RE: [U-Boot-Users] IDE LBA48 support and vsprintf 64bit support
Ummm... actually I don't like to increase the memory footprint for all systems for a feature which nearly nobody ever needs. I think it should be possible to print the large capacities without using such data formats (I guess you don't need 64 bit precision).
I guess I can add some #ifdefs around my code (especially the 64bit printing stuff) Hex isn't a problem, and decimal is not a problem as long as the disk is less than 548GB
For the IDE stuff itself, without 64 bit the IDE can handle drives up to 548GB (max sector numbers possible in 32 bit). What if I have a config option to use 64-bit sector numbers, and default to using 32-bit?
(I needed this since our board does have a 250GB disk attached, and I wanted to see the real capacity when booting)
In message DCEAAC0833DD314AB0B58112AD99B93B06DA77@ismail.innsys.innovsys.com you wrote:
We are not talking about the IDE code here. If you need "long long" numbers just used them (but carefully). But I don't see why you need "%LL" support in printf.
Rune Torgersen
