[U-Boot-Users] [PATCH] usb: codying style cleanup
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com --- common/cmd_usb.c | 261 ++++++++++++++++++++----------------- common/usb.c | 385 ++++++++++++++++++++++++++++-------------------------- common/usb_kbd.c | 317 +++++++++++++++++++++++---------------------- 3 files changed, 506 insertions(+), 457 deletions(-)
diff --git a/common/cmd_usb.c b/common/cmd_usb.c index 23413b5..b7d3d14 100644 --- a/common/cmd_usb.c +++ b/common/cmd_usb.c @@ -32,7 +32,7 @@ #include <usb.h>
#ifdef CONFIG_USB_STORAGE -static int usb_stor_curr_dev=-1; /* current device */ +static int usb_stor_curr_dev = -1; /* current device */ #endif
/* some display routines (info command) */ @@ -62,7 +62,7 @@ char * usb_get_class_desc(unsigned char dclass) } }
-void usb_display_class_sub(unsigned char dclass,unsigned char subclass,unsigned char proto) +void usb_display_class_sub(unsigned char dclass, unsigned char subclass, unsigned char proto) { switch(dclass) { case USB_CLASS_PER_INTERFACE: @@ -139,32 +139,41 @@ void usb_display_class_sub(unsigned char dclass,unsigned char subclass,unsigned } }
-void usb_display_string(struct usb_device *dev,int index) +void usb_display_string(struct usb_device *dev, int index) { char buffer[256]; - if (index!=0) { - if (usb_string(dev,index,&buffer[0],256)>0); - printf("String: "%s"",buffer); + + if (index != 0) { + if (usb_string(dev, index, &buffer[0], 256) > 0); + printf("String: "%s"", buffer); } }
void usb_display_desc(struct usb_device *dev) { - if (dev->descriptor.bDescriptorType==USB_DT_DEVICE) { - printf("%d: %s, USB Revision %x.%x\n",dev->devnum,usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass), - (dev->descriptor.bcdUSB>>8) & 0xff,dev->descriptor.bcdUSB & 0xff); + if (dev->descriptor.bDescriptorType == USB_DT_DEVICE) { + printf("%d: %s, USB Revision %x.%x\n", dev->devnum, + usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass), + (dev->descriptor.bcdUSB>>8) & 0xff ,dev->descriptor.bcdUSB & 0xff); if (strlen(dev->mf) || strlen(dev->prod) || strlen(dev->serial)) - printf(" - %s %s %s\n",dev->mf,dev->prod,dev->serial); + printf(" - %s %s %s\n", dev->mf, dev->prod, dev->serial); if (dev->descriptor.bDeviceClass) { printf(" - Class: "); - usb_display_class_sub(dev->descriptor.bDeviceClass,dev->descriptor.bDeviceSubClass,dev->descriptor.bDeviceProtocol); + usb_display_class_sub(dev->descriptor.bDeviceClass, + dev->descriptor.bDeviceSubClass, + dev->descriptor.bDeviceProtocol); printf("\n"); } else { - printf(" - Class: (from Interface) %s\n",usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass)); + printf(" - Class: (from Interface) %s\n", + usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass)); } - printf(" - PacketSize: %d Configurations: %d\n",dev->descriptor.bMaxPacketSize0,dev->descriptor.bNumConfigurations); - printf(" - Vendor: 0x%04x Product 0x%04x Version %d.%d\n",dev->descriptor.idVendor,dev->descriptor.idProduct,(dev->descriptor.bcdDevice>>8) & 0xff,dev->descriptor.bcdDevice & 0xff); + printf(" - PacketSize: %d Configurations: %d\n", + dev->descriptor.bMaxPacketSize0,dev->descriptor.bNumConfigurations); + printf(" - Vendor: 0x%04x Product 0x%04x Version %d.%d\n", + dev->descriptor.idVendor, dev->descriptor.idProduct, + (dev->descriptor.bcdDevice >> 8) & 0xff, + dev->descriptor.bcdDevice & 0xff); }
} @@ -172,42 +181,54 @@ void usb_display_desc(struct usb_device *dev) void usb_display_conf_desc(struct usb_config_descriptor *config,struct usb_device *dev) { printf(" Configuration: %d\n",config->bConfigurationValue); - printf(" - Interfaces: %d %s%s%dmA\n",config->bNumInterfaces,(config->bmAttributes & 0x40) ? "Self Powered " : "Bus Powered ", - (config->bmAttributes & 0x20) ? "Remote Wakeup " : "",config->MaxPower*2); + printf(" - Interfaces: %d %s%s%dmA\n", config->bNumInterfaces, + (config->bmAttributes & 0x40) ? "Self Powered " : "Bus Powered ", + (config->bmAttributes & 0x20) ? "Remote Wakeup " : "", config->MaxPower * 2); if (config->iConfiguration) { printf(" - "); - usb_display_string(dev,config->iConfiguration); + usb_display_string(dev, config->iConfiguration); printf("\n"); } }
-void usb_display_if_desc(struct usb_interface_descriptor *ifdesc,struct usb_device *dev) +void usb_display_if_desc(struct usb_interface_descriptor *ifdesc, struct usb_device *dev) { printf(" Interface: %d\n",ifdesc->bInterfaceNumber); - printf(" - Alternate Setting %d, Endpoints: %d\n",ifdesc->bAlternateSetting,ifdesc->bNumEndpoints); + printf(" - Alternate Setting %d, Endpoints: %d\n", + ifdesc->bAlternateSetting, ifdesc->bNumEndpoints); printf(" - Class "); - usb_display_class_sub(ifdesc->bInterfaceClass,ifdesc->bInterfaceSubClass,ifdesc->bInterfaceProtocol); + usb_display_class_sub(ifdesc->bInterfaceClass, ifdesc->bInterfaceSubClass, + ifdesc->bInterfaceProtocol); printf("\n"); if (ifdesc->iInterface) { printf(" - "); - usb_display_string(dev,ifdesc->iInterface); + usb_display_string(dev, ifdesc->iInterface); printf("\n"); } }
void usb_display_ep_desc(struct usb_endpoint_descriptor *epdesc) { - printf(" - Endpoint %d %s ",epdesc->bEndpointAddress & 0xf,(epdesc->bEndpointAddress & 0x80) ? "In" : "Out"); + printf(" - Endpoint %d %s ", epdesc->bEndpointAddress & 0xf, + (epdesc->bEndpointAddress & 0x80) ? "In" : "Out"); switch((epdesc->bmAttributes & 0x03)) { - case 0: printf("Control"); break; - case 1: printf("Isochronous"); break; - case 2: printf("Bulk"); break; - case 3: printf("Interrupt"); break; + case 0: + printf("Control"); + break; + case 1: + printf("Isochronous"); + break; + case 2: + printf("Bulk"); + break; + case 3: + printf("Interrupt"); + break; } - printf(" MaxPacket %d",epdesc->wMaxPacketSize); - if ((epdesc->bmAttributes & 0x03)==0x3) - printf(" Interval %dms",epdesc->bInterval); + printf(" MaxPacket %d", epdesc->wMaxPacketSize); + if ((epdesc->bmAttributes & 0x03) == 0x3) + printf(" Interval %dms", epdesc->bInterval); printf("\n"); }
@@ -217,15 +238,15 @@ void usb_display_config(struct usb_device *dev) struct usb_config_descriptor *config; struct usb_interface_descriptor *ifdesc; struct usb_endpoint_descriptor *epdesc; - int i,ii; + int i, ii;
- config= &dev->config; + config = &dev->config; usb_display_conf_desc(config,dev); - for(i=0;i<config->no_of_if;i++) { - ifdesc= &config->if_desc[i]; + for(i = 0; i < config->no_of_if; i++) { + ifdesc = &config->if_desc[i]; usb_display_if_desc(ifdesc,dev); - for(ii=0;ii<ifdesc->no_of_ep;ii++) { - epdesc= &ifdesc->ep_desc[ii]; + for(ii = 0; ii < ifdesc->no_of_ep; ii++) { + epdesc = &ifdesc->ep_desc[ii]; usb_display_ep_desc(epdesc); } } @@ -233,31 +254,31 @@ void usb_display_config(struct usb_device *dev) }
/* shows the device tree recursively */ -void usb_show_tree_graph(struct usb_device *dev,char *pre) +void usb_show_tree_graph(struct usb_device *dev, char *pre) { int i,index; - int has_child,last_child,port; + int has_child, last_child, port;
