[PATCH v2 0/8] net: tcp: improve tcp support
This series of patches greatly improve TCP support.
The benefits: * a lot of bug was fixed * tcp cliens becomes smaller/simpler * fix data uploading (now it's possible to transmit a huge array of data from the board to external server) * data downloading/uploading with netcat over tcp was added
Mikhail Kshevetskiy (9): net/tcp: fix TCP options processing net/tcp: fix selective acknowledge net/tcp: put connection specific data into a tcp_stream structure net/tcp: add connection info to tcp_stream structure net/tcp: rename ack_edge and seq_init to more common rcv_nxt and irs net/tcp: improve tcp framework, use better state machine net/tcp: simplify tcp header filling code net/tcp: define a fallback value for rcv_wnd size net/netcat: add netcat over tcp support
cmd/Kconfig | 7 + cmd/net.c | 34 +- include/net.h | 7 +- include/net/netcat.h | 20 + include/net/tcp.h | 227 +++++++- include/net/wget.h | 8 - net/Makefile | 1 + net/fastboot_tcp.c | 190 +++---- net/net.c | 30 +- net/netcat.c | 159 ++++++ net/tcp.c | 1253 +++++++++++++++++++++++++++++------------- net/wget.c | 479 +++++----------- 12 files changed, 1538 insertions(+), 877 deletions(-) create mode 100644 include/net/netcat.h create mode 100644 net/netcat.c
Current TCP code may miss an option if TCP_O_NOP option was used before it for proper aligning.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- net/tcp.c | 6 ++++-- 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/net/tcp.c b/net/tcp.c index a713e1dd609..c9bcd364ee3 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -476,7 +476,7 @@ void tcp_parse_options(uchar *o, int o_len) * NOPs are options with a zero length, and thus are special. * All other options have length fields. */ - for (p = o; p < (o + o_len); p = p + p[1]) { + for (p = o; p < (o + o_len); ) { if (!p[1]) return; /* Finished processing options */
@@ -491,12 +491,14 @@ void tcp_parse_options(uchar *o, int o_len) case TCP_O_TS: tsopt = (struct tcp_t_opt *)p; rmt_timestamp = tsopt->t_snd; - return; + break; }
/* Process optional NOPs */ if (p[0] == TCP_O_NOP) p++; + else + p += p[1]; } }
Current code assume that all (except last) packets are of the same size. This is definitely wrong. Replace SACK code with a new one, that does not rely on this assumption. Also this code uses less memory.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- net/tcp.c | 200 +++++++++++++++++++++++------------------------------- 1 file changed, 86 insertions(+), 114 deletions(-)
diff --git a/net/tcp.c b/net/tcp.c index c9bcd364ee3..228e1e4872c 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -39,21 +39,6 @@ static u32 tcp_ack_edge;
static int tcp_activity_count;
-/* - * Search for TCP_SACK and review the comments before the code section - * TCP_SACK is the number of packets at the front of the stream - */ - -enum pkt_state {PKT, NOPKT}; -struct sack_r { - struct sack_edges se; - enum pkt_state st; -}; - -static struct sack_r edge_a[TCP_SACK]; -static unsigned int sack_idx; -static unsigned int prev_len; - /* * TCP lengths are stored as a rounded up number of 32 bit words. * Add 3 to length round up, rounded, then divided into the @@ -70,6 +55,11 @@ static enum tcp_state current_tcp_state; /* Current TCP RX packet handler */ static rxhand_tcp *tcp_packet_handler;
+static inline s32 tcp_seq_cmp(u32 a, u32 b) +{ + return (s32)(a - b); +} + /** * tcp_get_tcp_state() - get current TCP state * @@ -268,6 +258,7 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, action = TCP_FIN; current_tcp_state = TCP_FIN_WAIT_1; } else { + tcp_lost.len = TCP_OPT_LEN_2; current_tcp_state = TCP_SYN_SENT; } break; @@ -354,6 +345,20 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, return pkt_hdr_len; }
+static void tcp_update_ack_edge(void) +{ + if (tcp_seq_cmp(tcp_ack_edge, tcp_lost.hill[0].l) >= 0) { + tcp_ack_edge = tcp_lost.hill[0].r; + + memmove(&tcp_lost.hill[0], &tcp_lost.hill[1], + (TCP_SACK_HILLS - 1) * sizeof(struct sack_edges)); + + tcp_lost.len -= TCP_OPT_LEN_8; + tcp_lost.hill[TCP_SACK_HILLS - 1].l = TCP_O_NOP; + tcp_lost.hill[TCP_SACK_HILLS - 1].r = TCP_O_NOP; + } +} + /** * tcp_hole() - Selective Acknowledgment (Essential for fast stream transfer) * @tcp_seq_num: TCP sequence start number @@ -361,106 +366,79 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, */ void tcp_hole(u32 tcp_seq_num, u32 len) { - u32 idx_sack, sack_in; - u32 sack_end = TCP_SACK - 1; - u32 hill = 0; - enum pkt_state expect = PKT; - u32 seq = tcp_seq_num - tcp_seq_init; - u32 hol_l = tcp_ack_edge - tcp_seq_init; - u32 hol_r = 0; - - /* Place new seq number in correct place in receive array */ - if (prev_len == 0) - prev_len = len; - - idx_sack = sack_idx + ((tcp_seq_num - tcp_ack_edge) / prev_len); - if (idx_sack < TCP_SACK) { - edge_a[idx_sack].se.l = tcp_seq_num; - edge_a[idx_sack].se.r = tcp_seq_num + len; - edge_a[idx_sack].st = PKT; + int i, j, cnt, cnt_move;
- /* - * The fin (last) packet is not the same length as data - * packets, and if it's length is recorded and used for - * array index calculation, calculation breaks. - */ - if (prev_len < len) - prev_len = len; - } + cnt = (tcp_lost.len - TCP_OPT_LEN_2) / TCP_OPT_LEN_8; + for (i = 0; i < cnt; i++) { + if (tcp_seq_cmp(tcp_lost.hill[i].r, tcp_seq_num) < 0) + continue; + if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num + len) > 0) + break;
- debug_cond(DEBUG_DEV_PKT, - "TCP 1 seq %d, edg %d, len %d, sack_idx %d, sack_end %d\n", - seq, hol_l, len, sack_idx, sack_end); + if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num) > 0) + tcp_lost.hill[i].l = tcp_seq_num; + if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num) < 0) { + len += tcp_seq_num - tcp_lost.hill[i].l; + tcp_seq_num = tcp_lost.hill[i].l; + } + if (tcp_seq_cmp(tcp_lost.hill[i].r, tcp_seq_num + len) >= 0) { + tcp_update_ack_edge(); + return; + }
- /* Right edge of contiguous stream, is the left edge of first hill */ - hol_l = tcp_seq_num - tcp_seq_init; - hol_r = hol_l + len; + /* check overlapping with next hills */ + cnt_move = 0; + tcp_lost.hill[i].r = tcp_seq_num + len; + for (j = i + 1; j < cnt; j++) { + if (tcp_seq_cmp(tcp_lost.hill[j].l, tcp_lost.hill[i].r) > 0) + break;
- if (IS_ENABLED(CONFIG_PROT_TCP_SACK)) - tcp_lost.len = TCP_OPT_LEN_2; + tcp_lost.hill[i].r = tcp_lost.hill[j].r; + cnt_move++; + }
- debug_cond(DEBUG_DEV_PKT, - "TCP 1 in %d, seq %d, pkt_l %d, pkt_r %d, sack_idx %d, sack_end %d\n", - idx_sack, seq, hol_l, hol_r, sack_idx, sack_end); - - for (sack_in = sack_idx; sack_in < sack_end && hill < TCP_SACK_HILLS; - sack_in++) { - switch (expect) { - case NOPKT: - switch (edge_a[sack_in].st) { - case NOPKT: - debug_cond(DEBUG_INT_STATE, "N"); - break; - case PKT: - debug_cond(DEBUG_INT_STATE, "n"); - if (IS_ENABLED(CONFIG_PROT_TCP_SACK)) { - tcp_lost.hill[hill].l = - edge_a[sack_in].se.l; - tcp_lost.hill[hill].r = - edge_a[sack_in].se.r; - } - expect = PKT; - break; - } - break; - case PKT: - switch (edge_a[sack_in].st) { - case NOPKT: - debug_cond(DEBUG_INT_STATE, "p"); - if (sack_in > sack_idx && - hill < TCP_SACK_HILLS) { - hill++; - if (IS_ENABLED(CONFIG_PROT_TCP_SACK)) - tcp_lost.len += TCP_OPT_LEN_8; - } - expect = NOPKT; - break; - case PKT: - debug_cond(DEBUG_INT_STATE, "P"); - - if (tcp_ack_edge == edge_a[sack_in].se.l) { - tcp_ack_edge = edge_a[sack_in].se.r; - edge_a[sack_in].st = NOPKT; - sack_idx++; - } else { - if (IS_ENABLED(CONFIG_PROT_TCP_SACK) && - hill < TCP_SACK_HILLS) - tcp_lost.hill[hill].r = - edge_a[sack_in].se.r; - if (IS_ENABLED(CONFIG_PROT_TCP_SACK) && - sack_in == sack_end - 1) - tcp_lost.hill[hill].r = - edge_a[sack_in].se.r; - } - break; + if (cnt_move > 0) { + if (cnt > i + cnt_move + 1) + memmove(&tcp_lost.hill[i + 1], + &tcp_lost.hill[i + cnt_move + 1], + cnt_move * sizeof(struct sack_edges)); + + cnt -= cnt_move; + tcp_lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8; + for (j = cnt; j < TCP_SACK_HILLS; j++) { + tcp_lost.hill[j].l = TCP_O_NOP; + tcp_lost.hill[j].r = TCP_O_NOP; } - break; } + + tcp_update_ack_edge(); + return; } - debug_cond(DEBUG_INT_STATE, "\n"); - if (!IS_ENABLED(CONFIG_PROT_TCP_SACK) || tcp_lost.len <= TCP_OPT_LEN_2) - sack_idx = 0; -} + + if (i == TCP_SACK_HILLS) { + tcp_update_ack_edge(); + return; + } + + if (cnt < TCP_SACK_HILLS) { + cnt_move = cnt - i; + cnt++; + } else { + cnt = TCP_SACK_HILLS; + cnt_move = TCP_SACK_HILLS - i; + } + + if (cnt_move > 0) + memmove(&tcp_lost.hill[i + 1], + &tcp_lost.hill[i], + cnt_move * sizeof(struct sack_edges)); + + tcp_lost.hill[i].l = tcp_seq_num; + tcp_lost.hill[i].r = tcp_seq_num + len; + tcp_lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8; + + tcp_update_ack_edge(); +};
/** * tcp_parse_options() - parsing TCP options @@ -510,7 +488,6 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) u8 tcp_push = tcp_flags & TCP_PUSH; u8 tcp_ack = tcp_flags & TCP_ACK; u8 action = TCP_DATA; - int i;
/* * tcp_flags are examined to determine TX action in a given state @@ -537,6 +514,7 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) action = TCP_SYN | TCP_ACK; tcp_seq_init = tcp_seq_num; tcp_ack_edge = tcp_seq_num + 1; + tcp_lost.len = TCP_OPT_LEN_2; current_tcp_state = TCP_SYN_RECEIVED; } else if (tcp_ack || tcp_fin) { action = TCP_DATA; @@ -553,13 +531,7 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) action |= TCP_ACK; tcp_seq_init = tcp_seq_num; tcp_ack_edge = tcp_seq_num + 1; - sack_idx = 0; - edge_a[sack_idx].se.l = tcp_ack_edge; - edge_a[sack_idx].se.r = tcp_ack_edge; - prev_len = 0; current_tcp_state = TCP_ESTABLISHED; - for (i = 0; i < TCP_SACK; i++) - edge_a[i].st = NOPKT;
if (tcp_syn && tcp_ack) action |= TCP_PUSH;
no functional changes
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- include/net/tcp.h | 37 +++++++- net/net.c | 11 ++- net/tcp.c | 231 +++++++++++++++++++++++----------------------- net/wget.c | 3 +- 4 files changed, 163 insertions(+), 119 deletions(-)
diff --git a/include/net/tcp.h b/include/net/tcp.h index c29d4ce24a7..14aee64cb1c 100644 --- a/include/net/tcp.h +++ b/include/net/tcp.h @@ -277,9 +277,40 @@ enum tcp_state { TCP_FIN_WAIT_2 };
-enum tcp_state tcp_get_tcp_state(void); -void tcp_set_tcp_state(enum tcp_state new_state); -int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, +/** + * struct tcp_stream - TCP data stream structure + * + * @state: TCP connection state + * + * @seq_init: Initial receive sequence number + * @ack_edge: Receive next + * + * @loc_timestamp: Local timestamp + * @rmt_timestamp: Remote timestamp + * + * @lost: Used for SACK + */ +struct tcp_stream { + /* TCP connection state */ + enum tcp_state state; + + u32 seq_init; + u32 ack_edge; + + /* TCP option timestamp */ + u32 loc_timestamp; + u32 rmt_timestamp; + + /* TCP sliding window control used to request re-TX */ + struct tcp_sack_v lost; +}; + +struct tcp_stream *tcp_stream_get(void); + +enum tcp_state tcp_get_tcp_state(struct tcp_stream *tcp); +void tcp_set_tcp_state(struct tcp_stream *tcp, enum tcp_state new_state); +int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, + int sport, int payload_len, u8 action, u32 tcp_seq_num, u32 tcp_ack_num);
/** diff --git a/net/net.c b/net/net.c index 0fb2d250773..8f076fa18e3 100644 --- a/net/net.c +++ b/net/net.c @@ -416,7 +416,7 @@ int net_init(void) /* Only need to setup buffer pointers once. */ first_call = 0; if (IS_ENABLED(CONFIG_PROT_TCP)) - tcp_set_tcp_state(TCP_CLOSED); + tcp_set_tcp_state(tcp_stream_get(), TCP_CLOSED); }
return net_init_loop(); @@ -917,6 +917,9 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, uchar *pkt; int eth_hdr_size; int pkt_hdr_size; +#if defined(CONFIG_PROT_TCP) + struct tcp_stream *tcp; +#endif
/* make sure the net_tx_packet is initialized (net_init() was called) */ assert(net_tx_packet != NULL); @@ -943,8 +946,12 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, break; #if defined(CONFIG_PROT_TCP) case IPPROTO_TCP: + tcp = tcp_stream_get(); + if (tcp == NULL) + return -EINVAL; + pkt_hdr_size = eth_hdr_size - + tcp_set_tcp_header(pkt + eth_hdr_size, dport, sport, + + tcp_set_tcp_header(tcp, pkt + eth_hdr_size, dport, sport, payload_len, action, tcp_seq_num, tcp_ack_num); break; diff --git a/net/tcp.c b/net/tcp.c index 228e1e4872c..80a161838f5 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -25,19 +25,8 @@ #include <net.h> #include <net/tcp.h>
-/* - * TCP sliding window control used by us to request re-TX - */ -static struct tcp_sack_v tcp_lost; - -/* TCP option timestamp */ -static u32 loc_timestamp; -static u32 rmt_timestamp; - -static u32 tcp_seq_init; -static u32 tcp_ack_edge; - static int tcp_activity_count; +static struct tcp_stream tcp_stream;
/* * TCP lengths are stored as a rounded up number of 32 bit words. @@ -49,9 +38,6 @@ static int tcp_activity_count; #define SHIFT_TO_TCPHDRLEN_FIELD(x) ((x) << 4) #define GET_TCP_HDR_LEN_IN_BYTES(x) ((x) >> 2)
-/* TCP connection state */ -static enum tcp_state current_tcp_state; - /* Current TCP RX packet handler */ static rxhand_tcp *tcp_packet_handler;
@@ -61,22 +47,30 @@ static inline s32 tcp_seq_cmp(u32 a, u32 b) }
/** - * tcp_get_tcp_state() - get current TCP state + * tcp_get_tcp_state() - get TCP stream state + * @tcp: tcp stream * - * Return: Current TCP state + * Return: TCP stream state */ -enum tcp_state tcp_get_tcp_state(void) +enum tcp_state tcp_get_tcp_state(struct tcp_stream *tcp) { - return current_tcp_state; + return tcp->state; }
/** - * tcp_set_tcp_state() - set current TCP state + * tcp_set_tcp_state() - set TCP stream state + * @tcp: tcp stream * @new_state: new TCP state */ -void tcp_set_tcp_state(enum tcp_state new_state) +void tcp_set_tcp_state(struct tcp_stream *tcp, + enum tcp_state new_state) { - current_tcp_state = new_state; + tcp->state = new_state; +} + +struct tcp_stream *tcp_stream_get(void) +{ + return &tcp_stream; }
static void dummy_handler(uchar *pkt, u16 dport, @@ -139,29 +133,30 @@ u16 tcp_set_pseudo_header(uchar *pkt, struct in_addr src, struct in_addr dest,
/** * net_set_ack_options() - set TCP options in acknowledge packets + * @tcp: tcp stream * @b: the packet * * Return: TCP header length */ -int net_set_ack_options(union tcp_build_pkt *b) +int net_set_ack_options(struct tcp_stream *tcp, union tcp_build_pkt *b) { b->sack.hdr.tcp_hlen = SHIFT_TO_TCPHDRLEN_FIELD(LEN_B_TO_DW(TCP_HDR_SIZE));
b->sack.t_opt.kind = TCP_O_TS; b->sack.t_opt.len = TCP_OPT_LEN_A; - b->sack.t_opt.t_snd = htons(loc_timestamp); - b->sack.t_opt.t_rcv = rmt_timestamp; + b->sack.t_opt.t_snd = htons(tcp->loc_timestamp); + b->sack.t_opt.t_rcv = tcp->rmt_timestamp; b->sack.sack_v.kind = TCP_1_NOP; b->sack.sack_v.len = 0;
if (IS_ENABLED(CONFIG_PROT_TCP_SACK)) { - if (tcp_lost.len > TCP_OPT_LEN_2) { + if (tcp->lost.len > TCP_OPT_LEN_2) { debug_cond(DEBUG_DEV_PKT, "TCP ack opt lost.len %x\n", - tcp_lost.len); - b->sack.sack_v.len = tcp_lost.len; + tcp->lost.len); + b->sack.sack_v.len = tcp->lost.len; b->sack.sack_v.kind = TCP_V_SACK; - b->sack.sack_v.hill[0].l = htonl(tcp_lost.hill[0].l); - b->sack.sack_v.hill[0].r = htonl(tcp_lost.hill[0].r); + b->sack.sack_v.hill[0].l = htonl(tcp->lost.hill[0].l); + b->sack.sack_v.hill[0].r = htonl(tcp->lost.hill[0].r);
/* * These SACK structures are initialized with NOPs to @@ -169,17 +164,17 @@ int net_set_ack_options(union tcp_build_pkt *b) * SACK structures used for both header padding and * internally. */ - b->sack.sack_v.hill[1].l = htonl(tcp_lost.hill[1].l); - b->sack.sack_v.hill[1].r = htonl(tcp_lost.hill[1].r); - b->sack.sack_v.hill[2].l = htonl(tcp_lost.hill[2].l); - b->sack.sack_v.hill[2].r = htonl(tcp_lost.hill[2].r); + b->sack.sack_v.hill[1].l = htonl(tcp->lost.hill[1].l); + b->sack.sack_v.hill[1].r = htonl(tcp->lost.hill[1].r); + b->sack.sack_v.hill[2].l = htonl(tcp->lost.hill[2].l); + b->sack.sack_v.hill[2].r = htonl(tcp->lost.hill[2].r); b->sack.sack_v.hill[3].l = TCP_O_NOP; b->sack.sack_v.hill[3].r = TCP_O_NOP; }
