[U-Boot] [PATCH] mx6: Add board mx6memcal for use in validating DDR
This is a virtual "board" that uses configuration files and Kconfig to define the memory layout used by a real board during the board bring-up process.
It generates an SPL image that can be loaded using imx_usb or SB_LOADER.exe.
When run, it will generate a set of calibration constants for use in either or both a DCD configuration file for boards that use u-boot.imx or struct mx6_mmdc_calibration for boards that boot via SPL.
In essence, it is a configurable, open-source variant of the Freescale ddr-stress tool.
https://community.nxp.com/docs/DOC-105652
File mx6memcal_defconfig configures the board for use with mx6sabresd or mx6qsabreauto.
Signed-off-by: Eric Nelson eric@nelint.com Signed-off-by: Fabio Estevam fabio.estevam@nxp.com --- This is an attempt to bring Eric's useful patch to life: https://lists.denx.de/pipermail/u-boot/2016-November/271597.html
Changes since RFC: - Rebased against latest U-Boot - Removed get_imx_type() as it does not build with SPL (to be added lates). - Include patch 2/9 into this one: https://lists.denx.de/pipermail/u-boot/2016-November/271596.html ,otherwise mmdc_do_dqs_calibration() always fail on my tests with mx6qsabresd - Fixed some Coding Style issues to make checkpatch happier
arch/arm/mach-imx/mx6/Kconfig | 9 + board/freescale/mx6memcal/Kconfig | 235 ++++++++++++++++++ board/freescale/mx6memcal/MAINTAINERS | 7 + board/freescale/mx6memcal/Makefile | 13 + board/freescale/mx6memcal/README | 49 ++++ board/freescale/mx6memcal/mx6memcal.c | 32 +++ board/freescale/mx6memcal/spl.c | 456 ++++++++++++++++++++++++++++++++++ configs/mx6memcal_defconfig | 33 +++ include/configs/mx6memcal.h | 59 +++++ scripts/config_whitelist.txt | 1 + 10 files changed, 894 insertions(+) create mode 100644 board/freescale/mx6memcal/Kconfig create mode 100644 board/freescale/mx6memcal/MAINTAINERS create mode 100644 board/freescale/mx6memcal/Makefile create mode 100644 board/freescale/mx6memcal/README create mode 100644 board/freescale/mx6memcal/mx6memcal.c create mode 100644 board/freescale/mx6memcal/spl.c create mode 100644 configs/mx6memcal_defconfig create mode 100644 include/configs/mx6memcal.h
diff --git a/arch/arm/mach-imx/mx6/Kconfig b/arch/arm/mach-imx/mx6/Kconfig index bee7eab..89bf1ae 100644 --- a/arch/arm/mach-imx/mx6/Kconfig +++ b/arch/arm/mach-imx/mx6/Kconfig @@ -202,6 +202,14 @@ config TARGET_MX6LOGICPD select DM_REGULATOR select OF_CONTROL
+config TARGET_MX6MEMCAL + bool "mx6memcal" + select SUPPORT_SPL + help + The mx6memcal board is a virtual board that can be used to validate + and characterize the memory layout of a new design during the initial + development and pre-production stages. + config TARGET_MX6QARM2 bool "mx6qarm2"
@@ -441,6 +449,7 @@ source "board/embest/mx6boards/Kconfig" source "board/engicam/imx6q/Kconfig" source "board/engicam/imx6ul/Kconfig" source "board/freescale/mx6qarm2/Kconfig" +source "board/freescale/mx6memcal/Kconfig" source "board/freescale/mx6sabreauto/Kconfig" source "board/freescale/mx6sabresd/Kconfig" source "board/freescale/mx6slevk/Kconfig" diff --git a/board/freescale/mx6memcal/Kconfig b/board/freescale/mx6memcal/Kconfig new file mode 100644 index 0000000..443804d --- /dev/null +++ b/board/freescale/mx6memcal/Kconfig @@ -0,0 +1,235 @@ +if TARGET_MX6MEMCAL + +config SYS_BOARD + default "mx6memcal" + +config SYS_VENDOR + default "freescale" + +config SYS_CONFIG_NAME + default "mx6memcal" + +menu "mx6memcal specifics" +choice + prompt "Serial console" + help + Either UART1 or UART2 will be used as the console for + displaying the calibration values or errors. + +config SERIAL_CONSOLE_UART1 + bool "UART1" + help + Select this if your board uses UART1 for its' console. + +config SERIAL_CONSOLE_UART2 + bool "UART2" + help + Select this if your board uses UART2 for its' console. + +endchoice + +choice + prompt "UART pads" + help + Select the RX and TX pads used for your serial console. + The choices below reflect the most commonly used options + for your UART. + + config UART2_EIM_D26_27 + bool "UART2 on EIM_D26/27 (SabreLite, Nitrogen6x)" + depends on SERIAL_CONSOLE_UART2 + help + Choose this configuration if you're using pads + EIM_D26 and D27 for a console on UART2. + This is typical for designs that are based on the + NXP SABRELite. + + config UART1_CSI0_DAT10_11 + bool "UART1 on CSI0_DAT10/11 (Wand)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + CSI0_DAT10 and DAT11 for a console on UART1 as + is done on the i.MX6 Wand board. + + config UART1_SD3_DAT6_7 + bool "UART1 on SD3_DAT6/7 (SabreSD, SabreAuto)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + SD3_DAT6 and DAT7 for a console on UART1 as is + done on the NXP SABRESD or SABREAUTO designs. + + config UART1_UART1 + bool "UART1 on UART1 (i.MX6SL EVK, WaRP)" + depends on SERIAL_CONSOLE_UART1 + help + Choose this configuration if you're using pads + UART1_TXD/RXD for a console on UART1 as is done + on most i.MX6SL designs. + +endchoice + +config IMXIMAGE_OUTPUT + bool "Include output for imximage .cfg files" + default y + help + Say "Y" if you want output formatted for use in non-SPL + (DCD-style) configuration files. + +config DDRWIDTH + int "DDR bus width" + default 64 + help + Select either 32 or 64 to reflect the DDR bus width. + +config DDRCS + int "DDR chip selects" + default 2 + range 1 2 + help + Select the number of chip selects used in your board design + +choice + prompt "Memory type" + help + Select the type of DDR (DDR3 or LPDDR2) used on your design + +config DDR3 + bool "DDR3" + help + Select this if your board design uses DDR3. + +config LPDDR2 + bool "LPDDR2" + help + Select this if your board design uses LPDDR2. + +endchoice + +choice + prompt "Memory device" + +config MT41K512M16TNA + bool "Micron MT41K512M16TNA 512Mx16 (1GiB/chip)" + depends on DDR3 + +config MT41K128M16JT + bool "Micron MT41K128M16JT 128Mx16 (256 MiB/chip)" + depends on DDR3 + +config H5TQ4G63AFR + bool "Hynix H5TQ4G63AFR 256Mx16 (512 MiB/chip)" + depends on DDR3 + +config H5TQ2G63DFR + bool "Hynix H5TQ2G63DFR 128Mx16 (256 MiB/chip)" + depends on DDR3 + +config MT42L256M32D2LG + bool "Micron MT42L256M32D2LG LPDDR2 256Mx32 (1GiB/chip)" + depends on LPDDR2 + +config MT29PZZZ4D4BKESK + bool "Micron MT29PZZZ4D4BKESK multi-chip 512MiB LPDDR2/4GiB eMMC" + depends on LPDDR2 + +endchoice + +config DDR_ODT + int "DDR On-die-termination" + default 2 + range 0 7 + help + Enter the on-die termination value as an index defined for + IOMUX settings for PAD_DRAM_SDCLK0_P and others. + 0 == Disabled + 1 == 120 Ohm + 2 == 60 Ohm + 3 == 40 Ohm + 4 == 30 Ohm + 5 == 24 Ohm + 6 == 20 Ohm + 7 == 17 Ohm + Value will be applied to all clock and data lines + + +config DRAM_DRIVE_STRENGTH + int "DRAM Drive strength" + default 6 + range 0 7 + help + Enter drive strength as an index defined for IOMUX settings + for GRP_B1DS and others. + 0 == Hi Z + 6 == 40 Ohm (default) + 7 == 34 Ohm + Value will be applied to all clock and data lines + +config RTT_NOM + int "RTT_NOM" + default 1 + range 1 2 + help + Enter the RTT_NOM selector + 1 == RZQ/4 (60ohm) + 2 == RZQ/2 (120ohm) + +config RTT_WR + int "RTT_WR" + default 1 + range 0 2 + help + Enter the RTT_WR selector for MR2 + 0 == Dynamic ODT disabled + 1 == RZQ/4 (60ohm) + 2 == RZQ/2 (120ohm) + +config RALAT + int "Read additional latency" + default 5 + range 0 7 + help + Enter a latency in number of cycles. This will be added to + CAS and internal delays for which the MMDC will retrieve the + read data from the internal FIFO. + This is used to compensate for board/chip delays. + +config WALAT + int "Write additional latency" + default 0 + range 0 7 + help + Enter a latency in number of cycles. This will be added to + CAS and internal delays for which the MMDC will retrieve the + read data from the internal FIFO + This is used to compensate for board/chip delays. + +config REFSEL + int "Refresh period" + range 0 3 + default 1 + help + Select the DDR refresh period. + See the description of bitfield REF_SEL in the reference manual + for details. + 0 == disabled + 1 == 32 kHz + 2 == 64 kHz + 3 == fast counter + +config REFR + int "Number of refreshes" + range 0 7 + default 7 + help + This selects the number of refreshes (-1) during each period. + i.e.: + 0 == 1 refresh (tRFC) + 7 == 8 refreshes (tRFC*8) + See the description of MDREF[REFR] in the reference manual for + details. + +endmenu +endif + diff --git a/board/freescale/mx6memcal/MAINTAINERS b/board/freescale/mx6memcal/MAINTAINERS new file mode 100644 index 0000000..5da38f7 --- /dev/null +++ b/board/freescale/mx6memcal/MAINTAINERS @@ -0,0 +1,7 @@ +MX6MEMCAL BOARD +M: Eric Nelson eric@nelint.com +S: Maintained +F: board/freescale/mx6memcal/ +F: include/configs/mx6memcal.h +F: configs/mx6memcal_defconfig + diff --git a/board/freescale/mx6memcal/Makefile b/board/freescale/mx6memcal/Makefile new file mode 100644 index 0000000..2d7a6fa --- /dev/null +++ b/board/freescale/mx6memcal/Makefile @@ -0,0 +1,13 @@ +# +# Copyright (C) 2007, Guennadi Liakhovetski lg@denx.de +# +# (C) Copyright 2011 Freescale Semiconductor, Inc. +# +# SPDX-License-Identifier: GPL-2.0+ +# + +ifdef CONFIG_SPL_BUILD +obj-y := spl.o +else +obj-y := mx6memcal.o +endif diff --git a/board/freescale/mx6memcal/README b/board/freescale/mx6memcal/README new file mode 100644 index 0000000..9fe2fe2 --- /dev/null +++ b/board/freescale/mx6memcal/README @@ -0,0 +1,49 @@ +mx6memcal - a tool for calibrating DDR on i.MX6 boards. + +The mx6memcal board isn't a real board, but a tool for use in bring-up of +new i.MX6 board designs. + +It provides a similar function to the tool from NXP([1]) with a number +of advantages: + +1. It's open-source, so it's easier to change if needed. + Typical reasons for needing to change include the use of alternate + UARTs and PMIC initialization. +2. It produces an image that's directly loadable with imx_usb [2] or + SB_LOADER.exe [3]. + The NXP tool requires either a cumbersome JTAG connection that + makes running the DDR very slow or a working U-Boot image that + suffers from a chicken-and-egg problem (i.e. where do you get the + DDR parameters for U-Boot?). +3. It doesn't prompt for parameters, so it's