[U-Boot] [PATCH 1/3] clk: renesas: Fix SDH clock divider decoding on Gen2
The gen2_clk_get_sdh_div() function is supposed to look up the $val value read out of the SDCKCR register in the supplied table and return the matching divider value. The current implementation was matching the value from SDCKCR on the divider value in the table, which is wrong. Fix this and rework the function a bit to make it more readable.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/clk/renesas/clk-rcar-gen2.c | 14 +++++++++----- 1 file changed, 9 insertions(+), 5 deletions(-)
diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index 6dfd02f2eb..aedaab723b 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -44,13 +44,17 @@ static const struct clk_div_table cpg_sd01_div_table[] = { { 0, 0 }, };
-static u8 gen2_clk_get_sdh_div(const struct clk_div_table *table, u8 div) +static u8 gen2_clk_get_sdh_div(const struct clk_div_table *table, u8 val) { - while ((*table++).val) { - if ((*table).div == div) - return div; + for (;;) { + if (!(*table).div) + return 0xff; + + if ((*table).val == val) + return (*table).div; + + table++; } - return 0xff; }
static int gen2_clk_enable(struct clk *clk)
The $div and $mul values were swapped in the debug output, fix this.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/clk/renesas/clk-rcar-gen2.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index aedaab723b..34abe784fd 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -121,7 +121,7 @@ static ulong gen2_clk_get_rate(struct clk *clk)
case CLK_TYPE_FF: rate = (gen2_clk_get_rate(&parent) * core->mult) / core->div; - debug("%s[%i] FIXED clk: parent=%i div=%i mul=%i => rate=%u\n", + debug("%s[%i] FIXED clk: parent=%i mul=%i div=%i => rate=%u\n", __func__, __LINE__, core->parent, core->mult, core->div, rate); return rate;
Add code for configuring the MMC0CKCR/MMC1CKCR on Gen2 platforms. This allows the MMCIF driver to set higher clock rate if desired.
Signed-off-by: Marek Vasut marek.vasut+renesas@gmail.com Cc: Nobuhiro Iwamatsu iwamatsu@nigauri.org --- drivers/clk/renesas/clk-rcar-gen2.c | 42 +++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/drivers/clk/renesas/clk-rcar-gen2.c b/drivers/clk/renesas/clk-rcar-gen2.c index 34abe784fd..13111b341a 100644 --- a/drivers/clk/renesas/clk-rcar-gen2.c +++ b/drivers/clk/renesas/clk-rcar-gen2.c @@ -206,8 +206,50 @@ static ulong gen2_clk_get_rate(struct clk *clk) return -ENOENT; }
+static int gen2_clk_setup_mmcif_div(struct clk *clk, ulong rate) +{ + struct gen2_clk_priv *priv = dev_get_priv(clk->dev); + struct cpg_mssr_info *info = priv->info; + const struct cpg_core_clk *core; + struct clk parent, pparent; + u32 val; + int ret; + + ret = renesas_clk_get_parent(clk, info, &parent); + if (ret) { + debug("%s[%i] parent fail, ret=%i\n", __func__, __LINE__, ret); + return ret; + } + + if (renesas_clk_is_mod(&parent)) + return 0; + + ret = renesas_clk_get_core(&parent, info, &core); + if (ret) + return ret; + + if (strcmp(core->name, "mmc0") && strcmp(core->name, "mmc1")) + return 0; + + ret = renesas_clk_get_parent(&parent, info, &pparent); + if (ret) { + debug("%s[%i] parent fail, ret=%i\n", __func__, __LINE__, ret); + return ret; + } + + val = (gen2_clk_get_rate(&pparent) / rate) - 1; + + debug("%s[%i] MMCIF offset=%x\n", __func__, __LINE__, core->offset); + + writel(val, priv->base + core->offset); + + return 0; +} + static ulong gen2_clk_set_rate(struct clk *clk, ulong rate) { + /* Force correct MMC-IF divider configuration if applicable */ + gen2_clk_setup_mmcif_div(clk, rate); return gen2_clk_get_rate(clk); }
