[PATCHv3 0/6] omap4/omap5: convert to DM model
This is a combined series of both omap4/omap5 DM conversion in one. The main change across all the boards in this version is to drop SPI support completely. SPI is only available on expansion headers on the omap4 panda / omap5 uevm boards, and it is impossible for the authors of the patches in this series to both complete the SPI conversion to DM model, and test it, so it was deemed better to drop it completely.
Again, if someone from community needs the SPI support later, it should be relatively straightforward to add it back with proper expertise / tools.
-Tero
-- Texas Instruments Finland Oy, Porkkalankatu 22, 00180 Helsinki. Y-tunnus/Business ID: 0615521-4. Kotipaikka/Domicile: Helsinki
Copy all device tree files required for omap4 panda support from mainline Linux.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/elpida_ecb240abacn.dtsi | 68 + arch/arm/dts/omap4-l4-abe.dtsi | 489 +++++ arch/arm/dts/omap4-l4.dtsi | 2474 ++++++++++++++++++++++++++ arch/arm/dts/omap4-mcpdm.dtsi | 44 + arch/arm/dts/omap4-panda-common.dtsi | 573 ++++++ arch/arm/dts/omap4-panda-es.dts | 82 + arch/arm/dts/omap4-panda.dts | 13 + arch/arm/dts/omap4.dtsi | 657 +++++++ arch/arm/dts/omap443x-clocks.dtsi | 15 + arch/arm/dts/omap443x.dtsi | 76 + arch/arm/dts/omap4460.dtsi | 131 ++ arch/arm/dts/omap446x-clocks.dtsi | 24 + arch/arm/dts/omap44xx-clocks.dtsi | 1324 ++++++++++++++ arch/arm/dts/twl6030.dtsi | 105 ++ arch/arm/dts/twl6030_omap4.dtsi | 35 + include/dt-bindings/clock/omap4.h | 149 ++ 16 files changed, 6259 insertions(+) create mode 100644 arch/arm/dts/elpida_ecb240abacn.dtsi create mode 100644 arch/arm/dts/omap4-l4-abe.dtsi create mode 100644 arch/arm/dts/omap4-l4.dtsi create mode 100644 arch/arm/dts/omap4-mcpdm.dtsi create mode 100644 arch/arm/dts/omap4-panda-common.dtsi create mode 100644 arch/arm/dts/omap4-panda-es.dts create mode 100644 arch/arm/dts/omap4-panda.dts create mode 100644 arch/arm/dts/omap4.dtsi create mode 100644 arch/arm/dts/omap443x-clocks.dtsi create mode 100644 arch/arm/dts/omap443x.dtsi create mode 100644 arch/arm/dts/omap4460.dtsi create mode 100644 arch/arm/dts/omap446x-clocks.dtsi create mode 100644 arch/arm/dts/omap44xx-clocks.dtsi create mode 100644 arch/arm/dts/twl6030.dtsi create mode 100644 arch/arm/dts/twl6030_omap4.dtsi create mode 100644 include/dt-bindings/clock/omap4.h
diff --git a/arch/arm/dts/elpida_ecb240abacn.dtsi b/arch/arm/dts/elpida_ecb240abacn.dtsi new file mode 100644 index 0000000000..d87ee4794f --- /dev/null +++ b/arch/arm/dts/elpida_ecb240abacn.dtsi @@ -0,0 +1,68 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common devices used in different OMAP boards + */ + +/ { + elpida_ECB240ABACN: lpddr2 { + compatible = "Elpida,ECB240ABACN","jedec,lpddr2-s4"; + density = <2048>; + io-width = <32>; + + tRPab-min-tck = <3>; + tRCD-min-tck = <3>; + tWR-min-tck = <3>; + tRASmin-min-tck = <3>; + tRRD-min-tck = <2>; + tWTR-min-tck = <2>; + tXP-min-tck = <2>; + tRTP-min-tck = <2>; + tCKE-min-tck = <3>; + tCKESR-min-tck = <3>; + tFAW-min-tck = <8>; + + timings_elpida_ECB240ABACN_400mhz: lpddr2-timings@0 { + compatible = "jedec,lpddr2-timings"; + min-freq = <10000000>; + max-freq = <400000000>; + tRPab = <21000>; + tRCD = <18000>; + tWR = <15000>; + tRAS-min = <42000>; + tRRD = <10000>; + tWTR = <7500>; + tXP = <7500>; + tRTP = <7500>; + tCKESR = <15000>; + tDQSCK-max = <5500>; + tFAW = <50000>; + tZQCS = <90000>; + tZQCL = <360000>; + tZQinit = <1000000>; + tRAS-max-ns = <70000>; + tDQSCK-max-derated = <6000>; + }; + + timings_elpida_ECB240ABACN_200mhz: lpddr2-timings@1 { + compatible = "jedec,lpddr2-timings"; + min-freq = <10000000>; + max-freq = <200000000>; + tRPab = <21000>; + tRCD = <18000>; + tWR = <15000>; + tRAS-min = <42000>; + tRRD = <10000>; + tWTR = <10000>; + tXP = <7500>; + tRTP = <7500>; + tCKESR = <15000>; + tDQSCK-max = <5500>; + tFAW = <50000>; + tZQCS = <90000>; + tZQCL = <360000>; + tZQinit = <1000000>; + tRAS-max-ns = <70000>; + tDQSCK-max-derated = <6000>; + }; + }; +}; diff --git a/arch/arm/dts/omap4-l4-abe.dtsi b/arch/arm/dts/omap4-l4-abe.dtsi new file mode 100644 index 0000000000..a6feb201c5 --- /dev/null +++ b/arch/arm/dts/omap4-l4-abe.dtsi @@ -0,0 +1,489 @@ +&l4_abe { /* 0x40100000 */ + compatible = "ti,omap4-l4-abe", "simple-bus"; + reg = <0x40100000 0x400>, + <0x40100400 0x400>; + reg-names = "la", "ap"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x40100000 0x100000>, /* segment 0 */ + <0x49000000 0x49000000 0x100000>; + segment@0 { /* 0x40100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = + /* CPU to L4 ABE mapping */ + <0x00000000 0x00000000 0x000400>, /* ap 0 */ + <0x00000400 0x00000400 0x000400>, /* ap 1 */ + <0x00022000 0x00022000 0x001000>, /* ap 2 */ + <0x00023000 0x00023000 0x001000>, /* ap 3 */ + <0x00024000 0x00024000 0x001000>, /* ap 4 */ + <0x00025000 0x00025000 0x001000>, /* ap 5 */ + <0x00026000 0x00026000 0x001000>, /* ap 6 */ + <0x00027000 0x00027000 0x001000>, /* ap 7 */ + <0x00028000 0x00028000 0x001000>, /* ap 8 */ + <0x00029000 0x00029000 0x001000>, /* ap 9 */ + <0x0002a000 0x0002a000 0x001000>, /* ap 10 */ + <0x0002b000 0x0002b000 0x001000>, /* ap 11 */ + <0x0002e000 0x0002e000 0x001000>, /* ap 12 */ + <0x0002f000 0x0002f000 0x001000>, /* ap 13 */ + <0x00030000 0x00030000 0x001000>, /* ap 14 */ + <0x00031000 0x00031000 0x001000>, /* ap 15 */ + <0x00032000 0x00032000 0x001000>, /* ap 16 */ + <0x00033000 0x00033000 0x001000>, /* ap 17 */ + <0x00038000 0x00038000 0x001000>, /* ap 18 */ + <0x00039000 0x00039000 0x001000>, /* ap 19 */ + <0x0003a000 0x0003a000 0x001000>, /* ap 20 */ + <0x0003b000 0x0003b000 0x001000>, /* ap 21 */ + <0x0003c000 0x0003c000 0x001000>, /* ap 22 */ + <0x0003d000 0x0003d000 0x001000>, /* ap 23 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 24 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 25 */ + <0x00080000 0x00080000 0x010000>, /* ap 26 */ + <0x00080000 0x00080000 0x001000>, /* ap 27 */ + <0x000a0000 0x000a0000 0x010000>, /* ap 28 */ + <0x000a0000 0x000a0000 0x001000>, /* ap 29 */ + <0x000c0000 0x000c0000 0x010000>, /* ap 30 */ + <0x000c0000 0x000c0000 0x001000>, /* ap 31 */ + <0x000f1000 0x000f1000 0x001000>, /* ap 32 */ + <0x000f2000 0x000f2000 0x001000>, /* ap 33 */ + + /* L3 to L4 ABE mapping */ + <0x49000000 0x49000000 0x000400>, /* ap 0 */ + <0x49000400 0x49000400 0x000400>, /* ap 1 */ + <0x49022000 0x49022000 0x001000>, /* ap 2 */ + <0x49023000 0x49023000 0x001000>, /* ap 3 */ + <0x49024000 0x49024000 0x001000>, /* ap 4 */ + <0x49025000 0x49025000 0x001000>, /* ap 5 */ + <0x49026000 0x49026000 0x001000>, /* ap 6 */ + <0x49027000 0x49027000 0x001000>, /* ap 7 */ + <0x49028000 0x49028000 0x001000>, /* ap 8 */ + <0x49029000 0x49029000 0x001000>, /* ap 9 */ + <0x4902a000 0x4902a000 0x001000>, /* ap 10 */ + <0x4902b000 0x4902b000 0x001000>, /* ap 11 */ + <0x4902e000 0x4902e000 0x001000>, /* ap 12 */ + <0x4902f000 0x4902f000 0x001000>, /* ap 13 */ + <0x49030000 0x49030000 0x001000>, /* ap 14 */ + <0x49031000 0x49031000 0x001000>, /* ap 15 */ + <0x49032000 0x49032000 0x001000>, /* ap 16 */ + <0x49033000 0x49033000 0x001000>, /* ap 17 */ + <0x49038000 0x49038000 0x001000>, /* ap 18 */ + <0x49039000 0x49039000 0x001000>, /* ap 19 */ + <0x4903a000 0x4903a000 0x001000>, /* ap 20 */ + <0x4903b000 0x4903b000 0x001000>, /* ap 21 */ + <0x4903c000 0x4903c000 0x001000>, /* ap 22 */ + <0x4903d000 0x4903d000 0x001000>, /* ap 23 */ + <0x4903e000 0x4903e000 0x001000>, /* ap 24 */ + <0x4903f000 0x4903f000 0x001000>, /* ap 25 */ + <0x49080000 0x49080000 0x010000>, /* ap 26 */ + <0x49080000 0x49080000 0x001000>, /* ap 27 */ + <0x490a0000 0x490a0000 0x010000>, /* ap 28 */ + <0x490a0000 0x490a0000 0x001000>, /* ap 29 */ + <0x490c0000 0x490c0000 0x010000>, /* ap 30 */ + <0x490c0000 0x490c0000 0x001000>, /* ap 31 */ + <0x490f1000 0x490f1000 0x001000>, /* ap 32 */ + <0x490f2000 0x490f2000 0x001000>; /* ap 33 */ + + target-module@22000 { /* 0x40122000, ap 2 02.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2208c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x22000 0x1000>, + <0x49022000 0x49022000 0x1000>; + + mcbsp1: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49022000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 33>, + <&sdma 34>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@24000 { /* 0x40124000, ap 4 04.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2408c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x24000 0x1000>, + <0x49024000 0x49024000 0x1000>; + + mcbsp2: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49024000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 17>, + <&sdma 18>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@26000 { /* 0x40126000, ap 6 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2608c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCBSP3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>, + <0x49026000 0x49026000 0x1000>; + + mcbsp3: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49026000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 19>, + <&sdma 20>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@28000 { /* 0x40128000, ap 8 08.0 */ + compatible = "ti,sysc-mcasp", "ti,sysc"; + reg = <0x28000 0x4>, + <0x28004 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCASP_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>, + <0x49028000 0x49028000 0x1000>; + + /* + * Child device unsupported by davinci-mcasp. At least + * RX path is disabled for omap4, and only DIT mode + * works with no I2S. See also old Android kernel + * omap-mcasp driver for more information. + */ + }; + + target-module@2a000 { /* 0x4012a000, ap 10 0a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>, + <0x4902a000 0x4902a000 0x1000>; + }; + + target-module@2e000 { /* 0x4012e000, ap 12 0c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x2e000 0x4>, + <0x2e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_DMIC_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2e000 0x1000>, + <0x4902e000 0x4902e000 0x1000>; + + dmic: dmic@0 { + compatible = "ti,omap4-dmic"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x4902e000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 67>; + dma-names = "up_link"; + status = "disabled"; + }; + }; + + target-module@30000 { /* 0x40130000, ap 14 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x30000 0x4>, + <0x30010 0x4>, + <0x30014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_WD_TIMER3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x30000 0x1000>, + <0x49030000 0x49030000 0x1000>; + + wdt3: wdt@0 { + compatible = "ti,omap4-wdt", "ti,omap3-wdt"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + mcpdm_module: target-module@32000 { /* 0x40132000, ap 16 10.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_MCPDM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>, + <0x49032000 0x49032000 0x1000>; + + /* Must be only enabled for boards with pdmclk wired */ + status = "disabled"; + + mcpdm: mcpdm@0 { + compatible = "ti,omap4-mcpdm"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x49032000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 65>, + <&sdma 66>; + dma-names = "up_link", "dn_link"; + }; + }; + + target-module@38000 { /* 0x40138000, ap 18 12.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x38000 0x4>, + <0x38010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x38000 0x1000>, + <0x49038000 0x49038000 0x1000>; + + timer5: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x49038000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER5_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3a000 { /* 0x4013a000, ap 20 14.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3a000 0x4>, + <0x3a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER6_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3a000 0x1000>, + <0x4903a000 0x4903a000 0x1000>; + + timer6: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903a000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER6_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3c000 { /* 0x4013c000, ap 22 16.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3c000 0x4>, + <0x3c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER7_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3c000 0x1000>, + <0x4903c000 0x4903c000 0x1000>; + + timer7: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903c000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER7_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3e000 { /* 0x4013e000, ap 24 18.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_TIMER8_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>, + <0x4903e000 0x4903e000 0x1000>; + + timer8: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x00000000 0x80>, + <0x4903e000 0x80>; + clocks = <&abe_clkctrl OMAP4_TIMER8_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + ti,timer-dsp; + }; + }; + + target-module@80000 { /* 0x40180000, ap 26 1a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x80000 0x10000>, + <0x49080000 0x49080000 0x10000>; + }; + + target-module@a0000 { /* 0x401a0000, ap 28 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa0000 0x10000>, + <0x490a0000 0x490a0000 0x10000>; + }; + + target-module@c0000 { /* 0x401c0000, ap 30 1e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc0000 0x10000>, + <0x490c0000 0x490c0000 0x10000>; + }; + + target-module@f1000 { /* 0x401f1000, ap 32 20.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xf1000 0x4>, + <0xf1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP4_AESS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xf1000 0x1000>, + <0x490f1000 0x490f1000 0x1000>; + + /* + * No child device binding or driver in mainline. + * See Android tree and related upstreaming efforts + * for the old driver. + */ + }; + }; +}; + diff --git a/arch/arm/dts/omap4-l4.dtsi b/arch/arm/dts/omap4-l4.dtsi new file mode 100644 index 0000000000..ef59e4e97d --- /dev/null +++ b/arch/arm/dts/omap4-l4.dtsi @@ -0,0 +1,2474 @@ +// SPDX-License-Identifier: GPL-2.0 +&l4_cfg { /* 0x4a000000 */ + compatible = "ti,omap4-l4-cfg", "simple-bus"; + reg = <0x4a000000 0x800>, + <0x4a000800 0x800>, + <0x4a001000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4a000000 0x080000>, /* segment 0 */ + <0x00080000 0x4a080000 0x080000>, /* segment 1 */ + <0x00100000 0x4a100000 0x080000>, /* segment 2 */ + <0x00180000 0x4a180000 0x080000>, /* segment 3 */ + <0x00200000 0x4a200000 0x080000>, /* segment 4 */ + <0x00280000 0x4a280000 0x080000>, /* segment 5 */ + <0x00300000 0x4a300000 0x080000>; /* segment 6 */ + + segment@0 { /* 0x4a000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00002000 0x00002000 0x001000>, /* ap 3 */ + <0x00003000 0x00003000 0x001000>, /* ap 4 */ + <0x00004000 0x00004000 0x001000>, /* ap 5 */ + <0x00005000 0x00005000 0x001000>, /* ap 6 */ + <0x00056000 0x00056000 0x001000>, /* ap 7 */ + <0x00057000 0x00057000 0x001000>, /* ap 8 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 9 */ + <0x00058000 0x00058000 0x004000>, /* ap 10 */ + <0x00062000 0x00062000 0x001000>, /* ap 11 */ + <0x00063000 0x00063000 0x001000>, /* ap 12 */ + <0x00008000 0x00008000 0x002000>, /* ap 23 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 24 */ + <0x00066000 0x00066000 0x001000>, /* ap 25 */ + <0x00067000 0x00067000 0x001000>, /* ap 26 */ + <0x0005e000 0x0005e000 0x002000>, /* ap 80 */ + <0x00060000 0x00060000 0x001000>, /* ap 81 */ + <0x00064000 0x00064000 0x001000>, /* ap 86 */ + <0x00065000 0x00065000 0x001000>; /* ap 87 */ + + target-module@2000 { /* 0x4a002000, ap 3 06.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_core"; + reg = <0x2000 0x4>, + <0x2010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + + omap4_scm_core: scm@0 { + compatible = "ti,omap4-scm-core", "simple-bus"; + reg = <0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + + scm_conf: scm_conf@0 { + compatible = "syscon"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + }; + + omap_control_usb2phy: control-phy@300 { + compatible = "ti,control-phy-usb2"; + reg = <0x300 0x4>; + reg-names = "power"; + }; + + omap_control_usbotg: control-phy@33c { + compatible = "ti,control-phy-otghs"; + reg = <0x33c 0x4>; + reg-names = "otghs_control"; + }; + }; + }; + + target-module@4000 { /* 0x4a004000, ap 5 02.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x4000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + cm1: cm1@0 { + compatible = "ti,omap4-cm1", "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + cm1_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm1_clockdomains: clockdomains { + }; + }; + }; + + target-module@8000 { /* 0x4a008000, ap 23 32.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x8000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x2000>; + + cm2: cm2@0 { + compatible = "ti,omap4-cm2", "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + cm2_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm2_clockdomains: clockdomains { + }; + }; + }; + + target-module@56000 { /* 0x4a056000, ap 7 0a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x56000 0x4>, + <0x5602c 0x4>, + <0x56028 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l3_dma_clkdm */ + clocks = <&l3_dma_clkctrl OMAP4_DMA_SYSTEM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x56000 0x1000>; + + sdma: dma-controller@0 { + compatible = "ti,omap4430-sdma", "ti,omap-sdma"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + dma-channels = <32>; + dma-requests = <127>; + }; + }; + + target-module@58000 { /* 0x4a058000, ap 10 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x58000 0x4>, + <0x58010 0x4>, + <0x58014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_HSI_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x58000 0x5000>; + + hsi: hsi@0 { + compatible = "ti,omap4-hsi"; + reg = <0x0 0x4000>, + <0x5000 0x1000>; + reg-names = "sys", "gdd"; + + clocks = <&l3_init_clkctrl OMAP4_HSI_CLKCTRL 0>; + clock-names = "hsi_fck"; + + interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "gdd_mpu"; + + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x4000>; + + hsi_port1: hsi-port@2000 { + compatible = "ti,omap4-hsi-port"; + reg = <0x2000 0x800>, + <0x2800 0x800>; + reg-names = "tx", "rx"; + interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; + }; + + hsi_port2: hsi-port@3000 { + compatible = "ti,omap4-hsi-port"; + reg = <0x3000 0x800>, + <0x3800 0x800>; + reg-names = "tx", "rx"; + interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + }; + + target-module@5e000 { /* 0x4a05e000, ap 80 68.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5e000 0x2000>; + }; + + target-module@62000 { /* 0x4a062000, ap 11 16.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "usb_tll_hs"; + reg = <0x62000 0x4>, + <0x62010 0x4>, + <0x62014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_TLL_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x62000 0x1000>; + + usbhstll: usbhstll@0 { + compatible = "ti,usbhs-tll"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@64000 { /* 0x4a064000, ap 86 1e.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "usb_host_hs"; + reg = <0x64000 0x4>, + <0x64010 0x4>, + <0x64014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_HOST_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x64000 0x1000>; + + usbhshost: usbhshost@0 { + compatible = "ti,usbhs-host"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + clocks = <&init_60m_fclk>, + <&xclk60mhsp1_ck>, + <&xclk60mhsp2_ck>; + clock-names = "refclk_60m_int", + "refclk_60m_ext_p1", + "refclk_60m_ext_p2"; + + usbhsohci: ohci@800 { + compatible = "ti,ohci-omap3"; + reg = <0x800 0x400>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + remote-wakeup-connected; + }; + + usbhsehci: ehci@c00 { + compatible = "ti,ehci-omap"; + reg = <0xc00 0x400>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + }; + + target-module@66000 { /* 0x4a066000, ap 25 26.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x66000 0x4>, + <0x66010 0x4>, + <0x66014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, tesla_pwrdm, tesla_clkdm */ + clocks = <&tesla_clkctrl OMAP4_DSP_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_tesla 1>; + reset-names = "rstctrl"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x66000 0x1000>; + + mmu_dsp: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + }; + }; + }; + + segment@80000 { /* 0x4a080000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00059000 0x000d9000 0x001000>, /* ap 13 */ + <0x0005a000 0x000da000 0x001000>, /* ap 14 */ + <0x0005b000 0x000db000 0x001000>, /* ap 15 */ + <0x0005c000 0x000dc000 0x001000>, /* ap 16 */ + <0x0005d000 0x000dd000 0x001000>, /* ap 17 */ + <0x0005e000 0x000de000 0x001000>, /* ap 18 */ + <0x00060000 0x000e0000 0x001000>, /* ap 19 */ + <0x00061000 0x000e1000 0x001000>, /* ap 20 */ + <0x00074000 0x000f4000 0x001000>, /* ap 27 */ + <0x00075000 0x000f5000 0x001000>, /* ap 28 */ + <0x00076000 0x000f6000 0x001000>, /* ap 29 */ + <0x00077000 0x000f7000 0x001000>, /* ap 30 */ + <0x00036000 0x000b6000 0x001000>, /* ap 69 */ + <0x00037000 0x000b7000 0x001000>, /* ap 70 */ + <0x0004d000 0x000cd000 0x001000>, /* ap 78 */ + <0x0004e000 0x000ce000 0x001000>, /* ap 79 */ + <0x00029000 0x000a9000 0x001000>, /* ap 82 */ + <0x0002a000 0x000aa000 0x001000>, /* ap 83 */ + <0x0002b000 0x000ab000 0x001000>, /* ap 84 */ + <0x0002c000 0x000ac000 0x001000>, /* ap 85 */ + <0x0002d000 0x000ad000 0x001000>, /* ap 88 */ + <0x0002e000 0x000ae000 0x001000>; /* ap 89 */ + + target-module@29000 { /* 0x4a0a9000, ap 82 04.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x29000 0x1000>; + }; + + target-module@2b000 { /* 0x4a0ab000, ap 84 12.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2b400 0x4>, + <0x2b404 0x4>, + <0x2b408 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_USB_OTG_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2b000 0x1000>; + + usb_otg_hs: usb_otg_hs@0 { + compatible = "ti,omap4-musb"; + reg = <0x0 0x7ff>; + interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>, <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "mc", "dma"; + usb-phy = <&usb2_phy>; + phys = <&usb2_phy>; + phy-names = "usb2-phy"; + multipoint = <1>; + num-eps = <16>; + ram-bits = <12>; + ctrl-module = <&omap_control_usbotg>; + }; + }; + + target-module@2d000 { /* 0x4a0ad000, ap 88 0c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2d000 0x4>, + <0x2d010 0x4>, + <0x2d014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_OCP2SCP_USB_PHY_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2d000 0x1000>; + + ocp2scp@0 { + compatible = "ti,omap-ocp2scp"; + reg = <0x0 0x1f>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + usb2_phy: usb2phy@80 { + compatible = "ti,omap-usb2"; + reg = <0x80 0x58>; + ctrl-module = <&omap_control_usb2phy>; + clocks = <&usb_phy_cm_clk32k>; + clock-names = "wkupclk"; + #phy-cells = <0>; + }; + }; + }; + + /* d2d mdm */ + target-module@36000 { /* 0x4a0b6000, ap 69 60.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x36000 0x4>, + <0x36010 0x4>, + <0x36014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, d2d_clkdm */ + clocks = <&d2d_clkctrl OMAP4_C2C_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + }; + + /* d2d mpu */ + target-module@4d000 { /* 0x4a0cd000, ap 78 58.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4d000 0x4>, + <0x4d010 0x4>, + <0x4d014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, d2d_clkdm */ + clocks = <&d2d_clkctrl OMAP4_C2C_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4d000 0x1000>; + }; + + target-module@59000 { /* 0x4a0d9000, ap 13 1a.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x59038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_MPU_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + + smartreflex_mpu: smartreflex@0 { + compatible = "ti,omap4-smartreflex-mpu"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@5b000 { /* 0x4a0db000, ap 15 08.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x5b038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_IVA_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + + smartreflex_iva: smartreflex@0 { + compatible = "ti,omap4-smartreflex-iva"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@5d000 { /* 0x4a0dd000, ap 17 22.0 */ + compatible = "ti,sysc-omap4-sr", "ti,sysc"; + reg = <0x5d038 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <SYSC_OMAP3_SR_ENAWAKEUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, always_on_core_pwrdm, l4_ao_clkdm */ + clocks = <&l4_ao_clkctrl OMAP4_SMARTREFLEX_CORE_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + + smartreflex_core: smartreflex@0 { + compatible = "ti,omap4-smartreflex-core"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@60000 { /* 0x4a0e0000, ap 19 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + }; + + target-module@74000 { /* 0x4a0f4000, ap 27 24.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x74000 0x4>, + <0x74010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + clocks = <&l4_cfg_clkctrl OMAP4_MAILBOX_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x74000 0x1000>; + + mailbox: mailbox@0 { + compatible = "ti,omap4-mailbox"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + ti,mbox-num-users = <3>; + ti,mbox-num-fifos = <8>; + mbox_ipu: mbox_ipu { + ti,mbox-tx = <0 0 0>; + ti,mbox-rx = <1 0 0>; + }; + mbox_dsp: mbox_dsp { + ti,mbox-tx = <3 0 0>; + ti,mbox-rx = <2 0 0>; + }; + }; + }; + + target-module@76000 { /* 0x4a0f6000, ap 29 3a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x76000 0x4>, + <0x76010 0x4>, + <0x76014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + clocks = <&l4_cfg_clkctrl OMAP4_SPINLOCK_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x76000 0x1000>; + + hwspinlock: spinlock@0 { + compatible = "ti,omap4-hwspinlock"; + reg = <0x0 0x1000>; + #hwlock-cells = <1>; + }; + }; + }; + + segment@100000 { /* 0x4a100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00100000 0x001000>, /* ap 21 */ + <0x00001000 0x00101000 0x001000>, /* ap 22 */ + <0x00002000 0x00102000 0x001000>, /* ap 61 */ + <0x00003000 0x00103000 0x001000>, /* ap 62 */ + <0x00008000 0x00108000 0x001000>, /* ap 63 */ + <0x00009000 0x00109000 0x001000>, /* ap 64 */ + <0x0000a000 0x0010a000 0x001000>, /* ap 65 */ + <0x0000b000 0x0010b000 0x001000>; /* ap 66 */ + + target-module@0 { /* 0x4a100000, ap 21 2a.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_pad_core"; + reg = <0x0 0x4>, + <0x10 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4_cfg_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + + omap4_pmx_core: pinmux@40 { + compatible = "ti,omap4-padconf", + "pinctrl-single"; + reg = <0x40 0x0196>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + + omap4_padconf_global: omap4_padconf_global@5a0 { + compatible = "syscon", + "simple-bus"; + reg = <0x5a0 0x170>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5a0 0x170>; + + pbias_regulator: pbias_regulator@60 { + compatible = "ti,pbias-omap4", "ti,pbias-omap"; + reg = <0x60 0x4>; + syscon = <&omap4_padconf_global>; + pbias_mmc_reg: pbias_mmc_omap4 { + regulator-name = "pbias_mmc_omap4"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + }; + }; + }; + }; + + target-module@2000 { /* 0x4a102000, ap 61 3c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@8000 { /* 0x4a108000, ap 63 62.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + }; + + target-module@a000 { /* 0x4a10a000, ap 65 50.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xa000 0x4>, + <0xa010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-delay-us = <2>; + /* Domains (V, P, C): core, cam_pwrdm, iss_clkdm */ + clocks = <&iss_clkctrl OMAP4_FDIF_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + + /* No child device binding or driver in mainline */ + }; + }; + + segment@180000 { /* 0x4a180000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + segment@200000 { /* 0x4a200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0001e000 0x0021e000 0x001000>, /* ap 31 */ + <0x0001f000 0x0021f000 0x001000>, /* ap 32 */ + <0x0000a000 0x0020a000 0x001000>, /* ap 33 */ + <0x0000b000 0x0020b000 0x001000>, /* ap 34 */ + <0x00004000 0x00204000 0x001000>, /* ap 35 */ + <0x00005000 0x00205000 0x001000>, /* ap 36 */ + <0x00006000 0x00206000 0x001000>, /* ap 37 */ + <0x00007000 0x00207000 0x001000>, /* ap 38 */ + <0x00012000 0x00212000 0x001000>, /* ap 39 */ + <0x00013000 0x00213000 0x001000>, /* ap 40 */ + <0x0000c000 0x0020c000 0x001000>, /* ap 41 */ + <0x0000d000 0x0020d000 0x001000>, /* ap 42 */ + <0x00010000 0x00210000 0x001000>, /* ap 43 */ + <0x00011000 0x00211000 0x001000>, /* ap 44 */ + <0x00016000 0x00216000 0x001000>, /* ap 45 */ + <0x00017000 0x00217000 0x001000>, /* ap 46 */ + <0x00014000 0x00214000 0x001000>, /* ap 47 */ + <0x00015000 0x00215000 0x001000>, /* ap 48 */ + <0x00018000 0x00218000 0x001000>, /* ap 49 */ + <0x00019000 0x00219000 0x001000>, /* ap 50 */ + <0x00020000 0x00220000 0x001000>, /* ap 51 */ + <0x00021000 0x00221000 0x001000>, /* ap 52 */ + <0x00026000 0x00226000 0x001000>, /* ap 53 */ + <0x00027000 0x00227000 0x001000>, /* ap 54 */ + <0x00028000 0x00228000 0x001000>, /* ap 55 */ + <0x00029000 0x00229000 0x001000>, /* ap 56 */ + <0x0002a000 0x0022a000 0x001000>, /* ap 57 */ + <0x0002b000 0x0022b000 0x001000>, /* ap 58 */ + <0x0001c000 0x0021c000 0x001000>, /* ap 59 */ + <0x0001d000 0x0021d000 0x001000>; /* ap 60 */ + + target-module@4000 { /* 0x4a204000, ap 35 42.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + }; + + target-module@6000 { /* 0x4a206000, ap 37 4a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x1000>; + }; + + target-module@a000 { /* 0x4a20a000, ap 33 2c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + }; + + target-module@c000 { /* 0x4a20c000, ap 41 20.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + }; + + target-module@10000 { /* 0x4a210000, ap 43 52.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x10000 0x1000>; + }; + + target-module@12000 { /* 0x4a212000, ap 39 18.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x12000 0x1000>; + }; + + target-module@14000 { /* 0x4a214000, ap 47 30.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x14000 0x1000>; + }; + + target-module@16000 { /* 0x4a216000, ap 45 28.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x16000 0x1000>; + }; + + target-module@18000 { /* 0x4a218000, ap 49 38.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x18000 0x1000>; + }; + + target-module@1c000 { /* 0x4a21c000, ap 59 5a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1c000 0x1000>; + }; + + target-module@1e000 { /* 0x4a21e000, ap 31 10.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1e000 0x1000>; + }; + + target-module@20000 { /* 0x4a220000, ap 51 40.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + }; + + target-module@26000 { /* 0x4a226000, ap 53 34.