[U-Boot-Users] Error in erasing the nand flash
19 May
2005
19 May
'05
5:49 a.m.
HI, I m using the u-boot for my arm926-ejs processor based board.And I m using the 32MB NAND flash of STMicroelectronics on my board.When I use the "nand erase" command to erase the content of the NAND flash I observe that during the erasing if u-boot is unable to erase one of the block ( the error is genrated by uboot "Error erasing at " )it immidiatly comes out of the while loop and do not try to erase further blocks(Reffering to nand_erase function of the u-boot/common/cmd_nand.c file).Isn't u-boot should mark this block as badblock (Because u-boot is getting error in erasing the block) and instead of going out of the while loop it should try to erase the futher blocks.Please provide ur feedback.
Regards Pankaj
7293
Pankaj GOYAL