much faster to gather + data from multiple boards. +4. Parameters to the calibration process can be chosen through + 'make menuconfig'. + +When booted, the mx6memcal board will run the DDR calibration +routines and display the result in a form suitable for cut and +paste into struct mx6_mmdc_calibration. It can also optionally +produce output in a form usable in a DCD-style .cfg file. + +Selections in Kconfig allow most system design settings to be chosen: + +1. The UART number and pad configuration for the UART. Options + include support for the most frequent reference designs on + i.MX6DQ/SDL (SABRE Lite and SABRESD designs). +2. The memory bus width (64 and 32-bit) +3. The number of chip-selects in use +4. The type of DDR (DDR3 or LPDDR2). Note that LPDDR2 support + is incomplete as of this writing. +5. The type of DDR chips in use. This selection allows re-use of common + parts and four DDR3 and two LPDDR2 parts are currently defined +6. The On-die termination value for the DRAM lines +7. The DRAM drive strength +8. The RTT_NOM and RTT_WR termination settings +9. RALAT/WALAT latency values + +References: +[1] - NXP DDR Stress Test Tool - https://community.nxp.com/docs/DOC-105652 +[2] - Boundary Devices imx_usb_loader + https://github.com/boundarydevices/imx_usb_loader +[3] - Use of SB_Loader.exe + https://boundarydevices.com/windows-users-and-unbricking diff --git a/board/freescale/mx6memcal/mx6memcal.c b/board/freescale/mx6memcal/mx6memcal.c new file mode 100644 index 0000000..afea0fb --- /dev/null +++ b/board/freescale/mx6memcal/mx6memcal.c @@ -0,0 +1,32 @@ +/* + * mx6memcal board support - provides a minimal, UART-only + * U-Boot that's capable of running a memory test. + * + * Copyright (C) 2016 Nelson Integration, LLC + * Author: Eric Nelson eric@nelint.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/arch/sys_proto.h> + +DECLARE_GLOBAL_DATA_PTR; + +int board_init(void) +{ + return 0; +} + +int checkboard(void) +{ + puts("Board: mx6memcal\n"); + return 0; +} + +int dram_init(void) +{ + gd->ram_size = imx_ddr_size(); + return 0; +} + diff --git a/board/freescale/mx6memcal/spl.c b/board/freescale/mx6memcal/spl.c new file mode 100644 index 0000000..9c19e9c --- /dev/null +++ b/board/freescale/mx6memcal/spl.c @@ -0,0 +1,456 @@ +/* + * Copyright (C) 2016 Nelson Integration, LLC + * Author: Eric Nelson eric@nelint.com + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#include <common.h> +#include <asm/io.h> +#include <asm/arch/iomux.h> +#include <asm/arch/clock.h> +#include <asm/arch/crm_regs.h> +#include <asm/arch/mx6-ddr.h> +#include <asm/arch/mx6-pins.h> +#include <asm/arch/sys_proto.h> +#include <spl.h> + +DECLARE_GLOBAL_DATA_PTR; + +#define UART_PAD_CTRL (PAD_CTL_PUS_100K_UP | \ + PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \ + PAD_CTL_SRE_FAST | PAD_CTL_HYS) + +static iomux_v3_cfg_t const uart_pads[] = { +#ifdef CONFIG_UART2_EIM_D26_27 + IOMUX_PADS(PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_CSI0_DAT10_11) + IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_SD3_DAT6_7) + IOMUX_PADS(PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), + IOMUX_PADS(PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)), +#elif defined(CONFIG_UART1_UART1) + MX6_PAD_UART1_TXD__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL), + MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL), +#else +#error select UART console pads +#endif +}; + +#ifdef CONFIG_DDR3 +#define GRP_DDRTYPE 0x000C0000 +#else +#define GRP_DDRTYPE 0x00080000 +#endif + +/* all existing designs have this disabled */ +#define DDR_PKE 0 + +/* use Kconfig for ODT and DRIVE_STRENGTH */ +#define DDR_ODT \ + (CONFIG_DDR_ODT << 8) +#define DRAM_DRIVE_STRENGTH \ + (CONFIG_DRAM_DRIVE_STRENGTH << 3) + +/* configure MX6Q/DUAL mmdc DDR io registers */ +static struct mx6dq_iomux_ddr_regs const mx6dq_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_sdclk_1 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_cas = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_ras = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_reset = DDR_ODT + DRAM_DRIVE_STRENGTH, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003000 + DRAM_DRIVE_STRENGTH, + .dram_sdodt1 = 0x00003000 + DRAM_DRIVE_STRENGTH, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_sdqs4 = DRAM_DRIVE_STRENGTH, + .dram_sdqs5 = DRAM_DRIVE_STRENGTH, + .dram_sdqs6 = DRAM_DRIVE_STRENGTH, + .dram_sdqs7 = DRAM_DRIVE_STRENGTH, + + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm4 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm5 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm6 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm7 = DDR_ODT + DRAM_DRIVE_STRENGTH, +}; + +/* configure MX6Q/DUAL mmdc GRP io registers */ +static struct mx6dq_iomux_grp_regs const mx6dq_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = GRP_DDRTYPE, + .grp_ddrmode_ctl = DDR_ODT, + /* disable DDR pullups */ + .grp_ddrpke = DDR_PKE, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = DRAM_DRIVE_STRENGTH, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = DRAM_DRIVE_STRENGTH, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = DDR_ODT, + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_b4ds = DRAM_DRIVE_STRENGTH, + .grp_b5ds = DRAM_DRIVE_STRENGTH, + .grp_b6ds = DRAM_DRIVE_STRENGTH, + .grp_b7ds = DRAM_DRIVE_STRENGTH, +}; + +static struct mx6sdl_iomux_ddr_regs const mx6sdl_ddr_ioregs = { + /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */ + .dram_sdclk_0 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_sdclk_1 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_cas = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_ras = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_reset = DDR_ODT + DRAM_DRIVE_STRENGTH, + /* SDCKE[0:1]: 100k pull-up */ + .dram_sdcke0 = 0x00003000, + .dram_sdcke1 = 0x00003000, + /* SDBA2: pull-up disabled */ + .dram_sdba2 = 0x00000000, + /* SDODT[0:1]: 100k pull-up, 40 ohm */ + .dram_sdodt0 = 0x00003000 + DRAM_DRIVE_STRENGTH, + .dram_sdodt1 = 0x00003000 + DRAM_DRIVE_STRENGTH, + /* SDQS[0:7]: Differential input, 40 ohm */ + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_sdqs4 = DRAM_DRIVE_STRENGTH, + .dram_sdqs5 = DRAM_DRIVE_STRENGTH, + .dram_sdqs6 = DRAM_DRIVE_STRENGTH, + .dram_sdqs7 = DRAM_DRIVE_STRENGTH, + + /* DQM[0:7]: Differential input, 40 ohm */ + .dram_dqm0 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm4 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm5 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm6 = DDR_ODT + DRAM_DRIVE_STRENGTH, + .dram_dqm7 = DDR_ODT + DRAM_DRIVE_STRENGTH, +}; + +/* configure MX6SOLO/DUALLITE mmdc GRP io registers */ +static struct mx6sdl_iomux_grp_regs const mx6sdl_grp_ioregs = { + /* DDR3 */ + .grp_ddr_type = GRP_DDRTYPE, + /* SDQS[0:7]: Differential input, 40 ohm */ + .grp_ddrmode_ctl = DDR_ODT, + /* disable DDR pullups */ + .grp_ddrpke = DDR_PKE, + /* ADDR[00:16], SDBA[0:1]: 40 ohm */ + .grp_addds = DRAM_DRIVE_STRENGTH, + /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */ + .grp_ctlds = DRAM_DRIVE_STRENGTH, + /* DATA[00:63]: Differential input, 40 ohm */ + .grp_ddrmode = DDR_ODT, + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_b4ds = DRAM_DRIVE_STRENGTH, + .grp_b5ds = DRAM_DRIVE_STRENGTH, + .grp_b6ds = DRAM_DRIVE_STRENGTH, + .grp_b7ds = DRAM_DRIVE_STRENGTH, +}; + +const struct mx6sl_iomux_ddr_regs mx6sl_ddr_ioregs = { + .dram_sdqs0 = DRAM_DRIVE_STRENGTH, + .dram_sdqs1 = DRAM_DRIVE_STRENGTH, + .dram_sdqs2 = DRAM_DRIVE_STRENGTH, + .dram_sdqs3 = DRAM_DRIVE_STRENGTH, + .dram_dqm0 = DRAM_DRIVE_STRENGTH, + .dram_dqm1 = DRAM_DRIVE_STRENGTH, + .dram_dqm2 = DRAM_DRIVE_STRENGTH, + .dram_dqm3 = DRAM_DRIVE_STRENGTH, + .dram_cas = DRAM_DRIVE_STRENGTH, + .dram_ras = DRAM_DRIVE_STRENGTH, + .dram_sdclk_0 = DRAM_DRIVE_STRENGTH, + .dram_reset = DRAM_DRIVE_STRENGTH, + .dram_sdba2 = 0x00020000, + .dram_odt0 = 0x00030000 + DRAM_DRIVE_STRENGTH, + .dram_odt1 = 0x00030000 + DRAM_DRIVE_STRENGTH, +}; + +const struct mx6sl_iomux_grp_regs mx6sl_grp_ioregs = { + .grp_b0ds = DRAM_DRIVE_STRENGTH, + .grp_b1ds = DRAM_DRIVE_STRENGTH, + .grp_b2ds = DRAM_DRIVE_STRENGTH, + .grp_b3ds = DRAM_DRIVE_STRENGTH, + .grp_addds = DRAM_DRIVE_STRENGTH, + .grp_ctlds = DRAM_DRIVE_STRENGTH, + .grp_ddrmode_ctl = DDR_ODT, + .grp_ddrpke = DDR_PKE, + .grp_ddrmode = DDR_ODT, + .grp_ddr_type = GRP_DDRTYPE, +}; + +static struct mx6_ddr_sysinfo const sysinfo = { + /* width of data bus:0=16,1=32,2=64 */ +#if CONFIG_DDRWIDTH == 32 + .dsize = 1, +#elif CONFIG_DDRWIDTH == 64 + .dsize = 2, +#else +#error missing CONFIG_DDRWIDTH +#endif + /* config for full 4GB range so that get_mem_size() works */ + .cs_density = 32, /* 32Gb per CS */ + + /* # of chip selects */ + .ncs = CONFIG_DDRCS, + .cs1_mirror = 0, + .bi_on = 1, /* Bank interleaving enabled */ + .rtt_nom = CONFIG_RTT_NOM, + .rtt_wr = CONFIG_RTT_WR, + .ralat = CONFIG_RALAT, /* Read additional latency */ + .walat = CONFIG_WALAT, /* Write additional latency */ + .mif3_mode = 3, /* Command prediction working mode */ +#ifdef CONFIG_DDR3 + .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */ + .sde_to_rst = 0x10, /* JEDEC value for LPDDR2 - 200us */ + .pd_fast_exit = 0, /* immaterial for calibration */ + .ddr_type = DDR_TYPE_DDR3, +#else + .rst_to_cke = 0x10, /* JEDEC value for LPDDR2: 200us */ + .sde_to_rst = 0, /* LPDDR2 does not need this field */ + .pd_fast_exit = 0, /* immaterial for calibration */ + .ddr_type = DDR_TYPE_LPDDR2, +#endif + .refsel = CONFIG_REFSEL, + .refr = CONFIG_REFR, +}; + +#ifdef CONFIG_MT41K512M16TNA +/* Micron MT41K512M16TNA-125 */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 8, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 1, + .trcd = 1375, + .trcmin = 5062, + .trasmin = 3750, +}; +#elif defined(CONFIG_MT41K128M16JT) +/* Micron MT41K128M16JT-125 */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; +#elif defined(CONFIG_H5TQ4G63AFR) +/* Hynix H5TQ4G63AFR */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1600, + .density = 4, + .width = 16, + .banks = 8, + .rowaddr = 15, + .coladdr = 10, + .pagesz = 2, + .trcd = 1375, + .trcmin = 4875, + .trasmin = 3500, +}; +#elif defined CONFIG_H5TQ2G63DFR +/* Hynix H5TQ2G63DFR */ +static struct mx6_ddr3_cfg const ddrtype = { + .mem_speed = 1333, + .density = 2, + .width = 16, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .pagesz = 2, + .trcd = 1350, + .trcmin = 4950, + .trasmin = 3600, +}; +#elif defined(CONFIG_MT42L256M32D2LG) +/* Micron MT42L256M32D2LG */ +static struct mx6_lpddr2_cfg ddrtype = { + .mem_speed = 800, + .density = 4, + .width = 32, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .trcd_lp = 2000, + .trppb_lp = 2000, + .trpab_lp = 2250, + .trasmin = 4200, +}; +#elif defined(CONFIG_MT29PZZZ4D4BKESK) +/* Micron MT29PZZZ4D4BKESK */ +static struct mx6_lpddr2_cfg ddrtype = { + .mem_speed = 800, + .density = 4, + .width = 32, + .banks = 8, + .rowaddr = 14, + .coladdr = 10, + .trcd_lp = 2000, + .trppb_lp = 2000, + .trpab_lp = 2250, + .trasmin = 4200, +}; +#else +#error please select DDR type using menuconfig +#endif + +static void ccgr_init(void) +{ + struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR; + + /* FIXME: these should probably be checked, especially + * for i.MX6SL, UL, ULL + */ + writel(0x00C03F3F, &ccm->CCGR0); + writel(0x0030FC03, &ccm->CCGR1); + writel(0x0FFFC000, &ccm->CCGR2); + writel(0x3FF00000, &ccm->CCGR3); + writel(0x00FFF300, &ccm->CCGR4); + writel(0x0F0000C3, &ccm->CCGR5); + writel(0x000003FF, &ccm->CCGR6); +} + +static void display_calibration(struct mx6_mmdc_calibration *calib) +{ + printf(".p0_mpdgctrl0\t= 0x%08X\n", calib->p0_mpdgctrl0); + printf(".p0_mpdgctrl1\t= 0x%08X\n", calib->p0_mpdgctrl1); + printf(".p0_mprddlctl\t= 0x%08X\n", calib->p0_mprddlctl); + printf(".p0_mpwrdlctl\t= 0x%08X\n", calib->p0_mpwrdlctl); + printf(".p0_mpwldectrl0\t= 0x%08X\n", calib->p0_mpwldectrl0); + printf(".p0_mpwldectrl1\t= 0x%08X\n", calib->p0_mpwldectrl1); + if (sysinfo.dsize == 2) { + printf(".p1_mpdgctrl0\t= 0x%08X\n", calib->p1_mpdgctrl0); + printf(".p1_mpdgctrl1\t= 0x%08X\n", calib->p1_mpdgctrl1); + printf(".p1_mprddlctl\t= 0x%08X\n", calib->p1_mprddlctl); + printf(".p1_mpwrdlctl\t= 0x%08X\n", calib->p1_mpwrdlctl); + printf(".p1_mpwldectrl0\t= 0x%08X\n", calib->p1_mpwldectrl0); + printf(".p1_mpwldectrl1\t= 0x%08X\n", calib->p1_mpwldectrl1); + } +#ifdef CONFIG_IMXIMAGE_OUTPUT + printf("DATA 4 MX6_MMDC_P0_MPDGCTRL0\t= 0x%08X\n", calib->p0_mpdgctrl0); + printf("DATA 4 MX6_MMDC_P0_MPDGCTRL1\t= 0x%08X\n", calib->p0_mpdgctrl1); + printf("DATA 4 MX6_MMDC_P0_MPRDDLCTL\t= 0x%08X\n", calib->p0_mprddlctl); + printf("DATA 4 MX6_MMDC_P0_MPWRDLCTL\t= 0x%08X\n", calib->p0_mpwrdlctl); + printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL0\t= 0x%08X\n", + calib->p0_mpwldectrl0); + printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL1\t= 0x%08X\n", + calib->p0_mpwldectrl1); + if (sysinfo.dsize == 2) { + printf("DATA 4 MX6_MMDC_P1_MPDGCTRL0\t= 0x%08X\n", + calib->p1_mpdgctrl0); + printf("DATA 4 MX6_MMDC_P1_MPDGCTRL1\t= 0x%08X\n", + calib->p1_mpdgctrl1); + printf("DATA 4 MX6_MMDC_P1_MPRDDLCTL\t= 0x%08X\n", + calib->p1_mprddlctl); + printf("DATA 4 MX6_MMDC_P1_MPWRDLCTL\t= 0x%08X\n", + calib->p1_mpwrdlctl); + printf("DATA 4 MX6_MMDC_P1_MPWLDECTRL0\t= 0x%08X\n", + calib->p1_mpwldectrl0); + printf("DATA 4 MX6_MMDC_P1_MPWLDECTRL1\t= 0x%08X\n", + calib->p1_mpwldectrl1); + } +#endif +} + +/* + * called from C runtime startup code (arch/arm/lib/crt0.S:_main) + * - we have a stack and a place to store GD, both in SRAM + * - no variable global data is available + */ +void board_init_f(ulong dummy) +{ + int errs; + struct mx6_mmdc_calibration calibration = {0}; + + memset((void *)gd, 0, sizeof(struct global_data)); + + /* write leveling calibration defaults */ + calibration.p0_mpwrdlctl = 0x40404040; + calibration.p1_mpwrdlctl = 0x40404040; + + /* setup AIPS and disable watchdog */ + arch_cpu_init(); + + ccgr_init(); + + SETUP_IOMUX_PADS(uart_pads); + + /* setup GP timer */ + timer_init(); + + /* UART clocks enabled and gd valid - init serial console */ + preloader_console_init(); + + if (sysinfo.dsize != 1) { + if (is_cpu_type(MXC_CPU_MX6SX) || + is_cpu_type(MXC_CPU_MX6UL) || + is_cpu_type(MXC_CPU_MX6SL)) { + printf("cpu type 0x%x doesn't support 64-bit bus\n", + get_cpu_type()); + reset_cpu(0); + } + } +#ifdef CONFIG_MX6SL + mx6sl_dram_iocfg(CONFIG_DDRWIDTH, &mx6sl_ddr_ioregs, + &mx6sl_grp_ioregs); +#else + if (is_cpu_type(MXC_CPU_MX6Q)) { + mx6dq_dram_iocfg(CONFIG_DDRWIDTH, &mx6dq_ddr_ioregs, + &mx6dq_grp_ioregs); + } else { + mx6sdl_dram_iocfg(CONFIG_DDRWIDTH, &mx6sdl_ddr_ioregs, + &mx6sdl_grp_ioregs); + } +#endif + mx6_dram_cfg(&sysinfo, &calibration, &ddrtype); + + errs = mmdc_do_write_level_calibration(&sysinfo); + if (errs) { + printf("error %d from write level calibration\n", errs); + } else { + errs = mmdc_do_dqs_calibration(&sysinfo); + if (errs) { + printf("error %d from write level calibration\n", errs); + } else { + printf("completed successfully\n"); + mmdc_read_calibration(&sysinfo, &calibration); + display_calibration(&calibration); + } + } + reset_cpu(0); +} diff --git a/configs/mx6memcal_defconfig b/configs/mx6memcal_defconfig new file mode 100644 index 0000000..9a3bb83 --- /dev/null +++ b/configs/mx6memcal_defconfig @@ -0,0 +1,33 @@ +CONFIG_ARM=y +CONFIG_ARCH_MX6=y +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_MX6_DDRCAL=y +CONFIG_TARGET_MX6MEMCAL=y +CONFIG_SPL_SERIAL_SUPPORT=y +CONFIG_SPL_WATCHDOG_SUPPORT=y +CONFIG_SYS_EXTRA_OPTIONS="IMX_CONFIG=arch/arm/mach-imx/spl_sd.cfg,SPL,MX6QDL" +CONFIG_SPL=y +CONFIG_HUSH_PARSER=y +# CONFIG_MMC is not set +# CONFIG_CMD_BOOTD is not set +# CONFIG_CMD_BOOTM is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_IMLS is not set +# CONFIG_CMD_XIMG is not set +# CONFIG_CMD_EXPORTENV is not set +# CONFIG_CMD_IMPORTENV is not set +# CONFIG_CMD_EDITENV is not set +# CONFIG_CMD_SAVEENV is not set +# CONFIG_CMD_ENV_EXISTS is not set +CONFIG_CMD_MEMTEST=y +CONFIG_CMD_MEMINFO=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +# CONFIG_CMD_FLASH is not set +# CONFIG_CMD_FPGA is not set +# CONFIG_CMD_NET is not set +# CONFIG_CMD_NFS is not set +CONFIG_CMD_CACHE=y +CONFIG_REGEX=y diff --git a/include/configs/mx6memcal.h b/include/configs/mx6memcal.h new file mode 100644 index 0000000..f5238a5 --- /dev/null +++ b/include/configs/mx6memcal.h @@ -0,0 +1,59 @@ +/* + * Copyright (C) 2010-2011 Freescale Semiconductor, Inc. + * + * Configuration settings for the Boundary Devices Nitrogen6X + * and Freescale i.MX6Q Sabre Lite boards. + * + * SPDX-License-Identifier: GPL-2.0+ + */ + +#ifndef __CONFIG_H +#define __CONFIG_H + +/* SPL */ + +#include "mx6_common.h" +#include "imx6_spl.h" + +#undef CONFIG_FSL_ESDHC +#undef CONFIG_MMC +#undef CONFIG_SPL_MMC_SUPPORT +#undef CONFIG_GENERIC_MMC +#undef CONFIG_CMD_FUSE + +#define CONFIG_SYS_MEMTEST_START 0x10000000 +#define CONFIG_SYS_MEMTEST_END 0x20000000 +#define CONFIG_SYS_MALLOC_LEN (64 * 1024 * 1024) + +#define CONFIG_MXC_UART +#ifdef CONFIG_SERIAL_CONSOLE_UART1 +#if defined(CONFIG_MX6SL) +#define CONFIG_MXC_UART_BASE UART1_IPS_BASE_ADDR +#else +#define CONFIG_MXC_UART_BASE UART1_BASE +#endif +#elif defined(CONFIG_SERIAL_CONSOLE_UART2) +#define CONFIG_MXC_UART_BASE UART2_BASE +#else +#error please define serial console (CONFIG_SERIAL_CONSOLE_UARTx) +#endif +#define CONFIG_BAUDRATE 115200 + +#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE + 16) + +/* Physical Memory Map */ +#define CONFIG_NR_DRAM_BANKS 1 +#define PHYS_SDRAM MMDC0_ARB_BASE_ADDR + +#define CONFIG_SYS_SDRAM_BASE PHYS_SDRAM +#define CONFIG_SYS_INIT_RAM_ADDR IRAM_BASE_ADDR +#define CONFIG_SYS_INIT_RAM_SIZE IRAM_SIZE + +#define CONFIG_SYS_INIT_SP_OFFSET \ + (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE) +#define CONFIG_SYS_INIT_SP_ADDR \ + (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET) + +#define CONFIG_ENV_SIZE (8 * 1024) + +#endif /* __CONFIG_H */ diff --git a/scripts/config_whitelist.txt b/scripts/config_whitelist.txt index d5ae1f4..3732f5e 100644 --- a/scripts/config_whitelist.txt +++ b/scripts/config_whitelist.txt @@ -372,6 +372,7 @@ CONFIG_DB_784MP_GP CONFIG_DCACHE CONFIG_DCACHE_OFF CONFIG_DCFG_ADDR +CONFIG_DDR3 CONFIG_DDR_ CONFIG_DDR_2HCLK CONFIG_DDR_2T_TIMING
Hi Fabio, Eric,
first of all, many thanks for this patch ! A full FOSS tool to replace the proprietary ddr-stress is what we are missing from the beginning of i.MX6.
Best regards, Stefano
Changes since RFC:
- bool "mx6memcal"
- select SUPPORT_SPL
- help
+config SYS_BOARD
- default "mx6memcal"
+config SYS_VENDOR
- default "freescale"
- prompt "Serial console"
- help
- bool "UART1"
- help
- bool "UART2"
- help
+endchoice
+choice
- prompt "UART pads"
- help
for your UART.
- config UART2_EIM_D26_27
help
NXP SABRELite.
- config UART1_CSI0_DAT10_11
help
- config UART1_SD3_DAT6_7
help
- config UART1_UART1
help
+endchoice
- bool "Include output for imximage .cfg files"
- default y
- help
+config DDRWIDTH
- int "DDR bus width"
- default 64
- help
+config DDRCS
- int "DDR chip selects"
- default 2
- range 1 2
- help
+choice
- prompt "Memory type"
- help
+config DDR3
- bool "DDR3"
- help
+config LPDDR2
- bool "LPDDR2"
- help
+endchoice
+choice
- prompt "Memory device"
- bool "Micron MT41K512M16TNA 512Mx16 (1GiB/chip)"
- depends on DDR3
- bool "Micron MT41K128M16JT 128Mx16 (256 MiB/chip)"
- depends on DDR3
+config H5TQ4G63AFR
- bool "Hynix H5TQ4G63AFR 256Mx16 (512 MiB/chip)"
- depends on DDR3
+config H5TQ2G63DFR
- bool "Hynix H5TQ2G63DFR 128Mx16 (256 MiB/chip)"
- depends on DDR3
- bool "Micron MT42L256M32D2LG LPDDR2 256Mx32 (1GiB/chip)"
- depends on LPDDR2
- bool "Micron MT29PZZZ4D4BKESK multi-chip 512MiB LPDDR2/4GiB eMMC"
- depends on LPDDR2
+endchoice
+config DDR_ODT
- int "DDR On-die-termination"
- default 2
- range 0 7
- help
0 == Disabled
1 == 120 Ohm
2 == 60 Ohm
3 == 40 Ohm
4 == 30 Ohm
5 == 24 Ohm
6 == 20 Ohm
7 == 17 Ohm
- int "DRAM Drive strength"
- default 6
- range 0 7
- help
0 == Hi Z
7 == 34 Ohm
+config RTT_NOM
- int "RTT_NOM"
- default 1
- range 1 2
- help
1 == RZQ/4 (60ohm)
2 == RZQ/2 (120ohm)
+config RTT_WR
- int "RTT_WR"
- default 1
- range 0 2
- help
1 == RZQ/4 (60ohm)
2 == RZQ/2 (120ohm)
+config RALAT
- int "Read additional latency"
- default 5
- range 0 7
- help
+config WALAT
- int "Write additional latency"
- default 0
- range 0 7
- help
+config REFSEL
- int "Refresh period"
- range 0 3
- default 1
- help
for details.