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>; + }; + + target-module@28000 { /* 0x4a228000, ap 55 2e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>; + }; + + target-module@2a000 { /* 0x4a22a000, ap 57 48.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>; + }; + }; + + segment@280000 { /* 0x4a280000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + l4_cfg_segment_300000: segment@300000 { /* 0x4a300000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00300000 0x020000>, /* ap 67 */ + <0x00040000 0x00340000 0x001000>, /* ap 68 */ + <0x00020000 0x00320000 0x004000>, /* ap 71 */ + <0x00024000 0x00324000 0x002000>, /* ap 72 */ + <0x00026000 0x00326000 0x001000>, /* ap 73 */ + <0x00027000 0x00327000 0x001000>, /* ap 74 */ + <0x00028000 0x00328000 0x001000>, /* ap 75 */ + <0x00029000 0x00329000 0x001000>, /* ap 76 */ + <0x00030000 0x00330000 0x010000>, /* ap 77 */ + <0x0002a000 0x0032a000 0x002000>, /* ap 90 */ + <0x0002c000 0x0032c000 0x004000>; /* ap 91 */ + + l4_cfg_target_0: target-module@0 { /* 0x4a300000, ap 67 14.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x00020000>, + <0x00020000 0x00020000 0x00004000>, + <0x00024000 0x00024000 0x00002000>, + <0x00026000 0x00026000 0x00001000>, + <0x00027000 0x00027000 0x00001000>, + <0x00028000 0x00028000 0x00001000>, + <0x00029000 0x00029000 0x00001000>, + <0x0002a000 0x0002a000 0x00002000>, + <0x0002c000 0x0002c000 0x00004000>, + <0x00030000 0x00030000 0x00010000>; + }; + }; +}; + +&l4_wkup { /* 0x4a300000 */ + compatible = "ti,omap4-l4-wkup", "simple-bus"; + reg = <0x4a300000 0x800>, + <0x4a300800 0x800>, + <0x4a301000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4a300000 0x010000>, /* segment 0 */ + <0x00010000 0x4a310000 0x010000>, /* segment 1 */ + <0x00020000 0x4a320000 0x010000>; /* segment 2 */ + + segment@0 { /* 0x4a300000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00006000 0x00006000 0x002000>, /* ap 3 */ + <0x00008000 0x00008000 0x001000>, /* ap 4 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 15 */ + <0x0000b000 0x0000b000 0x001000>, /* ap 16 */ + <0x00004000 0x00004000 0x001000>, /* ap 17 */ + <0x00005000 0x00005000 0x001000>, /* ap 18 */ + <0x0000c000 0x0000c000 0x001000>, /* ap 19 */ + <0x0000d000 0x0000d000 0x001000>; /* ap 20 */ + + target-module@4000 { /* 0x4a304000, ap 17 24.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "counter_32k"; + reg = <0x4000 0x4>, + <0x4004 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_COUNTER_32K_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + counter32k: counter@0 { + compatible = "ti,omap-counter32k"; + reg = <0x0 0x20>; + }; + }; + + target-module@6000 { /* 0x4a306000, ap 3 08.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x6000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x2000>; + + prm: prm@0 { + compatible = "ti,omap4-prm", "simple-bus"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + prm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + prm_clockdomains: clockdomains { + }; + }; + }; + + target-module@a000 { /* 0x4a30a000, ap 15 34.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xa000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + + scrm: scrm@0 { + compatible = "ti,omap4-scrm"; + reg = <0x0 0x2000>; + + scrm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + scrm_clockdomains: clockdomains { + }; + }; + }; + + target-module@c000 { /* 0x4a30c000, ap 19 2c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_wkup"; + reg = <0xc000 0x4>, + <0xc010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + omap4_scm_wkup: scm@c000 { + compatible = "ti,omap4-scm-wkup"; + reg = <0xc000 0x1000>; + }; + }; + }; + + segment@10000 { /* 0x4a310000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00010000 0x001000>, /* ap 5 */ + <0x00001000 0x00011000 0x001000>, /* ap 6 */ + <0x00004000 0x00014000 0x001000>, /* ap 7 */ + <0x00005000 0x00015000 0x001000>, /* ap 8 */ + <0x00008000 0x00018000 0x001000>, /* ap 9 */ + <0x00009000 0x00019000 0x001000>, /* ap 10 */ + <0x0000c000 0x0001c000 0x001000>, /* ap 11 */ + <0x0000d000 0x0001d000 0x001000>, /* ap 12 */ + <0x0000e000 0x0001e000 0x001000>, /* ap 21 */ + <0x0000f000 0x0001f000 0x001000>; /* ap 22 */ + + gpio1_target: target-module@0 { /* 0x4a310000, ap 5 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x0 0x4>, + <0x10 0x4>, + <0x114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_GPIO1_CLKCTRL 0>, + <&l4_wkup_clkctrl OMAP4_GPIO1_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + + gpio1: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + ti,gpio-always-on; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@4000 { /* 0x4a314000, ap 7 18.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4000 0x4>, + <0x4010 0x4>, + <0x4014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_WD_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + wdt2: wdt@0 { + compatible = "ti,omap4-wdt", "ti,omap3-wdt"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@8000 { /* 0x4a318000, ap 9 1c.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + ti,hwmods = "timer1"; + reg = <0x8000 0x4>, + <0x8010 0x4>, + <0x8014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_TIMER1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + + timer1: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_wkup_clkctrl OMAP4_TIMER1_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-alwon; + }; + }; + + target-module@c000 { /* 0x4a31c000, ap 11 20.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xc000 0x4>, + <0xc010 0x4>, + <0xc014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + clocks = <&l4_wkup_clkctrl OMAP4_KBD_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + keypad: keypad@0 { + compatible = "ti,omap4-keypad"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; + reg-names = "mpu"; + }; + }; + + target-module@e000 { /* 0x4a31e000, ap 21 30.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "ctrl_module_pad_wkup"; + reg = <0xe000 0x4>, + <0xe010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): wakeup, wkup_pwrdm, l4_wkup_clkdm */ + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xe000 0x1000>; + + omap4_pmx_wkup: pinmux@40 { + compatible = "ti,omap4-padconf", + "pinctrl-single"; + reg = <0x40 0x0038>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + }; + }; + + segment@20000 { /* 0x4a320000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00006000 0x00026000 0x001000>, /* ap 13 */ + <0x0000a000 0x0002a000 0x001000>, /* ap 14 */ + <0x00000000 0x00020000 0x001000>, /* ap 23 */ + <0x00001000 0x00021000 0x001000>, /* ap 24 */ + <0x00002000 0x00022000 0x001000>, /* ap 25 */ + <0x00003000 0x00023000 0x001000>, /* ap 26 */ + <0x00004000 0x00024000 0x001000>, /* ap 27 */ + <0x00005000 0x00025000 0x001000>, /* ap 28 */ + <0x00007000 0x00027000 0x000400>, /* ap 29 */ + <0x00008000 0x00028000 0x000800>, /* ap 30 */ + <0x00009000 0x00029000 0x000400>; /* ap 31 */ + + target-module@0 { /* 0x4a320000, ap 23 04.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + }; + + target-module@2000 { /* 0x4a322000, ap 25 0c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@4000 { /* 0x4a324000, ap 27 10.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + }; + + target-module@6000 { /* 0x4a326000, ap 13 28.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00006000 0x00001000>, + <0x00001000 0x00007000 0x00000400>, + <0x00002000 0x00008000 0x00000800>, + <0x00003000 0x00009000 0x00000400>; + }; + }; +}; + +&l4_per { /* 0x48000000 */ + compatible = "ti,omap4-l4-per", "simple-bus"; + reg = <0x48000000 0x800>, + <0x48000800 0x800>, + <0x48001000 0x400>, + <0x48001400 0x400>, + <0x48001800 0x400>, + <0x48001c00 0x400>; + reg-names = "ap", "la", "ia0", "ia1", "ia2", "ia3"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x48000000 0x200000>, /* segment 0 */ + <0x00200000 0x48200000 0x200000>; /* segment 1 */ + + segment@0 { /* 0x48000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x000400>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00020000 0x00020000 0x001000>, /* ap 3 */ + <0x00021000 0x00021000 0x001000>, /* ap 4 */ + <0x00032000 0x00032000 0x001000>, /* ap 5 */ + <0x00033000 0x00033000 0x001000>, /* ap 6 */ + <0x00034000 0x00034000 0x001000>, /* ap 7 */ + <0x00035000 0x00035000 0x001000>, /* ap 8 */ + <0x00036000 0x00036000 0x001000>, /* ap 9 */ + <0x00037000 0x00037000 0x001000>, /* ap 10 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 11 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 12 */ + <0x00040000 0x00040000 0x010000>, /* ap 13 */ + <0x00050000 0x00050000 0x001000>, /* ap 14 */ + <0x00055000 0x00055000 0x001000>, /* ap 15 */ + <0x00056000 0x00056000 0x001000>, /* ap 16 */ + <0x00057000 0x00057000 0x001000>, /* ap 17 */ + <0x00058000 0x00058000 0x001000>, /* ap 18 */ + <0x00059000 0x00059000 0x001000>, /* ap 19 */ + <0x0005a000 0x0005a000 0x001000>, /* ap 20 */ + <0x0005b000 0x0005b000 0x001000>, /* ap 21 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 22 */ + <0x0005d000 0x0005d000 0x001000>, /* ap 23 */ + <0x0005e000 0x0005e000 0x001000>, /* ap 24 */ + <0x00060000 0x00060000 0x001000>, /* ap 25 */ + <0x0006a000 0x0006a000 0x001000>, /* ap 26 */ + <0x0006b000 0x0006b000 0x001000>, /* ap 27 */ + <0x0006c000 0x0006c000 0x001000>, /* ap 28 */ + <0x0006d000 0x0006d000 0x001000>, /* ap 29 */ + <0x0006e000 0x0006e000 0x001000>, /* ap 30 */ + <0x0006f000 0x0006f000 0x001000>, /* ap 31 */ + <0x00070000 0x00070000 0x001000>, /* ap 32 */ + <0x00071000 0x00071000 0x001000>, /* ap 33 */ + <0x00072000 0x00072000 0x001000>, /* ap 34 */ + <0x00073000 0x00073000 0x001000>, /* ap 35 */ + <0x00061000 0x00061000 0x001000>, /* ap 36 */ + <0x00096000 0x00096000 0x001000>, /* ap 37 */ + <0x00097000 0x00097000 0x001000>, /* ap 38 */ + <0x00076000 0x00076000 0x001000>, /* ap 39 */ + <0x00077000 0x00077000 0x001000>, /* ap 40 */ + <0x00078000 0x00078000 0x001000>, /* ap 41 */ + <0x00079000 0x00079000 0x001000>, /* ap 42 */ + <0x00086000 0x00086000 0x001000>, /* ap 43 */ + <0x00087000 0x00087000 0x001000>, /* ap 44 */ + <0x00088000 0x00088000 0x001000>, /* ap 45 */ + <0x00089000 0x00089000 0x001000>, /* ap 46 */ + <0x000b0000 0x000b0000 0x001000>, /* ap 47 */ + <0x000b1000 0x000b1000 0x001000>, /* ap 48 */ + <0x00098000 0x00098000 0x001000>, /* ap 49 */ + <0x00099000 0x00099000 0x001000>, /* ap 50 */ + <0x0009a000 0x0009a000 0x001000>, /* ap 51 */ + <0x0009b000 0x0009b000 0x001000>, /* ap 52 */ + <0x0009c000 0x0009c000 0x001000>, /* ap 53 */ + <0x0009d000 0x0009d000 0x001000>, /* ap 54 */ + <0x0009e000 0x0009e000 0x001000>, /* ap 55 */ + <0x0009f000 0x0009f000 0x001000>, /* ap 56 */ + <0x00090000 0x00090000 0x002000>, /* ap 57 */ + <0x00092000 0x00092000 0x001000>, /* ap 58 */ + <0x000a4000 0x000a4000 0x001000>, /* ap 59 */ + <0x000a6000 0x000a6000 0x001000>, /* ap 60 */ + <0x000a8000 0x000a8000 0x004000>, /* ap 61 */ + <0x000ac000 0x000ac000 0x001000>, /* ap 62 */ + <0x000ad000 0x000ad000 0x001000>, /* ap 63 */ + <0x000ae000 0x000ae000 0x001000>, /* ap 64 */ + <0x000b2000 0x000b2000 0x001000>, /* ap 65 */ + <0x000b3000 0x000b3000 0x001000>, /* ap 66 */ + <0x000b4000 0x000b4000 0x001000>, /* ap 67 */ + <0x000b5000 0x000b5000 0x001000>, /* ap 68 */ + <0x000b8000 0x000b8000 0x001000>, /* ap 69 */ + <0x000b9000 0x000b9000 0x001000>, /* ap 70 */ + <0x000ba000 0x000ba000 0x001000>, /* ap 71 */ + <0x000bb000 0x000bb000 0x001000>, /* ap 72 */ + <0x000d1000 0x000d1000 0x001000>, /* ap 73 */ + <0x000d2000 0x000d2000 0x001000>, /* ap 74 */ + <0x000d5000 0x000d5000 0x001000>, /* ap 75 */ + <0x000d6000 0x000d6000 0x001000>, /* ap 76 */ + <0x000a2000 0x000a2000 0x001000>, /* ap 79 */ + <0x000a3000 0x000a3000 0x001000>, /* ap 80 */ + <0x00001400 0x00001400 0x000400>, /* ap 81 */ + <0x00001800 0x00001800 0x000400>, /* ap 82 */ + <0x00001c00 0x00001c00 0x000400>, /* ap 83 */ + <0x000a5000 0x000a5000 0x001000>; /* ap 84 */ + + target-module@20000 { /* 0x48020000, ap 3 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x20050 0x4>, + <0x20054 0x4>, + <0x20058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + + uart3: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@32000 { /* 0x48032000, ap 5 02.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>, + <0x32014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>; + + timer2: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER2_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@34000 { /* 0x48034000, ap 7 04.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x34000 0x4>, + <0x34010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x34000 0x1000>; + + timer3: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER3_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@36000 { /* 0x48036000, ap 9 0e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x36000 0x4>, + <0x36010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + + timer4: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER4_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@3e000 { /* 0x4803e000, ap 11 08.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER9_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>; + + timer9: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER9_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + /* Unused DSS L4 access, see L3 instead */ + target-module@40000 { /* 0x48040000, ap 13 0a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x40000 0x10000>; + }; + + target-module@55000 { /* 0x48055000, ap 15 0c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55000 0x4>, + <0x55010 0x4>, + <0x55114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO2_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO2_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x55000 0x1000>; + + gpio2: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@57000 { /* 0x48057000, ap 17 16.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x57000 0x4>, + <0x57010 0x4>, + <0x57114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO3_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO3_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x57000 0x1000>; + + gpio3: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@59000 { /* 0x48059000, ap 19 10.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x59000 0x4>, + <0x59010 0x4>, + <0x59114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO4_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO4_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + + gpio4: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5b000 { /* 0x4805b000, ap 21 12.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5b000 0x4>, + <0x5b010 0x4>, + <0x5b114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO5_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO5_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + + gpio5: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5d000 { /* 0x4805d000, ap 23 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5d000 0x4>, + <0x5d010 0x4>, + <0x5d114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_GPIO6_CLKCTRL 0>, + <&l4_per_clkctrl OMAP4_GPIO6_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + + gpio6: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@60000 { /* 0x48060000, ap 25 1e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x60000 0x8>, + <0x60010 0x8>, + <0x60090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + + i2c3: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@6a000 { /* 0x4806a000, ap 26 18.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6a050 0x4>, + <0x6a054 0x4>, + <0x6a058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6a000 0x1000>; + + uart1: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6c000 { /* 0x4806c000, ap 28 20.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6c050 0x4>, + <0x6c054 0x4>, + <0x6c058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6c000 0x1000>; + + uart2: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6e000 { /* 0x4806e000, ap 30 1c.1 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6e050 0x4>, + <0x6e054 0x4>, + <0x6e058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_UART4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6e000 0x1000>; + + uart4: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@70000 { /* 0x48070000, ap 32 28.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x70000 0x8>, + <0x70010 0x8>, + <0x70090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x70000 0x1000>; + + i2c1: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@72000 { /* 0x48072000, ap 34 30.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x72000 0x8>, + <0x72010 0x8>, + <0x72090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x72000 0x1000>; + + i2c2: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@76000 { /* 0x48076000, ap 39 38.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x76000 0x4>, + <0x76010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_SLIMBUS2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x76000 0x1000>; + + /* No child device binding or driver in mainline */ + }; + + target-module@78000 { /* 0x48078000, ap 41 1a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x78000 0x4>, + <0x78010 0x4>, + <0x78014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_ELM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x78000 0x1000>; + + elm: elm@0 { + compatible = "ti,am3352-elm"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 4 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + }; + }; + + target-module@86000 { /* 0x48086000, ap 43 24.0 */ + compatible = "ti,sysc-omap2-timer", "ti,sysc"; + reg = <0x86000 0x4>, + <0x86010 0x4>, + <0x86014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER10_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x86000 0x1000>; + + timer10: timer@0 { + compatible = "ti,omap3430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER10_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + target-module@88000 { /* 0x48088000, ap 45 2e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x88000 0x4>, + <0x88010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_TIMER11_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x88000 0x1000>; + + timer11: timer@0 { + compatible = "ti,omap4430-timer"; + reg = <0x0 0x80>; + clocks = <&l4_per_clkctrl OMAP4_TIMER11_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + rng_target: target-module@90000 { /* 0x48090000, ap 57 2a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x91fe0 0x4>, + <0x91fe4 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_RNG_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x90000 0x2000>; + + rng: rng@0 { + compatible = "ti,omap4-rng"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@96000 { /* 0x48096000, ap 37 26.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x9608c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCBSP4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x96000 0x1000>; + + mcbsp4: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>; /* L4 Interconnect */ + reg-names = "mpu"; + interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 31>, + <&sdma 32>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@98000 { /* 0x48098000, ap 49 22.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x98000 0x4>, + <0x98010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x98000 0x1000>; + + mcspi1: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <4>; + dmas = <&sdma 35>, + <&sdma 36>, + <&sdma 37>, + <&sdma 38>, + <&sdma 39>, + <&sdma 40>, + <&sdma 41>, + <&sdma 42>; + dma-names = "tx0", "rx0", "tx1", "rx1", + "tx2", "rx2", "tx3", "rx3"; + }; + }; + + target-module@9a000 { /* 0x4809a000, ap 51 2c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9a000 0x4>, + <0x9a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9a000 0x1000>; + + mcspi2: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 43>, + <&sdma 44>, + <&sdma 45>, + <&sdma 46>; + dma-names = "tx0", "rx0", "tx1", "rx1"; + }; + }; + + target-module@9c000 { /* 0x4809c000, ap 53 36.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9c000 0x4>, + <0x9c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_MMC1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9c000 0x1000>; + + mmc1: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + ti,dual-volt; + ti,needs-special-reset; + dmas = <&sdma 61>, <&sdma 62>; + dma-names = "tx", "rx"; + pbias-supply = <&pbias_mmc_reg>; + }; + }; + + target-module@9e000 { /* 0x4809e000, ap 55 48.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9e000 0x1000>; + }; + + target-module@a2000 { /* 0x480a2000, ap 79 3a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa2000 0x1000>; + }; + + target-module@a4000 { /* 0x480a4000, ap 59 34.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x000a4000 0x00001000>, + <0x00001000 0x000a5000 0x00001000>; + }; + + des_target: target-module@a5000 { /* 0x480a5000 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xa5030 0x4>, + <0xa5034 0x4>, + <0xa5038 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_DES3DES_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xa5000 0x00001000>; + + des: des@0 { + compatible = "ti,omap4-des"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 117>, <&sdma 116>; + dma-names = "tx", "rx"; + }; + }; + + target-module@a8000 { /* 0x480a8000, ap 61 3e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa8000 0x4000>; + }; + + target-module@ad000 { /* 0x480ad000, ap 63 50.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xad000 0x4>, + <0xad010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xad000 0x1000>; + + mmc3: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 77>, <&sdma 78>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b0000 { /* 0x480b0000, ap 47 40.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb0000 0x1000>; + }; + + target-module@b2000 { /* 0x480b2000, ap 65 3c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xb2000 0x4>, + <0xb2014 0x4>, + <0xb2018 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + ti,no-reset-on-init; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_HDQ1W_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb2000 0x1000>; + + hdqw1w: 1w@0 { + compatible = "ti,omap3-1w"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@b4000 { /* 0x480b4000, ap 67 46.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb4000 0x4>, + <0xb4010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3_init_clkdm */ + clocks = <&l3_init_clkctrl OMAP4_MMC2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb4000 0x1000>; + + mmc2: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 47>, <&sdma 48>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b8000 { /* 0x480b8000, ap 69 58.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb8000 0x4>, + <0xb8010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb8000 0x1000>; + + mcspi3: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 15>, <&sdma 16>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@ba000 { /* 0x480ba000, ap 71 32.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xba000 0x4>, + <0xba010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MCSPI4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xba000 0x1000>; + + mcspi4: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <1>; + dmas = <&sdma 70>, <&sdma 71>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@d1000 { /* 0x480d1000, ap 73 44.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd1000 0x4>, + <0xd1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd1000 0x1000>; + + mmc4: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 57>, <&sdma 58>; + dma-names = "tx", "rx"; + }; + }; + + target-module@d5000 { /* 0x480d5000, ap 75 4e.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd5000 0x4>, + <0xd5010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_MMC5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd5000 0x1000>; + + mmc5: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 59>, <&sdma 60>; + dma-names = "tx", "rx"; + }; + }; + }; + + segment@200000 { /* 0x48200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00150000 0x00350000 0x001000>, /* ap 77 */ + <0x00151000 0x00351000 0x001000>; /* ap 78 */ + + target-module@150000 { /* 0x48350000, ap 77 4c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x150000 0x8>, + <0x150010 0x8>, + <0x150090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l4per_pwrdm, l4_per_clkdm */ + clocks = <&l4_per_clkctrl OMAP4_I2C4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x150000 0x1000>; + + i2c4: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; +}; + diff --git a/arch/arm/dts/omap4-mcpdm.dtsi b/arch/arm/dts/omap4-mcpdm.dtsi new file mode 100644 index 0000000000..915a9b31a3 --- /dev/null +++ b/arch/arm/dts/omap4-mcpdm.dtsi @@ -0,0 +1,44 @@ +// SPDX-License-Identifier: GPL-2.0 +/* + * Common omap4 mcpdm configuration + * + * Only include this file if your board has pdmclk wired from the + * pmic to ABE as mcpdm uses an external clock for the module. + */ + +&omap4_pmx_core { + mcpdm_pins: pinmux_mcpdm_pins { + pinctrl-single,pins = < + /* 0x4a100106 abe_pdm_ul_data.abe_pdm_ul_data ag25 */ + OMAP4_IOPAD(0x106, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a100108 abe_pdm_dl_data.abe_pdm_dl_data af25 */ + OMAP4_IOPAD(0x108, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a10010a abe_pdm_frame.abe_pdm_frame ae25 */ + OMAP4_IOPAD(0x10a, PIN_INPUT_PULLUP | MUX_MODE0) + + /* 0x4a10010c abe_pdm_lb_clk.abe_pdm_lb_clk af26 */ + OMAP4_IOPAD(0x10c, PIN_INPUT_PULLDOWN | MUX_MODE0) + + /* 0x4a10010e abe_clks.abe_clks ah26 */ + OMAP4_IOPAD(0x10e, PIN_INPUT_PULLDOWN | MUX_MODE0) + >; + }; +}; + +&mcpdm_module { + /* + * McPDM pads must be muxed at the interconnect target module + * level as the module on the SoC needs external clock from + * the PMIC + */ + pinctrl-names = "default"; + pinctrl-0 = <&mcpdm_pins>; + status = "okay"; +}; + +&mcpdm { + clocks = <&twl6040>; + clock-names = "pdmclk"; +}; diff --git a/arch/arm/dts/omap4-panda-common.dtsi b/arch/arm/dts/omap4-panda-common.dtsi new file mode 100644 index 0000000000..55ea8b6189 --- /dev/null +++ b/arch/arm/dts/omap4-panda-common.dtsi @@ -0,0 +1,573 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011-2013 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include <dt-bindings/input/input.h> +#include "elpida_ecb240abacn.dtsi" +#include "omap4-mcpdm.dtsi" + +/ { + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x40000000>; /* 1 GB */ + }; + + chosen { + stdout-path = &uart3; + }; + + aliases { + display0 = &dvi0; + display1 = &hdmi0; + ethernet = ðernet; + }; + + leds: leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = < + &led_wkgpio_pins + >; + + heartbeat { + label = "pandaboard::status1"; + gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + }; + + mmc { + label = "pandaboard::status2"; + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + }; + }; + + gpio_keys: gpio_keys { + compatible = "gpio-keys"; + pinctrl-names = "default"; + pinctrl-0 = < + &button_pins + >; + + buttonS2 { + label = "button S2"; + gpios = <&gpio4 25 GPIO_ACTIVE_LOW>; /* gpio_121 */ + linux,code = <BTN_0>; + wakeup-source; + }; + }; + + sound: sound { + compatible = "ti,abe-twl6040"; + ti,model = "PandaBoard"; + + ti,mclk-freq = <38400000>; + + ti,mcpdm = <&mcpdm>; + + ti,twl6040 = <&twl6040>; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Ext Spk", "HFL", + "Ext Spk", "HFR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "HSMIC", "Headset Mic", + "Headset Mic", "Headset Mic Bias", + "AFML", "Line In", + "AFMR", "Line In"; + }; + + /* HS USB Port 1 Power */ + hsusb1_power: hsusb1_power_reg { + compatible = "regulator-fixed"; + regulator-name = "hsusb1_vbus"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio1 1 GPIO_ACTIVE_HIGH>; /* gpio_1 */ + startup-delay-us = <70000>; + enable-active-high; + /* + * boot-on is required along with always-on as the + * regulator framework doesn't enable the regulator + * if boot-on is not there. + */ + regulator-always-on; + regulator-boot-on; + }; + + /* HS USB Host PHY on PORT 1 */ + hsusb1_phy: hsusb1_phy { + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio2 30 GPIO_ACTIVE_LOW>; /* gpio_62 */ + #phy-cells = <0>; + vcc-supply = <&hsusb1_power>; + clocks = <&auxclk3_ck>; + clock-names = "main_clk"; + clock-frequency = <19200000>; + }; + + /* regulator for wl12xx on sdio5 */ + wl12xx_vmmc: wl12xx_vmmc { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_gpio>; + compatible = "regulator-fixed"; + regulator-name = "vwl1271"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio2 11 GPIO_ACTIVE_HIGH>; + startup-delay-us = <70000>; + enable-active-high; + }; + + tfp410: encoder0 { + compatible = "ti,tfp410"; + powerdown-gpios = <&gpio1 0 GPIO_ACTIVE_LOW>; /* gpio_0 */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tfp410_in: endpoint { + remote-endpoint = <&dpi_out>; + }; + }; + + port@1 { + reg = <1>; + + tfp410_out: endpoint { + remote-endpoint = <&dvi_connector_in>; + }; + }; + }; + }; + + dvi0: connector0 { + compatible = "dvi-connector"; + label = "dvi"; + + digital; + + ddc-i2c-bus = <&i2c3>; + + port { + dvi_connector_in: endpoint { + remote-endpoint = <&tfp410_out>; + }; + }; + }; + + tpd12s015: encoder1 { + compatible = "ti,tpd12s015"; + + gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>, /* 60, CT CP HPD */ + <&gpio2 9 GPIO_ACTIVE_HIGH>, /* 41, LS OE */ + <&gpio2 31 GPIO_ACTIVE_HIGH>; /* 63, HPD */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tpd12s015_in: endpoint { + remote-endpoint = <&hdmi_out>; + }; + }; + + port@1 { + reg = <1>; + + tpd12s015_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; + + hdmi0: connector1 { + compatible = "hdmi-connector"; + label = "hdmi"; + + type = "a"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tpd12s015_out>; + }; + }; + }; +}; + +&omap4_pmx_core { + pinctrl-names = "default"; + pinctrl-0 = < + &dss_dpi_pins + &tfp410_pins + &dss_hdmi_pins + &tpd12s015_pins + &hsusbb1_pins + >; + + twl6040_pins: pinmux_twl6040_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x120, PIN_OUTPUT | MUX_MODE3) /* hdq_sio.gpio_127 */ + OMAP4_IOPAD(0x1a0, PIN_INPUT | MUX_MODE0) /* sys_nirq2.sys_nirq2 */ + >; + }; + + mcbsp1_pins: pinmux_mcbsp1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0fe, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_clkx.abe_mcbsp1_clkx */ + OMAP4_IOPAD(0x100, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dr.abe_mcbsp1_dr */ + OMAP4_IOPAD(0x102, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dx.abe_mcbsp1_dx */ + OMAP4_IOPAD(0x104, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_fsx.abe_mcbsp1_fsx */ + >; + }; + + dss_dpi_pins: pinmux_dss_dpi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x162, PIN_OUTPUT | MUX_MODE5) /* dispc2_data23 */ + OMAP4_IOPAD(0x164, PIN_OUTPUT | MUX_MODE5) /* dispc2_data22 */ + OMAP4_IOPAD(0x166, PIN_OUTPUT | MUX_MODE5) /* dispc2_data21 */ + OMAP4_IOPAD(0x168, PIN_OUTPUT | MUX_MODE5) /* dispc2_data20 */ + OMAP4_IOPAD(0x16a, PIN_OUTPUT | MUX_MODE5) /* dispc2_data19 */ + OMAP4_IOPAD(0x16c, PIN_OUTPUT | MUX_MODE5) /* dispc2_data18 */ + OMAP4_IOPAD(0x16e, PIN_OUTPUT | MUX_MODE5) /* dispc2_data15 */ + OMAP4_IOPAD(0x170, PIN_OUTPUT | MUX_MODE5) /* dispc2_data14 */ + OMAP4_IOPAD(0x172, PIN_OUTPUT | MUX_MODE5) /* dispc2_data13 */ + OMAP4_IOPAD(0x174, PIN_OUTPUT | MUX_MODE5) /* dispc2_data12 */ + OMAP4_IOPAD(0x176, PIN_OUTPUT | MUX_MODE5) /* dispc2_data11 */ + + OMAP4_IOPAD(0x1b4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data10 */ + OMAP4_IOPAD(0x1b6, PIN_OUTPUT | MUX_MODE5) /* dispc2_data9 */ + OMAP4_IOPAD(0x1b8, PIN_OUTPUT | MUX_MODE5) /* dispc2_data16 */ + OMAP4_IOPAD(0x1ba, PIN_OUTPUT | MUX_MODE5) /* dispc2_data17 */ + OMAP4_IOPAD(0x1bc, PIN_OUTPUT | MUX_MODE5) /* dispc2_hsync */ + OMAP4_IOPAD(0x1be, PIN_OUTPUT | MUX_MODE5) /* dispc2_pclk */ + OMAP4_IOPAD(0x1c0, PIN_OUTPUT | MUX_MODE5) /* dispc2_vsync */ + OMAP4_IOPAD(0x1c2, PIN_OUTPUT | MUX_MODE5) /* dispc2_de */ + OMAP4_IOPAD(0x1c4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data8 */ + OMAP4_IOPAD(0x1c6, PIN_OUTPUT | MUX_MODE5) /* dispc2_data7 */ + OMAP4_IOPAD(0x1c8, PIN_OUTPUT | MUX_MODE5) /* dispc2_data6 */ + OMAP4_IOPAD(0x1ca, PIN_OUTPUT | MUX_MODE5) /* dispc2_data5 */ + OMAP4_IOPAD(0x1cc, PIN_OUTPUT | MUX_MODE5) /* dispc2_data4 */ + OMAP4_IOPAD(0x1ce, PIN_OUTPUT | MUX_MODE5) /* dispc2_data3 */ + + OMAP4_IOPAD(0x1d0, PIN_OUTPUT | MUX_MODE5) /* dispc2_data2 */ + OMAP4_IOPAD(0x1d2, PIN_OUTPUT | MUX_MODE5) /* dispc2_data1 */ + OMAP4_IOPAD(0x1d4, PIN_OUTPUT | MUX_MODE5) /* dispc2_data0 */ + >; + }; + + tfp410_pins: pinmux_tfp410_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x184, PIN_OUTPUT | MUX_MODE3) /* gpio_0 */ + >; + }; + + dss_hdmi_pins: pinmux_dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; + }; + + tpd12s015_pins: pinmux_tpd12s015_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x062, PIN_OUTPUT | MUX_MODE3) /* gpmc_a17.gpio_41 */ + OMAP4_IOPAD(0x088, PIN_OUTPUT | MUX_MODE3) /* gpmc_nbe1.gpio_60 */ + OMAP4_IOPAD(0x098, PIN_INPUT_PULLDOWN | MUX_MODE3) /* hdmi_hpd.gpio_63 */ + >; + }; + + hsusbb1_pins: pinmux_hsusbb1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0c2, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_clk.usbb1_ulpiphy_clk */ + OMAP4_IOPAD(0x0c4, PIN_OUTPUT | MUX_MODE4) /* usbb1_ulpitll_stp.usbb1_ulpiphy_stp */ + OMAP4_IOPAD(0x0c6, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dir.usbb1_ulpiphy_dir */ + OMAP4_IOPAD(0x0c8, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_nxt.usbb1_ulpiphy_nxt */ + OMAP4_IOPAD(0x0ca, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat0.usbb1_ulpiphy_dat0 */ + OMAP4_IOPAD(0x0cc, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat1.usbb1_ulpiphy_dat1 */ + OMAP4_IOPAD(0x0ce, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat2.usbb1_ulpiphy_dat2 */ + OMAP4_IOPAD(0x0d0, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat3.usbb1_ulpiphy_dat3 */ + OMAP4_IOPAD(0x0d2, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat4.usbb1_ulpiphy_dat4 */ + OMAP4_IOPAD(0x0d4, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat5.usbb1_ulpiphy_dat5 */ + OMAP4_IOPAD(0x0d6, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat6.usbb1_ulpiphy_dat6 */ + OMAP4_IOPAD(0x0d8, PIN_INPUT_PULLDOWN | MUX_MODE4) /* usbb1_ulpitll_dat7.usbb1_ulpiphy_dat7 */ + >; + }; + + i2c1_pins: pinmux_i2c1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x122, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl */ + OMAP4_IOPAD(0x124, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda */ + >; + }; + + i2c2_pins: pinmux_i2c2_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x126, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_scl */ + OMAP4_IOPAD(0x128, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_sda */ + >; + }; + + i2c3_pins: pinmux_i2c3_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12a, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_scl */ + OMAP4_IOPAD(0x12c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_sda */ + >; + }; + + i2c4_pins: pinmux_i2c4_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12e, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_scl */ + OMAP4_IOPAD(0x130, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_sda */ + >; + }; + + /* + * wl12xx GPIO outputs for WLAN_EN, BT_EN, FM_EN, BT_WAKEUP + * REVISIT: Are the pull-ups needed for GPIO 48 and 49? + */ + wl12xx_gpio: pinmux_wl12xx_gpio { + pinctrl-single,pins = < + OMAP4_IOPAD(0x066, PIN_OUTPUT | MUX_MODE3) /* gpmc_a19.gpio_43 */ + OMAP4_IOPAD(0x06c, PIN_OUTPUT | MUX_MODE3) /* gpmc_a22.gpio_46 */ + OMAP4_IOPAD(0x070, PIN_OUTPUT_PULLUP | MUX_MODE3) /* gpmc_a24.gpio_48 */ + OMAP4_IOPAD(0x072, PIN_OUTPUT_PULLUP | MUX_MODE3) /* gpmc_a25.gpio_49 */ + >; + }; + + /* wl12xx GPIO inputs and SDIO pins */ + wl12xx_pins: pinmux_wl12xx_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x078, PIN_INPUT | MUX_MODE3) /* gpmc_ncs2.gpio_52 */ + OMAP4_IOPAD(0x07a, PIN_INPUT | MUX_MODE3) /* gpmc_ncs3.gpio_53 */ + OMAP4_IOPAD(0x148, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_clk.sdmmc5_clk */ + OMAP4_IOPAD(0x14a, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_cmd.sdmmc5_cmd */ + OMAP4_IOPAD(0x14c, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat0.sdmmc5_dat0 */ + OMAP4_IOPAD(0x14e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat1.sdmmc5_dat1 */ + OMAP4_IOPAD(0x150, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat2.sdmmc5_dat2 */ + OMAP4_IOPAD(0x152, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat3.sdmmc5_dat3 */ + >; + }; + + button_pins: pinmux_button_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x114, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio_121 */ + >; + }; +}; + +&omap4_pmx_wkup { + led_wkgpio_pins: pinmux_leds_wkpins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x05a, PIN_OUTPUT | MUX_MODE3) /* gpio_wk7 */ + OMAP4_IOPAD(0x05c, PIN_OUTPUT | MUX_MODE3) /* gpio_wk8 */ + >; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + + clock-frequency = <400000>; + + twl: twl@48 { + reg = <0x48>; + /* IRQ# = 7 */ + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_1N cascaded to gic */ + }; + + twl6040: twl@4b { + compatible = "ti,twl6040"; + #clock-cells = <0>; + reg = <0x4b>; + + pinctrl-names = "default"; + pinctrl-0 = <&twl6040_pins>; + + /* IRQ# = 119 */ + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_2N cascaded to gic */ + ti,audpwron-gpio = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio line 127 */ + + vio-supply = <&v1v8>; + v2v1-supply = <&v2v1>; + enable-active-high; + }; +}; + +#include "twl6030.dtsi" +#include "twl6030_omap4.dtsi" + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + + clock-frequency = <400000>; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_pins>; + + clock-frequency = <100000>; + + /* + * Display monitor features are burnt in their EEPROM as EDID data. + * The EEPROM is connected as I2C slave device. + */ + eeprom@50 { + compatible = "ti,eeprom"; + reg = <0x50>; + }; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_pins>; + + clock-frequency = <400000>; +}; + +&mmc1 { + vmmc-supply = <&vmmc>; + bus-width = <8>; +}; + +&mmc2 { + status = "disabled"; +}; + +&mmc3 { + status = "disabled"; +}; + +&mmc4 { + status = "disabled"; +}; + +&mmc5 { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_pins>; + vmmc-supply = <&wl12xx_vmmc>; + interrupts-extended = <&wakeupgen GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core 0x10e>; + non-removable; + bus-width = <4>; + cap-power-off-card; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1271"; + reg = <2>; + /* gpio_53 with gpmc_ncs3 pad as wakeup */ + interrupts-extended = <&gpio2 21 IRQ_TYPE_LEVEL_HIGH>, + <&omap4_pmx_core 0x3a>; + interrupt-names = "irq", "wakeup"; + ref-clock-frequency = <38400000>; + }; +}; + +&emif1 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&emif2 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&mcbsp1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp1_pins>; + status = "okay"; +}; + +&twl_usb_comparator { + usb-supply = <&vusb>; +}; + +&uart2 { + interrupts-extended = <&wakeupgen GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART2_RX>; +}; + +&uart3 { + interrupts-extended = <&wakeupgen GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART3_RX>; +}; + +&uart4 { + interrupts-extended = <&wakeupgen GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART4_RX>; +}; + +&usb_otg_hs { + interface-type = <1>; + mode = <3>; + power = <50>; +}; + +&usbhshost { + port1-mode = "ehci-phy"; +}; + +&usbhsehci { + phys = <&hsusb1_phy>; + + #address-cells = <1>; + #size-cells = <0>; + + hub@1 { + compatible = "usb424,9514"; + reg = <1>; + #address-cells = <1>; + #size-cells = <0>; + + ethernet: usbether@1 { + compatible = "usb424,ec00"; + reg = <1>; + }; + }; +}; + +&dss { + status = "ok"; + + port { + dpi_out: endpoint { + remote-endpoint = <&tfp410_in>; + data-lines = <24>; + }; + }; +}; + +&dsi2 { + status = "ok"; + vdd-supply = <&vcxio>; +}; + +&hdmi { + status = "ok"; + vdda-supply = <&vdac>; + + port { + hdmi_out: endpoint { + remote-endpoint = <&tpd12s015_in>; + }; + }; +}; diff --git a/arch/arm/dts/omap4-panda-es.dts b/arch/arm/dts/omap4-panda-es.dts new file mode 100644 index 0000000000..9dd307b526 --- /dev/null +++ b/arch/arm/dts/omap4-panda-es.dts @@ -0,0 +1,82 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap4460.dtsi" +#include "omap4-panda-common.dtsi" + +/ { + model = "TI OMAP4 PandaBoard-ES"; + compatible = "ti,omap4-panda-es", "ti,omap4-panda", "ti,omap4460", "ti,omap4430", "ti,omap4"; +}; + +/* Audio routing is differnet between PandaBoard4430 and PandaBoardES */ +&sound { + ti,model = "PandaBoardES"; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Ext Spk", "HFL", + "Ext Spk", "HFR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "AFML", "Line In", + "AFMR", "Line In"; +}; + +/* PandaboardES has external pullups on SCL & SDA */ +&dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; +}; + +&omap4_pmx_core { + led_gpio_pins: gpio_led_pmx { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0f6, PIN_OUTPUT | MUX_MODE3) /* gpio_110 */ + >; + }; + + button_pins: pinmux_button_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x11b, PIN_INPUT_PULLUP | MUX_MODE3) /* gpio_113 */ + >; + }; +}; + +&led_wkgpio_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x05c, PIN_OUTPUT | MUX_MODE3) /* gpio_wk8 */ + >; +}; + +&leds { + pinctrl-0 = < + &led_gpio_pins + &led_wkgpio_pins + >; + + heartbeat { + gpios = <&gpio4 14 GPIO_ACTIVE_HIGH>; + }; + mmc { + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; + }; +}; + +&gpio_keys { + buttonS2 { + gpios = <&gpio4 17 GPIO_ACTIVE_LOW>; /* gpio_113 */ + }; +}; + +&gpio1_target { + ti,no-reset-on-init; +}; diff --git a/arch/arm/dts/omap4-panda.dts b/arch/arm/dts/omap4-panda.dts new file mode 100644 index 0000000000..fb2f47717b --- /dev/null +++ b/arch/arm/dts/omap4-panda.dts @@ -0,0 +1,13 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap443x.dtsi" +#include "omap4-panda-common.dtsi" + +/ { + model = "TI OMAP4 PandaBoard"; + compatible = "ti,omap4-panda", "ti,omap4430", "ti,omap4"; +}; diff --git a/arch/arm/dts/omap4.dtsi b/arch/arm/dts/omap4.dtsi new file mode 100644 index 0000000000..763bdea8c8 --- /dev/null +++ b/arch/arm/dts/omap4.dtsi @@ -0,0 +1,657 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ + +#include <dt-bindings/bus/ti-sysc.h> +#include <dt-bindings/clock/omap4.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/omap.h> +#include <dt-bindings/clock/omap4.h> + +/ { + compatible = "ti,omap4430", "ti,omap4"; + interrupt-parent = <&wakeupgen>; + #address-cells = <1>; + #size-cells = <1>; + chosen { }; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + i2c3 = &i2c4; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu@0 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + next-level-cache = <&L2>; + reg = <0x0>; + + clocks = <&dpll_mpu_ck>; + clock-names = "cpu"; + + clock-latency = <300000>; /* From omap-cpufreq driver */ + }; + cpu@1 { + compatible = "arm,cortex-a9"; + device_type = "cpu"; + next-level-cache = <&L2>; + reg = <0x1>; + }; + }; + + /* + * Note that 4430 needs cross trigger interface (CTI) supported + * before we can configure the interrupts. This means sampling + * events are not supported for pmu. Note that 4460 does not use + * CTI, see also 4460.dtsi. + */ + pmu { + compatible = "arm,cortex-a9-pmu"; + ti,hwmods = "debugss"; + }; + + gic: interrupt-controller@48241000 { + compatible = "arm,cortex-a9-gic"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x48241000 0x1000>, + <0x48240100 0x0100>; + interrupt-parent = <&gic>; + }; + + L2: l2-cache-controller@48242000 { + compatible = "arm,pl310-cache"; + reg = <0x48242000 0x1000>; + cache-unified; + cache-level = <2>; + }; + + local-timer@48240600 { + compatible = "arm,cortex-a9-twd-timer"; + clocks = <&mpu_periphclk>; + reg = <0x48240600 0x20>; + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_EDGE_RISING)>; + interrupt-parent = <&gic>; + }; + + wakeupgen: interrupt-controller@48281000 { + compatible = "ti,omap4-wugen-mpu"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0x48281000 0x1000>; + interrupt-parent = <&gic>; + }; + + /* + * The soc node represents the soc top level view. It is used for IPs + * that are not memory mapped in the MPU view or for the MPU itself. + */ + soc { + compatible = "ti,omap-infra"; + mpu { + compatible = "ti,omap4-mpu"; + ti,hwmods = "mpu"; + sram = <&ocmcram>; + }; + + dsp { + compatible = "ti,omap3-c64"; + }; + + iva { + compatible = "ti,ivahd"; + ti,hwmods = "iva"; + }; + }; + + /* + * XXX: Use a flat representation of the OMAP4 interconnect. + * The real OMAP interconnect network is quite complex. + * Since it will not bring real advantage to represent that in DT for + * the moment, just use a fake OCP bus entry to represent the whole bus + * hierarchy. + */ + ocp { + compatible = "ti,omap4-l3-noc", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges; + ti,hwmods = "l3_main_1", "l3_main_2", "l3_main_3"; + reg = <0x44000000 0x1000>, + <0x44800000 0x2000>, + <0x45000000 0x1000>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + + l4_wkup: interconnect@4a300000 { + }; + + l4_cfg: interconnect@4a000000 { + }; + + l4_per: interconnect@48000000 { + }; + + l4_abe: interconnect@40100000 { + }; + + ocmcram: sram@40304000 { + compatible = "mmio-sram"; + reg = <0x40304000 0xa000>; /* 40k */ + }; + + gpmc: gpmc@50000000 { + compatible = "ti,omap4430-gpmc"; + reg = <0x50000000 0x1000>; + #address-cells = <2>; + #size-cells = <1>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 4>; + dma-names = "rxtx"; + gpmc,num-cs = <8>; + gpmc,num-waitpins = <4>; + ti,hwmods = "gpmc"; + ti,no-idle-on-init; + clocks = <&l3_div_ck>; + clock-names = "fck"; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + target-module@52000000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "iss"; + reg = <0x52000000 0x4>, + <0x52000010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-delay-us = <2>; + clocks = <&iss_clkctrl OMAP4_ISS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x52000000 0x1000000>; + + /* No child device binding, driver in staging */ + }; + + target-module@55082000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55082000 0x4>, + <0x55082010 0x4>, + <0x55082014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + clocks = <&ducati_clkctrl OMAP4_IPU_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_core 2>; + reset-names = "rstctrl"; + ranges = <0x0 0x55082000 0x100>; + #size-cells = <1>; + #address-cells = <1>; + + mmu_ipu: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + ti,iommu-bus-err-back; + }; + }; + + target-module@4012c000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x4012c000 0x4>, + <0x4012c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + clocks = <&abe_clkctrl OMAP4_SLIMBUS1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4012c000 0x1000>, /* MPU */ + <0x4902c000 0x4902c000 0x1000>; /* L3 */ + + /* No child device binding or driver in mainline */ + }; + + dmm@4e000000 { + compatible = "ti,omap4-dmm"; + reg = <0x4e000000 0x800>; + interrupts = <0 113 0x4>; + ti,hwmods = "dmm"; + }; + + emif1: emif@4c000000 { + compatible = "ti,emif-4d"; + reg = <0x4c000000 0x100>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "emif1"; + ti,no-idle-on-init; + phy-type = <1>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + emif2: emif@4d000000 { + compatible = "ti,emif-4d"; + reg = <0x4d000000 0x100>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "emif2"; + ti,no-idle-on-init; + phy-type = <1>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + aes1_target: target-module@4b501000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4b501080 0x4>, + <0x4b501084 0x4>, + <0x4b501088 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_AES1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b501000 0x1000>; + + aes1: aes@0 { + compatible = "ti,omap4-aes"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 111>, <&sdma 110>; + dma-names = "tx", "rx"; + }; + }; + + aes2_target: target-module@4b701000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4b701080 0x4>, + <0x4b701084 0x4>, + <0x4b701088 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_AES2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b701000 0x1000>; + + aes2: aes@0 { + compatible = "ti,omap4-aes"; + reg = <0 0xa0>; + interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 114>, <&sdma 113>; + dma-names = "tx", "rx"; + }; + }; + + sham_target: target-module@4b100000 { + compatible = "ti,sysc-omap3-sham", "ti,sysc"; + reg = <0x4b100100 0x4>, + <0x4b100110 0x4>, + <0x4b100114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (P, C): l4per_pwrdm, l4_secure_clkdm */ + clocks = <&l4_secure_clkctrl OMAP4_SHA2MD5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4b100000 0x1000>; + + sham: sham@0 { + compatible = "ti,omap4-sham"; + reg = <0 0x300>; + interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 119>; + dma-names = "rx"; + }; + }; + + abb_mpu: regulator-abb-mpu { + compatible = "ti,abb-v2"; + regulator-name = "abb_mpu"; + #address-cells = <0>; + #size-cells = <0>; + ti,tranxdone-status-mask = <0x80>; + clocks = <&sys_clkin_ck>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + status = "disabled"; + }; + + abb_iva: regulator-abb-iva { + compatible = "ti,abb-v2"; + regulator-name = "abb_iva"; + #address-cells = <0>; + #size-cells = <0>; + ti,tranxdone-status-mask = <0x80000000>; + clocks = <&sys_clkin_ck>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + status = "disabled"; + }; + + target-module@56000000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x5600fe00 0x4>, + <0x5600fe10 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + clocks = <&l3_gfx_clkctrl OMAP4_GPU_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x56000000 0x2000000>; + + /* + * Closed source PowerVR driver, no child device + * binding or driver in mainline + */ + }; + + /* + * DSS is only using l3 mapping without l4 as noted in the TRM + * "10.1.3 DSS Register Manual" for omap4460. + */ + target-module@58000000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x58000000 4>, + <0x58000014 4>; + reg-names = "rev", "syss"; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 0>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 11>; + clock-names = "fck", "hdmi_clk", "sys_clk", "tv_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x58000000 0x1000000>; + + dss: dss@0 { + compatible = "ti,omap4-dss"; + reg = <0 0x80>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000000>; + + target-module@1000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x1000 0x4>, + <0x1010 0x4>, + <0x1014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x1000>; + + dispc@0 { + compatible = "ti,omap4-dispc"; + reg = <0 0x1000>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + }; + }; + + target-module@2000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2000 0x4>, + <0x2010 0x4>, + <0x2014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x2000 0x1000>; + + rfbi: encoder@0 { + reg = <0 0x1000>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, <&l3_div_ck>; + clock-names = "fck", "ick"; + }; + }; + + target-module@3000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x3000 0x4>; + reg-names = "rev"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "sys_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x3000 0x1000>; + + venc: encoder@0 { + compatible = "ti,omap4-venc"; + reg = <0 0x1000>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 11>; + clock-names = "fck"; + }; + }; + + target-module@4000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4000 0x4>, + <0x4010 0x4>, + <0x4014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x4000 0x1000>; + + dsi1: encoder@0 { + compatible = "ti,omap4-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x20>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + }; + }; + + target-module@5000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5000 0x4>, + <0x5010 0x4>, + <0x5014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5000 0x1000>; + + dsi2: encoder@0 { + compatible = "ti,omap4-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x20>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + }; + }; + + target-module@6000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x6000 0x4>, + <0x6010 0x4>; + reg-names = "rev", "sysc"; + /* + * Has SYSC_IDLE_SMART and SYSC_IDLE_SMART_WKUP + * but HDMI audio will fail with them. + */ + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + ti,sysc-mask = <(SYSC_OMAP4_SOFTRESET)>; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 8>; + clock-names = "fck", "dss_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x6000 0x2000>; + + hdmi: encoder@0 { + compatible = "ti,omap4-hdmi"; + reg = <0 0x200>, + <0x200 0x100>, + <0x300 0x100>, + <0x400 0x1000>; + reg-names = "wp", "pll", "phy", "core"; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 9>, + <&l3_dss_clkctrl OMAP4_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + dmas = <&sdma 76>; + dma-names = "audio_tx"; + }; + }; + }; + }; + }; +}; + +#include "omap4-l4.dtsi" +#include "omap4-l4-abe.dtsi" +#include "omap44xx-clocks.dtsi" + +&prm { + prm_tesla: prm@400 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x400 0x100>; + #reset-cells = <1>; + }; + + prm_core: prm@700 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x700 0x100>; + #reset-cells = <1>; + }; + + prm_ivahd: prm@f00 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0xf00 0x100>; + #reset-cells = <1>; + }; + + prm_device: prm@1b00 { + compatible = "ti,omap4-prm-inst", "ti,omap-prm-inst"; + reg = <0x1b00 0x40>; + #reset-cells = <1>; + }; +}; diff --git a/arch/arm/dts/omap443x-clocks.dtsi b/arch/arm/dts/omap443x-clocks.dtsi new file mode 100644 index 0000000000..39297868ec --- /dev/null +++ b/arch/arm/dts/omap443x-clocks.dtsi @@ -0,0 +1,15 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&prm_clocks { + bandgap_fclk: bandgap_fclk@1888 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_32k_ck>; + ti,bit-shift = <8>; + reg = <0x1888>; + }; +}; diff --git a/arch/arm/dts/omap443x.dtsi b/arch/arm/dts/omap443x.dtsi new file mode 100644 index 0000000000..cbcdcb4e7d --- /dev/null +++ b/arch/arm/dts/omap443x.dtsi @@ -0,0 +1,76 @@ +/* + * Device Tree Source for OMAP443x SoC + * + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ + +#include "omap4.dtsi" + +/ { + cpus { + cpu0: cpu@0 { + /* OMAP443x variants OPP50-OPPNT */ + operating-points = < + /* kHz uV */ + 300000 1025000 + 600000 1200000 + 800000 1313000 + 1008000 1375000 + >; + clock-latency = <300000>; /* From legacy driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + }; + + thermal-zones { + #include "omap4-cpu-thermal.dtsi" + }; + + ocp { + bandgap: bandgap@4a002260 { + reg = <0x4a002260 0x4 + 0x4a00232C 0x4>; + compatible = "ti,omap4430-bandgap"; + + #thermal-sensor-cells = <0>; + }; + }; + + ocp { + abb_mpu: regulator-abb-mpu { + status = "okay"; + + reg = <0x4a307bd0 0x8>, <0x4a306014 0x4>; + reg-names = "base-address", "int-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1025000 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1313000 0 0 0 0 0 + 1375000 1 0 0 0 0 + 1389000 1 0 0 0 0 + >; + }; + + /* Default unused, just provide register info for record */ + abb_iva: regulator-abb-iva { + reg = <0x4a307bd8 0x8>, <0x4a306010 0x4>; + reg-names = "base-address", "int-address"; + }; + + }; + +}; + +&cpu_thermal { + coefficients = <0 20000>; +}; + +/include/ "omap443x-clocks.dtsi" diff --git a/arch/arm/dts/omap4460.dtsi b/arch/arm/dts/omap4460.dtsi new file mode 100644 index 0000000000..2223dc0d63 --- /dev/null +++ b/arch/arm/dts/omap4460.dtsi @@ -0,0 +1,131 @@ +/* + * Device Tree Source for OMAP4460 SoC + * + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * This file is licensed under the terms of the GNU General Public License + * version 2. This program is licensed "as is" without any warranty of any + * kind, whether express or implied. + */ +#include "omap4.dtsi" + +/ { + cpus { + /* OMAP446x 'standard device' variants OPP50 to OPPTurbo */ + cpu0: cpu@0 { + operating-points = < + /* kHz uV */ + 350000 1025000 + 700000 1200000 + 920000 1313000 + >; + clock-latency = <300000>; /* From legacy driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + }; + + pmu { + compatible = "arm,cortex-a9-pmu"; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + ti,hwmods = "debugss"; + }; + + thermal-zones { + #include "omap4-cpu-thermal.dtsi" + }; + + ocp { + bandgap: bandgap@4a002260 { + reg = <0x4a002260 0x4 + 0x4a00232C 0x4 + 0x4a002378 0x18>; + compatible = "ti,omap4460-bandgap"; + interrupts = <0 126 IRQ_TYPE_LEVEL_HIGH>; /* talert */ + gpios = <&gpio3 22 GPIO_ACTIVE_HIGH>; /* tshut */ + + #thermal-sensor-cells = <0>; + }; + + abb_mpu: regulator-abb-mpu { + status = "okay"; + + reg = <0x4a307bd0 0x8>, <0x4a306014 0x4>, + <0x4A002268 0x4>; + reg-names = "base-address", "int-address", + "efuse-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1025000 0 0 0 0 0 + 1200000 0 0 0 0 0 + 1313000 0 0 0x100000 0x40000 0 + 1375000 1 0 0 0 0 + 1389000 1 0 0 0 0 + >; + }; + + abb_iva: regulator-abb-iva { + status = "okay"; + + reg = <0x4a307bd8 0x8>, <0x4a306010 0x4>, + <0x4A002268 0x4>; + reg-names = "base-address", "int-address", + "efuse-address"; + + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 950000 0 0 0 0 0 + 1140000 0 0 0 0 0 + 1291000 0 0 0x200000 0 0 + 1375000 1 0 0 0 0 + 1376000 1 0 0 0 0 + >; + }; + }; + +}; + +&cpu_thermal { + coefficients = <348 (-9301)>; +}; + +/* Only some L4 CFG interconnect ranges are different on 4460 */ +&l4_cfg_segment_300000 { + ranges = <0x00000000 0x00300000 0x020000>, /* ap 67 */ + <0x00040000 0x00340000 0x001000>, /* ap 68 */ + <0x00020000 0x00320000 0x004000>, /* ap 71 */ + <0x00024000 0x00324000 0x002000>, /* ap 72 */ + <0x00026000 0x00326000 0x001000>, /* ap 73 */ + <0x00027000 0x00327000 0x001000>, /* ap 74 */ + <0x00028000 0x00328000 0x001000>, /* ap 75 */ + <0x00029000 0x00329000 0x001000>, /* ap 76 */ + <0x00030000 0x00330000 0x010000>, /* ap 77 */ + <0x0002a000 0x0032a000 0x002000>, /* ap 90 */ + <0x0002c000 0x0032c000 0x004000>, /* ap 91 */ + <0x00010000 0x00310000 0x008000>, /* ap 92 */ + <0x00018000 0x00318000 0x004000>, /* ap 93 */ + <0x0001c000 0x0031c000 0x002000>, /* ap 94 */ + <0x0001e000 0x0031e000 0x002000>; /* ap 95 */ +}; + +&l4_cfg_target_0 { + ranges = <0x00000000 0x00000000 0x00010000>, + <0x00010000 0x00010000 0x00008000>, + <0x00018000 0x00018000 0x00004000>, + <0x0001c000 0x0001c000 0x00002000>, + <0x0001e000 0x0001e000 0x00002000>, + <0x00020000 0x00020000 0x00004000>, + <0x00024000 0x00024000 0x00002000>, + <0x00026000 0x00026000 0x00001000>, + <0x00027000 0x00027000 0x00001000>, + <0x00028000 0x00028000 0x00001000>, + <0x00029000 0x00029000 0x00001000>, + <0x0002a000 0x0002a000 0x00002000>, + <0x0002c000 0x0002c000 0x00004000>, + <0x00030000 0x00030000 0x00010000>; +}; + +/include/ "omap446x-clocks.dtsi" diff --git a/arch/arm/dts/omap446x-clocks.dtsi b/arch/arm/dts/omap446x-clocks.dtsi new file mode 100644 index 0000000000..0f41714cff --- /dev/null +++ b/arch/arm/dts/omap446x-clocks.dtsi @@ -0,0 +1,24 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&prm_clocks { + div_ts_ck: div_ts_ck@1888 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l4_wkup_clk_mux_ck>; + ti,bit-shift = <24>; + reg = <0x1888>; + ti,dividers = <8>, <16>, <32>; + }; + + bandgap_ts_fclk: bandgap_ts_fclk@1888 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&div_ts_ck>; + ti,bit-shift = <8>; + reg = <0x1888>; + }; +}; diff --git a/arch/arm/dts/omap44xx-clocks.dtsi b/arch/arm/dts/omap44xx-clocks.dtsi new file mode 100644 index 0000000000..5328685911 --- /dev/null +++ b/arch/arm/dts/omap44xx-clocks.dtsi @@ -0,0 +1,1324 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP4 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&cm1_clocks { + extalt_clkin_ck: extalt_clkin_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <59000000>; + }; + + pad_clks_src_ck: pad_clks_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + pad_clks_ck: pad_clks_ck@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&pad_clks_src_ck>; + ti,bit-shift = <8>; + reg = <0x0108>; + }; + + pad_slimbus_core_clks_ck: pad_slimbus_core_clks_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + secure_32k_clk_src_ck: secure_32k_clk_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + slimbus_src_clk: slimbus_src_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + slimbus_clk: slimbus_clk@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&slimbus_src_clk>; + ti,bit-shift = <10>; + reg = <0x0108>; + }; + + sys_32k_ck: sys_32k_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + virt_12000000_ck: virt_12000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + virt_13000000_ck: virt_13000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <13000000>; + }; + + virt_16800000_ck: virt_16800000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16800000>; + }; + + virt_19200000_ck: virt_19200000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <19200000>; + }; + + virt_26000000_ck: virt_26000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + }; + + virt_27000000_ck: virt_27000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <27000000>; + }; + + virt_38400000_ck: virt_38400000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <38400000>; + }; + + tie_low_clock_ck: tie_low_clock_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; + + utmi_phy_clkout_ck: utmi_phy_clkout_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60mhsp1_ck: xclk60mhsp1_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60mhsp2_ck: xclk60mhsp2_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60motg_ck: xclk60motg_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + dpll_abe_ck: dpll_abe_ck@1e0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-m4xen-clock"; + clocks = <&abe_dpll_refclk_mux_ck>, <&abe_dpll_bypass_clk_mux_ck>; + reg = <0x01e0>, <0x01e4>, <0x01ec>, <0x01e8>; + }; + + dpll_abe_x2_ck: dpll_abe_x2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_abe_ck>; + reg = <0x01f0>; + }; + + dpll_abe_m2x2_ck: dpll_abe_m2x2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01f0>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + abe_24m_fclk: abe_24m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + abe_clk: abe_clk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_m2x2_ck>; + ti,max-div = <4>; + reg = <0x0108>; + ti,index-power-of-two; + }; + + + dpll_abe_m3x2_ck: dpll_abe_m3x2_ck@1f4 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01f4>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + core_hsd_byp_clk_mux_ck: core_hsd_byp_clk_mux_ck@12c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_abe_m3x2_ck>; + ti,bit-shift = <23>; + reg = <0x012c>; + }; + + dpll_core_ck: dpll_core_ck@120 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-core-clock"; + clocks = <&sys_clkin_ck>, <&core_hsd_byp_clk_mux_ck>; + reg = <0x0120>, <0x0124>, <0x012c>, <0x0128>; + }; + + dpll_core_x2_ck: dpll_core_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_core_ck>; + }; + + dpll_core_m6x2_ck: dpll_core_m6x2_ck@140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0140>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_core_m2_ck: dpll_core_m2_ck@130 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0130>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + ddrphy_ck: ddrphy_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_m2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + dpll_core_m5x2_ck: dpll_core_m5x2_ck@13c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x013c>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + div_core_ck: div_core_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + reg = <0x0100>; + ti,max-div = <2>; + }; + + div_iva_hs_clk: div_iva_hs_clk@1dc { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + ti,max-div = <4>; + reg = <0x01dc>; + ti,index-power-of-two; + }; + + div_mpu_hs_clk: div_mpu_hs_clk@19c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_m5x2_ck>; + ti,max-div = <4>; + reg = <0x019c>; + ti,index-power-of-two; + }; + + dpll_core_m4x2_ck: dpll_core_m4x2_ck@138 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0138>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dll_clk_div_ck: dll_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_m4x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + dpll_abe_m2_ck: dpll_abe_m2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_ck>; + ti,max-div = <31>; + reg = <0x01f0>; + ti,index-starts-at-one; + }; + + dpll_core_m3x2_gate_ck: dpll_core_m3x2_gate_ck@134 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_x2_ck>; + ti,bit-shift = <8>; + reg = <0x0134>; + }; + + dpll_core_m3x2_div_ck: dpll_core_m3x2_div_ck@134 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + reg = <0x0134>; + ti,index-starts-at-one; + }; + + dpll_core_m3x2_ck: dpll_core_m3x2_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&dpll_core_m3x2_gate_ck>, <&dpll_core_m3x2_div_ck>; + }; + + dpll_core_m7x2_ck: dpll_core_m7x2_ck@144 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0144>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + iva_hsd_byp_clk_mux_ck: iva_hsd_byp_clk_mux_ck@1ac { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&div_iva_hs_clk>; + ti,bit-shift = <23>; + reg = <0x01ac>; + }; + + dpll_iva_ck: dpll_iva_ck@1a0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&iva_hsd_byp_clk_mux_ck>; + reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>; + assigned-clocks = <&dpll_iva_ck>; + assigned-clock-rates = <931200000>; + }; + + dpll_iva_x2_ck: dpll_iva_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_iva_ck>; + }; + + dpll_iva_m4x2_ck: dpll_iva_m4x2_ck@1b8 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01b8>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + assigned-clocks = <&dpll_iva_m4x2_ck>; + assigned-clock-rates = <465600000>; + }; + + dpll_iva_m5x2_ck: dpll_iva_m5x2_ck@1bc { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x01bc>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + assigned-clocks = <&dpll_iva_m5x2_ck>; + assigned-clock-rates = <266100000>; + }; + + dpll_mpu_ck: dpll_mpu_ck@160 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&div_mpu_hs_clk>; + reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>; + }; + + dpll_mpu_m2_ck: dpll_mpu_m2_ck@170 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_mpu_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0170>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + per_hs_clk_div_ck: per_hs_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + usb_hs_clk_div_ck: usb_hs_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <3>; + }; + + l3_div_ck: l3_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&div_core_ck>; + ti,bit-shift = <4>; + ti,max-div = <2>; + reg = <0x0100>; + }; + + l4_div_ck: l4_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&l3_div_ck>; + ti,bit-shift = <8>; + ti,max-div = <2>; + reg = <0x0100>; + }; + + lp_clk_div_ck: lp_clk_div_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + mpu_periphclk: mpu_periphclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_mpu_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + ocp_abe_iclk: ocp_abe_iclk@528 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&abe_clkctrl OMAP4_AESS_CLKCTRL 24>; + ti,bit-shift = <24>; + reg = <0x0528>; + ti,dividers = <2>, <1>; + }; + + per_abe_24m_fclk: per_abe_24m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + dummy_ck: dummy_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; +}; + +&prm_clocks { + sys_clkin_ck: sys_clkin_ck@110 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&virt_12000000_ck>, <&virt_13000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>; + reg = <0x0110>; + ti,index-starts-at-one; + }; + + abe_dpll_bypass_clk_mux_ck: abe_dpll_bypass_clk_mux_ck@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&sys_32k_ck>; + ti,bit-shift = <24>; + reg = <0x0108>; + }; + + abe_dpll_refclk_mux_ck: abe_dpll_refclk_mux_ck@10c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&sys_32k_ck>; + reg = <0x010c>; + }; + + dbgclk_mux_ck: dbgclk_mux_ck { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_clkin_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + l4_wkup_clk_mux_ck: l4_wkup_clk_mux_ck@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&lp_clk_div_ck>; + reg = <0x0108>; + }; + + syc_clk_div_ck: syc_clk_div_ck@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&sys_clkin_ck>; + reg = <0x0100>; + ti,max-div = <2>; + }; + + usim_ck: usim_ck@1858 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m4x2_ck>; + ti,bit-shift = <24>; + reg = <0x1858>; + ti,dividers = <14>, <18>; + }; + + usim_fclk: usim_fclk@1858 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&usim_ck>; + ti,bit-shift = <8>; + reg = <0x1858>; + }; + + trace_clk_div_ck: trace_clk_div_ck { + #clock-cells = <0>; + compatible = "ti,clkdm-gate-clock"; + clocks = <&emu_sys_clkctrl OMAP4_DEBUGSS_CLKCTRL 24>; + }; +}; + +&prm_clockdomains { + emu_sys_clkdm: emu_sys_clkdm { + compatible = "ti,clockdomain"; + clocks = <&trace_clk_div_ck>; + }; +}; + +&cm2_clocks { + per_hsd_byp_clk_mux_ck: per_hsd_byp_clk_mux_ck@14c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin_ck>, <&per_hs_clk_div_ck>; + ti,bit-shift = <23>; + reg = <0x014c>; + }; + + dpll_per_ck: dpll_per_ck@140 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin_ck>, <&per_hsd_byp_clk_mux_ck>; + reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>; + }; + + dpll_per_m2_ck: dpll_per_m2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_ck>; + ti,max-div = <31>; + reg = <0x0150>; + ti,index-starts-at-one; + }; + + dpll_per_x2_ck: dpll_per_x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_per_ck>; + reg = <0x0150>; + }; + + dpll_per_m2x2_ck: dpll_per_m2x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0150>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m3x2_gate_ck: dpll_per_m3x2_gate_ck@154 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_per_x2_ck>; + ti,bit-shift = <8>; + reg = <0x0154>; + }; + + dpll_per_m3x2_div_ck: dpll_per_m3x2_div_ck@154 { + #clock-cells = <0>; + compatible = "ti,composite-divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + reg = <0x0154>; + ti,index-starts-at-one; + }; + + dpll_per_m3x2_ck: dpll_per_m3x2_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&dpll_per_m3x2_gate_ck>, <&dpll_per_m3x2_div_ck>; + }; + + dpll_per_m4x2_ck: dpll_per_m4x2_ck@158 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0158>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m5x2_ck: dpll_per_m5x2_ck@15c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x015c>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m6x2_ck: dpll_per_m6x2_ck@160 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0160>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_per_m7x2_ck: dpll_per_m7x2_ck@164 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + ti,autoidle-shift = <8>; + reg = <0x0164>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + dpll_usb_ck: dpll_usb_ck@180 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-j-type-clock"; + clocks = <&sys_clkin_ck>, <&usb_hs_clk_div_ck>; + reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>; + }; + + dpll_usb_clkdcoldo_ck: dpll_usb_clkdcoldo_ck@1b4 { + #clock-cells = <0>; + compatible = "ti,fixed-factor-clock"; + clocks = <&dpll_usb_ck>; + ti,clock-div = <1>; + ti,autoidle-shift = <8>; + reg = <0x01b4>; + ti,clock-mult = <1>; + ti,invert-autoidle-bit; + }; + + dpll_usb_m2_ck: dpll_usb_m2_ck@190 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_ck>; + ti,max-div = <127>; + ti,autoidle-shift = <8>; + reg = <0x0190>; + ti,index-starts-at-one; + ti,invert-autoidle-bit; + }; + + ducati_clk_mux_ck: ducati_clk_mux_ck@100 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&div_core_ck>, <&dpll_per_m6x2_ck>; + reg = <0x0100>; + }; + + func_12m_fclk: func_12m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + func_24m_clk: func_24m_clk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_24mc_fclk: func_24mc_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + func_48m_fclk: func_48m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m2x2_ck>; + reg = <0x0108>; + ti,dividers = <4>, <8>; + }; + + func_48mc_fclk: func_48mc_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_64m_fclk: func_64m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m4x2_ck>; + reg = <0x0108>; + ti,dividers = <2>, <4>; + }; + + func_96m_fclk: func_96m_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m2x2_ck>; + reg = <0x0108>; + ti,dividers = <2>, <4>; + }; + + init_60m_fclk: init_60m_fclk@104 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_m2_ck>; + reg = <0x0104>; + ti,dividers = <1>, <8>; + }; + + per_abe_nc_fclk: per_abe_nc_fclk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_m2_ck>; + reg = <0x0108>; + ti,max-div = <2>; + }; + + sha2md5_fck: sha2md5_fck@15c8 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&l3_div_ck>; + ti,bit-shift = <1>; + reg = <0x15c8>; + }; + + usb_phy_cm_clk32k: usb_phy_cm_clk32k@640 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_32k_ck>; + ti,bit-shift = <8>; + reg = <0x0640>; + }; +}; + +&cm2_clockdomains { + l3_init_clkdm: l3_init_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll_usb_ck>; + }; +}; + +&scrm_clocks { + auxclk0_src_gate_ck: auxclk0_src_gate_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0310>; + }; + + auxclk0_src_mux_ck: auxclk0_src_mux_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0310>; + }; + + auxclk0_src_ck: auxclk0_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk0_src_gate_ck>, <&auxclk0_src_mux_ck>; + }; + + auxclk0_ck: auxclk0_ck@310 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk0_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0310>; + }; + + auxclk1_src_gate_ck: auxclk1_src_gate_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0314>; + }; + + auxclk1_src_mux_ck: auxclk1_src_mux_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0314>; + }; + + auxclk1_src_ck: auxclk1_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk1_src_gate_ck>, <&auxclk1_src_mux_ck>; + }; + + auxclk1_ck: auxclk1_ck@314 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk1_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0314>; + }; + + auxclk2_src_gate_ck: auxclk2_src_gate_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0318>; + }; + + auxclk2_src_mux_ck: auxclk2_src_mux_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0318>; + }; + + auxclk2_src_ck: auxclk2_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk2_src_gate_ck>, <&auxclk2_src_mux_ck>; + }; + + auxclk2_ck: auxclk2_ck@318 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk2_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0318>; + }; + + auxclk3_src_gate_ck: auxclk3_src_gate_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x031c>; + }; + + auxclk3_src_mux_ck: auxclk3_src_mux_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x031c>; + }; + + auxclk3_src_ck: auxclk3_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk3_src_gate_ck>, <&auxclk3_src_mux_ck>; + }; + + auxclk3_ck: auxclk3_ck@31c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk3_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x031c>; + }; + + auxclk4_src_gate_ck: auxclk4_src_gate_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0320>; + }; + + auxclk4_src_mux_ck: auxclk4_src_mux_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0320>; + }; + + auxclk4_src_ck: auxclk4_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk4_src_gate_ck>, <&auxclk4_src_mux_ck>; + }; + + auxclk4_ck: auxclk4_ck@320 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk4_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0320>; + }; + + auxclk5_src_gate_ck: auxclk5_src_gate_ck@324 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0324>; + }; + + auxclk5_src_mux_ck: auxclk5_src_mux_ck@324 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin_ck>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0324>; + }; + + auxclk5_src_ck: auxclk5_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk5_src_gate_ck>, <&auxclk5_src_mux_ck>; + }; + + auxclk5_ck: auxclk5_ck@324 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk5_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0324>; + }; + + auxclkreq0_ck: auxclkreq0_ck@210 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0210>; + }; + + auxclkreq1_ck: auxclkreq1_ck@214 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0214>; + }; + + auxclkreq2_ck: auxclkreq2_ck@218 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0218>; + }; + + auxclkreq3_ck: auxclkreq3_ck@21c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x021c>; + }; + + auxclkreq4_ck: auxclkreq4_ck@220 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0220>; + }; + + auxclkreq5_ck: auxclkreq5_ck@224 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>, <&auxclk5_ck>; + ti,bit-shift = <2>; + reg = <0x0224>; + }; +}; + +&cm1 { + mpuss_cm: mpuss_cm@300 { + compatible = "ti,omap4-cm"; + reg = <0x300 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x300 0x100>; + + mpuss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + tesla_cm: tesla_cm@400 { + compatible = "ti,omap4-cm"; + reg = <0x400 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x400 0x100>; + + tesla_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + abe_cm: abe_cm@500 { + compatible = "ti,omap4-cm"; + reg = <0x500 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x500 0x100>; + + abe_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x6c>; + #clock-cells = <2>; + }; + }; + +}; + +&cm2 { + l4_ao_cm: l4_ao_cm@600 { + compatible = "ti,omap4-cm"; + reg = <0x600 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x600 0x100>; + + l4_ao_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x1c>; + #clock-cells = <2>; + }; + }; + + l3_1_cm: l3_1_cm@700 { + compatible = "ti,omap4-cm"; + reg = <0x700 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x700 0x100>; + + l3_1_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_2_cm: l3_2_cm@800 { + compatible = "ti,omap4-cm"; + reg = <0x800 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x800 0x100>; + + l3_2_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x14>; + #clock-cells = <2>; + }; + }; + + ducati_cm: ducati_cm@900 { + compatible = "ti,omap4-cm"; + reg = <0x900 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x900 0x100>; + + ducati_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_dma_cm: l3_dma_cm@a00 { + compatible = "ti,omap4-cm"; + reg = <0xa00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xa00 0x100>; + + l3_dma_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_emif_cm: l3_emif_cm@b00 { + compatible = "ti,omap4-cm"; + reg = <0xb00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xb00 0x100>; + + l3_emif_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x1c>; + #clock-cells = <2>; + }; + }; + + d2d_cm: d2d_cm@c00 { + compatible = "ti,omap4-cm"; + reg = <0xc00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xc00 0x100>; + + d2d_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l4_cfg_cm: l4_cfg_cm@d00 { + compatible = "ti,omap4-cm"; + reg = <0xd00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xd00 0x100>; + + l4_cfg_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x14>; + #clock-cells = <2>; + }; + }; + + l3_instr_cm: l3_instr_cm@e00 { + compatible = "ti,omap4-cm"; + reg = <0xe00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xe00 0x100>; + + l3_instr_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x24>; + #clock-cells = <2>; + }; + }; + + ivahd_cm: ivahd_cm@f00 { + compatible = "ti,omap4-cm"; + reg = <0xf00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xf00 0x100>; + + ivahd_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc>; + #clock-cells = <2>; + }; + }; + + iss_cm: iss_cm@1000 { + compatible = "ti,omap4-cm"; + reg = <0x1000 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x100>; + + iss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc>; + #clock-cells = <2>; + }; + }; + + l3_dss_cm: l3_dss_cm@1100 { + compatible = "ti,omap4-cm"; + reg = <0x1100 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1100 0x100>; + + l3_dss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_gfx_cm: l3_gfx_cm@1200 { + compatible = "ti,omap4-cm"; + reg = <0x1200 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1200 0x100>; + + l3_gfx_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3_init_cm: l3_init_cm@1300 { + compatible = "ti,omap4-cm"; + reg = <0x1300 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1300 0x100>; + + l3_init_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc4>; + #clock-cells = <2>; + }; + }; + + l4_per_cm: l4_per_cm@1400 { + compatible = "ti,omap4-cm"; + reg = <0x1400 0x200>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1400 0x200>; + + l4_per_clkctrl: clock@20 { + compatible = "ti,clkctrl-l4-per", "ti,clkctrl"; + reg = <0x20 0x144>; + #clock-cells = <2>; + }; + + l4_secure_clkctrl: clock@1a0 { + compatible = "ti,clkctrl-l4-secure", "ti,clkctrl"; + reg = <0x1a0 0x3c>; + #clock-cells = <2>; + }; + }; +}; + +&prm { + l4_wkup_cm: l4_wkup_cm@1800 { + compatible = "ti,omap4-cm"; + reg = <0x1800 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1800 0x100>; + + l4_wkup_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x5c>; + #clock-cells = <2>; + }; + }; + + emu_sys_cm: emu_sys_cm@1a00 { + compatible = "ti,omap4-cm"; + reg = <0x1a00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1a00 0x100>; + + emu_sys_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; +}; diff --git a/arch/arm/dts/twl6030.dtsi b/arch/arm/dts/twl6030.dtsi new file mode 100644 index 0000000000..9d588cfaa5 --- /dev/null +++ b/arch/arm/dts/twl6030.dtsi @@ -0,0 +1,105 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ + +/* + * Integrated Power Management Chip + * http://www.ti.com/lit/ds/symlink/twl6030.pdf + */ +&twl { + compatible = "ti,twl6030"; + interrupt-controller; + #interrupt-cells = <1>; + + rtc { + compatible = "ti,twl4030-rtc"; + interrupts = <11>; + }; + + vaux1: regulator-vaux1 { + compatible = "ti,twl6030-vaux1"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + }; + + vaux2: regulator-vaux2 { + compatible = "ti,twl6030-vaux2"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <2800000>; + }; + + vaux3: regulator-vaux3 { + compatible = "ti,twl6030-vaux3"; + regulator-min-microvolt = <1000000>; + regulator-max-microvolt = <3000000>; + }; + + vmmc: regulator-vmmc { + compatible = "ti,twl6030-vmmc"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <3000000>; + }; + + vpp: regulator-vpp { + compatible = "ti,twl6030-vpp"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <2500000>; + }; + + vusim: regulator-vusim { + compatible = "ti,twl6030-vusim"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <2900000>; + }; + + vdac: regulator-vdac { + compatible = "ti,twl6030-vdac"; + }; + + vana: regulator-vana { + compatible = "ti,twl6030-vana"; + }; + + vcxio: regulator-vcxio { + compatible = "ti,twl6030-vcxio"; + regulator-always-on; + }; + + vusb: regulator-vusb { + compatible = "ti,twl6030-vusb"; + }; + + v1v8: regulator-v1v8 { + compatible = "ti,twl6030-v1v8"; + regulator-always-on; + }; + + v2v1: regulator-v2v1 { + compatible = "ti,twl6030-v2v1"; + regulator-always-on; + }; + + twl_usb_comparator: usb-comparator { + compatible = "ti,twl6030-usb"; + interrupts = <4>, <10>; + }; + + twl_pwm: pwm { + /* provides two PWMs (id 0, 1 for PWM1 and PWM2) */ + compatible = "ti,twl6030-pwm"; + #pwm-cells = <2>; + }; + + twl_pwmled: pwmled { + /* provides one PWM (id 0 for Charging indicator LED) */ + compatible = "ti,twl6030-pwmled"; + #pwm-cells = <2>; + }; + + gpadc { + compatible = "ti,twl6030-gpadc"; + interrupts = <3>; + #io-channel-cells = <1>; + }; +}; diff --git a/arch/arm/dts/twl6030_omap4.dtsi b/arch/arm/dts/twl6030_omap4.dtsi new file mode 100644 index 0000000000..fc498d0bde --- /dev/null +++ b/arch/arm/dts/twl6030_omap4.dtsi @@ -0,0 +1,35 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + */ + +&twl { + /* + * On most OMAP4 platforms, the twl6030 IRQ line is connected + * to the SYS_NIRQ1 line on OMAP and the twl6030 MSECURE line is + * connected to the fref_clk0_out.sys_drm_msecure line. + * Therefore, configure the defaults for the SYS_NIRQ1 and + * fref_clk0_out.sys_drm_msecure pins here. + */ + pinctrl-names = "default"; + pinctrl-0 = < + &twl6030_pins + &twl6030_wkup_pins + >; +}; + +&omap4_pmx_wkup { + twl6030_wkup_pins: pinmux_twl6030_wkup_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x054, PIN_OUTPUT | MUX_MODE2) /* fref_clk0_out.sys_drm_msecure */ + >; + }; +}; + +&omap4_pmx_core { + twl6030_pins: pinmux_twl6030_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x19e, WAKEUP_EN | PIN_INPUT_PULLUP | MUX_MODE0) /* sys_nirq1.sys_nirq1 */ + >; + }; +}; diff --git a/include/dt-bindings/clock/omap4.h b/include/dt-bindings/clock/omap4.h new file mode 100644 index 0000000000..88d73be84b --- /dev/null +++ b/include/dt-bindings/clock/omap4.h @@ -0,0 +1,149 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2017 Texas Instruments, Inc. + */ +#ifndef __DT_BINDINGS_CLK_OMAP4_H +#define __DT_BINDINGS_CLK_OMAP4_H + +#define OMAP4_CLKCTRL_OFFSET 0x20 +#define OMAP4_CLKCTRL_INDEX(offset) ((offset) - OMAP4_CLKCTRL_OFFSET) + +/* mpuss clocks */ +#define OMAP4_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* tesla clocks */ +#define OMAP4_DSP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* abe clocks */ +#define OMAP4_L4_ABE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_AESS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MCPDM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_DMIC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_MCASP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_MCBSP1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) +#define OMAP4_MCBSP2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_MCBSP3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_SLIMBUS1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_TIMER5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_TIMER6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) +#define OMAP4_TIMER7_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) +#define OMAP4_TIMER8_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) +#define OMAP4_WD_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) + +/* l4_ao clocks */ +#define OMAP4_SMARTREFLEX_MPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_SMARTREFLEX_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_SMARTREFLEX_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) + +/* l3_1 clocks */ +#define OMAP4_L3_MAIN_1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_2 clocks */ +#define OMAP4_L3_MAIN_2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_GPMC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_OCMC_RAM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) + +/* ducati clocks */ +#define OMAP4_IPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_dma clocks */ +#define OMAP4_DMA_SYSTEM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_emif clocks */ +#define OMAP4_DMM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_EMIF1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_EMIF2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) + +/* d2d clocks */ +#define OMAP4_C2C_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l4_cfg clocks */ +#define OMAP4_L4_CFG_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_SPINLOCK_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MAILBOX_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) + +/* l3_instr clocks */ +#define OMAP4_L3_MAIN_3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_L3_INSTR_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_OCP_WP_NOC_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) + +/* ivahd clocks */ +#define OMAP4_IVA_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_SL2IF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) + +/* iss clocks */ +#define OMAP4_ISS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_FDIF_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) + +/* l3_dss clocks */ +#define OMAP4_DSS_CORE_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_gfx clocks */ +#define OMAP4_GPU_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +/* l3_init clocks */ +#define OMAP4_MMC1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_MMC2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_HSI_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_USB_HOST_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_USB_OTG_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_USB_TLL_HS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_USB_HOST_FS_CLKCTRL OMAP4_CLKCTRL_INDEX(0xd0) +#define OMAP4_OCP2SCP_USB_PHY_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) + +/* l4_per clocks */ +#define OMAP4_TIMER10_CLKCTRL OMAP4_CLKCTRL_INDEX(0x28) +#define OMAP4_TIMER11_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_TIMER3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_TIMER4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x48) +#define OMAP4_TIMER9_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_ELM_CLKCTRL OMAP4_CLKCTRL_INDEX(0x58) +#define OMAP4_GPIO2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x60) +#define OMAP4_GPIO3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x68) +#define OMAP4_GPIO4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x70) +#define OMAP4_GPIO5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) +#define OMAP4_GPIO6_CLKCTRL OMAP4_CLKCTRL_INDEX(0x80) +#define OMAP4_HDQ1W_CLKCTRL OMAP4_CLKCTRL_INDEX(0x88) +#define OMAP4_I2C1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa0) +#define OMAP4_I2C2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xa8) +#define OMAP4_I2C3_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb0) +#define OMAP4_I2C4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xb8) +#define OMAP4_L4_PER_CLKCTRL OMAP4_CLKCTRL_INDEX(0xc0) +#define OMAP4_MCBSP4_CLKCTRL OMAP4_CLKCTRL_INDEX(0xe0) +#define OMAP4_MCSPI1_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf0) +#define OMAP4_MCSPI2_CLKCTRL OMAP4_CLKCTRL_INDEX(0xf8) +#define OMAP4_MCSPI3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x100) +#define OMAP4_MCSPI4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x108) +#define OMAP4_MMC3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x120) +#define OMAP4_MMC4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x128) +#define OMAP4_SLIMBUS2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x138) +#define OMAP4_UART1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x140) +#define OMAP4_UART2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x148) +#define OMAP4_UART3_CLKCTRL OMAP4_CLKCTRL_INDEX(0x150) +#define OMAP4_UART4_CLKCTRL OMAP4_CLKCTRL_INDEX(0x158) +#define OMAP4_MMC5_CLKCTRL OMAP4_CLKCTRL_INDEX(0x160) + +/* l4_secure clocks */ +#define OMAP4_L4_SECURE_CLKCTRL_OFFSET 0x1a0 +#define OMAP4_L4_SECURE_CLKCTRL_INDEX(offset) ((offset) - OMAP4_L4_SECURE_CLKCTRL_OFFSET) +#define OMAP4_AES1_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a0) +#define OMAP4_AES2_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1a8) +#define OMAP4_DES3DES_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b0) +#define OMAP4_PKA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1b8) +#define OMAP4_RNG_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c0) +#define OMAP4_SHA2MD5_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1c8) +#define OMAP4_CRYPTODMA_CLKCTRL OMAP4_L4_SECURE_CLKCTRL_INDEX(0x1d8) + +/* l4_wkup clocks */ +#define OMAP4_L4_WKUP_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) +#define OMAP4_WD_TIMER2_CLKCTRL OMAP4_CLKCTRL_INDEX(0x30) +#define OMAP4_GPIO1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x38) +#define OMAP4_TIMER1_CLKCTRL OMAP4_CLKCTRL_INDEX(0x40) +#define OMAP4_COUNTER_32K_CLKCTRL OMAP4_CLKCTRL_INDEX(0x50) +#define OMAP4_KBD_CLKCTRL OMAP4_CLKCTRL_INDEX(0x78) + +/* emu_sys clocks */ +#define OMAP4_DEBUGSS_CLKCTRL OMAP4_CLKCTRL_INDEX(0x20) + +#endif
Convert omap4 panda to device model.
