Pull request: u-boot-rockchip-20240812
Hi Tom,
Please pull the updates for rockchip platform: - Add board support: RK3566: Radxa ROCK 3 Model C Radxa ZERO 3W/3E Xunlong Orange Pi 3B RK3568J: Radxa ROCK 3B RK3308B: Radxa ROCK S0 RK3588: Radxa ROCK 5 ITX FriendlyElec CM3588 NAS board - dw-mmc: allow 4-bit mode; - dts and config updates;
CI: https://source.denx.de/u-boot/custodians/u-boot-rockchip/-/pipelines/21997
Thanks, - Kever
The following changes since commit 1c5445f190cabfd0e453f583aca44da10156c0d6:
Merge patch series "Low Power Mode: Package TIFS Stub in BeaglePlay" (2024-08-08 18:37:11 -0600)
https://source.denx.de/u-boot/custodians/u-boot-rockchip.git tags/u-boot-rockchip-20240812
for you to fetch changes up to 192318d3dcd42da47b9df532a9bda125ed120e4f:
configs: rockchip: enable "ums" command for Radxa ROCK 5B (2024-08-12 15:44:04 +0800)
---------------------------------------------------------------- Alexey Charkov (1): arm64: dts: rockchip: add thermal zones information on RK3588
Dragan Simic (1): arm64: dts: rockchip: Prepare RK3588 SoC dtsi files for per-variant OPPs
FUKAUMI Naoki (6): arm64: dts: rockchip: fix mmc aliases for Radxa ZERO 3E/3W arm: dts: rockchip: disable "usb_host0_ohci" to make boot faster for Radxa ROCK 3A arm64: dts: rockchip: change spi-max-frequency for Radxa ROCK 3C arm: dts: rockchip: remove upstreamed props for Radxa ROCK 3A arm: dts: rockchip: remove upstreamed props for Radxa ROCK 5B configs: rockchip: enable "ums" command for Radxa ROCK 5B
Heiko Stuebner (2): arm64: dts: rockchip: add ROCK 5 ITX board board: rockchip: Add Radxa ROCK 5 ITX
Jonas Karlman (26): mmc: rockchip_dw_mmc: Allow 4-bit mode when 8-bit mode is supported rockchip: io-domain: Add support for RK3308 rockchip: rk3566-pinetab2: Migrate to OF_UPSTREAM rockchip: rk3588-toybrick-x0: Migrate to OF_UPSTREAM rockchip: px30/rk3326: Use soc dtsi files from dts/upstream rockchip: Use files from dts/upstream rockchip: rk3308: Remove OTP device node from soc u-boot dtsi arm64: dts: rockchip: Add OTP device node for RK3308 arm64: dts: rockchip: Add rk3308 IO voltage domains arm64: dts: rockchip: Add sdmmc related properties on rk3308-rock-pi-s arm64: dts: rockchip: Add pinctrl for UART0 to rk3308-rock-pi-s arm64: dts: rockchip: Add mdio and ethernet-phy nodes to rk3308-rock-pi-s arm64: dts: rockchip: Add io-domains to rk3308-rock-pi-s arm64: dts: rockchip: Update WIFi/BT related nodes on rk3308-rock-pi-s rockchip: rk3308-rock-pi-s: Remove unnecessary u-boot dtsi overrides rockchip: rk3308-rock-pi-s: Enable LED and IO Domain driver arm64: dts: rockchip: Add Radxa ROCK S0 board: rockchip: Add Radxa ROCK S0 arm64: dts: rockchip: Add Radxa ROCK 3B board: rockchip: Add Radxa ROCK 3B arm64: dts: rockchip: Add Radxa ZERO 3W/3E dm: adc: Add SPL_ADC Kconfig symbol for use of ADC in SPL board: rockchip: Add Radxa ZERO 3W/3E arm64: dts: rockchip: Add Xunlong Orange Pi 3B board: rockchip: Add FriendlyElec CM3588 NAS rockchip: rk3568-nanopi-r5: Disable SPL_DM_WARN Kconfig option
