[U-Boot] [PATCH 1/2] SECURE_BOOT: Define CONFIG_SYS_LS_PPA_ESBC_ADDR for LS2080A
Add header address for PPA to be validated during ESBC phase for LS2080A platform based on Layescape Chasis 3.
Signed-off-by: Sumit Garg sumit.garg@nxp.com Signed-off-by: Udit Agarwal udit.agarwal@nxp.com --- arch/arm/include/asm/fsl_secure_boot.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/fsl_secure_boot.h b/arch/arm/include/asm/fsl_secure_boot.h index f920215..27cf096 100644 --- a/arch/arm/include/asm/fsl_secure_boot.h +++ b/arch/arm/include/asm/fsl_secure_boot.h @@ -125,6 +125,8 @@ #ifdef CONFIG_SYS_LS_PPA_FW_IN_XIP #ifdef CONFIG_LS1043A #define CONFIG_SYS_LS_PPA_ESBC_ADDR 0x600c0000 +#elif defined(CONFIG_FSL_LSCH3) +#define CONFIG_SYS_LS_PPA_ESBC_ADDR 0x580c40000 #endif #else #error "No CONFIG_SYS_LS_PPA_FW_IN_xxx defined"
Moves sec_init to board_init rather than in misc_init function beacuse PPA will be initialised in board_init function and for PPA validation sec_init has to be done prior to PPA init.
Signed-off-by: Sumit Garg sumit.garg@nxp.com Signed-off-by: Udit Agarwal udit.agarwal@nxp.com --- board/freescale/ls2080aqds/ls2080aqds.c | 6 +++--- board/freescale/ls2080ardb/ls2080ardb.c | 6 +++--- 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/board/freescale/ls2080aqds/ls2080aqds.c b/board/freescale/ls2080aqds/ls2080aqds.c index 73a61fd..d9d0bea 100644 --- a/board/freescale/ls2080aqds/ls2080aqds.c +++ b/board/freescale/ls2080aqds/ls2080aqds.c @@ -223,6 +223,9 @@ int board_init(void) #endif select_i2c_ch_pca9547(I2C_MUX_CH_DEFAULT); rtc_enable_32khz_output(); +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif
return 0; } @@ -264,9 +267,6 @@ int dram_init(void) #if defined(CONFIG_ARCH_MISC_INIT) int arch_misc_init(void) { -#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif return 0; } #endif diff --git a/board/freescale/ls2080ardb/ls2080ardb.c b/board/freescale/ls2080ardb/ls2080ardb.c index 02954ef..b0024d3 100644 --- a/board/freescale/ls2080ardb/ls2080ardb.c +++ b/board/freescale/ls2080ardb/ls2080ardb.c @@ -184,6 +184,9 @@ int board_init(void) /* invert AQR405 IRQ pins polarity */ out_le32(irq_ccsr + IRQCR_OFFSET / 4, AQR405_IRQ_MASK); #endif +#ifdef CONFIG_FSL_CAAM + sec_init(); +#endif
return 0; } @@ -237,9 +240,6 @@ int dram_init(void) #if defined(CONFIG_ARCH_MISC_INIT) int arch_misc_init(void) { -#ifdef CONFIG_FSL_CAAM - sec_init(); -#endif return 0; } #endif
sec_init();
Use tab instead of space in the future. I will fix this one for you.
- sec_init();
sec_init();
Same here.
York
Applied to fsl-qoriq master, awaiting upstream.
Thanks.
York
Thanks.
York
Udit Agarwal
york sun
