[U-Boot] [PATCH v1 0/5] db820: Add missing initialization for uart
Uart was lacking initialization of pinctrl & PLL's and relied on previous initialization from LK. Fix that.
Ramon Fried (5): arm: mach-snapdragon: db820c: Actually init PLL for serial arm: mach-snapdragon: add pinctrl driver for db820c configs: dragonboard820c: Enable pinctrl/mux config arm: mach-snapdragon: pinctrl: clarify gpio disable bit dts: 820c: Add pinctrl node and uart mux
arch/arm/dts/dragonboard820c-uboot.dtsi | 10 +++- arch/arm/dts/dragonboard820c.dts | 29 +++++++--- arch/arm/mach-snapdragon/Makefile | 5 +- arch/arm/mach-snapdragon/clock-apq8096.c | 34 +++++++++++ .../include/mach/sysmap-apq8096.h | 9 +++ arch/arm/mach-snapdragon/pinctrl-apq8096.c | 56 +++++++++++++++++++ arch/arm/mach-snapdragon/pinctrl-snapdragon.c | 6 +- arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 1 + configs/dragonboard820c_defconfig | 2 + 9 files changed, 139 insertions(+), 13 deletions(-) create mode 100644 arch/arm/mach-snapdragon/pinctrl-apq8096.c
The PLL for the UART was not set, and relied on previous initializtion made by LK. add the appropriate initialization.
Signed-off-by: Ramon Fried ramon.fried@gmail.com ---
arch/arm/mach-snapdragon/clock-apq8096.c | 34 +++++++++++++++++++ .../include/mach/sysmap-apq8096.h | 9 +++++ 2 files changed, 43 insertions(+)
diff --git a/arch/arm/mach-snapdragon/clock-apq8096.c b/arch/arm/mach-snapdragon/clock-apq8096.c index 628c38785b..e5011be8f2 100644 --- a/arch/arm/mach-snapdragon/clock-apq8096.c +++ b/arch/arm/mach-snapdragon/clock-apq8096.c @@ -34,6 +34,12 @@ static const struct pll_vote_clk gpll0_vote_clk = { .vote_bit = APCS_GPLL_ENA_VOTE_GPLL0, };
+static struct vote_clk gcc_blsp2_ahb_clk = { + .cbcr_reg = BLSP2_AHB_CBCR, + .ena_vote = APCS_CLOCK_BRANCH_ENA_VOTE, + .vote_bit = BIT(15), +}; + static int clk_init_sdc(struct msm_clk_priv *priv, uint rate) { int div = 3; @@ -47,6 +53,32 @@ static int clk_init_sdc(struct msm_clk_priv *priv, uint rate) return rate; }
+static const struct bcr_regs uart2_regs = { + .cfg_rcgr = BLSP2_UART2_APPS_CFG_RCGR, + .cmd_rcgr = BLSP2_UART2_APPS_CMD_RCGR, + .M = BLSP2_UART2_APPS_M, + .N = BLSP2_UART2_APPS_N, + .D = BLSP2_UART2_APPS_D, +}; + +static int clk_init_uart(struct msm_clk_priv *priv) +{ + /* Enable AHB clock */ + clk_enable_vote_clk(priv->base, &gcc_blsp2_ahb_clk); + + /* 7372800 uart block clock @ GPLL0 */ + clk_rcg_set_rate_mnd(priv->base, &uart2_regs, 1, 192, 15625, + CFG_CLK_SRC_GPLL0); + + /* Vote for gpll0 clock */ + clk_enable_gpll0(priv->base, &gpll0_vote_clk); + + /* Enable core clk */ + clk_enable_cbc(priv->base + BLSP2_UART2_APPS_CBCR); + + return 0; +} + ulong msm_set_rate(struct clk *clk, ulong rate) { struct msm_clk_priv *priv = dev_get_priv(clk->dev); @@ -55,6 +87,8 @@ ulong msm_set_rate(struct clk *clk, ulong rate) case 0: /* SDC1 */ return clk_init_sdc(priv, rate); break; + case 4: /*UART2*/ + return clk_init_uart(priv); default: return 0; } diff --git a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h index 14febb6487..36a902bd92 100644 --- a/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h +++ b/arch/arm/mach-snapdragon/include/mach/sysmap-apq8096.h @@ -15,6 +15,7 @@ /* Clocks: (from CLK_CTL_BASE) */ #define GPLL0_STATUS (0x0000) #define APCS_GPLL_ENA_VOTE (0x52000) +#define APCS_CLOCK_BRANCH_ENA_VOTE (0x52004)
#define SDCC2_BCR (0x14000) /* block reset */ #define SDCC2_APPS_CBCR (0x14004) /* branch control */ @@ -25,4 +26,12 @@ #define SDCC2_N (0x1401C) #define SDCC2_D (0x14020)
+#define BLSP2_AHB_CBCR (0x25004) +#define BLSP2_UART2_APPS_CBCR (0x29004) +#define BLSP2_UART2_APPS_CMD_RCGR (0x2900C) +#define BLSP2_UART2_APPS_CFG_RCGR (0x29010) +#define BLSP2_UART2_APPS_M (0x29014) +#define BLSP2_UART2_APPS_N (0x29018) +#define BLSP2_UART2_APPS_D (0x2901C) + #endif
Add pinctrl driver for Dragonboard820c, currently with only one mux func to initialize pins for serial console.