Signed-off-by: Tero Kristo t-kristo@ti.com --- v3: * dropped SPI support v2: * dropped some apparently dead USB EHCI init code, this was just causing a compile time warning.
arch/arm/dts/Makefile | 4 +++ arch/arm/dts/omap4-u-boot.dtsi | 39 ++++++++++++++++++++++++++ board/ti/panda/panda.c | 50 ++++++++-------------------------- configs/omap4_panda_defconfig | 12 ++++++-- 4 files changed, 64 insertions(+), 41 deletions(-) create mode 100644 arch/arm/dts/omap4-u-boot.dtsi
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 12ec6c71dc..dd574f57fa 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -848,6 +848,10 @@ dtb-$(CONFIG_TARGET_OMAP3_BEAGLE) += \ dtb-$(CONFIG_TARGET_OMAP3_IGEP00X0) += \ omap3-igep0020.dtb
+dtb-$(CONFIG_TARGET_OMAP4_PANDA) += \ + omap4-panda.dtb \ + omap4-panda-es.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_PTC_EK) += \ at91-sama5d2_ptc_ek.dtb
diff --git a/arch/arm/dts/omap4-u-boot.dtsi b/arch/arm/dts/omap4-u-boot.dtsi new file mode 100644 index 0000000000..4a6bafd6ed --- /dev/null +++ b/arch/arm/dts/omap4-u-boot.dtsi @@ -0,0 +1,39 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * U-Boot additions + * + * (C) Copyright 2020 Tero Kristo t-kristo@ti.com + */ + +&l4_cfg { + segment@0 { + /* SCM Core */ + target-module@2000 { + compatible = "simple-bus"; + }; + + /* USB HS */ + target-module@64000 { + compatible = "simple-bus"; + }; + }; +}; + +&l4_per { + segment@0 { + /* UART3 */ + target-module@20000 { + compatible = "simple-bus"; + }; + + /* I2C1 */ + target-module@70000 { + compatible = "simple-bus"; + }; + + /* MMC1 */ + target-module@9c000 { + compatible = "simple-bus"; + }; + }; +}; diff --git a/board/ti/panda/panda.c b/board/ti/panda/panda.c index 9ebecfdbf5..232d999a29 100644 --- a/board/ti/panda/panda.c +++ b/board/ti/panda/panda.c @@ -8,6 +8,7 @@ #include <init.h> #include <log.h> #include <net.h> +#include <serial.h> #include <asm/mach-types.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> @@ -19,12 +20,6 @@
#include "panda_mux_data.h"
-#ifdef CONFIG_USB_EHCI_HCD -#include <usb.h> -#include <asm/arch/ehci.h> -#include <asm/ehci-omap.h> -#endif - #define PANDA_ULPI_PHY_TYPE_GPIO 182 #define PANDA_BOARD_ID_1_GPIO 101 #define PANDA_ES_BOARD_ID_1_GPIO 48 @@ -55,6 +50,17 @@ int board_init(void) return 0; }
+#if defined(CONFIG_SPL_OS_BOOT) +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + return 0; +} +#endif /* CONFIG_SPL_OS_BOOT */ + int board_eth_init(bd_t *bis) { return 0; @@ -305,38 +311,6 @@ void board_mmc_power_init(void) #endif #endif
-#ifdef CONFIG_USB_EHCI_HCD - -static struct omap_usbhs_board_data usbhs_bdata = { - .port_mode[0] = OMAP_EHCI_PORT_MODE_PHY, - .port_mode[1] = OMAP_USBHS_PORT_MODE_UNUSED, - .port_mode[2] = OMAP_USBHS_PORT_MODE_UNUSED, -}; - -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - int ret; - unsigned int utmi_clk; - - /* Now we can enable our port clocks */ - utmi_clk = readl((void *)CM_L3INIT_HSUSBHOST_CLKCTRL); - utmi_clk |= HSUSBHOST_CLKCTRL_CLKSEL_UTMI_P1_MASK; - setbits_le32((void *)CM_L3INIT_HSUSBHOST_CLKCTRL, utmi_clk); - - ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); - if (ret < 0) - return ret; - - return 0; -} - -int ehci_hcd_stop(int index) -{ - return omap_ehci_hcd_stop(); -} -#endif - /* * get_board_rev() - get board revision */ diff --git a/configs/omap4_panda_defconfig b/configs/omap4_panda_defconfig index 3ac6319d2d..f8d37f4728 100644 --- a/configs/omap4_panda_defconfig +++ b/configs/omap4_panda_defconfig @@ -2,12 +2,14 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_PANDA=y +CONFIG_DEFAULT_DEVICE_TREE="omap4-panda" CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DEFAULT_FDT_FILE="omap4-panda.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_SPL_FS_EXT4 is not set # CONFIG_SPL_I2C_SUPPORT is not set @@ -18,21 +20,23 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_FAT=y CONFIG_ENV_FAT_DEVICE_AND_PART="0:1" CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y +# CONFIG_SPI is not set CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y @@ -40,3 +44,5 @@ CONFIG_USB_GADGET=y CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_OF_LIBFDT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_DM_ETH=y
Copy all device tree files required for omap4 sdp4430 support from mainline Linux.
Signed-off-by: Peter Ujfalusi peter.ujfalusi@ti.com Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/omap4-sdp-es23plus.dts | 14 + arch/arm/dts/omap4-sdp.dts | 713 ++++++++++++++++++++++++++++ 2 files changed, 727 insertions(+) create mode 100644 arch/arm/dts/omap4-sdp-es23plus.dts create mode 100644 arch/arm/dts/omap4-sdp.dts
diff --git a/arch/arm/dts/omap4-sdp-es23plus.dts b/arch/arm/dts/omap4-sdp-es23plus.dts new file mode 100644 index 0000000000..42154520d3 --- /dev/null +++ b/arch/arm/dts/omap4-sdp-es23plus.dts @@ -0,0 +1,14 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "omap4-sdp.dts" + +/* SDP boards with 4430 ES2.3+ or 4460 have external pullups on SCL & SDA */ +&dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; +}; diff --git a/arch/arm/dts/omap4-sdp.dts b/arch/arm/dts/omap4-sdp.dts new file mode 100644 index 0000000000..91480ac1f3 --- /dev/null +++ b/arch/arm/dts/omap4-sdp.dts @@ -0,0 +1,713 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap443x.dtsi" +#include "elpida_ecb240abacn.dtsi" +#include "omap4-mcpdm.dtsi" + +/ { + model = "TI OMAP4 SDP board"; + compatible = "ti,omap4-sdp", "ti,omap4430", "ti,omap4"; + + memory@80000000 { + device_type = "memory"; + reg = <0x80000000 0x40000000>; /* 1 GB */ + }; + + aliases { + display0 = &lcd0; + display1 = &lcd1; + display2 = &hdmi0; + }; + + vdd_eth: fixedregulator-vdd-eth { + pinctrl-names = "default"; + pinctrl-0 = <&enet_enable_gpio>; + + compatible = "regulator-fixed"; + regulator-name = "VDD_ETH"; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + gpio = <&gpio2 16 GPIO_ACTIVE_HIGH>; /* gpio line 48 */ + enable-active-high; + regulator-boot-on; + startup-delay-us = <25000>; + }; + + vbat: fixedregulator-vbat { + compatible = "regulator-fixed"; + regulator-name = "VBAT"; + regulator-min-microvolt = <3750000>; + regulator-max-microvolt = <3750000>; + regulator-boot-on; + }; + + leds { + compatible = "gpio-leds"; + debug0 { + label = "omap4:green:debug0"; + gpios = <&gpio2 29 GPIO_ACTIVE_HIGH>; /* 61 */ + }; + + debug1 { + label = "omap4:green:debug1"; + gpios = <&gpio1 30 GPIO_ACTIVE_HIGH>; /* 30 */ + }; + + debug2 { + label = "omap4:green:debug2"; + gpios = <&gpio1 7 GPIO_ACTIVE_HIGH>; /* 7 */ + }; + + debug3 { + label = "omap4:green:debug3"; + gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; /* 8 */ + }; + + debug4 { + label = "omap4:green:debug4"; + gpios = <&gpio2 18 GPIO_ACTIVE_HIGH>; /* 50 */ + }; + + user1 { + label = "omap4:blue:user"; + gpios = <&gpio6 9 GPIO_ACTIVE_HIGH>; /* 169 */ + }; + + user2 { + label = "omap4:red:user"; + gpios = <&gpio6 10 GPIO_ACTIVE_HIGH>; /* 170 */ + }; + + user3 { + label = "omap4:green:user"; + gpios = <&gpio5 11 GPIO_ACTIVE_HIGH>; /* 139 */ + }; + }; + + pwmleds { + compatible = "pwm-leds"; + kpad { + label = "omap4::keypad"; + pwms = <&twl_pwm 0 7812500>; + max-brightness = <127>; + }; + + charging { + label = "omap4:green:chrg"; + pwms = <&twl_pwmled 0 7812500>; + max-brightness = <255>; + }; + }; + + backlight { + compatible = "pwm-backlight"; + pwms = <&twl_pwm 1 7812500>; + brightness-levels = < + 0 10 20 30 40 + 50 60 70 80 90 + 100 110 120 127 + >; + default-brightness-level = <13>; + }; + + sound { + compatible = "ti,abe-twl6040"; + ti,model = "SDP4430"; + + ti,jack-detection = <1>; + ti,mclk-freq = <38400000>; + + ti,mcpdm = <&mcpdm>; + ti,dmic = <&dmic>; + + ti,twl6040 = <&twl6040>; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Earphone Spk", "EP", + "Ext Spk", "HFL", + "Ext Spk", "HFR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "Vibrator", "VIBRAL", + "Vibrator", "VIBRAR", + "HSMIC", "Headset Mic", + "Headset Mic", "Headset Mic Bias", + "MAINMIC", "Main Handset Mic", + "Main Handset Mic", "Main Mic Bias", + "SUBMIC", "Sub Handset Mic", + "Sub Handset Mic", "Main Mic Bias", + "AFML", "Line In", + "AFMR", "Line In", + "DMic", "Digital Mic", + "Digital Mic", "Digital Mic1 Bias"; + }; + + /* regulator for wl12xx on sdio5 */ + wl12xx_vmmc: wl12xx_vmmc { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_gpio>; + compatible = "regulator-fixed"; + regulator-name = "vwl1271"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio2 22 GPIO_ACTIVE_HIGH>; + startup-delay-us = <70000>; + enable-active-high; + }; + + tpd12s015: encoder { + compatible = "ti,tpd12s015"; + + gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>, /* 60, CT CP HPD */ + <&gpio2 9 GPIO_ACTIVE_HIGH>, /* 41, LS OE */ + <&gpio2 31 GPIO_ACTIVE_HIGH>; /* 63, HPD */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tpd12s015_in: endpoint { + remote-endpoint = <&hdmi_out>; + }; + }; + + port@1 { + reg = <1>; + + tpd12s015_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; + + hdmi0: connector { + compatible = "hdmi-connector"; + label = "hdmi"; + + type = "c"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tpd12s015_out>; + }; + }; + }; +}; + +&omap4_pmx_core { + pinctrl-names = "default"; + pinctrl-0 = < + &dss_hdmi_pins + &tpd12s015_pins + >; + + uart2_pins: pinmux_uart2_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x118, PIN_INPUT_PULLUP | MUX_MODE0) /* uart2_cts.uart2_cts */ + OMAP4_IOPAD(0x11a, PIN_OUTPUT | MUX_MODE0) /* uart2_rts.uart2_rts */ + OMAP4_IOPAD(0x11c, PIN_INPUT_PULLUP | MUX_MODE0) /* uart2_rx.uart2_rx */ + OMAP4_IOPAD(0x11e, PIN_OUTPUT | MUX_MODE0) /* uart2_tx.uart2_tx */ + >; + }; + + uart3_pins: pinmux_uart3_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x140, PIN_INPUT_PULLUP | MUX_MODE0) /* uart3_cts_rctx.uart3_cts_rctx */ + OMAP4_IOPAD(0x142, PIN_OUTPUT | MUX_MODE0) /* uart3_rts_sd.uart3_rts_sd */ + OMAP4_IOPAD(0x144, PIN_INPUT | MUX_MODE0) /* uart3_rx_irrx.uart3_rx_irrx */ + OMAP4_IOPAD(0x146, PIN_OUTPUT | MUX_MODE0) /* uart3_tx_irtx.uart3_tx_irtx */ + >; + }; + + uart4_pins: pinmux_uart4_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x15c, PIN_INPUT | MUX_MODE0) /* uart4_rx.uart4_rx */ + OMAP4_IOPAD(0x15e, PIN_OUTPUT | MUX_MODE0) /* uart4_tx.uart4_tx */ + >; + }; + + twl6040_pins: pinmux_twl6040_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x120, PIN_OUTPUT | MUX_MODE3) /* hdq_sio.gpio_127 */ + OMAP4_IOPAD(0x1a0, PIN_INPUT | MUX_MODE0) /* sys_nirq2.sys_nirq2 */ + >; + }; + + dmic_pins: pinmux_dmic_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x110, PIN_OUTPUT | MUX_MODE0) /* abe_dmic_clk1.abe_dmic_clk1 */ + OMAP4_IOPAD(0x112, PIN_INPUT | MUX_MODE0) /* abe_dmic_din1.abe_dmic_din1 */ + OMAP4_IOPAD(0x114, PIN_INPUT | MUX_MODE0) /* abe_dmic_din2.abe_dmic_din2 */ + OMAP4_IOPAD(0x116, PIN_INPUT | MUX_MODE0) /* abe_dmic_din3.abe_dmic_din3 */ + >; + }; + + mcbsp1_pins: pinmux_mcbsp1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0fe, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_clkx.abe_mcbsp1_clkx */ + OMAP4_IOPAD(0x100, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dr.abe_mcbsp1_dr */ + OMAP4_IOPAD(0x102, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp1_dx.abe_mcbsp1_dx */ + OMAP4_IOPAD(0x104, PIN_INPUT | MUX_MODE0) /* abe_mcbsp1_fsx.abe_mcbsp1_fsx */ + >; + }; + + mcbsp2_pins: pinmux_mcbsp2_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x0f6, PIN_INPUT | MUX_MODE0) /* abe_mcbsp2_clkx.abe_mcbsp2_clkx */ + OMAP4_IOPAD(0x0f8, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp2_dr.abe_mcbsp2_dr */ + OMAP4_IOPAD(0x0fa, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* abe_mcbsp2_dx.abe_mcbsp2_dx */ + OMAP4_IOPAD(0x0fc, PIN_INPUT | MUX_MODE0) /* abe_mcbsp2_fsx.abe_mcbsp2_fsx */ + >; + }; + + mcspi1_pins: pinmux_mcspi1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x132, PIN_INPUT | MUX_MODE0) /* mcspi1_clk.mcspi1_clk */ + OMAP4_IOPAD(0x134, PIN_INPUT | MUX_MODE0) /* mcspi1_somi.mcspi1_somi */ + OMAP4_IOPAD(0x136, PIN_INPUT | MUX_MODE0) /* mcspi1_simo.mcspi1_simo */ + OMAP4_IOPAD(0x138, PIN_INPUT | MUX_MODE0) /* mcspi1_cs0.mcspi1_cs0 */ + >; + }; + + dss_hdmi_pins: pinmux_dss_hdmi_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x09a, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP4_IOPAD(0x09c, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_scl.hdmi_scl */ + OMAP4_IOPAD(0x09e, PIN_INPUT_PULLUP | MUX_MODE0) /* hdmi_sda.hdmi_sda */ + >; + }; + + tpd12s015_pins: pinmux_tpd12s015_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x062, PIN_OUTPUT | MUX_MODE3) /* gpmc_a17.gpio_41 */ + OMAP4_IOPAD(0x088, PIN_OUTPUT | MUX_MODE3) /* gpmc_nbe1.gpio_60 */ + OMAP4_IOPAD(0x098, PIN_INPUT_PULLDOWN | MUX_MODE3) /* hdmi_hpd.gpio_63 */ + >; + }; + + i2c1_pins: pinmux_i2c1_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x122, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl */ + OMAP4_IOPAD(0x124, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda */ + >; + }; + + i2c2_pins: pinmux_i2c2_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x126, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_scl */ + OMAP4_IOPAD(0x128, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c2_sda */ + >; + }; + + i2c3_pins: pinmux_i2c3_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12a, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_scl */ + OMAP4_IOPAD(0x12c, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c3_sda */ + >; + }; + + i2c4_pins: pinmux_i2c4_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x12e, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_scl */ + OMAP4_IOPAD(0x130, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c4_sda */ + >; + }; + + /* wl12xx GPIO output for WLAN_EN */ + wl12xx_gpio: pinmux_wl12xx_gpio { + pinctrl-single,pins = < + OMAP4_IOPAD(0x07c, PIN_OUTPUT | MUX_MODE3) /* gpmc_nwp.gpio_54 */ + >; + }; + + /* wl12xx GPIO inputs and SDIO pins */ + wl12xx_pins: pinmux_wl12xx_pins { + pinctrl-single,pins = < + OMAP4_IOPAD(0x07a, PIN_INPUT | MUX_MODE3) /* gpmc_ncs3.gpio_53 */ + OMAP4_IOPAD(0x148, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_clk.sdmmc5_clk */ + OMAP4_IOPAD(0x14a, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_cmd.sdmmc5_cmd */ + OMAP4_IOPAD(0x14c, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat0.sdmmc5_dat0 */ + OMAP4_IOPAD(0x14e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat1.sdmmc5_dat1 */ + OMAP4_IOPAD(0x150, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat2.sdmmc5_dat2 */ + OMAP4_IOPAD(0x152, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc5_dat3.sdmmc5_dat3 */ + >; + }; + + /* gpio_48 for ENET_ENABLE */ + enet_enable_gpio: pinmux_enet_enable_gpio { + pinctrl-single,pins = < + OMAP4_IOPAD(0x070, PIN_OUTPUT_PULLDOWN | MUX_MODE3) /* gpmc_a24.gpio_48 */ + >; + }; + + ks8851_pins: pinmux_ks8851_pins { + pinctrl-single,pins = < + /* ENET_INT */ + OMAP4_IOPAD(0x054, PIN_INPUT_PULLUP | MUX_MODE3) /* gpmc_ad10.gpio_34 */ + /* + * Misterious pin which makes the ethernet working + * The legacy board file requested this pin on boot + * (ETH_KS8851_QUART) and set it to high, similarly to + * the ENET_ENABLE pin. + * We could use gpio-hog to keep it high, but let's use + * it as a reset GPIO for ks8851. + */ + OMAP4_IOPAD(0x13a, PIN_OUTPUT_PULLUP | MUX_MODE3) /* mcspi1_cs1.gpio_138 */ + >; + }; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + + clock-frequency = <400000>; + + twl: twl@48 { + reg = <0x48>; + /* SPI = 0, IRQ# = 7, 4 = active high level-sensitive */ + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_1N cascaded to gic */ + }; + + twl6040: twl@4b { + compatible = "ti,twl6040"; + #clock-cells = <0>; + reg = <0x4b>; + + pinctrl-names = "default"; + pinctrl-0 = <&twl6040_pins>; + + /* SPI = 0, IRQ# = 119, 4 = active high level-sensitive */ + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; /* IRQ_SYS_2N cascaded to gic */ + ti,audpwron-gpio = <&gpio4 31 GPIO_ACTIVE_HIGH>; /* gpio line 127 */ + + vio-supply = <&v1v8>; + v2v1-supply = <&v2v1>; + enable-active-high; + + /* regulators for vibra motor */ + vddvibl-supply = <&vbat>; + vddvibr-supply = <&vbat>; + + vibra { + /* Vibra driver, motor resistance parameters */ + ti,vibldrv-res = <8>; + ti,vibrdrv-res = <3>; + ti,viblmotor-res = <10>; + ti,vibrmotor-res = <10>; + }; + }; +}; + +#include "twl6030.dtsi" +#include "twl6030_omap4.dtsi" + +&i2c2 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c2_pins>; + + clock-frequency = <400000>; +}; + +&i2c3 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c3_pins>; + + clock-frequency = <400000>; + + /* + * Temperature Sensor + * http://www.ti.com/lit/ds/symlink/tmp105.pdf + */ + tmp105@48 { + compatible = "ti,tmp105"; + reg = <0x48>; + }; + + /* + * Ambient Light Sensor + * http://www.rohm.com/products/databook/sensor/pdf/bh1780gli-e.pdf + */ + bh1780@29 { + compatible = "rohm,bh1780"; + reg = <0x29>; + }; +}; + +&i2c4 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c4_pins>; + + clock-frequency = <400000>; + + /* + * 3-Axis Digital Compass + * http://www.sparkfun.com/datasheets/Sensors/Magneto/HMC5843.pdf + */ + hmc5843@1e { + compatible = "honeywell,hmc5843"; + reg = <0x1e>; + }; +}; + +&mcspi1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcspi1_pins>; + + eth@0 { + pinctrl-names = "default"; + pinctrl-0 = <&ks8851_pins>; + + compatible = "ks8851"; + spi-max-frequency = <24000000>; + reg = <0>; + interrupt-parent = <&gpio2>; + interrupts = <2 IRQ_TYPE_LEVEL_LOW>; /* gpio line 34 */ + vdd-supply = <&vdd_eth>; + reset-gpios = <&gpio5 10 GPIO_ACTIVE_HIGH>; + }; +}; + +&mmc1 { + vmmc-supply = <&vmmc>; + bus-width = <8>; +}; + +&mmc2 { + vmmc-supply = <&vaux1>; + bus-width = <8>; + ti,non-removable; +}; + +&mmc3 { + status = "disabled"; +}; + +&mmc4 { + status = "disabled"; +}; + +&mmc5 { + pinctrl-names = "default"; + pinctrl-0 = <&wl12xx_pins>; + vmmc-supply = <&wl12xx_vmmc>; + non-removable; + bus-width = <4>; + cap-power-off-card; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1281"; + reg = <2>; + interrupt-parent = <&gpio1>; + interrupts = <21 IRQ_TYPE_LEVEL_HIGH>; /* gpio 53 */ + ref-clock-frequency = <26000000>; + tcxo-clock-frequency = <26000000>; + }; +}; + +&emif1 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&emif2 { + cs1-used; + device-handle = <&elpida_ECB240ABACN>; +}; + +&keypad { + keypad,num-rows = <8>; + keypad,num-columns = <8>; + linux,keymap = <0x00000012 /* KEY_E */ + 0x00010013 /* KEY_R */ + 0x00020014 /* KEY_T */ + 0x00030066 /* KEY_HOME */ + 0x0004003f /* KEY_F5 */ + 0x000500f0 /* KEY_UNKNOWN */ + 0x00060017 /* KEY_I */ + 0x0007002a /* KEY_LEFTSHIFT */ + 0x01000020 /* KEY_D*/ + 0x01010021 /* KEY_F */ + 0x01020022 /* KEY_G */ + 0x010300e7 /* KEY_SEND */ + 0x01040040 /* KEY_F6 */ + 0x010500f0 /* KEY_UNKNOWN */ + 0x01060025 /* KEY_K */ + 0x0107001c /* KEY_ENTER */ + 0x0200002d /* KEY_X */ + 0x0201002e /* KEY_C */ + 0x0202002f /* KEY_V */ + 0x0203006b /* KEY_END */ + 0x02040041 /* KEY_F7 */ + 0x020500f0 /* KEY_UNKNOWN */ + 0x02060034 /* KEY_DOT */ + 0x0207003a /* KEY_CAPSLOCK */ + 0x0300002c /* KEY_Z */ + 0x0301004e /* KEY_KPLUS */ + 0x03020030 /* KEY_B */ + 0x0303003b /* KEY_F1 */ + 0x03040042 /* KEY_F8 */ + 0x030500f0 /* KEY_UNKNOWN */ + 0x03060018 /* KEY_O */ + 0x03070039 /* KEY_SPACE */ + 0x04000011 /* KEY_W */ + 0x04010015 /* KEY_Y */ + 0x04020016 /* KEY_U */ + 0x0403003c /* KEY_F2 */ + 0x04040073 /* KEY_VOLUMEUP */ + 0x040500f0 /* KEY_UNKNOWN */ + 0x04060026 /* KEY_L */ + 0x04070069 /* KEY_LEFT */ + 0x0500001f /* KEY_S */ + 0x05010023 /* KEY_H */ + 0x05020024 /* KEY_J */ + 0x0503003d /* KEY_F3 */ + 0x05040043 /* KEY_F9 */ + 0x05050072 /* KEY_VOLUMEDOWN */ + 0x05060032 /* KEY_M */ + 0x0507006a /* KEY_RIGHT */ + 0x06000010 /* KEY_Q */ + 0x0601001e /* KEY_A */ + 0x06020031 /* KEY_N */ + 0x0603009e /* KEY_BACK */ + 0x0604000e /* KEY_BACKSPACE */ + 0x060500f0 /* KEY_UNKNOWN */ + 0x06060019 /* KEY_P */ + 0x06070067 /* KEY_UP */ + 0x07000094 /* KEY_PROG1 */ + 0x07010095 /* KEY_PROG2 */ + 0x070200ca /* KEY_PROG3 */ + 0x070300cb /* KEY_PROG4 */ + 0x0704003e /* KEY_F4 */ + 0x070500f0 /* KEY_UNKNOWN */ + 0x07060160 /* KEY_OK */ + 0x0707006c>; /* KEY_DOWN */ + linux,input-no-autorepeat; +}; + +&uart2 { + interrupts-extended = <&wakeupgen GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART2_RX>; + pinctrl-names = "default"; + pinctrl-0 = <&uart2_pins>; +}; + +&uart3 { + interrupts-extended = <&wakeupgen GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART3_RX>; + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; +}; + +&uart4 { + interrupts-extended = <&wakeupgen GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH + &omap4_pmx_core OMAP4_UART4_RX>; + pinctrl-names = "default"; + pinctrl-0 = <&uart4_pins>; +}; + +&mcbsp1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp1_pins>; + status = "okay"; +}; + +&mcbsp2 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp2_pins>; + status = "okay"; +}; + +&dmic { + pinctrl-names = "default"; + pinctrl-0 = <&dmic_pins>; + status = "okay"; +}; + +&twl_usb_comparator { + usb-supply = <&vusb>; +}; + +&usb_otg_hs { + interface-type = <1>; + mode = <3>; + power = <50>; +}; + +&dss { + status = "ok"; +}; + +&dsi1 { + status = "ok"; + vdd-supply = <&vcxio>; + + port { + dsi1_out_ep: endpoint { + remote-endpoint = <&lcd0_in>; + lanes = <0 1 2 3 4 5>; + }; + }; + + lcd0: display { + compatible = "tpo,taal", "panel-dsi-cm"; + label = "lcd0"; + + reset-gpios = <&gpio4 6 GPIO_ACTIVE_HIGH>; /* 102 */ + + port { + lcd0_in: endpoint { + remote-endpoint = <&dsi1_out_ep>; + }; + }; + }; +}; + +&dsi2 { + status = "ok"; + vdd-supply = <&vcxio>; + + port { + dsi2_out_ep: endpoint { + remote-endpoint = <&lcd1_in>; + lanes = <0 1 2 3 4 5>; + }; + }; + + lcd1: display { + compatible = "tpo,taal", "panel-dsi-cm"; + label = "lcd1"; + + reset-gpios = <&gpio4 8 GPIO_ACTIVE_HIGH>; /* 104 */ + + port { + lcd1_in: endpoint { + remote-endpoint = <&dsi2_out_ep>; + }; + }; + }; +}; + +&hdmi { + status = "ok"; + vdda-supply = <&vdac>; + + port { + hdmi_out: endpoint { + remote-endpoint = <&tpd12s015_in>; + }; + }; +};
Convert omap4 sdp to device model.
