[U-Boot] [PATCH v2] Change kernel address in dataflash to match u-boot's size
On at91sam platforms, u-boot grew larger than the allocated size in dataflash, the layout was: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00042000
u-boot with the defconfig doesn't seem to fit in 0x42000 - 0x8400 = 0x39C00 bytes anymore.
Now, the layout is: bootstrap 0x00000000 uboot 0x00004000 ubootenv 0x00084000 ubootenv2 0x00088000 kernel 0x0008C000
Signed-off-by: Alexandre Belloni alexandre.belloni@piout.net --- include/configs/at91sam9260ek.h | 18 ++++++++++++------ include/configs/at91sam9261ek.h | 18 ++++++++++++------ include/configs/at91sam9263ek.h | 10 +++++++--- include/configs/at91sam9rlek.h | 10 +++++++--- 4 files changed, 38 insertions(+), 18 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index db52ee6..b537760 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -185,10 +185,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xC008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -199,10 +201,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS1 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xD008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -231,6 +235,8 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
/* * Size of malloc() pool diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 5140b26..fa461da 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -187,10 +187,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xC008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -201,10 +203,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS3 */ #define CONFIG_ENV_IS_IN_DATAFLASH #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xD008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -233,6 +237,8 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
/* * Size of malloc() pool diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 8399246..253bee4 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -314,10 +314,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xC008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) "\ @@ -347,6 +349,8 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
/* * Size of malloc() pool diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 79ea1f2..423f523 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -153,10 +153,12 @@ /* bootstrap + u-boot + env + linux in dataflash on CS0 */ #define CONFIG_ENV_IS_IN_DATAFLASH 1 #define CONFIG_SYS_MONITOR_BASE (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + 0x8400) -#define CONFIG_ENV_OFFSET 0x4200 +#define CONFIG_ENV_OFFSET 0x84000 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) -#define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_ENV_SIZE 0x4000 +#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR+CONFIG_ENV_SIZE) +#define CONFIG_ENV_SIZE_REDUND CONFIG_ENV_SIZE +#define CONFIG_BOOTCOMMAND "cp.b 0xC008C000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) "\ @@ -183,6 +185,8 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE +#define CONFIG_SYS_REDUNDAND_ENVIRONMENT
Signed-off-by: Alexandre Bellonialexandre.belloni@piout.net
Please prefix patch title/summary with "at91:" or better yet, with the involved boards' names.
Amicalement,
Hi again Alexandre,
Also, doesn't this overallocate for U-Boot and seriously reduce the space available for Linux in Flash?
Amicalement,
I did so on Marek's recommendation. Right now, u-boot's size for AT91SAM9261EK is 235kB. I guess we can allocate a bit less.
My board has 8MB of dataflash, I couldn't find what size is available on other evaluation kits...
Regards,
Hi Alexandre,
Hmm... With 8MByte FLASH the proposed mapping leaves 7+ MB for the flashed kernel, which should be enough :) so that's ok.
Regards,
Amicalement,
Hi Alexandre,
As this follows a V2 patch, you should post as V3 and with patch history (diffs from V3 to V2 and from V2 to V1) inserted here.
Amicalement,
Signed-off-by: Alexandre Belloni alexandre.belloni@piout.net --- Changes for v2: - changed the layout as per Marek's recommendation Changes for v3: - prefixed the patch title with AT91SAM9*:
NAK!
1. You need to be aware of the page size of dataflashes. Each page is 1056 bytes, not 1024 bytes. Your patch will make the U-Boot image start in the middle of a page. 2. Std AT91bootstrap loads U-Boot from 0x8400 so your patch breaks 99% of all SAM9 boards.
If you want to grow U-Boot, then
bootstrap 0x00000000 ; 16 kB ubootenv 0x00004200 ; 16 kB - Should be plenty uboot 0x00008400 ; kernel 0x00063000 ; Why waste space...
Changes for v2:
Changes for v3:
- Size of malloc() pool
NAK!
- You need to be aware of the page size of dataflashes. Each page is 1056 bytes, not 1024 bytes. Your patch will make the U-Boot image start in the middle of a page.
Ok, I couldn't find a clear spec on that dataflash...
- Std AT91bootstrap loads U-Boot from 0x8400 so your patch breaks 99% of all SAM9 boards.
Those boards are broken anyway ! As u-boot is bigger than the load size of at91bootstrap (0x33900 by default). So, not changing means that you are screwed after flashing a new u-boot.
What about the redundant env ? Why shouldn't we reorder u-boot and its env ?
Regards,
28 feb 2012 kl. 23:57 skrev Alexandre Belloni alexandre.belloni@piout.net:
NAK!
maybe you should have tried to look at the Atmel homepage...
No they are not. The partitioning gives you some hint on where to store the kernel, but you can store the kernel at any suitable address. you lose some conveniance, but thats all.
Storing U-boot at any other address than 0x8400, means that AT91bootstrap must be modified, and there is significant disadvantages in having two possible u-boot locations. if you have an at91bootstrap binary, will this use the old or new location? I fail to see any benefit in moving, so that
IIRC, The latest bootstrap with Kconfig has configurable size. Changing size is OK, changing location is not.