b->sack.hdr.tcp_hlen = SHIFT_TO_TCPHDRLEN_FIELD(ROUND_TCPHDR_LEN(TCP_HDR_SIZE + TCP_TSOPT_SIZE + - tcp_lost.len)); + tcp->lost.len)); } else { b->sack.sack_v.kind = 0; b->sack.hdr.tcp_hlen = SHIFT_TO_TCPHDRLEN_FIELD(ROUND_TCPHDR_LEN(TCP_HDR_SIZE + @@ -195,13 +190,14 @@ int net_set_ack_options(union tcp_build_pkt *b) }
/** - * net_set_ack_options() - set TCP options in SYN packets + * net_set_syn_options() - set TCP options in SYN packets + * @tcp: tcp stream * @b: the packet */ -void net_set_syn_options(union tcp_build_pkt *b) +void net_set_syn_options(struct tcp_stream *tcp, union tcp_build_pkt *b) { if (IS_ENABLED(CONFIG_PROT_TCP_SACK)) - tcp_lost.len = 0; + tcp->lost.len = 0;
b->ip.hdr.tcp_hlen = 0xa0;
@@ -220,14 +216,15 @@ void net_set_syn_options(union tcp_build_pkt *b) } b->ip.t_opt.kind = TCP_O_TS; b->ip.t_opt.len = TCP_OPT_LEN_A; - loc_timestamp = get_ticks(); - rmt_timestamp = 0; + tcp->loc_timestamp = get_ticks(); + tcp->rmt_timestamp = 0; b->ip.t_opt.t_snd = 0; b->ip.t_opt.t_rcv = 0; b->ip.end = TCP_O_END; }
-int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, +int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, + int sport, int payload_len, u8 action, u32 tcp_seq_num, u32 tcp_ack_num) { union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; @@ -250,21 +247,21 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); tcp_activity_count = 0; - net_set_syn_options(b); + net_set_syn_options(tcp, b); tcp_seq_num = 0; tcp_ack_num = 0; pkt_hdr_len = IP_TCP_O_SIZE; - if (current_tcp_state == TCP_SYN_SENT) { /* Too many SYNs */ + if (tcp->state == TCP_SYN_SENT) { /* Too many SYNs */ action = TCP_FIN; - current_tcp_state = TCP_FIN_WAIT_1; + tcp->state = TCP_FIN_WAIT_1; } else { - tcp_lost.len = TCP_OPT_LEN_2; - current_tcp_state = TCP_SYN_SENT; + tcp->lost.len = TCP_OPT_LEN_2; + tcp->state = TCP_SYN_SENT; } break; case TCP_SYN | TCP_ACK: case TCP_ACK: - pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(b); + pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(tcp, b); b->ip.hdr.tcp_flags = action; debug_cond(DEBUG_DEV_PKT, "TCP Hdr:ACK (%pI4, %pI4, s=%u, a=%u, A=%x)\n", @@ -277,20 +274,20 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); payload_len = 0; pkt_hdr_len = IP_TCP_HDR_SIZE; - current_tcp_state = TCP_FIN_WAIT_1; + tcp->state = TCP_FIN_WAIT_1; break; case TCP_RST | TCP_ACK: case TCP_RST: debug_cond(DEBUG_DEV_PKT, "TCP Hdr:RST (%pI4, %pI4, s=%u, a=%u)\n", &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); - current_tcp_state = TCP_CLOSED; + tcp->state = TCP_CLOSED; break; /* Notify connection closing */ case (TCP_FIN | TCP_ACK): case (TCP_FIN | TCP_ACK | TCP_PUSH): - if (current_tcp_state == TCP_CLOSE_WAIT) - current_tcp_state = TCP_CLOSING; + if (tcp->state == TCP_CLOSE_WAIT) + tcp->state = TCP_CLOSING;
debug_cond(DEBUG_DEV_PKT, "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%u, a=%u, A=%x)\n", @@ -298,7 +295,7 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, tcp_seq_num, tcp_ack_num, action); fallthrough; default: - pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(b); + pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(tcp, b); b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; debug_cond(DEBUG_DEV_PKT, "TCP Hdr:dft (%pI4, %pI4, s=%u, a=%u, A=%x)\n", @@ -309,9 +306,9 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, pkt_len = pkt_hdr_len + payload_len; tcp_len = pkt_len - IP_HDR_SIZE;
- tcp_ack_edge = tcp_ack_num; + tcp->ack_edge = tcp_ack_num; /* TCP Header */ - b->ip.hdr.tcp_ack = htonl(tcp_ack_edge); + b->ip.hdr.tcp_ack = htonl(tcp->ack_edge); b->ip.hdr.tcp_src = htons(sport); b->ip.hdr.tcp_dst = htons(dport); b->ip.hdr.tcp_seq = htonl(tcp_seq_num); @@ -345,78 +342,79 @@ int tcp_set_tcp_header(uchar *pkt, int dport, int sport, int payload_len, return pkt_hdr_len; }
-static void tcp_update_ack_edge(void) +static void tcp_update_ack_edge(struct tcp_stream *tcp) { - if (tcp_seq_cmp(tcp_ack_edge, tcp_lost.hill[0].l) >= 0) { - tcp_ack_edge = tcp_lost.hill[0].r; + if (tcp_seq_cmp(tcp->ack_edge, tcp->lost.hill[0].l) >= 0) { + tcp->ack_edge = tcp->lost.hill[0].r;
- memmove(&tcp_lost.hill[0], &tcp_lost.hill[1], + memmove(&tcp->lost.hill[0], &tcp->lost.hill[1], (TCP_SACK_HILLS - 1) * sizeof(struct sack_edges));
- tcp_lost.len -= TCP_OPT_LEN_8; - tcp_lost.hill[TCP_SACK_HILLS - 1].l = TCP_O_NOP; - tcp_lost.hill[TCP_SACK_HILLS - 1].r = TCP_O_NOP; + tcp->lost.len -= TCP_OPT_LEN_8; + tcp->lost.hill[TCP_SACK_HILLS - 1].l = TCP_O_NOP; + tcp->lost.hill[TCP_SACK_HILLS - 1].r = TCP_O_NOP; } }
/** * tcp_hole() - Selective Acknowledgment (Essential for fast stream transfer) + * @tcp: tcp stream * @tcp_seq_num: TCP sequence start number * @len: the length of sequence numbers */ -void tcp_hole(u32 tcp_seq_num, u32 len) +void tcp_hole(struct tcp_stream *tcp, u32 tcp_seq_num, u32 len) { int i, j, cnt, cnt_move;
- cnt = (tcp_lost.len - TCP_OPT_LEN_2) / TCP_OPT_LEN_8; + cnt = (tcp->lost.len - TCP_OPT_LEN_2) / TCP_OPT_LEN_8; for (i = 0; i < cnt; i++) { - if (tcp_seq_cmp(tcp_lost.hill[i].r, tcp_seq_num) < 0) + if (tcp_seq_cmp(tcp->lost.hill[i].r, tcp_seq_num) < 0) continue; - if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num + len) > 0) + if (tcp_seq_cmp(tcp->lost.hill[i].l, tcp_seq_num + len) > 0) break;
- if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num) > 0) - tcp_lost.hill[i].l = tcp_seq_num; - if (tcp_seq_cmp(tcp_lost.hill[i].l, tcp_seq_num) < 0) { - len += tcp_seq_num - tcp_lost.hill[i].l; - tcp_seq_num = tcp_lost.hill[i].l; + if (tcp_seq_cmp(tcp->lost.hill[i].l, tcp_seq_num) > 0) + tcp->lost.hill[i].l = tcp_seq_num; + if (tcp_seq_cmp(tcp->lost.hill[i].l, tcp_seq_num) < 0) { + len += tcp_seq_num - tcp->lost.hill[i].l; + tcp_seq_num = tcp->lost.hill[i].l; } - if (tcp_seq_cmp(tcp_lost.hill[i].r, tcp_seq_num + len) >= 0) { - tcp_update_ack_edge(); + if (tcp_seq_cmp(tcp->lost.hill[i].r, tcp_seq_num + len) >= 0) { + tcp_update_ack_edge(tcp); return; }
/* check overlapping with next hills */ cnt_move = 0; - tcp_lost.hill[i].r = tcp_seq_num + len; + tcp->lost.hill[i].r = tcp_seq_num + len; for (j = i + 1; j < cnt; j++) { - if (tcp_seq_cmp(tcp_lost.hill[j].l, tcp_lost.hill[i].r) > 0) + if (tcp_seq_cmp(tcp->lost.hill[j].l, tcp->lost.hill[i].r) > 0) break;
- tcp_lost.hill[i].r = tcp_lost.hill[j].r; + tcp->lost.hill[i].r = tcp->lost.hill[j].r; cnt_move++; }
if (cnt_move > 0) { if (cnt > i + cnt_move + 1) - memmove(&tcp_lost.hill[i + 1], - &tcp_lost.hill[i + cnt_move + 1], + memmove(&tcp->lost.hill[i + 1], + &tcp->lost.hill[i + cnt_move + 1], cnt_move * sizeof(struct sack_edges));
cnt -= cnt_move; - tcp_lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8; + tcp->lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8; for (j = cnt; j < TCP_SACK_HILLS; j++) { - tcp_lost.hill[j].l = TCP_O_NOP; - tcp_lost.hill[j].r = TCP_O_NOP; + tcp->lost.hill[j].l = TCP_O_NOP; + tcp->lost.hill[j].r = TCP_O_NOP; } }
- tcp_update_ack_edge(); + tcp_update_ack_edge(tcp); return; }
if (i == TCP_SACK_HILLS) { - tcp_update_ack_edge(); + tcp_update_ack_edge(tcp); return; }
@@ -429,23 +427,24 @@ void tcp_hole(u32 tcp_seq_num, u32 len) }
if (cnt_move > 0) - memmove(&tcp_lost.hill[i + 1], - &tcp_lost.hill[i], + memmove(&tcp->lost.hill[i + 1], + &tcp->lost.hill[i], cnt_move * sizeof(struct sack_edges));
- tcp_lost.hill[i].l = tcp_seq_num; - tcp_lost.hill[i].r = tcp_seq_num + len; - tcp_lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8; + tcp->lost.hill[i].l = tcp_seq_num; + tcp->lost.hill[i].r = tcp_seq_num + len; + tcp->lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8;
- tcp_update_ack_edge(); + tcp_update_ack_edge(tcp); };
/** * tcp_parse_options() - parsing TCP options + * @tcp: tcp stream * @o: pointer to the option field. * @o_len: length of the option field. */ -void tcp_parse_options(uchar *o, int o_len) +void tcp_parse_options(struct tcp_stream *tcp, uchar *o, int o_len) { struct tcp_t_opt *tsopt; uchar *p = o; @@ -468,7 +467,7 @@ void tcp_parse_options(uchar *o, int o_len) break; case TCP_O_TS: tsopt = (struct tcp_t_opt *)p; - rmt_timestamp = tsopt->t_snd; + tcp->rmt_timestamp = tsopt->t_snd; break; }
@@ -480,7 +479,8 @@ void tcp_parse_options(uchar *o, int o_len) } }
-static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) +static u8 tcp_state_machine(struct tcp_stream *tcp, u8 tcp_flags, + u32 tcp_seq_num, int payload_len) { u8 tcp_fin = tcp_flags & TCP_FIN; u8 tcp_syn = tcp_flags & TCP_SYN; @@ -501,21 +501,21 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) debug_cond(DEBUG_INT_STATE, "TCP STATE ENTRY %x\n", action); if (tcp_rst) { action = TCP_DATA; - current_tcp_state = TCP_CLOSED; + tcp->state = TCP_CLOSED; net_set_state(NETLOOP_FAIL); debug_cond(DEBUG_INT_STATE, "TCP Reset %x\n", tcp_flags); return TCP_RST; }
- switch (current_tcp_state) { + switch (tcp->state) { case TCP_CLOSED: debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); if (tcp_syn) { action = TCP_SYN | TCP_ACK; - tcp_seq_init = tcp_seq_num; - tcp_ack_edge = tcp_seq_num + 1; - tcp_lost.len = TCP_OPT_LEN_2; - current_tcp_state = TCP_SYN_RECEIVED; + tcp->seq_init = tcp_seq_num; + tcp->ack_edge = tcp_seq_num + 1; + tcp->lost.len = TCP_OPT_LEN_2; + tcp->state = TCP_SYN_RECEIVED; } else if (tcp_ack || tcp_fin) { action = TCP_DATA; } @@ -526,12 +526,12 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) tcp_flags, tcp_seq_num); if (tcp_fin) { action = action | TCP_PUSH; - current_tcp_state = TCP_CLOSE_WAIT; + tcp->state = TCP_CLOSE_WAIT; } else if (tcp_ack || (tcp_syn && tcp_ack)) { action |= TCP_ACK; - tcp_seq_init = tcp_seq_num; - tcp_ack_edge = tcp_seq_num + 1; - current_tcp_state = TCP_ESTABLISHED; + tcp->seq_init = tcp_seq_num; + tcp->ack_edge = tcp_seq_num + 1; + tcp->state = TCP_ESTABLISHED;
if (tcp_syn && tcp_ack) action |= TCP_PUSH; @@ -542,15 +542,15 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) case TCP_ESTABLISHED: debug_cond(DEBUG_INT_STATE, "TCP_ESTABLISHED %x\n", tcp_flags); if (payload_len > 0) { - tcp_hole(tcp_seq_num, payload_len); + tcp_hole(tcp, tcp_seq_num, payload_len); tcp_fin = TCP_DATA; /* cause standalone FIN */ }
if ((tcp_fin) && (!IS_ENABLED(CONFIG_PROT_TCP_SACK) || - tcp_lost.len <= TCP_OPT_LEN_2)) { + tcp->lost.len <= TCP_OPT_LEN_2)) { action = action | TCP_FIN | TCP_PUSH | TCP_ACK; - current_tcp_state = TCP_CLOSE_WAIT; + tcp->state = TCP_CLOSE_WAIT; } else if (tcp_ack) { action = TCP_DATA; } @@ -568,7 +568,7 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_2 (%x)\n", tcp_flags); if (tcp_ack) { action = TCP_PUSH | TCP_ACK; - current_tcp_state = TCP_CLOSED; + tcp->state = TCP_CLOSED; puts("\n"); } else if (tcp_syn) { action = TCP_DATA; @@ -579,20 +579,20 @@ static u8 tcp_state_machine(u8 tcp_flags, u32 tcp_seq_num, int payload_len) case TCP_FIN_WAIT_1: debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); if (tcp_fin) { - tcp_ack_edge++; + tcp->ack_edge++; action = TCP_ACK | TCP_FIN; - current_tcp_state = TCP_FIN_WAIT_2; + tcp->state = TCP_FIN_WAIT_2; } if (tcp_syn) action = TCP_RST; if (tcp_ack) - current_tcp_state = TCP_CLOSED; + tcp->state = TCP_CLOSED; break; case TCP_CLOSING: debug_cond(DEBUG_INT_STATE, "TCP_CLOSING (%x)\n", tcp_flags); if (tcp_ack) { action = TCP_PUSH; - current_tcp_state = TCP_CLOSED; + tcp->state = TCP_CLOSED; puts("\n"); } else if (tcp_syn) { action = TCP_RST; @@ -616,6 +616,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) u8 tcp_action = TCP_DATA; u32 tcp_seq_num, tcp_ack_num; int tcp_hdr_len, payload_len; + struct tcp_stream *tcp;
/* Verify IP header */ debug_cond(DEBUG_DEV_PKT, @@ -644,11 +645,15 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) return; }
+ tcp = tcp_stream_get(); + if (tcp == NULL) + return; + tcp_hdr_len = GET_TCP_HDR_LEN_IN_BYTES(b->ip.hdr.tcp_hlen); payload_len = tcp_len - tcp_hdr_len;
if (tcp_hdr_len > TCP_HDR_SIZE) - tcp_parse_options((uchar *)b + IP_TCP_HDR_SIZE, + tcp_parse_options(tcp, (uchar *)b + IP_TCP_HDR_SIZE, tcp_hdr_len - TCP_HDR_SIZE); /* * Incoming sequence and ack numbers are server's view of the numbers. @@ -658,7 +663,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) tcp_ack_num = ntohl(b->ip.hdr.tcp_ack);
/* Packets are not ordered. Send to app as received. */ - tcp_action = tcp_state_machine(b->ip.hdr.tcp_flags, + tcp_action = tcp_state_machine(tcp, b->ip.hdr.tcp_flags, tcp_seq_num, payload_len);
tcp_activity_count++; @@ -679,7 +684,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) } else if (tcp_action != TCP_DATA) { debug_cond(DEBUG_DEV_PKT, "TCP Action (action=%x,Seq=%u,Ack=%u,Pay=%d)\n", - tcp_action, tcp_ack_num, tcp_ack_edge, payload_len); + tcp_action, tcp_ack_num, tcp->ack_edge, payload_len);
/* * Warning: Incoming Ack & Seq sequence numbers are transposed @@ -688,6 +693,6 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) net_send_tcp_packet(0, ntohs(b->ip.hdr.tcp_src), ntohs(b->ip.hdr.tcp_dst), (tcp_action & (~TCP_PUSH)), - tcp_ack_num, tcp_ack_edge); + tcp_ack_num, tcp->ack_edge); } } diff --git a/net/wget.c b/net/wget.c index abab371e58e..1c0f97a6cc0 100644 --- a/net/wget.c +++ b/net/wget.c @@ -357,7 +357,8 @@ static void wget_handler(uchar *pkt, u16 dport, u32 tcp_seq_num, u32 tcp_ack_num, u8 action, unsigned int len) { - enum tcp_state wget_tcp_state = tcp_get_tcp_state(); + struct tcp_stream *tcp = tcp_stream_get(); + enum tcp_state wget_tcp_state = tcp_get_tcp_state(tcp);
net_set_timeout_handler(wget_timeout, wget_timeout_handler); packets++;
Changes: * Avoid use net_server_ip in tcp code, use tcp_stream data instead * Ignore packets from other connections if connection already created. This prevents us from connection break caused by other tcp stream.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- include/net.h | 5 +- include/net/tcp.h | 57 +++++++++++++++++--- net/fastboot_tcp.c | 46 ++++++++-------- net/net.c | 12 ++--- net/tcp.c | 129 ++++++++++++++++++++++++++++++++++----------- net/wget.c | 52 +++++++----------- 6 files changed, 201 insertions(+), 100 deletions(-)
diff --git a/include/net.h b/include/net.h index ac511eab103..fe645245f0f 100644 --- a/include/net.h +++ b/include/net.h @@ -668,6 +668,7 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, /** * net_send_tcp_packet() - Transmit TCP packet. * @payload_len: length of payload + * @dhost: Destination host * @dport: Destination TCP port * @sport: Source TCP port * @action: TCP action to be performed @@ -676,8 +677,8 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, * * Return: 0 on success, other value on failure */ -int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, - u32 tcp_seq_num, u32 tcp_ack_num); +int net_send_tcp_packet(int payload_len, struct in_addr dhost, int dport, + int sport, u8 action, u32 tcp_seq_num, u32 tcp_ack_num); int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, int payload_len);
diff --git a/include/net/tcp.h b/include/net/tcp.h index 14aee64cb1c..f224d0cae2f 100644 --- a/include/net/tcp.h +++ b/include/net/tcp.h @@ -279,6 +279,9 @@ enum tcp_state {
/** * struct tcp_stream - TCP data stream structure + * @rhost: Remote host, network byte order + * @rport: Remote port, host byte order + * @lport: Local port, host byte order * * @state: TCP connection state * @@ -291,6 +294,10 @@ enum tcp_state { * @lost: Used for SACK */ struct tcp_stream { + struct in_addr rhost; + u16 rport; + u16 lport; + /* TCP connection state */ enum tcp_state state;
@@ -305,16 +312,53 @@ struct tcp_stream { struct tcp_sack_v lost; };
