[U-Boot] [PATCH 2/2] Convert CONFIG_SYS_I2C_BUS_MAX to Kconfig
This converts the following to Kconfig: CONFIG_SYS_I2C_BUS_MAX
Signed-off-by: Adam Ford aford173@gmail.com --- arch/arm/include/asm/arch-am33xx/i2c.h | 1 - arch/arm/include/asm/arch-omap3/i2c.h | 1 - arch/arm/include/asm/arch-omap4/i2c.h | 1 - arch/arm/include/asm/arch-omap5/i2c.h | 1 - drivers/i2c/Kconfig | 10 ++++++++++ include/configs/socfpga_common.h | 1 - include/configs/ti_armv7_keystone2.h | 1 - 7 files changed, 10 insertions(+), 6 deletions(-)
diff --git a/arch/arm/include/asm/arch-am33xx/i2c.h b/arch/arm/include/asm/arch-am33xx/i2c.h index a34282a..16e9a99 100644 --- a/arch/arm/include/asm/arch-am33xx/i2c.h +++ b/arch/arm/include/asm/arch-am33xx/i2c.h @@ -10,7 +10,6 @@ #define I2C_BASE1 0x44E0B000 #define I2C_BASE2 0x4802A000 #define I2C_BASE3 0x4819C000 -#define CONFIG_SYS_I2C_BUS_MAX 3
#define I2C_DEFAULT_BASE I2C_BASE1
diff --git a/arch/arm/include/asm/arch-omap3/i2c.h b/arch/arm/include/asm/arch-omap3/i2c.h index d142175..48676dd 100644 --- a/arch/arm/include/asm/arch-omap3/i2c.h +++ b/arch/arm/include/asm/arch-omap3/i2c.h @@ -7,7 +7,6 @@ #ifndef _OMAP3_I2C_H_ #define _OMAP3_I2C_H_
-#define CONFIG_SYS_I2C_BUS_MAX 3 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/arch/arm/include/asm/arch-omap4/i2c.h b/arch/arm/include/asm/arch-omap4/i2c.h index 1c5ed9b..96c0954 100644 --- a/arch/arm/include/asm/arch-omap4/i2c.h +++ b/arch/arm/include/asm/arch-omap4/i2c.h @@ -7,7 +7,6 @@ #ifndef _OMAP4_I2C_H_ #define _OMAP4_I2C_H_
-#define CONFIG_SYS_I2C_BUS_MAX 4 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/arch/arm/include/asm/arch-omap5/i2c.h b/arch/arm/include/asm/arch-omap5/i2c.h index 5122cd6..6d620dc 100644 --- a/arch/arm/include/asm/arch-omap5/i2c.h +++ b/arch/arm/include/asm/arch-omap5/i2c.h @@ -7,7 +7,6 @@ #ifndef _OMAP5_I2C_H_ #define _OMAP5_I2C_H_
-#define CONFIG_SYS_I2C_BUS_MAX 5 #define I2C_DEFAULT_BASE I2C_BASE1
struct i2c { diff --git a/drivers/i2c/Kconfig b/drivers/i2c/Kconfig index 720e82d..f4fd843 100644 --- a/drivers/i2c/Kconfig +++ b/drivers/i2c/Kconfig @@ -207,6 +207,16 @@ config TEGRA186_BPMP_I2C by the BPMP, and can only be accessed by the main CPU via IPC requests to the BPMP. This driver covers the latter case.
+config SYS_I2C_BUS_MAX + int "Max I2C busses" + depends on ARCH_KEYSTONE || ARCH_OMAP2PLUS || ARCH_SOCFPGA + default 2 if TI816X + default 3 if OMAP34XX || AM33XX || ARCH_KEYSTONE + default 4 if ARCH_SOCFPGA || OMAP44XX || AM44XX || AM43XX ||TI814X + default 5 if OMAP54XX + help + Define the maximum number of available I2C buses. + source "drivers/i2c/muxes/Kconfig"
endmenu diff --git a/include/configs/socfpga_common.h b/include/configs/socfpga_common.h index 175b01e..73a9744 100644 --- a/include/configs/socfpga_common.h +++ b/include/configs/socfpga_common.h @@ -156,7 +156,6 @@ * I2C support */ #define CONFIG_SYS_I2C -#define CONFIG_SYS_I2C_BUS_MAX 4 #define CONFIG_SYS_I2C_BASE SOCFPGA_I2C0_ADDRESS #define CONFIG_SYS_I2C_BASE1 SOCFPGA_I2C1_ADDRESS #define CONFIG_SYS_I2C_BASE2 SOCFPGA_I2C2_ADDRESS diff --git a/include/configs/ti_armv7_keystone2.h b/include/configs/ti_armv7_keystone2.h index 812ba51..6831b2c 100644 --- a/include/configs/ti_armv7_keystone2.h +++ b/include/configs/ti_armv7_keystone2.h @@ -160,7 +160,6 @@ #define CONFIG_SYS_DAVINCI_I2C_SLAVE1 0x10 /* SMBus host address */ #define CONFIG_SYS_DAVINCI_I2C_SPEED2 100000 #define CONFIG_SYS_DAVINCI_I2C_SLAVE2 0x10 /* SMBus host address */ -#define CONFIG_SYS_I2C_BUS_MAX 3
/* EEPROM definitions */ #define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2
Hello Adam,
Am 11.08.2017 um 13:39 schrieb Adam Ford:
Reviewed-by: Heiko Schocher hs@denx.de
bye, Heiko
Signed-off-by: Adam Ford aford173@gmail.com Reviewed-by: Heiko Schocher hs@denx.de
Adam Ford
Heiko Schocher
