }, + { } +}; + +U_BOOT_DRIVER(mt7628_clk) = { + .name = "mt7628-clk", + .id = UCLASS_CLK, + .of_match = mt7628_clk_ids, + .probe = mt7628_clk_probe, + .priv_auto_alloc_size = sizeof(struct mt7628_clk_priv), + .ops = &mt7628_clk_ops, +}; diff --git a/include/dt-bindings/clock/mt7628-clk.h b/include/dt-bindings/clock/mt7628-clk.h new file mode 100644 index 0000000000..b5866fdc0e --- /dev/null +++ b/include/dt-bindings/clock/mt7628-clk.h @@ -0,0 +1,37 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7628_CLK_H_ +#define _DT_BINDINGS_MT7628_CLK_H_ + +/* Base clocks */ +#define CLK_SYS 34 +#define CLK_CPU 33 +#define CLK_XTAL 32 + +/* Peripheral clocks */ +#define CLK_PWM 31 +#define CLK_SDXC 30 +#define CLK_CRYPTO 29 +#define CLK_MIPS_CNT 28 +#define CLK_PCIE 26 +#define CLK_UPHY 25 +#define CLK_ETH 23 +#define CLK_UART2 20 +#define CLK_UART1 19 +#define CLK_SPI 18 +#define CLK_I2S 17 +#define CLK_I2C 16 +#define CLK_GDMA 14 +#define CLK_PIO 13 +#define CLK_UART0 12 +#define CLK_PCM 11 +#define CLK_MC 10 +#define CLK_INTC 9 +#define CLK_TIMER 8 + +#endif /* _DT_BINDINGS_MT7628_CLK_H_ */
This patch adds clkctrl node for mt7628 and adds clocks property for some node.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Changed clkgate node to clkctrl node. Replaced clock-frequency with <&clkctrl CLK_UARTx> for uarts and spi. --- arch/mips/dts/mt7628a.dtsi | 21 +++++++++++++++++---- 1 file changed, 17 insertions(+), 4 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index e9241a0737..6d2142f429 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -1,4 +1,5 @@ // SPDX-License-Identifier: GPL-2.0 +#include <dt-bindings/clock/mt7628-clk.h>
/ { #address-cells = <1>; @@ -48,6 +49,14 @@ mask = <0x1>; };
+ clkctrl: clkctrl@0x2c { + reg = <0x2c 0x8>, <0x10 0x4>; + reg-names = "syscfg0", "clkcfg"; + compatible = "mediatek,mt7628-clk"; + #clock-cells = <1>; + u-boot,dm-pre-reloc; + }; + watchdog: watchdog@100 { compatible = "ralink,mt7628a-wdt", "mediatek,mt7621-wdt"; reg = <0x100 0x30>; @@ -120,14 +129,14 @@ #address-cells = <1>; #size-cells = <0>;
- clock-frequency = <200000000>; + clocks = <&clkctrl CLK_SPI>; };
uart0: uartlite@c00 { compatible = "mediatek,hsuart", "ns16550a"; reg = <0xc00 0x100>;
- clock-frequency = <40000000>; + clocks = <&clkctrl CLK_UART0>;
resets = <&resetc 12>; reset-names = "uart0"; @@ -142,7 +151,7 @@ compatible = "mediatek,hsuart", "ns16550a"; reg = <0xd00 0x100>;
- clock-frequency = <40000000>; + clocks = <&clkctrl CLK_UART1>;
resets = <&resetc 19>; reset-names = "uart1"; @@ -157,7 +166,7 @@ compatible = "mediatek,hsuart", "ns16550a"; reg = <0xe00 0x100>;
- clock-frequency = <40000000>; + clocks = <&clkctrl CLK_UART2>;
resets = <&resetc 20>; reset-names = "uart2"; @@ -184,8 +193,12 @@ #phy-cells = <0>;
ralink,sysctl = <&sysc>; + resets = <&resetc 22 &resetc 25>; reset-names = "host", "device"; + + clocks = <&clkctrl CLK_UPHY>; + clock-names = "cg"; };
ehci@101c0000 {
This patch lets the spi driver to use clock provided by the clk driver since the new clk-mt7628 driver provides accurate sys clock frequency.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: newly added --- drivers/spi/mt7621_spi.c | 20 +++++++++++++------- 1 file changed, 13 insertions(+), 7 deletions(-)
diff --git a/drivers/spi/mt7621_spi.c b/drivers/spi/mt7621_spi.c index 107e58f657..b37f859b98 100644 --- a/drivers/spi/mt7621_spi.c +++ b/drivers/spi/mt7621_spi.c @@ -9,6 +9,7 @@ */
#include <common.h> +#include <clk.h> #include <dm.h> #include <spi.h> #include <wait_bit.h> @@ -266,19 +267,24 @@ static int mt7621_spi_xfer(struct udevice *dev, unsigned int bitlen, static int mt7621_spi_probe(struct udevice *dev) { struct mt7621_spi *rs = dev_get_priv(dev); + struct clk clk; + int ret;
rs->base = dev_remap_addr(dev); if (!rs->base) return -EINVAL;
- /* - * Read input clock via DT for now. At some point this should be - * replaced by implementing a clock driver for this SoC and getting - * the SPI frequency via this clock driver. - */ - rs->sys_freq = dev_read_u32_default(dev, "clock-frequency", 0); + ret = clk_get_by_index(dev, 0, &clk); + if (ret < 0) { + printf("Please provide a clock!\n"); + return ret; + } + + clk_enable(&clk); + + rs->sys_freq = clk_get_rate(&clk); if (!rs->sys_freq) { - printf("Please provide clock-frequency!\n"); + printf("Please provide a valid clock!\n"); return -EINVAL; }
The mt7621 spi controller supports continuous generic half-duplex spi transaction. There is no need to cache xfer data at all.
To achieve this goal, the OPADDR register must be used as the first data to be sent. And follows the eight generic DIDO registers. But one thing different between OPADDR and DIDO registers is OPADDR has a reversed byte order.
With this patch, any amount of data can be read/written in a single xfer function call.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/spi/mt7621_spi.c | 197 ++++++++++++++++++--------------------- 1 file changed, 91 insertions(+), 106 deletions(-)
diff --git a/drivers/spi/mt7621_spi.c b/drivers/spi/mt7621_spi.c index b37f859b98..716256ab59 100644 --- a/drivers/spi/mt7621_spi.c +++ b/drivers/spi/mt7621_spi.c @@ -15,9 +15,8 @@ #include <wait_bit.h> #include <linux/io.h>
-#define SPI_MSG_SIZE_MAX 32 /* SPI message chunk size */ -/* Enough for SPI NAND page read / write with page size 2048 bytes */ -#define SPI_MSG_SIZE_OVERALL (2048 + 16) +#define MT7621_RX_FIFO_LEN 32 +#define MT7621_TX_FIFO_LEN 36
#define MT7621_SPI_TRANS 0x00 #define MT7621_SPI_TRANS_START BIT(8) @@ -39,11 +38,16 @@ #define MASTER_RS_CLK_SEL_SHIFT 16 #define MASTER_RS_SLAVE_SEL GENMASK(31, 29)
+#define MOREBUF_CMD_CNT GENMASK(29, 24) +#define MOREBUF_CMD_CNT_SHIFT 24 +#define MOREBUF_MISO_CNT GENMASK(20, 12) +#define MOREBUF_MISO_CNT_SHIFT 12 +#define MOREBUF_MOSI_CNT GENMASK(8, 0) +#define MOREBUF_MOSI_CNT_SHIFT 0 + struct mt7621_spi { void __iomem *base; unsigned int sys_freq; - u32 data[(SPI_MSG_SIZE_OVERALL / 4) + 1]; - int tx_len; };
static void mt7621_spi_reset(struct mt7621_spi *rs, int duplex) @@ -129,20 +133,89 @@ static inline int mt7621_spi_wait_till_ready(struct mt7621_spi *rs) return ret; }
+static int mt7621_spi_read(struct mt7621_spi *rs, u8 *buf, size_t len) +{ + size_t rx_len; + int i, ret; + u32 val = 0; + + while (len) { + rx_len = min_t(size_t, len, MT7621_RX_FIFO_LEN); + + iowrite32((rx_len * 8) << MOREBUF_MISO_CNT_SHIFT, + rs->base + MT7621_SPI_MOREBUF); + iowrite32(MT7621_SPI_TRANS_START, rs->base + MT7621_SPI_TRANS); + + ret = mt7621_spi_wait_till_ready(rs); + if (ret) + return ret; + + for (i = 0; i < rx_len; i++) { + if ((i % 4) == 0) + val = ioread32(rs->base + MT7621_SPI_DATA0 + i); + *buf++ = val & 0xff; + val >>= 8; + } + + len -= rx_len; + } + + return ret; +} + +static int mt7621_spi_write(struct mt7621_spi *rs, const u8 *buf, size_t len) +{ + size_t tx_len, opcode_len, dido_len; + int i, ret; + u32 val; + + while (len) { + tx_len = min_t(size_t, len, MT7621_TX_FIFO_LEN); + + opcode_len = min_t(size_t, tx_len, 4); + dido_len = tx_len - opcode_len; + + val = 0; + for (i = 0; i < opcode_len; i++) { + val <<= 8; + val |= *buf++; + } + + iowrite32(val, rs->base + MT7621_SPI_OPCODE); + + val = 0; + for (i = 0; i < dido_len; i++) { + val |= (*buf++) << ((i % 4) * 8); + + if ((i % 4 == 3) || (i == dido_len - 1)) { + iowrite32(val, rs->base + MT7621_SPI_DATA0 + + (i & ~3)); + val = 0; + } + } + + iowrite32(((opcode_len * 8) << MOREBUF_CMD_CNT_SHIFT) | + ((dido_len * 8) << MOREBUF_MOSI_CNT_SHIFT), + rs->base + MT7621_SPI_MOREBUF); + iowrite32(MT7621_SPI_TRANS_START, rs->base + MT7621_SPI_TRANS); + + ret = mt7621_spi_wait_till_ready(rs); + if (ret) + return ret; + + len -= tx_len; + } + + return 0; +} + static int mt7621_spi_xfer(struct udevice *dev, unsigned int bitlen, const void *dout, void *din, unsigned long flags) { struct udevice *bus = dev->parent; struct mt7621_spi *rs = dev_get_priv(bus); - const u8 *tx_buf = dout; - u8 *ptr = (u8 *)dout; - u8 *rx_buf = din; int total_size = bitlen >> 3; - int chunk_size; - int rx_len = 0; - u32 data[(SPI_MSG_SIZE_MAX / 4) + 1] = { 0 }; - u32 val; - int i; + int ret = 0;
debug("%s: dout=%p, din=%p, len=%x, flags=%lx\n", __func__, dout, din, total_size, flags); @@ -156,13 +229,6 @@ static int mt7621_spi_xfer(struct udevice *dev, unsigned int bitlen, return -EIO; }
- if (dout) { - debug("TX-DATA: "); - for (i = 0; i < total_size; i++) - debug("%02x ", *ptr++); - debug("\n"); - } - mt7621_spi_wait_till_ready(rs);
/* @@ -172,96 +238,15 @@ static int mt7621_spi_xfer(struct udevice *dev, unsigned int bitlen, if (flags & SPI_XFER_BEGIN) mt7621_spi_set_cs(rs, spi_chip_select(dev), 1);
- while (total_size > 0) { - /* Don't exceed the max xfer size */ - chunk_size = min_t(int, total_size, SPI_MSG_SIZE_MAX); - - /* - * We might have some TX data buffered from the last xfer - * message. Make sure, that this does not exceed the max - * xfer size - */ - if (rs->tx_len > 4) - chunk_size -= rs->tx_len; - if (din) - rx_len = chunk_size; - - if (tx_buf) { - /* Check if this message does not exceed the buffer */ - if ((chunk_size + rs->tx_len) > SPI_MSG_SIZE_OVERALL) { - printf("TX message size too big (%d)\n", - chunk_size + rs->tx_len); - return -EMSGSIZE; - } - - /* - * Write all TX data into internal buffer to collect - * all TX messages into one buffer (might be split into - * multiple calls to this function) - */ - for (i = 0; i < chunk_size; i++, rs->tx_len++) { - rs->data[rs->tx_len / 4] |= - tx_buf[i] << (8 * (rs->tx_len & 3)); - } - } - - if (flags & SPI_XFER_END) { - /* Write TX data into controller */ - if (rs->tx_len) { - rs->data[0] = swab32(rs->data[0]); - if (rs->tx_len < 4) - rs->data[0] >>= (4 - rs->tx_len) * 8; - - for (i = 0; i < rs->tx_len; i += 4) { - iowrite32(rs->data[i / 4], rs->base + - MT7621_SPI_OPCODE + i); - } - } - - /* Write length into controller */ - val = (min_t(int, rs->tx_len, 4) * 8) << 24; - if (rs->tx_len > 4) - val |= (rs->tx_len - 4) * 8; - val |= (rx_len * 8) << 12; - iowrite32(val, rs->base + MT7621_SPI_MOREBUF); - - /* Start the xfer */ - setbits_le32(rs->base + MT7621_SPI_TRANS, - MT7621_SPI_TRANS_START); - - /* Wait until xfer is finished on bus */ - mt7621_spi_wait_till_ready(rs); - - /* Reset TX length and TX buffer for next xfer */ - rs->tx_len = 0; - memset(rs->data, 0, sizeof(rs->data)); - } - - for (i = 0; i < rx_len; i += 4) - data[i / 4] = ioread32(rs->base + MT7621_SPI_DATA0 + i); - - if (rx_len) { - debug("RX-DATA: "); - for (i = 0; i < rx_len; i++) { - rx_buf[i] = data[i / 4] >> (8 * (i & 3)); - debug("%02x ", rx_buf[i]); - } - debug("\n"); - } - - if (tx_buf) - tx_buf += chunk_size; - if (rx_buf) - rx_buf += chunk_size; - total_size -= chunk_size; - } + if (din) + ret = mt7621_spi_read(rs, din, total_size); + else if (dout) + ret = mt7621_spi_write(rs, dout, total_size);
- /* Wait until xfer is finished on bus and de-assert CS */ - mt7621_spi_wait_till_ready(rs); if (flags & SPI_XFER_END) mt7621_spi_set_cs(rs, spi_chip_select(dev), 0);
- return 0; + return ret; }
Currently this driver uses a different way to implement the spi xfer, by modifying some fields of two registers, which is incompatible with the MTK's original SDK linux driver. This will cause the flash data being damaged by the SDK driver.