-struct tcp_stream *tcp_stream_get(void); +void tcp_init(void); + +typedef int tcp_incoming_filter(struct in_addr rhost, + u16 rport, u16 sport); + +/* + * This function sets user callback used to accept/drop incoming + * connections. Callback should: + * + Check TCP stream endpoint and make connection verdict + * - return non-zero value to accept connection + * - return zero to drop connection + * + * WARNING: If callback is NOT defined, all incoming connections + * will be dropped. + */ +void tcp_set_incoming_filter(tcp_incoming_filter *filter); + +/* + * tcp_stream_get -- Get or create TCP stream + * @is_new: if non-zero and no stream found, then create a new one + * @rhost: Remote host, network byte order + * @rport: Remote port, host byte order + * @lport: Local port, host byte order + * + * Returns: TCP stream structure or NULL (if not found/created) + */ +struct tcp_stream *tcp_stream_get(int is_new, struct in_addr rhost, + u16 rport, u16 lport); + +/* + * tcp_stream_connect -- Create new TCP stream for remote connection. + * @rhost: Remote host, network byte order + * @rport: Remote port, host byte order + * + * Returns: TCP new stream structure or NULL (if not created). + * Random local port will be used. + */ +struct tcp_stream *tcp_stream_connect(struct in_addr rhost, u16 rport); + +enum tcp_state tcp_stream_get_state(struct tcp_stream *tcp);
-enum tcp_state tcp_get_tcp_state(struct tcp_stream *tcp); -void tcp_set_tcp_state(struct tcp_stream *tcp, enum tcp_state new_state); -int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, - int sport, int payload_len, +int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, u8 action, u32 tcp_seq_num, u32 tcp_ack_num);
/** * rxhand_tcp() - An incoming packet handler. + * @tcp: TCP stream * @pkt: pointer to the application packet * @dport: destination TCP port * @sip: source IP address @@ -324,8 +368,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, * @action: TCP action (SYN, ACK, FIN, etc) * @len: packet length */ -typedef void rxhand_tcp(uchar *pkt, u16 dport, - struct in_addr sip, u16 sport, +typedef void rxhand_tcp(struct tcp_stream *tcp, uchar *pkt, u32 tcp_seq_num, u32 tcp_ack_num, u8 action, unsigned int len); void tcp_set_tcp_handler(rxhand_tcp *f); diff --git a/net/fastboot_tcp.c b/net/fastboot_tcp.c index 2eb52ea2567..de1048e366e 100644 --- a/net/fastboot_tcp.c +++ b/net/fastboot_tcp.c @@ -9,14 +9,14 @@ #include <net/fastboot_tcp.h> #include <net/tcp.h>
+#define FASTBOOT_TCP_PORT 5554 + static char command[FASTBOOT_COMMAND_LEN] = {0}; static char response[FASTBOOT_RESPONSE_LEN] = {0};
static const unsigned short handshake_length = 4; static const uchar *handshake = "FB01";
-static u16 curr_sport; -static u16 curr_dport; static u32 curr_tcp_seq_num; static u32 curr_tcp_ack_num; static unsigned int curr_request_len; @@ -26,34 +26,37 @@ static enum fastboot_tcp_state { FASTBOOT_DISCONNECTING } state = FASTBOOT_CLOSED;
-static void fastboot_tcp_answer(u8 action, unsigned int len) +static void fastboot_tcp_answer(struct tcp_stream *tcp, u8 action, + unsigned int len) { const u32 response_seq_num = curr_tcp_ack_num; const u32 response_ack_num = curr_tcp_seq_num + (curr_request_len > 0 ? curr_request_len : 1);
- net_send_tcp_packet(len, htons(curr_sport), htons(curr_dport), + net_send_tcp_packet(len, tcp->rhost, tcp->rport, tcp->lport, action, response_seq_num, response_ack_num); }
-static void fastboot_tcp_reset(void) +static void fastboot_tcp_reset(struct tcp_stream *tcp) { - fastboot_tcp_answer(TCP_RST, 0); + fastboot_tcp_answer(tcp, TCP_RST, 0); state = FASTBOOT_CLOSED; }
-static void fastboot_tcp_send_packet(u8 action, const uchar *data, unsigned int len) +static void fastboot_tcp_send_packet(struct tcp_stream *tcp, u8 action, + const uchar *data, unsigned int len) { uchar *pkt = net_get_async_tx_pkt_buf();
memset(pkt, '\0', PKTSIZE); pkt += net_eth_hdr_size() + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; memcpy(pkt, data, len); - fastboot_tcp_answer(action, len); + fastboot_tcp_answer(tcp, action, len); memset(pkt, '\0', PKTSIZE); }
-static void fastboot_tcp_send_message(const char *message, unsigned int len) +static void fastboot_tcp_send_message(struct tcp_stream *tcp, + const char *message, unsigned int len) { __be64 len_be = __cpu_to_be64(len); uchar *pkt = net_get_async_tx_pkt_buf(); @@ -64,12 +67,11 @@ static void fastboot_tcp_send_message(const char *message, unsigned int len) memcpy(pkt, &len_be, 8); pkt += 8; memcpy(pkt, message, len); - fastboot_tcp_answer(TCP_ACK | TCP_PUSH, len + 8); + fastboot_tcp_answer(tcp, TCP_ACK | TCP_PUSH, len + 8); memset(pkt, '\0', PKTSIZE); }
-static void fastboot_tcp_handler_ipv4(uchar *pkt, u16 dport, - struct in_addr sip, u16 sport, +static void fastboot_tcp_handler_ipv4(struct tcp_stream *tcp, uchar *pkt, u32 tcp_seq_num, u32 tcp_ack_num, u8 action, unsigned int len) { @@ -78,8 +80,6 @@ static void fastboot_tcp_handler_ipv4(uchar *pkt, u16 dport, u8 tcp_fin = action & TCP_FIN; u8 tcp_push = action & TCP_PUSH;
- curr_sport = sport; - curr_dport = dport; curr_tcp_seq_num = tcp_seq_num; curr_tcp_ack_num = tcp_ack_num; curr_request_len = len; @@ -90,17 +90,17 @@ static void fastboot_tcp_handler_ipv4(uchar *pkt, u16 dport, if (len != handshake_length || strlen(pkt) != handshake_length || memcmp(pkt, handshake, handshake_length) != 0) { - fastboot_tcp_reset(); + fastboot_tcp_reset(tcp); break; } - fastboot_tcp_send_packet(TCP_ACK | TCP_PUSH, + fastboot_tcp_send_packet(tcp, TCP_ACK | TCP_PUSH, handshake, handshake_length); state = FASTBOOT_CONNECTED; } break; case FASTBOOT_CONNECTED: if (tcp_fin) { - fastboot_tcp_answer(TCP_FIN | TCP_ACK, 0); + fastboot_tcp_answer(tcp, TCP_FIN | TCP_ACK, 0); state = FASTBOOT_DISCONNECTING; break; } @@ -112,12 +112,12 @@ static void fastboot_tcp_handler_ipv4(uchar *pkt, u16 dport,
// Only single packet messages are supported ATM if (strlen(pkt) != command_size) { - fastboot_tcp_reset(); + fastboot_tcp_reset(tcp); break; } strlcpy(command, pkt, len + 1); fastboot_command_id = fastboot_handle_command(command, response); - fastboot_tcp_send_message(response, strlen(response)); + fastboot_tcp_send_message(tcp, response, strlen(response)); fastboot_handle_boot(fastboot_command_id, strncmp("OKAY", response, 4) == 0); } @@ -130,17 +130,21 @@ static void fastboot_tcp_handler_ipv4(uchar *pkt, u16 dport,
memset(command, 0, FASTBOOT_COMMAND_LEN); memset(response, 0, FASTBOOT_RESPONSE_LEN); - curr_sport = 0; - curr_dport = 0; curr_tcp_seq_num = 0; curr_tcp_ack_num = 0; curr_request_len = 0; }
+static int incoming_filter(struct in_addr rhost, u16 rport, u16 lport) +{ + return (lport == FASTBOOT_TCP_PORT); +} + void fastboot_tcp_start_server(void) { printf("Using %s device\n", eth_get_name()); printf("Listening for fastboot command on tcp %pI4\n", &net_ip);
+ tcp_set_incoming_filter(incoming_filter); tcp_set_tcp_handler(fastboot_tcp_handler_ipv4); } diff --git a/net/net.c b/net/net.c index 8f076fa18e3..ff3018e6494 100644 --- a/net/net.c +++ b/net/net.c @@ -416,7 +416,7 @@ int net_init(void) /* Only need to setup buffer pointers once. */ first_call = 0; if (IS_ENABLED(CONFIG_PROT_TCP)) - tcp_set_tcp_state(tcp_stream_get(), TCP_CLOSED); + tcp_init(); }
return net_init_loop(); @@ -901,10 +901,10 @@ int net_send_udp_packet(uchar *ether, struct in_addr dest, int dport, int sport, }
#if defined(CONFIG_PROT_TCP) -int net_send_tcp_packet(int payload_len, int dport, int sport, u8 action, - u32 tcp_seq_num, u32 tcp_ack_num) +int net_send_tcp_packet(int payload_len, struct in_addr dhost, int dport, + int sport, u8 action, u32 tcp_seq_num, u32 tcp_ack_num) { - return net_send_ip_packet(net_server_ethaddr, net_server_ip, dport, + return net_send_ip_packet(net_server_ethaddr, dhost, dport, sport, payload_len, IPPROTO_TCP, action, tcp_seq_num, tcp_ack_num); } @@ -946,12 +946,12 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, break; #if defined(CONFIG_PROT_TCP) case IPPROTO_TCP: - tcp = tcp_stream_get(); + tcp = tcp_stream_get(0, dest, dport, sport); if (tcp == NULL) return -EINVAL;
pkt_hdr_size = eth_hdr_size - + tcp_set_tcp_header(tcp, pkt + eth_hdr_size, dport, sport, + + tcp_set_tcp_header(tcp, pkt + eth_hdr_size, payload_len, action, tcp_seq_num, tcp_ack_num); break; diff --git a/net/tcp.c b/net/tcp.c index 80a161838f5..efa12c9e8d3 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -27,6 +27,7 @@
static int tcp_activity_count; static struct tcp_stream tcp_stream; +static tcp_incoming_filter *incoming_filter;
/* * TCP lengths are stored as a rounded up number of 32 bit words. @@ -41,40 +42,95 @@ static struct tcp_stream tcp_stream; /* Current TCP RX packet handler */ static rxhand_tcp *tcp_packet_handler;
+#define RANDOM_PORT_START 1024 +#define RANDOM_PORT_RANGE 0x4000 + +/** + * random_port() - make port a little random (1024-17407) + * + * Return: random port number from 1024 to 17407 + * + * This keeps the math somewhat trivial to compute, and seems to work with + * all supported protocols/clients/servers + */ +static unsigned int random_port(void) +{ + return RANDOM_PORT_START + (get_timer(0) % RANDOM_PORT_RANGE); +} + static inline s32 tcp_seq_cmp(u32 a, u32 b) { return (s32)(a - b); }
/** - * tcp_get_tcp_state() - get TCP stream state + * tcp_stream_get_state() - get TCP stream state * @tcp: tcp stream * * Return: TCP stream state */ -enum tcp_state tcp_get_tcp_state(struct tcp_stream *tcp) +enum tcp_state tcp_stream_get_state(struct tcp_stream *tcp) { return tcp->state; }
/** - * tcp_set_tcp_state() - set TCP stream state + * tcp_stream_set_state() - set TCP stream state * @tcp: tcp stream * @new_state: new TCP state */ -void tcp_set_tcp_state(struct tcp_stream *tcp, - enum tcp_state new_state) +static void tcp_stream_set_state(struct tcp_stream *tcp, + enum tcp_state new_state) { tcp->state = new_state; }
-struct tcp_stream *tcp_stream_get(void) +void tcp_init(void) +{ + incoming_filter = NULL; + tcp_stream.state = TCP_CLOSED; +} + +void tcp_set_incoming_filter(tcp_incoming_filter *filter) +{ + incoming_filter = filter; +} + +static struct tcp_stream *tcp_stream_add(struct in_addr rhost, + u16 rport, u16 lport) +{ + struct tcp_stream *tcp = &tcp_stream; + + if (tcp->state != TCP_CLOSED) + return NULL; + + memset(tcp, 0, sizeof(struct tcp_stream)); + tcp->rhost.s_addr = rhost.s_addr; + tcp->rport = rport; + tcp->lport = lport; + tcp->state = TCP_CLOSED; + tcp->lost.len = TCP_OPT_LEN_2; + return tcp; +} + +struct tcp_stream *tcp_stream_get(int is_new, struct in_addr rhost, + u16 rport, u16 lport) { - return &tcp_stream; + struct tcp_stream *tcp = &tcp_stream; + + if ((tcp->rhost.s_addr == rhost.s_addr) && + (tcp->rport == rport) && + (tcp->lport == lport)) + return tcp; + + if (!is_new || (incoming_filter == NULL) || + !incoming_filter(rhost, rport, lport)) + return NULL; + + return tcp_stream_add(rhost, rport, lport); }
-static void dummy_handler(uchar *pkt, u16 dport, - struct in_addr sip, u16 sport, +static void dummy_handler(struct tcp_stream *tcp, uchar *pkt, u32 tcp_seq_num, u32 tcp_ack_num, u8 action, unsigned int len) { @@ -223,8 +279,7 @@ void net_set_syn_options(struct tcp_stream *tcp, union tcp_build_pkt *b) b->ip.end = TCP_O_END; }
-int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, - int sport, int payload_len, +int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, u8 action, u32 tcp_seq_num, u32 tcp_ack_num) { union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; @@ -244,7 +299,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, case TCP_SYN: debug_cond(DEBUG_DEV_PKT, "TCP Hdr:SYN (%pI4, %pI4, sq=%u, ak=%u)\n", - &net_server_ip, &net_ip, + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); tcp_activity_count = 0; net_set_syn_options(tcp, b); @@ -265,13 +320,13 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, b->ip.hdr.tcp_flags = action; debug_cond(DEBUG_DEV_PKT, "TCP Hdr:ACK (%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num, + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num, action); break; case TCP_FIN: debug_cond(DEBUG_DEV_PKT, "TCP Hdr:FIN (%pI4, %pI4, s=%u, a=%u)\n", - &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); payload_len = 0; pkt_hdr_len = IP_TCP_HDR_SIZE; tcp->state = TCP_FIN_WAIT_1; @@ -280,7 +335,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, case TCP_RST: debug_cond(DEBUG_DEV_PKT, "TCP Hdr:RST (%pI4, %pI4, s=%u, a=%u)\n", - &net_server_ip, &net_ip, tcp_seq_num, tcp_ack_num); + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); tcp->state = TCP_CLOSED; break; /* Notify connection closing */ @@ -291,7 +346,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport,
debug_cond(DEBUG_DEV_PKT, "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &net_server_ip, &net_ip, + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num, action); fallthrough; default: @@ -299,7 +354,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; debug_cond(DEBUG_DEV_PKT, "TCP Hdr:dft (%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &net_server_ip, &net_ip, + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num, action); }
@@ -309,8 +364,8 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, tcp->ack_edge = tcp_ack_num; /* TCP Header */ b->ip.hdr.tcp_ack = htonl(tcp->ack_edge); - b->ip.hdr.tcp_src = htons(sport); - b->ip.hdr.tcp_dst = htons(dport); + b->ip.hdr.tcp_src = htons(tcp->lport); + b->ip.hdr.tcp_dst = htons(tcp->rport); b->ip.hdr.tcp_seq = htonl(tcp_seq_num);
/* @@ -333,10 +388,10 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int dport, b->ip.hdr.tcp_xsum = 0; b->ip.hdr.tcp_ugr = 0;
- b->ip.hdr.tcp_xsum = tcp_set_pseudo_header(pkt, net_ip, net_server_ip, + b->ip.hdr.tcp_xsum = tcp_set_pseudo_header(pkt, net_ip, tcp->rhost, tcp_len, pkt_len);
- net_set_ip_header((uchar *)&b->ip, net_server_ip, net_ip, + net_set_ip_header((uchar *)&b->ip, tcp->rhost, net_ip, pkt_len, IPPROTO_TCP);
return pkt_hdr_len; @@ -617,19 +672,26 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) u32 tcp_seq_num, tcp_ack_num; int tcp_hdr_len, payload_len; struct tcp_stream *tcp; + struct in_addr src;
/* Verify IP header */ debug_cond(DEBUG_DEV_PKT, "TCP RX in RX Sum (to=%pI4, from=%pI4, len=%d)\n", &b->ip.hdr.ip_src, &b->ip.hdr.ip_dst, pkt_len);
- b->ip.hdr.ip_src = net_server_ip; + /* + * src IP address will be destroyed by TCP checksum verification + * algorithm (see tcp_set_pseudo_header()), so remember it before + * it was garbaged. + */ + src.s_addr = b->ip.hdr.ip_src.s_addr; + b->ip.hdr.ip_dst = net_ip; b->ip.hdr.ip_sum = 0; if (tcp_rx_xsum != compute_ip_checksum(b, IP_HDR_SIZE)) { debug_cond(DEBUG_DEV_PKT, "TCP RX IP xSum Error (%pI4, =%pI4, len=%d)\n", - &net_ip, &net_server_ip, pkt_len); + &net_ip, &src, pkt_len); return; }
@@ -641,11 +703,14 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) pkt_len)) { debug_cond(DEBUG_DEV_PKT, "TCP RX TCP xSum Error (%pI4, %pI4, len=%d)\n", - &net_ip, &net_server_ip, tcp_len); + &net_ip, &src, tcp_len); return; }
- tcp = tcp_stream_get(); + tcp = tcp_stream_get(b->ip.hdr.tcp_flags & TCP_SYN, + src, + ntohs(b->ip.hdr.tcp_src), + ntohs(b->ip.hdr.tcp_dst)); if (tcp == NULL) return;
@@ -677,9 +742,9 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) "TCP Notify (action=%x, Seq=%u,Ack=%u,Pay%d)\n", tcp_action, tcp_seq_num, tcp_ack_num, payload_len);
- (*tcp_packet_handler) ((uchar *)b + pkt_len - payload_len, b->ip.hdr.tcp_dst, - b->ip.hdr.ip_src, b->ip.hdr.tcp_src, tcp_seq_num, - tcp_ack_num, tcp_action, payload_len); + (*tcp_packet_handler) (tcp, (uchar *)b + pkt_len - payload_len, + tcp_seq_num, tcp_ack_num, tcp_action, + payload_len);
} else if (tcp_action != TCP_DATA) { debug_cond(DEBUG_DEV_PKT, @@ -690,9 +755,13 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) * Warning: Incoming Ack & Seq sequence numbers are transposed * here to outgoing Seq & Ack sequence numbers */ - net_send_tcp_packet(0, ntohs(b->ip.hdr.tcp_src), - ntohs(b->ip.hdr.tcp_dst), + net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, (tcp_action & (~TCP_PUSH)), tcp_ack_num, tcp->ack_edge); } } + +struct tcp_stream *tcp_stream_connect(struct in_addr rhost, u16 rport) +{ + return tcp_stream_add(rhost, rport, random_port()); +} diff --git a/net/wget.c b/net/wget.c index 1c0f97a6cc0..327fe3cfbce 100644 --- a/net/wget.c +++ b/net/wget.c @@ -28,9 +28,8 @@ static const char http_eom[] = "\r\n\r\n"; static const char http_ok[] = "200"; static const char content_len[] = "Content-Length"; static const char linefeed[] = "\r\n"; -static struct in_addr web_server_ip; -static int our_port; static int wget_timeout_count; +struct tcp_stream *tcp;