- index=strlen(pre); + index = strlen(pre); printf(" %s",pre); /* check if the device has connected children */ - has_child=0; - for(i=0;i<dev->maxchild;i++) { - if (dev->children[i]!=NULL) - has_child=1; + has_child = 0; + for(i = 0; i < dev->maxchild; i++) { + if (dev->children[i] != NULL) + has_child = 1; } /* check if we are the last one */ - last_child=1; - if (dev->parent!=NULL) { - for(i=0;i<dev->parent->maxchild;i++) { + last_child = 1; + if (dev->parent != NULL) { + for(i = 0; i < dev->parent->maxchild; i++) { /* search for children */ - if (dev->parent->children[i]==dev) { + if (dev->parent->children[i] == dev) { /* found our pointer, see if we have a little sister */ - port=i; - while(i++<dev->parent->maxchild) { - if (dev->parent->children[i]!=NULL) { + port = i; + while(i++ < dev->parent->maxchild) { + if (dev->parent->children[i] != NULL) { /* found a sister */ - last_child=0; + last_child = 0; break; } /* if */ } /* while */ @@ -265,28 +286,28 @@ void usb_show_tree_graph(struct usb_device *dev,char *pre) } /* for all children of the parent */ printf("\b+-"); /* correct last child */ - if (last_child) { - pre[index-1]=' '; - } + if (last_child) + pre[index-1] =' '; } /* if not root hub */ - else + else { printf(" "); - printf("%d ",dev->devnum); - pre[index++]=' '; - pre[index++]= has_child ? '|' : ' '; - pre[index]=0; - printf(" %s (%s, %dmA)\n",usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass), - dev->slow ? "1.5MBit/s" : "12MBit/s",dev->config.MaxPower * 2); - if (strlen(dev->mf) || - strlen(dev->prod) || - strlen(dev->serial)) - printf(" %s %s %s %s\n",pre,dev->mf,dev->prod,dev->serial); - printf(" %s\n",pre); - if (dev->maxchild>0) { - for(i=0;i<dev->maxchild;i++) { - if (dev->children[i]!=NULL) { - usb_show_tree_graph(dev->children[i],pre); - pre[index]=0; + } + printf("%d ", dev->devnum); + pre[index++] = ' '; + pre[index++] = has_child ? '|' : ' '; + pre[index] = 0; + printf(" %s (%s, %dmA)\n", usb_get_class_desc(dev->config.if_desc[0].bInterfaceClass), + dev->slow ? "1.5MBit/s" : "12MBit/s", dev->config.MaxPower * 2); + + if (strlen(dev->mf) || strlen(dev->prod) || strlen(dev->serial)) + printf(" %s %s %s %s\n", pre, dev->mf, dev->prod, dev->serial); + + printf(" %s\n", pre); + if (dev->maxchild > 0) { + for(i = 0; i < dev->maxchild; i++) { + if (dev->children[i] != NULL) { + usb_show_tree_graph(dev->children[i], pre); + pre[index] = 0; } } } @@ -297,8 +318,8 @@ void usb_show_tree(struct usb_device *dev) { char preamble[32];
- memset(preamble,0,32); - usb_show_tree_graph(dev,&preamble[0]); + memset(preamble, 0, 32); + usb_show_tree_graph(dev, &preamble[0]); }
@@ -310,7 +331,8 @@ int do_usbboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) { char *boot_device = NULL; char *ep; - int dev, part=1, rcode; + int dev, rcode; + int part = 1; ulong addr, cnt; disk_partition_t info; image_header_t *hdr; @@ -348,7 +370,7 @@ int do_usbboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) printf ("\n** Device %d not available\n", dev); return 1; } - if (stor_dev->block_read==NULL) { + if (stor_dev->block_read == NULL) { printf("storage device not initialized. Use usb scan\n"); return 1; } @@ -364,13 +386,13 @@ int do_usbboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) /* try to boot raw .... */ strncpy((char *)&info.type[0], BOOT_PART_TYPE, sizeof(BOOT_PART_TYPE)); strncpy((char *)&info.name[0], "Raw", 4); - info.start=0; - info.blksz=0x200; - info.size=2880; + info.start = 0; + info.blksz = 0x200; + info.size = 2880; printf("error reading partinfo...try to boot raw\n"); } if ((strncmp((char *)info.type, BOOT_PART_TYPE, sizeof(info.type)) != 0) && - (strncmp((char *)info.type, BOOT_PART_COMP, sizeof(info.type)) != 0)) { + (strncmp((char *)info.type, BOOT_PART_COMP, sizeof(info.type)) != 0)) { printf ("\n** Invalid partition type "%.32s"" " (expect "" BOOT_PART_TYPE "")\n", info.type); @@ -422,8 +444,8 @@ int do_usbboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) cnt /= info.blksz; cnt -= 1;
- if (stor_dev->block_read (dev, info.start+1, cnt, - (ulong *)(addr+info.blksz)) != cnt) { + if (stor_dev->block_read (dev, info.start + 1, cnt, + (ulong *)(addr+info.blksz)) != cnt) { printf ("\n** Read error on %d:%d\n", dev, part); return 1; } @@ -437,23 +459,23 @@ int do_usbboot (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) /* Loading ok, update default load address */ load_addr = addr;
- flush_cache (addr, (cnt+1)*info.blksz); + flush_cache (addr, (cnt + 1) * info.blksz);
/* Check if we should attempt an auto-start */ - if (((ep = getenv("autostart")) != NULL) && (strcmp(ep,"yes") == 0)) { + if (((ep = getenv("autostart")) != NULL) && (strcmp(ep, "yes") == 0)) { char *local_args[2]; extern int do_bootm (cmd_tbl_t *, int, int, char *[]); + local_args[0] = argv[0]; local_args[1] = NULL; printf ("Automatic boot of image at addr 0x%08lX ...\n", addr); - rcode=do_bootm (cmdtp, 0, 1, local_args); + rcode = do_bootm (cmdtp, 0, 1, local_args); return rcode; } return 0; } #endif /* CONFIG_USB_STORAGE */
- /********************************************************************************* * usb command intepreter */ @@ -475,14 +497,14 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) #ifdef CONFIG_USB_STORAGE /* try to recognize storage devices immediately */ if (i >= 0) - usb_stor_curr_dev = usb_stor_scan(1); + usb_stor_curr_dev = usb_stor_scan(1); #endif return 0; } - if (strncmp(argv[1],"stop",4) == 0) { + if (strncmp(argv[1], "stop", 4) == 0) { #ifdef CONFIG_USB_KEYBOARD - if (argc==2) { - if (usb_kbd_deregister()!=0) { + if (argc == 2) { + if (usb_kbd_deregister() != 0) { printf("USB not stopped: usbkbd still using USB\n"); return 1; } @@ -500,17 +522,18 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) printf("USB is stopped. Please issue 'usb start' first.\n"); return 1; } - if (strncmp(argv[1],"tree",4) == 0) { + if (strncmp(argv[1], "tree", 4) == 0) { printf("\nDevice Tree:\n"); usb_show_tree(usb_get_dev_index(0)); return 0; } - if (strncmp(argv[1],"inf",3) == 0) { + if (strncmp(argv[1], "inf", 3) == 0) { int d; - if (argc==2) { - for(d=0;d<USB_MAX_DEVICE;d++) { - dev=usb_get_dev_index(d); - if (dev==NULL) + + if (argc == 2) { + for(d = 0; d < USB_MAX_DEVICE; d++) { + dev = usb_get_dev_index(d); + if (dev == NULL) break; usb_display_desc(dev); usb_display_config(dev); @@ -518,18 +541,16 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; } else { - int d; - - i=simple_strtoul(argv[2], NULL, 16); - printf("config for device %d\n",i); - for(d=0;d<USB_MAX_DEVICE;d++) { - dev=usb_get_dev_index(d); - if (dev==NULL) + i = simple_strtoul(argv[2], NULL, 16); + printf("config for device %d\n", i); + for(d = 0; d < USB_MAX_DEVICE; d++) { + dev = usb_get_dev_index(d); + if (dev == NULL) break; - if (dev->devnum==i) + if (dev->devnum == i) break; } - if (dev==NULL) { + if (dev == NULL) { printf("*** NO Device avaiable ***\n"); return 0; } @@ -548,19 +569,19 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) return 0; }
- if (strncmp(argv[1], "stor", 4) == 0) { + if (strncmp(argv[1], "stor", 4) == 0) return usb_stor_info(); - }
- if (strncmp(argv[1],"part",4) == 0) { + if (strncmp(argv[1], "part", 4) == 0) { int devno, ok; - for (ok=0, devno=0; devno<USB_MAX_STOR_DEV; ++devno) { - stor_dev=usb_stor_get_dev(devno); - if (stor_dev->type!=DEV_TYPE_UNKNOWN) { + + for (ok = 0, devno = 0; devno < USB_MAX_STOR_DEV; ++devno) { + stor_dev = usb_stor_get_dev(devno); + if (stor_dev->type != DEV_TYPE_UNKNOWN) { ok++; if (devno) printf("\n"); - printf("print_part of %x\n",devno); + printf("print_part of %x\n", devno); print_part(stor_dev); } } @@ -570,22 +591,23 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } return 0; } - if (strcmp(argv[1],"read") == 0) { - if (usb_stor_curr_dev<0) { + if (strcmp(argv[1], "read") == 0) { + if (usb_stor_curr_dev < 0) { printf("no current device selected\n"); return 1; } - if (argc==5) { + if (argc == 5) { unsigned long addr = simple_strtoul(argv[2], NULL, 16); - unsigned long blk = simple_strtoul(argv[3], NULL, 16); - unsigned long cnt = simple_strtoul(argv[4], NULL, 16); + unsigned long blk = simple_strtoul(argv[3], NULL, 16); + unsigned long cnt = simple_strtoul(argv[4], NULL, 16); unsigned long n; + printf ("\nUSB read: device %d block # %ld, count %ld ... ", usb_stor_curr_dev, blk, cnt); - stor_dev=usb_stor_get_dev(usb_stor_curr_dev); + stor_dev = usb_stor_get_dev(usb_stor_curr_dev); n = stor_dev->block_read(usb_stor_curr_dev, blk, cnt, (ulong *)addr); printf ("%ld blocks read: %s\n",n,(n==cnt) ? "OK" : "ERROR"); - if (n==cnt) + if (n == cnt) return 0; return 1; } @@ -593,13 +615,14 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) if (strncmp(argv[1], "dev", 3) == 0) { if (argc == 3) { int dev = (int)simple_strtoul(argv[2], NULL, 10); + printf ("\nUSB device %d: ", dev); if (dev >= USB_MAX_STOR_DEV) { printf("unknown device\n"); return 1; } printf ("\n Device %d: ", dev); - stor_dev=usb_stor_get_dev(dev); + stor_dev = usb_stor_get_dev(dev); dev_print(stor_dev); if (stor_dev->type == DEV_TYPE_UNKNOWN) { return 1; @@ -610,7 +633,7 @@ int do_usb (cmd_tbl_t *cmdtp, int flag, int argc, char *argv[]) } else { printf ("\nUSB device %d: ", usb_stor_curr_dev); - stor_dev=usb_stor_get_dev(usb_stor_curr_dev); + stor_dev = usb_stor_get_dev(usb_stor_curr_dev); dev_print(stor_dev); if (stor_dev->type == DEV_TYPE_UNKNOWN) { return 1; diff --git a/common/usb.c b/common/usb.c index 4df01ea..6c10282 100644 --- a/common/usb.c +++ b/common/usb.c @@ -1,5 +1,4 @@ /* - * * Most of this source has been derived from the Linux USB * project: * (C) Copyright Linus Torvalds 1999 @@ -10,7 +9,7 @@ * (C) Copyright Randy Dunlap 2000 * (C) Copyright David Brownell 2000 (kernel hotplug, usb_device_id) * (C) Copyright Yggdrasil Computing, Inc. 2000 - * (usb_device_id matching changes by Adam J. Richter) + * (usb_device_id matching changes by Adam J. Richter) * * Adapted for U-Boot: * (C) Copyright 2001 Denis Peter, MPL AG Switzerland @@ -82,7 +81,6 @@ void usb_scan_devices(void); int usb_hub_probe(struct usb_device *dev, int ifnum); void usb_hub_reset(void);
