[PATCH] arm64: zynqmp: Add MTD partition handling for dfu_alt_info generation
Generate dfu_alt_info generation based on information from MTD partitions. mtd_found_part() is trying to identify MTD partition which code is running from. If partitions are not defined and location is not found it is going to previous behavior.
Signed-off-by: Michal Simek michal.simek@amd.com ---
board/xilinx/zynqmp/zynqmp.c | 52 +++++++++++++++++++++++++++++++----- 1 file changed, 45 insertions(+), 7 deletions(-)
diff --git a/board/xilinx/zynqmp/zynqmp.c b/board/xilinx/zynqmp/zynqmp.c index ba49eb7be229..eee89284de9d 100644 --- a/board/xilinx/zynqmp/zynqmp.c +++ b/board/xilinx/zynqmp/zynqmp.c @@ -626,6 +626,31 @@ enum env_location env_get_location(enum env_operation op, int prio)
#define DFU_ALT_BUF_LEN SZ_1K
+static void mtd_found_part(u32 *base, u32 *size) +{ + struct mtd_info *part, *mtd; + + mtd_probe_devices(); + + mtd = get_mtd_device_nm("nor0"); + if (!IS_ERR_OR_NULL(mtd)) { + list_for_each_entry(part, &mtd->partitions, node) { + debug("0x%012llx-0x%012llx : "%s"\n", + part->offset, part->offset + part->size, + part->name); + + if (*base >= part->offset && + *base < part->offset + part->size) { + debug("Found my partition: %d/%s\n", + part->index, part->name); + *base = part->offset; + *size = part->size; + break; + } + } + } +} + void set_dfu_alt_info(char *interface, char *devstr) { int multiboot, bootseq = 0, len = 0; @@ -667,15 +692,28 @@ void set_dfu_alt_info(char *interface, char *devstr) break; case QSPI_MODE_24BIT: case QSPI_MODE_32BIT: - len += snprintf(buf + len, DFU_ALT_BUF_LEN, - "sf 0:0=boot.bin raw %x 0x1500000", - multiboot * SZ_32K); + { + u32 base = multiboot * SZ_32K; + u32 size = 0x1500000; + u32 limit = size; + + mtd_found_part(&base, &limit); + +#if defined(CONFIG_SYS_SPI_U_BOOT_OFFS) + size = limit; + limit = CONFIG_SYS_SPI_U_BOOT_OFFS; +#endif + + len += snprintf(buf + len, DFU_ALT_BUF_LEN, + "sf 0:0=boot.bin raw 0x%x 0x%x", + base, limit); #if defined(CONFIG_SPL_FS_LOAD_PAYLOAD_NAME) && defined(CONFIG_SYS_SPI_U_BOOT_OFFS) - len += snprintf(buf + len, DFU_ALT_BUF_LEN, - ";%s raw 0x%x 0x500000", - CONFIG_SPL_FS_LOAD_PAYLOAD_NAME, - multiboot * SZ_32K + CONFIG_SYS_SPI_U_BOOT_OFFS); + len += snprintf(buf + len, DFU_ALT_BUF_LEN, + ";%s raw 0x%x 0x%x", + CONFIG_SPL_FS_LOAD_PAYLOAD_NAME, + base + limit, size - limit); #endif + } break; default: return;
- struct mtd_info *part, *mtd;
- mtd_probe_devices();
- mtd = get_mtd_device_nm("nor0");
- if (!IS_ERR_OR_NULL(mtd)) {
debug("0x%012llx-0x%012llx : \"%s\"\n",
part->name);
*size = part->size;
break;
- void set_dfu_alt_info(char *interface, char *devstr) { int multiboot, bootseq = 0, len = 0;
u32 limit = size;
size = limit;
#if defined(CONFIG_SPL_FS_LOAD_PAYLOAD_NAME) && defined(CONFIG_SYS_SPI_U_BOOT_OFFS)base, limit);
#endifbase + limit, size - limit);
break; default: return;}
Based on discussion here https://lore.kernel.org/all/561f9d0ee96ebb6cd674042f269f280ab68fbbac.1708705...
I will send updated version of this patch.
M
Michal Simek