Signed-off-by: Peter Ujfalusi peter.ujfalusi@ti.com Signed-off-by: Tero Kristo t-kristo@ti.com --- v3: * dropped SPI support
arch/arm/dts/Makefile | 4 ++++ board/ti/sdp4430/sdp.c | 12 ++++++++++++ configs/omap4_sdp4430_defconfig | 12 +++++++++--- 3 files changed, 25 insertions(+), 3 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index dd574f57fa..70cf05f2b8 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -852,6 +852,10 @@ dtb-$(CONFIG_TARGET_OMAP4_PANDA) += \ omap4-panda.dtb \ omap4-panda-es.dtb
+dtb-$(CONFIG_TARGET_OMAP4_SDP4430) += \ + omap4-sdp.dtb \ + omap4-sdp-es23plus.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_PTC_EK) += \ at91-sama5d2_ptc_ek.dtb
diff --git a/board/ti/sdp4430/sdp.c b/board/ti/sdp4430/sdp.c index a5b3504045..5b294ea79b 100644 --- a/board/ti/sdp4430/sdp.c +++ b/board/ti/sdp4430/sdp.c @@ -9,6 +9,7 @@ #include <init.h> #include <net.h> #include <twl6030.h> +#include <serial.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h>
@@ -91,6 +92,17 @@ void board_mmc_power_init(void) #endif #endif
+#if defined(CONFIG_SPL_OS_BOOT) +int spl_start_uboot(void) +{ + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + + return 0; +} +#endif /* CONFIG_SPL_OS_BOOT */ + /* * get_board_rev() - get board revision */ diff --git a/configs/omap4_sdp4430_defconfig b/configs/omap4_sdp4430_defconfig index 219721388f..e9a8a90786 100644 --- a/configs/omap4_sdp4430_defconfig +++ b/configs/omap4_sdp4430_defconfig @@ -5,6 +5,7 @@ CONFIG_ARCH_OMAP2PLUS=y CONFIG_ENV_OFFSET=0xE0000 CONFIG_OMAP44XX=y CONFIG_TARGET_OMAP4_SDP4430=y +CONFIG_DEFAULT_DEVICE_TREE="omap4-sdp" CONFIG_CMD_BAT=y CONFIG_SPL=y CONFIG_SPL_TEXT_BASE=0x40300000 @@ -12,6 +13,7 @@ CONFIG_DISTRO_DEFAULTS=y CONFIG_BOOTCOMMAND="if test ${boot_fit} -eq 1; then run update_to_fit; fi; run findfdt; run init_console; run envboot; run distro_bootcmd" CONFIG_SYS_CONSOLE_IS_IN_ENV=y CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DEFAULT_FDT_FILE="omap4-sdp.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_SPL_I2C_SUPPORT is not set # CONFIG_SPL_NAND_SUPPORT is not set @@ -19,20 +21,22 @@ CONFIG_CMD_ASKENV=y CONFIG_CMD_GPIO=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y # CONFIG_CMD_SETEXPR is not set # CONFIG_CMD_NFS is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y # CONFIG_EFI_PARTITION is not set CONFIG_SPL_PARTITION_UUIDS=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_DM=y +CONFIG_DM_MMC=y CONFIG_MMC_OMAP_HS=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y +# CONFIG_SPI is not set CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_MUSB_UDC=y CONFIG_USB_OMAP3=y CONFIG_USB_GADGET=y @@ -40,3 +44,5 @@ CONFIG_FAT_WRITE=y # CONFIG_REGEX is not set CONFIG_OF_LIBFDT=y # CONFIG_EFI_LOADER is not set +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_DM_ETH=y
Copy all the device tree files required for omap5 uevm support from mainline Linux.
Signed-off-by: Tero Kristo t-kristo@ti.com --- arch/arm/dts/Makefile | 3 + arch/arm/dts/omap5-board-common.dtsi | 762 ++++++++ arch/arm/dts/omap5-l4-abe.dtsi | 450 +++++ arch/arm/dts/omap5-l4.dtsi | 2438 ++++++++++++++++++++++++++ arch/arm/dts/omap5-uevm.dts | 200 +++ arch/arm/dts/omap5.dtsi | 583 ++++++ arch/arm/dts/omap54xx-clocks.dtsi | 1208 +++++++++++++ include/dt-bindings/clock/omap5.h | 129 ++ 8 files changed, 5773 insertions(+) create mode 100644 arch/arm/dts/omap5-board-common.dtsi create mode 100644 arch/arm/dts/omap5-l4-abe.dtsi create mode 100644 arch/arm/dts/omap5-l4.dtsi create mode 100644 arch/arm/dts/omap5-uevm.dts create mode 100644 arch/arm/dts/omap5.dtsi create mode 100644 arch/arm/dts/omap54xx-clocks.dtsi create mode 100644 include/dt-bindings/clock/omap5.h
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 70cf05f2b8..196b72a5ad 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -856,6 +856,9 @@ dtb-$(CONFIG_TARGET_OMAP4_SDP4430) += \ omap4-sdp.dtb \ omap4-sdp-es23plus.dtb
+dtb-$(CONFIG_TARGET_OMAP5_UEVM) += \ + omap5-uevm.dtb + dtb-$(CONFIG_TARGET_SAMA5D2_PTC_EK) += \ at91-sama5d2_ptc_ek.dtb
diff --git a/arch/arm/dts/omap5-board-common.dtsi b/arch/arm/dts/omap5-board-common.dtsi new file mode 100644 index 0000000000..68ac04641b --- /dev/null +++ b/arch/arm/dts/omap5-board-common.dtsi @@ -0,0 +1,762 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + */ +#include "omap5.dtsi" +#include <dt-bindings/interrupt-controller/irq.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> + +/ { + aliases { + display0 = &hdmi0; + }; + + chosen { + stdout-path = &uart3; + }; + + vmain: fixedregulator-vmain { + compatible = "regulator-fixed"; + regulator-name = "vmain"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vsys_cobra: fixedregulator-vsys_cobra { + compatible = "regulator-fixed"; + regulator-name = "vsys_cobra"; + vin-supply = <&vmain>; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vdds_1v8_main: fixedregulator-vdds_1v8_main { + compatible = "regulator-fixed"; + regulator-name = "vdds_1v8_main"; + vin-supply = <&smps7_reg>; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + vmmcsd_fixed: fixedregulator-mmcsd { + compatible = "regulator-fixed"; + regulator-name = "vmmcsd_fixed"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + }; + + mmc3_pwrseq: sdhci0_pwrseq { + compatible = "mmc-pwrseq-simple"; + clocks = <&clk32kgaudio>; + clock-names = "ext_clock"; + }; + + vmmcsdio_fixed: fixedregulator-mmcsdio { + compatible = "regulator-fixed"; + regulator-name = "vmmcsdio_fixed"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + gpio = <&gpio5 12 GPIO_ACTIVE_HIGH>; /* gpio140 WLAN_EN */ + enable-active-high; + startup-delay-us = <70000>; + pinctrl-names = "default"; + pinctrl-0 = <&wlan_pins>; + }; + + /* HS USB Host PHY on PORT 2 */ + hsusb2_phy: hsusb2_phy { + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio3 16 GPIO_ACTIVE_LOW>; /* gpio3_80 HUB_NRESET */ + clocks = <&auxclk1_ck>; + clock-names = "main_clk"; + clock-frequency = <19200000>; + #phy-cells = <0>; + }; + + /* HS USB Host PHY on PORT 3 */ + hsusb3_phy: hsusb3_phy { + compatible = "usb-nop-xceiv"; + reset-gpios = <&gpio3 15 GPIO_ACTIVE_LOW>; /* gpio3_79 ETH_NRESET */ + #phy-cells = <0>; + }; + + tpd12s015: encoder { + compatible = "ti,tpd12s015"; + + pinctrl-names = "default"; + pinctrl-0 = <&tpd12s015_pins>; + + /* gpios defined in the board specific dts */ + + ports { + #address-cells = <1>; + #size-cells = <0>; + + port@0 { + reg = <0>; + + tpd12s015_in: endpoint { + remote-endpoint = <&hdmi_out>; + }; + }; + + port@1 { + reg = <1>; + + tpd12s015_out: endpoint { + remote-endpoint = <&hdmi_connector_in>; + }; + }; + }; + }; + + hdmi0: connector { + compatible = "hdmi-connector"; + label = "hdmi"; + + type = "b"; + + port { + hdmi_connector_in: endpoint { + remote-endpoint = <&tpd12s015_out>; + }; + }; + }; + + sound: sound { + compatible = "ti,abe-twl6040"; + ti,model = "omap5-uevm"; + + ti,jack-detection; + ti,mclk-freq = <19200000>; + + ti,mcpdm = <&mcpdm>; + + ti,twl6040 = <&twl6040>; + + /* Audio routing */ + ti,audio-routing = + "Headset Stereophone", "HSOL", + "Headset Stereophone", "HSOR", + "Line Out", "AUXL", + "Line Out", "AUXR", + "HSMIC", "Headset Mic", + "Headset Mic", "Headset Mic Bias", + "AFML", "Line In", + "AFMR", "Line In"; + }; +}; + +&gpio8 { + /* TI trees use GPIO instead of msecure, see also muxing */ + p234 { + gpio-hog; + gpios = <10 GPIO_ACTIVE_HIGH>; + output-high; + line-name = "gpio8_234/msecure"; + }; +}; + +&omap5_pmx_core { + pinctrl-names = "default"; + pinctrl-0 = < + &usbhost_pins + &led_gpio_pins + >; + + twl6040_pins: pinmux_twl6040_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1be, PIN_OUTPUT | MUX_MODE6) /* mcspi1_somi.gpio5_141 */ + >; + }; + + mcpdm_pins: pinmux_mcpdm_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x182, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abe_clks.abe_clks */ + OMAP5_IOPAD(0x19c, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abemcpdm_ul_data.abemcpdm_ul_data */ + OMAP5_IOPAD(0x19e, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abemcpdm_dl_data.abemcpdm_dl_data */ + OMAP5_IOPAD(0x1a0, PIN_INPUT_PULLUP | MUX_MODE0) /* abemcpdm_frame.abemcpdm_frame */ + OMAP5_IOPAD(0x1a2, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abemcpdm_lb_clk.abemcpdm_lb_clk */ + >; + }; + + mcbsp1_pins: pinmux_mcbsp1_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x18c, PIN_INPUT | MUX_MODE1) /* abedmic_clk2.abemcbsp1_fsx */ + OMAP5_IOPAD(0x18e, PIN_OUTPUT_PULLDOWN | MUX_MODE1) /* abedmic_clk3.abemcbsp1_dx */ + OMAP5_IOPAD(0x190, PIN_INPUT | MUX_MODE1) /* abeslimbus1_clock.abemcbsp1_clkx */ + OMAP5_IOPAD(0x192, PIN_INPUT_PULLDOWN | MUX_MODE1) /* abeslimbus1_data.abemcbsp1_dr */ + >; + }; + + mcbsp2_pins: pinmux_mcbsp2_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x194, PIN_INPUT_PULLDOWN | MUX_MODE0) /* abemcbsp2_dr.abemcbsp2_dr */ + OMAP5_IOPAD(0x196, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* abemcbsp2_dx.abemcbsp2_dx */ + OMAP5_IOPAD(0x198, PIN_INPUT | MUX_MODE0) /* abemcbsp2_fsx.abemcbsp2_fsx */ + OMAP5_IOPAD(0x19a, PIN_INPUT | MUX_MODE0) /* abemcbsp2_clkx.abemcbsp2_clkx */ + >; + }; + + i2c1_pins: pinmux_i2c1_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1f2, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_scl */ + OMAP5_IOPAD(0x1f4, PIN_INPUT_PULLUP | MUX_MODE0) /* i2c1_sda */ + >; + }; + + mcspi2_pins: pinmux_mcspi2_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x0fc, PIN_INPUT | MUX_MODE0) /* mcspi2_clk */ + OMAP5_IOPAD(0x0fe, PIN_INPUT | MUX_MODE0) /* mcspi2_simo */ + OMAP5_IOPAD(0x100, PIN_INPUT_PULLUP | MUX_MODE0) /* mcspi2_somi */ + OMAP5_IOPAD(0x102, PIN_OUTPUT | MUX_MODE0) /* mcspi2_cs0 */ + >; + }; + + mcspi3_pins: pinmux_mcspi3_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x0b8, PIN_INPUT | MUX_MODE1) /* mcspi3_somi */ + OMAP5_IOPAD(0x0ba, PIN_INPUT | MUX_MODE1) /* mcspi3_cs0 */ + OMAP5_IOPAD(0x0bc, PIN_INPUT | MUX_MODE1) /* mcspi3_simo */ + OMAP5_IOPAD(0x0be, PIN_INPUT | MUX_MODE1) /* mcspi3_clk */ + >; + }; + + mmc3_pins: pinmux_mmc3_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x01a4, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_clk */ + OMAP5_IOPAD(0x01a6, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_cmd */ + OMAP5_IOPAD(0x01a8, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_data0 */ + OMAP5_IOPAD(0x01aa, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_data1 */ + OMAP5_IOPAD(0x01ac, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_data2 */ + OMAP5_IOPAD(0x01ae, PIN_INPUT_PULLUP | MUX_MODE0) /* wlsdio_data3 */ + >; + }; + + wlan_pins: pinmux_wlan_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1bc, PIN_OUTPUT | MUX_MODE6) /* mcspi1_clk.gpio5_140 */ + >; + }; + + /* TI trees use GPIO mode; msecure mode does not work reliably? */ + palmas_msecure_pins: palmas_msecure_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x180, PIN_OUTPUT | MUX_MODE6) /* gpio8_234 */ + >; + }; + + usbhost_pins: pinmux_usbhost_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x0c4, PIN_INPUT | MUX_MODE0) /* usbb2_hsic_strobe */ + OMAP5_IOPAD(0x0c6, PIN_INPUT | MUX_MODE0) /* usbb2_hsic_data */ + + OMAP5_IOPAD(0x1de, PIN_INPUT | MUX_MODE0) /* usbb3_hsic_strobe */ + OMAP5_IOPAD(0x1e0, PIN_INPUT | MUX_MODE0) /* usbb3_hsic_data */ + + OMAP5_IOPAD(0x0b0, PIN_OUTPUT | MUX_MODE6) /* gpio3_80 HUB_NRESET */ + OMAP5_IOPAD(0x0ae, PIN_OUTPUT | MUX_MODE6) /* gpio3_79 ETH_NRESET */ + >; + }; + + led_gpio_pins: pinmux_led_gpio_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1d6, PIN_OUTPUT | MUX_MODE6) /* uart3_cts_rctx.gpio5_153 */ + >; + }; + + uart1_pins: pinmux_uart1_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x0a0, PIN_OUTPUT | MUX_MODE0) /* uart1_tx.uart1_cts */ + OMAP5_IOPAD(0x0a2, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_tx.uart1_cts */ + OMAP5_IOPAD(0x0a4, PIN_INPUT_PULLUP | MUX_MODE0) /* uart1_rx.uart1_rts */ + OMAP5_IOPAD(0x0a6, PIN_OUTPUT | MUX_MODE0) /* uart1_rx.uart1_rts */ + >; + }; + + uart3_pins: pinmux_uart3_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1da, PIN_OUTPUT | MUX_MODE0) /* uart3_rts_irsd.uart3_tx_irtx */ + OMAP5_IOPAD(0x1dc, PIN_INPUT_PULLUP | MUX_MODE0) /* uart3_rx_irrx.uart3_usbb3_hsic */ + >; + }; + + uart5_pins: pinmux_uart5_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1b0, PIN_INPUT_PULLUP | MUX_MODE0) /* uart5_rx.uart5_rx */ + OMAP5_IOPAD(0x1b2, PIN_OUTPUT | MUX_MODE0) /* uart5_tx.uart5_tx */ + OMAP5_IOPAD(0x1b4, PIN_INPUT_PULLUP | MUX_MODE0) /* uart5_cts.uart5_rts */ + OMAP5_IOPAD(0x1b6, PIN_OUTPUT | MUX_MODE0) /* uart5_cts.uart5_rts */ + >; + }; + + dss_hdmi_pins: pinmux_dss_hdmi_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x13c, PIN_INPUT | MUX_MODE0) /* hdmi_cec.hdmi_cec */ + OMAP5_IOPAD(0x140, PIN_INPUT | MUX_MODE0) /* hdmi_ddc_scl.hdmi_ddc_scl */ + OMAP5_IOPAD(0x142, PIN_INPUT | MUX_MODE0) /* hdmi_ddc_sda.hdmi_ddc_sda */ + >; + }; + + tpd12s015_pins: pinmux_tpd12s015_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x13e, PIN_INPUT_PULLDOWN | MUX_MODE6) /* hdmi_hpd.gpio7_193 */ + >; + }; +}; + +&omap5_pmx_wkup { + pinctrl-names = "default"; + pinctrl-0 = < + &usbhost_wkup_pins + >; + + palmas_sys_nirq_pins: pinmux_palmas_sys_nirq_pins { + pinctrl-single,pins = < + /* sys_nirq1 is pulled down as the SoC is inverting it for GIC */ + OMAP5_IOPAD(0x068, PIN_INPUT_PULLUP | MUX_MODE0) + >; + }; + + usbhost_wkup_pins: pinmux_usbhost_wkup_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x05a, PIN_OUTPUT | MUX_MODE0) /* fref_clk1_out, USB hub clk */ + >; + }; + + wlcore_irq_pin: pinmux_wlcore_irq_pin { + pinctrl-single,pins = < + OMAP5_IOPAD(0x40, PIN_INPUT | MUX_MODE6) /* llia_wakereqin.gpio1_wk14 */ + >; + }; +}; + +&mmc1 { + vmmc-supply = <&ldo9_reg>; + bus-width = <4>; +}; + +&mmc2 { + vmmc-supply = <&vmmcsd_fixed>; + bus-width = <8>; + ti,non-removable; +}; + +&mmc3 { + vmmc-supply = <&vmmcsdio_fixed>; + mmc-pwrseq = <&mmc3_pwrseq>; + bus-width = <4>; + non-removable; + cap-power-off-card; + pinctrl-names = "default"; + pinctrl-0 = <&mmc3_pins>; + interrupts-extended = <&wakeupgen GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH + &omap5_pmx_core 0x16a>; + + #address-cells = <1>; + #size-cells = <0>; + wlcore: wlcore@2 { + compatible = "ti,wl1271"; + reg = <2>; + pinctrl-names = "default"; + pinctrl-0 = <&wlcore_irq_pin>; + interrupt-parent = <&gpio1>; + interrupts = <14 IRQ_TYPE_LEVEL_HIGH>; /* gpio 14 */ + ref-clock-frequency = <26000000>; + }; +}; + +&mmc4 { + status = "disabled"; +}; + +&mmc5 { + status = "disabled"; +}; + +&i2c1 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c1_pins>; + + clock-frequency = <400000>; + + palmas: palmas@48 { + compatible = "ti,palmas"; + /* sys_nirq/ext_sys_irq pins get inverted at mpuss wakeupgen */ + interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_LOW>; + reg = <0x48>; + interrupt-controller; + #interrupt-cells = <2>; + ti,system-power-controller; + ti,mux-pad1 = <0xa1>; + ti,mux-pad2 = <0x1b>; + pinctrl-names = "default"; + pinctrl-0 = <&palmas_sys_nirq_pins &palmas_msecure_pins>; + + palmas_gpio: gpio { + compatible = "ti,palmas-gpio"; + gpio-controller; + #gpio-cells = <2>; + }; + + extcon_usb3: palmas_usb { + compatible = "ti,palmas-usb-vid"; + ti,enable-vbus-detection; + ti,enable-id-detection; + ti,wakeup; + id-gpios = <&palmas_gpio 0 GPIO_ACTIVE_HIGH>; + }; + + clk32kgaudio: palmas_clk32k@1 { + compatible = "ti,palmas-clk32kgaudio"; + #clock-cells = <0>; + }; + + rtc { + compatible = "ti,palmas-rtc"; + interrupt-parent = <&palmas>; + interrupts = <8 IRQ_TYPE_NONE>; + ti,backup-battery-chargeable; + ti,backup-battery-charge-high-current; + }; + + gpadc: gpadc { + compatible = "ti,palmas-gpadc"; + interrupts = <18 0 + 16 0 + 17 0>; + #io-channel-cells = <1>; + ti,channel0-current-microamp = <5>; + ti,channel3-current-microamp = <10>; + }; + + palmas_pmic { + compatible = "ti,palmas-pmic"; + interrupt-parent = <&palmas>; + interrupts = <14 IRQ_TYPE_NONE>; + interrupt-names = "short-irq"; + + ti,ldo6-vibrator; + + smps123-in-supply = <&vsys_cobra>; + smps45-in-supply = <&vsys_cobra>; + smps6-in-supply = <&vsys_cobra>; + smps7-in-supply = <&vsys_cobra>; + smps8-in-supply = <&vsys_cobra>; + smps9-in-supply = <&vsys_cobra>; + smps10_out2-in-supply = <&vsys_cobra>; + smps10_out1-in-supply = <&vsys_cobra>; + ldo1-in-supply = <&vsys_cobra>; + ldo2-in-supply = <&vsys_cobra>; + ldo3-in-supply = <&vdds_1v8_main>; + ldo4-in-supply = <&vdds_1v8_main>; + ldo5-in-supply = <&vsys_cobra>; + ldo6-in-supply = <&vdds_1v8_main>; + ldo7-in-supply = <&vsys_cobra>; + ldo8-in-supply = <&vsys_cobra>; + ldo9-in-supply = <&vmmcsd_fixed>; + ldoln-in-supply = <&vsys_cobra>; + ldousb-in-supply = <&vsys_cobra>; + + regulators { + smps123_reg: smps123 { + /* VDD_OPP_MPU */ + regulator-name = "smps123"; + regulator-min-microvolt = < 600000>; + regulator-max-microvolt = <1500000>; + regulator-always-on; + regulator-boot-on; + }; + + smps45_reg: smps45 { + /* VDD_OPP_MM */ + regulator-name = "smps45"; + regulator-min-microvolt = < 600000>; + regulator-max-microvolt = <1310000>; + regulator-always-on; + regulator-boot-on; + }; + + smps6_reg: smps6 { + /* VDD_DDR3 - over VDD_SMPS6 */ + regulator-name = "smps6"; + regulator-min-microvolt = <1350000>; + regulator-max-microvolt = <1350000>; + regulator-always-on; + regulator-boot-on; + }; + + smps7_reg: smps7 { + /* VDDS_1v8_OMAP over VDDS_1v8_MAIN */ + regulator-name = "smps7"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + smps8_reg: smps8 { + /* VDD_OPP_CORE */ + regulator-name = "smps8"; + regulator-min-microvolt = < 600000>; + regulator-max-microvolt = <1310000>; + regulator-always-on; + regulator-boot-on; + }; + + smps9_reg: smps9 { + /* VDDA_2v1_AUD over VDD_2v1 */ + regulator-name = "smps9"; + regulator-min-microvolt = <2100000>; + regulator-max-microvolt = <2100000>; + ti,smps-range = <0x80>; + }; + + smps10_out2_reg: smps10_out2 { + /* VBUS_5V_OTG */ + regulator-name = "smps10_out2"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + regulator-always-on; + regulator-boot-on; + }; + + smps10_out1_reg: smps10_out1 { + /* VBUS_5V_OTG */ + regulator-name = "smps10_out1"; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + ldo1_reg: ldo1 { + /* VDDAPHY_CAM: vdda_csiport */ + regulator-name = "ldo1"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo2_reg: ldo2 { + /* VCC_2V8_DISP: Does not go anywhere */ + regulator-name = "ldo2"; + regulator-min-microvolt = <2800000>; + regulator-max-microvolt = <2800000>; + /* Unused */ + status = "disabled"; + }; + + ldo3_reg: ldo3 { + /* VDDAPHY_MDM: vdda_lli */ + regulator-name = "ldo3"; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + regulator-boot-on; + /* Only if Modem is used */ + status = "disabled"; + }; + + ldo4_reg: ldo4 { + /* VDDAPHY_DISP: vdda_dsiport/hdmi */ + regulator-name = "ldo4"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + }; + + ldo5_reg: ldo5 { + /* VDDA_1V8_PHY: usb/sata/hdmi.. */ + regulator-name = "ldo5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo6_reg: ldo6 { + /* VDDS_1V2_WKUP: hsic/ldo_emu_wkup */ + regulator-name = "ldo6"; + regulator-min-microvolt = <1200000>; + regulator-max-microvolt = <1200000>; + regulator-always-on; + regulator-boot-on; + }; + + ldo7_reg: ldo7 { + /* VDD_VPP: vpp1 */ + regulator-name = "ldo7"; + regulator-min-microvolt = <2000000>; + regulator-max-microvolt = <2000000>; + /* Only for efuse reprograming! */ + status = "disabled"; + }; + + ldo8_reg: ldo8 { + /* VDD_3v0: Does not go anywhere */ + regulator-name = "ldo8"; + regulator-min-microvolt = <3000000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + /* Unused */ + status = "disabled"; + }; + + ldo9_reg: ldo9 { + /* VCC_DV_SDIO: vdds_sdcard */ + regulator-name = "ldo9"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3000000>; + regulator-boot-on; + }; + + ldoln_reg: ldoln { + /* VDDA_1v8_REF: vdds_osc/mm_l4per.. */ + regulator-name = "ldoln"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + regulator-always-on; + regulator-boot-on; + }; + + ldousb_reg: ldousb { + /* VDDA_3V_USB: VDDA_USBHS33 */ + regulator-name = "ldousb"; + regulator-min-microvolt = <3250000>; + regulator-max-microvolt = <3250000>; + regulator-always-on; + regulator-boot-on; + }; + + regen3_reg: regen3 { + /* REGEN3 controls LDO9 supply to card */ + regulator-name = "regen3"; + regulator-always-on; + regulator-boot-on; + }; + }; + }; + + palmas_power_button: palmas_power_button { + compatible = "ti,palmas-pwrbutton"; + interrupt-parent = <&palmas>; + interrupts = <1 IRQ_TYPE_EDGE_FALLING>; + wakeup-source; + }; + }; + + twl6040: twl@4b { + compatible = "ti,twl6040"; + #clock-cells = <0>; + reg = <0x4b>; + + pinctrl-names = "default"; + pinctrl-0 = <&twl6040_pins>; + + /* sys_nirq/ext_sys_irq pins get inverted at mpuss wakeupgen */ + interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_LOW>; + + /* audpwron gpio defined in the board specific dts */ + + vio-supply = <&smps7_reg>; + v2v1-supply = <&smps9_reg>; + enable-active-high; + + clocks = <&clk32kgaudio>, <&fref_xtal_ck>; + clock-names = "clk32k", "mclk"; + }; +}; + +&mcpdm_module { + /* Module on the SoC needs external clock from the PMIC */ + pinctrl-names = "default"; + pinctrl-0 = <&mcpdm_pins>; + status = "okay"; +}; + +&mcpdm { + clocks = <&twl6040>; + clock-names = "pdmclk"; +}; + +&mcbsp1 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp1_pins>; + status = "okay"; +}; + +&mcbsp2 { + pinctrl-names = "default"; + pinctrl-0 = <&mcbsp2_pins>; + status = "okay"; +}; + +&usbhshost { + port2-mode = "ehci-hsic"; + port3-mode = "ehci-hsic"; +}; + +&usbhsehci { + phys = <0 &hsusb2_phy &hsusb3_phy>; +}; + +&usb3 { + extcon = <&extcon_usb3>; + vbus-supply = <&smps10_out1_reg>; +}; + +&dwc3 { + extcon = <&extcon_usb3>; + dr_mode = "otg"; +}; + +&mcspi1 { + +}; + +&mcspi2 { + pinctrl-names = "default"; + pinctrl-0 = <&mcspi2_pins>; +}; + +&mcspi3 { + pinctrl-names = "default"; + pinctrl-0 = <&mcspi3_pins>; +}; + +&uart1 { + pinctrl-names = "default"; + pinctrl-0 = <&uart1_pins>; +}; + +&uart3 { + pinctrl-names = "default"; + pinctrl-0 = <&uart3_pins>; + interrupts-extended = <&wakeupgen GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, + <&omap5_pmx_core 0x19c>; +}; + +&uart5 { + pinctrl-names = "default"; + pinctrl-0 = <&uart5_pins>; +}; + +&cpu0 { + cpu0-supply = <&smps123_reg>; +}; + +&dss { + status = "ok"; +}; + +&hdmi { + status = "ok"; + + /* vdda-supply populated in board specific dts file */ + + pinctrl-names = "default"; + pinctrl-0 = <&dss_hdmi_pins>; + + port { + hdmi_out: endpoint { + remote-endpoint = <&tpd12s015_in>; + }; + }; +}; diff --git a/arch/arm/dts/omap5-l4-abe.dtsi b/arch/arm/dts/omap5-l4-abe.dtsi new file mode 100644 index 0000000000..bafd6adf9f --- /dev/null +++ b/arch/arm/dts/omap5-l4-abe.dtsi @@ -0,0 +1,450 @@ +&l4_abe { /* 0x40100000 */ + compatible = "ti,omap5-l4-abe", "simple-bus"; + reg = <0x40100000 0x400>, + <0x40100400 0x400>; + reg-names = "la", "ap"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x40100000 0x100000>, /* segment 0 */ + <0x49000000 0x49000000 0x100000>; + segment@0 { /* 0x40100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = + /* CPU to L4 ABE mapping */ + <0x00000000 0x00000000 0x000400>, /* ap 0 */ + <0x00000400 0x00000400 0x000400>, /* ap 1 */ + <0x00022000 0x00022000 0x001000>, /* ap 2 */ + <0x00023000 0x00023000 0x001000>, /* ap 3 */ + <0x00024000 0x00024000 0x001000>, /* ap 4 */ + <0x00025000 0x00025000 0x001000>, /* ap 5 */ + <0x00026000 0x00026000 0x001000>, /* ap 6 */ + <0x00027000 0x00027000 0x001000>, /* ap 7 */ + <0x00028000 0x00028000 0x001000>, /* ap 8 */ + <0x00029000 0x00029000 0x001000>, /* ap 9 */ + <0x0002a000 0x0002a000 0x001000>, /* ap 10 */ + <0x0002b000 0x0002b000 0x001000>, /* ap 11 */ + <0x0002e000 0x0002e000 0x001000>, /* ap 12 */ + <0x0002f000 0x0002f000 0x001000>, /* ap 13 */ + <0x00030000 0x00030000 0x001000>, /* ap 14 */ + <0x00031000 0x00031000 0x001000>, /* ap 15 */ + <0x00032000 0x00032000 0x001000>, /* ap 16 */ + <0x00033000 0x00033000 0x001000>, /* ap 17 */ + <0x00038000 0x00038000 0x001000>, /* ap 18 */ + <0x00039000 0x00039000 0x001000>, /* ap 19 */ + <0x0003a000 0x0003a000 0x001000>, /* ap 20 */ + <0x0003b000 0x0003b000 0x001000>, /* ap 21 */ + <0x0003c000 0x0003c000 0x001000>, /* ap 22 */ + <0x0003d000 0x0003d000 0x001000>, /* ap 23 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 24 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 25 */ + <0x00080000 0x00080000 0x010000>, /* ap 26 */ + <0x00080000 0x00080000 0x001000>, /* ap 27 */ + <0x000a0000 0x000a0000 0x010000>, /* ap 28 */ + <0x000a0000 0x000a0000 0x001000>, /* ap 29 */ + <0x000c0000 0x000c0000 0x010000>, /* ap 30 */ + <0x000c0000 0x000c0000 0x001000>, /* ap 31 */ + <0x000f1000 0x000f1000 0x001000>, /* ap 32 */ + <0x000f2000 0x000f2000 0x001000>, /* ap 33 */ + + /* L3 to L4 ABE mapping */ + <0x49000000 0x49000000 0x000400>, /* ap 0 */ + <0x49000400 0x49000400 0x000400>, /* ap 1 */ + <0x49022000 0x49022000 0x001000>, /* ap 2 */ + <0x49023000 0x49023000 0x001000>, /* ap 3 */ + <0x49024000 0x49024000 0x001000>, /* ap 4 */ + <0x49025000 0x49025000 0x001000>, /* ap 5 */ + <0x49026000 0x49026000 0x001000>, /* ap 6 */ + <0x49027000 0x49027000 0x001000>, /* ap 7 */ + <0x49028000 0x49028000 0x001000>, /* ap 8 */ + <0x49029000 0x49029000 0x001000>, /* ap 9 */ + <0x4902a000 0x4902a000 0x001000>, /* ap 10 */ + <0x4902b000 0x4902b000 0x001000>, /* ap 11 */ + <0x4902e000 0x4902e000 0x001000>, /* ap 12 */ + <0x4902f000 0x4902f000 0x001000>, /* ap 13 */ + <0x49030000 0x49030000 0x001000>, /* ap 14 */ + <0x49031000 0x49031000 0x001000>, /* ap 15 */ + <0x49032000 0x49032000 0x001000>, /* ap 16 */ + <0x49033000 0x49033000 0x001000>, /* ap 17 */ + <0x49038000 0x49038000 0x001000>, /* ap 18 */ + <0x49039000 0x49039000 0x001000>, /* ap 19 */ + <0x4903a000 0x4903a000 0x001000>, /* ap 20 */ + <0x4903b000 0x4903b000 0x001000>, /* ap 21 */ + <0x4903c000 0x4903c000 0x001000>, /* ap 22 */ + <0x4903d000 0x4903d000 0x001000>, /* ap 23 */ + <0x4903e000 0x4903e000 0x001000>, /* ap 24 */ + <0x4903f000 0x4903f000 0x001000>, /* ap 25 */ + <0x49080000 0x49080000 0x010000>, /* ap 26 */ + <0x49080000 0x49080000 0x001000>, /* ap 27 */ + <0x490a0000 0x490a0000 0x010000>, /* ap 28 */ + <0x490a0000 0x490a0000 0x001000>, /* ap 29 */ + <0x490c0000 0x490c0000 0x010000>, /* ap 30 */ + <0x490c0000 0x490c0000 0x001000>, /* ap 31 */ + <0x490f1000 0x490f1000 0x001000>, /* ap 32 */ + <0x490f2000 0x490f2000 0x001000>; /* ap 33 */ + + target-module@22000 { /* 0x40122000, ap 2 02.