struct pkt_qd { uchar *pkt; @@ -138,22 +137,19 @@ static void wget_send_stored(void) int len = retry_len; unsigned int tcp_ack_num = retry_tcp_seq_num + (len == 0 ? 1 : len); unsigned int tcp_seq_num = retry_tcp_ack_num; - unsigned int server_port; uchar *ptr, *offset;
- server_port = env_get_ulong("httpdstp", 10, SERVER_PORT) & 0xffff; - switch (current_wget_state) { case WGET_CLOSED: debug_cond(DEBUG_WGET, "wget: send SYN\n"); current_wget_state = WGET_CONNECTING; - net_send_tcp_packet(0, server_port, our_port, action, + net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, tcp_seq_num, tcp_ack_num); packets = 0; break; case WGET_CONNECTING: pkt_q_idx = 0; - net_send_tcp_packet(0, server_port, our_port, action, + net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, tcp_seq_num, tcp_ack_num);
ptr = net_tx_packet + net_eth_hdr_size() + @@ -168,14 +164,14 @@ static void wget_send_stored(void)
memcpy(offset, &bootfile3, strlen(bootfile3)); offset += strlen(bootfile3); - net_send_tcp_packet((offset - ptr), server_port, our_port, + net_send_tcp_packet((offset - ptr), tcp->rhost, tcp->rport, tcp->lport, TCP_PUSH, tcp_seq_num, tcp_ack_num); current_wget_state = WGET_CONNECTED; break; case WGET_CONNECTED: case WGET_TRANSFERRING: case WGET_TRANSFERRED: - net_send_tcp_packet(0, server_port, our_port, action, + net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, tcp_seq_num, tcp_ack_num); break; } @@ -340,10 +336,8 @@ static void wget_connected(uchar *pkt, unsigned int tcp_seq_num,
/** * wget_handler() - TCP handler of wget + * @tcp: TCP stream * @pkt: pointer to the application packet - * @dport: destination TCP port - * @sip: source IP address - * @sport: source TCP port * @tcp_seq_num: TCP sequential number * @tcp_ack_num: TCP acknowledgment number * @action: TCP action (SYN, ACK, FIN, etc) @@ -352,13 +346,11 @@ static void wget_connected(uchar *pkt, unsigned int tcp_seq_num, * In the "application push" invocation, the TCP header with all * its information is pointed to by the packet pointer. */ -static void wget_handler(uchar *pkt, u16 dport, - struct in_addr sip, u16 sport, +static void wget_handler(struct tcp_stream *tcp, uchar *pkt, u32 tcp_seq_num, u32 tcp_ack_num, u8 action, unsigned int len) { - struct tcp_stream *tcp = tcp_stream_get(); - enum tcp_state wget_tcp_state = tcp_get_tcp_state(tcp); + enum tcp_state wget_tcp_state = tcp_stream_get_state(tcp);
net_set_timeout_handler(wget_timeout, wget_timeout_handler); packets++; @@ -442,26 +434,13 @@ static void wget_handler(uchar *pkt, u16 dport, } }
-#define RANDOM_PORT_START 1024 -#define RANDOM_PORT_RANGE 0x4000 - -/** - * random_port() - make port a little random (1024-17407) - * - * Return: random port number from 1024 to 17407 - * - * This keeps the math somewhat trivial to compute, and seems to work with - * all supported protocols/clients/servers - */ -static unsigned int random_port(void) -{ - return RANDOM_PORT_START + (get_timer(0) % RANDOM_PORT_RANGE); -} - #define BLOCKSIZE 512
void wget_start(void) { + struct in_addr web_server_ip; + unsigned int server_port; + image_url = strchr(net_boot_file_name, ':'); if (image_url > 0) { web_server_ip = string_to_ip(net_boot_file_name); @@ -514,8 +493,6 @@ void wget_start(void) wget_timeout_count = 0; current_wget_state = WGET_CLOSED;
- our_port = random_port(); - /* * Zero out server ether to force arp resolution in case * the server ip for the previous u-boot command, for example dns @@ -524,6 +501,13 @@ void wget_start(void)
memset(net_server_ethaddr, 0, 6);
+ server_port = env_get_ulong("httpdstp", 10, SERVER_PORT) & 0xffff; + tcp = tcp_stream_connect(web_server_ip, server_port); + if (tcp == NULL) { + net_set_state(NETLOOP_FAIL); + return; + } + wget_send(TCP_SYN, 0, 0, 0); }
Use the names from RFC 9293
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- include/net/tcp.h | 8 ++++---- net/tcp.c | 32 ++++++++++++++++---------------- 2 files changed, 20 insertions(+), 20 deletions(-)
diff --git a/include/net/tcp.h b/include/net/tcp.h index f224d0cae2f..0694af9d5b1 100644 --- a/include/net/tcp.h +++ b/include/net/tcp.h @@ -285,8 +285,8 @@ enum tcp_state { * * @state: TCP connection state * - * @seq_init: Initial receive sequence number - * @ack_edge: Receive next + * @irs: Initial receive sequence number + * @rcv_nxt: Receive next * * @loc_timestamp: Local timestamp * @rmt_timestamp: Remote timestamp @@ -301,8 +301,8 @@ struct tcp_stream { /* TCP connection state */ enum tcp_state state;
- u32 seq_init; - u32 ack_edge; + u32 irs; + u32 rcv_nxt;
/* TCP option timestamp */ u32 loc_timestamp; diff --git a/net/tcp.c b/net/tcp.c index efa12c9e8d3..2a0dcc4e771 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -361,9 +361,9 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, pkt_len = pkt_hdr_len + payload_len; tcp_len = pkt_len - IP_HDR_SIZE;
- tcp->ack_edge = tcp_ack_num; + tcp->rcv_nxt = tcp_ack_num; /* TCP Header */ - b->ip.hdr.tcp_ack = htonl(tcp->ack_edge); + b->ip.hdr.tcp_ack = htonl(tcp->rcv_nxt); b->ip.hdr.tcp_src = htons(tcp->lport); b->ip.hdr.tcp_dst = htons(tcp->rport); b->ip.hdr.tcp_seq = htonl(tcp_seq_num); @@ -397,10 +397,10 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, return pkt_hdr_len; }
-static void tcp_update_ack_edge(struct tcp_stream *tcp) +static void tcp_update_rcv_nxt(struct tcp_stream *tcp) { - if (tcp_seq_cmp(tcp->ack_edge, tcp->lost.hill[0].l) >= 0) { - tcp->ack_edge = tcp->lost.hill[0].r; + if (tcp_seq_cmp(tcp->rcv_nxt, tcp->lost.hill[0].l) >= 0) { + tcp->rcv_nxt = tcp->lost.hill[0].r;
memmove(&tcp->lost.hill[0], &tcp->lost.hill[1], (TCP_SACK_HILLS - 1) * sizeof(struct sack_edges)); @@ -435,7 +435,7 @@ void tcp_hole(struct tcp_stream *tcp, u32 tcp_seq_num, u32 len) tcp_seq_num = tcp->lost.hill[i].l; } if (tcp_seq_cmp(tcp->lost.hill[i].r, tcp_seq_num + len) >= 0) { - tcp_update_ack_edge(tcp); + tcp_update_rcv_nxt(tcp); return; }
@@ -464,12 +464,12 @@ void tcp_hole(struct tcp_stream *tcp, u32 tcp_seq_num, u32 len) } }
if (i == TCP_SACK_HILLS) { - tcp_update_ack_edge(tcp); + tcp_update_rcv_nxt(tcp); return; }
@@ -490,7 +490,7 @@ void tcp_hole(struct tcp_stream *tcp, u32 tcp_seq_num, u32 len) tcp->lost.hill[i].r = tcp_seq_num + len; tcp->lost.len = TCP_OPT_LEN_2 + cnt * TCP_OPT_LEN_8;
- tcp_update_ack_edge(tcp); + tcp_update_rcv_nxt(tcp); };
/** @@ -567,8 +567,8 @@ static u8 tcp_state_machine(struct tcp_stream *tcp, u8 tcp_flags, debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); if (tcp_syn) { action = TCP_SYN | TCP_ACK; - tcp->seq_init = tcp_seq_num; - tcp->ack_edge = tcp_seq_num + 1; + tcp->irs = tcp_seq_num; + tcp->rcv_nxt = tcp_seq_num + 1; tcp->lost.len = TCP_OPT_LEN_2; tcp->state = TCP_SYN_RECEIVED; } else if (tcp_ack || tcp_fin) { @@ -584,8 +584,8 @@ static u8 tcp_state_machine(struct tcp_stream *tcp, u8 tcp_flags, tcp->state = TCP_CLOSE_WAIT; } else if (tcp_ack || (tcp_syn && tcp_ack)) { action |= TCP_ACK; - tcp->seq_init = tcp_seq_num; - tcp->ack_edge = tcp_seq_num + 1; + tcp->irs = tcp_seq_num; + tcp->rcv_nxt = tcp_seq_num + 1; tcp->state = TCP_ESTABLISHED;
if (tcp_syn && tcp_ack) @@ -634,7 +634,7 @@ static u8 tcp_state_machine(struct tcp_stream *tcp, u8 tcp_flags, case TCP_FIN_WAIT_1: debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); if (tcp_fin) { - tcp->ack_edge++; + tcp->rcv_nxt++; action = TCP_ACK | TCP_FIN; tcp->state = TCP_FIN_WAIT_2; } @@ -749,7 +749,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) } else if (tcp_action != TCP_DATA) { debug_cond(DEBUG_DEV_PKT, "TCP Action (action=%x,Seq=%u,Ack=%u,Pay=%d)\n", - tcp_action, tcp_ack_num, tcp->ack_edge, payload_len); + tcp_action, tcp_ack_num, tcp->rcv_nxt, payload_len);
/* * Warning: Incoming Ack & Seq sequence numbers are transposed @@ -757,7 +757,7 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) */ net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, (tcp_action & (~TCP_PUSH)), - tcp_ack_num, tcp->ack_edge); + tcp_ack_num, tcp->rcv_nxt); } }
Changes: * Fix initial send sequence always zero issue * Use state machine close to RFC 9293. This should make TCP transfers more reliable (now we can upload a huge array of data from the board to external server) * Improve TCP framework a lot. This should make tcp client code much more simple. * rewrite wget with new tcp stack * rewrite fastboot_tcp with new tcp stack
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- include/net/tcp.h | 171 +++++++-- include/net/wget.h | 8 - net/fastboot_tcp.c | 190 +++++----- net/net.c | 4 + net/tcp.c | 837 ++++++++++++++++++++++++++++++++++----------- net/wget.c | 460 +++++++------------------ 6 files changed, 992 insertions(+), 678 deletions(-)
diff --git a/include/net/tcp.h b/include/net/tcp.h index 0694af9d5b1..b070354e871 100644 --- a/include/net/tcp.h +++ b/include/net/tcp.h @@ -265,6 +265,7 @@ union tcp_build_pkt { * @TCP_CLOSING: Rec FIN, sent FIN, ACK waiting for ACK * @TCP_FIN_WAIT_1: Sent FIN waiting for response * @TCP_FIN_WAIT_2: Rec ACK from FIN sent, waiting for FIN + * @TCP_LAST_ACK: Waiting for ACK of the connection termination */ enum tcp_state { TCP_CLOSED, @@ -274,7 +275,20 @@ enum tcp_state { TCP_CLOSE_WAIT, TCP_CLOSING, TCP_FIN_WAIT_1, - TCP_FIN_WAIT_2 + TCP_FIN_WAIT_2, + TCP_LAST_ACK, +}; + +/** + * enum tcp_status - TCP stream status for connection + * @TCP_ERR_OK: no rx/tx errors + * @TCP_ERR_TOUT: rx/tx timeout happened + * @TCP_ERR_RST: connection was reset + */ +enum tcp_status { + TCP_ERR_OK = 0, + TCP_ERR_TOUT, + TCP_ERR_RST, };
/** @@ -283,51 +297,150 @@ enum tcp_state { * @rport: Remote port, host byte order * @lport: Local port, host byte order * + * @priv: User private data (not used by tcp module) + * + * @max_retry_count: Maximum retransmit attempts (default 3) + * @initial_timeout: Timeout from initial TX to reTX (default 2 sec) + * @rx_inactiv_timeout: Maximum time from last rx till connection drop + * (default 30 sec) + * + * @on_closed: User callback, called just before destroying TCP stream + * @on_established: User callback, called when TCP stream enters + * TCP_ESTABLISHED state + * @on_rcv_nxt_update: User callback, called when all data in the segment + * [0..rx_bytes - 1] was received + * @on_snd_una_update: User callback, called when all data in the segment + * [0..tx_bytes - 1] were transferred and acknowledged + * @rx: User callback, called on receive of segment + * [rx_offs..rx_offs+len-1]. If NULL -- all incoming data + * will be ignored. User SHOULD store the segment and + * return the number of accepted bytes. + * WARNING: Previous segmengs may not be received yet + * @tx: User callback, called on transmit/retransmit of segment + * [tx_offs..tx_offs+maxlen-1]. If NULL -- no data will + * be transmitted. User SHOULD fill provided buffer and + * return the number of bytes in the buffer. + * WARNING: do not use tcp_stream_close() from this + * callback (it will break stream). Better use + * on_snd_una_update() callback for such purposes. + * + * @time_last_rx: Arrival time of last valid incoming package (ticks) + * @time_start: Timeout start time (ticks) + * @time_delta: Timeout duration (ticks) + * @time_handler Timeout handler for a stream + * * @state: TCP connection state + * @status: TCP stream status (OK or ERR) + * + * @fin_rx: Non-zero if TCP_FIN was received + * @fin_rx_seq: TCP sequence of rx FIN bit + * @fin_tx: Non-zero if TCP_FIN was sent (or planned to send) + * @fin_tx_seq: TCP sequence of tx FIN bit + * + * @iss: Initial send sequence number + * @snd_una: Send unacknowledged + * @snd_nxt: Send next + * @snd_wnd: Send window (in bytes) + * @snd_wl1: Segment sequence number used for last window update + * @snd_wl2: Segment acknowledgment number used for last window update * * @irs: Initial receive sequence number * @rcv_nxt: Receive next + * @rcv_wnd: Receive window (in bytes) * * @loc_timestamp: Local timestamp * @rmt_timestamp: Remote timestamp * + * @rmt_win_scale: Remote window scale factor + * * @lost: Used for SACK + * + * @retry_cnt: Number of retry attempts remaining. Only SYN, FIN + * or DATA segments are tried to retransmit. + * @retry_timeout: Current retry timeout (ms) + * @retry_action: TCP flags used for sending + * @retry_seq_num: TCP sequence for retransmit + * retry_tx_len: Number of data to transmit + * @retry_tx_offs: Position in the TX stream */ struct tcp_stream { struct in_addr rhost; u16 rport; u16 lport;
- /* TCP connection state */ + void *priv; + + int max_retry_count; + int initial_timeout; + int rx_inactiv_timeout; + + void (*on_closed)(struct tcp_stream *tcp); + void (*on_established)(struct tcp_stream *tcp); + void (*on_rcv_nxt_update)(struct tcp_stream *tcp, u32 rx_bytes); + void (*on_snd_una_update)(struct tcp_stream *tcp, u32 tx_bytes); + u32 (*rx)(struct tcp_stream *tcp, u32 rx_offs, void *buf, u32 len); + u32 (*tx)(struct tcp_stream *tcp, u32 tx_offs, void *buf, u32 maxlen); + + ulong time_last_rx; + ulong time_start; + ulong time_delta; + void (*time_handler)(struct tcp_stream *tcp); + enum tcp_state state; + enum tcp_status status; + + int fin_rx; + u32 fin_rx_seq; + + int fin_tx; + u32 fin_tx_seq; + + u32 iss; + u32 snd_una; + u32 snd_nxt; + u32 snd_wnd; + u32 snd_wl1; + u32 snd_wl2;
u32 irs; u32 rcv_nxt; + u32 rcv_wnd;
/* TCP option timestamp */ u32 loc_timestamp; u32 rmt_timestamp;
+ /* TCP window scale */ + u8 rmt_win_scale; + /* TCP sliding window control used to request re-TX */ struct tcp_sack_v lost; + + /* used for data retransmission */ + int retry_cnt; + int retry_timeout; + u8 retry_action; + u32 retry_seq_num; + u32 retry_tx_len; + u32 retry_tx_offs; };
-typedef int tcp_incoming_filter(struct in_addr rhost, - u16 rport, u16 sport); - /* - * This function sets user callback used to accept/drop incoming - * connections. Callback should: + * This function sets user callback called on TCP stream creation. + * Callback should: * + Check TCP stream endpoint and make connection verdict * - return non-zero value to accept connection * - return zero to drop connection + * + Setup TCP stream callbacks like: on_closed(), on_established(), + * n_rcv_nxt_update(), on_snd_una_update(), rx() and tx(). + * + Setup other stream related data * - * WARNING: If callback is NOT defined, all incoming connections - * will be dropped. + * WARNING: User MUST setup TCP stream on_create handler. Without it + * no connection (including outgoung) will be created. */ -void tcp_set_incoming_filter(tcp_incoming_filter *filter); +void tcp_stream_set_on_create_handler(int (*on_create)(struct tcp_stream *));
/* * tcp_stream_get -- Get or create TCP stream @@ -351,28 +464,30 @@ struct tcp_stream *tcp_stream_get(int is_new, struct in_addr rhost, */ struct tcp_stream *tcp_stream_connect(struct in_addr rhost, u16 rport);
-enum tcp_state tcp_stream_get_state(struct tcp_stream *tcp); +/* + * tcp_stream_put -- Return stream to a TCP subsystem. Subsystem will + * check stream and destroy it (if stream was already + * closed). Otherwize no stream change will happen. + * @tcp: TCP stream to put + */ +void tcp_stream_put(struct tcp_stream *tcp); + +enum tcp_state tcp_stream_get_state(struct tcp_stream *tcp); +enum tcp_status tcp_stream_get_status(struct tcp_stream *tcp); + +u32 tcp_stream_rx_offs(struct tcp_stream *tcp); +u32 tcp_stream_tx_offs(struct tcp_stream *tcp); + +/* reset tcp stream */ +void tcp_stream_reset(struct tcp_stream *tcp); +/* force TCP stream closing, do NOT use from tcp->tx callback */ +void tcp_stream_close(struct tcp_stream *tcp); + +void tcp_streams_poll(void);