- /*********************************************************************** * wait_ms */ @@ -100,17 +98,17 @@ int usb_init(void) { int result;
- running=0; - dev_index=0; - asynch_allowed=1; + running = 0; + dev_index = 0; + asynch_allowed = 1; usb_hub_reset(); /* init low_level USB */ printf("USB: "); result = usb_lowlevel_init(); /* if lowlevel init is OK, scan the bus for devices i.e. search HUBs and configure them */ - if(result==0) { + if(result == 0) { printf("scanning bus for devices... "); - running=1; + running = 1; usb_scan_devices(); usb_started = 1; return 0; @@ -127,7 +125,7 @@ int usb_init(void) */ int usb_stop(void) { - asynch_allowed=1; + asynch_allowed = 1; usb_started = 0; usb_hub_reset(); return usb_lowlevel_stop(); @@ -139,10 +137,9 @@ int usb_stop(void) */ void usb_disable_asynch(int disable) { - asynch_allowed=!disable; + asynch_allowed = !disable; }
- /*------------------------------------------------------------------- * Message wrappers. * @@ -154,11 +151,11 @@ void usb_disable_asynch(int disable) int usb_submit_int_msg(struct usb_device *dev, unsigned long pipe, void *buffer,int transfer_len, int interval) { - return submit_int_msg(dev,pipe,buffer,transfer_len,interval); + return submit_int_msg(dev, pipe, buffer, transfer_len, interval); }
/* - * submits a control message and waits for comletion (at least timeout * 1ms) + * submits a control message and waits for completion (at least timeout * 1ms) * If timeout is 0, we don't wait for completion (used as example to set and * clear keyboards LEDs). For data transfers, (storage transfers) we don't * allow control messages with 0 timeout, by previousely resetting the flag @@ -171,7 +168,7 @@ int usb_control_msg(struct usb_device *dev, unsigned int pipe, unsigned short value, unsigned short index, void *data, unsigned short size, int timeout) { - if((timeout==0)&&(!asynch_allowed)) /* request for a asynch control pipe is not allowed */ + if((timeout == 0) && (!asynch_allowed)) /* request for a asynch control pipe is not allowed */ return -1;
/* set setup command */ @@ -180,12 +177,12 @@ int usb_control_msg(struct usb_device *dev, unsigned int pipe, setup_packet.value = swap_16(value); setup_packet.index = swap_16(index); setup_packet.length = swap_16(size); - USB_PRINTF("usb_control_msg: request: 0x%X, requesttype: 0x%X\nvalue 0x%X index 0x%X length 0x%X\n", + USB_PRINTF("usb_control_msg: request: 0x%X, requesttype: 0x%X\nvalue 0x%X index 0x%X length 0x%X\n", request,requesttype,value,index,size); - dev->status=USB_ST_NOT_PROC; /*not yet processed */ + dev->status = USB_ST_NOT_PROC; /*not yet processed */
- submit_control_msg(dev,pipe,data,size,&setup_packet); - if(timeout==0) { + submit_control_msg(dev, pipe, data, size, &setup_packet); + if(timeout == 0) { return (int)size; } while(timeout--) { @@ -193,11 +190,10 @@ int usb_control_msg(struct usb_device *dev, unsigned int pipe, break; wait_ms(1); } - if(dev->status==0) + if(dev->status == 0) return dev->act_len; - else { - return -1; - } + + return -1; }
/*------------------------------------------------------------------- @@ -210,20 +206,19 @@ int usb_bulk_msg(struct usb_device *dev, unsigned int pipe, { if (len < 0) return -1; - dev->status=USB_ST_NOT_PROC; /*not yet processed */ - submit_bulk_msg(dev,pipe,data,len); + dev->status = USB_ST_NOT_PROC; /*not yet processed */ + submit_bulk_msg(dev, pipe, data, len); while(timeout--) { if(!((volatile unsigned long)dev->status & USB_ST_NOT_PROC)) break; wait_ms(1); } - *actual_length=dev->act_len; - if(dev->status==0) + *actual_length = dev->act_len; + if(dev->status == 0) return 0; - else - return -1; -}
+ return -1; +}
/*------------------------------------------------------------------- * Max Packet stuff @@ -236,9 +231,9 @@ int usb_bulk_msg(struct usb_device *dev, unsigned int pipe, int usb_maxpacket(struct usb_device *dev,unsigned long pipe) { if((pipe & USB_DIR_IN)==0) /* direction is out -> use emaxpacket out */ - return(dev->epmaxpacketout[((pipe>>15) & 0xf)]); + return(dev->epmaxpacketout[((pipe >> 15) & 0xf)]); else - return(dev->epmaxpacketin[((pipe>>15) & 0xf)]); + return(dev->epmaxpacketin[((pipe >> 15) & 0xf)]); }
/* @@ -249,27 +244,31 @@ int usb_set_maxpacket(struct usb_device *dev) int i,ii,b; struct usb_endpoint_descriptor *ep;
- for(i=0; i<dev->config.bNumInterfaces;i++) { - for(ii=0; ii<dev->config.if_desc[i].bNumEndpoints; ii++) { - ep=&dev->config.if_desc[i].ep_desc[ii]; - b=ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK; + for(i = 0; i < dev->config.bNumInterfaces; i++) { + for(ii = 0; ii < dev->config.if_desc[i].bNumEndpoints; ii++) { + ep = &dev->config.if_desc[i].ep_desc[ii]; + b = ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
- if((ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK)==USB_ENDPOINT_XFER_CONTROL) { /* Control => bidirectional */ + if((ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == + USB_ENDPOINT_XFER_CONTROL) { /* Control => bidirectional */ dev->epmaxpacketout[b] = ep->wMaxPacketSize; dev->epmaxpacketin [b] = ep->wMaxPacketSize; - USB_PRINTF("##Control EP epmaxpacketout/in[%d] = %d\n",b,dev->epmaxpacketin[b]); + USB_PRINTF("##Control EP epmaxpacketout/in[%d] = %d\n", + b, dev->epmaxpacketin[b]); } else { - if ((ep->bEndpointAddress & 0x80)==0) { /* OUT Endpoint */ + if ((ep->bEndpointAddress & 0x80) == 0) { /* OUT Endpoint */ if(ep->wMaxPacketSize > dev->epmaxpacketout[b]) { dev->epmaxpacketout[b] = ep->wMaxPacketSize; - USB_PRINTF("##EP epmaxpacketout[%d] = %d\n",b,dev->epmaxpacketout[b]); + USB_PRINTF("##EP epmaxpacketout[%d] = %d\n", + b, dev->epmaxpacketout[b]); } } - else { /* IN Endpoint */ + else { /* IN Endpoint */ if(ep->wMaxPacketSize > dev->epmaxpacketin[b]) { dev->epmaxpacketin[b] = ep->wMaxPacketSize; - USB_PRINTF("##EP epmaxpacketin[%d] = %d\n",b,dev->epmaxpacketin[b]); + USB_PRINTF("##EP epmaxpacketin[%d] = %d\n", + b, dev->epmaxpacketin[b]); } } /* if out */ } /* if control */ @@ -294,7 +293,7 @@ int usb_parse_config(struct usb_device *dev, unsigned char *buffer, int cfgno) curr_if_num = -1;
dev->configno = cfgno; - head = (struct usb_descriptor_header *) &buffer[0]; + head = (struct usb_descriptor_header *)&buffer[0]; if(head->bDescriptorType != USB_DT_CONFIG) { printf(" ERROR: NOT USB_CONFIG_DESC %x\n", head->bDescriptorType); return -1; @@ -305,11 +304,11 @@ int usb_parse_config(struct usb_device *dev, unsigned char *buffer, int cfgno)
index = dev->config.bLength; /* Ok the first entry must be a configuration entry, now process the others */ - head = (struct usb_descriptor_header *) &buffer[index]; + head = (struct usb_descriptor_header *)&buffer[index]; while(index + 1 < dev->config.wTotalLength) { switch(head->bDescriptorType) { case USB_DT_INTERFACE: - if(((struct usb_interface_descriptor *) &buffer[index])-> + if(((struct usb_interface_descriptor *)&buffer[index])-> bInterfaceNumber != curr_if_num) { /* this is a new interface, copy new desc */ ifno = dev->config.no_of_if; @@ -359,10 +358,11 @@ int usb_parse_config(struct usb_device *dev, unsigned char *buffer, int cfgno) int usb_clear_halt(struct usb_device *dev, int pipe) { int result; - int endp = usb_pipeendpoint(pipe)|(usb_pipein(pipe)<<7); + int endp = usb_pipeendpoint(pipe) | (usb_pipein(pipe) << 7);
