[U-Boot] [PATCH] fs/ext4/ext4fs.c, fs/fs.c: Use lldiv and multiplication / subtraction on 64bit ops
In some cases we need to do math on 64bit quantities. We need to be using lldiv in these cases rather than letting the compiler do it. In addition we need to avoid doing % operations on these same quantities. These changes fix compilation on MIPS/MIPSEL.
Cc: Daniel Schwierzeck daniel.schwierzeck@gmail.com Cc: Suriyan Ramasami suriyan.r@gmail.com Cc: Simon Glass sjg@chromium.org Signed-off-by: Tom Rini trini@ti.com --- fs/ext4/ext4fs.c | 11 ++++++----- fs/fs.c | 3 ++- 2 files changed, 8 insertions(+), 6 deletions(-)
diff --git a/fs/ext4/ext4fs.c b/fs/ext4/ext4fs.c index 943b5bc..258b9379 100644 --- a/fs/ext4/ext4fs.c +++ b/fs/ext4/ext4fs.c @@ -25,6 +25,7 @@ #include <ext_common.h> #include <ext4fs.h> #include "ext4_common.h" +#include <div64.h>
int ext4fs_symlinknest; struct ext_filesystem ext_fs; @@ -67,11 +68,11 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos, if (len > filesize) len = filesize;
- blockcnt = ((len + pos) + blocksize - 1) / blocksize; + blockcnt = lldiv(((len + pos) + blocksize - 1), blocksize);
- for (i = pos / blocksize; i < blockcnt; i++) { + for (i = lldiv(pos, blocksize); i < blockcnt; i++) { lbaint_t blknr; - int blockoff = pos % blocksize; + int blockoff = pos - (blocksize * i); int blockend = blocksize; int skipfirst = 0; blknr = read_allocated_block(&(node->inode), i); @@ -82,7 +83,7 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos,
/* Last block. */ if (i == blockcnt - 1) { - blockend = (len + pos) % blocksize; + blockend = (len + pos) - (blocksize * i);
/* The last portion is exactly blocksize. */ if (!blockend) @@ -90,7 +91,7 @@ int ext4fs_read_file(struct ext2fs_node *node, loff_t pos, }
/* First block. */ - if (i == pos / blocksize) { + if (i == lldiv(pos, blocksize)) { skipfirst = blockoff; blockend -= skipfirst; } diff --git a/fs/fs.c b/fs/fs.c index 3da7860..760f4a6 100644 --- a/fs/fs.c +++ b/fs/fs.c @@ -17,6 +17,7 @@ #include <config.h> #include <errno.h> #include <common.h> +#include <div64.h> #include <part.h> #include <ext4fs.h> #include <fat.h> @@ -399,7 +400,7 @@ int do_load(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[], printf("%llu bytes read in %lu ms", len_read, time); if (time > 0) { puts(" ("); - print_size(len_read / time * 1000, "/s"); + print_size(lldiv(len_read, time * 1000), "/s"); puts(")"); } puts("\n");
blockend = (len + pos) - (blocksize * i); /* The last portion is exactly blocksize. */ if (!blockend)
/* First block. */
-- 1.7.9.5
Hi Tom,
I'm not sure this goes far enough. I am still seeing problems even with this patch, e.g. for pm9g45:
/opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: error: /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(bpabi.o) uses VFP register arguments, u-boot does not /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: failed to merge target specific data of file /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(bpabi.o) /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: error: /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(_divdi3.o) uses VFP register arguments, u-boot does not /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: failed to merge target specific data of file /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(_divdi3.o) /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: error: /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(_udivdi3.o) uses VFP register arguments, u-boot does not /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/arm-linux-gnueabihf-ld.bfd: failed to merge target specific data of file /opt/linaro/gcc-linaro-arm-linux-gnueabihf-4.8-2013.10_linux/bin/../lib/gcc/arm-linux-gnueabihf/4.8.2/libgcc.a(_udivdi3.o) make[1]: *** [u-boot] Error 1 make: *** [sub-make] Error 2
On Tue, Nov 25, 2014 at 02:45:33PM -0700, Simon Glass wrote:
Hi Tom,
Indeed it's not. I'll post a V2 soon, I've figured out the places I missed but need to step out now.