-/** - * rxhand_tcp() - An incoming packet handler. - * @tcp: TCP stream - * @pkt: pointer to the application packet - * @dport: destination TCP port - * @sip: source IP address - * @sport: source TCP port - * @tcp_seq_num: TCP sequential number - * @tcp_ack_num: TCP acknowledgment number - * @action: TCP action (SYN, ACK, FIN, etc) - * @len: packet length - */ -typedef void rxhand_tcp(struct tcp_stream *tcp, uchar *pkt, - u32 tcp_seq_num, u32 tcp_ack_num, - u8 action, unsigned int len); -void tcp_set_tcp_handler(rxhand_tcp *f); - void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int len);
u16 tcp_set_pseudo_header(uchar *pkt, struct in_addr src, struct in_addr dest, diff --git a/include/net/wget.h b/include/net/wget.h index 6714f7ea573..9a423b30414 100644 --- a/include/net/wget.h +++ b/include/net/wget.h @@ -8,14 +8,6 @@ */ void wget_start(void);
-enum wget_state { - WGET_CLOSED, - WGET_CONNECTING, - WGET_CONNECTED, - WGET_TRANSFERRING, - WGET_TRANSFERRED -}; - #define DEBUG_WGET 0 /* Set to 1 for debug messages */ #define WGET_RETRY_COUNT 30 #define WGET_TIMEOUT 2000UL diff --git a/net/fastboot_tcp.c b/net/fastboot_tcp.c index de1048e366e..30eacca8d1e 100644 --- a/net/fastboot_tcp.c +++ b/net/fastboot_tcp.c @@ -11,140 +11,106 @@
-static char command[FASTBOOT_COMMAND_LEN] = {0}; -static char response[FASTBOOT_RESPONSE_LEN] = {0}; - static const unsigned short handshake_length = 4; static const uchar *handshake = "FB01";
-static u32 curr_tcp_seq_num; -static u32 curr_tcp_ack_num; -static unsigned int curr_request_len; -static enum fastboot_tcp_state { - FASTBOOT_CLOSED, - FASTBOOT_CONNECTED, - FASTBOOT_DISCONNECTING -} state = FASTBOOT_CLOSED; - -static void fastboot_tcp_answer(struct tcp_stream *tcp, u8 action, - unsigned int len) -{ - const u32 response_seq_num = curr_tcp_ack_num; - const u32 response_ack_num = curr_tcp_seq_num + - (curr_request_len > 0 ? curr_request_len : 1); +static char rxbuf[sizeof(u64) + FASTBOOT_COMMAND_LEN + 1]; +static char txbuf[sizeof(u64) + FASTBOOT_RESPONSE_LEN + 1];
- net_send_tcp_packet(len, tcp->rhost, tcp->rport, tcp->lport, - action, response_seq_num, response_ack_num); -} +static u32 data_read; +static u32 tx_last_offs, tx_last_len;
-static void fastboot_tcp_reset(struct tcp_stream *tcp) +static void tcp_stream_on_rcv_nxt_update(struct tcp_stream *tcp, u32 rx_bytes) { - fastboot_tcp_answer(tcp, TCP_RST, 0); - state = FASTBOOT_CLOSED; -} + u64 cmd_size; + __be64 len_be; + char saved; + int fastboot_command_id, len; + + if ((data_read == 0) && (rx_bytes >= handshake_length)) { + if (memcmp(rxbuf, handshake, handshake_length) != 0) { + printf("fastboot: bad handshake\n"); + tcp_stream_close(tcp); + return; + }
-static void fastboot_tcp_send_packet(struct tcp_stream *tcp, u8 action, - const uchar *data, unsigned int len) -{ - uchar *pkt = net_get_async_tx_pkt_buf(); + tx_last_offs = 0; + tx_last_len = handshake_length; + memcpy(txbuf, handshake, handshake_length); + + data_read += handshake_length; + rx_bytes -= handshake_length; + if (rx_bytes > 0) + memmove(rxbuf, rxbuf + handshake_length, rx_bytes); + return; + }
- memset(pkt, '\0', PKTSIZE); - pkt += net_eth_hdr_size() + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; - memcpy(pkt, data, len); - fastboot_tcp_answer(tcp, action, len); - memset(pkt, '\0', PKTSIZE); + if (rx_bytes < sizeof(u64)) + return; + + memcpy(&cmd_size, rxbuf, sizeof(u64)); + cmd_size = __be64_to_cpu(cmd_size); + if (rx_bytes < sizeof(u64) + cmd_size) + return; + + saved = rxbuf[sizeof(u64) + cmd_size]; + rxbuf[sizeof(u64) + cmd_size] = '\0'; + fastboot_command_id = fastboot_handle_command(rxbuf + sizeof(u64), + txbuf + sizeof(u64)); + fastboot_handle_boot(fastboot_command_id, + strncmp("OKAY", txbuf + sizeof(u64), 4) != 0); + rxbuf[sizeof(u64) + cmd_size] = saved; + + len = strlen(txbuf + sizeof(u64)); + len_be = __cpu_to_be64(len); + memcpy(txbuf, &len_be, sizeof(u64)); + + tx_last_offs += tx_last_len; + tx_last_len = len + sizeof(u64); + + data_read += sizeof(u64) + cmd_size; + rx_bytes -= sizeof(u64) + cmd_size; + if (rx_bytes > 0) + memmove(rxbuf, rxbuf + sizeof(u64) + cmd_size, rx_bytes); }
-static void fastboot_tcp_send_message(struct tcp_stream *tcp, - const char *message, unsigned int len) +static u32 tcp_stream_rx(struct tcp_stream *tcp, u32 rx_offs, void *buf, u32 len) { - __be64 len_be = __cpu_to_be64(len); - uchar *pkt = net_get_async_tx_pkt_buf(); - - memset(pkt, '\0', PKTSIZE); - pkt += net_eth_hdr_size() + IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; - // Put first 8 bytes as a big endian message length - memcpy(pkt, &len_be, 8); - pkt += 8; - memcpy(pkt, message, len); - fastboot_tcp_answer(tcp, TCP_ACK | TCP_PUSH, len + 8); - memset(pkt, '\0', PKTSIZE); + memcpy(rxbuf + rx_offs - data_read, buf, len); + return len; }
-static void fastboot_tcp_handler_ipv4(struct tcp_stream *tcp, uchar *pkt, - u32 tcp_seq_num, u32 tcp_ack_num, - u8 action, unsigned int len) +static u32 tcp_stream_tx(struct tcp_stream *tcp, u32 tx_offs, void *buf, u32 maxlen) { - int fastboot_command_id; - u64 command_size; - u8 tcp_fin = action & TCP_FIN; - u8 tcp_push = action & TCP_PUSH; - - curr_tcp_seq_num = tcp_seq_num; - curr_tcp_ack_num = tcp_ack_num; - curr_request_len = len; - - switch (state) { - case FASTBOOT_CLOSED: - if (tcp_push) { - if (len != handshake_length || - strlen(pkt) != handshake_length || - memcmp(pkt, handshake, handshake_length) != 0) { - fastboot_tcp_reset(tcp); - break; - } - fastboot_tcp_send_packet(tcp, TCP_ACK | TCP_PUSH, - handshake, handshake_length); - state = FASTBOOT_CONNECTED; - } - break; - case FASTBOOT_CONNECTED: - if (tcp_fin) { - fastboot_tcp_answer(tcp, TCP_FIN | TCP_ACK, 0); - state = FASTBOOT_DISCONNECTING; - break; - } - if (tcp_push) { - // First 8 bytes is big endian message length - command_size = __be64_to_cpu(*(u64 *)pkt); - len -= 8; - pkt += 8; - - // Only single packet messages are supported ATM - if (strlen(pkt) != command_size) { - fastboot_tcp_reset(tcp); - break; - } - strlcpy(command, pkt, len + 1); - fastboot_command_id = fastboot_handle_command(command, response); - fastboot_tcp_send_message(tcp, response, strlen(response)); - fastboot_handle_boot(fastboot_command_id, - strncmp("OKAY", response, 4) == 0); - } - break; - case FASTBOOT_DISCONNECTING: - if (tcp_push) - state = FASTBOOT_CLOSED; - break; - } + /* by design: tx_offs >= tx_last_offs */ + if (tx_offs >= tx_last_offs + tx_last_len) + return 0;
- memset(command, 0, FASTBOOT_COMMAND_LEN); - memset(response, 0, FASTBOOT_RESPONSE_LEN); - curr_tcp_seq_num = 0; - curr_tcp_ack_num = 0; - curr_request_len = 0; + maxlen = tx_last_offs + tx_last_len - tx_offs; + memcpy(buf, txbuf + (tx_offs - tx_last_offs), maxlen); + return maxlen; }
-static int incoming_filter(struct in_addr rhost, u16 rport, u16 lport) +static int tcp_stream_on_create(struct tcp_stream *tcp) { - return (lport == FASTBOOT_TCP_PORT); + if (tcp->lport != FASTBOOT_TCP_PORT) + return 0; + + data_read = 0; + tx_last_offs = 0; + tx_last_len = 0; + + tcp->on_rcv_nxt_update = tcp_stream_on_rcv_nxt_update; + tcp->rx = tcp_stream_rx; + tcp->tx = tcp_stream_tx; + return 1; }
void fastboot_tcp_start_server(void) { + memset(net_server_ethaddr, 0, 6); + tcp_stream_set_on_create_handler(tcp_stream_on_create); + printf("Using %s device\n", eth_get_name()); printf("Listening for fastboot command on tcp %pI4\n", &net_ip); - - tcp_set_incoming_filter(incoming_filter); - tcp_set_tcp_handler(fastboot_tcp_handler_ipv4); } diff --git a/net/net.c b/net/net.c index ff3018e6494..0fca11d3e8c 100644 --- a/net/net.c +++ b/net/net.c @@ -648,6 +648,9 @@ restart: * errors that may have happened. */ eth_rx(); +#if defined(CONFIG_PROT_TCP) + tcp_streams_poll(); +#endif
/* * Abort if ctrl-c was pressed. @@ -954,6 +957,7 @@ int net_send_ip_packet(uchar *ether, struct in_addr dest, int dport, int sport, + tcp_set_tcp_header(tcp, pkt + eth_hdr_size, payload_len, action, tcp_seq_num, tcp_ack_num); + tcp_stream_put(tcp); break; #endif default: diff --git a/net/tcp.c b/net/tcp.c index 2a0dcc4e771..a5689a892b2 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -25,9 +25,18 @@ #include <net.h> #include <net/tcp.h>
-static int tcp_activity_count; +#define TCP_SEND_RETRY 3 +#define TCP_SEND_TIMEOUT 2000UL +#define TCP_RX_INACTIVE_TIMEOUT 30000UL +#define TCP_START_SEQ_INC 2153 /* just large prime number */ +#define TCP_RCV_WND_SIZE (PKTBUFSRX * TCP_MSS) + +#define TCP_PACKET_OK 0 +#define TCP_PACKET_DROP 1 + static struct tcp_stream tcp_stream; -static tcp_incoming_filter *incoming_filter; + +static int (*tcp_stream_on_create)(struct tcp_stream *tcp);
/* * TCP lengths are stored as a rounded up number of 32 bit words. @@ -36,12 +45,10 @@ static tcp_incoming_filter *incoming_filter; */ #define LEN_B_TO_DW(x) ((x) >> 2) #define ROUND_TCPHDR_LEN(x) (LEN_B_TO_DW((x) + 3)) +#define ROUND_TCPHDR_BYTES(x) (((x) + 3) & ~3) #define SHIFT_TO_TCPHDRLEN_FIELD(x) ((x) << 4) #define GET_TCP_HDR_LEN_IN_BYTES(x) ((x) >> 2)
-/* Current TCP RX packet handler */ -static rxhand_tcp *tcp_packet_handler; - #define RANDOM_PORT_START 1024 #define RANDOM_PORT_RANGE 0x4000
@@ -63,6 +70,21 @@ static inline s32 tcp_seq_cmp(u32 a, u32 b) return (s32)(a - b); }
+static inline u32 tcp_get_start_seq(void) +{ + static u32 tcp_seq_inc; + u32 tcp_seq; + + tcp_seq = (get_timer(0) & 0xffffffff) + tcp_seq_inc; + tcp_seq_inc += TCP_START_SEQ_INC; + return tcp_seq; +} + +static inline ulong msec_to_ticks(ulong msec) +{ + return msec * CONFIG_SYS_HZ / 1000; +} + /** * tcp_stream_get_state() - get TCP stream state * @tcp: tcp stream @@ -85,15 +107,70 @@ static void tcp_stream_set_state(struct tcp_stream *tcp, tcp->state = new_state; }
+/** + * tcp_stream_get_status() - get TCP stream status + * @tcp: tcp stream + * + * Return: TCP stream status + */ +enum tcp_status tcp_stream_get_status(struct tcp_stream *tcp) +{ + return tcp->status; +} + +/** + * tcp_stream_set_status() - set TCP stream state + * @tcp: tcp stream + * @new_satus: new TCP stream status + */ +static void tcp_stream_set_status(struct tcp_stream *tcp, + enum tcp_state new_status) +{ + tcp->status = new_status; +} + +static void tcp_stream_init(struct tcp_stream *tcp, + struct in_addr rhost, u16 rport, u16 lport) +{ + memset(tcp, 0, sizeof(struct tcp_stream)); + tcp->rhost.s_addr = rhost.s_addr; + tcp->rport = rport; + tcp->lport = lport; + tcp->state = TCP_CLOSED; + tcp->lost.len = TCP_OPT_LEN_2; + tcp->rcv_wnd = TCP_RCV_WND_SIZE; + tcp->max_retry_count = TCP_SEND_RETRY; + tcp->initial_timeout = TCP_SEND_TIMEOUT; + tcp->rx_inactiv_timeout = TCP_RX_INACTIVE_TIMEOUT; + tcp->time_last_rx = get_timer(0); +} + +static void tcp_stream_destroy(struct tcp_stream *tcp) +{ + if (tcp->on_closed != NULL) + tcp->on_closed(tcp); + memset(tcp, 0, sizeof(struct tcp_stream)); +} + void tcp_init(void) { - incoming_filter = NULL; - tcp_stream.state = TCP_CLOSED; + static int initialized; + struct tcp_stream *tcp = &tcp_stream; + + tcp_stream_on_create = NULL; + if (!initialized) { + initialized = 1; + memset(tcp, 0, sizeof(struct tcp_stream)); + } + + tcp_stream_set_state(tcp, TCP_CLOSED); + tcp_stream_set_status(tcp, TCP_ERR_RST); + tcp_stream_destroy(tcp); }
-void tcp_set_incoming_filter(tcp_incoming_filter *filter) +void tcp_stream_set_on_create_handler(int (*on_create)(struct tcp_stream *)) { - incoming_filter = filter; + tcp_stream_on_create = on_create; }
static struct tcp_stream *tcp_stream_add(struct in_addr rhost, @@ -101,15 +178,14 @@ static struct tcp_stream *tcp_stream_add(struct in_addr rhost, { struct tcp_stream *tcp = &tcp_stream;
- if (tcp->state != TCP_CLOSED) + if ((tcp_stream_on_create == NULL) || + (tcp->state != TCP_CLOSED)) + return NULL; + + tcp_stream_init(tcp, rhost, rport, lport); + if (!tcp_stream_on_create(tcp)) return NULL;
- memset(tcp, 0, sizeof(struct tcp_stream)); - tcp->rhost.s_addr = rhost.s_addr; - tcp->rport = rport; - tcp->lport = lport; - tcp->state = TCP_CLOSED; - tcp->lost.len = TCP_OPT_LEN_2; return tcp; }
@@ -123,30 +199,203 @@ struct tcp_stream *tcp_stream_get(int is_new, struct in_addr rhost, (tcp->lport == lport)) return tcp;
- if (!is_new || (incoming_filter == NULL) || - !incoming_filter(rhost, rport, lport)) - return NULL; + return is_new ? tcp_stream_add(rhost, rport, lport) : NULL; +}
- return tcp_stream_add(rhost, rport, lport); +void tcp_stream_put(struct tcp_stream *tcp) +{ + if (tcp->state == TCP_CLOSED) + tcp_stream_destroy(tcp); }
-static void dummy_handler(struct tcp_stream *tcp, uchar *pkt, - u32 tcp_seq_num, u32 tcp_ack_num, - u8 action, unsigned int len) +u32 tcp_stream_rx_offs(struct tcp_stream *tcp) { + u32 ret; + + switch (tcp->state) { + case TCP_CLOSED: + case TCP_SYN_SENT: + case TCP_SYN_RECEIVED: + return 0; + default: + break; + } + + ret = tcp->rcv_nxt - tcp->irs - 1; + if (tcp->fin_rx && (tcp->rcv_nxt == tcp->fin_rx_seq)) + ret--; + return ret; }
-/** - * tcp_set_tcp_handler() - set a handler to receive data - * @f: handler - */ -void tcp_set_tcp_handler(rxhand_tcp *f) +u32 tcp_stream_tx_offs(struct tcp_stream *tcp) { - debug_cond(DEBUG_INT_STATE, "--- net_loop TCP handler set (%p)\n", f); - if (!f) - tcp_packet_handler = dummy_handler; - else - tcp_packet_handler = f; + u32 ret; + + switch (tcp->state) { + case TCP_CLOSED: + case TCP_SYN_SENT: + case TCP_SYN_RECEIVED: + return 0; + default: + break; + } + + ret = tcp->snd_una - tcp->iss - 1; + if (tcp->fin_tx && (tcp->snd_una == tcp->fin_tx_seq + 1)) + ret--; + return ret; +} + +static void tcp_stream_set_time_handler(struct tcp_stream *tcp, ulong msec, + void (*handler)(struct tcp_stream *)) +{ + if (msec == 0) { + tcp->time_handler = NULL; + return; + } + + tcp->time_handler = handler; + tcp->time_start = get_timer(0); + tcp->time_delta = msec_to_ticks(msec); +} + +static void tcp_send_packet(struct tcp_stream *tcp, u8 action, + u32 tcp_seq_num, u32 tcp_ack_num, u32 tx_len) +{ + net_send_tcp_packet(tx_len, tcp->rhost, tcp->rport, + tcp->lport, action, tcp_seq_num, + tcp_ack_num); +} + +static void tcp_send_repeat(struct tcp_stream *tcp) +{ + uchar *ptr; + u32 tcp_opts_size; + + if (tcp->retry_cnt == 0) { + puts("\nTCP: send retry counter exceeded\n"); + tcp_send_packet(tcp, TCP_RST, tcp->retry_seq_num, + tcp->rcv_nxt, 0); + tcp_stream_set_status(tcp, TCP_ERR_TOUT); + tcp_stream_set_state(tcp, TCP_CLOSED); + tcp_stream_destroy(tcp); + return; + } + tcp->retry_cnt--; + tcp->retry_timeout += tcp->initial_timeout; + + if (tcp->retry_tx_len > 0) { + tcp_opts_size = ROUND_TCPHDR_BYTES(TCP_TSOPT_SIZE + + tcp->lost.len); + ptr = net_tx_packet + net_eth_hdr_size() + + IP_TCP_HDR_SIZE + tcp_opts_size; + + if (tcp->retry_tx_len > TCP_MSS - tcp_opts_size) + tcp->retry_tx_len = TCP_MSS - tcp_opts_size; + + /* refill packet data */ + tcp->tx(tcp, tcp->retry_tx_offs, ptr, tcp->retry_tx_len); + } + tcp_send_packet(tcp, tcp->retry_action, tcp->retry_seq_num, + tcp->rcv_nxt, tcp->retry_tx_len); + + tcp_stream_set_time_handler(tcp, tcp->retry_timeout, tcp_send_repeat); +} + +static void tcp_send_packet_with_retry(struct tcp_stream *tcp, u8 action, + u32 tcp_seq_num, u32 tx_len, u32 tx_offs) +{ + tcp->retry_cnt = tcp->max_retry_count; + tcp->retry_timeout = tcp->initial_timeout; + tcp->retry_action = action; + tcp->retry_seq_num = tcp_seq_num; + tcp->retry_tx_len = tx_len; + tcp->retry_tx_offs = tx_offs; + + tcp_send_packet(tcp, action, tcp_seq_num, tcp->rcv_nxt, tx_len); + tcp_stream_set_time_handler(tcp, tcp->retry_timeout, tcp_send_repeat); +} + +static inline u8 tcp_stream_fin_needed(struct tcp_stream *tcp, u32 tcp_seq_num) +{ + return (tcp->fin_tx && (tcp_seq_num == tcp->fin_tx_seq)) ? TCP_FIN : 0; +} + +static void tcp_steam_tx_try(struct tcp_stream *tcp) +{ + uchar *ptr; + u32 tx_offs, tx_len, tcp_opts_size; + + if ((tcp->state != TCP_ESTABLISHED) || + (tcp->time_handler != NULL) || + (tcp->tx == NULL)) + return; + + tcp_opts_size = ROUND_TCPHDR_BYTES(TCP_TSOPT_SIZE + tcp->lost.len); + tx_len = TCP_MSS - tcp_opts_size; + if (tcp->fin_tx) { + /* do not try to send beyonds FIN packet limits */ + if (tcp_seq_cmp(tcp->snd_una, tcp->fin_tx_seq) >= 0) + return; + + tx_len = tcp->fin_tx_seq - tcp->snd_una; + if (tx_len > TCP_MSS - tcp_opts_size) + tx_len = TCP_MSS - tcp_opts_size; + } + + tx_offs = tcp_stream_tx_offs(tcp); + ptr = net_tx_packet + net_eth_hdr_size() + + IP_TCP_HDR_SIZE + tcp_opts_size; + + /* fill packet data and adjust size */ + tx_len = tcp->tx(tcp, tx_offs, ptr, tx_len); + if (tx_len == 0) + return; + + if (tcp_seq_cmp(tcp->snd_una + tx_len, tcp->snd_nxt) > 0) + tcp->snd_nxt = tcp->snd_una + tx_len; + + tcp_send_packet_with_retry(tcp, TCP_ACK | TCP_PUSH, + tcp->snd_una, tx_len, tx_offs); +} + +static void tcp_stream_poll(struct tcp_stream *tcp, ulong time) +{ + ulong delta; + void (*handler)(struct tcp_stream *tcp); + + if (tcp->state == TCP_CLOSED) + return; + + /* handle rx inactivity timeout */ + delta = msec_to_ticks(tcp->rx_inactiv_timeout); + if (time - tcp->time_last_rx >= delta) { + puts("\nTCP: rx inactivity timeout exceeded\n"); + tcp_stream_reset(tcp); + tcp_stream_set_status(tcp, TCP_ERR_TOUT); + tcp_stream_destroy(tcp); + return; + } + + /* handle retransmit timeout */ + if ((tcp->time_handler != NULL) && + (time - tcp->time_start >= tcp->time_delta)) { + handler = tcp->time_handler; + tcp->time_handler = NULL; + handler(tcp); + } + + tcp_steam_tx_try(tcp); +} + +void tcp_streams_poll(void) +{ + ulong time; + struct tcp_stream *tcp; + + time = get_timer(0); + tcp = &tcp_stream; + tcp_stream_poll(tcp, time); }