This patch lets the mt7621_spi_set_cs() restore the original register fields after cs deactivated.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/spi/mt7621_spi.c | 30 +++++++++++++++++------------- 1 file changed, 17 insertions(+), 13 deletions(-)
diff --git a/drivers/spi/mt7621_spi.c b/drivers/spi/mt7621_spi.c index 716256ab59..90e85c6b44 100644 --- a/drivers/spi/mt7621_spi.c +++ b/drivers/spi/mt7621_spi.c @@ -21,6 +21,10 @@ #define MT7621_SPI_TRANS 0x00 #define MT7621_SPI_TRANS_START BIT(8) #define MT7621_SPI_TRANS_BUSY BIT(16) +#define TRANS_ADDR_SZ GENMASK(20, 19) +#define TRANS_ADDR_SZ_SHIFT 19 +#define TRANS_MOSI_BCNT GENMASK(3, 0) +#define TRANS_MOSI_BCNT_SHIFT 0
#define MT7621_SPI_OPCODE 0x04 #define MT7621_SPI_DATA0 0x08 @@ -50,20 +54,22 @@ struct mt7621_spi { unsigned int sys_freq; };
-static void mt7621_spi_reset(struct mt7621_spi *rs, int duplex) -{ - setbits_le32(rs->base + MT7621_SPI_MASTER, - MASTER_RS_SLAVE_SEL | MASTER_MORE_BUFMODE); -} - static void mt7621_spi_set_cs(struct mt7621_spi *rs, int cs, int enable) { - u32 val = 0; - debug("%s: cs#%d -> %s\n", __func__, cs, enable ? "enable" : "disable"); - if (enable) - val = BIT(cs); - iowrite32(val, rs->base + MT7621_SPI_POLAR); + + if (enable) { + setbits_le32(rs->base + MT7621_SPI_MASTER, + MASTER_RS_SLAVE_SEL | MASTER_MORE_BUFMODE); + iowrite32(BIT(cs), rs->base + MT7621_SPI_POLAR); + } else { + iowrite32(0, rs->base + MT7621_SPI_POLAR); + iowrite32((2 << TRANS_ADDR_SZ_SHIFT) | + (1 << TRANS_MOSI_BCNT_SHIFT), + rs->base + MT7621_SPI_TRANS); + clrbits_le32(rs->base + MT7621_SPI_MASTER, + MASTER_RS_SLAVE_SEL | MASTER_MORE_BUFMODE); + } }
static int mt7621_spi_set_mode(struct udevice *bus, uint mode) @@ -273,8 +279,6 @@ static int mt7621_spi_probe(struct udevice *dev) return -EINVAL; }
- mt7621_spi_reset(rs, 0); - return 0; }
This patch adds pinctrl support for mt7628, with a file for common pinmux functions and a file for mt7628 which has additional support for pinconf.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/pinctrl/Kconfig | 1 + drivers/pinctrl/Makefile | 1 + drivers/pinctrl/mtmips/Kconfig | 13 + drivers/pinctrl/mtmips/Makefile | 7 + drivers/pinctrl/mtmips/pinctrl-mt7628.c | 585 ++++++++++++++++++ .../pinctrl/mtmips/pinctrl-mtmips-common.c | 87 +++ .../pinctrl/mtmips/pinctrl-mtmips-common.h | 53 ++ 7 files changed, 747 insertions(+) create mode 100644 drivers/pinctrl/mtmips/Kconfig create mode 100644 drivers/pinctrl/mtmips/Makefile create mode 100644 drivers/pinctrl/mtmips/pinctrl-mt7628.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mtmips-common.c create mode 100644 drivers/pinctrl/mtmips/pinctrl-mtmips-common.h
diff --git a/drivers/pinctrl/Kconfig b/drivers/pinctrl/Kconfig index a0ac167d14..1634dffb35 100644 --- a/drivers/pinctrl/Kconfig +++ b/drivers/pinctrl/Kconfig @@ -244,6 +244,7 @@ source "drivers/pinctrl/exynos/Kconfig" source "drivers/pinctrl/mediatek/Kconfig" source "drivers/pinctrl/meson/Kconfig" source "drivers/pinctrl/mscc/Kconfig" +source "drivers/pinctrl/mtmips/Kconfig" source "drivers/pinctrl/mvebu/Kconfig" source "drivers/pinctrl/nxp/Kconfig" source "drivers/pinctrl/renesas/Kconfig" diff --git a/drivers/pinctrl/Makefile b/drivers/pinctrl/Makefile index 4b080b74dc..ce0879a2b7 100644 --- a/drivers/pinctrl/Makefile +++ b/drivers/pinctrl/Makefile @@ -9,6 +9,7 @@ obj-y += nxp/ obj-$(CONFIG_$(SPL_)PINCTRL_ROCKCHIP) += rockchip/ obj-$(CONFIG_ARCH_ASPEED) += aspeed/ obj-$(CONFIG_ARCH_ATH79) += ath79/ +obj-$(CONFIG_ARCH_MTMIPS) += mtmips/ obj-$(CONFIG_ARCH_RMOBILE) += renesas/ obj-$(CONFIG_PINCTRL_SANDBOX) += pinctrl-sandbox.o
diff --git a/drivers/pinctrl/mtmips/Kconfig b/drivers/pinctrl/mtmips/Kconfig new file mode 100644 index 0000000000..8482a38ebc --- /dev/null +++ b/drivers/pinctrl/mtmips/Kconfig @@ -0,0 +1,13 @@ + +config PINCTRL_MTMIPS + depends on ARCH_MTMIPS + bool + +config PINCTRL_MT7628 + bool "MediaTek MT7628 pin control driver" + select PINCTRL_MTMIPS + depends on SOC_MT7628 && PINCTRL_GENERIC + help + Support pin multiplexing control on MediaTek MT7628. + The driver is controlled by a device tree node which contains + the pin mux functions for each available pin groups. diff --git a/drivers/pinctrl/mtmips/Makefile b/drivers/pinctrl/mtmips/Makefile new file mode 100644 index 0000000000..3ba5c0c66d --- /dev/null +++ b/drivers/pinctrl/mtmips/Makefile @@ -0,0 +1,7 @@ +# SPDX-License-Identifier: GPL-2.0 + +# Core +obj-$(CONFIG_PINCTRL_MTMIPS) += pinctrl-mtmips-common.o + +# SoC Drivers +obj-$(CONFIG_PINCTRL_MT7628) += pinctrl-mt7628.o diff --git a/drivers/pinctrl/mtmips/pinctrl-mt7628.c b/drivers/pinctrl/mtmips/pinctrl-mt7628.c new file mode 100644 index 0000000000..6883450a09 --- /dev/null +++ b/drivers/pinctrl/mtmips/pinctrl-mt7628.c @@ -0,0 +1,585 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <linux/bitops.h> +#include <linux/io.h> + +#include "pinctrl-mtmips-common.h" + +DECLARE_GLOBAL_DATA_PTR; + +#define AGPIO_OFS 0 +#define GPIOMODE1_OFS 0x24 +#define GPIOMODE2_OFS 0x28 + +#define EPHY4_1_PAD_SHIFT 17 +#define EPHY4_1_PAD_MASK 0x0f +#define EPHY0_SHIFT 16 +#define RF_OLT_MODE_SHIFT 12 +#define N9_EINT_SRC_SHIFT 9 +#define WLED_OD_SHIFT 8 +#define REF_CLKO_PAD_SHIFT 4 +#define I2S_CLK_PAD_SHIFT 3 +#define I2S_WS_PAD_SHIFT 2 +#define I2S_SDO_PAD_SHIFT 1 +#define I2S_SDI_PAD_SHIFT 0 + +#define GM4_MASK 3 + +#define P4LED_K_SHIFT 26 +#define P3LED_K_SHIFT 24 +#define P2LED_K_SHIFT 22 +#define P1LED_K_SHIFT 20 +#define P0LED_K_SHIFT 18 +#define WLED_K_SHIFT 16 +#define P4LED_A_SHIFT 10 +#define P3LED_A_SHIFT 8 +#define P2LED_A_SHIFT 6 +#define P1LED_A_SHIFT 4 +#define P0LED_A_SHIFT 2 +#define WLED_A_SHIFT 0 + +#define PWM1_SHIFT 30 +#define PWM0_SHIFT 28 +#define UART2_SHIFT 26 +#define UART1_SHIFT 24 +#define I2C_SHIFT 20 +#define REFCLK_SHIFT 18 +#define PERST_SHIFT 16 +#define ESD_SHIFT 15 +#define WDT_SHIFT 14 +#define SPI_SHIFT 12 +#define SDMODE_SHIFT 10 +#define UART0_SHIFT 8 +#define I2S_SHIFT 6 +#define SPI_CS1_SHIFT 4 +#define SPIS_SHIFT 2 +#define GPIO0_SHIFT 0 + +#define PAD_PU_G0_REG 0x00 +#define PAD_PU_G1_REG 0x04 +#define PAD_PD_G0_REG 0x10 +#define PAD_PD_G1_REG 0x14 +#define PAD_SR_G0_REG 0x20 +#define PAD_SR_G1_REG 0x24 +#define PAD_SMT_G0_REG 0x30 +#define PAD_SMT_G1_REG 0x34 +#define PAD_E2_G0_REG 0x40 +#define PAD_E2_G1_REG 0x44 +#define PAD_E4_G0_REG 0x50 +#define PAD_E4_G1_REG 0x54 +#define PAD_E8_G0_REG 0x60 +#define PAD_E8_G1_REG 0x64 + +#define PIN_CONFIG_DRIVE_STRENGTH_28 (PIN_CONFIG_END + 1) +#define PIN_CONFIG_DRIVE_STRENGTH_4G (PIN_CONFIG_END + 2) + +struct mt7628_pinctrl_priv { + struct mtmips_pinctrl_priv mp; + + void __iomem *pcbase; +}; + +#if CONFIG_IS_ENABLED(PINMUX) +static struct mtmips_pmx_func ephy4_1_pad_grp[] = { + FUNC("digital", 0xf), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func ephy0_grp[] = { + FUNC("disable", 1), + FUNC("enable", 0), +}; + +static struct mtmips_pmx_func rf_olt_grp[] = { + FUNC("enable", 1), + FUNC("disable", 0), +}; + +static struct mtmips_pmx_func n9_eint_src_grp[] = { + FUNC("gpio", 1), + FUNC("utif", 0), +}; + +static struct mtmips_pmx_func wlen_od_grp[] = { + FUNC("enable", 1), + FUNC("disable", 0), +}; + +static struct mtmips_pmx_func ref_clko_grp[] = { + FUNC("digital", 1), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func i2s_clk_grp[] = { + FUNC("digital", 1), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func i2s_ws_grp[] = { + FUNC("digital", 1), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func i2s_sdo_grp[] = { + FUNC("digital", 1), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func i2s_sdi_grp[] = { + FUNC("digital", 1), + FUNC("analog", 0), +}; + +static struct mtmips_pmx_func pwm1_grp[] = { + FUNC("sdxc d6", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("pwm1", 0), +}; + +static struct mtmips_pmx_func pwm0_grp[] = { + FUNC("sdxc d7", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("pwm0", 0), +}; + +static struct mtmips_pmx_func uart2_grp[] = { + FUNC("sdxc d5 d4", 3), + FUNC("pwm", 2), + FUNC("gpio", 1), + FUNC("uart2", 0), +}; + +static struct mtmips_pmx_func uart1_grp[] = { + FUNC("sw_r", 3), + FUNC("pwm", 2), + FUNC("gpio", 1), + FUNC("uart1", 0), +}; + +static struct mtmips_pmx_func i2c_grp[] = { + FUNC("-", 3), + FUNC("debug", 2), + FUNC("gpio", 1), + FUNC("i2c", 0), +}; + +static struct mtmips_pmx_func refclk_grp[] = { + FUNC("gpio", 1), + FUNC("refclk", 0), +}; + +static struct mtmips_pmx_func perst_grp[] = { + FUNC("gpio", 1), + FUNC("perst", 0), +}; + +static struct mtmips_pmx_func esd_grp[] = { + FUNC("router", 1), + FUNC("iot", 0), +}; + +static struct mtmips_pmx_func wdt_grp[] = { + FUNC("gpio", 1), + FUNC("wdt", 0), +}; + +static struct mtmips_pmx_func spi_grp[] = { + FUNC("gpio", 1), + FUNC("spi", 0), +}; + +static struct mtmips_pmx_func sd_mode_grp[] = { + FUNC("n9 jtag", 3), + FUNC("utif1", 2), + FUNC("gpio", 1), + FUNC("sdxc", 0), +}; + +static struct mtmips_pmx_func uart0_grp[] = { + FUNC("-", 3), + FUNC("-", 2), + FUNC("gpio", 1), + FUNC("uart0", 0), +}; + +static struct mtmips_pmx_func i2s_grp[] = { + FUNC("antenna", 3), + FUNC("pcm", 2), + FUNC("gpio", 1), + FUNC("i2s", 0), +}; + +static struct mtmips_pmx_func spi_cs1_grp[] = { + FUNC("-", 3), + FUNC("refclk", 2), + FUNC("gpio", 1), + FUNC("spi cs1", 0), +}; + +static struct mtmips_pmx_func spis_grp[] = { + FUNC("pwm_uart2", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("spis", 0), +}; + +static struct mtmips_pmx_func gpio0_grp[] = { + FUNC("perst", 3), + FUNC("refclk", 2), + FUNC("gpio", 1), + FUNC("gpio0", 0), +}; + +static struct mtmips_pmx_func wled_a_grp[] = { + FUNC("-", 3), + FUNC("-", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p0led_a_grp[] = { + FUNC("jtag", 3), + FUNC("rsvd", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p1led_a_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p2led_a_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p3led_a_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p4led_a_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func wled_k_grp[] = { + FUNC("-", 3), + FUNC("-", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p0led_k_grp[] = { + FUNC("jtag", 3), + FUNC("rsvd", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p1led_k_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p2led_k_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p3led_k_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_func p4led_k_grp[] = { + FUNC("jtag", 3), + FUNC("utif", 2), + FUNC("gpio", 1), + FUNC("led", 0), +}; + +static struct mtmips_pmx_group mt7628_pinmux_data[] = { + GRP("ephy4_1_pad", ephy4_1_pad_grp, AGPIO_OFS, EPHY4_1_PAD_SHIFT, + EPHY4_1_PAD_MASK), + GRP("ephy0", ephy0_grp, AGPIO_OFS, EPHY0_SHIFT, 1), + GRP("rf_olt", rf_olt_grp, AGPIO_OFS, RF_OLT_MODE_SHIFT, 1), + GRP("n9_eint_src", n9_eint_src_grp, AGPIO_OFS, N9_EINT_SRC_SHIFT, 1), + GRP("wlen_od", wlen_od_grp, AGPIO_OFS, WLED_OD_SHIFT, 1), + GRP("ref_clko_pad", ref_clko_grp, AGPIO_OFS, REF_CLKO_PAD_SHIFT, 1), + GRP("i2s_clk_pad", i2s_clk_grp, AGPIO_OFS, I2S_CLK_PAD_SHIFT, 1), + GRP("i2s_ws_pad", i2s_ws_grp, AGPIO_OFS, I2S_WS_PAD_SHIFT, 