[U-Boot-Users] [MIPS] Extend MIPS_MAX_CACHE_SIZE upto 64kB
Signed-off-by: Shinya Kuribayashi skuribay@ruby.dti.ne.jp ---
cpu/mips/cache.S | 9 +++++---- 1 files changed, 5 insertions(+), 4 deletions(-)
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index bda9bb1..2998a3b 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -32,10 +32,11 @@
#define RA t8
- /* 16KB is the maximum size of instruction and data caches on - * MIPS 4K. - */ -#define MIPS_MAX_CACHE_SIZE 0x4000 +/* + * 16kB is the maximum size of instruction and data caches on MIPS 4K, + * 64kB is on 4KE, 24K, 5K, 34K, etc. Set bigger size for convenience. + */ +#define MIPS_MAX_CACHE_SIZE 0x10000
#define INDEX_BASE KSEG0
#define RA t8
* MIPS 4K.
- 16kB is the maximum size of instruction and data caches on MIPS 4K,
- 64kB is on 4KE, 24K, 5K, 34K, etc. Set bigger size for convenience.
Revised patch is attached.
- add some comments on L2 cache, - and cache.S is no longer 4K specific routines now!
cpu/mips/cache.S | 14 +++++++++----- 1 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/cpu/mips/cache.S b/cpu/mips/cache.S index e6f3175..89ada71 100644 --- a/cpu/mips/cache.S +++ b/cpu/mips/cache.S @@ -1,5 +1,5 @@ /* - * Cache-handling routined for MIPS 4K CPUs + * Cache-handling routined for MIPS CPUs * * Copyright (c) 2003 Wolfgang Denk wd@denx.de * @@ -32,10 +32,14 @@
#define RA t8
- /* 16KB is the maximum size of instruction and data caches on - * MIPS 4K. - */ -#define MIPS_MAX_CACHE_SIZE 0x4000 +/* + * 16kB is the maximum size of instruction and data caches on MIPS 4K, + * 64kB is on 4KE, 24K, 5K, etc. Set bigger size for convenience. + * + * Note that the above size is the maximum size of primary cache. U-Boot + * doesn't have L2 cache support for now. + */ +#define MIPS_MAX_CACHE_SIZE 0x10000
Shinya Kuribayashi