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2208c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_MCBSP1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x22000 0x1000>, + <0x49022000 0x49022000 0x1000>; + + mcbsp1: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49022000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 33>, + <&sdma 34>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@24000 { /* 0x40124000, ap 4 04.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2408c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_MCBSP2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x24000 0x1000>, + <0x49024000 0x49024000 0x1000>; + + mcbsp2: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49024000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 17>, + <&sdma 18>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@26000 { /* 0x40126000, ap 6 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2608c 0x4>; + reg-names = "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_MCBSP3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>, + <0x49026000 0x49026000 0x1000>; + + mcbsp3: mcbsp@0 { + compatible = "ti,omap4-mcbsp"; + reg = <0x0 0xff>, /* MPU private access */ + <0x49026000 0xff>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "common"; + ti,buffer-size = <128>; + dmas = <&sdma 19>, + <&sdma 20>; + dma-names = "tx", "rx"; + status = "disabled"; + }; + }; + + target-module@28000 { /* 0x40128000, ap 8 08.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>, + <0x49028000 0x49028000 0x1000>; + }; + + target-module@2a000 { /* 0x4012a000, ap 10 0a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>, + <0x4902a000 0x4902a000 0x1000>; + }; + + target-module@2e000 { /* 0x4012e000, ap 12 0c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x2e000 0x4>, + <0x2e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_DMIC_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2e000 0x1000>, + <0x4902e000 0x4902e000 0x1000>; + + dmic: dmic@0 { + compatible = "ti,omap4-dmic"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x4902e000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 67>; + dma-names = "up_link"; + status = "disabled"; + }; + }; + + target-module@30000 { /* 0x40130000, ap 14 0e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x30000 0x1000>, + <0x49030000 0x49030000 0x1000>; + }; + + mcpdm_module: target-module@32000 { /* 0x40132000, ap 16 10.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_MCPDM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>, + <0x49032000 0x49032000 0x1000>; + + /* Must be only enabled for boards with pdmclk wired */ + status = "disabled"; + + mcpdm: mcpdm@0 { + compatible = "ti,omap4-mcpdm"; + reg = <0x0 0x7f>, /* MPU private access */ + <0x49032000 0x7f>; /* L3 Interconnect */ + reg-names = "mpu", "dma"; + interrupts = <GIC_SPI 112 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 65>, + <&sdma 66>; + dma-names = "up_link", "dn_link"; + }; + }; + + target-module@38000 { /* 0x40138000, ap 18 12.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x38000 0x4>, + <0x38010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_TIMER5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x38000 0x1000>, + <0x49038000 0x49038000 0x1000>; + + timer5: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>, + <0x49038000 0x80>; + clocks = <&abe_clkctrl OMAP5_TIMER5_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + ti,timer-pwm; + }; + }; + + target-module@3a000 { /* 0x4013a000, ap 20 14.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3a000 0x4>, + <0x3a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_TIMER6_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3a000 0x1000>, + <0x4903a000 0x4903a000 0x1000>; + + timer6: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>, + <0x4903a000 0x80>; + clocks = <&abe_clkctrl OMAP5_TIMER6_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + ti,timer-pwm; + }; + }; + + target-module@3c000 { /* 0x4013c000, ap 22 16.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3c000 0x4>, + <0x3c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_TIMER7_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3c000 0x1000>, + <0x4903c000 0x4903c000 0x1000>; + + timer7: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>, + <0x4903c000 0x80>; + clocks = <&abe_clkctrl OMAP5_TIMER7_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + }; + }; + + target-module@3e000 { /* 0x4013e000, ap 24 18.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_TIMER8_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>, + <0x4903e000 0x4903e000 0x1000>; + + timer8: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>, + <0x4903e000 0x80>; + clocks = <&abe_clkctrl OMAP5_TIMER8_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-dsp; + ti,timer-pwm; + }; + }; + + target-module@80000 { /* 0x40180000, ap 26 1a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x80000 0x10000>, + <0x49080000 0x49080000 0x10000>; + }; + + target-module@a0000 { /* 0x401a0000, ap 28 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa0000 0x10000>, + <0x490a0000 0x490a0000 0x10000>; + }; + + target-module@c0000 { /* 0x401c0000, ap 30 1e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc0000 0x10000>, + <0x490c0000 0x490c0000 0x10000>; + }; + + target-module@f1000 { /* 0x401f1000, ap 32 20.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xf1000 0x4>, + <0xf1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): iva, abe_pwrdm, abe_clkdm */ + clocks = <&abe_clkctrl OMAP5_AESS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xf1000 0x1000>, + <0x490f1000 0x490f1000 0x1000>; + }; + }; +}; + diff --git a/arch/arm/dts/omap5-l4.dtsi b/arch/arm/dts/omap5-l4.dtsi new file mode 100644 index 0000000000..f68740abb8 --- /dev/null +++ b/arch/arm/dts/omap5-l4.dtsi @@ -0,0 +1,2438 @@ +&l4_cfg { /* 0x4a000000 */ + compatible = "ti,omap5-l4-cfg", "simple-bus"; + reg = <0x4a000000 0x800>, + <0x4a000800 0x800>, + <0x4a001000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4a000000 0x080000>, /* segment 0 */ + <0x00080000 0x4a080000 0x080000>, /* segment 1 */ + <0x00100000 0x4a100000 0x080000>, /* segment 2 */ + <0x00180000 0x4a180000 0x080000>, /* segment 3 */ + <0x00200000 0x4a200000 0x080000>, /* segment 4 */ + <0x00280000 0x4a280000 0x080000>, /* segment 5 */ + <0x00300000 0x4a300000 0x080000>; /* segment 6 */ + + segment@0 { /* 0x4a000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00002000 0x00002000 0x001000>, /* ap 3 */ + <0x00003000 0x00003000 0x001000>, /* ap 4 */ + <0x00004000 0x00004000 0x001000>, /* ap 5 */ + <0x00005000 0x00005000 0x001000>, /* ap 6 */ + <0x00056000 0x00056000 0x001000>, /* ap 7 */ + <0x00057000 0x00057000 0x001000>, /* ap 8 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 9 */ + <0x00058000 0x00058000 0x001000>, /* ap 10 */ + <0x00062000 0x00062000 0x001000>, /* ap 11 */ + <0x00063000 0x00063000 0x001000>, /* ap 12 */ + <0x00008000 0x00008000 0x002000>, /* ap 21 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 22 */ + <0x00066000 0x00066000 0x001000>, /* ap 23 */ + <0x00067000 0x00067000 0x001000>, /* ap 24 */ + <0x0005e000 0x0005e000 0x002000>, /* ap 69 */ + <0x00060000 0x00060000 0x001000>, /* ap 70 */ + <0x00064000 0x00064000 0x001000>, /* ap 71 */ + <0x00065000 0x00065000 0x001000>, /* ap 72 */ + <0x0005a000 0x0005a000 0x001000>, /* ap 77 */ + <0x0005b000 0x0005b000 0x001000>, /* ap 78 */ + <0x00070000 0x00070000 0x004000>, /* ap 79 */ + <0x00074000 0x00074000 0x001000>, /* ap 80 */ + <0x00075000 0x00075000 0x001000>, /* ap 81 */ + <0x00076000 0x00076000 0x001000>, /* ap 82 */ + <0x00020000 0x00020000 0x020000>, /* ap 109 */ + <0x00040000 0x00040000 0x001000>, /* ap 110 */ + <0x00059000 0x00059000 0x001000>; /* ap 111 */ + + target-module@2000 { /* 0x4a002000, ap 3 44.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x2000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + + scm_core: scm@0 { + compatible = "ti,omap5-scm-core", "simple-bus"; + reg = <0x0 0x1000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x800>; + + scm_conf: scm_conf@0 { + compatible = "syscon"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + }; + }; + + scm_padconf_core: scm@800 { + compatible = "ti,omap5-scm-padconf-core", + "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x800 0x800>; + + omap5_pmx_core: pinmux@40 { + compatible = "ti,omap5-padconf", + "pinctrl-single"; + reg = <0x40 0x01b6>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + + omap5_padconf_global: omap5_padconf_global@5a0 { + compatible = "syscon", + "simple-bus"; + reg = <0x5a0 0xec>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5a0 0xec>; + + pbias_regulator: pbias_regulator@60 { + compatible = "ti,pbias-omap5", "ti,pbias-omap"; + reg = <0x60 0x4>; + syscon = <&omap5_padconf_global>; + pbias_mmc_reg: pbias_mmc_omap5 { + regulator-name = "pbias_mmc_omap5"; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <3300000>; + }; + }; + }; + }; + }; + + target-module@4000 { /* 0x4a004000, ap 5 5c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x4000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + cm_core_aon: cm_core_aon@0 { + compatible = "ti,omap5-cm-core-aon", + "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + + cm_core_aon_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm_core_aon_clockdomains: clockdomains { + }; + }; + }; + + target-module@8000 { /* 0x4a008000, ap 21 4c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x8000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x2000>; + + cm_core: cm_core@0 { + compatible = "ti,omap5-cm-core", "simple-bus"; + reg = <0x0 0x2000>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + cm_core_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + cm_core_clockdomains: clockdomains { + }; + }; + }; + + target-module@20000 { /* 0x4a020000, ap 109 08.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "usb_otg_ss"; + reg = <0x20000 0x4>, + <0x20010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_DMADISABLE>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_USB_OTG_SS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x20000>; + + usb3: omap_dwc3@0 { + compatible = "ti,dwc3"; + reg = <0x0 0x10000>; + interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + utmi-mode = <2>; + ranges = <0 0 0x20000>; + dwc3: dwc3@10000 { + compatible = "snps,dwc3"; + reg = <0x10000 0x10000>; + interrupts = <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; + interrupt-names = "peripheral", + "host", + "otg"; + phys = <&usb2_phy>, <&usb3_phy>; + phy-names = "usb2-phy", "usb3-phy"; + dr_mode = "peripheral"; + }; + }; + }; + + target-module@56000 { /* 0x4a056000, ap 7 02.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x56000 0x4>, + <0x5602c 0x4>, + <0x56028 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, dma_clkdm */ + clocks = <&dma_clkctrl OMAP5_DMA_SYSTEM_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x56000 0x1000>; + + sdma: dma-controller@0 { + compatible = "ti,omap4430-sdma", "ti,omap-sdma"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; + #dma-cells = <1>; + dma-channels = <32>; + dma-requests = <127>; + }; + }; + + target-module@58000 { /* 0x4a058000, ap 10 06.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00058000 0x00001000>, + <0x00001000 0x00059000 0x00001000>, + <0x00002000 0x0005a000 0x00001000>, + <0x00003000 0x0005b000 0x00001000>; + }; + + target-module@5e000 { /* 0x4a05e000, ap 69 2a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5e000 0x2000>; + }; + + target-module@62000 { /* 0x4a062000, ap 11 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "usb_tll_hs"; + reg = <0x62000 0x4>, + <0x62010 0x4>, + <0x62014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_USB_TLL_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x62000 0x1000>; + + usbhstll: usbhstll@0 { + compatible = "ti,usbhs-tll"; + reg = <0x0 0x1000>; + interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@64000 { /* 0x4a064000, ap 71 1e.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + ti,hwmods = "usb_host_hs"; + reg = <0x64000 0x4>, + <0x64010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_USB_HOST_HS_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x64000 0x1000>; + + usbhshost: usbhshost@0 { + compatible = "ti,usbhs-host"; + reg = <0x0 0x800>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000>; + clocks = <&l3init_60m_fclk>, + <&xclk60mhsp1_ck>, + <&xclk60mhsp2_ck>; + clock-names = "refclk_60m_int", + "refclk_60m_ext_p1", + "refclk_60m_ext_p2"; + + usbhsohci: ohci@800 { + compatible = "ti,ohci-omap3"; + reg = <0x800 0x400>; + interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; + remote-wakeup-connected; + }; + + usbhsehci: ehci@c00 { + compatible = "ti,ehci-omap"; + reg = <0xc00 0x400>; + interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + }; + + target-module@66000 { /* 0x4a066000, ap 23 0a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x66000 0x4>, + <0x66010 0x4>, + <0x66014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): mm, dsp_pwrdm, dsp_clkdm */ + clocks = <&dsp_clkctrl OMAP5_MMU_DSP_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_dsp 1>; + reset-names = "rstctrl"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x66000 0x1000>; + + mmu_dsp: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + }; + }; + + target-module@70000 { /* 0x4a070000, ap 79 2e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x70000 0x4000>; + }; + + target-module@75000 { /* 0x4a075000, ap 81 32.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x75000 0x1000>; + }; + }; + + segment@80000 { /* 0x4a080000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00059000 0x000d9000 0x001000>, /* ap 13 */ + <0x0005a000 0x000da000 0x001000>, /* ap 14 */ + <0x0005b000 0x000db000 0x001000>, /* ap 15 */ + <0x0005c000 0x000dc000 0x001000>, /* ap 16 */ + <0x0005d000 0x000dd000 0x001000>, /* ap 17 */ + <0x0005e000 0x000de000 0x001000>, /* ap 18 */ + <0x00060000 0x000e0000 0x001000>, /* ap 19 */ + <0x00061000 0x000e1000 0x001000>, /* ap 20 */ + <0x00074000 0x000f4000 0x001000>, /* ap 25 */ + <0x00075000 0x000f5000 0x001000>, /* ap 26 */ + <0x00076000 0x000f6000 0x001000>, /* ap 27 */ + <0x00077000 0x000f7000 0x001000>, /* ap 28 */ + <0x00036000 0x000b6000 0x001000>, /* ap 65 */ + <0x00037000 0x000b7000 0x001000>, /* ap 66 */ + <0x0004d000 0x000cd000 0x001000>, /* ap 67 */ + <0x0004e000 0x000ce000 0x001000>, /* ap 68 */ + <0x00000000 0x00080000 0x004000>, /* ap 83 */ + <0x00004000 0x00084000 0x001000>, /* ap 84 */ + <0x00005000 0x00085000 0x001000>, /* ap 85 */ + <0x00006000 0x00086000 0x001000>, /* ap 86 */ + <0x00007000 0x00087000 0x001000>, /* ap 87 */ + <0x00008000 0x00088000 0x001000>, /* ap 88 */ + <0x00010000 0x00090000 0x004000>, /* ap 89 */ + <0x00014000 0x00094000 0x001000>, /* ap 90 */ + <0x00015000 0x00095000 0x001000>, /* ap 91 */ + <0x00016000 0x00096000 0x001000>, /* ap 92 */ + <0x00017000 0x00097000 0x001000>, /* ap 93 */ + <0x00018000 0x00098000 0x001000>, /* ap 94 */ + <0x00020000 0x000a0000 0x004000>, /* ap 95 */ + <0x00024000 0x000a4000 0x001000>, /* ap 96 */ + <0x00025000 0x000a5000 0x001000>, /* ap 97 */ + <0x00026000 0x000a6000 0x001000>, /* ap 98 */ + <0x00027000 0x000a7000 0x001000>, /* ap 99 */ + <0x00028000 0x000a8000 0x001000>; /* ap 100 */ + + target-module@0 { /* 0x4a080000, ap 83 28.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x0 0x4>, + <0x10 0x4>, + <0x14 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_OCP2SCP1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x00004000>, + <0x00004000 0x00004000 0x00001000>, + <0x00005000 0x00005000 0x00001000>, + <0x00006000 0x00006000 0x00001000>, + <0x00007000 0x00007000 0x00001000>; + + ocp2scp@0 { + compatible = "ti,omap-ocp2scp"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0 0x20>; + }; + + usb2_phy: usb2phy@4000 { + compatible = "ti,omap-usb2"; + reg = <0x4000 0x7c>; + syscon-phy-power = <&scm_conf 0x300>; + clocks = <&usb_phy_cm_clk32k>, + <&l3init_clkctrl OMAP5_USB_OTG_SS_CLKCTRL 8>; + clock-names = "wkupclk", "refclk"; + #phy-cells = <0>; + }; + + usb3_phy: usb3phy@4400 { + compatible = "ti,omap-usb3"; + reg = <0x4400 0x80>, + <0x4800 0x64>, + <0x4c00 0x40>; + reg-names = "phy_rx", "phy_tx", "pll_ctrl"; + syscon-phy-power = <&scm_conf 0x370>; + clocks = <&usb_phy_cm_clk32k>, + <&sys_clkin>, + <&l3init_clkctrl OMAP5_USB_OTG_SS_CLKCTRL 8>; + clock-names = "wkupclk", + "sysclk", + "refclk"; + #phy-cells = <0>; + }; + }; + + target-module@10000 { /* 0x4a090000, ap 89 36.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x10000 0x4>, + <0x10010 0x4>, + <0x10014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_OCP2SCP3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00010000 0x00004000>, + <0x00004000 0x00014000 0x00001000>, + <0x00005000 0x00015000 0x00001000>, + <0x00006000 0x00016000 0x00001000>, + <0x00007000 0x00017000 0x00001000>; + + ocp2scp@0 { + compatible = "ti,omap-ocp2scp"; + #address-cells = <1>; + #size-cells = <1>; + reg = <0x0 0x20>; + }; + + sata_phy: phy@6000 { + compatible = "ti,phy-pipe3-sata"; + reg = <0x6000 0x80>, /* phy_rx */ + <0x6400 0x64>, /* phy_tx */ + <0x6800 0x40>; /* pll_ctrl */ + reg-names = "phy_rx", "phy_tx", "pll_ctrl"; + syscon-phy-power = <&scm_conf 0x374>; + clocks = <&sys_clkin>, + <&l3init_clkctrl OMAP5_SATA_CLKCTRL 8>; + clock-names = "sysclk", "refclk"; + #phy-cells = <0>; + }; + }; + + target-module@20000 { /* 0x4a0a0000, ap 95 50.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00020000 0x00004000>, + <0x00004000 0x00024000 0x00001000>, + <0x00005000 0x00025000 0x00001000>, + <0x00006000 0x00026000 0x00001000>, + <0x00007000 0x00027000 0x00001000>; + }; + + target-module@36000 { /* 0x4a0b6000, ap 65 6c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + }; + + target-module@4d000 { /* 0x4a0cd000, ap 67 64.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4d000 0x1000>; + }; + + target-module@59000 { /* 0x4a0d9000, ap 13 20.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + }; + + target-module@5b000 { /* 0x4a0db000, ap 15 10.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + }; + + target-module@5d000 { /* 0x4a0dd000, ap 17 18.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + }; + + target-module@60000 { /* 0x4a0e0000, ap 19 54.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + }; + + target-module@74000 { /* 0x4a0f4000, ap 25 04.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x74000 0x4>, + <0x74010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <SYSC_OMAP4_SOFTRESET>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): core, core_pwrdm, l4cfg_clkdm */ + clocks = <&l4cfg_clkctrl OMAP5_MAILBOX_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x74000 0x1000>; + + mailbox: mailbox@0 { + compatible = "ti,omap4-mailbox"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; + #mbox-cells = <1>; + ti,mbox-num-users = <3>; + ti,mbox-num-fifos = <8>; + mbox_ipu: mbox_ipu { + ti,mbox-tx = <0 0 0>; + ti,mbox-rx = <1 0 0>; + }; + mbox_dsp: mbox_dsp { + ti,mbox-tx = <3 0 0>; + ti,mbox-rx = <2 0 0>; + }; + }; + }; + + target-module@76000 { /* 0x4a0f6000, ap 27 0c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x76000 0x4>, + <0x76010 0x4>, + <0x76014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4cfg_clkdm */ + clocks = <&l4cfg_clkctrl OMAP5_SPINLOCK_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x76000 0x1000>; + + hwspinlock: spinlock@0 { + compatible = "ti,omap4-hwspinlock"; + reg = <0x0 0x1000>; + #hwlock-cells = <1>; + }; + }; + }; + + segment@100000 { /* 0x4a100000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00002000 0x00102000 0x001000>, /* ap 59 */ + <0x00003000 0x00103000 0x001000>, /* ap 60 */ + <0x00008000 0x00108000 0x001000>, /* ap 61 */ + <0x00009000 0x00109000 0x001000>, /* ap 62 */ + <0x0000a000 0x0010a000 0x001000>, /* ap 63 */ + <0x0000b000 0x0010b000 0x001000>, /* ap 64 */ + <0x00040000 0x00140000 0x010000>, /* ap 101 */ + <0x00050000 0x00150000 0x001000>; /* ap 102 */ + + target-module@2000 { /* 0x4a102000, ap 59 2c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@8000 { /* 0x4a108000, ap 61 26.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + }; + + target-module@a000 { /* 0x4a10a000, ap 63 22.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + }; + + target-module@40000 { /* 0x4a140000, ap 101 16.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x40000 0x10000>; + }; + }; + + segment@180000 { /* 0x4a180000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + segment@200000 { /* 0x4a200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0001e000 0x0021e000 0x001000>, /* ap 29 */ + <0x0001f000 0x0021f000 0x001000>, /* ap 30 */ + <0x0000a000 0x0020a000 0x001000>, /* ap 31 */ + <0x0000b000 0x0020b000 0x001000>, /* ap 32 */ + <0x00006000 0x00206000 0x001000>, /* ap 33 */ + <0x00007000 0x00207000 0x001000>, /* ap 34 */ + <0x00004000 0x00204000 0x001000>, /* ap 35 */ + <0x00005000 0x00205000 0x001000>, /* ap 36 */ + <0x00012000 0x00212000 0x001000>, /* ap 37 */ + <0x00013000 0x00213000 0x001000>, /* ap 38 */ + <0x0000c000 0x0020c000 0x001000>, /* ap 39 */ + <0x0000d000 0x0020d000 0x001000>, /* ap 40 */ + <0x00010000 0x00210000 0x001000>, /* ap 41 */ + <0x00011000 0x00211000 0x001000>, /* ap 42 */ + <0x00016000 0x00216000 0x001000>, /* ap 43 */ + <0x00017000 0x00217000 0x001000>, /* ap 44 */ + <0x00014000 0x00214000 0x001000>, /* ap 45 */ + <0x00015000 0x00215000 0x001000>, /* ap 46 */ + <0x00018000 0x00218000 0x001000>, /* ap 47 */ + <0x00019000 0x00219000 0x001000>, /* ap 48 */ + <0x00020000 0x00220000 0x001000>, /* ap 49 */ + <0x00021000 0x00221000 0x001000>, /* ap 50 */ + <0x00026000 0x00226000 0x001000>, /* ap 51 */ + <0x00027000 0x00227000 0x001000>, /* ap 52 */ + <0x00028000 0x00228000 0x001000>, /* ap 53 */ + <0x00029000 0x00229000 0x001000>, /* ap 54 */ + <0x0002a000 0x0022a000 0x001000>, /* ap 55 */ + <0x0002b000 0x0022b000 0x001000>, /* ap 56 */ + <0x0001c000 0x0021c000 0x001000>, /* ap 57 */ + <0x0001d000 0x0021d000 0x001000>, /* ap 58 */ + <0x0001a000 0x0021a000 0x001000>, /* ap 73 */ + <0x0001b000 0x0021b000 0x001000>, /* ap 74 */ + <0x00024000 0x00224000 0x001000>, /* ap 75 */ + <0x00025000 0x00225000 0x001000>, /* ap 76 */ + <0x00002000 0x00202000 0x001000>, /* ap 103 */ + <0x00003000 0x00203000 0x001000>, /* ap 104 */ + <0x00008000 0x00208000 0x001000>, /* ap 105 */ + <0x00009000 0x00209000 0x001000>, /* ap 106 */ + <0x00022000 0x00222000 0x001000>, /* ap 107 */ + <0x00023000 0x00223000 0x001000>; /* ap 108 */ + + target-module@2000 { /* 0x4a202000, ap 103 3c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@4000 { /* 0x4a204000, ap 35 46.