/** @@ -301,18 +550,8 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, "TCP Hdr:SYN (%pI4, %pI4, sq=%u, ak=%u)\n", &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); - tcp_activity_count = 0; net_set_syn_options(tcp, b); - tcp_seq_num = 0; - tcp_ack_num = 0; pkt_hdr_len = IP_TCP_O_SIZE; - if (tcp->state == TCP_SYN_SENT) { /* Too many SYNs */ - action = TCP_FIN; - tcp->state = TCP_FIN_WAIT_1; - } else { - tcp->lost.len = TCP_OPT_LEN_2; - tcp->state = TCP_SYN_SENT; - } break; case TCP_SYN | TCP_ACK: case TCP_ACK: @@ -329,21 +568,16 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); payload_len = 0; pkt_hdr_len = IP_TCP_HDR_SIZE; - tcp->state = TCP_FIN_WAIT_1; break; case TCP_RST | TCP_ACK: case TCP_RST: debug_cond(DEBUG_DEV_PKT, "TCP Hdr:RST (%pI4, %pI4, s=%u, a=%u)\n", &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); - tcp->state = TCP_CLOSED; break; /* Notify connection closing */ case (TCP_FIN | TCP_ACK): case (TCP_FIN | TCP_ACK | TCP_PUSH): - if (tcp->state == TCP_CLOSE_WAIT) - tcp->state = TCP_CLOSING; - debug_cond(DEBUG_DEV_PKT, "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%u, a=%u, A=%x)\n", &tcp->rhost, &net_ip, @@ -383,7 +617,7 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, * it is, then the u-boot tftp or nfs kernel netboot should be * considered. */ - b->ip.hdr.tcp_win = htons(PKTBUFSRX * TCP_MSS >> TCP_SCALE); + b->ip.hdr.tcp_win = htons(tcp->rcv_wnd >> TCP_SCALE);
b->ip.hdr.tcp_xsum = 0; b->ip.hdr.tcp_ugr = 0; @@ -502,6 +736,7 @@ void tcp_hole(struct tcp_stream *tcp, u32 tcp_seq_num, u32 len) void tcp_parse_options(struct tcp_stream *tcp, uchar *o, int o_len) { struct tcp_t_opt *tsopt; + struct tcp_scale *wsopt; uchar *p = o;
/* @@ -516,10 +751,13 @@ void tcp_parse_options(struct tcp_stream *tcp, uchar *o, int o_len) case TCP_O_END: return; case TCP_O_MSS: - case TCP_O_SCL: case TCP_P_SACK: case TCP_V_SACK: break; + case TCP_O_SCL: + wsopt = (struct tcp_scale *)p; + tcp->rmt_win_scale = wsopt->scale; + break; case TCP_O_TS: tsopt = (struct tcp_t_opt *)p; tcp->rmt_timestamp = tsopt->t_snd; @@ -534,129 +772,330 @@ void tcp_parse_options(struct tcp_stream *tcp, uchar *o, int o_len) } }
-static u8 tcp_state_machine(struct tcp_stream *tcp, u8 tcp_flags, - u32 tcp_seq_num, int payload_len) +static int tcp_seg_in_wnd(struct tcp_stream *tcp, + u32 tcp_seq_num, int payload_len) +{ + if ((payload_len == 0) && (tcp->rcv_wnd == 0)) { + if (tcp_seq_num == tcp->rcv_nxt) + return 1; + } + if ((payload_len == 0) && (tcp->rcv_wnd > 0)) { + if ((tcp_seq_cmp(tcp->rcv_nxt, tcp_seq_num) <= 0) && + (tcp_seq_cmp(tcp_seq_num, tcp->rcv_nxt + tcp->rcv_wnd) < 0)) + return 1; + } + if ((payload_len > 0) && (tcp->rcv_wnd > 0)) { + if ((tcp_seq_cmp(tcp->rcv_nxt, tcp_seq_num) <= 0) && + (tcp_seq_cmp(tcp_seq_num, tcp->rcv_nxt + tcp->rcv_wnd) < 0)) + return 1; + tcp_seq_num += payload_len - 1; + if ((tcp_seq_cmp(tcp->rcv_nxt, tcp_seq_num) <= 0) && + (tcp_seq_cmp(tcp_seq_num, tcp->rcv_nxt + tcp->rcv_wnd) < 0)) + return 1; + } + return 0; +} + +static int tcp_rx_check_ack_num(struct tcp_stream *tcp, u32 tcp_seq_num, + u32 tcp_ack_num, u32 tcp_win_size) +{ + u32 old_offs, new_offs; + u8 action; + + switch (tcp->state) { + case TCP_SYN_RECEIVED: + if ((tcp_seq_cmp(tcp->snd_una, tcp_ack_num) >= 0) || + (tcp_seq_cmp(tcp_ack_num, tcp->snd_nxt) > 0)) { + // segment acknowledgment is not acceptable + tcp_send_packet(tcp, TCP_RST, tcp_ack_num, 0, 0); + return TCP_PACKET_DROP; + } + + tcp_stream_set_state(tcp, TCP_ESTABLISHED); + tcp->snd_wnd = tcp_win_size; + tcp->snd_wl1 = tcp_seq_num; + tcp->snd_wl2 = tcp_ack_num; + + if (tcp->on_established != NULL) + tcp->on_established(tcp); + + fallthrough; + + case TCP_ESTABLISHED: + case TCP_FIN_WAIT_1: + case TCP_FIN_WAIT_2: + case TCP_CLOSE_WAIT: + case TCP_CLOSING: + if (tcp_seq_cmp(tcp_ack_num, tcp->snd_nxt) > 0) { + // ACK acks something not yet sent + action = tcp_stream_fin_needed(tcp, tcp->snd_una) | TCP_ACK; + tcp_send_packet(tcp, action, tcp->snd_una, tcp->rcv_nxt, 0); + return TCP_PACKET_DROP; + } + + if (tcp_seq_cmp(tcp->snd_una, tcp_ack_num) < 0) { + old_offs = tcp_stream_tx_offs(tcp); + tcp->snd_una = tcp_ack_num; + new_offs = tcp_stream_tx_offs(tcp); + if ((tcp->time_handler != NULL) && + (tcp_seq_cmp(tcp->snd_una, tcp->retry_seq_num) > 0)) { + tcp_stream_set_time_handler(tcp, 0, NULL); + } + if ((tcp->on_snd_una_update != NULL) && + (old_offs != new_offs)) + tcp->on_snd_una_update(tcp, new_offs); + } + + if (tcp_seq_cmp(tcp->snd_una, tcp_ack_num) <= 0) { + if ((tcp_seq_cmp(tcp->snd_wl1, tcp_seq_num) < 0) || + ((tcp->snd_wl1 == tcp_seq_num) && + (tcp_seq_cmp(tcp->snd_wl2, tcp_seq_num) <= 0))) { + tcp->snd_wnd = tcp_win_size; + tcp->snd_wl1 = tcp_seq_num; + tcp->snd_wl2 = tcp_ack_num; + } + } + + if (tcp->state == TCP_FIN_WAIT_1) { + if (tcp->snd_una == tcp->snd_nxt) + tcp_stream_set_state(tcp, TCP_FIN_WAIT_2); + } + + if (tcp->state == TCP_CLOSING) { + if (tcp->snd_una == tcp->snd_nxt) + tcp_stream_set_state(tcp, TCP_CLOSED); + } + return TCP_PACKET_OK; + + case TCP_LAST_ACK: + if (tcp_ack_num == tcp->snd_nxt) + tcp_stream_set_state(tcp, TCP_CLOSED); + return TCP_PACKET_OK; + + default: + return TCP_PACKET_DROP; + } +} + +static int tcp_rx_user_data(struct tcp_stream *tcp, u32 tcp_seq_num, + char *buf, int len) +{ + u32 tmp_len, buf_offs, old_offs, new_offs; + u8 action; + + if (len == 0) + return TCP_PACKET_OK; + + switch (tcp->state) { + case TCP_ESTABLISHED: + case TCP_FIN_WAIT_1: + case TCP_FIN_WAIT_2: + break; + default: + return TCP_PACKET_DROP; + } + + tmp_len = len; + old_offs = tcp_stream_rx_offs(tcp); + buf_offs = tcp_seq_num - tcp->irs - 1; + if (tcp->rx != NULL) + tmp_len = tcp->rx(tcp, buf_offs, buf, len); + if (tmp_len) + tcp_hole(tcp, tcp_seq_num, tmp_len); + + new_offs = tcp_stream_rx_offs(tcp); + if ((tcp->on_rcv_nxt_update != NULL) && (old_offs != new_offs)) + tcp->on_rcv_nxt_update(tcp, new_offs); + + action = tcp_stream_fin_needed(tcp, tcp->snd_una) | TCP_ACK; + tcp_send_packet(tcp, action, tcp->snd_una, tcp->rcv_nxt, 0); + return TCP_PACKET_OK; +} + +void tcp_rx_state_machine(struct tcp_stream *tcp, + union tcp_build_pkt *b, unsigned int pkt_len) { - u8 tcp_fin = tcp_flags & TCP_FIN; - u8 tcp_syn = tcp_flags & TCP_SYN; - u8 tcp_rst = tcp_flags & TCP_RST; - u8 tcp_push = tcp_flags & TCP_PUSH; - u8 tcp_ack = tcp_flags & TCP_ACK; - u8 action = TCP_DATA; + int tcp_len = pkt_len - IP_HDR_SIZE; + u32 tcp_seq_num, tcp_ack_num, tcp_win_size; + int tcp_hdr_len, payload_len; + u8 tcp_flags, action; + + tcp_hdr_len = GET_TCP_HDR_LEN_IN_BYTES(b->ip.hdr.tcp_hlen); + payload_len = tcp_len - tcp_hdr_len;
+ if (tcp_hdr_len > TCP_HDR_SIZE) + tcp_parse_options(tcp, (uchar *)b + IP_TCP_HDR_SIZE, + tcp_hdr_len - TCP_HDR_SIZE); /* - * tcp_flags are examined to determine TX action in a given state - * tcp_push is interpreted to mean "inform the app" - * urg, ece, cer and nonce flags are not supported. - * - * exe and crw are use to signal and confirm knowledge of congestion. - * This TCP only sends a file request and acks. If it generates - * congestion, the network is broken. + * Incoming sequence and ack numbers are server's view of the numbers. + * The app must swap the numbers when responding. */ - debug_cond(DEBUG_INT_STATE, "TCP STATE ENTRY %x\n", action); - if (tcp_rst) { - action = TCP_DATA; - tcp->state = TCP_CLOSED; - net_set_state(NETLOOP_FAIL); - debug_cond(DEBUG_INT_STATE, "TCP Reset %x\n", tcp_flags); - return TCP_RST; - } + tcp_seq_num = ntohl(b->ip.hdr.tcp_seq); + tcp_ack_num = ntohl(b->ip.hdr.tcp_ack); + tcp_win_size = ntohs(b->ip.hdr.tcp_win) << tcp->rmt_win_scale;
- switch (tcp->state) { + tcp_flags = b->ip.hdr.tcp_flags; + +// printf("pkt: seq=%d, ack=%d, flags=%x, len=%d\n", +// tcp_seq_num - tcp->irs, tcp_ack_num - tcp->iss, tcp_flags, pkt_len); +// printf("tcp: rcv_nxt=%d, snd_una=%d, snd_nxt=%d\n\n", +// tcp->rcv_nxt - tcp->irs, tcp->snd_una - tcp->iss, tcp->snd_nxt - tcp->iss); + + switch (tcp->state) { case TCP_CLOSED: - debug_cond(DEBUG_INT_STATE, "TCP CLOSED %x\n", tcp_flags); - if (tcp_syn) { - action = TCP_SYN | TCP_ACK; - tcp->irs = tcp_seq_num; - tcp->rcv_nxt = tcp_seq_num + 1; - tcp->lost.len = TCP_OPT_LEN_2; - tcp->state = TCP_SYN_RECEIVED; - } else if (tcp_ack || tcp_fin) { - action = TCP_DATA; + if (tcp_flags & TCP_RST) + return; + + if (tcp_flags & TCP_ACK) { + tcp_send_packet(tcp, TCP_RST, tcp_ack_num, 0, 0); + return; } - break; - case TCP_SYN_RECEIVED: + + if (!(tcp_flags & TCP_SYN)) + return; + + tcp->irs = tcp_seq_num; + tcp->rcv_nxt = tcp->irs + 1; + + tcp->iss = tcp_get_start_seq(); + tcp->snd_una = tcp->iss; + tcp->snd_nxt = tcp->iss + 1; + tcp->snd_wnd = tcp_win_size; + + tcp->time_last_rx = get_timer(0); + + tcp_stream_set_state(tcp, TCP_SYN_RECEIVED); + tcp_send_packet_with_retry(tcp, TCP_SYN | TCP_ACK, + tcp->iss, 0, 0); + return; + case TCP_SYN_SENT: - debug_cond(DEBUG_INT_STATE, "TCP_SYN_SENT | TCP_SYN_RECEIVED %x, %u\n", - tcp_flags, tcp_seq_num); - if (tcp_fin) { - action = action | TCP_PUSH; - tcp->state = TCP_CLOSE_WAIT; - } else if (tcp_ack || (tcp_syn && tcp_ack)) { - action |= TCP_ACK; - tcp->irs = tcp_seq_num; - tcp->rcv_nxt = tcp_seq_num + 1; - tcp->state = TCP_ESTABLISHED; - - if (tcp_syn && tcp_ack) - action |= TCP_PUSH; - } else { - action = TCP_DATA; + if (!(tcp_flags & TCP_ACK)) + return; + + if ((tcp_seq_cmp(tcp_ack_num, tcp->iss) <= 0) || + (tcp_seq_cmp(tcp_ack_num, tcp->snd_nxt) > 0)) { + if (!(tcp_flags & TCP_RST)) + tcp_send_packet(tcp, TCP_RST, tcp_ack_num, 0, 0); + return; } - break; + + if (tcp_flags & TCP_RST) { + tcp_stream_set_status(tcp, TCP_ERR_RST); + tcp_stream_set_state(tcp, TCP_CLOSED); + return; + } + + if (!(tcp_flags & TCP_SYN)) + return; + + /* stop retransmit of SYN */ + tcp_stream_set_time_handler(tcp, 0, NULL); + + tcp->irs = tcp_seq_num; + tcp->rcv_nxt = tcp->irs + 1; + tcp->snd_una = tcp_ack_num; + + tcp->time_last_rx = get_timer(0); + + /* our SYN has been ACKed */ + tcp_stream_set_state(tcp, TCP_ESTABLISHED); + + if (tcp->on_established != NULL) + tcp->on_established(tcp); + + action = tcp_stream_fin_needed(tcp, tcp->snd_una) | TCP_ACK; + tcp_send_packet(tcp, action, tcp->snd_una, tcp->rcv_nxt, 0); + tcp_rx_user_data(tcp, tcp_seq_num, + ((char *)b) + pkt_len - payload_len, + payload_len); + return; + + case TCP_SYN_RECEIVED: case TCP_ESTABLISHED: - debug_cond(DEBUG_INT_STATE, "TCP_ESTABLISHED %x\n", tcp_flags); - if (payload_len > 0) { - tcp_hole(tcp, tcp_seq_num, payload_len); - tcp_fin = TCP_DATA; /* cause standalone FIN */ + case TCP_FIN_WAIT_1: + case TCP_FIN_WAIT_2: + case TCP_CLOSE_WAIT: + case TCP_CLOSING: + case TCP_LAST_ACK: + if (!tcp_seg_in_wnd(tcp, tcp_seq_num, payload_len)) { + if (tcp_flags & TCP_RST) + return; + action = tcp_stream_fin_needed(tcp, tcp->snd_una) | TCP_ACK; + tcp_send_packet(tcp, action, tcp->snd_una, tcp->rcv_nxt, 0); + return; }
- if ((tcp_fin) && - (!IS_ENABLED(CONFIG_PROT_TCP_SACK) || - tcp->lost.len <= TCP_OPT_LEN_2)) { - action = action | TCP_FIN | TCP_PUSH | TCP_ACK; - tcp->state = TCP_CLOSE_WAIT; - } else if (tcp_ack) { - action = TCP_DATA; + tcp->time_last_rx = get_timer(0); + + if (tcp_flags & TCP_RST) { + tcp_stream_set_status(tcp, TCP_ERR_RST); + tcp_stream_set_state(tcp, TCP_CLOSED); + return; }
- if (tcp_syn) - action = TCP_ACK + TCP_RST; - else if (tcp_push) - action = action | TCP_PUSH; - break; - case TCP_CLOSE_WAIT: - debug_cond(DEBUG_INT_STATE, "TCP_CLOSE_WAIT (%x)\n", tcp_flags); - action = TCP_DATA; - break; - case TCP_FIN_WAIT_2: - debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_2 (%x)\n", tcp_flags); - if (tcp_ack) { - action = TCP_PUSH | TCP_ACK; - tcp->state = TCP_CLOSED; - puts("\n"); - } else if (tcp_syn) { - action = TCP_DATA; - } else if (tcp_fin) { - action = TCP_DATA; + if (tcp_flags & TCP_SYN) { + tcp_send_packet(tcp, TCP_RST, tcp_ack_num, 0, 0); + tcp_stream_set_status(tcp, TCP_ERR_RST); + tcp_stream_set_state(tcp, TCP_CLOSED); + return; } - break; - case TCP_FIN_WAIT_1: - debug_cond(DEBUG_INT_STATE, "TCP_FIN_WAIT_1 (%x)\n", tcp_flags); - if (tcp_fin) { - tcp->rcv_nxt++; - action = TCP_ACK | TCP_FIN; - tcp->state = TCP_FIN_WAIT_2; + + if (!(tcp_flags & TCP_ACK)) + return; + + if (tcp_rx_check_ack_num(tcp, tcp_seq_num, tcp_ack_num, + tcp_win_size) == TCP_PACKET_DROP) { + return; } - if (tcp_syn) - action = TCP_RST; - if (tcp_ack) - tcp->state = TCP_CLOSED; - break; - case TCP_CLOSING: - debug_cond(DEBUG_INT_STATE, "TCP_CLOSING (%x)\n", tcp_flags); - if (tcp_ack) { - action = TCP_PUSH; - tcp->state = TCP_CLOSED; - puts("\n"); - } else if (tcp_syn) { - action = TCP_RST; - } else if (tcp_fin) { - action = TCP_DATA; + + if (tcp_rx_user_data(tcp, tcp_seq_num, + ((char *)b) + pkt_len - payload_len, + payload_len) == TCP_PACKET_DROP) { + return; + } + + if (tcp_flags & TCP_FIN) { + tcp->fin_rx = 1; + tcp->fin_rx_seq = tcp_seq_num + payload_len + 1; + tcp_hole(tcp, tcp_seq_num + payload_len, 1); + action = tcp_stream_fin_needed(tcp, tcp->snd_una) | TCP_ACK; + tcp_send_packet(tcp, action, tcp->snd_una, tcp->rcv_nxt, 0); + } + + if (tcp->fin_rx && (tcp->fin_rx_seq == tcp->rcv_nxt)) { + /* all rx data were processed */ + switch (tcp->state) { + case TCP_ESTABLISHED: + tcp_stream_set_state(tcp, TCP_LAST_ACK); + tcp_send_packet_with_retry(tcp, TCP_ACK | TCP_FIN, + tcp->snd_nxt, 0, 0); + tcp->snd_nxt++; + break; + + case TCP_FIN_WAIT_1: + if (tcp_ack_num == tcp->snd_nxt) + tcp_stream_set_state(tcp, TCP_CLOSED); + else + tcp_stream_set_state(tcp, TCP_CLOSING); + break; + + case TCP_FIN_WAIT_2: + tcp_stream_set_state(tcp, TCP_CLOSED); + break; + + default: + break; + } + } + + if ((tcp->state == TCP_FIN_WAIT_1) && + tcp_stream_fin_needed(tcp, tcp->snd_una)) { + /* all tx data were acknowledged */ + tcp_send_packet_with_retry(tcp, TCP_ACK | TCP_FIN, + tcp->snd_una, 0, 0); } - break; } - return action; }
/** @@ -668,9 +1107,6 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) { int tcp_len = pkt_len - IP_HDR_SIZE; u16 tcp_rx_xsum = b->ip.hdr.ip_sum; - u8 tcp_action = TCP_DATA; - u32 tcp_seq_num, tcp_ack_num; - int tcp_hdr_len, payload_len; struct tcp_stream *tcp; struct in_addr src;
@@ -714,54 +1150,57 @@ void rxhand_tcp_f(union tcp_build_pkt *b, unsigned int pkt_len) if (tcp == NULL) return;
- tcp_hdr_len = GET_TCP_HDR_LEN_IN_BYTES(b->ip.hdr.tcp_hlen); - payload_len = tcp_len - tcp_hdr_len; + tcp_rx_state_machine(tcp, b, pkt_len); + tcp_stream_put(tcp); +}