result = usb_control_msg(dev, usb_sndctrlpipe(dev, 0), - USB_REQ_CLEAR_FEATURE, USB_RECIP_ENDPOINT, 0, endp, NULL, 0, USB_CNTL_TIMEOUT * 3); + USB_REQ_CLEAR_FEATURE, USB_RECIP_ENDPOINT, 0, endp, NULL, + 0, USB_CNTL_TIMEOUT * 3);
/* don't clear if failed */ if (result < 0) @@ -384,10 +384,11 @@ int usb_clear_halt(struct usb_device *dev, int pipe) /********************************************************************** * get_descriptor type */ -int usb_get_descriptor(struct usb_device *dev, unsigned char type, unsigned char index, void *buf, int size) +int usb_get_descriptor(struct usb_device *dev, unsigned char type, unsigned char index, + void *buf, int size) { int res; - res = usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), + res = usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), USB_REQ_GET_DESCRIPTOR, USB_DIR_IN, (type << 8) + index, 0, buf, size, USB_CNTL_TIMEOUT); @@ -399,18 +400,17 @@ int usb_get_descriptor(struct usb_device *dev, unsigned char type, unsigned char */ int usb_get_configuration_no(struct usb_device *dev,unsigned char *buffer,int cfgno) { - int result; + int result; unsigned int tmp; struct usb_config_descriptor *config;
- - config=(struct usb_config_descriptor *)&buffer[0]; + config = (struct usb_config_descriptor *)&buffer[0]; result = usb_get_descriptor(dev, USB_DT_CONFIG, cfgno, buffer, 8); if (result < 8) { if (result < 0) - printf("unable to get descriptor, error %lX\n",dev->status); + printf("unable to get descriptor, error %lX\n", dev->status); else - printf("config descriptor too short (expected %i, got %i)\n",8,result); + printf("config descriptor too short (expected %i, got %i)\n", 8, result); return -1; } tmp=swap_16(config->wTotalLength); @@ -422,7 +422,7 @@ int usb_get_configuration_no(struct usb_device *dev,unsigned char *buffer,int cf }
result = usb_get_descriptor(dev, USB_DT_CONFIG, cfgno, buffer, tmp); - USB_PRINTF("get_conf_no %d Result %d, wLength %d\n",cfgno,result,tmp); + USB_PRINTF("get_conf_no %d Result %d, wLength %d\n", cfgno, result, tmp); return result; }
@@ -435,10 +435,10 @@ int usb_set_address(struct usb_device *dev) int res;
USB_PRINTF("set address %d\n",dev->devnum); - res=usb_control_msg(dev, usb_snddefctrl(dev), + res = usb_control_msg(dev, usb_snddefctrl(dev), USB_REQ_SET_ADDRESS, 0, - (dev->devnum),0, - NULL,0, USB_CNTL_TIMEOUT); + (dev->devnum), 0, + NULL, 0, USB_CNTL_TIMEOUT); return res; }
@@ -470,8 +470,8 @@ int usb_set_interface(struct usb_device *dev, int interface, int alternate) return 0;
if ((ret = usb_control_msg(dev, usb_sndctrlpipe(dev, 0), - USB_REQ_SET_INTERFACE, USB_RECIP_INTERFACE, alternate, - interface, NULL, 0, USB_CNTL_TIMEOUT * 5)) < 0) + USB_REQ_SET_INTERFACE, USB_RECIP_INTERFACE, alternate, + interface, NULL, 0, USB_CNTL_TIMEOUT * 5)) < 0) return ret;
return 0; @@ -483,19 +483,20 @@ int usb_set_interface(struct usb_device *dev, int interface, int alternate) int usb_set_configuration(struct usb_device *dev, int configuration) { int res; - USB_PRINTF("set configuration %d\n",configuration); + + USB_PRINTF("set configuration %d\n", configuration); /* set setup command */ - res=usb_control_msg(dev, usb_sndctrlpipe(dev,0), + res = usb_control_msg(dev, usb_sndctrlpipe(dev, 0), USB_REQ_SET_CONFIGURATION, 0, - configuration,0, - NULL,0, USB_CNTL_TIMEOUT); - if(res==0) { + configuration, 0, + NULL, 0, USB_CNTL_TIMEOUT); + if(res == 0) { dev->toggle[0] = 0; dev->toggle[1] = 0; return 0; } - else - return -1; + + return -1; }
/******************************************************************** @@ -521,7 +522,8 @@ int usb_set_idle(struct usb_device *dev, int ifnum, int duration, int report_id) /******************************************************************** * get report */ -int usb_get_report(struct usb_device *dev, int ifnum, unsigned char type, unsigned char id, void *buf, int size) +int usb_get_report(struct usb_device *dev, int ifnum, unsigned char type, + unsigned char id, void *buf, int size) { return usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), USB_REQ_GET_REPORT, USB_DIR_IN | USB_TYPE_CLASS | USB_RECIP_INTERFACE, @@ -542,7 +544,8 @@ int usb_get_class_descriptor(struct usb_device *dev, int ifnum, /******************************************************************** * get string index in buffer */ -int usb_get_string(struct usb_device *dev, unsigned short langid, unsigned char index, void *buf, int size) +int usb_get_string(struct usb_device *dev, unsigned short langid, + unsigned char index, void *buf, int size) { int i; int result; @@ -561,10 +564,10 @@ int usb_get_string(struct usb_device *dev, unsigned short langid, unsigned char return result; }
- static void usb_try_string_workarounds(unsigned char *buf, int *length) { - int newlength, oldlength = *length; + int newlength; + int oldlength = *length;
for (newlength = 2; newlength + 1 < oldlength; newlength += 2) if (!isprint(buf[newlength]) || buf[newlength + 1]) @@ -576,7 +579,6 @@ static void usb_try_string_workarounds(unsigned char *buf, int *length) } }
- static int usb_string_sub(struct usb_device *dev, unsigned int langid, unsigned int index, unsigned char *buf) { @@ -611,7 +613,6 @@ static int usb_string_sub(struct usb_device *dev, unsigned int langid, return rc; }
- /******************************************************************** * usb_string: * Get string index and translate it to ascii. @@ -627,20 +628,21 @@ int usb_string(struct usb_device *dev, int index, char *buf, size_t size) if (size <= 0 || !buf || !index) return -1; buf[0] = 0; - tbuf=&mybuf[0]; + tbuf = &mybuf[0];
/* get langid for strings if it's not yet known */ if (!dev->have_langid) { err = usb_string_sub(dev, 0, 0, tbuf); if (err < 0) { - USB_PRINTF("error getting string descriptor 0 (error=%x)\n",dev->status); + USB_PRINTF("error getting string descriptor 0 (error=%x)\n", + dev->status); return -1; } else if (tbuf[0] < 4) { USB_PRINTF("string descriptor 0 too short\n"); return -1; } else { dev->have_langid = -1; - dev->string_langid = tbuf[2] | (tbuf[3]<< 8); + dev->string_langid = tbuf[2] | (tbuf[3] << 8); /* always use the first langid listed */ USB_PRINTF("USB device number %d default language ID 0x%x\n", dev->devnum, dev->string_langid); @@ -655,8 +657,8 @@ int usb_string(struct usb_device *dev, int index, char *buf, size_t size) for (idx = 0, u = 2; u < err; u += 2) { if (idx >= size) break; - if (tbuf[u+1]) /* high byte */ - buf[idx++] = '?'; /* non-ASCII character */ + if (tbuf[u + 1]) /* high byte */ + buf[idx++] = '?'; /* non-ASCII character */ else buf[idx++] = tbuf[u]; } @@ -665,70 +667,47 @@ int usb_string(struct usb_device *dev, int index, char *buf, size_t size) return err; }
- /******************************************************************** * USB device handling: * the USB device are static allocated [USB_MAX_DEVICE]. */
- /* returns a pointer to the device with the index [index]. * if the device is not assigned (dev->devnum==-1) returns NULL */ struct usb_device * usb_get_dev_index(int index) { - if(usb_dev[index].devnum==-1) + if(usb_dev[index].devnum == -1) return NULL; - else - return &usb_dev[index]; -}
+ return &usb_dev[index]; +}
/* returns a pointer of a new device structure or NULL, if * no device struct is available */ -struct usb_device * usb_alloc_new_device(void) +struct usb_device* usb_alloc_new_device(void) { int i; + USB_PRINTF("New Device %d\n",dev_index); - if(dev_index==USB_MAX_DEVICE) { - printf("ERROR, too many USB Devices, max=%d\n",USB_MAX_DEVICE); + if(dev_index == USB_MAX_DEVICE) { + printf("ERROR, too many USB Devices, max=%d\n", USB_MAX_DEVICE); return NULL; } - usb_dev[dev_index].devnum=dev_index+1; /* default Address is 0, real addresses start with 1 */ - usb_dev[dev_index].maxchild=0; - for(i=0;i<USB_MAXCHILDREN;i++) - usb_dev[dev_index].children[i]=NULL; - usb_dev[dev_index].parent=NULL; + usb_dev[dev_index].devnum = dev_index + 1; /* default Address is 0, real addresses start with 1 */ + usb_dev[dev_index].maxchild = 0; + for(i = 0; i < USB_MAXCHILDREN; i++) + usb_dev[dev_index].children[i] = NULL; + usb_dev[dev_index].parent = NULL; dev_index++; - return &usb_dev[dev_index-1]; + return &usb_dev[dev_index - 1]; }
