[PATCH] usb: cdns3: gadget.c: Set fast access bit
When the device port is in a low power state [U3/L2/Not Connected], accesses to usb device registers may take a long time. This could lead to potential core hang when the controller registers are accessed after the port is disabled by setting DEVDS field. Setting the fast register access bit ensures that the PHY clock is keeping up in active state.
Therefore, set fast access bit to ensure the accesses to device registers are quick even in low power states.
Signed-off-by: Aswath Govindraju a-govindraju@ti.com --- drivers/usb/cdns3/gadget.c | 4 ++++ 1 file changed, 4 insertions(+)
diff --git a/drivers/usb/cdns3/gadget.c b/drivers/usb/cdns3/gadget.c index fcaeab9cc1..fddc8c931a 100644 --- a/drivers/usb/cdns3/gadget.c +++ b/drivers/usb/cdns3/gadget.c @@ -2321,6 +2321,9 @@ static void cdns3_gadget_config(struct cdns3_device *priv_dev) writel(USB_IEN_INIT, ®s->usb_ien); writel(USB_CONF_CLK2OFFDS | USB_CONF_L1DS, ®s->usb_conf);
+ /* Set the Fast access bit */ + writel(PUSB_PWR_FST_REG_ACCESS, &priv_dev->regs->usb_pwr); + cdns3_configure_dmult(priv_dev, NULL);
cdns3_gadget_pullup(&priv_dev->gadget, 1); @@ -2378,6 +2381,7 @@ static int cdns3_gadget_udc_stop(struct usb_gadget *gadget)
/* disable interrupt for device */ writel(0, &priv_dev->regs->usb_ien); + writel(0, &priv_dev->regs->usb_pwr); writel(USB_CONF_DEVDS, &priv_dev->regs->usb_conf);
return ret;
base-commit: a25dcda452bf6a6de72764a8d990d72e5def643d
Hi Ravi,
- /* Set the Fast access bit */
- writel(PUSB_PWR_FST_REG_ACCESS, &priv_dev->regs->usb_pwr);
Should this be done in cdns3_gadget_udc_start() so it is symmetric?
return ret;
cheers, -roger
Hi Roger,
On 05/05/23 6:02 pm, Roger Quadros wrote:
Hi Ravi,
cdns3_gadget_config() is called in cdns3_gadget_udc_start() and cdns3_gadget_resume(). These settings seems to be needed during resume as well.
return ret;
cheers, -roger
+Pawel & Peter
On 09/05/2023 08:58, Ravi Gunasekaran wrote:
Hi Roger,
Hi Ravi,
But this bit was never cleared in suspend so why do you need to set it again it in resume?
The commit log says that this bit must be kept set in low power states.
return ret;
+Pawel & Peter
Hi Roger,
Hi Ravi,
active state.
In my opinion setting PUSB_PWR_FST_REG_ACCESS is not needed in cdns3_gadget_resume, but it should not have any negative impact for driver. The cdns3_gadget_config function seems like a good place for setting this bit.
Regards, Pawel Laszczak
return ret;
-- cheers, -roger
Pawel,
On 11/05/23 11:00 am, Pawel Laszczak wrote:
+Pawel & Peter
Hi Roger,
Hi Ravi,
active state.
In the suspend(), USB_CONF_CFGRST (register: usb_conf.CFGRST) is set, resetting the USB device configuration. Does this mean PUSB_PWR_FST_REG_ACCESS will also be reset?
Regards, Ravi
return ret;
-- cheers, -roger
+Pawel & Peter
Hi Roger,
Hi Ravi,
active state.
usb_pwr);
Setting usb_conf.CFGRST doesn't reset the PUSB_PWR_FST_REG_ACCESS.
Regards, Pawel
Regards, Ravi
return ret;
-- cheers, -roger
Reviewed-by: Roger Quadros rogerq@kernel.org
Pawel Laszczak
Ravi Gunasekaran
Roger Quadros