1), + GRP("i2s_sdo_pad", i2s_sdo_grp, AGPIO_OFS, I2S_SDO_PAD_SHIFT, 1), + GRP("i2s_sdi_pad", i2s_sdi_grp, AGPIO_OFS, I2S_SDI_PAD_SHIFT, 1), + GRP("pwm1", pwm1_grp, GPIOMODE1_OFS, PWM1_SHIFT, GM4_MASK), + GRP("pwm0", pwm0_grp, GPIOMODE1_OFS, PWM0_SHIFT, GM4_MASK), + GRP("uart2", uart2_grp, GPIOMODE1_OFS, UART2_SHIFT, GM4_MASK), + GRP("uart1", uart1_grp, GPIOMODE1_OFS, UART1_SHIFT, GM4_MASK), + GRP("i2c", i2c_grp, GPIOMODE1_OFS, I2C_SHIFT, GM4_MASK), + GRP("refclk", refclk_grp, GPIOMODE1_OFS, REFCLK_SHIFT, 1), + GRP("perst", perst_grp, GPIOMODE1_OFS, PERST_SHIFT, 1), + GRP("sd router", esd_grp, GPIOMODE1_OFS, ESD_SHIFT, 1), + GRP("wdt", wdt_grp, GPIOMODE1_OFS, WDT_SHIFT, 1), + GRP("spi", spi_grp, GPIOMODE1_OFS, SPI_SHIFT, 1), + GRP("sdmode", sd_mode_grp, GPIOMODE1_OFS, SDMODE_SHIFT, GM4_MASK), + GRP("uart0", uart0_grp, GPIOMODE1_OFS, UART0_SHIFT, GM4_MASK), + GRP("i2s", i2s_grp, GPIOMODE1_OFS, I2S_SHIFT, GM4_MASK), + GRP("spi cs1", spi_cs1_grp, GPIOMODE1_OFS, SPI_CS1_SHIFT, GM4_MASK), + GRP("spis", spis_grp, GPIOMODE1_OFS, SPIS_SHIFT, GM4_MASK), + GRP("gpio0", gpio0_grp, GPIOMODE1_OFS, GPIO0_SHIFT, GM4_MASK), + GRP("wled_a", wled_a_grp, GPIOMODE2_OFS, WLED_A_SHIFT, GM4_MASK), + GRP("p0led_a", p0led_a_grp, GPIOMODE2_OFS, P0LED_A_SHIFT, GM4_MASK), + GRP("p1led_a", p1led_a_grp, GPIOMODE2_OFS, P1LED_A_SHIFT, GM4_MASK), + GRP("p2led_a", p2led_a_grp, GPIOMODE2_OFS, P2LED_A_SHIFT, GM4_MASK), + GRP("p3led_a", p3led_a_grp, GPIOMODE2_OFS, P3LED_A_SHIFT, GM4_MASK), + GRP("p4led_a", p4led_a_grp, GPIOMODE2_OFS, P4LED_A_SHIFT, GM4_MASK), + GRP("wled_k", wled_k_grp, GPIOMODE2_OFS, WLED_K_SHIFT, GM4_MASK), + GRP("p0led_k", p0led_k_grp, GPIOMODE2_OFS, P0LED_K_SHIFT, GM4_MASK), + GRP("p1led_k", p1led_k_grp, GPIOMODE2_OFS, P1LED_K_SHIFT, GM4_MASK), + GRP("p2led_k", p2led_k_grp, GPIOMODE2_OFS, P2LED_K_SHIFT, GM4_MASK), + GRP("p3led_k", p3led_k_grp, GPIOMODE2_OFS, P3LED_K_SHIFT, GM4_MASK), + GRP("p4led_k", p4led_k_grp, GPIOMODE2_OFS, P4LED_K_SHIFT, GM4_MASK), +}; + +static int mt7628_get_groups_count(struct udevice *dev) +{ + return ARRAY_SIZE(mt7628_pinmux_data); +} + +static const char *mt7628_get_group_name(struct udevice *dev, + unsigned int selector) +{ + return mt7628_pinmux_data[selector].name; +} +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + +#if CONFIG_IS_ENABLED(PINCONF) +static const struct pinconf_param mt7628_conf_params[] = { + { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 }, + { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 }, + { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 }, + { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 }, + { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 }, + { "drive-strength-28", PIN_CONFIG_DRIVE_STRENGTH_28, 0 }, + { "drive-strength-4g", PIN_CONFIG_DRIVE_STRENGTH_4G, 0 }, + { "slew-rate", PIN_CONFIG_SLEW_RATE, 0 }, +}; + +static const char *const mt7628_pins[] = { + "i2s_sdi", + "i2s_sdo", + "i2s_ws", + "i2s_clk", + "i2s_sclk", + "i2c_sd", + "spi_cs1", + "spi_clk", + "spi_mosi", + "spi_miso", + "spi_cs0", + "gpio0", + "uart0_txd", + "uart0_rxd", + "spis_cs", + "spis_clk", + "spis_miso", + "spis_mosi", + "pwm_ch0", + "pwm_ch1", + "uart2_txd", + "uart2_rxd", + "sd_wp", + "sd_cd", + "sd_d1", + "sd_d0", + "sd_clk", + "sd_cmd", + "sd_d3", + "sd_d2", + "ephy_led4_k", + "ephy_led3_k", + "ephy_led2_k", + "ephy_led1_k", + "ephy_led0_k", + "wled_k", + "perst_n", + "co_clko", + "wdt", + "ephy_led4_a", + "ephy_led3_a", + "ephy_led2_a", + "ephy_led1_a", + "ephy_led0_a", + "wled_a", + "uart1_txd", + "uart1_rxd", +}; + +static const u32 mt7628_drv_strength_28_tbl[] = {2, 4, 6, 8}; +static const u32 mt7628_drv_strength_4g_tbl[] = {4, 8, 12, 16}; + +static int mt7628_set_drv_strength(void __iomem *base, u32 val, u32 bit, + const u32 tbl[], u32 reg_lo, u32 reg_hi) +{ + int i; + + for (i = 0; i < 4; i++) + if (tbl[i] == val) + break; + + if (i >= 4) + return -EINVAL; + + clrsetbits_32(base + reg_lo, BIT(bit), (i & 1) << bit); + clrsetbits_32(base + reg_hi, BIT(bit), ((i >> 1) & 1) << bit); + + return 0; +} + +static int mt7628_get_pins_count(struct udevice *dev) +{ + return ARRAY_SIZE(mt7628_pins); +} + +static const char *mt7628_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + return mt7628_pins[selector]; +} + +static int mt7628_pinconf_set(struct udevice *dev, unsigned int pin_selector, + unsigned int param, unsigned int argument) +{ + struct mt7628_pinctrl_priv *priv = dev_get_priv(dev); + u32 offs, bit; + int ret = 0; + + offs = (pin_selector / 32) * 4; + bit = pin_selector % 32; + + switch (param) { + case PIN_CONFIG_BIAS_DISABLE: + clrbits_32(priv->pcbase + offs + PAD_PU_G0_REG, BIT(bit)); + clrbits_32(priv->pcbase + offs + PAD_PD_G0_REG, BIT(bit)); + break; + case PIN_CONFIG_BIAS_PULL_UP: + setbits_32(priv->pcbase + offs + PAD_PU_G0_REG, BIT(bit)); + clrbits_32(priv->pcbase + offs + PAD_PD_G0_REG, BIT(bit)); + break; + case PIN_CONFIG_BIAS_PULL_DOWN: + clrbits_32(priv->pcbase + offs + PAD_PU_G0_REG, BIT(bit)); + setbits_32(priv->pcbase + offs + PAD_PD_G0_REG, BIT(bit)); + break; + case PIN_CONFIG_INPUT_SCHMITT_ENABLE: + clrsetbits_32(priv->pcbase + offs + PAD_SMT_G0_REG, + BIT(bit), (!!argument) << bit); + break; + case PIN_CONFIG_DRIVE_STRENGTH_28: + ret = mt7628_set_drv_strength(priv->pcbase + offs, argument, + bit, mt7628_drv_strength_28_tbl, + PAD_E2_G0_REG, PAD_E4_G0_REG); + break; + case PIN_CONFIG_DRIVE_STRENGTH_4G: + ret = mt7628_set_drv_strength(priv->pcbase + offs, argument, + bit, mt7628_drv_strength_4g_tbl, + PAD_E4_G0_REG, PAD_E8_G0_REG); + break; + case PIN_CONFIG_SLEW_RATE: + clrsetbits_32(priv->pcbase + offs + PAD_SR_G0_REG, + BIT(bit), (!!argument) << bit); + break; + default: + ret = -EINVAL; + } + + return ret; +} +#endif + +static int mt7628_pinctrl_probe(struct udevice *dev) +{ + struct mt7628_pinctrl_priv *priv = dev_get_priv(dev); + int ret = 0; + +#if CONFIG_IS_ENABLED(PINMUX) + ret = mtmips_pinctrl_probe(&priv->mp, ARRAY_SIZE(mt7628_pinmux_data), + mt7628_pinmux_data); +#endif /* CONFIG_IS_ENABLED(PINMUX) */ + + return ret; +} + +static int mt7628_pinctrl_ofdata_to_platdata(struct udevice *dev) +{ + struct mt7628_pinctrl_priv *priv = dev_get_priv(dev); + + priv->mp.base = (void __iomem *)dev_remap_addr_index(dev, 0); + + if (!priv->mp.base) + return -EINVAL; + + priv->pcbase = (void __iomem *)dev_remap_addr_index(dev, 1); + + if (!priv->pcbase) + return -EINVAL; + + return 0; +} + +static struct pinctrl_ops mt7628_pinctrl_ops = { +#if CONFIG_IS_ENABLED(PINMUX) + .get_groups_count = mt7628_get_groups_count, + .get_group_name = mt7628_get_group_name, + .get_functions_count = mtmips_get_functions_count, + .get_function_name = mtmips_get_function_name, + .pinmux_group_set = mtmips_pinmux_group_set, +#endif /* CONFIG_IS_ENABLED(PINMUX) */ +#if CONFIG_IS_ENABLED(PINCONF) + .pinconf_num_params = ARRAY_SIZE(mt7628_conf_params), + .pinconf_params = mt7628_conf_params, + .get_pins_count = mt7628_get_pins_count, + .get_pin_name = mt7628_get_pin_name, + .pinconf_set = mt7628_pinconf_set, +#endif /* CONFIG_IS_ENABLED(PINCONF) */ + .set_state = pinctrl_generic_set_state, +}; + +static const struct udevice_id mt7628_pinctrl_ids[] = { + { .compatible = "mediatek,mt7628-pinctrl" }, + { } +}; + +U_BOOT_DRIVER(mt7628_pinctrl) = { + .name = "mt7628-pinctrl", + .id = UCLASS_PINCTRL, + .of_match = mt7628_pinctrl_ids, + .ofdata_to_platdata = mt7628_pinctrl_ofdata_to_platdata, + .ops = &mt7628_pinctrl_ops, + .probe = mt7628_pinctrl_probe, + .priv_auto_alloc_size = sizeof(struct mt7628_pinctrl_priv), +}; diff --git a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c new file mode 100644 index 0000000000..ee6a9d1fc8 --- /dev/null +++ b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.c @@ -0,0 +1,87 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <dm.h> +#include <dm/pinctrl.h> +#include <linux/io.h> + +#include "pinctrl-mtmips-common.h" + +static void mtmips_pinctrl_reg_set(struct mtmips_pinctrl_priv *priv, + u32 reg, u32 shift, u32 mask, u32 value) +{ + u32 val; + + val = readl(priv->base + reg); + val &= ~(mask << shift); + val |= value << shift; + writel(val, priv->base + reg); +} + +int mtmips_get_functions_count(struct udevice *dev) +{ + struct mtmips_pinctrl_priv *priv = dev_get_priv(dev); + + return priv->nfuncs; +} + +const char *mtmips_get_function_name(struct udevice *dev, unsigned int selector) +{ + struct mtmips_pinctrl_priv *priv = dev_get_priv(dev); + + return priv->funcs[selector]->name; +} + +int mtmips_pinmux_group_set(struct udevice *dev, unsigned int group_selector, + unsigned int func_selector) +{ + struct mtmips_pinctrl_priv *priv = dev_get_priv(dev); + const struct mtmips_pmx_group *grp = &priv->groups[group_selector]; + const struct mtmips_pmx_func *func = priv->funcs[func_selector]; + int i; + + if (!grp->nfuncs) + return 0; + + for (i = 0; i < grp->nfuncs; i++) { + if (!strcmp(grp->funcs[i].name, func->name)) { + mtmips_pinctrl_reg_set(priv, grp->reg, grp->shift, + grp->mask, grp->funcs[i].value); + return 0; + } + } + + return -EINVAL; +} + +int mtmips_pinctrl_probe(struct mtmips_pinctrl_priv *priv, u32 ngroups, + const struct mtmips_pmx_group *groups) +{ + int i, j, n; + + priv->ngroups = ngroups; + priv->groups = groups; + + priv->nfuncs = 0; + + for (i = 0; i < ngroups; i++) + priv->nfuncs += groups[i].nfuncs; + + priv->funcs = malloc(priv->nfuncs * sizeof(*priv->funcs)); + if (!priv->funcs) + return -ENOMEM; + + n = 0; + + for (i = 0; i < ngroups; i++) { + for (j = 0; j < groups[i].nfuncs; j++) + priv->funcs[n++] = &groups[i].funcs[j]; + } + + return 0; +} diff --git a/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h new file mode 100644 index 0000000000..b51d8f009c --- /dev/null +++ b/drivers/pinctrl/mtmips/pinctrl-mtmips-common.h @@ -0,0 +1,53 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _PINCTRL_MTMIPS_COMMON_H_ +#define _PINCTRL_MTMIPS_COMMON_H_ + +#include <common.h> + +struct mtmips_pmx_func { + const char *name; + int value; +}; + +struct mtmips_pmx_group { + const char *name; + + u32 reg; + u32 shift; + char mask; + + int nfuncs; + const struct mtmips_pmx_func *funcs; +}; + +struct mtmips_pinctrl_priv { + void __iomem *base; + + u32 ngroups; + const struct mtmips_pmx_group *groups; + + u32 nfuncs; + const struct mtmips_pmx_func **funcs; +}; + +#define FUNC(name, value) { name, value } + +#define GRP(_name, _funcs, _reg, _shift, _mask) \ + { .name = (_name), .reg = (_reg), .shift = (_shift), .mask = (_mask), \ + .funcs = (_funcs), .nfuncs = ARRAY_SIZE(_funcs) } + +int mtmips_get_functions_count(struct udevice *dev); +const char *mtmips_get_function_name(struct udevice *dev, + unsigned int selector); +int mtmips_pinmux_group_set(struct udevice *dev, unsigned int group_selector, + unsigned int func_selector); +int mtmips_pinctrl_probe(struct mtmips_pinctrl_priv *priv, u32 ngroups, + const struct mtmips_pmx_group *groups); + +#endif /* _PINCTRL_MTMIPS_COMMON_H_ */
Am 18.09.19 um 04:15 schrieb Weijie Gao:
- depends on ARCH_MTMIPS
- bool
- bool "MediaTek MT7628 pin control driver"
- select PINCTRL_MTMIPS
- depends on SOC_MT7628 && PINCTRL_GENERIC
- help
- Copyright (C) 2019 MediaTek Inc. All Rights Reserved.
