[U-Boot] [patch] i.MX use u-boot baud rate and don't assume UART master clock
1) Change the i.MX serial driver to use the baud rate set in the u-boot environment
2) don't assume a 16MHz value for PERCLK1 in baud rate calculations
3) don't write a 1 to the RDR bit in the USR2 reg. (bit is not "write one to clear" like other status bits in the reg.)
Signed-off-by: Andrew Dyer adyer@righthandtech.com --- cpu/arm920t/imx/serial.c | 34 ++++++++++++++++++++++++++++++---- 1 files changed, 30 insertions(+), 4 deletions(-)
diff --git a/cpu/arm920t/imx/serial.c b/cpu/arm920t/imx/serial.c index 6c56acb..ea5f42c 100644 --- a/cpu/arm920t/imx/serial.c +++ b/cpu/arm920t/imx/serial.c @@ -52,6 +52,8 @@ struct imx_serial { volatile uint32_t uts; };
+DECLARE_GLOBAL_DATA_PTR; + void serial_setbrg (void) { serial_init(); @@ -67,6 +69,9 @@ extern void imx_gpio_mode(int gpio_mode); int serial_init (void) { volatile struct imx_serial* base = (struct imx_serial *)UART_BASE; + unsigned int ufcr_rfdiv; + unsigned int refclk; + #ifdef CONFIG_IMX_SERIAL1 imx_gpio_mode(PC11_PF_UART1_TXD); imx_gpio_mode(PC12_PF_UART1_RXD); @@ -95,11 +100,33 @@ int serial_init (void) /* Configure FIFOs */ base->ufcr = 0xa81;
+ /* set the baud rate. + * + * baud * 16 x + * --------- = - + * refclk y + * + * x - 1 = UBIR + * y - 1 = UBMR + * + * each register is 16 bits wide. refclk max is 96 MHz + * + */ + + ufcr_rfdiv = ((base->ufcr) & UFCR_RFDIV) >> 7; + if (ufcr_rfdiv == 6) + ufcr_rfdiv = 7; + else + ufcr_rfdiv = 6 - ufcr_rfdiv; + + refclk = get_PERCLK1(); + refclk /= ufcr_rfdiv; + /* Set the numerator value minus one of the BRM ratio */ - base->ubir = (CONFIG_BAUDRATE / 100) - 1; + base->ubir = (gd->baudrate / 100) - 1;
/* Set the denominator value minus one of the BRM ratio */ - base->ubmr = 10000 - 1; + base->ubmr = (refclk/(16 * 100)) - 1;
/* Set to 8N1 */ base->ucr2 &= ~UCR2_PREN; @@ -123,8 +150,7 @@ int serial_init (void) USR2_WAKE | USR2_RTSF | USR2_BRCD | - USR2_ORE | - USR2_RDR; + USR2_ORE;
/* Clear status flags */ base->usr1 |= USR1_PARITYERR |
Andrew Dyer wrote:
- Change the i.MX serial driver to use the baud rate set in the
u-boot environment
fixes a whitespace error in the previous patch that slipped through
Signed-off-by: Andrew Dyer adyer@righthandtech.com --- cpu/arm920t/imx/serial.c | 56 +++++++++++++++++++++++++++++++++------------ 1 files changed, 41 insertions(+), 15 deletions(-)
diff --git a/cpu/arm920t/imx/serial.c b/cpu/arm920t/imx/serial.c index 6c56acb..d5d4507 100644 --- a/cpu/arm920t/imx/serial.c +++ b/cpu/arm920t/imx/serial.c @@ -52,6 +52,8 @@ struct imx_serial { volatile uint32_t uts; };
/* Set to 8N1 */ base->ucr2 &= ~UCR2_PREN; @@ -117,22 +144,21 @@ int serial_init (void)
/* Clear status flags */ base->usr2 |= USR2_ADET | - USR2_DTRF | - USR2_IDLE | - USR2_IRINT | - USR2_WAKE | - USR2_RTSF | - USR2_BRCD | - USR2_ORE | - USR2_RDR; + USR2_DTRF | + USR2_IDLE | + USR2_IRINT | + USR2_WAKE | + USR2_RTSF | + USR2_BRCD | + USR2_ORE;
/* Clear status flags */ base->usr1 |= USR1_PARITYERR | - USR1_RTSD | - USR1_ESCF | - USR1_FRAMERR | - USR1_AIRINT | - USR1_AWAKE; + USR1_RTSD | + USR1_ESCF | + USR1_FRAMERR | + USR1_AIRINT | + USR1_AWAKE; return (0); }
Andrew Dyer
