[U-Boot-Users] [PATCH] MPC85xx: Change traps.c to not reference non-addressable memory
Currently, END_OF_RAM is used by the trap code to determine if we should attempt to access the stack pointer or not. However, on systems with a lot of RAM, only a subset of the RAM is guaranteed to be mapped in and accessible. Change END_OF_RAM to use get_effective_memsize() instead of using the raw ram size out of the bd.
Signed-off-by: Becky Bruce becky.bruce@freescale.com --- cpu/mpc85xx/traps.c | 8 +++++--- 1 files changed, 5 insertions(+), 3 deletions(-)
diff --git a/cpu/mpc85xx/traps.c b/cpu/mpc85xx/traps.c index 2381fb0..fd36658 100644 --- a/cpu/mpc85xx/traps.c +++ b/cpu/mpc85xx/traps.c @@ -50,10 +50,12 @@ int (*debugger_exception_handler)(struct pt_regs *) = 0; extern unsigned long search_exception_table(unsigned long);
/* - * End of memory as shown by board info and determined by DDR setup. + * End of addressable memory. This may be less than the actual + * amount of memory on the system if we're unable to keep all + * the memory mapped in. */ -#define END_OF_MEM (gd->bd->bi_memstart + gd->bd->bi_memsize) - +extern ulong get_effective_memsize(void); +#define END_OF_MEM (gd->bd->bi_memstart + get_effective_memsize())
static __inline__ void set_tsr(unsigned long val) {
what, no love for 4xx, 83xx, and 74xx_7xx?
can also be made a single patch for WD to apply directly.
Kim
The other platforms currently set a hard limit that should still be valid - I just changed the ones that were reading memsize directly out of the bd.
Sure, I just split it up in case there was some reason we shouldn't do it for one of them.
-B
On Wed, 14 May 2008 15:31:43 -0500 Becky Bruce becky.bruce@freescale.com wrote:
sure, 5xx, 82xx and 8xx are hardcoded, but 74xx_7xx (albeit only AMIGAONE), all 83xx, and all 4xx use the bd just like in your current patchseries. I'm just trying to maintain some level of consistency.
ah, I thought you wanted individual maintainers to pick them up individually. Either way works, really.
Kim
74xx_7xx only does it if CONFIG_AMIGA-something-or-the other is defined, and I have no idea about that particular platform, so I left it alone in that case. Otherwise 74xx_7xx hardcodes it. I actually think perhaps the right answer there is to change the whole thing to use get_effective_memsize in both cases. Does anyone have a contrary opinion on this.
You're right that I missed 83xx, and I will patch that one (sorry, too much grep output, and I missed this one).
I'm also happy to do 4xx if we're pretty sure this it The Right Thing (TM).
Cheers, B
Applied, merci
Andy
Andy Fleming
Becky Bruce
becky.bruceļ¼ freescale.com
Kim Phillips