- Author: Weijie Gao weijie.gao@mediatek.com
+#define GM4_MASK 3
- struct mtmips_pinctrl_priv mp;
- void __iomem *pcbase;
- FUNC("digital", 0xf),
- FUNC("analog", 0),
all those structs could be made "const"
- FUNC("disable", 1),
- FUNC("enable", 0),
- FUNC("enable", 1),
- FUNC("disable", 0),
- FUNC("gpio", 1),
- FUNC("utif", 0),
- FUNC("digital", 1),
- FUNC("sdxc d6", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("pwm1", 0),
- FUNC("sdxc d7", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("pwm0", 0),
- FUNC("sdxc d5 d4", 3),
- FUNC("pwm", 2),
- FUNC("gpio", 1),
- FUNC("uart2", 0),
- FUNC("sw_r", 3),
- FUNC("pwm", 2),
- FUNC("gpio", 1),
- FUNC("uart1", 0),
- FUNC("-", 3),
- FUNC("debug", 2),
- FUNC("gpio", 1),
- FUNC("i2c", 0),
- FUNC("gpio", 1),
- FUNC("refclk", 0),
- FUNC("gpio", 1),
- FUNC("perst", 0),
- FUNC("router", 1),
- FUNC("iot", 0),
- FUNC("gpio", 1),
- FUNC("wdt", 0),
- FUNC("gpio", 1),
- FUNC("spi", 0),
- FUNC("n9 jtag", 3),
- FUNC("utif1", 2),
- FUNC("gpio", 1),
- FUNC("sdxc", 0),
- FUNC("-", 3),
- FUNC("-", 2),
- FUNC("gpio", 1),
- FUNC("uart0", 0),
- FUNC("antenna", 3),
- FUNC("pcm", 2),
- FUNC("gpio", 1),
- FUNC("i2s", 0),
- FUNC("-", 3),
- FUNC("refclk", 2),
- FUNC("gpio", 1),
- FUNC("spi cs1", 0),
- FUNC("pwm_uart2", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("spis", 0),
- FUNC("perst", 3),
- FUNC("gpio", 1),
- FUNC("gpio0", 0),
- FUNC("-", 3),
- FUNC("-", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("rsvd", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("-", 3),
- FUNC("-", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("rsvd", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- FUNC("jtag", 3),
- FUNC("utif", 2),
- FUNC("gpio", 1),
- FUNC("led", 0),
- GRP("ephy4_1_pad", ephy4_1_pad_grp, AGPIO_OFS, EPHY4_1_PAD_SHIFT,
EPHY4_1_PAD_MASK),
- GRP("ephy0", ephy0_grp, AGPIO_OFS, EPHY0_SHIFT, 1),
- GRP("rf_olt", rf_olt_grp, AGPIO_OFS, RF_OLT_MODE_SHIFT, 1),
- GRP("n9_eint_src", n9_eint_src_grp, AGPIO_OFS, N9_EINT_SRC_SHIFT, 1),
- GRP("wlen_od", wlen_od_grp, AGPIO_OFS, WLED_OD_SHIFT, 1),
- GRP("ref_clko_pad", ref_clko_grp, AGPIO_OFS, REF_CLKO_PAD_SHIFT, 1),
- GRP("i2s_clk_pad", i2s_clk_grp, AGPIO_OFS, I2S_CLK_PAD_SHIFT, 1),
- GRP("i2s_ws_pad", i2s_ws_grp, AGPIO_OFS, I2S_WS_PAD_SHIFT, 1),
- GRP("i2s_sdo_pad", i2s_sdo_grp, AGPIO_OFS, I2S_SDO_PAD_SHIFT, 1),
- GRP("i2s_sdi_pad", i2s_sdi_grp, AGPIO_OFS, I2S_SDI_PAD_SHIFT, 1),
- GRP("pwm1", pwm1_grp, GPIOMODE1_OFS, PWM1_SHIFT, GM4_MASK),
- GRP("pwm0", pwm0_grp, GPIOMODE1_OFS, PWM0_SHIFT, GM4_MASK),
- GRP("uart2", uart2_grp, GPIOMODE1_OFS, UART2_SHIFT, GM4_MASK),
- GRP("uart1", uart1_grp, GPIOMODE1_OFS, UART1_SHIFT, GM4_MASK),
- GRP("i2c", i2c_grp, GPIOMODE1_OFS, I2C_SHIFT, GM4_MASK),
- GRP("refclk", refclk_grp, GPIOMODE1_OFS, REFCLK_SHIFT, 1),
- GRP("perst", perst_grp, GPIOMODE1_OFS, PERST_SHIFT, 1),
- GRP("sd router", esd_grp, GPIOMODE1_OFS, ESD_SHIFT, 1),
- GRP("wdt", wdt_grp, GPIOMODE1_OFS, WDT_SHIFT, 1),
- GRP("spi", spi_grp, GPIOMODE1_OFS, SPI_SHIFT, 1),
- GRP("sdmode", sd_mode_grp, GPIOMODE1_OFS, SDMODE_SHIFT, GM4_MASK),
- GRP("uart0", uart0_grp, GPIOMODE1_OFS, UART0_SHIFT, GM4_MASK),
- GRP("i2s", i2s_grp, GPIOMODE1_OFS, I2S_SHIFT, GM4_MASK),
- GRP("spi cs1", spi_cs1_grp, GPIOMODE1_OFS, SPI_CS1_SHIFT, GM4_MASK),
- GRP("spis", spis_grp, GPIOMODE1_OFS, SPIS_SHIFT, GM4_MASK),
- GRP("gpio0", gpio0_grp, GPIOMODE1_OFS, GPIO0_SHIFT, GM4_MASK),
- GRP("wled_a", wled_a_grp, GPIOMODE2_OFS, WLED_A_SHIFT, GM4_MASK),
- GRP("p0led_a", p0led_a_grp, GPIOMODE2_OFS, P0LED_A_SHIFT, GM4_MASK),
- GRP("p1led_a", p1led_a_grp, GPIOMODE2_OFS, P1LED_A_SHIFT, GM4_MASK),
- GRP("p2led_a", p2led_a_grp, GPIOMODE2_OFS, P2LED_A_SHIFT, GM4_MASK),
- GRP("p3led_a", p3led_a_grp, GPIOMODE2_OFS, P3LED_A_SHIFT, GM4_MASK),
- GRP("p4led_a", p4led_a_grp, GPIOMODE2_OFS, P4LED_A_SHIFT, GM4_MASK),
- GRP("wled_k", wled_k_grp, GPIOMODE2_OFS, WLED_K_SHIFT, GM4_MASK),
- GRP("p0led_k", p0led_k_grp, GPIOMODE2_OFS, P0LED_K_SHIFT, GM4_MASK),
- GRP("p1led_k", p1led_k_grp, GPIOMODE2_OFS, P1LED_K_SHIFT, GM4_MASK),
- GRP("p2led_k", p2led_k_grp, GPIOMODE2_OFS, P2LED_K_SHIFT, GM4_MASK),
- GRP("p3led_k", p3led_k_grp, GPIOMODE2_OFS, P3LED_K_SHIFT, GM4_MASK),
- GRP("p4led_k", p4led_k_grp, GPIOMODE2_OFS, P4LED_K_SHIFT, GM4_MASK),
- return ARRAY_SIZE(mt7628_pinmux_data);
- return mt7628_pinmux_data[selector].name;
- { "bias-disable", PIN_CONFIG_BIAS_DISABLE, 0 },
- { "bias-pull-up", PIN_CONFIG_BIAS_PULL_UP, 1 },
- { "bias-pull-down", PIN_CONFIG_BIAS_PULL_DOWN, 1 },
- { "input-schmitt-enable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 1 },
- { "input-schmitt-disable", PIN_CONFIG_INPUT_SCHMITT_ENABLE, 0 },
- { "drive-strength-28", PIN_CONFIG_DRIVE_STRENGTH_28, 0 },
- { "drive-strength-4g", PIN_CONFIG_DRIVE_STRENGTH_4G, 0 },
- { "slew-rate", PIN_CONFIG_SLEW_RATE, 0 },
- "i2s_sdi",
- "i2s_sdo",
- "i2s_ws",
- "i2s_clk",
- "i2s_sclk",
- "i2c_sd",
- "spi_cs1",
- "spi_clk",
- "spi_mosi",
- "spi_miso",
- "spi_cs0",
- "gpio0",
- "uart0_txd",
- "uart0_rxd",
- "spis_cs",
- "spis_clk",
- "spis_miso",
- "spis_mosi",
- "pwm_ch0",
- "pwm_ch1",
- "uart2_txd",
- "uart2_rxd",
- "sd_wp",
- "sd_cd",
- "sd_d1",
- "sd_d0",
- "sd_clk",
- "sd_cmd",
- "sd_d3",
- "sd_d2",
- "ephy_led4_k",
- "ephy_led3_k",
- "ephy_led2_k",
- "ephy_led1_k",
- "ephy_led0_k",
- "wled_k",
- "perst_n",
- "co_clko",
- "wdt",
- "ephy_led4_a",
- "ephy_led3_a",
- "ephy_led2_a",
- "ephy_led1_a",
- "ephy_led0_a",
- "wled_a",
- "uart1_txd",
- "uart1_rxd",
- int i;
- for (i = 0; i < 4; i++)
if (tbl[i] == val)
break;
- if (i >= 4)
return -EINVAL;
- clrsetbits_32(base + reg_lo, BIT(bit), (i & 1) << bit);
- clrsetbits_32(base + reg_hi, BIT(bit), ((i >> 1) & 1) << bit);
- return ARRAY_SIZE(mt7628_pins);
- return mt7628_pins[selector];
- struct mt7628_pinctrl_priv *priv = dev_get_priv(dev);
- u32 offs, bit;
- int ret = 0;
- offs = (pin_selector / 32) * 4;
- bit = pin_selector % 32;
- switch (param) {
- case PIN_CONFIG_BIAS_DISABLE:
break;
- case PIN_CONFIG_BIAS_PULL_UP:
break;
- case PIN_CONFIG_BIAS_PULL_DOWN:
break;
- case PIN_CONFIG_INPUT_SCHMITT_ENABLE:
break;
- case PIN_CONFIG_DRIVE_STRENGTH_28:
break;
- case PIN_CONFIG_DRIVE_STRENGTH_4G:
break;
- case PIN_CONFIG_SLEW_RATE:
break;
- default:
ret = -EINVAL;
- return ret;
+} +#endif
- int ret = 0;
- ret = mtmips_pinctrl_probe(&priv->mp, ARRAY_SIZE(mt7628_pinmux_data),
- return ret;
- priv->mp.base = (void __iomem *)dev_remap_addr_index(dev, 0);
- if (!priv->mp.base)
return -EINVAL;
- priv->pcbase = (void __iomem *)dev_remap_addr_index(dev, 1);
- if (!priv->pcbase)
return -EINVAL;
- .get_groups_count = mt7628_get_groups_count,
- .get_group_name = mt7628_get_group_name,
- .get_functions_count = mtmips_get_functions_count,
- .get_function_name = mtmips_get_function_name,
- .pinmux_group_set = mtmips_pinmux_group_set,
- .pinconf_num_params = ARRAY_SIZE(mt7628_conf_params),
- .pinconf_params = mt7628_conf_params,
- .get_pins_count = mt7628_get_pins_count,
- .get_pin_name = mt7628_get_pin_name,
- .pinconf_set = mt7628_pinconf_set,
- .set_state = pinctrl_generic_set_state,
- { .compatible = "mediatek,mt7628-pinctrl" },
- .name = "mt7628-pinctrl",
- .id = UCLASS_PINCTRL,
- .of_match = mt7628_pinctrl_ids,
- .ofdata_to_platdata = mt7628_pinctrl_ofdata_to_platdata,
- .ops = &mt7628_pinctrl_ops,
- .probe = mt7628_pinctrl_probe,
- .priv_auto_alloc_size = sizeof(struct mt7628_pinctrl_priv),
- u32 val;
- val = readl(priv->base + reg);
- val &= ~(mask << shift);
- val |= value << shift;
- writel(val, priv->base + reg);
- struct mtmips_pinctrl_priv *priv = dev_get_priv(dev);
- return priv->nfuncs;
- return priv->funcs[selector]->name;
- const struct mtmips_pmx_group *grp = &priv->groups[group_selector];
- const struct mtmips_pmx_func *func = priv->funcs[func_selector];
- int i;
- if (!grp->nfuncs)
- for (i = 0; i < grp->nfuncs; i++) {
- return -EINVAL;
- int i, j, n;
- priv->ngroups = ngroups;
- priv->groups = groups;
- priv->nfuncs = 0;
- for (i = 0; i < ngroups; i++)
- priv->funcs = malloc(priv->nfuncs * sizeof(*priv->funcs));
- if (!priv->funcs)
return -ENOMEM;
- n = 0;
- for (i = 0; i < ngroups; i++) {
- const char *name;
- int value;
- const char *name;
- u32 reg;
- u32 shift;
- char mask;
- int nfuncs;
- const struct mtmips_pmx_func *funcs;
- void __iomem *base;
- u32 ngroups;
- const struct mtmips_pmx_group *groups;
- u32 nfuncs;
- const struct mtmips_pmx_func **funcs;
- { .name = (_name), .reg = (_reg), .shift = (_shift), .mask = (_mask), \
This patch adds pinctrl node with default pin state for mt7628an.dtsi.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/mt7628a.dtsi | 150 +++++++++++++++++++++++++++++++++++++ 1 file changed, 150 insertions(+)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 6d2142f429..8afea1865d 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -57,6 +57,156 @@ u-boot,dm-pre-reloc; };
+ pinctrl: pinctrl@60 { + compatible = "mediatek,mt7628-pinctrl"; + reg = <0x3c 0x2c>, <0x1300 0x100>; + reg-names = "gpiomode", "padconf"; + + pinctrl-names = "default"; + pinctrl-0 = <&state_default>; + + state_default: pin_state { + }; + + spi_single_pins: spi_single_pins { + groups = "spi"; + function = "spi"; + }; + + spi_dual_pins: spi_dual_pins { + spi_master_pins { + groups = "spi"; + function = "spi"; + }; + + spi_cs1_pin { + groups = "spi cs1"; + function = "spi cs1"; + }; + }; + + uart0_pins: uart0_pins { + groups = "uart0"; + function = "uart0"; + }; + + uart1_pins: uart1_pins { + groups = "uart1"; + function = "uart1"; + }; + + uart2_pins: uart2_pins { + groups = "uart2"; + function = "uart2"; + }; + + i2c_pins: i2c_pins { + groups = "i2c"; + function = "i2c"; + }; + + ephy_iot_mode: ephy_iot_mode { + ephy4_1_dis { + groups = "ephy4_1_pad"; + function = "digital"; + }; + + ephy0_en { + groups = "ephy0"; + function = "enable"; + }; + }; + + ephy_router_mode: ephy_router_mode { + ephy4_1_en { + groups = "ephy4_1_pad"; + function = "analog"; + }; + + ephy0_en { + groups = "ephy0"; + function = "enable"; + }; + }; + + sd_iot_mode: sd_iot_mode { + ephy4_1_dis { + groups = "ephy4_1_pad"; + function = "digital"; + }; + + sdxc_en { + groups = "sdmode"; + function = "sdxc"; + }; + + sdxc_iot_mode { + groups = "sd router"; + function = "iot"; + }; + + sd_clk_pad { + pins = "sd_clk"; + drive-strength-4g = <8>; + }; + }; + + sd_router_mode: sd_router_mode { + sdxc_router_mode { + groups = "sd router"; + function = "router"; + }; + + sdxc_map_pins { + groups = "gpio0", "i2s", "sdmode", \ + "i2c", "uart1"; + function = "gpio"; + }; + + sd_clk_pad { + pins = "gpio0"; + drive-strength-28 = <8>; + }; + }; + + emmc_iot_8bit_mode: emmc_iot_8bit_mode { + ephy4_1_dis { + groups = "ephy4_1_pad"; + function = "digital"; + }; + + emmc_en { + groups = "sdmode"; + function = "sdxc"; + }; + + emmc_iot_mode { + groups = "sd router"; + function = "iot"; + }; + + emmc_d4_d5 { + groups = "uart2"; + function = "sdxc d5 d4"; + }; + + emmc_d6 { + groups = "pwm1"; + function = "sdxc d6"; + }; + + emmc_d7 { + groups = "pwm0"; + function = "sdxc d7"; + }; + + sd_clk_pad { + pins = "sd_clk"; + drive-strength-4g = <8>; + }; + }; + }; + watchdog: watchdog@100 { compatible = "ralink,mt7628a-wdt", "mediatek,mt7621-wdt"; reg = <0x100 0x30>;
This patch adds default pinctrl for uart nodes
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/mt7628a.dtsi | 9 +++++++++ 1 file changed, 9 insertions(+)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 8afea1865d..44fbbd5b25 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -286,6 +286,9 @@ compatible = "mediatek,hsuart", "ns16550a"; reg = <0xc00 0x100>;
+ pinctrl-names = "default"; + pinctrl-0 = <&uart0_pins>; + clocks = <&clkctrl CLK_UART0>;
resets = <&resetc 12>; @@ -301,6 +304,9 @@ compatible = "mediatek,hsuart", "ns16550a"; reg = <0xd00 0x100>;
+ pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; + clocks = <&clkctrl CLK_UART1>;
resets = <&resetc 19>; @@ -316,6 +322,9 @@ compatible = "mediatek,hsuart", "ns16550a"; reg = <0xe00 0x100>;
+ pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; + clocks = <&clkctrl CLK_UART2>;
This patch adds reset controller driver for MediaTek MIPS platform and header file for mt7628.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/reset/Kconfig | 7 ++ drivers/reset/Makefile | 1 + drivers/reset/reset-mtmips.c | 82 ++++++++++++++++++++++++ include/dt-bindings/reset/mt7628-reset.h | 36 +++++++++++ 4 files changed, 126 insertions(+) create mode 100644 drivers/reset/reset-mtmips.c create mode 100644 include/dt-bindings/reset/mt7628-reset.h
diff --git a/drivers/reset/Kconfig b/drivers/reset/Kconfig index 6ec6f39c85..76866a2e90 100644 --- a/drivers/reset/Kconfig +++ b/drivers/reset/Kconfig @@ -113,6 +113,13 @@ config RESET_MEDIATEK help Support for reset controller on MediaTek SoCs.