arch/arm/mach-snapdragon/Makefile | 5 +- arch/arm/mach-snapdragon/pinctrl-apq8096.c | 56 +++++++++++++++++++ arch/arm/mach-snapdragon/pinctrl-snapdragon.c | 2 +- arch/arm/mach-snapdragon/pinctrl-snapdragon.h | 1 + 4 files changed, 61 insertions(+), 3 deletions(-) create mode 100644 arch/arm/mach-snapdragon/pinctrl-apq8096.c
diff --git a/arch/arm/mach-snapdragon/Makefile b/arch/arm/mach-snapdragon/Makefile index 2d94083600..709919fce4 100644 --- a/arch/arm/mach-snapdragon/Makefile +++ b/arch/arm/mach-snapdragon/Makefile @@ -6,8 +6,9 @@ obj-$(CONFIG_TARGET_DRAGONBOARD820C) += clock-apq8096.o obj-$(CONFIG_TARGET_DRAGONBOARD820C) += sysmap-apq8096.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += clock-apq8016.o obj-$(CONFIG_TARGET_DRAGONBOARD410C) += sysmap-apq8016.o -obj-$(CONFIG_TARGET_DRAGONBOARD410C) += pinctrl-apq8016.o -obj-$(CONFIG_TARGET_DRAGONBOARD410C) += pinctrl-snapdragon.o obj-y += misc.o obj-y += clock-snapdragon.o obj-y += dram.o +obj-y += pinctrl-snapdragon.o +obj-y += pinctrl-apq8016.o +obj-y += pinctrl-apq8096.o diff --git a/arch/arm/mach-snapdragon/pinctrl-apq8096.c b/arch/arm/mach-snapdragon/pinctrl-apq8096.c new file mode 100644 index 0000000000..20a71c319b --- /dev/null +++ b/arch/arm/mach-snapdragon/pinctrl-apq8096.c @@ -0,0 +1,56 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * Qualcomm APQ8096 pinctrl + * + * (C) Copyright 2019 Ramon Fried ramon.fried@gmail.com + * + */ + +#include "pinctrl-snapdragon.h" +#include <common.h> + +#define MAX_PIN_NAME_LEN 32 +static char pin_name[MAX_PIN_NAME_LEN]; +static const char * const msm_pinctrl_pins[] = { + "SDC1_CLK", + "SDC1_CMD", + "SDC1_DATA", + "SDC2_CLK", + "SDC2_CMD", + "SDC2_DATA", + "SDC1_RCLK", +}; + +static const struct pinctrl_function msm_pinctrl_functions[] = { + {"blsp_uart8", 2}, +}; + +static const char *apq8096_get_function_name(struct udevice *dev, + unsigned int selector) +{ + return msm_pinctrl_functions[selector].name; +} + +static const char *apq8096_get_pin_name(struct udevice *dev, + unsigned int selector) +{ + if (selector < 150) { + snprintf(pin_name, MAX_PIN_NAME_LEN, "GPIO_%u", selector); + return pin_name; + } else { + return msm_pinctrl_pins[selector - 150]; + } +} + +static unsigned int apq8096_get_function_mux(unsigned int selector) +{ + return msm_pinctrl_functions[selector].val; +} + +struct msm_pinctrl_data apq8096_data = { + .pin_count = 157, + .functions_count = ARRAY_SIZE(msm_pinctrl_functions), + .get_function_name = apq8096_get_function_name, + .get_function_mux = apq8096_get_function_mux, + .get_pin_name = apq8096_get_pin_name, +}; diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c index 5365ccdb70..ac511d9ee5 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c @@ -113,8 +113,8 @@ static struct pinctrl_ops msm_pinctrl_ops = { };
static const struct udevice_id msm_pinctrl_ids[] = { - { .compatible = "qcom,tlmm-msm8916", .data = (ulong)&apq8016_data }, { .compatible = "qcom,tlmm-apq8016", .data = (ulong)&apq8016_data }, + { .compatible = "qcom,tlmm-apq8096", .data = (ulong)&apq8096_data }, { } };
diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h index c47d988af4..24f8863f59 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.h +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.h @@ -26,5 +26,6 @@ struct pinctrl_function { };
extern struct msm_pinctrl_data apq8016_data; +extern struct msm_pinctrl_data apq8096_data;
#endif
configs/dragonboard820c_defconfig | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/configs/dragonboard820c_defconfig b/configs/dragonboard820c_defconfig index d1e0b77717..20a6ba9b61 100644 --- a/configs/dragonboard820c_defconfig +++ b/configs/dragonboard820c_defconfig @@ -31,6 +31,8 @@ CONFIG_PM8916_GPIO=y CONFIG_DM_MMC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_MSM=y +CONFIG_PINCTRL=y +CONFIG_PINCONF=y CONFIG_DM_PMIC=y CONFIG_PMIC_PM8916=y CONFIG_MSM_SERIAL=y
The TLMM_GPIO_ENABLE bit is actually use to disable the GPIO. change it to TLMM_GPIO_DISABLE so it's clearer.
