[U-Boot] [GIT PULL] Pull request: u-boot-imx
Hi Wolfgang,
The following changes since commit cdc51c294ad33879c4e57edf4c9d2155381b1d59:
Merge branch 'next' of ../next (2010-12-22 21:16:17 +0100)
git://www.denx.de/git/u-boot-imx.git master
Liu Hui-R64343 (9): MX51EVK: UART does not print out the early information MX5: Add initial support for MX53 processor fec_mxc: add support for MX53 processor serial_mxc: add support for MX53 processor mxc_gpio: add support for MX53 processor mxc_i2c: add support for MX53 processor fsl_pmic: add I2C interface support imximage: Add MX53 boot image support MX5:MX53: add initial support for MX53EVK board
MAINTAINERS | 4 + arch/arm/cpu/armv7/mx5/iomux.c | 30 ++- arch/arm/cpu/armv7/mx5/lowlevel_init.S | 91 +++--- arch/arm/cpu/armv7/mx5/soc.c | 22 +- arch/arm/include/asm/arch-mx5/asm-offsets.h | 5 + arch/arm/include/asm/arch-mx5/imx-regs.h | 82 ++--- arch/arm/include/asm/arch-mx5/iomux.h | 102 ------ arch/arm/include/asm/arch-mx5/mx5x_pins.h | 469 ++++++++++++++++++++++++++- board/freescale/mx51evk/mx51evk.c | 11 +- board/freescale/mx53evk/Makefile | 48 +++ board/freescale/mx53evk/config.mk | 24 ++ board/freescale/mx53evk/imximage.cfg | 112 +++++++ board/freescale/mx53evk/mx53evk.c | 397 +++++++++++++++++++++++ boards.cfg | 1 + doc/README.imximage | 12 +- drivers/gpio/mxc_gpio.c | 9 +- drivers/i2c/mxc_i2c.c | 21 +- drivers/misc/fsl_pmic.c | 45 +++- drivers/net/fec_mxc.c | 2 +- drivers/net/fec_mxc.h | 4 +- drivers/serial/serial_mxc.c | 6 + include/configs/mx51evk.h | 5 +- include/configs/mx53evk.h | 193 +++++++++++ include/configs/vision2.h | 3 +- include/mc13892.h | 5 + tools/imximage.c | 421 +++++++++++++++++++----- tools/imximage.h | 110 +++++-- 27 files changed, 1900 insertions(+), 334 deletions(-) mode change 100644 => 100755 arch/arm/cpu/armv7/mx5/iomux.c mode change 100644 => 100755 arch/arm/cpu/armv7/mx5/lowlevel_init.S mode change 100644 => 100755 arch/arm/include/asm/arch-mx5/imx-regs.h mode change 100644 => 100755 arch/arm/include/asm/arch-mx5/mx5x_pins.h create mode 100755 board/freescale/mx53evk/Makefile create mode 100755 board/freescale/mx53evk/config.mk create mode 100644 board/freescale/mx53evk/imximage.cfg create mode 100755 board/freescale/mx53evk/mx53evk.c mode change 100644 => 100755 drivers/i2c/mxc_i2c.c mode change 100644 => 100755 include/configs/mx51evk.h create mode 100755 include/configs/mx53evk.h
Le 13/01/2011 07:40, Stefano Babic a écrit :
Hi Wolfgang,
I think I should be the one doing the pull as the ARM custodian. I'll be doing it this evening.
Amicalement,
Sorry, of course you are right, I forget to readdress my pull-request after you became the ARM custodian ;-).
Stefano
Hi Wolfgang,
Applied to u-boot-arm/master, thanks.
Amicalement,
Dear Stefano Babic,
In message 4D2E9E54.6040704@denx.de you wrote:
Hi Wolfgang,
Is this really you working base? Then you should probably rebase against current master first.
Please sends your pull request to the Albert, ARM custodian.
Yes, I do it.
Sorry, for the inconvenience. Albert has already saw I sent the pull request to the wrong person and has pulled to u-boot-arm. I will be more careful next time before sending the pull request.
Best regards, Stefano Babic
Albert ARIBAUD
Stefano Babic