+config RESET_MTMIPS + bool "Reset controller driver for MediaTek MIPS platform" + depends on DM_RESET && ARCH_MTMIPS + default y + help + Support for reset controller on MediaTek MIPS platform. + config RESET_SUNXI bool "RESET support for Allwinner SoCs" depends on DM_RESET && ARCH_SUNXI diff --git a/drivers/reset/Makefile b/drivers/reset/Makefile index 7fec75bb49..87d2bc4f18 100644 --- a/drivers/reset/Makefile +++ b/drivers/reset/Makefile @@ -18,5 +18,6 @@ obj-$(CONFIG_RESET_ROCKCHIP) += reset-rockchip.o obj-$(CONFIG_RESET_MESON) += reset-meson.o obj-$(CONFIG_RESET_SOCFPGA) += reset-socfpga.o obj-$(CONFIG_RESET_MEDIATEK) += reset-mediatek.o +obj-$(CONFIG_RESET_MTMIPS) += reset-mtmips.o obj-$(CONFIG_RESET_SUNXI) += reset-sunxi.o obj-$(CONFIG_RESET_HISILICON) += reset-hisilicon.o diff --git a/drivers/reset/reset-mtmips.c b/drivers/reset/reset-mtmips.c new file mode 100644 index 0000000000..59734565d7 --- /dev/null +++ b/drivers/reset/reset-mtmips.c @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Copyright (C) 2019 MediaTek Inc. All Rights Reserved. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#include <common.h> +#include <dm.h> +#include <errno.h> +#include <reset-uclass.h> +#include <linux/io.h> + +struct mtmips_reset_priv { + void __iomem *base; +}; + +static int mtmips_reset_request(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int mtmips_reset_free(struct reset_ctl *reset_ctl) +{ + return 0; +} + +static int mtmips_reset_assert(struct reset_ctl *reset_ctl) +{ + struct mtmips_reset_priv *priv = dev_get_priv(reset_ctl->dev); + + setbits_32(priv->base, BIT(reset_ctl->id)); + + return 0; +} + +static int mtmips_reset_deassert(struct reset_ctl *reset_ctl) +{ + struct mtmips_reset_priv *priv = dev_get_priv(reset_ctl->dev); + + clrbits_32(priv->base, BIT(reset_ctl->id)); + + return 0; +} + +static const struct reset_ops mtmips_reset_ops = { + .request = mtmips_reset_request, + .free = mtmips_reset_free, + .rst_assert = mtmips_reset_assert, + .rst_deassert = mtmips_reset_deassert, +}; + +static int mtmips_reset_probe(struct udevice *dev) +{ + return 0; +} + +static int mtmips_reset_ofdata_to_platdata(struct udevice *dev) +{ + struct mtmips_reset_priv *priv = dev_get_priv(dev); + + priv->base = (void __iomem *)dev_remap_addr_index(dev, 0); + if (!priv->base) + return -EINVAL; + + return 0; +} + +static const struct udevice_id mtmips_reset_ids[] = { + { .compatible = "mediatek,mtmips-reset" }, + { } +}; + +U_BOOT_DRIVER(mtmips_reset) = { + .name = "mtmips-reset", + .id = UCLASS_RESET, + .of_match = mtmips_reset_ids, + .ofdata_to_platdata = mtmips_reset_ofdata_to_platdata, + .probe = mtmips_reset_probe, + .priv_auto_alloc_size = sizeof(struct mtmips_reset_priv), + .ops = &mtmips_reset_ops, +}; diff --git a/include/dt-bindings/reset/mt7628-reset.h b/include/dt-bindings/reset/mt7628-reset.h new file mode 100644 index 0000000000..2a674c1ea7 --- /dev/null +++ b/include/dt-bindings/reset/mt7628-reset.h @@ -0,0 +1,36 @@ +/* SPDX-License-Identifier: GPL-2.0 */ +/* + * Copyright (C) 2019 MediaTek Inc. + * + * Author: Weijie Gao weijie.gao@mediatek.com + */ + +#ifndef _DT_BINDINGS_MT7628_RESET_H_ +#define _DT_BINDINGS_MT7628_RESET_H_ + +#define MT7628_PWM_RST 31 +#define MT7628_SDXC_RST 30 +#define MT7628_CRYPTO_RST 29 +#define MT7628_AUX_STCK_RST 28 +#define MT7628_PCIE_RST 26 +#define MT7628_EPHY_RST 24 +#define MT7628_ETH_RST 23 +#define MT7628_UPHY_RST 22 +#define MT7628_UART2_RST 20 +#define MT7628_UART1_RST 19 +#define MT7628_SPI_RST 18 +#define MT7628_I2S_RST 17 +#define MT7628_I2C_RST 16 +#define MT7628_GDMA_RST 14 +#define MT7628_PIO_RST 13 +#define MT7628_UART0_RST 12 +#define MT7628_PCM_RST 11 +#define MT7628_MC_RST 10 +#define MT7628_INT_RST 9 +#define MT7628_TIMER_RST 8 +#define MT7628_HIF_RST 5 +#define MT7628_WIFI_RST 4 +#define MT7628_SPIS_RST 3 +#define MT7628_SYS_RST 0 + +#endif /* _DT_BINDINGS_MT7628_RESET_H_ */
This patch updates reset controller node for mt7628
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/mt7628a.dtsi | 36 ++++++++++++++++++++++++------------ 1 file changed, 24 insertions(+), 12 deletions(-)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 44fbbd5b25..b0e0ed7ec8 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -1,5 +1,6 @@ // SPDX-License-Identifier: GPL-2.0 #include <dt-bindings/clock/mt7628-clk.h> +#include <dt-bindings/reset/mt7628-reset.h>
/ { #address-cells = <1>; @@ -17,11 +18,6 @@ }; };
- resetc: reset-controller { - compatible = "ralink,rt2880-reset"; - #reset-cells = <1>; - }; - cpuintc: interrupt-controller { #address-cells = <0>; #interrupt-cells = <1>; @@ -57,6 +53,12 @@ u-boot,dm-pre-reloc; };
+ rstctrl: rstctrl@0x34 { + reg = <0x34 0x4>; + compatible = "mediatek,mtmips-reset"; + #reset-cells = <1>; + }; + pinctrl: pinctrl@60 { compatible = "mediatek,mt7628-pinctrl"; reg = <0x3c 0x2c>, <0x1300 0x100>; @@ -211,7 +213,7 @@ compatible = "ralink,mt7628a-wdt", "mediatek,mt7621-wdt"; reg = <0x100 0x30>;
- resets = <&resetc 8>; + resets = <&rstctrl MT7628_TIMER_RST>; reset-names = "wdt";
interrupt-parent = <&intc>; @@ -225,7 +227,7 @@ interrupt-controller; #interrupt-cells = <1>;
- resets = <&resetc 9>; + resets = <&rstctrl MT7628_INT_RST>; reset-names = "intc";
interrupt-parent = <&cpuintc>; @@ -248,6 +250,9 @@ compatible = "mtk,mt7628-gpio", "mtk,mt7621-gpio"; reg = <0x600 0x100>;
+ resets = <&rstctrl MT7628_PIO_RST>; + reset-names = "pio"; + interrupt-parent = <&intc>; interrupts = <6>;
@@ -276,6 +281,10 @@ spi0: spi@b00 { compatible = "ralink,mt7621-spi"; reg = <0xb00 0x40>; + + resets = <&rstctrl MT7628_SPI_RST>; + reset-names = "spi"; + #address-cells = <1>; #size-cells = <0>;
@@ -291,7 +300,7 @@
- resets = <&resetc 12>; + resets = <&rstctrl MT7628_UART0_RST>; reset-names = "uart0";
interrupt-parent = <&intc>; @@ -309,7 +318,7 @@
- resets = <&resetc 19>; + resets = <&rstctrl MT7628_UART1_RST>; reset-names = "uart1";
interrupt-parent = <&intc>; @@ -327,7 +336,7 @@
- resets = <&resetc 20>; + resets = <&rstctrl MT7628_UART2_RST>; reset-names = "uart2";
interrupt-parent = <&intc>; @@ -342,6 +351,9 @@ reg = <0x10100000 0x10000 0x10110000 0x8000>;
+ resets = <&rstctrl MT7628_EPHY_RST>; + reset-names = "ephy"; + syscon = <&sysc>; };
@@ -353,8 +365,8 @@
- resets = <&resetc 22 &resetc 25>; - reset-names = "host", "device"; + resets = <&rstctrl MT7628_UPHY_RST>; + reset-names = "phy";
clocks = <&clkctrl CLK_UPHY>; clock-names = "cg";
This patch adds slew rate calibration for mt76x8-usb-phy, removes code which belongs to mt7620, and gets rid of using syscon and regmap by using clock driver and reset controller.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/phy/Kconfig | 2 + drivers/phy/mt76x8-usb-phy.c | 225 ++++++++++++++++++++++++----------- 2 files changed, 159 insertions(+), 68 deletions(-)
diff --git a/drivers/phy/Kconfig b/drivers/phy/Kconfig index 02312273e2..5c7b221431 100644 --- a/drivers/phy/Kconfig +++ b/drivers/phy/Kconfig @@ -200,6 +200,8 @@ config KEYSTONE_USB_PHY config MT76X8_USB_PHY bool "MediaTek MT76x8 (7628/88) USB PHY support" depends on PHY + select CLK + select DM_RESET help Support the USB PHY in MT76x8 SoCs
diff --git a/drivers/phy/mt76x8-usb-phy.c b/drivers/phy/mt76x8-usb-phy.c index 268da8ef6c..1e7c5f334b 100644 --- a/drivers/phy/mt76x8-usb-phy.c +++ b/drivers/phy/mt76x8-usb-phy.c @@ -6,93 +6,185 @@ * Copyright (C) 2017 John Crispin john@phrozen.org */
