[PATCH v2 3/4] NSA310S : Use Ethernet PHY name from device tree
In DM Ethernet, the old "egiga0" name is no longer valid, so replace it with Ethernet PHY name from device tree.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
Changes in v2: - Correct copyright
board/zyxel/nsa310s/nsa310s.c | 19 ++++++++----------- 1 file changed, 8 insertions(+), 11 deletions(-)
diff --git a/board/zyxel/nsa310s/nsa310s.c b/board/zyxel/nsa310s/nsa310s.c index cd4a7723b1..41479af8e6 100644 --- a/board/zyxel/nsa310s/nsa310s.c +++ b/board/zyxel/nsa310s/nsa310s.c @@ -1,8 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* - * Copyright (C) 2015 - * Gerald Kerma dreagle@doukki.net - * Tony Dinh mibodhi@gmail.com + * Copyright (C) 2015, 2021 Tony Dinh mibodhi@gmail.com + * Copyright (C) 2015 Gerald Kerma dreagle@doukki.net */
#include <common.h> @@ -81,22 +80,18 @@ int board_init(void) return 0; }
+#define PHY_ADR 1 + #ifdef CONFIG_RESET_PHY_R void reset_phy(void) { u16 reg; - u16 phyaddr; - char *name = "egiga0"; + u16 phyaddr = PHY_ADR; + char *name = "ethernet-controller@72000";
if (miiphy_set_current_dev(name)) return;
- /* read PHY dev address */ - if (miiphy_read(name, 0xee, 0xee, (u16 *) &phyaddr)) { - printf("could not read PHY dev address\n"); - return; - } - /* set RGMII delay */ miiphy_write(name, phyaddr, MV88E1318_PGADR_REG, MV88E1318_MAC_CTRL_PG); miiphy_read(name, phyaddr, MV88E1318_MAC_CTRL_REG, ®); @@ -131,5 +126,7 @@ void reset_phy(void) /* downshift */ miiphy_write(name, phyaddr, 0x10, 0x3860); miiphy_write(name, phyaddr, 0x0, 0x9140); + + printf("MV88E1318 PHY initialized on %s\n", name); } #endif /* CONFIG_RESET_PHY_R */
Enable DM SATA, removed IDE driver, and add SATA MV driver.
include/configs/nsa310s.h | 10 +++++----- 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/include/configs/nsa310s.h b/include/configs/nsa310s.h index e38c65a485..23cf94ec99 100644 --- a/include/configs/nsa310s.h +++ b/include/configs/nsa310s.h @@ -1,8 +1,8 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* + * Copyright (C) 2015, 2021 Tony Dinh mibodhi@gmail.com * Copyright (C) 2015 * Gerald Kerma dreagle@doukki.net - * Tony Dinh mibodhi@gmail.com * Luka Perkov luka.perkov@sartura.hr */
@@ -46,10 +46,10 @@ #endif /* CONFIG_CMD_NET */
/* SATA driver configuration */ -#ifdef CONFIG_IDE -#define __io -#define CONFIG_SYS_ATA_IDE0_OFFSET MV_SATA_PORT0_OFFSET -#endif /* CONFIG_IDE */ +#ifdef CONFIG_SATA +#define CONFIG_SYS_SATA_MAX_DEVICE 1 +#define CONFIG_LBA48 +#endif /* CONFIG_SATA */
/* RTC driver configuration */ #ifdef CONFIG_CMD_DATE
Changes in v2:
Correct copyright
- Copyright (C) 2015
- Gerald Kerma dreagle@doukki.net
- Tony Dinh mibodhi@gmail.com
- Copyright (C) 2015, 2021 Tony Dinh mibodhi@gmail.com
- Copyright (C) 2015 Gerald Kerma dreagle@doukki.net
#include <common.h>
+#define PHY_ADR 1
Please read the PHY address from the DT instead. It's encoded in the "reg" property and should be able to read it from there. No need to double define this value here again.
Thanks, Stefan
- u16 phyaddr;
return;
- printf("MV88E1318 PHY initialized on %s\n", name); } #endif /* CONFIG_RESET_PHY_R */
Viele Grüße, Stefan
Stefan Roese
Tony Dinh