Because it adds problems without any benefits. When I looked the last time, the environment is only 8 pages, So you can fit a redundant environment anyway in 16 kB+}
Regards,
-- Alexandre Belloni
Best Regards Ulf Samuelsson ulf@emagii.com
Doesn't that mean that you then have to recompile/reflash at91bootstrap and so that the boards are broken using the latest ut-boot ? I couldn't get my board working with the stock at91bootstrap because it cannot load u-boot.
It has to be fixed or I don't see the point in keeping those configs. If we don't want to change the location, and I can understand the reasons why, then was my first patch ok ?
http://lists.denx.de/pipermail/u-boot/2012-January/114485.html
I'd like to see that fixed so that I could integrate it properly in buildroot...
SIZE
The size of the image loaded by at91bootstrap can be configured by the user using KConfig.
The load address cannot be changed in KConfig For this, you have to modify the source code - bad idea.
I think it would be good, if the u-boot image contained its own size somewhere. (Maybe it does already) marked with some magic key, so that the size can be determined during run time.
I don't like the idea to move the environment as the default. There are people that try to fit the complete kernel + file system into a single 8 MB dataflash and you are using way too much space for U-Boot. If you want to have environment in the high memory, then this should be an option, and not enabled by default.
Also, you are putting the environment into the same block as the kernel.
From the datasheet: "Each page within a sector must be updated/rewritten at least once within every 10,000 cumulative page erase/program operations in that sector."
So updating the environment, may corrupt the kernel.
With a large environment = 32 kB this will happen 4 times faster than with an 8 kB environement. I.E: instead of within every 1250 "saveenv", it must happen within every 312 "saveenv" which is "danger close".
The environment should thus be as small as acceptable.-
To avoid the problem fully, you have to allocate a 256 KB sector for each environment, which means that U-Boot will use 1 MB. Maybe a single 256 kB sector will do. This will cause a significant addition to programming time and is real wasteful in terms of memory-
Better to localize the problem and put the 2 x 8 kB environment and U-Boot in the first sector with U-Boot overlapping into the second sector. This will allow people to choose exactly where the kernel starts.
The kernel should start at sector 3 (page 512) = 0x84000 to avoid problems, if you keep reprogramming u-boot. Sector 0 = 8 kB, 1 = 248 kB, 2 = 256 kB (with 1 kB = 1056 bytes in this case)
People which wants to optimize memory can then still put the kernel at a lower location.
Did not study the size issue, fully, but I would not be surprised if you could, by removing features, still fit u-boot within sector 1, so moving "kernel" to 0x84000 should be an option, enabled in those configs, which do result in growing beyond 0x42000.
Now, the layout is: bootstrap 0x00000000 ubootenv 0x00004200 uboot 0x00008400 kernel 0x00084000
Signed-off-by: Alexandre Belloni alexandre.belloni@piout.net --- Changes for v2: - changed the layout as per Marek's recommendation Changes for v3: - prefixed the patch title with AT91SAM9*: Changes for v4: - changed the layout again as per Ulf Samuelsson's request: http://lists.denx.de/pipermail/u-boot/2012-February/118988.html
include/configs/at91sam9260ek.h | 5 +++-- include/configs/at91sam9261ek.h | 5 +++-- include/configs/at91sam9263ek.h | 4 +++- include/configs/at91sam9rlek.h | 3 ++- 4 files changed, 11 insertions(+), 6 deletions(-)
diff --git a/include/configs/at91sam9260ek.h b/include/configs/at91sam9260ek.h index db52ee6..49b3386 100644 --- a/include/configs/at91sam9260ek.h +++ b/include/configs/at91sam9260ek.h @@ -188,7 +188,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -202,7 +202,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS1 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xD0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -231,6 +231,7 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE
/* * Size of malloc() pool diff --git a/include/configs/at91sam9261ek.h b/include/configs/at91sam9261ek.h index 5140b26..967a4c4 100644 --- a/include/configs/at91sam9261ek.h +++ b/include/configs/at91sam9261ek.h @@ -190,7 +190,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -204,7 +204,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS3 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xD0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xD0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) " \ @@ -233,6 +233,7 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP #define CONFIG_CMDLINE_EDITING +#define CONFIG_AUTO_COMPLETE
/* * Size of malloc() pool diff --git a/include/configs/at91sam9263ek.h b/include/configs/at91sam9263ek.h index 8399246..a6fe325 100644 --- a/include/configs/at91sam9263ek.h +++ b/include/configs/at91sam9263ek.h @@ -317,7 +317,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) "\ @@ -347,6 +347,8 @@ #define CONFIG_AUTO_COMPLETE #define CONFIG_SYS_HUSH_PARSER #define CONFIG_SYS_PROMPT_HUSH_PS2 "> " +#define CONFIG_AUTO_COMPLETE +
/* * Size of malloc() pool diff --git a/include/configs/at91sam9rlek.h b/include/configs/at91sam9rlek.h index 79ea1f2..6640b06 100644 --- a/include/configs/at91sam9rlek.h +++ b/include/configs/at91sam9rlek.h @@ -156,7 +156,7 @@ #define CONFIG_ENV_OFFSET 0x4200 #define CONFIG_ENV_ADDR (CONFIG_SYS_DATAFLASH_LOGIC_ADDR_CS0 + CONFIG_ENV_OFFSET) #define CONFIG_ENV_SIZE 0x4200 -#define CONFIG_BOOTCOMMAND "cp.b 0xC0042000 0x22000000 0x210000; bootm" +#define CONFIG_BOOTCOMMAND "cp.b 0xC0084000 0x22000000 0x210000; bootm" #define CONFIG_BOOTARGS "console=ttyS0,115200 " \ "root=/dev/mtdblock0 " \ "mtdparts=atmel_nand:-(root) "\ @@ -183,6 +183,7 @@ #define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + sizeof(CONFIG_SYS_PROMPT) + 16) #define CONFIG_SYS_LONGHELP 1 #define CONFIG_CMDLINE_EDITING 1 +#define CONFIG_AUTO_COMPLETE
Dear Alexandre Belloni,
In message 1333909023-6725-1-git-send-email-alexandre.belloni@piout.net you wrote:
Where are these odd sizes like
coming from? Has a size of 0x4200 any special maning on these systems?