+#include <clk.h> #include <common.h> #include <dm.h> #include <generic-phy.h> -#include <regmap.h> -#include <reset-uclass.h> -#include <syscon.h> +#include <reset.h> #include <asm/io.h> - -#define RT_SYSC_REG_SYSCFG1 0x014 -#define RT_SYSC_REG_CLKCFG1 0x030 -#define RT_SYSC_REG_USB_PHY_CFG 0x05c +#include <linux/bitops.h>
#define OFS_U2_PHY_AC0 0x800 +#define USBPLL_FBDIV_S 16 +#define USBPLL_FBDIV_M GENMASK(22, 16) +#define BG_TRIM_S 8 +#define BG_TRIM_M GENMASK(11, 8) +#define BG_RBSEL_S 6 +#define BG_RBSEL_M GENMASK(7, 6) +#define BG_RASEL_S 4 +#define BG_RASEL_M GENMASK(5, 4) +#define BGR_DIV_S 2 +#define BGR_DIV_M GENMASK(3, 2) +#define CHP_EN BIT(1) + #define OFS_U2_PHY_AC1 0x804 +#define VRT_VREF_SEL_S 28 +#define VRT_VREF_SEL_M GENMASK(30, 28) +#define TERM_VREF_SEL_S 24 +#define TERM_VREF_SEL_M GENMASK(26, 24) +#define USBPLL_RSVD BIT(4) +#define USBPLL_ACCEN BIT(3) +#define USBPLL_LF BIT(2) + #define OFS_U2_PHY_AC2 0x808 + #define OFS_U2_PHY_ACR0 0x810 -#define OFS_U2_PHY_ACR1 0x814 -#define OFS_U2_PHY_ACR2 0x818 +#define HSTX_SRCAL_EN BIT(23) +#define HSTX_SRCTRL_S 16 +#define HSTX_SRCTRL_M GENMASK(18, 16) + #define OFS_U2_PHY_ACR3 0x81C -#define OFS_U2_PHY_ACR4 0x820 -#define OFS_U2_PHY_AMON0 0x824 +#define HSTX_DBIST_S 28 +#define HSTX_DBIST_M GENMASK(31, 28) +#define HSRX_BIAS_EN_SEL_S 20 +#define HSRX_BIAS_EN_SEL_M GENMASK(21, 20) + #define OFS_U2_PHY_DCR0 0x860 -#define OFS_U2_PHY_DCR1 0x864 +#define PHYD_RESERVE_S 8 +#define PHYD_RESERVE_M GENMASK(23, 8) +#define CDR_FILT_S 0 +#define CDR_FILT_M GENMASK(3, 0) + #define OFS_U2_PHY_DTM0 0x868 -#define OFS_U2_PHY_DTM1 0x86C +#define FORCE_USB_CLKEN BIT(25) + +#define OFS_FM_CR0 0xf00 +#define FREQDET_EN BIT(24) +#define CYCLECNT_S 0 +#define CYCLECNT_M GENMASK(23, 0)
-#define RT_RSTCTRL_UDEV BIT(25) -#define RT_RSTCTRL_UHST BIT(22) -#define RT_SYSCFG1_USB0_HOST_MODE BIT(10) +#define OFS_FM_MONR0 0xf0c
-#define MT7620_CLKCFG1_UPHY0_CLK_EN BIT(25) -#define MT7620_CLKCFG1_UPHY1_CLK_EN BIT(22) -#define RT_CLKCFG1_UPHY1_CLK_EN BIT(20) -#define RT_CLKCFG1_UPHY0_CLK_EN BIT(18) +#define OFS_FM_MONR1 0xf10 +#define FRCK_EN BIT(8)
-#define USB_PHY_UTMI_8B60M BIT(1) -#define UDEV_WAKEUP BIT(0) +#define U2_SR_COEF_7628 32
struct mt76x8_usb_phy { - u32 clk; void __iomem *base; - struct regmap *sysctl; + struct clk cg; /* for clock gating */ + struct reset_ctl rst_phy; };
-static void u2_phy_w32(struct mt76x8_usb_phy *phy, u32 val, u32 reg) +static void phy_w32(struct mt76x8_usb_phy *phy, u32 reg, u32 val) { writel(val, phy->base + reg); }
-static u32 u2_phy_r32(struct mt76x8_usb_phy *phy, u32 reg) +static u32 phy_r32(struct mt76x8_usb_phy *phy, u32 reg) { return readl(phy->base + reg); }
+static void phy_rmw32(struct mt76x8_usb_phy *phy, u32 reg, u32 clr, u32 set) +{ + clrsetbits_32(phy->base + reg, clr, set); +} + static void mt76x8_usb_phy_init(struct mt76x8_usb_phy *phy) { - u2_phy_r32(phy, OFS_U2_PHY_AC2); - u2_phy_r32(phy, OFS_U2_PHY_ACR0); - u2_phy_r32(phy, OFS_U2_PHY_DCR0); - - u2_phy_w32(phy, 0x00ffff02, OFS_U2_PHY_DCR0); - u2_phy_r32(phy, OFS_U2_PHY_DCR0); - u2_phy_w32(phy, 0x00555502, OFS_U2_PHY_DCR0); - u2_phy_r32(phy, OFS_U2_PHY_DCR0); - u2_phy_w32(phy, 0x00aaaa02, OFS_U2_PHY_DCR0); - u2_phy_r32(phy, OFS_U2_PHY_DCR0); - u2_phy_w32(phy, 0x00000402, OFS_U2_PHY_DCR0); - u2_phy_r32(phy, OFS_U2_PHY_DCR0); - u2_phy_w32(phy, 0x0048086a, OFS_U2_PHY_AC0); - u2_phy_w32(phy, 0x4400001c, OFS_U2_PHY_AC1); - u2_phy_w32(phy, 0xc0200000, OFS_U2_PHY_ACR3); - u2_phy_w32(phy, 0x02000000, OFS_U2_PHY_DTM0); + phy_r32(phy, OFS_U2_PHY_AC2); + phy_r32(phy, OFS_U2_PHY_ACR0); + phy_r32(phy, OFS_U2_PHY_DCR0); + + phy_w32(phy, OFS_U2_PHY_DCR0, + (0xffff << PHYD_RESERVE_S) | (2 << CDR_FILT_S)); + phy_r32(phy, OFS_U2_PHY_DCR0); + + phy_w32(phy, OFS_U2_PHY_DCR0, + (0x5555 << PHYD_RESERVE_S) | (2 << CDR_FILT_S)); + phy_r32(phy, OFS_U2_PHY_DCR0); + + phy_w32(phy, OFS_U2_PHY_DCR0, + (0xaaaa << PHYD_RESERVE_S) | (2 << CDR_FILT_S)); + phy_r32(phy, OFS_U2_PHY_DCR0); + + phy_w32(phy, OFS_U2_PHY_DCR0, + (4 << PHYD_RESERVE_S) | (2 << CDR_FILT_S)); + phy_r32(phy, OFS_U2_PHY_DCR0); + + phy_w32(phy, OFS_U2_PHY_AC0, + (0x48 << USBPLL_FBDIV_S) | (8 << BG_TRIM_S) | + (1 << BG_RBSEL_S) | (2 << BG_RASEL_S) | (2 << BGR_DIV_S) | + CHP_EN); + + phy_w32(phy, OFS_U2_PHY_AC1, + (4 << VRT_VREF_SEL_S) | (4 << TERM_VREF_SEL_S) | USBPLL_RSVD | + USBPLL_ACCEN | USBPLL_LF); + + phy_w32(phy, OFS_U2_PHY_ACR3, + (12 << HSTX_DBIST_S) | (2 << HSRX_BIAS_EN_SEL_S)); + + phy_w32(phy, OFS_U2_PHY_DTM0, FORCE_USB_CLKEN); +} + +static void mt76x8_usb_phy_sr_calibrate(struct mt76x8_usb_phy *phy) +{ + u32 fmout, tmp = 4; + int i; + + /* Enable HS TX SR calibration */ + phy_rmw32(phy, OFS_U2_PHY_ACR0, 0, HSTX_SRCAL_EN); + mdelay(1); + + /* Enable free run clock */ + phy_rmw32(phy, OFS_FM_MONR1, 0, FRCK_EN); + + /* Set cycle count = 0x400 */ + phy_rmw32(phy, OFS_FM_CR0, CYCLECNT_M, 0x400 << CYCLECNT_S); + + /* Enable frequency meter */ + phy_rmw32(phy, OFS_FM_CR0, 0, FREQDET_EN); + + /* Wait for FM detection done, set timeout to 10ms */ + for (i = 0; i < 10; i++) { + fmout = phy_r32(phy, OFS_FM_MONR0); + + if (fmout) + break; + + mdelay(1); + } + + /* Disable frequency meter */ + phy_rmw32(phy, OFS_FM_CR0, FREQDET_EN, 0); + + /* Disable free run clock */ + phy_rmw32(phy, OFS_FM_MONR1, FRCK_EN, 0); + + /* Disable HS TX SR calibration */ + phy_rmw32(phy, OFS_U2_PHY_ACR0, HSTX_SRCAL_EN, 0); + mdelay(1); + + if (fmout) { + /* + * set reg = (1024 / FM_OUT) * 25 * 0.028 + * (round to the nearest digits) + */ + tmp = (((1024 * 25 * U2_SR_COEF_7628) / fmout) + 500) / 1000; + } + + phy_rmw32(phy, OFS_U2_PHY_ACR0, HSTX_SRCTRL_M, + (tmp << HSTX_SRCTRL_S) & HSTX_SRCTRL_M); }
static int mt76x8_usb_phy_power_on(struct phy *_phy) { struct mt76x8_usb_phy *phy = dev_get_priv(_phy->dev); - u32 t;
- /* enable the phy */ - regmap_update_bits(phy->sysctl, RT_SYSC_REG_CLKCFG1, - phy->clk, phy->clk); + clk_enable(&phy->cg);
- /* setup host mode */ - regmap_update_bits(phy->sysctl, RT_SYSC_REG_SYSCFG1, - RT_SYSCFG1_USB0_HOST_MODE, - RT_SYSCFG1_USB0_HOST_MODE); + reset_deassert(&phy->rst_phy);
/* * The SDK kernel had a delay of 100ms. however on device @@ -100,17 +192,8 @@ static int mt76x8_usb_phy_power_on(struct phy *_phy) */ mdelay(10);
- if (phy->base) - mt76x8_usb_phy_init(phy); - - /* print some status info */ - regmap_read(phy->sysctl, RT_SYSC_REG_USB_PHY_CFG, &t); - printf("remote usb device wakeup %s\n", - (t & UDEV_WAKEUP) ? "enabled" : "disabled"); - if (t & USB_PHY_UTMI_8B60M) - printf("UTMI 8bit 60MHz\n"); - else - printf("UTMI 16bit 30MHz\n"); + mt76x8_usb_phy_init(phy); + mt76x8_usb_phy_sr_calibrate(phy);
return 0; } @@ -119,9 +202,9 @@ static int mt76x8_usb_phy_power_off(struct phy *_phy) { struct mt76x8_usb_phy *phy = dev_get_priv(_phy->dev);
- /* disable the phy */ - regmap_update_bits(phy->sysctl, RT_SYSC_REG_CLKCFG1, - phy->clk, 0); + clk_disable(&phy->cg); + + reset_assert(&phy->rst_phy);
return 0; } @@ -129,15 +212,21 @@ static int mt76x8_usb_phy_power_off(struct phy *_phy) static int mt76x8_usb_phy_probe(struct udevice *dev) { struct mt76x8_usb_phy *phy = dev_get_priv(dev); - - phy->sysctl = syscon_regmap_lookup_by_phandle(dev, "ralink,sysctl"); - if (IS_ERR(phy->sysctl)) - return PTR_ERR(phy->sysctl); + int ret;
phy->base = dev_read_addr_ptr(dev); if (!phy->base) return -EINVAL;
+ /* clock gate */ + ret = clk_get_by_name(dev, "cg", &phy->cg); + if (ret) + return ret; + + ret = reset_get_by_name(dev, "phy", &phy->rst_phy); + if (ret) + return ret; + return 0; }
- select CLK
- select DM_RESET
in patch 27/28 you select those unconditionally for ARCH_MTMIPS. Thus it's superfluous here. Maybe the depends on should be changed to PHY && ARCH_MTMIPS instead?
