[U-Boot] [PATCH v2] test: py: Add an option to skip sleep test
Some QEMUs have a problem with time setup that's why sleep test is failing. Introduce env__sleep_accurate boardenv variable to have an option to skip sleep test.
Changes in v2: - Remove unrelated zc706 change
Changes in v1: - Change subject line and patch description - Move from RFC to regular patch - Remove boardidentity marker and use variable instead
test/py/tests/test_sleep.py | 13 +++++++++++++ 1 file changed, 13 insertions(+)
diff --git a/test/py/tests/test_sleep.py b/test/py/tests/test_sleep.py index 64e057132622..ccef24d7f7b8 100644 --- a/test/py/tests/test_sleep.py +++ b/test/py/tests/test_sleep.py @@ -5,10 +5,23 @@ import pytest import time
+""" +Note: This test doesn't rely on boardenv_* configuration values but they can +change test behavior. + +# Setup env__sleep_accurate to False if time is not accurate on your platform +env__sleep_accurate = False + +""" + def test_sleep(u_boot_console): """Test the sleep command, and validate that it sleeps for approximately the correct amount of time."""
+ sleep_skip = u_boot_console.config.env.get('env__sleep_accurate', True) + if not sleep_skip: + pytest.skip('sleep is not accurate') + if u_boot_console.config.buildconfig.get('config_cmd_misc', 'n') != 'y': pytest.skip('sleep command not supported') # 3s isn't too long, but is enough to cross a few second boundaries.
Nit: Commit descriptions are typically wrapped around 70-74 characters; the above is very narrow.
Nit: No need for that trailing empty line in the docstring.
Reviewed-by: Stephen Warren swarren@nvidia.com
(I was going to contemplate a more generic system implemented in conftest.py that could work with any test, but I guess this is simple enough and solves the only issue we have right now, so it's fine.)
2017-12-08 17:54 GMT+01:00 Stephen Warren swarren@wwwdotorg.org:
I think also that generic solution would be better. I was checking xilinx repo where we have some simple i2c device tests which also needs to be run based on platforms. This test is broken on qemu and some boards are also broken. There is not an issue with travis because sleep tests are disabled now. For my qemu testing it is not big deal and I can use -k not sleep or this patch as temporary workaround till we have generic solution in place.
Thanks, Michal
Signed-off-by: Michal Simek michal.simek@xilinx.com Reviewed-by: Tom Rini trini@konsulko.com Reviewed-by: Stephen Warren swarren@nvidia.com
Michal Simek
Michal Simek
Stephen Warren