Dear Wolfgang,
please read Ulfs mail: http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/123862/focus=125897
I think it is OK to apply this patch. All these atmel boards need some more attention (lack of maintainer). Reinhard started to migrate a lot of stuff but unfortunately this process is not completely finished. I will not say it is left undone but there is still a lot to do. I think another point is that these Atmel devices became less important than before in U-Boot (I see not really much users here even though a lot of people use it): a) a lot of users favor the at91bootstrap SPL to boot linux (no need for u-boot) b) they have well-hung cores
best regards
Andreas Bießmann
PS: besides a) there was a user in irc around Christmas who count 'the SPL for atmel devices in U-Boot' a good idea. He said he wants to play with it ... I wonder if he does.
Dear Andreas,
Thanks for the pointer.
I did not intend to object against this patch; I just wonered about the odd numbers,
This could probably be changed if they were converted to using U-Boot's SPL mechanism instead - but then, I also realize that there is only very low interest for them.
Indeed.
On 2012-04-09 10:15, Wolfgang Denk wrote:
Dear Andreas,
While AT91bootstrap supports booting linux, this is real minimal support. Everything is hard-wired so for development it really sucks. It is really only useful for production work. I personally never used this capability.
This functionality is pretty new in AT91boostrap, and the Atmel (non) presence in the mailing list is an older problem.
While I no longer work for Atmel, I have a feeling that the problem is as follows:
Users are using the Atmel version of U-Boot, not mainstream. If not using the Atmel version, then they maybe using a build system like OpenEmbedded where u-boot is built as a part of the build process and people have very little incentive in modifying that part
There is very little incentive at Atmel to upgrade because 1. Patches provided by Atmel are ignored. 2. Patches are applied to mainline which keeps breaking the AT91 support. 3. All possible fixes to boot problem are rejected (discussion with Haavard). 4. It is considered more important to have a "clean" implementation, than a working implementation. (Choice of NOR Flash Driver)
Atmel does not want to continuously spend effort on unbreaking other peoples work.
Problems are not fixed in the mainline due to problem (1). Instead the problems are fixed in the buildsystem and it is not considered worthwhile to submit such fixes to the mailinglist.
The action by the project to "solve" the problem by removing the boards from the MAKEALL scripts and also to remove BSPs is not encouraging.
There used to be a rule that patches should not break board support, but that rule seems to have gone down the drains.
The Atmel code is (IIRC) based on 0.3.4 so it is very old, so an update is really needed but before U-Boot becomes "developer-friendly", I doubt that will happen. If the project wants to have Atmel "on-board", then fixing problem (1) is key.
I think you are right. Atmel wants control over this part.
Still plenty of ARM9 users out there, but a new core would be an obvious way forward for the 2012 model AT91 application processors. Don't see many reasons for updating the current SAM9Gx5 family.
"http://www.mscbp.hu/Documents/Atmel Q-Touch.pdf" seems to hint at a Cortex-A5, but this document is from 2010, so plans may have changed.
Indeed.
- Patches provided by Atmel are ignored.
- Patches are applied to mainline which keeps breaking the AT91 support.
- All possible fixes to boot problem are rejected (discussion with
Would it be possible to get a list of what is not working on mainline but is working in ATMEL's version ? or at least some pointers. It seems to be working well on my board. I'm really interested in getting mainline working well.
I know there is not much interest in the AT91 boards now but I would really like to see that issue fixed.
Regards,
Ok then, I just prefixed the patch title with AT91SAM9*:
Regards,
participants (6)
Albert ARIBAUD
Alexandre Belloni
Andreas Bießmann
Ulf Samuelsson
Ulf Samuelsson
