[U-Boot] Pull request for v2019.04-rc4
Hi Tom,
please pull last minute fix for Ethernet on i.MX8QXP MEK board. These patches were already reviewed/tested and acked by Joe, but didn't make it into the tree yet (last u-boot-net pull request was rejected due to issues with other patches).
Thanks, Anatolij
The following changes since commit afbc31948a007e03d6a1282677aafc2208f45819:
net: phy: implement fallback mechanism for negative phy adresses (2019-04-07 20:31:16 -0400)
git://git.denx.de/u-boot-staging.git tags/fixes-for-2019.04-rc4
for you to fetch changes up to e82fa10b3ef745ea08d5dac8ff088553846c2ca1:
dts: imx8qxp-mek: Add PHY post reset delay (2019-04-08 15:24:39 +0200)
---------------------------------------------------------------- - i.MX8QXP-MEK ethernet fix
---------------------------------------------------------------- Andrejs Cainikovs (2): net: dm: fec: Support phy-reset-post-delay property dts: imx8qxp-mek: Add PHY post reset delay
arch/arm/dts/fsl-imx8qxp-mek.dts | 1 + drivers/net/fec_mxc.c | 11 +++++++++++ drivers/net/fec_mxc.h | 1 + 3 files changed, 13 insertions(+)
On Mon, Apr 08, 2019 at 03:47:31PM +0200, Anatolij Gustschin wrote:
Hi Tom,
Thanks, Anatolij
Anatolij Gustschin