Kever Yang (1): rockchip: dts: rk3568: Sync the evb board name with kernel
Maxim Moskalets (1): board: rockchip: add Radxa ROCK 3 Model C
Quentin Schulz (1): rockchip: configs: puma-rk3399: disable VIDEO support that breaks Linux
Ricardo Pardini (1): board: rockchip: Add Xunlong Orange Pi 3B
Sebastian Kropatsch (2): phy: rockchip: naneng-combphy: Introduce PHY-IDs to fix RK3588 muxing arm64: dts: rockchip: Add FriendlyElec CM3588 NAS board
Trevor Woerner (1): arm64: dts: rockchip: add gpio-line-names to radxa-zero-3
arch/arm/dts/px30-firefly.dts | 4 + arch/arm/dts/px30-u-boot.dtsi | 4 + arch/arm/dts/px30.dtsi | 2415 ----------------- arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi | 19 - arch/arm/dts/rk3308-rock-s0-u-boot.dtsi | 21 + arch/arm/dts/rk3308-u-boot.dtsi | 16 - arch/arm/dts/rk3326-odroid-go2-u-boot.dtsi | 4 + arch/arm/dts/rk3326.dtsi | 15 - arch/arm/dts/rk3566-orangepi-3b-u-boot.dtsi | 14 + arch/arm/dts/rk3566-orangepi-3b-v1.1-u-boot.dtsi | 3 + arch/arm/dts/rk3566-orangepi-3b-v1.1.dts | 3 + arch/arm/dts/rk3566-orangepi-3b-v2.1-u-boot.dtsi | 3 + arch/arm/dts/rk3566-orangepi-3b-v2.1.dts | 3 + arch/arm/dts/rk3566-orangepi-3b.dts | 5 + arch/arm/dts/rk3566-pinetab2-v0.1.dts | 28 - arch/arm/dts/rk3566-pinetab2-v2.0.dts | 48 - arch/arm/dts/rk3566-pinetab2.dtsi | 943 ------- arch/arm/dts/rk3566-radxa-zero-3e-u-boot.dtsi | 15 + arch/arm/dts/rk3566-radxa-zero-3w-u-boot.dtsi | 15 + arch/arm/dts/rk3566-rock-3c-u-boot.dtsi | 18 + ...evb-u-boot.dtsi => rk3568-evb1-v10-u-boot.dtsi} | 0 arch/arm/dts/rk3568-rock-3a-u-boot.dtsi | 13 +- arch/arm/dts/rk3568-rock-3b-u-boot.dtsi | 15 + .../dts/rk3588-friendlyelec-cm3588-nas-u-boot.dtsi | 8 + arch/arm/dts/rk3588-rock-5-itx-u-boot.dtsi | 22 + arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 17 - arch/arm/dts/rockchip-pinconf.dtsi | 344 --- arch/arm/mach-rockchip/rk3308/syscon_rk3308.c | 3 + arch/arm/mach-rockchip/rk3568/Kconfig | 12 + arch/arm/mach-rockchip/rk3588/Kconfig | 53 + board/friendlyelec/cm3588-nas-rk3588/Kconfig | 12 + board/friendlyelec/cm3588-nas-rk3588/MAINTAINERS | 6 + board/radxa/rock-5-itx-rk3588/Kconfig | 12 + board/radxa/rock-5-itx-rk3588/MAINTAINERS | 8 + board/radxa/zero3-rk3566/Kconfig | 12 + board/radxa/zero3-rk3566/MAINTAINERS | 6 + board/radxa/zero3-rk3566/Makefile | 3 + board/radxa/zero3-rk3566/zero3-rk3566.c | 59 + board/rockchip/evb_rk3308/MAINTAINERS | 6 + board/rockchip/evb_rk3568/MAINTAINERS | 13 + board/xunlong/orangepi-3b-rk3566/Kconfig | 12 + board/xunlong/orangepi-3b-rk3566/MAINTAINERS | 6 + board/xunlong/orangepi-3b-rk3566/Makefile | 3 + .../orangepi-3b-rk3566/orangepi-3b-rk3566.c | 77 + configs/cm3588-nas-rk3588_defconfig | 90 + configs/nanopi-r5c-rk3568_defconfig | 1 - configs/nanopi-r5s-rk3568_defconfig | 1 - configs/orangepi-3b-rk3566_defconfig | 98 + configs/pinetab2-rk3566_defconfig | 5 +- configs/puma-rk3399_defconfig | 10 +- configs/radxa-zero-3-rk3566_defconfig | 85 + configs/rock-3b-rk3568_defconfig | 100 + configs/rock-3c-rk3566_defconfig | 97 + configs/rock-5-itx-rk3588_defconfig | 111 + configs/rock-pi-s-rk3308_defconfig | 4 + configs/rock-s0-rk3308_defconfig | 72 + configs/rock5b-rk3588_defconfig | 1 + configs/toybrick-rk3588_defconfig | 3 +- doc/board/rockchip/rockchip.rst | 9 +- drivers/Makefile | 2 +- drivers/adc/Kconfig | 5 + drivers/adc/Makefile | 2 +- drivers/misc/rockchip-io-domain.c | 37 + drivers/mmc/rockchip_dw_mmc.c | 4 + drivers/phy/rockchip/phy-rockchip-naneng-combphy.c | 46 +- .../src/arm64/rockchip/rk3308-rock-pi-s.dts | 81 +- dts/upstream/src/arm64/rockchip/rk3308-rock-s0.dts | 293 ++ dts/upstream/src/arm64/rockchip/rk3308.dtsi | 29 + .../src/arm64/rockchip/rk3566-orangepi-3b-v1.1.dts | 29 + .../src/arm64/rockchip/rk3566-orangepi-3b-v2.1.dts | 70 + .../src/arm64/rockchip/rk3566-orangepi-3b.dtsi | 678 +++++ .../src/arm64/rockchip/rk3566-radxa-zero-3.dtsi | 531 ++++ .../src/arm64/rockchip/rk3566-radxa-zero-3e.dts | 52 + .../src/arm64/rockchip/rk3566-radxa-zero-3w.dts | 92 + dts/upstream/src/arm64/rockchip/rk3566-rock-3c.dts | 2 +- dts/upstream/src/arm64/rockchip/rk3568-rock-3b.dts | 781 ++++++ ...3588s-pinctrl.dtsi => rk3588-base-pinctrl.dtsi} | 0 dts/upstream/src/arm64/rockchip/rk3588-base.dtsi | 2823 ++++++++++++++++++++ ...3588-pinctrl.dtsi => rk3588-extra-pinctrl.dtsi} | 0 dts/upstream/src/arm64/rockchip/rk3588-extra.dtsi | 413 +++ .../rockchip/rk3588-friendlyelec-cm3588-nas.dts | 778 ++++++ .../arm64/rockchip/rk3588-friendlyelec-cm3588.dtsi | 455 ++-- .../src/arm64/rockchip/rk3588-rock-5-itx.dts | 1177 ++++++++ dts/upstream/src/arm64/rockchip/rk3588.dtsi | 412 +-- dts/upstream/src/arm64/rockchip/rk3588j.dtsi | 2 +- dts/upstream/src/arm64/rockchip/rk3588s.dtsi | 2669 +----------------- include/configs/rock-5-itx-rk3588.h | 15 + include/dt-bindings/clock/px30-cru.h | 389 --- include/dt-bindings/clock/rockchip,rk808.h | 11 - include/dt-bindings/power/px30-power.h | 27 - include/dt-bindings/soc/rockchip,boot-mode.h | 16 - include/dt-bindings/soc/rockchip,vop2.h | 18 - 92 files changed, 9278 insertions(+), 7666 deletions(-) delete mode 100644 arch/arm/dts/px30.dtsi create mode 100644 arch/arm/dts/rk3308-rock-s0-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3326.dtsi create mode 100644 arch/arm/dts/rk3566-orangepi-3b-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-orangepi-3b-v1.1-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-orangepi-3b-v1.1.dts create mode 100644 arch/arm/dts/rk3566-orangepi-3b-v2.1-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-orangepi-3b-v2.1.dts create mode 100644 arch/arm/dts/rk3566-orangepi-3b.dts delete mode 100644 arch/arm/dts/rk3566-pinetab2-v0.1.dts delete mode 100644 arch/arm/dts/rk3566-pinetab2-v2.0.dts delete mode 100644 arch/arm/dts/rk3566-pinetab2.dtsi create mode 100644 arch/arm/dts/rk3566-radxa-zero-3e-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-radxa-zero-3w-u-boot.dtsi create mode 100644 arch/arm/dts/rk3566-rock-3c-u-boot.dtsi rename arch/arm/dts/{rk3568-evb-u-boot.dtsi => rk3568-evb1-v10-u-boot.dtsi} (100%) create mode 100644 arch/arm/dts/rk3568-rock-3b-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-friendlyelec-cm3588-nas-u-boot.dtsi create mode 100644 arch/arm/dts/rk3588-rock-5-itx-u-boot.dtsi delete mode 100644 arch/arm/dts/rockchip-pinconf.dtsi create mode 100644 board/friendlyelec/cm3588-nas-rk3588/Kconfig create mode 100644 board/friendlyelec/cm3588-nas-rk3588/MAINTAINERS create mode 100644 board/radxa/rock-5-itx-rk3588/Kconfig create mode 100644 board/radxa/rock-5-itx-rk3588/MAINTAINERS create mode 100644 board/radxa/zero3-rk3566/Kconfig create mode 100644 board/radxa/zero3-rk3566/MAINTAINERS create mode 100644 board/radxa/zero3-rk3566/Makefile create mode 100644 board/radxa/zero3-rk3566/zero3-rk3566.c create mode 100644 board/xunlong/orangepi-3b-rk3566/Kconfig create mode 100644 board/xunlong/orangepi-3b-rk3566/MAINTAINERS create mode 100644 board/xunlong/orangepi-3b-rk3566/Makefile create mode 100644 board/xunlong/orangepi-3b-rk3566/orangepi-3b-rk3566.c create mode 100644 configs/cm3588-nas-rk3588_defconfig create mode 100644 configs/orangepi-3b-rk3566_defconfig create mode 100644 configs/radxa-zero-3-rk3566_defconfig create mode 100644 configs/rock-3b-rk3568_defconfig create mode 100644 configs/rock-3c-rk3566_defconfig create mode 100644 configs/rock-5-itx-rk3588_defconfig create mode 100644 configs/rock-s0-rk3308_defconfig create mode 100644 dts/upstream/src/arm64/rockchip/rk3308-rock-s0.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-orangepi-3b-v1.1.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-orangepi-3b-v2.1.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-orangepi-3b.dtsi create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-radxa-zero-3.dtsi create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-radxa-zero-3e.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3566-radxa-zero-3w.dts create mode 100644 dts/upstream/src/arm64/rockchip/rk3568-rock-3b.dts rename dts/upstream/src/arm64/rockchip/{rk3588s-pinctrl.dtsi => rk3588-base-pinctrl.dtsi} (100%) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-base.dtsi rename dts/upstream/src/arm64/rockchip/{rk3588-pinctrl.dtsi => rk3588-extra-pinctrl.dtsi} (100%) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-extra.dtsi create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-friendlyelec-cm3588-nas.dts rename arch/arm/dts/rk3588-toybrick-x0.dts => dts/upstream/src/arm64/rockchip/rk3588-friendlyelec-cm3588.dtsi (66%) create mode 100644 dts/upstream/src/arm64/rockchip/rk3588-rock-5-itx.dts create mode 100644 include/configs/rock-5-itx-rk3588.h delete mode 100644 include/dt-bindings/clock/px30-cru.h delete mode 100644 include/dt-bindings/clock/rockchip,rk808.h delete mode 100644 include/dt-bindings/power/px30-power.h delete mode 100644 include/dt-bindings/soc/rockchip,boot-mode.h delete mode 100644 include/dt-bindings/soc/rockchip,vop2.h
On Mon, Aug 12, 2024 at 05:45:30PM +0800, Kever Yang wrote:
Hi Tom,
Thanks,
- Kever
Kever Yang
