[U-Boot-Users] unable to mount root
hi,all
when mount root there throws a exception,can anyone help me?
thanks,
best regards,
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
TFTP from server 10.0.0.155; our IP address is 10.0.0.110
Filename 'uimage.bin'.
Load address: 0x30007fc0
Loading: #################################################################
done
Bytes transferred = 723556 (b0a64 hex)
## Booting image at 30007fc0 ...
Image Name: linux kerne
Created: 2006-06-08 21:45:38 UTC
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 723492 Bytes = 706.5 kB
Load Address: 30007fc0
Entry Point: 30008000
Verifying Checksum ... OK
XIP Kernel Image ... OK
## Loading Ramdisk Image at 00030000 ...
Image Name: init ramdisk
Created: 2006-06-20 7:15:26 UTC
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 1269760 Bytes = 1.2 MB
Load Address: 00000000
Entry Point: 00000000
Starting kernel ...
Uncompressing Linux...................................................... done,.
Linux version 2.4.18-rmk7-pxa1 (Huangrx@huangrx) (gcc version 2.95.3 20010315 (5
CPU: ARM/CIRRUS Arm920Tsid(wb) revision 0
Machine: Embest S3CEB2410 (S3C2410x)
On node 0 totalpages: 16384
zone(0): 16384 pages.
zone(1): 0 pages.
zone(2): 0 pages.
Kernel command line: initrd=0x30800000,0x200000 root=/dev/mtdblock/2 init=/linu0
DEBUG: timer count 15626
Console: colour dummy device 80x30
Calibrating delay loop... 99.94 BogoMIPS
Memory: 64MB = 64MB total
Memory: 62664KB available (1416K code, 310K data, 76K init)
Dentry-cache hash table entries: 8192 (order: 4, 65536 bytes)
Inode-cache hash table entries: 4096 (order: 3, 32768 bytes)
Mount-cache hash table entries: 1024 (order: 1, 8192 bytes)
Buffer-cache hash table entries: 4096 (order: 2, 16384 bytes)
Page-cache hash table entries: 16384 (order: 4, 65536 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
CPU clock = 200.000 Mhz, HCLK = 100.000 Mhz, PCLK = 50.000 Mhz
Initializing S3C2410 buffer pool for DMA workaround
Starting kswapd
devfs: v1.10 (20020120) Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
ttyS%d0 at I/O 0x50000000 (irq = 52) is a S3C2410
ttyS%d1 at I/O 0x50004000 (irq = 55) is a S3C2410
ttyS%d2 at I/O 0x50008000 (irq = 58) is a S3C2410
Console: switching to colour frame buffer device 80x60
Installed S3C2410 frame buffer
pty: 256 Unix98 ptys configured
s3c2410-ts initialized
S3C2410 Real Time Clock Driver v0.1
block: 128 slots per queue, batch=32
eth0: cs8900 rev K(3.3 Volts) found at 0xd0000300
cs89x0 media RJ-45, IRQ 37
loop: loaded (max 8 devices)
SCSI subsystem driver Revision: 1.00
request_module[scsi_hostadapter]: Root fs not mounted
NAND device: Manufacture ID: 0xec, Chip ID: 0x76 (Samsung K9D1208V0M)
bon0: 00000000-00030000 (00030000) 00000000
bon1: 00030000-00100000 (000d0000) 00000000
bon2: 00100000-03ff8000 (03ef8000) 00000000
usb.c: registered new driver usbdevfs
usb.c: registered new driver hub
usb-ohci.c: USB OHCI at membase 0xe9000000, IRQ 26
usb.c: new USB bus registered, assigned bus number 1
hub.c: USB hub found
port #1 suspened!
port #0 alived!
hub.c: 1 port detected
usb.c: registered new driver usb_mouse
usbmouse.c: v1.6:USB HID Boot Protocol mouse driver
usb.c: registered new driver keyboard
usbkbd.c: :USB HID Boot Protocol keyboard driver
Initializing USB Mass Storage driver...
usb.c: registered new driver usb-storage
USB Mass Storage support registered.
mice: PS/2 mouse device common for all mice
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP, IGMP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 4096 bind 4096)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
NetWinder Floating Point Emulator V0.95 (c) 1998-1999 Rebel.com
cramfs: wrong magic
FAT: bogus logical sector size 25322
Kernel panic: VFS: Unable to mount root fs on 1f:00
On 6/20/06, cpjzjut cpjzjut@163.com wrote:
hi,all when mount root there throws a exception,can anyone help me?
(off topic for the u-boot list; this is a Linux problem. You really should ask on the arm linux mailing list)
Technically it's a kernel panic (the kernel doesn't know what it should do, so it stops). It cannot mount the root filesystem image that you've given it. Throwing an exception is something else.
What format are you using for your initrd? ext2? Do you have the filesystem configured into your kernel?
Cheers, g.
As mentioned before, this is off topic here.
A few comments anyway:
Uou boot with a ramdisk image...
Image Name: init ramdisk Created: 2006-06-20 7:15:26 UTC Image Type: ARM Linux RAMDisk Image (uncompressed) Data Size: 1269760 Bytes = 1.2 MB
For an uncompressed image the size if very small. Are you sure this is OK?
This kernel version is extremely old. You will not find much support for it any more.
You boot with a ramdisk, but put the root file system on a MTD device? Strange.
The "/dev/mtdblock/2" suggests that you are attemptiong to use devfs. IMHO not a good idea.
Also, the "init=/linu0" is strange.
ttyS%d0 at I/O 0x50000000 (irq = 52) is a S3C2410 ttyS%d1 at I/O 0x50004000 (irq = 55) is a S3C2410 ttyS%d2 at I/O 0x50008000 (irq = 58) is a S3C2410
Your kernel seems to have a bug when printing the serial port names.
cramfs: wrong magic FAT: bogus logical sector size 25322 Kernel panic: VFS: Unable to mount root fs on 1f:00
Are you sure there is actually a root file system in your MTD partition?
--Boundary-=_ELFRGmRbeaYKlQHgUhIykzBuuTGc Content-Type: text/html; charset="gb2312" Content-Transfer-Encoding: quoted-printable
<div>hi,all<br>
Please never post HTML here!
cpjzjut
Grant Likely
