[U-Boot] [PATCH] powerpc/t4qds: move VSC3316 config data from t4qds.h to t4qds.c
Static variables should be defined in C files, not header files, because otherwise every C file that #includes the header file will generate a duplicate of the variables. Since the vsc3316_xxx[] arrays are only used by t4qds.c anyway, just put the variables there.
Signed-off-by: Timur Tabi timur@freescale.com --- board/freescale/t4qds/t4qds.c | 12 ++++++++++++ board/freescale/t4qds/t4qds.h | 11 ----------- 2 files changed, 12 insertions(+), 11 deletions(-)
diff --git a/board/freescale/t4qds/t4qds.c b/board/freescale/t4qds/t4qds.c index 88b8ced..392c8c0 100644 --- a/board/freescale/t4qds/t4qds.c +++ b/board/freescale/t4qds/t4qds.c @@ -42,6 +42,18 @@
DECLARE_GLOBAL_DATA_PTR;
+static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, + {8, 8}, {9, 9}, {14, 14}, {15, 15} }; + +static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, + {10, 10}, {11, 11}, {12, 12}, {13, 13} }; + +static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, + {10, 11}, {11, 10}, {12, 2}, {13, 3} }; + +static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, + {8, 9}, {9, 8}, {14, 1}, {15, 0} }; + int checkboard(void) { u8 sw; diff --git a/board/freescale/t4qds/t4qds.h b/board/freescale/t4qds/t4qds.h index c6a3492..f290f3c 100644 --- a/board/freescale/t4qds/t4qds.h +++ b/board/freescale/t4qds/t4qds.h @@ -23,15 +23,4 @@ void fdt_fixup_board_enet(void *blob); void pci_of_setup(void *blob, bd_t *bd);
-static const int8_t vsc3316_fsm1_tx[8][2] = { {0, 0}, {1, 1}, {6, 6}, {7, 7}, - {8, 8}, {9, 9}, {14, 14}, {15, 15} }; - -static const int8_t vsc3316_fsm2_tx[8][2] = { {2, 2}, {3, 3}, {4, 4}, {5, 5}, - {10, 10}, {11, 11}, {12, 12}, {13, 13} }; - -static const int8_t vsc3316_fsm1_rx[8][2] = { {2, 12}, {3, 13}, {4, 5}, {5, 4}, - {10, 11}, {11, 10}, {12, 2}, {13, 3} }; - -static const int8_t vsc3316_fsm2_rx[8][2] = { {0, 15}, {1, 14}, {6, 7}, {7, 6}, - {8, 9}, {9, 8}, {14, 1}, {15, 0} }; #endif
Timur Tabi
