[U-Boot] [PATCH v4 4/5] i2c: lpc32xx: add support for OTG I2C
Updated the LPC32xx I2C driver to support the OTG I2C that is part of the USB module.
Signed-off-by: Sylvain Lemieux slemieux@tycoint.com --- Changes from v3 to v4: * No changes.
Changes from v2 to v3: * New patch added in v3.
drivers/i2c/lpc32xx_i2c.c | 20 +++++++++++++++++--- 1 file changed, 17 insertions(+), 3 deletions(-)
diff --git a/drivers/i2c/lpc32xx_i2c.c b/drivers/i2c/lpc32xx_i2c.c index 98106fa..be166b0 100644 --- a/drivers/i2c/lpc32xx_i2c.c +++ b/drivers/i2c/lpc32xx_i2c.c @@ -1,7 +1,7 @@ /* * LPC32xx I2C interface driver * - * (C) Copyright 2014 DENX Software Engineering GmbH + * (C) Copyright 2014-2015 DENX Software Engineering GmbH * Written-by: Albert ARIBAUD - 3ADEV albert.aribaud@3adev.fr * * SPDX-License-Identifier: GPL-2.0+ @@ -60,7 +60,8 @@ struct lpc32xx_i2c_registers {
static struct lpc32xx_i2c_registers *lpc32xx_i2c[] = { (struct lpc32xx_i2c_registers *)I2C1_BASE, - (struct lpc32xx_i2c_registers *)I2C2_BASE + (struct lpc32xx_i2c_registers *)I2C2_BASE, + (struct lpc32xx_i2c_registers *)(USB_BASE + 0x300) };
/* Set I2C bus speed */ @@ -68,11 +69,17 @@ static unsigned int lpc32xx_i2c_set_bus_speed(struct i2c_adapter *adap, unsigned int speed) { int half_period; + int clk_rate;
if (speed == 0) return -EINVAL;
- half_period = (get_hclk_clk_rate() / speed) / 2; + if (adap->hwadapnr == 2) + /* OTG I2C clock source is different. */ + clk_rate = get_periph_clk_rate(); + else + clk_rate = get_hclk_clk_rate(); + half_period = (clk_rate / speed) / 2;
if ((half_period > 255) || (half_period < 0)) return -EINVAL; @@ -247,3 +254,10 @@ U_BOOT_I2C_ADAP_COMPLETE(lpc32xx_1, _i2c_init, lpc32xx_i2c_probe, CONFIG_SYS_I2C_LPC32XX_SPEED, CONFIG_SYS_I2C_LPC32XX_SLAVE, 1) + +U_BOOT_I2C_ADAP_COMPLETE(lpc32xx_2, _i2c_init, NULL, + lpc32xx_i2c_read, lpc32xx_i2c_write, + lpc32xx_i2c_set_bus_speed, + 100000, + 0, + 2)
Acked-by: Marek Vasut marex@denx.de
Best regards, Marek Vasut
Signed-off-by: Sylvain Lemieux slemieux@tycoint.com Acked-by: Marek Vasut marex@denx.de