- -/* - * By the time we get here, the device has gotten a new device ID - * and is in the default state. We need to identify the thing and - * get the ball rolling.. - * - * Returns 0 for success, != 0 for error. - */ -int usb_new_device(struct usb_device *dev) -{ - int addr, err; - int tmp; - unsigned char tmpbuf[USB_BUFSIZ]; - - dev->descriptor.bMaxPacketSize0 = 8; /* Start off at 8 bytes */ - dev->maxpacketsize = 0; /* Default to 8 byte max packet size */ - dev->epmaxpacketin [0] = 8; - dev->epmaxpacketout[0] = 8; - - /* We still haven't set the Address yet */ - addr = dev->devnum; - dev->devnum = 0; - #undef NEW_INIT_SEQ #ifdef NEW_INIT_SEQ +static inline init_sec(struct usb_device *dev) +{ /* this is a Windows scheme of initialization sequence, with double * reset of the device. Some equipment is said to work only with such * init sequence; this patch is based on the work by Alan Stern: @@ -740,8 +719,8 @@ int usb_new_device(struct usb_device *dev) struct usb_device *parent = dev->parent; unsigned short portstatus;
- /* send 64-byte GET-DEVICE-DESCRIPTOR request. Since the descriptor is - * only 18 bytes long, this will terminate with a short packet. But if + /* send 64-byte GET-DEVICE-DESCRIPTOR request. Since the descriptor is + * only 18 bytes long, this will terminate with a short packet. But if * the maxpacket size is 8 or 16 the device may be waiting to transmit * some more. */
@@ -777,22 +756,65 @@ int usb_new_device(struct usb_device *dev) return 1; } } + + return 0; +} #else +int init_sec(struct usb_device *dev) +{ + int err; + /* and this is the old and known way of initializing devices */ err = usb_get_descriptor(dev, USB_DT_DEVICE, 0, &dev->descriptor, 8); if (err < 8) { printf("\n USB device not responding, giving up (status=%lX)\n",dev->status); return 1; } + + return 0; +} #endif +/* + * By the time we get here, the device has gotten a new device ID + * and is in the default state. We need to identify the thing and + * get the ball rolling.. + * + * Returns 0 for success, != 0 for error. + */ +int usb_new_device(struct usb_device *dev) +{ + int addr, err; + int tmp; + unsigned char tmpbuf[USB_BUFSIZ]; + + dev->descriptor.bMaxPacketSize0 = 8; /* Start off at 8 bytes */ + dev->maxpacketsize = 0; /* Default to 8 byte max packet size */ + dev->epmaxpacketin [0] = 8; + dev->epmaxpacketout[0] = 8; + + /* We still haven't set the Address yet */ + addr = dev->devnum; + dev->devnum = 0; + + err = init_sec(dev); + if(err) + return err;
dev->epmaxpacketin [0] = dev->descriptor.bMaxPacketSize0; dev->epmaxpacketout[0] = dev->descriptor.bMaxPacketSize0; switch (dev->descriptor.bMaxPacketSize0) { - case 8: dev->maxpacketsize = 0; break; - case 16: dev->maxpacketsize = 1; break; - case 32: dev->maxpacketsize = 2; break; - case 64: dev->maxpacketsize = 3; break; + case 8: + dev->maxpacketsize = 0; + break; + case 16: + dev->maxpacketsize = 1; + break; + case 32: + dev->maxpacketsize = 2; + break; + case 64: + dev->maxpacketsize = 3; + break; } dev->devnum = addr;
@@ -812,21 +834,21 @@ int usb_new_device(struct usb_device *dev) if (err < 0) printf("unable to get device descriptor (error=%d)\n",err); else - printf("USB device descriptor short read (expected %i, got %i)\n",tmp,err); + printf("USB device descriptor short read (expected %i, got %i)\n", tmp, err); return 1; } /* correct le values */ - dev->descriptor.bcdUSB=swap_16(dev->descriptor.bcdUSB); - dev->descriptor.idVendor=swap_16(dev->descriptor.idVendor); - dev->descriptor.idProduct=swap_16(dev->descriptor.idProduct); - dev->descriptor.bcdDevice=swap_16(dev->descriptor.bcdDevice); + dev->descriptor.bcdUSB = swap_16(dev->descriptor.bcdUSB); + dev->descriptor.idVendor = swap_16(dev->descriptor.idVendor); + dev->descriptor.idProduct = swap_16(dev->descriptor.idProduct); + dev->descriptor.bcdDevice = swap_16(dev->descriptor.bcdDevice); /* only support for one config for now */ - usb_get_configuration_no(dev,&tmpbuf[0],0); - usb_parse_config(dev,&tmpbuf[0],0); + usb_get_configuration_no(dev, &tmpbuf[0], 0); + usb_parse_config(dev, &tmpbuf[0], 0); usb_set_maxpacket(dev); /* we set the default configuration here */ if (usb_set_configuration(dev, dev->config.bConfigurationValue)) { - printf("failed to set default configuration len %d, status %lX\n",dev->act_len,dev->status); + printf("failed to set default configuration len %d, status %lX\n", dev->act_len, dev->status); return -1; } USB_PRINTF("new device strings: Mfr=%d, Product=%d, SerialNumber=%d\n", @@ -848,22 +870,22 @@ int usb_new_device(struct usb_device *dev) return 0; }
-/* build device Tree */ +/* build device Tree */ void usb_scan_devices(void) { int i; struct usb_device *dev;
/* first make all devices unknown */ - for(i=0;i<USB_MAX_DEVICE;i++) { - memset(&usb_dev[i],0,sizeof(struct usb_device)); - usb_dev[i].devnum=-1; + for(i = 0; i < USB_MAX_DEVICE; i++) { + memset(&usb_dev[i], 0, sizeof(struct usb_device)); + usb_dev[i].devnum = -1; } - dev_index=0; + dev_index = 0; /* device 0 is always present (root hub, so let it analyze) */ - dev=usb_alloc_new_device(); + dev = usb_alloc_new_device(); usb_new_device(dev); - printf("%d USB Device(s) found\n",dev_index); + printf("%d USB Device(s) found\n", dev_index); /* insert "driver" if possible */ #ifdef CONFIG_USB_KEYBOARD drv_usb_kbd_init(); @@ -871,7 +893,6 @@ void usb_scan_devices(void) #endif }
- /**************************************************************************** * HUB "Driver" * Probes device for being a hub and configurate it @@ -885,11 +906,9 @@ void usb_scan_devices(void) #define USB_HUB_PRINTF(fmt,args...) #endif
- static struct usb_hub_device hub_dev[USB_MAX_HUB]; static int usb_hub_index;
- int usb_get_hub_descriptor(struct usb_device *dev, void *data, int size) { return usb_control_msg(dev, usb_rcvctrlpipe(dev, 0), @@ -940,22 +959,22 @@ static void usb_hub_power_on(struct usb_hub_device *hub) USB_HUB_PRINTF("enabling power on all ports\n"); for (i = 0; i < dev->maxchild; i++) { usb_set_port_feature(dev, i + 1, USB_PORT_FEAT_POWER); - USB_HUB_PRINTF("port %d returns %lX\n",i+1,dev->status); + USB_HUB_PRINTF("port %d returns %lX\n", i + 1, dev->status); wait_ms(hub->desc.bPwrOn2PwrGood * 2); } }
void usb_hub_reset(void) { - usb_hub_index=0; + usb_hub_index = 0; }
struct usb_hub_device *usb_hub_allocate(void) { - if(usb_hub_index<USB_MAX_HUB) { + if(usb_hub_index < USB_MAX_HUB) { return &hub_dev[usb_hub_index++]; } - printf("ERROR: USB_MAX_HUB (%d) reached\n",USB_MAX_HUB); + printf("ERROR: USB_MAX_HUB (%d) reached\n", USB_MAX_HUB); return NULL; }
@@ -968,15 +987,14 @@ static int hub_port_reset(struct usb_device *dev, int port, struct usb_port_status portsts; unsigned short portstatus, portchange;
- USB_HUB_PRINTF("hub_port_reset: resetting port %d...\n", port); - for(tries=0;tries<MAX_TRIES;tries++) { + for(tries = 0; tries < MAX_TRIES; tries++) {
usb_set_port_feature(dev, port + 1, USB_PORT_FEAT_RESET); wait_ms(200);
- if (usb_get_port_status(dev, port + 1, &portsts)<0) { - USB_HUB_PRINTF("get_port_status failed status %lX\n",dev->status); + if (usb_get_port_status(dev, port + 1, &portsts) < 0) { + USB_HUB_PRINTF("get_port_status failed status %lX\n", dev->status); return -1; } portstatus = swap_16(portsts.wPortStatus); @@ -988,19 +1006,18 @@ static int hub_port_reset(struct usb_device *dev, int port, (portstatus & USB_PORT_STAT_CONNECTION) ? 1 : 0, (portstatus & USB_PORT_STAT_ENABLE) ? 1 : 0); if ((portchange & USB_PORT_STAT_C_CONNECTION) || - !(portstatus & USB_PORT_STAT_CONNECTION)) + !(portstatus & USB_PORT_STAT_CONNECTION)) return -1;
- if (portstatus & USB_PORT_STAT_ENABLE) { - + if (portstatus & USB_PORT_STAT_ENABLE) break; - }
wait_ms(200); }