arch/arm/mach-snapdragon/pinctrl-snapdragon.c | 4 ++-- 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c index ac511d9ee5..9ba8fdd729 100644 --- a/arch/arm/mach-snapdragon/pinctrl-snapdragon.c +++ b/arch/arm/mach-snapdragon/pinctrl-snapdragon.c @@ -22,7 +22,7 @@ struct msm_pinctrl_priv { #define TLMM_GPIO_PULL_MASK GENMASK(1, 0) #define TLMM_FUNC_SEL_MASK GENMASK(5, 2) #define TLMM_DRV_STRENGTH_MASK GENMASK(8, 6) -#define TLMM_GPIO_ENABLE BIT(9) +#define TLMM_GPIO_DISABLE BIT(9)
static const struct pinconf_param msm_conf_params[] = { { "drive-strength", PIN_CONFIG_DRIVE_STRENGTH, 3 }, @@ -74,7 +74,7 @@ static int msm_pinmux_set(struct udevice *dev, unsigned int pin_selector, struct msm_pinctrl_priv *priv = dev_get_priv(dev);
clrsetbits_le32(priv->base + GPIO_CONFIG_OFFSET(pin_selector), - TLMM_FUNC_SEL_MASK | TLMM_GPIO_ENABLE, + TLMM_FUNC_SEL_MASK | TLMM_GPIO_DISABLE, priv->data->get_function_mux(func_selector) << 2); return 0; }
* Add pinctrl node for TLMM and add mux request for uart node. * Rename uart to the actual board uart port. * Fix indentendation of sdhc2 node.
arch/arm/dts/dragonboard820c-uboot.dtsi | 10 ++++++++- arch/arm/dts/dragonboard820c.dts | 29 +++++++++++++++++++------ 2 files changed, 31 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/dragonboard820c-uboot.dtsi b/arch/arm/dts/dragonboard820c-uboot.dtsi index d60aa04494..8610d7ec37 100644 --- a/arch/arm/dts/dragonboard820c-uboot.dtsi +++ b/arch/arm/dts/dragonboard820c-uboot.dtsi @@ -13,14 +13,22 @@ soc { u-boot,dm-pre-reloc;
+ qcom,tlmm@1010000 { + u-boot,dm-pre-reloc; + + uart { + u-boot,dm-pre-reloc; + }; + }; + clock-controller@300000 { u-boot,dm-pre-reloc; };
serial@75b0000 { u-boot,dm-pre-reloc; - }; }; + }; };
&pm8994_pon { diff --git a/arch/arm/dts/dragonboard820c.dts b/arch/arm/dts/dragonboard820c.dts index 34abbc9110..dac15775dd 100644 --- a/arch/arm/dts/dragonboard820c.dts +++ b/arch/arm/dts/dragonboard820c.dts @@ -8,6 +8,7 @@ /dts-v1/;
#include "skeleton64.dtsi" +#include <dt-bindings/pinctrl/pinctrl-snapdragon.h>
/ { model = "Qualcomm Technologies, Inc. DB820c"; @@ -16,7 +17,7 @@ #size-cells = <2>;
aliases { - serial0 = &blsp2_uart1; + serial0 = &blsp2_uart2; };
chosen { @@ -63,18 +64,32 @@ reg = <0x300000 0x90000>; };
- blsp2_uart1: serial@75b0000 { + pinctrl: qcom,tlmm@1010000 { + compatible = "qcom,tlmm-apq8096"; + reg = <0x1010000 0x400000>; + + blsp8_uart: uart { + function = "blsp_uart8"; + pins = "GPIO_4", "GPIO_5"; + drive-strength = <DRIVE_STRENGTH_8MA>; + bias-disable; + }; + }; + + blsp2_uart2: serial@75b0000 { compatible = "qcom,msm-uartdm-v1.4", "qcom,msm-uartdm"; reg = <0x75b0000 0x1000>; clock = <&gcc 4>; + pinctrl-names = "uart"; + pinctrl-0 = <&blsp8_uart>; };
sdhc2: sdhci@74a4900 { - compatible = "qcom,sdhci-msm-v4"; - reg = <0x74a4900 0x314>, <0x74a4000 0x800>; - index = <0x0>; - bus-width = <4>; - clock = <&gcc 0>; + compatible = "qcom,sdhci-msm-v4"; + reg = <0x74a4900 0x314>, <0x74a4000 0x800>; + index = <0x0>; + bus-width = <4>; + clock = <&gcc 0>; clock-frequency = <200000000>; };
On Sat, Jan 12, 2019 at 11:47:28AM +0200, Ramon Fried wrote:
- Add pinctrl node for TLMM and add mux request for uart node.
- Rename uart to the actual board uart port.
- Fix indentendation of sdhc2 node.
Ramon Fried
