[U-Boot] [RFC] SPDX License text updates
Hey all,
In another thread Felix Brack brought up that as of version 3.0 of SPDX, there's a number of deprecated tags (see https://spdx.org/licenses/) and that we're using at least one of them.
Specifically, "GPL-2.0+" should be "GPL-2.0-or-later".
Now, we have a few options here: - Deprecated isn't removed. SPDX specifically says the old links shall remain valid, etc, etc. We could continue to use "GPL-2.0+", etc and not have to change (literally) 8000 files. This will also keep us in line with what the Linux kernel currently does. I also have no idea, nor have I looked to see if that's going to change. - Allow both old and new. Both are valid, the newer form allows for easier tooling and more precise management of options that I'm not sure apply to our use cases. - Switch to the new tags. A few hour I imagine of playing around with sed and then manual fixups and I can probably convert all the existing cases to the new syntax (we have some DTS files for example with (GPL-2.0+ OR MIT) which would become (GPL-2.0-or-later OR MIT). But then we need some tooling to make checkpatch.pl at least noisy about unconverted and to get everyone into the habit of changing and so forth.
At this point in time I'm leaning towards the first, and as is often the case, watching what the kernel does. Thoughts / comments? Thanks!
Dear Tom,
OK...
Both sound not really attractive to me.
Umm... where do you expect problems? Running for example
fgrep -hR GPL-2.0+ * | sort -u | less
gives a realtively short list which looks harmless to me.
Yes, and why do you think this would be a problem?
We have a few other places that don't match current SPDX spcification, like all these
GPL-2.0+ BSD-2-Clause GPL-2.0+ BSD-3-Clause GPL-2.0+ or X11 GPL-2.0+ X11 |____GPL-2.0+
but these cases are few and easy to spot. I currentlse see neither the need for "few hour of playing around with sed" nor the need for manual fxes - a plain string substitution should work just fine, and we could even clean up the other inconsistencies whil we are at it.
I vote for 3 plus additional cleanup.
On Mon, Jan 22, 2018 at 08:44:27PM +0100, Wolfgang Denk wrote:
Dear Tom,
OK...
Note we also need go convert "GPL-2.0" (and LGPL-...), but yes, that's only going to add a tiny bit more work.
This is the second time today I've not spoken clearly enough, sorry. Yes, the sed side of correcting "GPL-2.0+", "GPL-2.0" and the LGPL instances as well to take a minute, and perhaps another hour, hopefully no more than 2 to correct the multi-license things to follow the license expression format and update Licenses/README. I don't think that the above effort is a problem.
What I do see as at least a minor burden moving forward is catching new files with an SPDX tag of the old variety. Whacking checkpatch.pl to catch that will make sure I don't miss them (since I am running checkpatch.pl every time now). I see https://patchwork.kernel.org/patch/10053699/ exists, and it's easy enough to extend that to catch old-style GPL-2.0/GPL2.0+/LGPL-2.0+/.. and warn about that.
Noted, thanks!
On Mon, 22 Jan 2018 12:06:07 -0500 Tom Rini trini@konsulko.com wrote:
Hey all,
+1
Lukasz Majewski
DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-10 Fax: (+49)-8142-66989-80 Email: wd@denx.de
Lukasz Majewski