- if (tries==MAX_TRIES) { - USB_HUB_PRINTF("Cannot enable port %i after %i retries, disabling port.\n", port+1, MAX_TRIES); + if (tries == MAX_TRIES) { + USB_HUB_PRINTF("Cannot enable port %i after %i retries, disabling port.\n", + port + 1, MAX_TRIES); USB_HUB_PRINTF("Maybe the USB cable is bad?\n"); return -1; } @@ -1019,7 +1036,7 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port) unsigned short portstatus, portchange;
/* Check status */ - if (usb_get_port_status(dev, port + 1, &portsts)<0) { + if (usb_get_port_status(dev, port + 1, &portsts) < 0) { USB_HUB_PRINTF("get_port_status failed\n"); return; } @@ -1034,7 +1051,7 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port)
/* Disconnect any existing devices under this port */ if (((!(portstatus & USB_PORT_STAT_CONNECTION)) && - (!(portstatus & USB_PORT_STAT_ENABLE)))|| (dev->children[port])) { + (!(portstatus & USB_PORT_STAT_ENABLE)))|| (dev->children[port])) { USB_HUB_PRINTF("usb_disconnect(&hub->children[port]);\n"); /* Return now if nothing is connected */ if (!(portstatus & USB_PORT_STAT_CONNECTION)) @@ -1051,11 +1068,11 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port) wait_ms(200);
/* Allocate a new device struct for it */ - usb=usb_alloc_new_device(); + usb = usb_alloc_new_device(); usb->slow = (portstatus & USB_PORT_STAT_LOW_SPEED) ? 1 : 0;
dev->children[port] = usb; - usb->parent=dev; + usb->parent = dev; /* Run it through the hoops (find a driver, etc) */ if (usb_new_device(usb)) { /* Woops, disable the port */ @@ -1064,23 +1081,25 @@ void usb_hub_port_connect_change(struct usb_device *dev, int port) } }
- int usb_hub_configure(struct usb_device *dev) { - unsigned char buffer[USB_BUFSIZ], *bitmap; + unsigned char buffer[USB_BUFSIZ]; + unsigned char *bitmap; struct usb_hub_descriptor *descriptor; struct usb_hub_status *hubsts; int i; struct usb_hub_device *hub;
/* "allocate" Hub device */ - hub=usb_hub_allocate(); - if(hub==NULL) + hub = usb_hub_allocate(); + if(hub == NULL) return -1; - hub->pusb_dev=dev; + + hub->pusb_dev = dev; /* Get the the hub descriptor */ if (usb_get_hub_descriptor(dev, buffer, 4) < 0) { - USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor, giving up %lX\n",dev->status); + USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor, giving up %lX\n", + dev->status); return -1; } descriptor = (struct usb_hub_descriptor *)buffer; @@ -1088,29 +1107,30 @@ int usb_hub_configure(struct usb_device *dev) /* silence compiler warning if USB_BUFSIZ is > 256 [= sizeof(char)] */ i = descriptor->bLength; if (i > USB_BUFSIZ) { - USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor - too long: %d\N", + USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor - too long: %d\n", descriptor->bLength); return -1; }
if (usb_get_hub_descriptor(dev, buffer, descriptor->bLength) < 0) { - USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor 2nd giving up %lX\n",dev->status); + USB_HUB_PRINTF("usb_hub_configure: failed to get hub descriptor 2nd giving up %lX\n", + dev->status); return -1; } - memcpy((unsigned char *)&hub->desc,buffer,descriptor->bLength); + memcpy((unsigned char *)&hub->desc, buffer, descriptor->bLength); /* adjust 16bit values */ hub->desc.wHubCharacteristics=swap_16(descriptor->wHubCharacteristics); /* set the bitmap */ bitmap=(unsigned char *)&hub->desc.DeviceRemovable[0]; - memset(bitmap,0xff,(USB_MAXCHILDREN+1+7)/8); /* devices not removable by default */ + memset(bitmap, 0xff, (USB_MAXCHILDREN + 1 + 7) / 8); /* devices not removable by default */ bitmap=(unsigned char *)&hub->desc.PortPowerCtrlMask[0]; - memset(bitmap,0xff,(USB_MAXCHILDREN+1+7)/8); /* PowerMask = 1B */ - for(i=0;i<((hub->desc.bNbrPorts + 1 + 7)/8);i++) { - hub->desc.DeviceRemovable[i]=descriptor->DeviceRemovable[i]; - } - for(i=0;i<((hub->desc.bNbrPorts + 1 + 7)/8);i++) { - hub->desc.DeviceRemovable[i]=descriptor->PortPowerCtrlMask[i]; - } + memset(bitmap, 0xff, (USB_MAXCHILDREN + 1 + 7) / 8); /* PowerMask = 1B */ + for(i = 0; i < ((hub->desc.bNbrPorts + 1 + 7) / 8); i++) + hub->desc.DeviceRemovable[i] = descriptor->DeviceRemovable[i]; + + for(i = 0; i < ((hub->desc.bNbrPorts + 1 + 7) / 8); i++) + hub->desc.DeviceRemovable[i] = descriptor->PortPowerCtrlMask[i]; + dev->maxchild = descriptor->bNbrPorts; USB_HUB_PRINTF("%d ports detected\n", dev->maxchild);
@@ -1142,13 +1162,13 @@ int usb_hub_configure(struct usb_device *dev) case 0x10: case 0x18: USB_HUB_PRINTF("no over-current protection\n"); - break; + break; } USB_HUB_PRINTF("power on to power good time: %dms\n", descriptor->bPwrOn2PwrGood * 2); USB_HUB_PRINTF("hub controller current requirement: %dmA\n", descriptor->bHubContrCurrent); for (i = 0; i < dev->maxchild; i++) USB_HUB_PRINTF("port %d is%s removable\n", i + 1, - hub->desc.DeviceRemovable[(i + 1)/8] & (1 << ((i + 1)%8)) ? " not" : ""); + hub->desc.DeviceRemovable[(i + 1) / 8] & (1 << ((i + 1) % 8)) ? " not" : ""); if (sizeof(struct usb_hub_status) > USB_BUFSIZ) { USB_HUB_PRINTF("usb_hub_configure: failed to get Status - too long: %d\n", descriptor->bLength); @@ -1161,7 +1181,7 @@ int usb_hub_configure(struct usb_device *dev) } hubsts = (struct usb_hub_status *)buffer; USB_HUB_PRINTF("get_hub_status returned status %X, change %X\n", - swap_16(hubsts->wHubStatus),swap_16(hubsts->wHubChange)); + swap_16(hubsts->wHubStatus), swap_16(hubsts->wHubChange)); USB_HUB_PRINTF("local power source is %s\n", (swap_16(hubsts->wHubStatus) & HUB_STATUS_LOCAL_POWER) ? "lost (inactive)" : "good"); USB_HUB_PRINTF("%sover-current condition exists\n", @@ -1175,9 +1195,10 @@ int usb_hub_configure(struct usb_device *dev) USB_HUB_PRINTF("get_port_status failed\n"); continue; } + portstatus = swap_16(portsts.wPortStatus); portchange = swap_16(portsts.wPortChange); - USB_HUB_PRINTF("Port %d Status %X Change %X\n",i+1,portstatus,portchange); + USB_HUB_PRINTF("Port %d Status %X Change %X\n", i + 1, portstatus, portchange); if (portchange & USB_PORT_STAT_C_CONNECTION) { USB_HUB_PRINTF("port %d connection change\n", i + 1); usb_hub_port_connect_change(dev, i); @@ -1198,7 +1219,7 @@ int usb_hub_configure(struct usb_device *dev) } if (portstatus & USB_PORT_STAT_SUSPEND) { USB_HUB_PRINTF("port %d suspend change\n", i + 1); - usb_clear_port_feature(dev, i + 1, USB_PORT_FEAT_SUSPEND); + usb_clear_port_feature(dev, i + 1, USB_PORT_FEAT_SUSPEND); }
if (portchange & USB_PORT_STAT_C_OVERCURRENT) { @@ -1229,7 +1250,7 @@ int usb_hub_probe(struct usb_device *dev, int ifnum) /* Some hubs have a subclass of 1, which AFAICT according to the */ /* specs is not defined, but it works */ if ((iface->bInterfaceSubClass != 0) && - (iface->bInterfaceSubClass != 1)) + (iface->bInterfaceSubClass != 1)) return 0; /* Multiple endpoints? What kind of mutant ninja-hub is this? */ if (iface->bNumEndpoints != 1) @@ -1243,10 +1264,8 @@ int usb_hub_probe(struct usb_device *dev, int ifnum) return 0; /* We found a hub */ USB_HUB_PRINTF("USB hub found\n"); - ret=usb_hub_configure(dev); + ret = usb_hub_configure(dev); return ret; }
#endif - -/* EOF */ diff --git a/common/usb_kbd.c b/common/usb_kbd.c index 1703b23..e5cdb43 100644 --- a/common/usb_kbd.c +++ b/common/usb_kbd.c @@ -53,25 +53,25 @@ int overwrite_console (void) #endif
-#define REPEAT_RATE 40/4 /* 40msec -> 25cps */ -#define REPEAT_DELAY 10 /* 10 x REAPEAT_RATE = 400msec */ +#define REPEAT_RATE 40/4 /* 40msec -> 25cps */ +#define REPEAT_DELAY 10 /* 10 x REAPEAT_RATE = 400msec */
#define NUM_LOCK 0x53 -#define CAPS_LOCK 0x39 -#define SCROLL_LOCK 0x47 +#define CAPS_LOCK 0x39 +#define SCROLL_LOCK 0x47
/* Modifier bits */ -#define LEFT_CNTR 0 +#define LEFT_CNTR 0 #define LEFT_SHIFT 1 -#define LEFT_ALT 2 -#define LEFT_GUI 3 +#define LEFT_ALT 2 +#define LEFT_GUI 3 #define RIGHT_CNTR 4 #define RIGHT_SHIFT 5 -#define RIGHT_ALT 6 -#define RIGHT_GUI 7 +#define RIGHT_ALT 6 +#define RIGHT_GUI 7
-#define USB_KBD_BUFFER_LEN 0x20 /* size of the keyboardbuffer */ +#define USB_KBD_BUFFER_LEN 0x20 /* size of the keyboardbuffer */