- if (tcp_hdr_len > TCP_HDR_SIZE) - tcp_parse_options(tcp, (uchar *)b + IP_TCP_HDR_SIZE, - tcp_hdr_len - TCP_HDR_SIZE); - /* - * Incoming sequence and ack numbers are server's view of the numbers. - * The app must swap the numbers when responding. - */ - tcp_seq_num = ntohl(b->ip.hdr.tcp_seq); - tcp_ack_num = ntohl(b->ip.hdr.tcp_ack); +struct tcp_stream *tcp_stream_connect(struct in_addr rhost, u16 rport) +{ + struct tcp_stream *tcp;
- /* Packets are not ordered. Send to app as received. */ - tcp_action = tcp_state_machine(tcp, b->ip.hdr.tcp_flags, - tcp_seq_num, payload_len); + tcp = tcp_stream_add(rhost, rport, random_port()); + if (tcp == NULL) + return NULL;
- tcp_activity_count++; - if (tcp_activity_count > TCP_ACTIVITY) { - puts("| "); - tcp_activity_count = 0; - } + tcp->iss = tcp_get_start_seq(); + tcp->snd_una = tcp->iss; + tcp->snd_nxt = tcp->iss + 1;
- if ((tcp_action & TCP_PUSH) || payload_len > 0) { - debug_cond(DEBUG_DEV_PKT, - "TCP Notify (action=%x, Seq=%u,Ack=%u,Pay%d)\n", - tcp_action, tcp_seq_num, tcp_ack_num, payload_len); + tcp_stream_set_state(tcp, TCP_SYN_SENT); + tcp_send_packet_with_retry(tcp, TCP_SYN, tcp->snd_una, 0, 0); + return tcp; +}
- (*tcp_packet_handler) (tcp, (uchar *)b + pkt_len - payload_len, - tcp_seq_num, tcp_ack_num, tcp_action, - payload_len); +void tcp_stream_reset(struct tcp_stream *tcp) +{ + if (tcp->state == TCP_CLOSED) + return;
- } else if (tcp_action != TCP_DATA) { - debug_cond(DEBUG_DEV_PKT, - "TCP Action (action=%x,Seq=%u,Ack=%u,Pay=%d)\n", - tcp_action, tcp_ack_num, tcp->rcv_nxt, payload_len); - - /* - * Warning: Incoming Ack & Seq sequence numbers are transposed - * here to outgoing Seq & Ack sequence numbers - */ - net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, - (tcp_action & (~TCP_PUSH)), - tcp_ack_num, tcp->rcv_nxt); - } + tcp_stream_set_time_handler(tcp, 0, NULL); + tcp_send_packet(tcp, TCP_RST, tcp->snd_una, 0, 0); + tcp_stream_set_status(tcp, TCP_ERR_RST); + tcp_stream_set_state(tcp, TCP_CLOSED); }
-struct tcp_stream *tcp_stream_connect(struct in_addr rhost, u16 rport) +void tcp_stream_close(struct tcp_stream *tcp) { - return tcp_stream_add(rhost, rport, random_port()); + switch (tcp->state) { + case TCP_SYN_SENT: + tcp_stream_reset(tcp); + break; + case TCP_SYN_RECEIVED: + case TCP_ESTABLISHED: + tcp->fin_tx = 1; + tcp->fin_tx_seq = tcp->snd_nxt; + if (tcp_stream_fin_needed(tcp, tcp->snd_una)) { + /* all tx data were acknowledged */ + tcp_send_packet_with_retry(tcp, TCP_ACK | TCP_FIN, + tcp->snd_una, 0, 0); + } + tcp_stream_set_state(tcp, TCP_FIN_WAIT_1); + tcp->snd_nxt++; + break; + default: + break; + } } diff --git a/net/wget.c b/net/wget.c index 327fe3cfbce..c91ca0bbc90 100644 --- a/net/wget.c +++ b/net/wget.c @@ -22,48 +22,26 @@ DECLARE_GLOBAL_DATA_PTR; /* The default, change with environment variable 'httpdstp' */ #define SERVER_PORT 80
+#define HASHES_PER_LINE 65 + +#define HTTP_MAX_HDR_LEN 2048 + static const char bootfile1[] = "GET "; static const char bootfile3[] = " HTTP/1.0\r\n\r\n"; static const char http_eom[] = "\r\n\r\n"; -static const char http_ok[] = "200"; -static const char content_len[] = "Content-Length"; +static const char http_ok[] = " 200 "; +static const char content_len[] = "Content-Length:"; static const char linefeed[] = "\r\n"; -static int wget_timeout_count; -struct tcp_stream *tcp; - -struct pkt_qd { - uchar *pkt; - unsigned int tcp_seq_num; - unsigned int len; -}; - -/* - * This is a control structure for out of order packets received. - * The actual packet bufers are in the kernel space, and are - * expected to be overwritten by the downloaded image. - */ -#define PKTQ_SZ (PKTBUFSRX / 4) -static struct pkt_qd pkt_q[PKTQ_SZ]; -static int pkt_q_idx; +static struct in_addr web_server_ip; +static unsigned int server_port; static unsigned long content_length; static unsigned int packets; - -static unsigned int initial_data_seq_num; -static unsigned int next_data_seq_num; - -static enum wget_state current_wget_state; +static u32 http_hdr_size; +static int wget_tsize_num_hash;
static char *image_url; -static unsigned int wget_timeout = WGET_TIMEOUT; - static enum net_loop_state wget_loop_state;
-/* Timeout retry parameters */ -static u8 retry_action; /* actions for TCP retry */ -static unsigned int retry_tcp_ack_num; /* TCP retry acknowledge number*/ -static unsigned int retry_tcp_seq_num; /* TCP retry sequence number */ -static int retry_len; /* TCP retry length */ - static ulong wget_load_size;
/** @@ -96,7 +74,6 @@ static int wget_init_load_size(void) static inline int store_block(uchar *src, unsigned int offset, unsigned int len) { ulong store_addr = image_load_addr + offset; - ulong newsize = offset + len; uchar *ptr;
if (IS_ENABLED(CONFIG_LMB)) { @@ -116,330 +93,150 @@ static inline int store_block(uchar *src, unsigned int offset, unsigned int len) ptr = map_sysmem(store_addr, len); memcpy(ptr, src, len); unmap_sysmem(ptr); - - if (net_boot_file_size < (offset + len)) - net_boot_file_size = newsize; - return 0; }
-/** - * wget_send_stored() - wget response dispatcher - * - * WARNING, This, and only this, is the place in wget.c where - * SEQUENCE NUMBERS are swapped between incoming (RX) - * and outgoing (TX). - * Procedure wget_handler() is correct for RX traffic. - */ -static void wget_send_stored(void) +static void show_block_marker(void) { - u8 action = retry_action; - int len = retry_len; - unsigned int tcp_ack_num = retry_tcp_seq_num + (len == 0 ? 1 : len); - unsigned int tcp_seq_num = retry_tcp_ack_num; - uchar *ptr, *offset; - - switch (current_wget_state) { - case WGET_CLOSED: - debug_cond(DEBUG_WGET, "wget: send SYN\n"); - current_wget_state = WGET_CONNECTING; - net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, - tcp_seq_num, tcp_ack_num); - packets = 0; - break; - case WGET_CONNECTING: - pkt_q_idx = 0; - net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, - tcp_seq_num, tcp_ack_num); - - ptr = net_tx_packet + net_eth_hdr_size() + - IP_TCP_HDR_SIZE + TCP_TSOPT_SIZE + 2; - offset = ptr; - - memcpy(offset, &bootfile1, strlen(bootfile1)); - offset += strlen(bootfile1); - - memcpy(offset, image_url, strlen(image_url)); - offset += strlen(image_url); - - memcpy(offset, &bootfile3, strlen(bootfile3)); - offset += strlen(bootfile3); - net_send_tcp_packet((offset - ptr), tcp->rhost, tcp->rport, tcp->lport, - TCP_PUSH, tcp_seq_num, tcp_ack_num); - current_wget_state = WGET_CONNECTED; - break; - case WGET_CONNECTED: - case WGET_TRANSFERRING: - case WGET_TRANSFERRED: - net_send_tcp_packet(0, tcp->rhost, tcp->rport, tcp->lport, action, - tcp_seq_num, tcp_ack_num); - break; - } -} + int cnt;
-static void wget_send(u8 action, unsigned int tcp_seq_num, - unsigned int tcp_ack_num, int len) -{ - retry_action = action; - retry_tcp_ack_num = tcp_ack_num; - retry_tcp_seq_num = tcp_seq_num; - retry_len = len; + if (content_length != -1) { + if (net_boot_file_size > content_length) + content_length = net_boot_file_size;
- wget_send_stored(); + cnt = net_boot_file_size * 50 / content_length; + while (wget_tsize_num_hash < cnt) { + putc('#'); + wget_tsize_num_hash++; + } + } else { + if ((packets % 10) == 0) + putc('#'); + else if (((packets + 1) % (10 * HASHES_PER_LINE)) == 0) + puts("\n"); + } }
-void wget_fail(char *error_message, unsigned int tcp_seq_num, - unsigned int tcp_ack_num, u8 action) +static void tcp_stream_on_closed(struct tcp_stream *tcp) { - printf("wget: Transfer Fail - %s\n", error_message); - net_set_timeout_handler(0, NULL); - wget_send(action, tcp_seq_num, tcp_ack_num, 0); + if (tcp->status != TCP_ERR_OK) + wget_loop_state = NETLOOP_FAIL; + + if (wget_loop_state != NETLOOP_SUCCESS) + printf("\nwget: Transfer Fail, TCP status - %d\n", tcp->status); + else + printf("\nPackets received %d, Transfer Successful\n", packets); + net_set_state(wget_loop_state); }
-void wget_success(u8 action, unsigned int tcp_seq_num, - unsigned int tcp_ack_num, int len, int packets) +static void tcp_stream_on_rcv_nxt_update(struct tcp_stream *tcp, u32 rx_bytes) { - printf("Packets received %d, Transfer Successful\n", packets); - wget_send(action, tcp_seq_num, tcp_ack_num, len); -} + char *pos, *tail; + uchar saved, *ptr; + int i;
-/* - * Interfaces of U-BOOT - */ -static void wget_timeout_handler(void) -{ - if (++wget_timeout_count > WGET_RETRY_COUNT) { - puts("\nRetry count exceeded; starting again\n"); - wget_send(TCP_RST, 0, 0, 0); - net_start_again(); - } else { - puts("T "); - net_set_timeout_handler(wget_timeout + - WGET_TIMEOUT * wget_timeout_count, - wget_timeout_handler); - wget_send_stored(); + if (http_hdr_size != 0) { + net_boot_file_size = rx_bytes - http_hdr_size; + show_block_marker(); + return; } -}
-#define PKT_QUEUE_OFFSET 0x20000 -#define PKT_QUEUE_PACKET_SIZE 0x800 + ptr = map_sysmem(image_load_addr, rx_bytes + 1);
-static void wget_connected(uchar *pkt, unsigned int tcp_seq_num, - u8 action, unsigned int tcp_ack_num, unsigned int len) -{ - uchar *pkt_in_q; - char *pos; - int hlen, i; - uchar *ptr1; + saved = ptr[rx_bytes]; + ptr[rx_bytes] = '\0'; + pos = strstr((char *)ptr, http_eom); + ptr[rx_bytes] = saved;
- pkt[len] = '\0'; - pos = strstr((char *)pkt, http_eom); + if (pos == NULL) { + if ((rx_bytes < HTTP_MAX_HDR_LEN) && + (tcp->state == TCP_ESTABLISHED)) + goto end;
- if (!pos) { - debug_cond(DEBUG_WGET, - "wget: Connected, data before Header %p\n", pkt); - pkt_in_q = (void *)image_load_addr + PKT_QUEUE_OFFSET + - (pkt_q_idx * PKT_QUEUE_PACKET_SIZE); - - ptr1 = map_sysmem((phys_addr_t)pkt_in_q, len); - memcpy(ptr1, pkt, len); - unmap_sysmem(ptr1); - - pkt_q[pkt_q_idx].pkt = pkt_in_q; - pkt_q[pkt_q_idx].tcp_seq_num = tcp_seq_num; - pkt_q[pkt_q_idx].len = len; - pkt_q_idx++; - - if (pkt_q_idx >= PKTQ_SZ) { - printf("wget: Fatal error, queue overrun!\n"); - net_set_state(NETLOOP_FAIL); + printf("ERROR: misssed HTTP header\n"); + tcp_stream_close(tcp); + wget_loop_state = NETLOOP_FAIL; + goto end; + }
- return; - } - } else { - debug_cond(DEBUG_WGET, "wget: Connected HTTP Header %p\n", pkt); - /* sizeof(http_eom) - 1 is the string length of (http_eom) */ - hlen = pos - (char *)pkt + sizeof(http_eom) - 1; - pos = strstr((char *)pkt, linefeed); - if (pos > 0) - i = pos - (char *)pkt; - else - i = hlen; - printf("%.*s", i, pkt); - - current_wget_state = WGET_TRANSFERRING; - - initial_data_seq_num = tcp_seq_num + hlen; - next_data_seq_num = tcp_seq_num + len; - - if (strstr((char *)pkt, http_ok) == 0) { - debug_cond(DEBUG_WGET, - "wget: Connected Bad Xfer\n"); - wget_loop_state = NETLOOP_FAIL; - wget_send(action, tcp_seq_num, tcp_ack_num, len); - } else { - debug_cond(DEBUG_WGET, - "wget: Connctd pkt %p hlen %x\n", - pkt, hlen); - - pos = strstr((char *)pkt, content_len); - if (!pos) { - content_length = -1; - } else { - pos += sizeof(content_len) + 2; - strict_strtoul(pos, 10, &content_length); - debug_cond(DEBUG_WGET, - "wget: Connected Len %lu\n", - content_length); - } - - net_boot_file_size = 0; - - if (len > hlen) { - if (store_block(pkt + hlen, 0, len - hlen) != 0) { - wget_loop_state = NETLOOP_FAIL; - wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); - net_set_state(NETLOOP_FAIL); - return; - } - } + http_hdr_size = pos - (char *)ptr + strlen(http_eom); + *pos = '\0'; + + pos = strstr((char *)ptr, linefeed); + if (pos > 0) + i = pos - (char *)ptr; + else + i = http_hdr_size - strlen(http_eom); + printf("%.*s\n", i, ptr); + + if (strstr((char *)ptr, http_ok) == NULL) { + debug_cond(DEBUG_WGET, "wget: Connected Bad Xfer\n"); + tcp_stream_close(tcp); + wget_loop_state = NETLOOP_FAIL; + goto end; + }
- debug_cond(DEBUG_WGET, - "wget: Connected Pkt %p hlen %x\n", - pkt, hlen); - - for (i = 0; i < pkt_q_idx; i++) { - int err; - - ptr1 = map_sysmem( - (phys_addr_t)(pkt_q[i].pkt), - pkt_q[i].len); - err = store_block(ptr1, - pkt_q[i].tcp_seq_num - - initial_data_seq_num, - pkt_q[i].len); - unmap_sysmem(ptr1); - debug_cond(DEBUG_WGET, - "wget: Connctd pkt Q %p len %x\n", - pkt_q[i].pkt, pkt_q[i].len); - if (err) { - wget_loop_state = NETLOOP_FAIL; - wget_fail("wget: store error\n", tcp_seq_num, tcp_ack_num, action); - net_set_state(NETLOOP_FAIL); - return; - } - } - } + debug_cond(DEBUG_WGET, "wget: Connctd pkt %p hlen %x\n", + ptr, http_hdr_size); + + pos = strstr((char *)ptr, content_len); + if (!pos) { + content_length = -1; + } else { + pos += strlen(content_len) + 1; + content_length = simple_strtoul(pos, &tail, 10); + if ((*tail != '\r') && (*tail != '\n') && (*tail != '\0')) + content_length = -1; + printf("%s %d\n", content_len, (int)content_length); } - wget_send(action, tcp_seq_num, tcp_ack_num, len); + + net_boot_file_size = rx_bytes - http_hdr_size; + memmove(ptr, ptr + http_hdr_size, net_boot_file_size); + +end: + unmap_sysmem(ptr); + + wget_loop_state = NETLOOP_SUCCESS; }
-/** - * wget_handler() - TCP handler of wget - * @tcp: TCP stream - * @pkt: pointer to the application packet - * @tcp_seq_num: TCP sequential number - * @tcp_ack_num: TCP acknowledgment number - * @action: TCP action (SYN, ACK, FIN, etc) - * @len: packet length - * - * In the "application push" invocation, the TCP header with all - * its information is pointed to by the packet pointer. - */ -static void wget_handler(struct tcp_stream *tcp, uchar *pkt, - u32 tcp_seq_num, u32 tcp_ack_num, - u8 action, unsigned int len) +static u32 tcp_stream_rx(struct tcp_stream *tcp, u32 rx_offs, void *buf, u32 len) { - enum tcp_state wget_tcp_state = tcp_stream_get_state(tcp); - - net_set_timeout_handler(wget_timeout, wget_timeout_handler); packets++; + store_block(buf, rx_offs - http_hdr_size, len); + return len; +}
- switch (current_wget_state) { - case WGET_CLOSED: - debug_cond(DEBUG_WGET, "wget: Handler: Error!, State wrong\n"); - break; - case WGET_CONNECTING: - debug_cond(DEBUG_WGET, - "wget: Connecting In len=%x, Seq=%u, Ack=%u\n", - len, tcp_seq_num, tcp_ack_num); - if (!len) { - if (wget_tcp_state == TCP_ESTABLISHED) { - debug_cond(DEBUG_WGET, - "wget: Cting, send, len=%x\n", len); - wget_send(action, tcp_seq_num, tcp_ack_num, - len); - } else { - printf("%.*s", len, pkt); - wget_fail("wget: Handler Connected Fail\n", - tcp_seq_num, tcp_ack_num, action); - } - } - break; - case WGET_CONNECTED: - debug_cond(DEBUG_WGET, "wget: Connected seq=%u, len=%x\n", - tcp_seq_num, len); - if (!len) { - wget_fail("Image not found, no data returned\n", - tcp_seq_num, tcp_ack_num, action); - } else { - wget_connected(pkt, tcp_seq_num, action, tcp_ack_num, len); - } - break; - case WGET_TRANSFERRING: - debug_cond(DEBUG_WGET, - "wget: Transferring, seq=%x, ack=%x,len=%x\n", - tcp_seq_num, tcp_ack_num, len); - - if (next_data_seq_num != tcp_seq_num) { - debug_cond(DEBUG_WGET, "wget: seq=%x packet was lost\n", next_data_seq_num); - return; - } - next_data_seq_num = tcp_seq_num + len; +static u32 tcp_stream_tx(struct tcp_stream *tcp, u32 tx_offs, void *buf, u32 maxlen) +{ + int ret;
- if (store_block(pkt, tcp_seq_num - initial_data_seq_num, len) != 0) { - wget_fail("wget: store error\n", - tcp_seq_num, tcp_ack_num, action); - net_set_state(NETLOOP_FAIL); - return; - } + if (tx_offs != 0) + return 0;
- switch (wget_tcp_state) { - case TCP_FIN_WAIT_2: - wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, len); - fallthrough; - case TCP_SYN_SENT: - case TCP_SYN_RECEIVED: - case TCP_CLOSING: - case TCP_FIN_WAIT_1: - case TCP_CLOSED: - net_set_state(NETLOOP_FAIL); - break; - case TCP_ESTABLISHED: - wget_send(TCP_ACK, tcp_seq_num, tcp_ack_num, - len); - wget_loop_state = NETLOOP_SUCCESS; - break; - case TCP_CLOSE_WAIT: /* End of transfer */ - current_wget_state = WGET_TRANSFERRED; - wget_send(action | TCP_ACK | TCP_FIN, - tcp_seq_num, tcp_ack_num, len); - break; - } - break; - case WGET_TRANSFERRED: - printf("Packets received %d, Transfer Successful\n", packets); - net_set_state(wget_loop_state); - break; - } + ret = snprintf(buf, maxlen, "%s%s%s", bootfile1, image_url, bootfile3); + return ret; +} + +static int tcp_stream_on_create(struct tcp_stream *tcp) +{ + if ((tcp->rhost.s_addr != web_server_ip.s_addr) || + (tcp->rport != server_port)) + return 0; + + tcp->max_retry_count = WGET_RETRY_COUNT; + tcp->initial_timeout = WGET_TIMEOUT; + tcp->on_closed = tcp_stream_on_closed; + tcp->on_rcv_nxt_update = tcp_stream_on_rcv_nxt_update; + tcp->rx = tcp_stream_rx; + tcp->tx = tcp_stream_tx; + return 1; }
