[PATCH v4 0/3] Random Number Generator fixes
This series aim to fix smccc bind issue and add a list command for RNG devices.
Changelog:
v3 --> v4 - update doc/usage/cmd/rng.rst
v2 --> v3 - remove fallback smc call - add Fixes tag
v1 --> v2 - check SMCCC_ARCH_FEATURES - update commit message and rng help info
Weizhao Ouyang (3): firmware: psci: Fix bind_smccc_features psci check driver: rng: Fix SMCCC TRNG crash cmd: rng: Add rng list command
cmd/rng.c | 23 ++++++++++++++++++----- doc/usage/cmd/rng.rst | 14 ++++++++++---- drivers/firmware/psci.c | 5 ++++- drivers/rng/smccc_trng.c | 2 +- include/linux/arm-smccc.h | 6 ++++++ 5 files changed, 39 insertions(+), 11 deletions(-)
According to PSCI specification DEN0022F, PSCI_FEATURES is used to check whether the SMCCC is implemented by discovering SMCCC_VERSION.
Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- v3: remove fallback smc call v2: check SMCCC_ARCH_FEATURES --- drivers/firmware/psci.c | 5 ++++- include/linux/arm-smccc.h | 6 ++++++ 2 files changed, 10 insertions(+), 1 deletion(-)
diff --git a/drivers/firmware/psci.c b/drivers/firmware/psci.c index c6b9efab41..03544d76ed 100644 --- a/drivers/firmware/psci.c +++ b/drivers/firmware/psci.c @@ -135,10 +135,13 @@ static int bind_smccc_features(struct udevice *dev, int psci_method) PSCI_VERSION_MAJOR(psci_0_2_get_version()) == 0) return 0;
- if (request_psci_features(ARM_SMCCC_ARCH_FEATURES) == + if (request_psci_features(ARM_SMCCC_VERSION) == PSCI_RET_NOT_SUPPORTED) return 0;
+ if (invoke_psci_fn(ARM_SMCCC_VERSION, 0, 0, 0) < ARM_SMCCC_VERSION_1_1) + return 0; + if (psci_method == PSCI_METHOD_HVC) pdata->invoke_fn = smccc_invoke_hvc; else diff --git a/include/linux/arm-smccc.h b/include/linux/arm-smccc.h index f44e9e8f93..da3d29aabe 100644 --- a/include/linux/arm-smccc.h +++ b/include/linux/arm-smccc.h @@ -55,8 +55,14 @@ #define ARM_SMCCC_QUIRK_NONE 0 #define ARM_SMCCC_QUIRK_QCOM_A6 1 /* Save/restore register a6 */
+#define ARM_SMCCC_VERSION 0x80000000 #define ARM_SMCCC_ARCH_FEATURES 0x80000001
+#define ARM_SMCCC_VERSION_1_0 0x10000 +#define ARM_SMCCC_VERSION_1_1 0x10001 +#define ARM_SMCCC_VERSION_1_2 0x10002 +#define ARM_SMCCC_VERSION_1_3 0x10003 + #define ARM_SMCCC_RET_NOT_SUPPORTED ((unsigned long)-1)
#ifndef __ASSEMBLY__
Fix a SMCCC TRNG null pointer crash due to a failed smccc feature binding.
Fixes: 53355bb86c25 ("drivers: rng: add smccc trng driver") Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- v3: add Fixes tag --- drivers/rng/smccc_trng.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/rng/smccc_trng.c b/drivers/rng/smccc_trng.c index 3a4bb33941..3087cb991a 100644 --- a/drivers/rng/smccc_trng.c +++ b/drivers/rng/smccc_trng.c @@ -166,7 +166,7 @@ static int smccc_trng_probe(struct udevice *dev) struct smccc_trng_priv *priv = dev_get_priv(dev); struct arm_smccc_res res;
- if (!(smccc_trng_is_supported(smccc->invoke_fn))) + if (!smccc || !(smccc_trng_is_supported(smccc->invoke_fn))) return -ENODEV;
/* At least one of 64bit and 32bit interfaces is available */
The 'rng list' command probes all RNG devices and list those devices that are successfully probed. Also update the help info.
Reviewed-by: Heinrich Schuchardt xypron.glpk@gmx.de Signed-off-by: Weizhao Ouyang o451686892@gmail.com --- v4: update doc/usage/cmd/rng.rst --- cmd/rng.c | 23 ++++++++++++++++++----- doc/usage/cmd/rng.rst | 14 ++++++++++---- 2 files changed, 28 insertions(+), 9 deletions(-)
diff --git a/cmd/rng.c b/cmd/rng.c index 52f722c7af..b073a6c849 100644 --- a/cmd/rng.c +++ b/cmd/rng.c @@ -19,6 +19,22 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) struct udevice *dev; int ret = CMD_RET_SUCCESS;
+ if (argc == 2 && !strcmp(argv[1], "list")) { + int idx = 0; + + uclass_foreach_dev_probe(UCLASS_RNG, dev) { + idx++; + printf("RNG #%d - %s\n", dev->seq_, dev->name); + } + + if (!idx) { + log_err("No RNG device\n"); + return CMD_RET_FAILURE; + } + + return CMD_RET_SUCCESS; + } + switch (argc) { case 1: devnum = 0; @@ -56,12 +72,9 @@ static int do_rng(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) return ret; }
-U_BOOT_LONGHELP(rng, - "[dev [n]]\n" - " - print n random bytes(max 64) read from dev\n"); - U_BOOT_CMD( rng, 3, 0, do_rng, "print bytes from the hardware random number generator", - rng_help_text + "list - list all the probed rng devices\n" + "rng [dev] [n] - print n random bytes(max 64) read from dev\n" ); diff --git a/doc/usage/cmd/rng.rst b/doc/usage/cmd/rng.rst index 274e4d88df..4a61e33d27 100644 --- a/doc/usage/cmd/rng.rst +++ b/doc/usage/cmd/rng.rst @@ -11,16 +11,22 @@ Synopsis
- rng [devnum [n]] + rng list + rng [dev] [n]
-Description ------------ +rng list +-------- + +List all the probed rng devices. + +rng [dev] [n] +-------------
The *rng* command reads the random number generator(RNG) device and prints the random bytes read on the console. A maximum of 64 bytes can be read in one invocation of the command.
-devnum +dev The RNG device from which the random bytes are to be read. Defaults to 0.
Weizhao Ouyang