static volatile char usb_kbd_buffer[USB_KBD_BUFFER_LEN]; static volatile int usb_in_pointer = 0; @@ -103,18 +103,17 @@ static unsigned char usb_kbd_numkey_shifted[] = { /* puts character in the queue and sets up the in and out pointer */ static void usb_kbd_put_queue(char data) { - if((usb_in_pointer+1)==USB_KBD_BUFFER_LEN) { - if(usb_out_pointer==0) { + if((usb_in_pointer + 1) == USB_KBD_BUFFER_LEN) { + if(usb_out_pointer == 0) return; /* buffer full */ - } else{ - usb_in_pointer=0; - } + else + usb_in_pointer = 0; } else { - if((usb_in_pointer+1)==usb_out_pointer) + if((usb_in_pointer + 1) == usb_out_pointer) return; /* buffer full */ usb_in_pointer++; } - usb_kbd_buffer[usb_in_pointer]=data; + usb_kbd_buffer[usb_in_pointer] = data; return; }
@@ -124,7 +123,7 @@ static int usb_kbd_testc(void) #ifdef CFG_USB_EVENT_POLL usb_event_poll(); #endif - if(usb_in_pointer==usb_out_pointer) + if(usb_in_pointer == usb_out_pointer) return(0); /* no data */ else return(1); @@ -133,16 +132,17 @@ static int usb_kbd_testc(void) static int usb_kbd_getc(void) { char c; - while(usb_in_pointer==usb_out_pointer) { + + while(usb_in_pointer == usb_out_pointer) { #ifdef CFG_USB_EVENT_POLL usb_event_poll(); #endif } - if((usb_out_pointer+1)==USB_KBD_BUFFER_LEN) - usb_out_pointer=0; + if((usb_out_pointer + 1) == USB_KBD_BUFFER_LEN) + usb_out_pointer = 0; else usb_out_pointer++; - c=usb_kbd_buffer[usb_out_pointer]; + c = usb_kbd_buffer[usb_out_pointer]; return (int)c;
} @@ -153,23 +153,23 @@ static int usb_kbd_probe(struct usb_device *dev, unsigned int ifnum); /* search for keyboard and register it if found */ int drv_usb_kbd_init(void) { - int error,i,index; - device_t usb_kbd_dev,*old_dev; + int error, i, index; + device_t usb_kbd_dev, *old_dev; struct usb_device *dev; - char *stdinname = getenv ("stdin"); + char *stdinname = getenv ("stdin");
- usb_in_pointer=0; - usb_out_pointer=0; + usb_in_pointer = 0; + usb_out_pointer = 0; /* scan all USB Devices */ - for(i=0;i<USB_MAX_DEVICE;i++) { - dev=usb_get_dev_index(i); /* get device */ - if(dev->devnum!=-1) { - if(usb_kbd_probe(dev,0)==1) { /* Ok, we found a keyboard */ + for(i = 0; i < USB_MAX_DEVICE; i++) { + dev = usb_get_dev_index(i); /* get device */ + if(dev->devnum !=- 1) { + if(usb_kbd_probe(dev,0) == 1) { /* Ok, we found a keyboard */ /* check, if it is already registered */ USB_KBD_PRINTF("USB KBD found set up device.\n"); - for (index=1; index<=ListNumItems(devlist); index++) { + for (index = 1; index <= ListNumItems(devlist); index++) { old_dev = ListGetPtrToItem(devlist, index); - if(strcmp(old_dev->name,DEVNAME)==0) { + if(strcmp(old_dev->name, DEVNAME) == 0) { /* ok, already registered, just return ok */ USB_KBD_PRINTF("USB KBD is already registered.\n"); return 1; @@ -177,23 +177,23 @@ int drv_usb_kbd_init(void) } /* register the keyboard */ USB_KBD_PRINTF("USB KBD register.\n"); - memset (&usb_kbd_dev, 0, sizeof(device_t)); + memset(&usb_kbd_dev, 0, sizeof(device_t)); strcpy(usb_kbd_dev.name, DEVNAME); - usb_kbd_dev.flags = DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; + usb_kbd_dev.flags = DEV_FLAGS_INPUT | DEV_FLAGS_SYSTEM; usb_kbd_dev.putc = NULL; usb_kbd_dev.puts = NULL; usb_kbd_dev.getc = usb_kbd_getc; usb_kbd_dev.tstc = usb_kbd_testc; - error = device_register (&usb_kbd_dev); - if(error==0) { + error = device_register(&usb_kbd_dev); + if(error == 0) { /* check if this is the standard input device */ - if(strcmp(stdinname,DEVNAME)==0) { + if(strcmp(stdinname, DEVNAME) == 0) { /* reassign the console */ - if(overwrite_console()) { + if(overwrite_console()) return 1; - } - error=console_assign(stdin,DEVNAME); - if(error==0) + + error = console_assign(stdin, DEVNAME); + if(error == 0) return 1; else return error; @@ -208,7 +208,6 @@ int drv_usb_kbd_init(void) return -1; }
- /* deregistering the keyboard */ int usb_kbd_deregister(void) { @@ -226,78 +225,81 @@ int usb_kbd_deregister(void) static void usb_kbd_setled(struct usb_device *dev) { struct usb_interface_descriptor *iface; + iface = &dev->config.if_desc[0]; - leds=0; - if(scroll_lock!=0) - leds|=1; - leds<<=1; - if(caps_lock!=0) - leds|=1; - leds<<=1; - if(num_lock!=0) - leds|=1; + leds = 0; + if(scroll_lock != 0) + leds |= 1; + leds <<= 1; + if(caps_lock != 0) + leds |= 1; + leds <<= 1; + if(num_lock != 0) + leds |= 1; usb_control_msg(dev, usb_sndctrlpipe(dev, 0), USB_REQ_SET_REPORT, USB_TYPE_CLASS | USB_RECIP_INTERFACE, - 0x200, iface->bInterfaceNumber,(void *)&leds, 1, 0); + 0x200, iface->bInterfaceNumber, (void *)&leds, 1, 0);
#define CAPITAL_MASK 0x20 /* Translate the scancode in ASCII */ -static int usb_kbd_translate(unsigned char scancode,unsigned char modifier,int pressed) +static int usb_kbd_translate(unsigned char scancode, unsigned char modifier, int pressed) { unsigned char keycode;
- if(pressed==0) { + if(pressed == 0) { /* key released */ - repeat_delay=0; + repeat_delay = 0; return 0; } - if(pressed==2) { + if(pressed == 2) { repeat_delay++; - if(repeat_delay<REPEAT_DELAY) + if(repeat_delay < REPEAT_DELAY) return 0; - repeat_delay=REPEAT_DELAY; + repeat_delay = REPEAT_DELAY; } - keycode=0; - if((scancode>3) && (scancode<=0x1d)) { /* alpha numeric values */ - keycode=scancode-4 + 0x61; + keycode = 0; + if((scancode > 3) && (scancode <= 0x1d)) { /* alpha numeric values */ + keycode = scancode - 4 + 0x61; if(caps_lock) - keycode&=~CAPITAL_MASK; /* switch to capital Letters */ - if(((modifier&(1<<LEFT_SHIFT))!=0)||((modifier&(1<<RIGHT_SHIFT))!=0)) { + keycode &= ~CAPITAL_MASK; /* switch to capital Letters */ + if(((modifier&(1 << LEFT_SHIFT)) != 0) || + ((modifier&(1 << RIGHT_SHIFT)) != 0)) { if(keycode & CAPITAL_MASK) - keycode&=~CAPITAL_MASK; /* switch to capital Letters */ + keycode& = ~CAPITAL_MASK; /* switch to capital Letters */ else - keycode|=CAPITAL_MASK; /* switch to non capital Letters */ + keycode |= CAPITAL_MASK; /* switch to non capital Letters */ } } - if((scancode>0x1d) && (scancode<0x3A)) { - if(((modifier&(1<<LEFT_SHIFT))!=0)||((modifier&(1<<RIGHT_SHIFT))!=0)) /* shifted */ - keycode=usb_kbd_numkey_shifted[scancode-0x1e]; + if((scancode > 0x1d) && (scancode < 0x3A)) { + if(((modifier&(1 << LEFT_SHIFT)) != 0) || + ((modifier&(1 << RIGHT_SHIFT)) != 0)) /* shifted */ + keycode = usb_kbd_numkey_shifted[scancode - 0x1e]; else /* non shifted */ - keycode=usb_kbd_numkey[scancode-0x1e]; + keycode = usb_kbd_numkey[scancode - 0x1e]; }
if (ctrl) keycode = scancode - 0x3;
- if(pressed==1) { - if(scancode==NUM_LOCK) { - num_lock=~num_lock; + if(pressed == 1) { + if(scancode == NUM_LOCK) { + num_lock = ~num_lock; return 1; } - if(scancode==CAPS_LOCK) { - caps_lock=~caps_lock; + if(scancode == CAPS_LOCK) { + caps_lock = ~caps_lock; return 1; } - if(scancode==SCROLL_LOCK) { - scroll_lock=~scroll_lock; + if(scancode == SCROLL_LOCK) { + scroll_lock = ~scroll_lock; return 1; } } - if(keycode!=0) { - USB_KBD_PRINTF("%c",keycode); + if(keycode != 0) { + USB_KBD_PRINTF("%c", keycode); usb_kbd_put_queue(keycode); } return 0; @@ -306,14 +308,15 @@ static int usb_kbd_translate(unsigned char scancode,unsigned char modifier,int p /* Interrupt service routine */ static int usb_kbd_irq(struct usb_device *dev) { - int i,res; + int i, res;
- if((dev->irq_status!=0)||(dev->irq_act_len!=8)) + if((dev->irq_status != 0) || (dev->irq_act_len != 8)) { - USB_KBD_PRINTF("usb_keyboard Error %lX, len %d\n",dev->irq_status,dev->irq_act_len); + USB_KBD_PRINTF("usb_keyboard Error %lX, len %d\n", + dev->irq_status, dev->irq_act_len); return 1; } - res=0; + res = 0;
switch (new[0]) { case 0x0: /* No combo key pressed */ @@ -326,18 +329,18 @@ static int usb_kbd_irq(struct usb_device *dev) }
for (i = 2; i < 8; i++) { - if (old[i] > 3 && memscan(&new[2], old[i], 6) == &new[8]) { - res|=usb_kbd_translate(old[i],new[0],0); - } - if (new[i] > 3 && memscan(&old[2], new[i], 6) == &old[8]) { - res|=usb_kbd_translate(new[i],new[0],1); - } + if (old[i] > 3 && memscan(&new[2], old[i], 6) == &new[8]) + res |= usb_kbd_translate(old[i], new[0], 0); + + if (new[i] > 3 && memscan(&old[2], new[i], 6) == &old[8]) + res |= usb_kbd_translate(new[i], new[0], 1); + } - if((new[2]>3) && (old[2]==new[2])) /* still pressed */ - res|=usb_kbd_translate(new[2],new[0],2); - if(res==1) + if((new[2] > 3) && (old[2] == new[2])) /* still pressed */ + res |= usb_kbd_translate(new[2], new[0], 2); + if(res == 1) usb_kbd_setled(dev); - memcpy(&old[0],&new[0], 8); + memcpy(&old[0], &new[0], 8); return 1; /* install IRQ Handler again */ }
