[U-Boot] [PATCH] ARM: dts: Rename memory@0 to memory
zynq-7000.dtsi include skeleton.dtsi which contains memory node with base address and size zero. If you add memory@0 node to the platform DTS in final DTB there are two memory nodes and U-Boot works with the first one (with zeros) which end up in failing in dram_init because size is zero. Platform memory node should rewrite default memory node setup from skeleton.dtsi that's why platfroms needs to also use memory as node name instead of memory@0.
Reported-by: Siva Durga Prasad Paladugu sivadur@xilinx.com Signed-off-by: Michal Simek michal.simek@xilinx.com ---
arch/arm/dts/zynq-zc770-xm010.dts | 2 +- arch/arm/dts/zynq-zc770-xm011.dts | 2 +- arch/arm/dts/zynq-zc770-xm012.dts | 2 +- arch/arm/dts/zynq-zc770-xm013.dts | 2 +- 4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/arch/arm/dts/zynq-zc770-xm010.dts b/arch/arm/dts/zynq-zc770-xm010.dts index da3a182ea1e1..680f24c9c44d 100644 --- a/arch/arm/dts/zynq-zc770-xm010.dts +++ b/arch/arm/dts/zynq-zc770-xm010.dts @@ -25,7 +25,7 @@ stdout-path = &uart1; };
- memory@0 { + memory { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm011.dts b/arch/arm/dts/zynq-zc770-xm011.dts index d38c8201353c..f73c0ddcb8d4 100644 --- a/arch/arm/dts/zynq-zc770-xm011.dts +++ b/arch/arm/dts/zynq-zc770-xm011.dts @@ -23,7 +23,7 @@ stdout-path = &uart1; };
- memory@0 { + memory { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm012.dts b/arch/arm/dts/zynq-zc770-xm012.dts index f8cc5039d6b7..4289e31f4615 100644 --- a/arch/arm/dts/zynq-zc770-xm012.dts +++ b/arch/arm/dts/zynq-zc770-xm012.dts @@ -25,7 +25,7 @@ stdout-path = &uart1; };
- memory@0 { + memory { device_type = "memory"; reg = <0x0 0x40000000>; }; diff --git a/arch/arm/dts/zynq-zc770-xm013.dts b/arch/arm/dts/zynq-zc770-xm013.dts index 436a8cd1b9a9..5124cdc5cdf0 100644 --- a/arch/arm/dts/zynq-zc770-xm013.dts +++ b/arch/arm/dts/zynq-zc770-xm013.dts @@ -25,7 +25,7 @@ stdout-path = &uart0; };
Michal Simek