0 == disabled
1 == 32 kHz
2 == 64 kHz
3 == fast counter
+config REFR
- int "Number of refreshes"
- range 0 7
- default 7
- help
i.e.:
details.
+endmenu +endif
- Typical reasons for needing to change include the use of alternate
- UARTs and PMIC initialization.
- SB_LOADER.exe [3].
- The NXP tool requires either a cumbersome JTAG connection that
- makes running the DDR very slow or a working U-Boot image that
- suffers from a chicken-and-egg problem (i.e. where do you get the
- DDR parameters for U-Boot?).
- data from multiple boards.
- 'make menuconfig'.
- include support for the most frequent reference designs on
- i.MX6DQ/SDL (SABRE Lite and SABRESD designs).
- is incomplete as of this writing.
- parts and four DDR3 and two LPDDR2 parts are currently defined
- mx6memcal board support - provides a minimal, UART-only
- U-Boot that's capable of running a memory test.
- Copyright (C) 2016 Nelson Integration, LLC
- Author: Eric Nelson eric@nelint.com
- puts("Board: mx6memcal\n");
- gd->ram_size = imx_ddr_size();
- PAD_CTL_SPEED_MED | PAD_CTL_DSE_40ohm | \
- PAD_CTL_SRE_FAST | PAD_CTL_HYS)
- IOMUX_PADS(PAD_EIM_D26__UART2_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_EIM_D27__UART2_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_CSI0_DAT10__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_CSI0_DAT11__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT6__UART1_RX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- IOMUX_PADS(PAD_SD3_DAT7__UART1_TX_DATA | MUX_PAD_CTRL(UART_PAD_CTRL)),
- MX6_PAD_UART1_TXD__UART1_TXD | MUX_PAD_CTRL(UART_PAD_CTRL),
- MX6_PAD_UART1_RXD__UART1_RXD | MUX_PAD_CTRL(UART_PAD_CTRL),
- (CONFIG_DDR_ODT << 8)
- (CONFIG_DRAM_DRIVE_STRENGTH << 3)
- /* SDCLK[0:1], CAS, RAS, Reset: Differential input, 40ohm */
- .dram_sdclk_0 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_sdclk_1 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_cas = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_ras = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_reset = DDR_ODT + DRAM_DRIVE_STRENGTH,
- /* SDCKE[0:1]: 100k pull-up */
- .dram_sdcke0 = 0x00003000,
- .dram_sdcke1 = 0x00003000,
- /* SDBA2: pull-up disabled */
- .dram_sdba2 = 0x00000000,
- /* SDODT[0:1]: 100k pull-up, 40 ohm */
- .dram_sdodt0 = 0x00003000 + DRAM_DRIVE_STRENGTH,
- .dram_sdodt1 = 0x00003000 + DRAM_DRIVE_STRENGTH,
- /* SDQS[0:7]: Differential input, 40 ohm */
- .dram_sdqs0 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs1 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs2 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs3 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs4 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs5 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs6 = DRAM_DRIVE_STRENGTH,
- .dram_sdqs7 = DRAM_DRIVE_STRENGTH,
- /* DQM[0:7]: Differential input, 40 ohm */
- .dram_dqm0 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm1 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm2 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm3 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm4 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm5 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm6 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- .dram_dqm7 = DDR_ODT + DRAM_DRIVE_STRENGTH,
- /* DDR3 */
- .grp_ddr_type = GRP_DDRTYPE,
- .grp_ddrmode_ctl = DDR_ODT,
- /* disable DDR pullups */
- .grp_ddrpke = DDR_PKE,
- /* ADDR[00:16], SDBA[0:1]: 40 ohm */
- .grp_addds = DRAM_DRIVE_STRENGTH,
- /* CS0/CS1/SDBA2/CKE0/CKE1/SDWE: 40 ohm */
- .grp_ctlds = DRAM_DRIVE_STRENGTH,
- /* DATA[00:63]: Differential input, 40 ohm */
- .grp_ddrmode = DDR_ODT,
- .grp_b0ds = DRAM_DRIVE_STRENGTH,
- .grp_b1ds = DRAM_DRIVE_STRENGTH,
- .grp_b2ds = DRAM_DRIVE_STRENGTH,
- .grp_b3ds = DRAM_DRIVE_STRENGTH,
- .grp_b4ds = DRAM_DRIVE_STRENGTH,
- .grp_b5ds = DRAM_DRIVE_STRENGTH,
- .grp_b6ds = DRAM_DRIVE_STRENGTH,
- .grp_b7ds = DRAM_DRIVE_STRENGTH,
- /* DDR3 */
- .dram_dqm0 = DRAM_DRIVE_STRENGTH,
- .dram_dqm1 = DRAM_DRIVE_STRENGTH,
- .dram_dqm2 = DRAM_DRIVE_STRENGTH,
- .dram_dqm3 = DRAM_DRIVE_STRENGTH,
- .dram_cas = DRAM_DRIVE_STRENGTH,
- .dram_ras = DRAM_DRIVE_STRENGTH,
- .dram_sdclk_0 = DRAM_DRIVE_STRENGTH,
- .dram_reset = DRAM_DRIVE_STRENGTH,
- .dram_sdba2 = 0x00020000,
- .dram_odt0 = 0x00030000 + DRAM_DRIVE_STRENGTH,