Copyright (C) 2017 John Crispin <john@phrozen.org>
- struct clk cg; /* for clock gating */
- struct reset_ctl rst_phy;
- clrsetbits_32(phy->base + reg, clr, set);
- phy_r32(phy, OFS_U2_PHY_AC2);
- phy_r32(phy, OFS_U2_PHY_ACR0);
- phy_r32(phy, OFS_U2_PHY_DCR0);
- phy_w32(phy, OFS_U2_PHY_DCR0,
- phy_w32(phy, OFS_U2_PHY_AC0,
CHP_EN);
- phy_w32(phy, OFS_U2_PHY_AC1,
- phy_w32(phy, OFS_U2_PHY_ACR3,
- phy_w32(phy, OFS_U2_PHY_DTM0, FORCE_USB_CLKEN);
- u32 fmout, tmp = 4;
- int i;
- /* Enable HS TX SR calibration */
- phy_rmw32(phy, OFS_U2_PHY_ACR0, 0, HSTX_SRCAL_EN);
- mdelay(1);
- /* Enable free run clock */
- phy_rmw32(phy, OFS_FM_MONR1, 0, FRCK_EN);
- /* Set cycle count = 0x400 */
- phy_rmw32(phy, OFS_FM_CR0, CYCLECNT_M, 0x400 << CYCLECNT_S);
- /* Enable frequency meter */
- phy_rmw32(phy, OFS_FM_CR0, 0, FREQDET_EN);
- /* Wait for FM detection done, set timeout to 10ms */
- for (i = 0; i < 10; i++) {
if (fmout)
break;
mdelay(1);
- /* Disable frequency meter */
- phy_rmw32(phy, OFS_FM_CR0, FREQDET_EN, 0);
- /* Disable free run clock */
- phy_rmw32(phy, OFS_FM_MONR1, FRCK_EN, 0);
- /* Disable HS TX SR calibration */
- phy_rmw32(phy, OFS_U2_PHY_ACR0, HSTX_SRCAL_EN, 0);
- mdelay(1);
- if (fmout) {
- phy_rmw32(phy, OFS_U2_PHY_ACR0, HSTX_SRCTRL_M,
u32 t;
- clk_enable(&phy->cg);
- The SDK kernel had a delay of 100ms. however on device
- if (phy->base)
- else
phy->clk, 0);
int ret;
/* clock gate */
if (ret)
return ret;
if (ret)
return ret;
This patch removes hardcoded gpio settings as they have been replaced by pinctrl in dts, and also replaces regmap-based phy reset with a more generic reset controller.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/net/mt7628-eth.c | 45 +++++++--------------------------------- 1 file changed, 8 insertions(+), 37 deletions(-)
diff --git a/drivers/net/mt7628-eth.c b/drivers/net/mt7628-eth.c index 7833b2f47a..4675b0f003 100644 --- a/drivers/net/mt7628-eth.c +++ b/drivers/net/mt7628-eth.c @@ -18,23 +18,12 @@ #include <malloc.h> #include <miiphy.h> #include <net.h> -#include <regmap.h> -#include <syscon.h> +#include <reset.h> #include <wait_bit.h> #include <asm/io.h> #include <linux/bitfield.h> #include <linux/err.h>
-/* System controller register */ -#define MT7628_RSTCTRL_REG 0x34 -#define RSTCTRL_EPHY_RST BIT(24) - -#define MT7628_AGPIO_CFG_REG 0x3c -#define MT7628_EPHY_GPIO_AIO_EN GENMASK(20, 17) -#define MT7628_EPHY_P0_DIS BIT(16) - -#define MT7628_GPIO2_MODE_REG 0x64 - /* Ethernet frame engine register */ #define PDMA_RELATED 0x0800
@@ -137,7 +126,6 @@ struct fe_tx_dma { struct mt7628_eth_dev { void __iomem *base; /* frame engine base address */ void __iomem *eth_sw_base; /* switch base address */ - struct regmap *sysctrl_regmap; /* system-controller reg-map */
struct mii_dev *bus;
@@ -150,6 +138,8 @@ struct mt7628_eth_dev { int rx_dma_idx; /* Point to the next TXD in TXD Ring0 CPU wants to use */ int tx_dma_idx; + + struct reset_ctl rst_ephy; };
static int mdio_wait_read(struct mt7628_eth_dev *priv, u32 mask, bool mask_set) @@ -301,20 +291,9 @@ static void rt305x_esw_init(struct mt7628_eth_dev *priv) /* 1us cycle number=125 (FE's clock=125Mhz) */ writel(0x7d000000, base + MT7628_SWITCH_BMU_CTRL);
- /* Configure analog GPIO setup */ - regmap_update_bits(priv->sysctrl_regmap, MT7628_AGPIO_CFG_REG, - MT7628_EPHY_P0_DIS, MT7628_EPHY_GPIO_AIO_EN); - /* Reset PHY */ - regmap_update_bits(priv->sysctrl_regmap, MT7628_RSTCTRL_REG, - 0, RSTCTRL_EPHY_RST); - regmap_update_bits(priv->sysctrl_regmap, MT7628_RSTCTRL_REG, - RSTCTRL_EPHY_RST, 0); - mdelay(10); - - /* Set P0 EPHY LED mode */ - regmap_update_bits(priv->sysctrl_regmap, MT7628_GPIO2_MODE_REG, - 0x0ffc0ffc, 0x05540554); + reset_assert(&priv->rst_ephy); + reset_deassert(&priv->rst_ephy); mdelay(10);
mt7628_ephy_init(priv); @@ -558,7 +537,6 @@ static void mt7628_eth_stop(struct udevice *dev) static int mt7628_eth_probe(struct udevice *dev) { struct mt7628_eth_dev *priv = dev_get_priv(dev); - struct udevice *syscon; struct mii_dev *bus; int ret; int i; @@ -573,20 +551,13 @@ static int mt7628_eth_probe(struct udevice *dev) if (IS_ERR(priv->eth_sw_base)) return PTR_ERR(priv->eth_sw_base);
- /* Get system controller regmap */ - ret = uclass_get_device_by_phandle(UCLASS_SYSCON, dev, - "syscon", &syscon); + /* Reset controller */ + ret = reset_get_by_name(dev, "ephy", &priv->rst_ephy); if (ret) { - pr_err("unable to find syscon device\n"); + pr_err("unable to find reset controller for ethernet PHYs\n"); return ret; }
- priv->sysctrl_regmap = syscon_get_regmap(syscon); - if (!priv->sysctrl_regmap) { - pr_err("unable to find regmap\n"); - return -ENODEV; - } - /* Put rx and tx rings into KSEG1 area (uncached) */ priv->tx_ring = (struct fe_tx_dma *) KSEG1ADDR(memalign(ARCH_DMA_MINALIGN,
The mt7628 has an embedded ethernet switch (5 phy ports + 1 cpu port). Although in IOT mode only port0 is usable, the phy0 is still connected to the switch, not the ethernet gmac directly.
This patch rewrites it and makes it optional. It can be turned on by adding mediatek,poll-link-phy = <?> explicitly into the eth node. By default the driver is switch mode with all 5 phy ports working without link detection.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Make link detection optional rather than removing directly. --- drivers/net/Kconfig | 1 + drivers/net/mt7628-eth.c | 59 ++++++++++++++++++++-------------------- 2 files changed, 31 insertions(+), 29 deletions(-)
diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 2ce3092db0..eb3d7ed45f 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -322,6 +322,7 @@ config MACB_ZYNQ config MT7628_ETH bool "MediaTek MT7628 Ethernet Interface" depends on SOC_MT7628 + select PHYLIB help The MediaTek MT7628 ethernet interface is used on MT7628 and MT7688 based boards. diff --git a/drivers/net/mt7628-eth.c b/drivers/net/mt7628-eth.c index 4675b0f003..abfdc75ad8 100644 --- a/drivers/net/mt7628-eth.c +++ b/drivers/net/mt7628-eth.c @@ -111,6 +111,7 @@ struct fe_tx_dma {
#define NUM_RX_DESC 256 #define NUM_TX_DESC 4 +#define NUM_PHYS 5
#define PADDING_LENGTH 60
@@ -120,9 +121,6 @@ struct fe_tx_dma { #define CONFIG_DMA_STOP_TIMEOUT 100 #define CONFIG_TX_DMA_TIMEOUT 100
-#define LINK_DELAY_TIME 500 /* 500 ms */ -#define LINK_TIMEOUT 10000 /* 10 seconds */ - struct mt7628_eth_dev { void __iomem *base; /* frame engine base address */ void __iomem *eth_sw_base; /* switch base address */ @@ -140,6 +138,8 @@ struct mt7628_eth_dev { int tx_dma_idx;
struct reset_ctl rst_ephy; + + struct phy_device *phy; };
static int mdio_wait_read(struct mt7628_eth_dev *priv, u32 mask, bool mask_set) @@ -437,20 +437,13 @@ static int mt7628_eth_free_pkt(struct udevice *dev, uchar *packet, int length) return 0; }
-static int phy_link_up(struct mt7628_eth_dev *priv) -{ - u32 val; - - mii_mgr_read(priv, 0x00, MII_BMSR, &val); - return !!(val & BMSR_LSTATUS); -} - static int mt7628_eth_start(struct udevice *dev) { struct mt7628_eth_dev *priv = dev_get_priv(dev); void __iomem *base = priv->base; uchar packet[MTK_QDMA_PAGE_SIZE]; uchar *packetp; + int ret; int i;
for (i = 0; i < NUM_RX_DESC; i++) { @@ -493,25 +486,13 @@ static int mt7628_eth_start(struct udevice *dev) wmb(); eth_dma_start(priv);
- /* Check if link is not up yet */ - if (!phy_link_up(priv)) { - /* Wait for link to come up */ - - printf("Waiting for link to come up ."); - for (i = 0; i < (LINK_TIMEOUT / LINK_DELAY_TIME); i++) { - mdelay(LINK_DELAY_TIME); - if (phy_link_up(priv)) { - mdelay(100); /* Ensure all is ready */ - break; - } + if (priv->phy) { + ret = phy_startup(priv->phy); + if (ret) + return ret;
- printf("."); - } - - if (phy_link_up(priv)) - printf(" done\n"); - else - printf(" timeout! Trying anyways\n"); + if (!priv->phy->link) + return -EAGAIN; }
/* @@ -538,6 +519,7 @@ static int mt7628_eth_probe(struct udevice *dev) { struct mt7628_eth_dev *priv = dev_get_priv(dev); struct mii_dev *bus; + int poll_link_phy; int ret; int i;
@@ -584,6 +566,25 @@ static int mt7628_eth_probe(struct udevice *dev) if (ret) return ret;
+ poll_link_phy = dev_read_u32_default(dev, "mediatek,poll-link-phy", -1); + if (poll_link_phy >= 0) { + if (poll_link_phy >= NUM_PHYS) { + pr_err("invalid phy %d for poll-link-phy\n", + poll_link_phy); + return ret; + } + + priv->phy = phy_connect(bus, poll_link_phy, dev, + PHY_INTERFACE_MODE_MII); + if (!priv->phy) { + pr_err("failed to probe phy %d\n", poll_link_phy); + return -ENODEV; + } + + priv->phy->advertising = priv->phy->supported; + phy_config(priv->phy); + } + /* Switch configuration */ rt305x_esw_init(priv);
When received a packet with an invalid length recorded in rx descriptor, we should free this rx descriptor to allow us to continue to receive following packets. Without doing so, u-boot will stuck in a dead loop trying to process this invalid rx descriptor.
This patch adds a call to mt7628_eth_free_pkt() after received an invalid packet length.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/net/mt7628-eth.c | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/drivers/net/mt7628-eth.c b/drivers/net/mt7628-eth.c index abfdc75ad8..d77da26d50 100644 --- a/drivers/net/mt7628-eth.c +++ b/drivers/net/mt7628-eth.c @@ -142,6 +142,8 @@ struct mt7628_eth_dev { struct phy_device *phy; };
+static int mt7628_eth_free_pkt(struct udevice *dev, uchar *packet, int length); + static int mdio_wait_read(struct mt7628_eth_dev *priv, u32 mask, bool mask_set) { void __iomem *base = priv->eth_sw_base; @@ -403,6 +405,7 @@ static int mt7628_eth_recv(struct udevice *dev, int flags, uchar **packetp) length = FIELD_GET(RX_DMA_PLEN0, priv->rx_ring[idx].rxd2); if (length == 0 || length > MTK_QDMA_PAGE_SIZE) { printf("%s: invalid length (%d bytes)\n", __func__, length); + mt7628_eth_free_pkt(dev, NULL, 0); return -EIO; }
This patch add support for mt7628-eth to isolate LAN/WAN ports mainly to prevent LAN devices from getting IP address from WAN.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/net/mt7628-eth.c | 32 ++++++++++++++++++++++++++++++++ 1 file changed, 32 insertions(+)
diff --git a/drivers/net/mt7628-eth.c b/drivers/net/mt7628-eth.c index d77da26d50..a1d12f6902 100644 --- a/drivers/net/mt7628-eth.c +++ b/drivers/net/mt7628-eth.c @@ -57,6 +57,11 @@ /* Ethernet switch register */ #define MT7628_SWITCH_FCT0 0x0008 #define MT7628_SWITCH_PFC1 0x0014 +#define MT7628_SWITCH_PVIDC0 0x0040 +#define MT7628_SWITCH_PVIDC1 0x0044 +#define MT7628_SWITCH_PVIDC2 0x0048 +#define MT7628_SWITCH_PVIDC3 0x004c +#define MT7628_SWITCH_VMSC0 0x0070 #define MT7628_SWITCH_FPA 0x0084 #define MT7628_SWITCH_SOCPC 0x008c #define MT7628_SWITCH_POC0 0x0090 @@ -140,6 +145,8 @@ struct mt7628_eth_dev { struct reset_ctl rst_ephy;
struct phy_device *phy; + + int wan_port; };
static int mt7628_eth_free_pkt(struct udevice *dev, uchar *packet, int length); @@ -272,6 +279,9 @@ static void mt7628_ephy_init(struct mt7628_eth_dev *priv) static void rt305x_esw_init(struct mt7628_eth_dev *priv) { void __iomem *base = priv->eth_sw_base; + void __iomem *reg; + u32 val = 0, pvid; + int i;
/* * FC_RLS_TH=200, FC_SET_TH=160 @@ -293,6 +303,25 @@ static void rt305x_esw_init(struct mt7628_eth_dev *priv) /* 1us cycle number=125 (FE's clock=125Mhz) */ writel(0x7d000000, base + MT7628_SWITCH_BMU_CTRL);
+ /* LAN/WAN partition, WAN port will be unusable in u-boot network */ + if (priv->wan_port >= 0 && priv->wan_port < 6) { + for (i = 0; i < 8; i++) { + pvid = i == priv->wan_port ? 2 : 1; + reg = base + MT7628_SWITCH_PVIDC0 + (i / 2) * 4; + if (i % 2 == 0) { + val = pvid; + } else { + val |= (pvid << 12); + writel(val, reg); + } + } + + val = 0xffff407f; + val |= 1 << (8 + priv->wan_port); + val &= ~(1 << priv->wan_port); + writel(val, base + MT7628_SWITCH_VMSC0); + } + /* Reset PHY */ reset_assert(&priv->rst_ephy); reset_deassert(&priv->rst_ephy); @@ -543,6 +572,9 @@ static int mt7628_eth_probe(struct udevice *dev) return ret; }
+ /* WAN port will be isolated from LAN ports */ + priv->wan_port = dev_read_u32_default(dev, "mediatek,wan-port", -1); + /* Put rx and tx rings into KSEG1 area (uncached) */ priv->tx_ring = (struct fe_tx_dma *) KSEG1ADDR(memalign(ARCH_DMA_MINALIGN,
This patch adds default p0led status and phy0 link polling for all boards.
