[U-Boot] [PATCH] board/t1040qds: Add sgmii ports support in 0xA7 protocol
T1042QDS (T1042 is T1040 Personality without L2 switch) supports following sgmii interfaces with serdes protocol 0xA7 -SGMII-MAC3 on Lane B - slot 7 -SGMII-MAC5 on Lane H - slot 7 -SGMII2.5G-MAC1 on Lane C - slot 6 -SGMII2.5G-MAC2 on Lane D - slot 5
Add support of above sgmii interfaces
Signed-off-by: Priyanka Jain Priyanka.Jain@freescale.com --- board/freescale/t1040qds/eth.c | 4 ++++ drivers/net/fm/t1040.c | 2 -- 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/board/freescale/t1040qds/eth.c b/board/freescale/t1040qds/eth.c index 1929bba..06d9086 100644 --- a/board/freescale/t1040qds/eth.c +++ b/board/freescale/t1040qds/eth.c @@ -241,6 +241,8 @@ static void initialize_lane_to_slot(void) break; case 0xA7: lane_to_slot[1] = 7; + lane_to_slot[2] = 6; + lane_to_slot[3] = 5; lane_to_slot[7] = 7; break; case 0xAA: @@ -410,6 +412,8 @@ void t1040_handle_phy_interface_sgmii(int i) fm_info_set_phy_address(i, riser_phy_addr[1]); if (FM1_DTSEC3 == i) fm_info_set_phy_address(i, riser_phy_addr[2]); + if (FM1_DTSEC5 == i) + fm_info_set_phy_address(i, riser_phy_addr[3]);
mdio_mux[i] = EMI1_SLOT7; fm_info_set_mdio(i, mii_dev_for_muxval(mdio_mux[i])); diff --git a/drivers/net/fm/t1040.c b/drivers/net/fm/t1040.c index bcc871d..4cce46d 100644 --- a/drivers/net/fm/t1040.c +++ b/drivers/net/fm/t1040.c @@ -49,8 +49,6 @@ phy_interface_t fman_port_enet_if(enum fm_port port) else if ((rcwsr13 & FSL_CORENET_RCWSR13_EC2) == FSL_CORENET_RCWSR13_EC2_FM1_DTSEC5_MII) return PHY_INTERFACE_MODE_MII; - else - return PHY_INTERFACE_MODE_NONE; }
switch (port) {
Applied to u-boot-mpc85xx, awaiting upstream.
York
Priyanka Jain
York Sun