@@ -346,20 +349,27 @@ static int usb_kbd_probe(struct usb_device *dev, unsigned int ifnum) { struct usb_interface_descriptor *iface; struct usb_endpoint_descriptor *ep; - int pipe,maxp; + int pipe, maxp;
- if (dev->descriptor.bNumConfigurations != 1) return 0; + if (dev->descriptor.bNumConfigurations != 1) + return 0; iface = &dev->config.if_desc[ifnum];
- if (iface->bInterfaceClass != 3) return 0; - if (iface->bInterfaceSubClass != 1) return 0; - if (iface->bInterfaceProtocol != 1) return 0; - if (iface->bNumEndpoints != 1) return 0; + if (iface->bInterfaceClass != 3) + return 0; + if (iface->bInterfaceSubClass != 1) + return 0; + if (iface->bInterfaceProtocol != 1) + return 0; + if (iface->bNumEndpoints != 1) + return 0;
ep = &iface->ep_desc[0];
- if (!(ep->bEndpointAddress & 0x80)) return 0; - if ((ep->bmAttributes & 3) != 3) return 0; + if (!(ep->bEndpointAddress & 0x80)) + return 0; + if ((ep->bmAttributes & 3) != 3) + return 0; USB_KBD_PRINTF("USB KBD found set protocol...\n"); /* ok, we found a USB Keyboard, install it */ /* usb_kbd_get_hid_desc(dev); */ @@ -368,24 +378,23 @@ static int usb_kbd_probe(struct usb_device *dev, unsigned int ifnum) usb_set_idle(dev, iface->bInterfaceNumber, REPEAT_RATE, 0); memset(&new[0], 0, 8); memset(&old[0], 0, 8); - repeat_delay=0; + repeat_delay = 0; pipe = usb_rcvintpipe(dev, ep->bEndpointAddress); maxp = usb_maxpacket(dev, pipe); - dev->irq_handle=usb_kbd_irq; + dev->irq_handle = usb_kbd_irq; USB_KBD_PRINTF("USB KBD enable interrupt pipe...\n"); - usb_submit_int_msg(dev,pipe,&new[0], maxp > 8 ? 8 : maxp,ep->bInterval); + usb_submit_int_msg(dev, pipe, &new[0], maxp > 8 ? 8 : maxp, ep->bInterval); return 1; }
- #if 0 struct usb_hid_descriptor { - unsigned char bLength; - unsigned char bDescriptorType; /* 0x21 for HID */ + unsigned char bLength; + unsigned char bDescriptorType; /* 0x21 for HID */ unsigned short bcdHID; /* release number */ - unsigned char bCountryCode; - unsigned char bNumDescriptors; - unsigned char bReportDescriptorType; + unsigned char bCountryCode; + unsigned char bNumDescriptors; + unsigned char bReportDescriptorType; unsigned short wDescriptorLength; } __attribute__ ((packed));
@@ -401,13 +410,13 @@ struct hid_item { unsigned char type; unsigned char tag; union { - unsigned char u8; - char s8; - unsigned short u16; - short s16; - unsigned long u32; - long s32; - unsigned char *longdata; + unsigned char u8; + char s8; + unsigned short u16; + short s16; + unsigned long u32; + long s32; + unsigned char *longdata; } data; };
@@ -430,15 +439,14 @@ static struct usb_hid_descriptor usb_kbd_hid_desc; void usb_kbd_display_hid(struct usb_hid_descriptor *hid) { printf("USB_HID_DESC:\n"); - printf(" bLenght 0x%x\n",hid->bLength); - printf(" bcdHID 0x%x\n",hid->bcdHID); - printf(" bCountryCode %d\n",hid->bCountryCode); - printf(" bNumDescriptors 0x%x\n",hid->bNumDescriptors); - printf(" bReportDescriptorType 0x%x\n",hid->bReportDescriptorType); - printf(" wDescriptorLength 0x%x\n",hid->wDescriptorLength); + printf(" bLenght 0x%x\n", hid->bLength); + printf(" bcdHID 0x%x\n", hid->bcdHID); + printf(" bCountryCode %d\n", hid->bCountryCode); + printf(" bNumDescriptors 0x%x\n", hid->bNumDescriptors); + printf(" bReportDescriptorType 0x%x\n", hid->bReportDescriptorType); + printf(" wDescriptorLength 0x%x\n", hid->wDescriptorLength); }
- /* * Fetch a report description item from the data stream. We support long * items, though they are not used yet. @@ -449,12 +457,12 @@ static int fetch_item(unsigned char *start,unsigned char *end, struct hid_item * if((end - start) > 0) { unsigned char b = *start++; item->type = (b >> 2) & 3; - item->tag = (b >> 4) & 15; + item->tag = (b >> 4) & 15; if (item->tag == HID_ITEM_TAG_LONG) { item->format = HID_ITEM_FORMAT_LONG; if ((end - start) >= 2) { item->size = *start++; - item->tag = *start++; + item->tag = *start++; if ((end - start) >= item->size) { item->data.longdata = start; start += item->size; @@ -476,14 +484,14 @@ static int fetch_item(unsigned char *start,unsigned char *end, struct hid_item * case 2: if ((end - start) >= 2) { item->data.u16 = swap_16((unsigned short *)start); - start+=2; + start += 2; return item->size; } case 3: item->size++; if ((end - start) >= 4) { item->data.u32 = swap_32((unsigned long *)start); - start+=4; + start += 4; return item->size; } } @@ -584,7 +592,7 @@ static void usb_kbd_show_item(struct hid_item *item) printf("Main End Collection"); break; default: - printf("Main reserved %d",item->tag); + printf("Main reserved %d", item->tag); break; } break; @@ -692,36 +700,36 @@ static int usb_kbd_get_hid_desc(struct usb_device *dev) unsigned char buffer[256]; struct usb_descriptor_header *head; struct usb_config_descriptor *config; - int index,len,i; + int index, len, i; unsigned char *start, *end; struct hid_item item;
- if(usb_get_configuration_no(dev,&buffer[0],0)==-1) + if(usb_get_configuration_no(dev, &buffer[0], 0) == -1) return -1; - head =(struct usb_descriptor_header *)&buffer[0]; - if(head->bDescriptorType!=USB_DT_CONFIG) { - printf(" ERROR: NOT USB_CONFIG_DESC %x\n",head->bDescriptorType); + head = (struct usb_descriptor_header *)&buffer[0]; + if(head->bDescriptorType != USB_DT_CONFIG) { + printf(" ERROR: NOT USB_CONFIG_DESC %x\n", head->bDescriptorType); return -1; } - index=head->bLength; - config=(struct usb_config_descriptor *)&buffer[0]; - len=swap_16(config->wTotalLength); + index = head->bLength; + config = (struct usb_config_descriptor *)&buffer[0]; + len = swap_16(config->wTotalLength); /* Ok the first entry must be a configuration entry, now process the others */ - head=(struct usb_descriptor_header *)&buffer[index]; - while(index+1 < len) { - if(head->bDescriptorType==USB_DT_HID) { + head = (struct usb_descriptor_header *)&buffer[index]; + while(index + 1 < len) { + if(head->bDescriptorType == USB_DT_HID) { printf("HID desc found\n"); - memcpy(&usb_kbd_hid_desc,&buffer[index],buffer[index]); - usb_kbd_hid_desc.bcdHID=swap_16(usb_kbd_hid_desc.bcdHID); + memcpy(&usb_kbd_hid_desc, &buffer[index], buffer[index]); + usb_kbd_hid_desc.bcdHID = swap_16(usb_kbd_hid_desc.bcdHID); usb_kbd_hid_desc.wDescriptorLength=swap_16(usb_kbd_hid_desc.wDescriptorLength); usb_kbd_display_hid(&usb_kbd_hid_desc); - len=0; + len = 0; break; } - index+=head->bLength; - head=(struct usb_descriptor_header *)&buffer[index]; + index += head->bLength; + head = (struct usb_descriptor_header *)&buffer[index]; } - if(len>0) + if(len > 0) return -1; len=usb_kbd_hid_desc.wDescriptorLength; if((index = usb_get_class_descriptor(dev, 0, USB_DT_REPORT, 0, &buffer[0], len)) < 0) { @@ -729,23 +737,22 @@ static int usb_kbd_get_hid_desc(struct usb_device *dev) return -1; } printf(" report descriptor (size %u, read %d)\n", len, index); - start=&buffer[0]; - end=&buffer[len]; - i=0; + start = &buffer[0]; + end = &buffer[len]; + i = 0; do { - index=fetch_item(start,end,&item); - i+=index; + index = fetch_item(start, end, &item); + i += index; i++; - if(index>=0) + if(index >= 0) usb_kbd_show_item(&item);
- start+=index; + start += index; start++; - } while(index>=0); + } while(index >= 0);
- #endif
#endif /* CONFIG_USB_KEYBOARD */
In message 1211311182-27504-1-git-send-email-plagnioj@jcrosoft.com you wrote:
Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD plagnioj@jcrosoft.com
common/cmd_usb.c | 261 ++++++++++++++++++++----------------- common/usb.c | 385 ++++++++++++++++++++++++++++-------------------------- common/usb_kbd.c | 317 +++++++++++++++++++++++---------------------- 3 files changed, 506 insertions(+), 457 deletions(-)
Sorry, this patch fails bacause of (expected, and announced) conflicts with the "Big white-space cleanup" patch.
Please rebase.
Wolfgang Denk wd@denx.de writes:
Please rebase.
Wolfgang, I'll pick this one up.
Best regards
Markus Klotzbuecher
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-0 Fax: +49-8142-66989-80 Email: office@denx.de
Markus Klotzbücher
