[U-Boot-Users] Re: Download U-Boot in RAM on Memec Board
Subject: [U-Boot-Users] Download U-Boot in RAM on Memec Board
Hei at all
I have comiled u-boot and want to download the u-boot in RAM on Memec Evaluation Board. The board has 64K RAM and address is 0x00000000 to 0x03FFFFFF.
When i use the commands described in examples e.g. xmd> ppcconnect xmd> dow uboot.elf xmd> run the xmd begins to download at address 0x04000000 !!! and at the console I get information on which addresses the sectors were placed.
You have to change TEXT_BASE (see "board/xilinx/ml300/config.mk" file, default is 0x04000000) to some address inside RAM (for example 0x100000) and change accordingly CFG_MONITOR_BASE in file "include/configs/ml300.h" (see README at top of u-boot sources). It should be sufficient to run u-boot this way on a Memec board via xmd.
Pierre Kestener.
Pierre Kestener
