[U-Boot] [PATCH] i.MX6: Set and clear the gating bits for Phase Fractional Dividers
This addresses silicon errata ERR006282 as described in this document: https://community.freescale.com/docs/DOC-94581
Also implemented in Freescale's 2009.08-based release:
http://git.freescale.com/git/cgit.cgi/imx/uboot-imx.git/ Commit id: b7c5badf94ffbe6cd0845efbb75e16e05e3af404
Signed-off-by: Eric Nelson eric.nelson@boundarydevices.com --- arch/arm/cpu/armv7/mx6/soc.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/arch/arm/cpu/armv7/mx6/soc.c b/arch/arm/cpu/armv7/mx6/soc.c index 8150bff..a390296 100644 --- a/arch/arm/cpu/armv7/mx6/soc.c +++ b/arch/arm/cpu/armv7/mx6/soc.c @@ -213,6 +213,34 @@ const struct boot_mode soc_boot_modes[] = {
void s_init(void) { + struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR; + int is_6q = is_cpu_type(MXC_CPU_MX6Q); + u32 mask480; + u32 mask528; + + /* Due to hardware limitation, on MX6Q we need to gate/ungate all PFDs + * to make sure PFD is working right, otherwise, PFDs may + * not output clock after reset, MX6DL and MX6SL have added 396M pfd + * workaround in ROM code, as bus clock need it + */ + + mask480 = ANATOP_PFD_CLKGATE_MASK(0) | + ANATOP_PFD_CLKGATE_MASK(1) | + ANATOP_PFD_CLKGATE_MASK(2) | + ANATOP_PFD_CLKGATE_MASK(3); + mask528 = ANATOP_PFD_CLKGATE_MASK(0) | + ANATOP_PFD_CLKGATE_MASK(1) | + ANATOP_PFD_CLKGATE_MASK(3); + + /* + * Don't reset PFD2 on DL/S + */ + if (is_6q) + mask528 |= ANATOP_PFD_CLKGATE_MASK(2); + writel(mask480, &anatop->pfd_480_set); + writel(mask528, &anatop->pfd_528_set); + writel(mask480, &anatop->pfd_480_clr); + writel(mask528, &anatop->pfd_528_clr); }
#ifdef CONFIG_IMX_HDMI
void s_init(void) {
- struct anatop_regs *anatop = (struct anatop_regs *)ANATOP_BASE_ADDR;
- int is_6q = is_cpu_type(MXC_CPU_MX6Q);
- u32 mask480;
- u32 mask528;
- /* Due to hardware limitation, on MX6Q we need to gate/ungate all PFDs
- mask480 = ANATOP_PFD_CLKGATE_MASK(0) |
- mask528 = ANATOP_PFD_CLKGATE_MASK(0) |
- if (is_6q)
- writel(mask480, &anatop->pfd_480_set);
- writel(mask528, &anatop->pfd_528_set);
- writel(mask480, &anatop->pfd_480_clr);
- writel(mask528, &anatop->pfd_528_clr);
Acked-by: Stefano Babic sbabic@denx.de
Best regards, Stefano Babic
Applied to u-boot-imx, thanks.
Eric Nelson
Stefano Babic