#define BLOCKSIZE 512
void wget_start(void) { - struct in_addr web_server_ip; - unsigned int server_port; + struct tcp_stream *tcp;
image_url = strchr(net_boot_file_name, ':'); if (image_url > 0) { @@ -487,12 +284,6 @@ void wget_start(void) } }
- net_set_timeout_handler(wget_timeout, wget_timeout_handler); - tcp_set_tcp_handler(wget_handler); - - wget_timeout_count = 0; - current_wget_state = WGET_CLOSED; - /* * Zero out server ether to force arp resolution in case * the server ip for the previous u-boot command, for example dns @@ -501,14 +292,21 @@ void wget_start(void)
+ packets = 0; + net_boot_file_size = 0; + http_hdr_size = 0; + wget_tsize_num_hash = 0; + wget_loop_state = NETLOOP_FAIL; + server_port = env_get_ulong("httpdstp", 10, SERVER_PORT) & 0xffff; + tcp_stream_set_on_create_handler(tcp_stream_on_create); tcp = tcp_stream_connect(web_server_ip, server_port); if (tcp == NULL) { + printf("No free tcp streams\n"); net_set_state(NETLOOP_FAIL); return; } - - wget_send(TCP_SYN, 0, 0, 0); + tcp_stream_put(tcp); }
#if (IS_ENABLED(CONFIG_CMD_DNS))
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- net/tcp.c | 70 +++++++++++++++++++++++++++++-------------------------- 1 file changed, 37 insertions(+), 33 deletions(-)
diff --git a/net/tcp.c b/net/tcp.c index a5689a892b2..9fb80f9c2a8 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -528,10 +528,37 @@ void net_set_syn_options(struct tcp_stream *tcp, union tcp_build_pkt *b) b->ip.end = TCP_O_END; }
+const char *tcpflags_to_str(char tcpflags, char *buf, int size) +{ + int i = 0, len; + char *orig = buf; + const struct { + int bit; + const char *name; + } desc[] = {{TCP_RST, "RST"}, {TCP_SYN, "SYN"}, {TCP_PUSH, "PSH"}, + {TCP_FIN, "FIN"}, {TCP_ACK, "ACK"}, {0, NULL}}; + + *orig = '\0'; + while (desc[i].name != NULL) { + len = strlen(desc[i].name); + if (size <= len + 1) + break; + if (buf != orig) { + *buf++ = ','; + size--; + } + strcpy(buf, desc[i].name); + buf += len; + size -= len; + } + return orig; +} + int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, u8 action, u32 tcp_seq_num, u32 tcp_ack_num) { union tcp_build_pkt *b = (union tcp_build_pkt *)pkt; + char buf[24]; int pkt_hdr_len; int pkt_len; int tcp_len; @@ -541,55 +568,32 @@ int tcp_set_tcp_header(struct tcp_stream *tcp, uchar *pkt, int payload_len, * 4 bits reserved options */ b->ip.hdr.tcp_flags = action; - pkt_hdr_len = IP_TCP_HDR_SIZE; b->ip.hdr.tcp_hlen = SHIFT_TO_TCPHDRLEN_FIELD(LEN_B_TO_DW(TCP_HDR_SIZE));
switch (action) { case TCP_SYN: debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:SYN (%pI4, %pI4, sq=%u, ak=%u)\n", - &tcp->rhost, &net_ip, - tcp_seq_num, tcp_ack_num); + "TCP Hdr:%s (%pI4, %pI4, s=%u, a=%u)\n", + tcpflags_to_str(action, buf, sizeof(buf)), + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); net_set_syn_options(tcp, b); pkt_hdr_len = IP_TCP_O_SIZE; break; - case TCP_SYN | TCP_ACK: - case TCP_ACK: - pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(tcp, b); - b->ip.hdr.tcp_flags = action; - debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:ACK (%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num, - action); - break; - case TCP_FIN: - debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:FIN (%pI4, %pI4, s=%u, a=%u)\n", - &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); - payload_len = 0; - pkt_hdr_len = IP_TCP_HDR_SIZE; - break; case TCP_RST | TCP_ACK: case TCP_RST: debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:RST (%pI4, %pI4, s=%u, a=%u)\n", + "TCP Hdr:%s (%pI4, %pI4, s=%u, a=%u)\n", + tcpflags_to_str(action, buf, sizeof(buf)), &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); + pkt_hdr_len = IP_TCP_HDR_SIZE; break; - /* Notify connection closing */ - case (TCP_FIN | TCP_ACK): - case (TCP_FIN | TCP_ACK | TCP_PUSH): - debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:FIN ACK PSH(%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &tcp->rhost, &net_ip, - tcp_seq_num, tcp_ack_num, action); - fallthrough; default: pkt_hdr_len = IP_HDR_SIZE + net_set_ack_options(tcp, b); - b->ip.hdr.tcp_flags = action | TCP_PUSH | TCP_ACK; debug_cond(DEBUG_DEV_PKT, - "TCP Hdr:dft (%pI4, %pI4, s=%u, a=%u, A=%x)\n", - &tcp->rhost, &net_ip, - tcp_seq_num, tcp_ack_num, action); + "TCP Hdr:%s (%pI4, %pI4, s=%u, a=%u)\n", + tcpflags_to_str(action, buf, sizeof(buf)), + &tcp->rhost, &net_ip, tcp_seq_num, tcp_ack_num); + break; }
pkt_len = pkt_hdr_len + payload_len;
Some driver implements it's own network packet pool, so PKTBUFSRX is zero. This results in zero-size TCP receive window, so data transfer doesn't work. Avod it by setting a reasonable fallback value.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- net/tcp.c | 6 +++++- 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/net/tcp.c b/net/tcp.c index 9fb80f9c2a8..fc713f503fa 100644 --- a/net/tcp.c +++ b/net/tcp.c @@ -29,7 +29,11 @@ #define TCP_SEND_TIMEOUT 2000UL #define TCP_RX_INACTIVE_TIMEOUT 30000UL #define TCP_START_SEQ_INC 2153 /* just large prime number */ -#define TCP_RCV_WND_SIZE (PKTBUFSRX * TCP_MSS) +#if PKTBUFSRX != 0 + #define TCP_RCV_WND_SIZE (PKTBUFSRX * TCP_MSS) +#else + #define TCP_RCV_WND_SIZE (4 * TCP_MSS) +#endif
#define TCP_PACKET_OK 0 #define TCP_PACKET_DROP 1
This patch adds downloading/uploading of data with netcat. Client/server mode both supported.
Signed-off-by: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu --- cmd/Kconfig | 7 ++ cmd/net.c | 34 +++++++-- include/net.h | 2 +- include/net/netcat.h | 20 ++++++ net/Makefile | 1 + net/net.c | 9 +++ net/netcat.c | 159 +++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 226 insertions(+), 6 deletions(-) create mode 100644 include/net/netcat.h create mode 100644 net/netcat.c
diff --git a/cmd/Kconfig b/cmd/Kconfig index 6834bbd82f3..00cc13e2006 100644 --- a/cmd/Kconfig +++ b/cmd/Kconfig @@ -1990,6 +1990,13 @@ config CMD_WGET wget is a simple command to download kernel, or other files, from a http server over TCP.
+config CMD_NETCAT + bool "netcat" + select PROT_TCP + help + netcat is a simple command to load/store kernel, or other files, + using netcat like manner over TCP. + config CMD_MII bool "mii" imply CMD_MDIO diff --git a/cmd/net.c b/cmd/net.c index d407d8320a3..ecc1b49f52f 100644 --- a/cmd/net.c +++ b/cmd/net.c @@ -208,6 +208,28 @@ U_BOOT_CMD( ); #endif
+#if defined(CONFIG_CMD_NETCAT) +static int do_netcat(struct cmd_tbl *cmdtp, int flag, int argc, char *const argv[]) +{ + if (argc < 2) + return 1; + + if (strcmp(argv[1], "load") == 0) + return netboot_common(NETCAT_LOAD, cmdtp, argc - 1, argv + 1); + else if (strcmp(argv[1], "store") == 0) + return netboot_common(NETCAT_STORE, cmdtp, argc - 1, argv + 1); + else + return 1; +} + +U_BOOT_CMD( + netcat, 5, 1, do_netcat, + "load/store data via tcp netcat utility", + "load [loadAddress] [[hostIPaddr:]port]\n" + "store Address Size [[hostIPaddr:]port]\n" +); +#endif + static void netboot_update_env(void) { char tmp[46]; @@ -325,16 +347,17 @@ static int parse_args(enum proto_t proto, int argc, char *const argv[])
switch (argc) { case 1: - if (IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) + if ((IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) || + (IS_ENABLED(CONFIG_CMD_NETCAT) && proto == NETCAT_STORE)) return 1; - /* refresh bootfile name from env */ copy_filename(net_boot_file_name, env_get("bootfile"), sizeof(net_boot_file_name)); break;
case 2: - if (IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) + if ((IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) || + (IS_ENABLED(CONFIG_CMD_NETCAT) && proto == NETCAT_STORE)) return 1; /* * Only one arg - accept two forms: @@ -356,7 +379,8 @@ static int parse_args(enum proto_t proto, int argc, char *const argv[]) break;
case 3: - if (IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) { + if ((IS_ENABLED(CONFIG_CMD_TFTPPUT) && proto == TFTPPUT) || + (IS_ENABLED(CONFIG_CMD_NETCAT) && proto == NETCAT_STORE)) { if (parse_addr_size(argv)) return 1; } else { @@ -367,7 +391,7 @@ static int parse_args(enum proto_t proto, int argc, char *const argv[]) } break;
-#ifdef CONFIG_CMD_TFTPPUT +#if defined(CONFIG_CMD_TFTPPUT) || defined(CONFIG_CMD_NETCAT) case 4: if (parse_addr_size(argv)) return 1; diff --git a/include/net.h b/include/net.h index fe645245f0f..235396a171b 100644 --- a/include/net.h +++ b/include/net.h @@ -516,7 +516,7 @@ extern int net_restart_wrap; /* Tried all network devices */ enum proto_t { BOOTP, RARP, ARP, TFTPGET, DHCP, DHCP6, PING, PING6, DNS, NFS, CDP, NETCONS, SNTP, TFTPSRV, TFTPPUT, LINKLOCAL, FASTBOOT_UDP, FASTBOOT_TCP, - WOL, UDP, NCSI, WGET, RS + WOL, UDP, NCSI, WGET, NETCAT_LOAD, NETCAT_STORE, RS };
extern char net_boot_file_name[1024];/* Boot File name */ diff --git a/include/net/netcat.h b/include/net/netcat.h new file mode 100644 index 00000000000..09470e7f0ce --- /dev/null +++ b/include/net/netcat.h @@ -0,0 +1,20 @@ +/* SPDX-License-Identifier: BSD-2-Clause + * + * netcat include file + * Copyright (C) 2024 IOPSYS Software Solutions AB + * Author: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu + */ +#ifndef __NET_NETCAT_TCP_H__ +#define __NET_NETCAT_TCP_H__ + +/** + * netcat_load_start() - begin netcat in loading mode + */ +void netcat_load_start(void); + +/** + * netcat_store_start() - begin netcat in data storing mode + */ +void netcat_store_start(void); + +#endif /* __NET_NETCAT_TCP_H__ */ diff --git a/net/Makefile b/net/Makefile index 64ab7ec740a..dac7b4859fb 100644 --- a/net/Makefile +++ b/net/Makefile @@ -33,6 +33,7 @@ obj-$(CONFIG_CMD_WOL) += wol.o obj-$(CONFIG_PROT_UDP) += udp.o obj-$(CONFIG_PROT_TCP) += tcp.o obj-$(CONFIG_CMD_WGET) += wget.o +obj-$(CONFIG_CMD_NETCAT) += netcat.o
# Disable this warning as it is triggered by: # sprintf(buf, index ? "foo%d" : "foo", index) diff --git a/net/net.c b/net/net.c index 0fca11d3e8c..809fe5c4792 100644 --- a/net/net.c +++ b/net/net.c @@ -110,6 +110,7 @@ #include <test/test.h> #include <net/tcp.h> #include <net/wget.h> +#include <net/netcat.h> #include "arp.h" #include "bootp.h" #include "cdp.h" @@ -566,6 +567,14 @@ restart: wget_start(); break; #endif +#if defined(CONFIG_CMD_NETCAT) + case NETCAT_LOAD: + netcat_load_start(); + break; + case NETCAT_STORE: + netcat_store_start(); + break; +#endif #if defined(CONFIG_CMD_CDP) case CDP: cdp_start(); diff --git a/net/netcat.c b/net/netcat.c new file mode 100644 index 00000000000..ea225c68c87 --- /dev/null +++ b/net/netcat.c @@ -0,0 +1,159 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * netcat support driver + * Copyright (C) 2024 IOPSYS Software Solutions AB + * Author: Mikhail Kshevetskiy mikhail.kshevetskiy@iopsys.eu + */ + +#include <command.h> +#include <display_options.h> +#include <env.h> +#include <image.h> +#include <mapmem.h> +#include <net.h> +#include <net/tcp.h> +#include <net/netcat.h> + +#define HASHES_PER_LINE 65 + +static struct in_addr server_ip; +static u16 server_port; +static u16 local_port; +static int listen; +static int reading; +static unsigned int packets; +static enum net_loop_state netcat_loop_state; + +static void show_block_marker(void) +{ + if ((packets % 10) == 0) + putc('#'); + else if (((packets + 1) % (10 * HASHES_PER_LINE)) == 0) + puts("\n"); +} + +static void tcp_stream_on_closed(struct tcp_stream *tcp) +{ + if (tcp->status != TCP_ERR_OK) + netcat_loop_state = NETLOOP_FAIL; + + if (netcat_loop_state != NETLOOP_SUCCESS) + printf("\nnetcat: Transfer Fail, TCP status - %d\n", tcp->status); + else + printf("\nPackets %s %d, Transfer Successful\n", + reading ? "received" : "transmitted", packets); + net_set_state(netcat_loop_state); +} + +static void tcp_stream_on_rcv_nxt_update(struct tcp_stream *tcp, u32 rx_bytes) +{ + net_boot_file_size = rx_bytes; + show_block_marker(); +} + +static void tcp_stream_on_snd_una_update(struct tcp_stream *tcp, u32 tx_bytes) +{ + show_block_marker(); + if (tx_bytes == image_save_size) + tcp_stream_close(tcp); +} + +static void tcp_stream_on_established(struct tcp_stream *tcp) +{ + netcat_loop_state = NETLOOP_SUCCESS; +} + +static u32 tcp_stream_rx(struct tcp_stream *tcp, u32 rx_offs, void *buf, u32 len) +{ + void *ptr; + + packets++; + ptr = map_sysmem(image_load_addr + rx_offs, len); + memcpy(ptr, buf, len); + unmap_sysmem(ptr); + return len; +} + +static u32 tcp_stream_tx(struct tcp_stream *tcp, u32 tx_offs, void *buf, u32 maxlen) +{ + void *ptr; + + if (tx_offs + maxlen > image_save_size) + maxlen = image_save_size - tx_offs; + if (maxlen == 0) + return 0; + + packets++; + ptr = map_sysmem(image_save_addr + tx_offs, maxlen); + memcpy(buf, ptr, maxlen); + unmap_sysmem(ptr); + return maxlen; +} + +static int tcp_stream_on_create(struct tcp_stream *tcp) +{ + if (listen) { + if (tcp->lport != local_port) + return 0; + } else { + if ((tcp->rhost.s_addr != server_ip.s_addr) || + (tcp->rport != server_port)) + return 0; + } + + netcat_loop_state = NETLOOP_FAIL; + net_boot_file_size = 0; + packets = 0; + + tcp->on_closed = tcp_stream_on_closed; + tcp->on_established = tcp_stream_on_established; + if (reading) { + tcp->on_rcv_nxt_update = tcp_stream_on_rcv_nxt_update; + tcp->rx = tcp_stream_rx; + } else { + tcp->on_snd_una_update = tcp_stream_on_snd_una_update; + tcp->tx = tcp_stream_tx; + } + return 1; +} + +static void netcat_start(void) +{ + struct tcp_stream *tcp; + + memset(net_server_ethaddr, 0, 6); + tcp_stream_set_on_create_handler(tcp_stream_on_create); + + if (strchr(net_boot_file_name, ':') == NULL) { + listen = 1; + printf("Listening on port %s...\n", net_boot_file_name); + + local_port = dectoul(net_boot_file_name, NULL); + } else { + listen = 0; + printf("Connecting to %s...\n", net_boot_file_name); + + server_ip = string_to_ip(net_boot_file_name); + server_port = dectoul(strchr(net_boot_file_name, ':') + 1, NULL); + + tcp = tcp_stream_connect(server_ip, server_port); + if (tcp == NULL) { + printf("No free tcp streams\n"); + net_set_state(NETLOOP_FAIL); + return; + } + tcp_stream_put(tcp); + } +} + +void netcat_load_start(void) +{ + reading = 1; + return netcat_start(); +} + +void netcat_store_start(void) +{ + reading = 0; + return netcat_start(); +}
Hi Mikhail,
This series of patches greatly improve TCP support.
Where's the changelog of what changed from v1?
The benefits:
- a lot of bug was fixed
- tcp cliens becomes smaller/simpler
- fix data uploading (now it's possible to transmit a huge array of data from the board to external server)
- data downloading/uploading with netcat over tcp was added
Mikhail Kshevetskiy (9): net/tcp: fix TCP options processing net/tcp: fix selective acknowledge net/tcp: put connection specific data into a tcp_stream structure net/tcp: add connection info to tcp_stream structure net/tcp: rename ack_edge and seq_init to more common rcv_nxt and irs net/tcp: improve tcp framework, use better state machine net/tcp: simplify tcp header filling code net/tcp: define a fallback value for rcv_wnd size net/netcat: add netcat over tcp support
cmd/Kconfig | 7 + cmd/net.c | 34 +- include/net.h | 7 +- include/net/netcat.h | 20 + include/net/tcp.h | 227 +++++++- include/net/wget.h | 8 - net/Makefile | 1 + net/fastboot_tcp.c | 190 +++---- net/net.c | 30 +- net/netcat.c | 159 ++++++ net/tcp.c | 1253 +++++++++++++++++++++++++++++------------- net/wget.c | 479 +++++----------- 12 files changed, 1538 insertions(+), 877 deletions(-) create mode 100644 include/net/netcat.h create mode 100644 net/netcat.c
-- 2.39.2
On 05.07.2024 20:56, Peter Robinson wrote:
Hi Mikhail,
no changes, just remove some patches and add a cover letter
The benefits:
-- 2.39.2
On Fri, 5 Jul 2024 at 22:16, Mikhail Kshevetskiy mikhail.kshevetskiy@genexis.eu wrote:
Hi Mikhail,
So there were changes then :-)
The benefits:
-- 2.39.2
Mikhail Kshevetskiy
Mikhail Kshevetskiy
Peter Robinson