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Add phy link detection for all boards. --- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 13 +++++++++++++ arch/mips/dts/linkit-smart-7688.dts | 13 +++++++++++++ arch/mips/dts/mt7628a.dtsi | 2 +- 3 files changed, 27 insertions(+), 1 deletion(-)
diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts index 95675a3947..fc1f5e93dd 100644 --- a/arch/mips/dts/gardena-smart-gateway-mt7688.dts +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -85,6 +85,15 @@ }; };
+&pinctrl { + state_default: pin_state { + p0led { + groups = "p0led_a"; + function = "led"; + }; + }; +}; + &uart0 { status = "okay"; }; @@ -109,3 +118,7 @@ reg = <1>; }; }; + +ð { + mediatek,poll-link-phy = <0>; +}; diff --git a/arch/mips/dts/linkit-smart-7688.dts b/arch/mips/dts/linkit-smart-7688.dts index 935315743c..740b73b3d1 100644 --- a/arch/mips/dts/linkit-smart-7688.dts +++ b/arch/mips/dts/linkit-smart-7688.dts @@ -26,6 +26,15 @@ }; };
+&pinctrl { + state_default: pin_state { + p0led { + groups = "p0led_a"; + function = "led"; + }; + }; +}; + &uart2 { status = "okay"; }; @@ -42,3 +51,7 @@ reg = <0>; }; }; + +ð { + mediatek,poll-link-phy = <0>; +}; diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index b0e0ed7ec8..5fd83c1623 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -346,7 +346,7 @@ }; };
- eth@10110000 { + eth: eth@10110000 { compatible = "mediatek,mt7628-eth"; reg = <0x10100000 0x10000 0x10110000 0x8000>;
This patch adds mmc support for MediaTek MT7620/MT7628 SoCs.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Removed unnecessary braces in Kconfig --- drivers/mmc/Kconfig | 2 +- drivers/mmc/mtk-sd.c | 23 ++++++++++++++++++++--- 2 files changed, 21 insertions(+), 4 deletions(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 7361bcaf8e..a05c6fc736 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -681,7 +681,7 @@ config FTSDC010_SDIO
config MMC_MTK bool "MediaTek SD/MMC Card Interface support" - depends on ARCH_MEDIATEK + depends on ARCH_MEDIATEK || ARCH_MTMIPS depends on BLK && DM_MMC depends on OF_CONTROL help diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index f555357af2..7069fe8948 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -217,6 +217,7 @@ struct mtk_sd_regs {
struct msdc_compatible { u8 clk_div_bits; + u8 sclk_cycle_shift; bool pad_tune0; bool async_fifo; bool data_tune; @@ -664,7 +665,7 @@ static int msdc_ops_send_cmd(struct udevice *dev, struct mmc_cmd *cmd,
static void msdc_set_timeout(struct msdc_host *host, u32 ns, u32 clks) { - u32 timeout, clk_ns; + u32 timeout, clk_ns, shift; u32 mode = 0;
host->timeout_ns = ns; @@ -673,10 +674,11 @@ static void msdc_set_timeout(struct msdc_host *host, u32 ns, u32 clks) if (host->sclk == 0) { timeout = 0; } else { + shift = host->dev_comp->sclk_cycle_shift; clk_ns = 1000000000UL / host->sclk; timeout = (ns + clk_ns - 1) / clk_ns + clks; /* unit is 1048576 sclk cycles */ - timeout = (timeout + (0x1 << 20) - 1) >> 20; + timeout = (timeout + (0x1 << shift) - 1) >> shift; if (host->dev_comp->clk_div_bits == 8) mode = (readl(&host->base->msdc_cfg) & MSDC_CFG_CKMOD_M) >> MSDC_CFG_CKMOD_S; @@ -1301,7 +1303,7 @@ static int msdc_drv_probe(struct udevice *dev)
host->mmc = &plat->mmc; host->timeout_ns = 100000000; - host->timeout_clks = 3 * 1048576; + host->timeout_clks = 3 * (1 << host->dev_comp->sclk_cycle_shift);
#ifdef CONFIG_PINCTRL pinctrl_select_state(dev, "default"); @@ -1374,8 +1376,20 @@ static const struct dm_mmc_ops msdc_ops = { #endif };
+static const struct msdc_compatible mt7620_compat = { + .clk_div_bits = 8, + .sclk_cycle_shift = 16, + .pad_tune0 = false, + .async_fifo = false, + .data_tune = false, + .busy_check = false, + .stop_clk_fix = false, + .enhance_rx = false +}; + static const struct msdc_compatible mt7623_compat = { .clk_div_bits = 12, + .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1386,6 +1400,7 @@ static const struct msdc_compatible mt7623_compat = {
static const struct msdc_compatible mt8516_compat = { .clk_div_bits = 12, + .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1395,6 +1410,7 @@ static const struct msdc_compatible mt8516_compat = {
static const struct msdc_compatible mt8183_compat = { .clk_div_bits = 12, + .sclk_cycle_shift = 20, .pad_tune0 = true, .async_fifo = true, .data_tune = true, @@ -1403,6 +1419,7 @@ static const struct msdc_compatible mt8183_compat = { };
static const struct udevice_id msdc_ids[] = { + { .compatible = "mediatek,mt7620-mmc", .data = (ulong)&mt7620_compat }, { .compatible = "mediatek,mt7623-mmc", .data = (ulong)&mt7623_compat }, { .compatible = "mediatek,mt8516-mmc", .data = (ulong)&mt8516_compat }, { .compatible = "mediatek,mt8183-mmc", .data = (ulong)&mt8183_compat },
This patch adds a dts property cd-active-high for builtin-cd mode to make it configurable instead of using hardcoded active-low.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- drivers/mmc/mtk-sd.c | 9 ++++++++- 1 file changed, 8 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/mtk-sd.c b/drivers/mmc/mtk-sd.c index 7069fe8948..814a1b5fe9 100644 --- a/drivers/mmc/mtk-sd.c +++ b/drivers/mmc/mtk-sd.c @@ -270,6 +270,7 @@ struct msdc_host {
/* whether to use gpio detection or built-in hw detection */ bool builtin_cd; + bool cd_active_high;
/* card detection / write protection GPIOs */ #if CONFIG_IS_ENABLED(DM_GPIO) @@ -852,7 +853,12 @@ static int msdc_ops_get_cd(struct udevice *dev)
if (host->builtin_cd) { val = readl(&host->base->msdc_ps); - return !(val & MSDC_PS_CDSTS); + val &= MSDC_PS_CDSTS; + + if (!host->cd_active_high) + val = !val; + + return val; }
#if CONFIG_IS_ENABLED(DM_GPIO) @@ -1355,6 +1361,7 @@ static int msdc_ofdata_to_platdata(struct udevice *dev) host->latch_ck = dev_read_u32_default(dev, "latch-ck", 0); host->r_smpl = dev_read_u32_default(dev, "r_smpl", 0); host->builtin_cd = dev_read_u32_default(dev, "builtin-cd", 0); + host->cd_active_high = dev_read_bool(dev, "cd-active-high");
return 0; }
val = !val;
return val;
you could shorten this to
return !(val & MSDC_PS_CDSTS) ^ host->cd_active_high;
This patch adds mmc related nodes for mt7628an.dtsi
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/mt7628a.dtsi | 22 ++++++++++++++++++++++ 1 file changed, 22 insertions(+)
diff --git a/arch/mips/dts/mt7628a.dtsi b/arch/mips/dts/mt7628a.dtsi index 5fd83c1623..76a80c8952 100644 --- a/arch/mips/dts/mt7628a.dtsi +++ b/arch/mips/dts/mt7628a.dtsi @@ -25,6 +25,14 @@ compatible = "mti,cpu-interrupt-controller"; };
+ clk48m: clk48m@0 { + compatible = "fixed-clock"; + + clock-frequency = <48000000>; + + #clock-cells = <0>; + }; + palmbus@10000000 { compatible = "palmbus", "simple-bus"; reg = <0x10000000 0x200000>; @@ -382,4 +390,18 @@ interrupt-parent = <&intc>; interrupts = <18>; }; + + mmc: mmc@10130000 { + compatible = "mediatek,mt7620-mmc"; + reg = <0x10130000 0x4000>; + builtin-cd = <1>; + r_smpl = <1>; + + clocks = <&clk48m>, <&clkctrl CLK_SDXC>; + clock-names = "source", "hclk"; + + resets = <&rstctrl MT7628_SDXC_RST>; + + status = "disabled"; + }; };
This adds default pinctrl (dual SPI chip select) for gardena smart gateway
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 3 +++ 1 file changed, 3 insertions(+)
diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts index fc1f5e93dd..987824a76c 100644 --- a/arch/mips/dts/gardena-smart-gateway-mt7688.dts +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -102,6 +102,9 @@ status = "okay"; num-cs = <2>;
+ pinctrl-names = "default"; + pinctrl-0 = <&spi_dual_pins>; + spi-flash@0 { #address-cells = <1>; #size-cells = <1>;
This patch adds default eth pinctrl for all boards.
There are two pinctrl nodes used for two scenarios: ephy_iot_mode - for IOT boards which have only one port (PHY0) ephy_router_mode - For routers which have more than one ports
Reviewed-by: Stefan Roese sr@denx.de Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- arch/mips/dts/gardena-smart-gateway-mt7688.dts | 2 ++ arch/mips/dts/linkit-smart-7688.dts | 2 ++ 2 files changed, 4 insertions(+)
diff --git a/arch/mips/dts/gardena-smart-gateway-mt7688.dts b/arch/mips/dts/gardena-smart-gateway-mt7688.dts index 987824a76c..b7b5a24058 100644 --- a/arch/mips/dts/gardena-smart-gateway-mt7688.dts +++ b/arch/mips/dts/gardena-smart-gateway-mt7688.dts @@ -123,5 +123,7 @@ };
ð { + pinctrl-names = "default"; + pinctrl-0 = <&ephy_iot_mode>; mediatek,poll-link-phy = <0>; }; diff --git a/arch/mips/dts/linkit-smart-7688.dts b/arch/mips/dts/linkit-smart-7688.dts index 740b73b3d1..f154aae190 100644 --- a/arch/mips/dts/linkit-smart-7688.dts +++ b/arch/mips/dts/linkit-smart-7688.dts @@ -53,5 +53,7 @@ };
This patch changes baudrate table for all boards preparing for using mtk highspeed uart driver.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: Removed configs in defconfig files. --- include/configs/gardena-smart-gateway-mt7688.h | 2 +- include/configs/linkit-smart-7688.h | 2 +- 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/include/configs/gardena-smart-gateway-mt7688.h b/include/configs/gardena-smart-gateway-mt7688.h index b3b89d2ab9..e83a96ad5e 100644 --- a/include/configs/gardena-smart-gateway-mt7688.h +++ b/include/configs/gardena-smart-gateway-mt7688.h @@ -22,7 +22,7 @@
/* UART */ #define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, \ - 230400, 500000, 1500000 } + 230400, 460800, 921600 }
/* RAM */ #define CONFIG_SYS_MEMTEST_START 0x80100000 diff --git a/include/configs/linkit-smart-7688.h b/include/configs/linkit-smart-7688.h index 2adf38545a..4d30d98abf 100644 --- a/include/configs/linkit-smart-7688.h +++ b/include/configs/linkit-smart-7688.h @@ -22,7 +22,7 @@
Some drivers (clk, pinctrl, reset, ...) are necessary for reset of the system, they should be always selected.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: newly added --- arch/mips/Kconfig | 6 ++++++ arch/mips/mach-mtmips/Kconfig | 2 ++ 2 files changed, 8 insertions(+)
diff --git a/arch/mips/Kconfig b/arch/mips/Kconfig index e3e7945567..fd3bf18bd7 100644 --- a/arch/mips/Kconfig +++ b/arch/mips/Kconfig @@ -76,12 +76,18 @@ config ARCH_BMIPS
config ARCH_MTMIPS bool "Support MediaTek MIPS platforms" + select CLK imply CMD_DM select DISPLAY_CPUINFO select DM imply DM_ETH imply DM_GPIO + select DM_RESET select DM_SERIAL + select PINCTRL + select PINMUX + select PINCONF + select RESET_MTMIPS imply DM_SPI imply DM_SPI_FLASH select LAST_STAGE_INIT diff --git a/arch/mips/mach-mtmips/Kconfig b/arch/mips/mach-mtmips/Kconfig index 4af2d54528..c8dcf19c0d 100644 --- a/arch/mips/mach-mtmips/Kconfig +++ b/arch/mips/mach-mtmips/Kconfig @@ -13,6 +13,8 @@ choice config SOC_MT7628 bool "MT7628" select MIPS_L1_CACHE_SHIFT_5 + select PINCTRL_MT7628 + select MTK_SERIAL help This supports MediaTek MT7628/MT7688.
Some configs are selected in Kconfig and is no longer needed in the defconfig files. Some configs (power domain, ram) are never used.
Signed-off-by: Weijie Gao weijie.gao@mediatek.com --- v2: newly added --- configs/gardena-smart-gateway-mt7688-ram_defconfig | 7 ------- configs/gardena-smart-gateway-mt7688_defconfig | 7 ------- configs/linkit-smart-7688-ram_defconfig | 7 ------- configs/linkit-smart-7688_defconfig | 7 ------- 4 files changed, 28 deletions(-)
diff --git a/configs/gardena-smart-gateway-mt7688-ram_defconfig b/configs/gardena-smart-gateway-mt7688-ram_defconfig index 1a1167b2a6..d1bb59c124 100644 --- a/configs/gardena-smart-gateway-mt7688-ram_defconfig +++ b/configs/gardena-smart-gateway-mt7688-ram_defconfig @@ -45,7 +45,6 @@ CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y @@ -60,15 +59,9 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_XMC=y CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_BEB_LIMIT=22 -CONFIG_PHYLIB=y -CONFIG_PHY_FIXED=y CONFIG_MT7628_ETH=y CONFIG_PHY=y -CONFIG_POWER_DOMAIN=y -CONFIG_RAM=y -CONFIG_DM_RESET=y # CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_SYSRESET_SYSCON=y diff --git a/configs/gardena-smart-gateway-mt7688_defconfig b/configs/gardena-smart-gateway-mt7688_defconfig index a456e3b575..552ea37164 100644 --- a/configs/gardena-smart-gateway-mt7688_defconfig +++ b/configs/gardena-smart-gateway-mt7688_defconfig @@ -48,7 +48,6 @@ CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_HAVE_BLOCK_DEVICE=y CONFIG_BOOTCOUNT_LIMIT=y -CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y @@ -63,15 +62,9 @@ CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_XMC=y CONFIG_SPI_FLASH_MTD=y CONFIG_MTD_UBI_BEB_LIMIT=22 -CONFIG_PHYLIB=y -CONFIG_PHY_FIXED=y CONFIG_MT7628_ETH=y CONFIG_PHY=y -CONFIG_POWER_DOMAIN=y -CONFIG_RAM=y -CONFIG_DM_RESET=y # CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_SYSRESET_SYSCON=y diff --git a/configs/linkit-smart-7688-ram_defconfig b/configs/linkit-smart-7688-ram_defconfig index aa76633802..bec6dd030c 100644 --- a/configs/linkit-smart-7688-ram_defconfig +++ b/configs/linkit-smart-7688-ram_defconfig @@ -35,7 +35,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_BLK=y -CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y @@ -46,16 +45,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y -CONFIG_PHYLIB=y -CONFIG_PHY_FIXED=y CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y -CONFIG_POWER_DOMAIN=y -CONFIG_RAM=y -CONFIG_DM_RESET=y # CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_SYSRESET_SYSCON=y diff --git a/configs/linkit-smart-7688_defconfig b/configs/linkit-smart-7688_defconfig index 3750e59a4b..e8db9070e6 100644 --- a/configs/linkit-smart-7688_defconfig +++ b/configs/linkit-smart-7688_defconfig @@ -39,7 +39,6 @@ CONFIG_ENV_IS_IN_SPI_FLASH=y CONFIG_NET_RANDOM_ETHADDR=y # CONFIG_DM_DEVICE_REMOVE is not set CONFIG_BLK=y -CONFIG_CLK=y CONFIG_LED=y CONFIG_LED_BLINK=y CONFIG_LED_GPIO=y @@ -50,16 +49,10 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_STMICRO=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y -CONFIG_PHYLIB=y -CONFIG_PHY_FIXED=y CONFIG_MT7628_ETH=y CONFIG_PHY=y CONFIG_MT76X8_USB_PHY=y -CONFIG_POWER_DOMAIN=y -CONFIG_RAM=y -CONFIG_DM_RESET=y # CONFIG_SPL_SERIAL_PRESENT is not set -CONFIG_SYS_NS16550=y CONFIG_SPI=y CONFIG_MT7621_SPI=y CONFIG_SYSRESET_SYSCON=y
Daniel Schwierzeck
Weijie Gao