- .dram_odt1 = 0x00030000 + DRAM_DRIVE_STRENGTH,
- /* width of data bus:0=16,1=32,2=64 */
- .dsize = 1,
- .dsize = 2,
- /* config for full 4GB range so that get_mem_size() works */
- .cs_density = 32, /* 32Gb per CS */
- /* # of chip selects */
- .ncs = CONFIG_DDRCS,
- .cs1_mirror = 0,
- .bi_on = 1, /* Bank interleaving enabled */
- .rtt_nom = CONFIG_RTT_NOM,
- .rtt_wr = CONFIG_RTT_WR,
- .ralat = CONFIG_RALAT, /* Read additional latency */
- .walat = CONFIG_WALAT, /* Write additional latency */
- .mif3_mode = 3, /* Command prediction working mode */
+#ifdef CONFIG_DDR3
- .rst_to_cke = 0x23, /* 33 cycles, 500us (JEDEC default) */
- .sde_to_rst = 0x10, /* JEDEC value for LPDDR2 - 200us */
- .pd_fast_exit = 0, /* immaterial for calibration */
- .ddr_type = DDR_TYPE_DDR3,
+#else
- .rst_to_cke = 0x10, /* JEDEC value for LPDDR2: 200us */
- .sde_to_rst = 0, /* LPDDR2 does not need this field */
- .ddr_type = DDR_TYPE_LPDDR2,
- .refsel = CONFIG_REFSEL,
- .refr = CONFIG_REFR,
- .mem_speed = 1600,
- .density = 8,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 1,
- .trcd = 1375,
- .trcmin = 5062,
- .trasmin = 3750,
- .density = 2,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- .density = 4,
- .width = 16,
- .banks = 8,
- .rowaddr = 15,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1375,
- .trcmin = 4875,
- .trasmin = 3500,
- .mem_speed = 1333,
- .density = 2,
- .width = 16,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .pagesz = 2,
- .trcd = 1350,
- .trcmin = 4950,
- .trasmin = 3600,
- .mem_speed = 800,
- .density = 4,
- .width = 32,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .trcd_lp = 2000,
- .trppb_lp = 2000,
- .trpab_lp = 2250,
- .trasmin = 4200,
- .mem_speed = 800,
- .density = 4,
- .width = 32,
- .banks = 8,
- .rowaddr = 14,
- .coladdr = 10,
- .trcd_lp = 2000,
- .trppb_lp = 2000,
- .trpab_lp = 2250,
- .trasmin = 4200,
- struct mxc_ccm_reg *ccm = (struct mxc_ccm_reg *)CCM_BASE_ADDR;
- /* FIXME: these should probably be checked, especially
- writel(0x00C03F3F, &ccm->CCGR0);
- writel(0x0030FC03, &ccm->CCGR1);
- writel(0x0FFFC000, &ccm->CCGR2);
- writel(0x3FF00000, &ccm->CCGR3);
- writel(0x00FFF300, &ccm->CCGR4);
- writel(0x0F0000C3, &ccm->CCGR5);
- writel(0x000003FF, &ccm->CCGR6);
- printf(".p0_mpdgctrl0\t= 0x%08X\n", calib->p0_mpdgctrl0);
- printf(".p0_mpdgctrl1\t= 0x%08X\n", calib->p0_mpdgctrl1);
- printf(".p0_mprddlctl\t= 0x%08X\n", calib->p0_mprddlctl);
- printf(".p0_mpwrdlctl\t= 0x%08X\n", calib->p0_mpwrdlctl);
- printf(".p0_mpwldectrl0\t= 0x%08X\n", calib->p0_mpwldectrl0);
- printf(".p0_mpwldectrl1\t= 0x%08X\n", calib->p0_mpwldectrl1);
- if (sysinfo.dsize == 2) {
- printf("DATA 4 MX6_MMDC_P0_MPDGCTRL0\t= 0x%08X\n", calib->p0_mpdgctrl0);
- printf("DATA 4 MX6_MMDC_P0_MPDGCTRL1\t= 0x%08X\n", calib->p0_mpdgctrl1);
- printf("DATA 4 MX6_MMDC_P0_MPRDDLCTL\t= 0x%08X\n", calib->p0_mprddlctl);
- printf("DATA 4 MX6_MMDC_P0_MPWRDLCTL\t= 0x%08X\n", calib->p0_mpwrdlctl);
- printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL0\t= 0x%08X\n",
- printf("DATA 4 MX6_MMDC_P0_MPWLDECTRL1\t= 0x%08X\n",
+#endif +}
- called from C runtime startup code (arch/arm/lib/crt0.S:_main)
- int errs;
- struct mx6_mmdc_calibration calibration = {0};
- memset((void *)gd, 0, sizeof(struct global_data));
- /* write leveling calibration defaults */
- calibration.p0_mpwrdlctl = 0x40404040;
- calibration.p1_mpwrdlctl = 0x40404040;
- /* setup AIPS and disable watchdog */
- arch_cpu_init();
- ccgr_init();
- SETUP_IOMUX_PADS(uart_pads);
- /* setup GP timer */
- timer_init();
- /* UART clocks enabled and gd valid - init serial console */
- preloader_console_init();
- if (sysinfo.dsize != 1) {
get_cpu_type());
reset_cpu(0);
- mx6sl_dram_iocfg(CONFIG_DDRWIDTH, &mx6sl_ddr_ioregs,
&mx6sl_grp_ioregs);
+#else
- if (is_cpu_type(MXC_CPU_MX6Q)) {
&mx6dq_grp_ioregs);
- } else {
- mx6_dram_cfg(&sysinfo, &calibration, &ddrtype);
- errs = mmdc_do_write_level_calibration(&sysinfo);
- if (errs) {
- } else {
if (errs) {
} else {
- reset_cpu(0);
- Copyright (C) 2010-2011 Freescale Semiconductor, Inc.
- Configuration settings for the Boundary Devices Nitrogen6X
- and Freescale i.MX6Q Sabre Lite boards.
+/* SPL */
- (CONFIG_SYS_INIT_RAM_SIZE - GENERATED_GBL_DATA_SIZE)
- (CONFIG_SYS_INIT_RAM_ADDR + CONFIG_SYS_INIT_SP_OFFSET)
Fabio Estevam
Stefano Babic
