[U-Boot] [PATCH v2] armv8/ls1043a: Implement workaround for erratum A009660
Memory controller performance is not optimal with default internal target queue register value, write required value for optimal DDR performance.
Signed-off-by: Mingkai Hu mingkai.hu@nxp.com --- v2: - Add a check to make sure A009660 and A008514 is are not both enabled. - Add comment for the offset of eddrtqcr1.
arch/arm/cpu/armv8/fsl-layerscape/soc.c | 15 +++++++++++++++ arch/arm/include/asm/arch-fsl-layerscape/config.h | 5 +++++ 2 files changed, 20 insertions(+)
diff --git a/arch/arm/cpu/armv8/fsl-layerscape/soc.c b/arch/arm/cpu/armv8/fsl-layerscape/soc.c index 7ff0148..8b01fd2 100644 --- a/arch/arm/cpu/armv8/fsl-layerscape/soc.c +++ b/arch/arm/cpu/armv8/fsl-layerscape/soc.c @@ -213,6 +213,20 @@ static void erratum_a009929(void) #endif }
+/* + * This erratum requires setting a value to eddrtqcr1 to optimal + * the DDR performance. The eddrtqcr1 register is in SCFG space + * of LS1043A and the offset is 0x157_020c. + */ +static void erratum_a009660(void) +{ +#if defined(CONFIG_SYS_FSL_ERRATUM_A009660) \ + && !defined(CONFIG_SYS_FSL_ERRATUM_A008514) + u32 *eddrtqcr1 = (void *)CONFIG_SYS_FSL_SCFG_ADDR + 0x20c; + out_be32(eddrtqcr1, 0x63b20042); +#endif +} + void fsl_lsch2_early_init_f(void) { struct ccsr_cci400 *cci = (struct ccsr_cci400 *)CONFIG_SYS_CCI400_ADDR; @@ -238,6 +252,7 @@ void fsl_lsch2_early_init_f(void)
/* Erratum */ erratum_a009929(); + erratum_a009660(); } #endif
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/config.h b/arch/arm/include/asm/arch-fsl-layerscape/config.h index f1b164f..854ed0b 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/config.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/config.h @@ -171,6 +171,11 @@
#define CONFIG_SYS_FSL_ERRATUM_A009663 #define CONFIG_SYS_FSL_ERRATUM_A009929 +#define CONFIG_SYS_FSL_ERRATUM_A009660 +#if defined(CONFIG_SYS_FSL_ERRATUM_A009660) \ + && defined(CONFIG_SYS_FSL_ERRATUM_A008514) +#error "A009660 and A008514 are both enabed for LS1043A, please check it." +#endif #else #error SoC not defined #endif
v2:
- This erratum requires setting a value to eddrtqcr1 to optimal
- the DDR performance. The eddrtqcr1 register is in SCFG space
- of LS1043A and the offset is 0x157_020c.
- && !defined(CONFIG_SYS_FSL_ERRATUM_A008514)
- u32 *eddrtqcr1 = (void *)CONFIG_SYS_FSL_SCFG_ADDR + 0x20c;
- out_be32(eddrtqcr1, 0x63b20042);
+#endif +}
- erratum_a009660();
} #endif
- && defined(CONFIG_SYS_FSL_ERRATUM_A008514)
This is a wrong location to check macros. It should be in soc.c. The point is to avoid errors in future/customer boards, where two macros might be both enabled by mistake.
York
Mingkai Hu
york sun