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + }; + + target-module@6000 { /* 0x4a206000, ap 33 4e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x1000>; + }; + + target-module@8000 { /* 0x4a208000, ap 105 34.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + }; + + target-module@a000 { /* 0x4a20a000, ap 31 30.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + }; + + target-module@c000 { /* 0x4a20c000, ap 39 14.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + }; + + target-module@10000 { /* 0x4a210000, ap 41 56.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x10000 0x1000>; + }; + + target-module@12000 { /* 0x4a212000, ap 37 52.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x12000 0x1000>; + }; + + target-module@14000 { /* 0x4a214000, ap 45 1c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x14000 0x1000>; + }; + + target-module@16000 { /* 0x4a216000, ap 43 42.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x16000 0x1000>; + }; + + target-module@18000 { /* 0x4a218000, ap 47 1a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x18000 0x1000>; + }; + + target-module@1a000 { /* 0x4a21a000, ap 73 3e.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1a000 0x1000>; + }; + + target-module@1c000 { /* 0x4a21c000, ap 57 40.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1c000 0x1000>; + }; + + target-module@1e000 { /* 0x4a21e000, ap 29 12.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x1e000 0x1000>; + }; + + target-module@20000 { /* 0x4a220000, ap 49 4a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + }; + + target-module@22000 { /* 0x4a222000, ap 107 3a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x22000 0x1000>; + }; + + target-module@24000 { /* 0x4a224000, ap 75 48.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x24000 0x1000>; + }; + + target-module@26000 { /* 0x4a226000, ap 51 24.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x26000 0x1000>; + }; + + target-module@28000 { /* 0x4a228000, ap 53 38.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x28000 0x1000>; + }; + + target-module@2a000 { /* 0x4a22a000, ap 55 5a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2a000 0x1000>; + }; + }; + + segment@280000 { /* 0x4a280000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; + + segment@300000 { /* 0x4a300000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&l4_per { /* 0x48000000 */ + compatible = "ti,omap5-l4-per", "simple-bus"; + reg = <0x48000000 0x800>, + <0x48000800 0x800>, + <0x48001000 0x400>, + <0x48001400 0x400>, + <0x48001800 0x400>, + <0x48001c00 0x400>; + reg-names = "ap", "la", "ia0", "ia1", "ia2", "ia3"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x48000000 0x200000>, /* segment 0 */ + <0x00200000 0x48200000 0x200000>; /* segment 1 */ + + segment@0 { /* 0x48000000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x000400>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00020000 0x00020000 0x001000>, /* ap 3 */ + <0x00021000 0x00021000 0x001000>, /* ap 4 */ + <0x00032000 0x00032000 0x001000>, /* ap 5 */ + <0x00033000 0x00033000 0x001000>, /* ap 6 */ + <0x00034000 0x00034000 0x001000>, /* ap 7 */ + <0x00035000 0x00035000 0x001000>, /* ap 8 */ + <0x00036000 0x00036000 0x001000>, /* ap 9 */ + <0x00037000 0x00037000 0x001000>, /* ap 10 */ + <0x0003e000 0x0003e000 0x001000>, /* ap 11 */ + <0x0003f000 0x0003f000 0x001000>, /* ap 12 */ + <0x00055000 0x00055000 0x001000>, /* ap 13 */ + <0x00056000 0x00056000 0x001000>, /* ap 14 */ + <0x00057000 0x00057000 0x001000>, /* ap 15 */ + <0x00058000 0x00058000 0x001000>, /* ap 16 */ + <0x00059000 0x00059000 0x001000>, /* ap 17 */ + <0x0005a000 0x0005a000 0x001000>, /* ap 18 */ + <0x0005b000 0x0005b000 0x001000>, /* ap 19 */ + <0x0005c000 0x0005c000 0x001000>, /* ap 20 */ + <0x0005d000 0x0005d000 0x001000>, /* ap 21 */ + <0x0005e000 0x0005e000 0x001000>, /* ap 22 */ + <0x00060000 0x00060000 0x001000>, /* ap 23 */ + <0x0006a000 0x0006a000 0x001000>, /* ap 24 */ + <0x0006b000 0x0006b000 0x001000>, /* ap 25 */ + <0x0006c000 0x0006c000 0x001000>, /* ap 26 */ + <0x0006d000 0x0006d000 0x001000>, /* ap 27 */ + <0x0006e000 0x0006e000 0x001000>, /* ap 28 */ + <0x0006f000 0x0006f000 0x001000>, /* ap 29 */ + <0x00070000 0x00070000 0x001000>, /* ap 30 */ + <0x00071000 0x00071000 0x001000>, /* ap 31 */ + <0x00072000 0x00072000 0x001000>, /* ap 32 */ + <0x00073000 0x00073000 0x001000>, /* ap 33 */ + <0x00061000 0x00061000 0x001000>, /* ap 34 */ + <0x00053000 0x00053000 0x001000>, /* ap 35 */ + <0x00054000 0x00054000 0x001000>, /* ap 36 */ + <0x000b2000 0x000b2000 0x001000>, /* ap 37 */ + <0x000b3000 0x000b3000 0x001000>, /* ap 38 */ + <0x00078000 0x00078000 0x001000>, /* ap 39 */ + <0x00079000 0x00079000 0x001000>, /* ap 40 */ + <0x00086000 0x00086000 0x001000>, /* ap 41 */ + <0x00087000 0x00087000 0x001000>, /* ap 42 */ + <0x00088000 0x00088000 0x001000>, /* ap 43 */ + <0x00089000 0x00089000 0x001000>, /* ap 44 */ + <0x00051000 0x00051000 0x001000>, /* ap 45 */ + <0x00052000 0x00052000 0x001000>, /* ap 46 */ + <0x00098000 0x00098000 0x001000>, /* ap 47 */ + <0x00099000 0x00099000 0x001000>, /* ap 48 */ + <0x0009a000 0x0009a000 0x001000>, /* ap 49 */ + <0x0009b000 0x0009b000 0x001000>, /* ap 50 */ + <0x0009c000 0x0009c000 0x001000>, /* ap 51 */ + <0x0009d000 0x0009d000 0x001000>, /* ap 52 */ + <0x00068000 0x00068000 0x001000>, /* ap 53 */ + <0x00069000 0x00069000 0x001000>, /* ap 54 */ + <0x00090000 0x00090000 0x002000>, /* ap 55 */ + <0x00092000 0x00092000 0x001000>, /* ap 56 */ + <0x000a4000 0x000a4000 0x001000>, /* ap 57 */ + <0x000a6000 0x000a6000 0x001000>, /* ap 58 */ + <0x000a8000 0x000a8000 0x004000>, /* ap 59 */ + <0x000ac000 0x000ac000 0x001000>, /* ap 60 */ + <0x000ad000 0x000ad000 0x001000>, /* ap 61 */ + <0x000ae000 0x000ae000 0x001000>, /* ap 62 */ + <0x00066000 0x00066000 0x001000>, /* ap 63 */ + <0x00067000 0x00067000 0x001000>, /* ap 64 */ + <0x000b4000 0x000b4000 0x001000>, /* ap 65 */ + <0x000b5000 0x000b5000 0x001000>, /* ap 66 */ + <0x000b8000 0x000b8000 0x001000>, /* ap 67 */ + <0x000b9000 0x000b9000 0x001000>, /* ap 68 */ + <0x000ba000 0x000ba000 0x001000>, /* ap 69 */ + <0x000bb000 0x000bb000 0x001000>, /* ap 70 */ + <0x000d1000 0x000d1000 0x001000>, /* ap 71 */ + <0x000d2000 0x000d2000 0x001000>, /* ap 72 */ + <0x000d5000 0x000d5000 0x001000>, /* ap 73 */ + <0x000d6000 0x000d6000 0x001000>, /* ap 74 */ + <0x000a2000 0x000a2000 0x001000>, /* ap 75 */ + <0x000a3000 0x000a3000 0x001000>, /* ap 76 */ + <0x00001400 0x00001400 0x000400>, /* ap 77 */ + <0x00001800 0x00001800 0x000400>, /* ap 78 */ + <0x00001c00 0x00001c00 0x000400>, /* ap 79 */ + <0x000a5000 0x000a5000 0x001000>, /* ap 80 */ + <0x0007a000 0x0007a000 0x001000>, /* ap 81 */ + <0x0007b000 0x0007b000 0x001000>, /* ap 82 */ + <0x0007c000 0x0007c000 0x001000>, /* ap 83 */ + <0x0007d000 0x0007d000 0x001000>; /* ap 84 */ + + target-module@20000 { /* 0x48020000, ap 3 04.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x20050 0x4>, + <0x20054 0x4>, + <0x20058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x20000 0x1000>; + + uart3: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@32000 { /* 0x48032000, ap 5 3e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x32000 0x4>, + <0x32010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x32000 0x1000>; + + timer2: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER2_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@34000 { /* 0x48034000, ap 7 46.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x34000 0x4>, + <0x34010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x34000 0x1000>; + + timer3: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER3_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@36000 { /* 0x48036000, ap 9 4e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x36000 0x4>, + <0x36010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x36000 0x1000>; + + timer4: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER4_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@3e000 { /* 0x4803e000, ap 11 56.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x3e000 0x4>, + <0x3e010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER9_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x3e000 0x1000>; + + timer9: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER9_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + target-module@51000 { /* 0x48051000, ap 45 2e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x51000 0x4>, + <0x51010 0x4>, + <0x51114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO7_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO7_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x51000 0x1000>; + + gpio7: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@53000 { /* 0x48053000, ap 35 36.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x53000 0x4>, + <0x53010 0x4>, + <0x53114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO8_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO8_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x53000 0x1000>; + + gpio8: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@55000 { /* 0x48055000, ap 13 0e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55000 0x4>, + <0x55010 0x4>, + <0x55114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO2_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO2_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x55000 0x1000>; + + gpio2: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@57000 { /* 0x48057000, ap 15 06.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x57000 0x4>, + <0x57010 0x4>, + <0x57114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO3_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO3_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x57000 0x1000>; + + gpio3: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@59000 { /* 0x48059000, ap 17 16.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x59000 0x4>, + <0x59010 0x4>, + <0x59114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO4_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO4_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x59000 0x1000>; + + gpio4: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5b000 { /* 0x4805b000, ap 19 1e.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5b000 0x4>, + <0x5b010 0x4>, + <0x5b114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO5_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO5_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5b000 0x1000>; + + gpio5: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@5d000 { /* 0x4805d000, ap 21 26.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5d000 0x4>, + <0x5d010 0x4>, + <0x5d114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_GPIO6_CLKCTRL 0>, + <&l4per_clkctrl OMAP5_GPIO6_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x5d000 0x1000>; + + gpio6: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@60000 { /* 0x48060000, ap 23 24.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x60000 0x8>, + <0x60010 0x8>, + <0x60090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_I2C3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x60000 0x1000>; + + i2c3: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@66000 { /* 0x48066000, ap 63 4c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x66050 0x4>, + <0x66054 0x4>, + <0x66058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x66000 0x1000>; + + uart5: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@68000 { /* 0x48068000, ap 53 54.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x68050 0x4>, + <0x68054 0x4>, + <0x68058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART6_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x68000 0x1000>; + + uart6: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6a000 { /* 0x4806a000, ap 24 0a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6a050 0x4>, + <0x6a054 0x4>, + <0x6a058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6a000 0x1000>; + + uart1: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6c000 { /* 0x4806c000, ap 26 22.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6c050 0x4>, + <0x6c054 0x4>, + <0x6c058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6c000 0x1000>; + + uart2: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@6e000 { /* 0x4806e000, ap 28 44.1 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x6e050 0x4>, + <0x6e054 0x4>, + <0x6e058 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_UART4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6e000 0x1000>; + + uart4: serial@0 { + compatible = "ti,omap4-uart"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 70 IRQ_TYPE_LEVEL_HIGH>; + clock-frequency = <48000000>; + }; + }; + + target-module@70000 { /* 0x48070000, ap 30 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x70000 0x8>, + <0x70010 0x8>, + <0x70090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_I2C1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x70000 0x1000>; + + i2c1: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@72000 { /* 0x48072000, ap 32 1c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x72000 0x8>, + <0x72010 0x8>, + <0x72090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_I2C2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x72000 0x1000>; + + i2c2: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@78000 { /* 0x48078000, ap 39 12.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x78000 0x1000>; + }; + + target-module@7a000 { /* 0x4807a000, ap 81 2c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x7a000 0x8>, + <0x7a010 0x8>, + <0x7a090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_I2C4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x7a000 0x1000>; + + i2c4: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@7c000 { /* 0x4807c000, ap 83 34.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x7c000 0x8>, + <0x7c010 0x8>, + <0x7c090 0x8>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_I2C5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x7c000 0x1000>; + + i2c5: i2c@0 { + compatible = "ti,omap4-i2c"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + }; + }; + + target-module@86000 { /* 0x48086000, ap 41 5e.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x86000 0x4>, + <0x86010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER10_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x86000 0x1000>; + + timer10: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER10_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + target-module@88000 { /* 0x48088000, ap 43 66.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + reg = <0x88000 0x4>, + <0x88010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_TIMER11_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x88000 0x1000>; + + timer11: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&l4per_clkctrl OMAP5_TIMER11_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-pwm; + }; + }; + + rng_target: target-module@90000 { /* 0x48090000, ap 55 1a.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x91fe0 0x4>, + <0x91fe4 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (P, C): l4per_pwrdm, l4sec_clkdm */ + clocks = <&l4sec_clkctrl OMAP5_RNG_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x90000 0x2000>; + + rng: rng@0 { + compatible = "ti,omap4-rng"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@98000 { /* 0x48098000, ap 47 08.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x98000 0x4>, + <0x98010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MCSPI1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x98000 0x1000>; + + mcspi1: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <4>; + dmas = <&sdma 35>, + <&sdma 36>, + <&sdma 37>, + <&sdma 38>, + <&sdma 39>, + <&sdma 40>, + <&sdma 41>, + <&sdma 42>; + dma-names = "tx0", "rx0", "tx1", "rx1", + "tx2", "rx2", "tx3", "rx3"; + }; + }; + + target-module@9a000 { /* 0x4809a000, ap 49 10.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9a000 0x4>, + <0x9a010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MCSPI2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9a000 0x1000>; + + mcspi2: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 43>, + <&sdma 44>, + <&sdma 45>, + <&sdma 46>; + dma-names = "tx0", "rx0", "tx1", "rx1"; + }; + }; + + target-module@9c000 { /* 0x4809c000, ap 51 3a.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x9c000 0x4>, + <0x9c010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_MMC1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x9c000 0x1000>; + + mmc1: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; + ti,dual-volt; + ti,needs-special-reset; + dmas = <&sdma 61>, <&sdma 62>; + dma-names = "tx", "rx"; + pbias-supply = <&pbias_mmc_reg>; + }; + }; + + target-module@a2000 { /* 0x480a2000, ap 75 02.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa2000 0x1000>; + }; + + target-module@a4000 { /* 0x480a4000, ap 57 3c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x000a4000 0x00001000>, + <0x00001000 0x000a5000 0x00001000>; + }; + + target-module@a8000 { /* 0x480a8000, ap 59 2a.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa8000 0x4000>; + }; + + target-module@ad000 { /* 0x480ad000, ap 61 20.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xad000 0x4>, + <0xad010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MMC3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xad000 0x1000>; + + mmc3: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 77>, <&sdma 78>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b2000 { /* 0x480b2000, ap 37 0c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb2000 0x1000>; + }; + + target-module@b4000 { /* 0x480b4000, ap 65 42.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb4000 0x4>, + <0xb4010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, l3init_pwrdm, l3init_clkdm */ + clocks = <&l3init_clkctrl OMAP5_MMC2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb4000 0x1000>; + + mmc2: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 47>, <&sdma 48>; + dma-names = "tx", "rx"; + }; + }; + + target-module@b8000 { /* 0x480b8000, ap 67 32.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xb8000 0x4>, + <0xb8010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MCSPI3_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xb8000 0x1000>; + + mcspi3: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <2>; + dmas = <&sdma 15>, <&sdma 16>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@ba000 { /* 0x480ba000, ap 69 18.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xba000 0x4>, + <0xba010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MCSPI4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xba000 0x1000>; + + mcspi4: spi@0 { + compatible = "ti,omap4-mcspi"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <0>; + ti,spi-num-cs = <1>; + dmas = <&sdma 70>, <&sdma 71>; + dma-names = "tx0", "rx0"; + }; + }; + + target-module@d1000 { /* 0x480d1000, ap 71 28.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd1000 0x4>, + <0xd1010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MMC4_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd1000 0x1000>; + + mmc4: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 57>, <&sdma 58>; + dma-names = "tx", "rx"; + }; + }; + + target-module@d5000 { /* 0x480d5000, ap 73 30.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xd5000 0x4>, + <0xd5010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): core, core_pwrdm, l4per_clkdm */ + clocks = <&l4per_clkctrl OMAP5_MMC5_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xd5000 0x1000>; + + mmc5: mmc@0 { + compatible = "ti,omap4-hsmmc"; + reg = <0x0 0x400>; + interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>; + ti,needs-special-reset; + dmas = <&sdma 59>, <&sdma 60>; + dma-names = "tx", "rx"; + }; + }; + }; + + segment@200000 { /* 0x48200000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + }; +}; + +&l4_wkup { /* 0x4ae00000 */ + compatible = "ti,omap5-l4-wkup", "simple-bus"; + reg = <0x4ae00000 0x800>, + <0x4ae00800 0x800>, + <0x4ae01000 0x1000>; + reg-names = "ap", "la", "ia0"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x4ae00000 0x010000>, /* segment 0 */ + <0x00010000 0x4ae10000 0x010000>, /* segment 1 */ + <0x00020000 0x4ae20000 0x010000>; /* segment 2 */ + + segment@0 { /* 0x4ae00000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00000000 0x000800>, /* ap 0 */ + <0x00001000 0x00001000 0x001000>, /* ap 1 */ + <0x00000800 0x00000800 0x000800>, /* ap 2 */ + <0x00006000 0x00006000 0x002000>, /* ap 3 */ + <0x00008000 0x00008000 0x001000>, /* ap 4 */ + <0x0000a000 0x0000a000 0x001000>, /* ap 15 */ + <0x0000b000 0x0000b000 0x001000>, /* ap 16 */ + <0x00004000 0x00004000 0x001000>, /* ap 17 */ + <0x00005000 0x00005000 0x001000>, /* ap 18 */ + <0x0000c000 0x0000c000 0x001000>, /* ap 19 */ + <0x0000d000 0x0000d000 0x001000>; /* ap 20 */ + + target-module@4000 { /* 0x4ae04000, ap 17 20.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + ti,hwmods = "counter_32k"; + reg = <0x4000 0x4>, + <0x4010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>; + /* Domains (V, P, C): wkup, wkupaon_pwrdm, wkupaon_clkdm */ + clocks = <&wkupaon_clkctrl OMAP5_COUNTER_32K_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + counter32k: counter@0 { + compatible = "ti,omap-counter32k"; + reg = <0x0 0x40>; + }; + }; + + target-module@6000 { /* 0x4ae06000, ap 3 08.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x6000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x6000 0x2000>; + + prm: prm@0 { + compatible = "ti,omap5-prm", "simple-bus"; + reg = <0x0 0x2000>; + interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x2000>; + + prm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + prm_clockdomains: clockdomains { + }; + }; + }; + + target-module@a000 { /* 0x4ae0a000, ap 15 2c.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xa000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xa000 0x1000>; + + scrm: scrm@0 { + compatible = "ti,omap5-scrm"; + reg = <0x0 0x1000>; + + scrm_clocks: clocks { + #address-cells = <1>; + #size-cells = <0>; + }; + + scrm_clockdomains: clockdomains { + }; + }; + }; + + target-module@c000 { /* 0x4ae0c000, ap 19 28.0 */ + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0xc000 0x4>; + reg-names = "rev"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + omap5_pmx_wkup: pinmux@840 { + compatible = "ti,omap5-padconf", + "pinctrl-single"; + reg = <0x840 0x003c>; + #address-cells = <1>; + #size-cells = <0>; + #pinctrl-cells = <1>; + #interrupt-cells = <1>; + interrupt-controller; + pinctrl-single,register-width = <16>; + pinctrl-single,function-mask = <0x7fff>; + }; + + omap5_scm_wkup_pad_conf: omap5_scm_wkup_pad_conf@da0 { + compatible = "ti,omap5-scm-wkup-pad-conf", + "simple-bus"; + reg = <0xda0 0x60>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x60>; + + scm_wkup_pad_conf: scm_conf@0 { + compatible = "syscon", "simple-bus"; + reg = <0x0 0x60>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x0 0x60>; + + scm_wkup_pad_conf_clocks: clocks@0 { + #address-cells = <1>; + #size-cells = <0>; + }; + }; + }; + }; + }; + + segment@10000 { /* 0x4ae10000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00010000 0x001000>, /* ap 5 */ + <0x00001000 0x00011000 0x001000>, /* ap 6 */ + <0x00004000 0x00014000 0x001000>, /* ap 7 */ + <0x00005000 0x00015000 0x001000>, /* ap 8 */ + <0x00008000 0x00018000 0x001000>, /* ap 9 */ + <0x00009000 0x00019000 0x001000>, /* ap 10 */ + <0x0000c000 0x0001c000 0x001000>, /* ap 11 */ + <0x0000d000 0x0001d000 0x001000>; /* ap 12 */ + + target-module@0 { /* 0x4ae10000, ap 5 10.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x0 0x4>, + <0x10 0x4>, + <0x114 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wkup, wkupaon_pwrdm, wkupaon_clkdm */ + clocks = <&wkupaon_clkctrl OMAP5_GPIO1_CLKCTRL 0>, + <&wkupaon_clkctrl OMAP5_GPIO1_CLKCTRL 8>; + clock-names = "fck", "dbclk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + + gpio1: gpio@0 { + compatible = "ti,omap4-gpio"; + reg = <0x0 0x200>; + interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; + ti,gpio-always-on; + gpio-controller; + #gpio-cells = <2>; + interrupt-controller; + #interrupt-cells = <2>; + }; + }; + + target-module@4000 { /* 0x4ae14000, ap 7 14.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x4000 0x4>, + <0x4010 0x4>, + <0x4014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,syss-mask = <1>; + /* Domains (V, P, C): wkup, wkupaon_pwrdm, wkupaon_clkdm */ + clocks = <&wkupaon_clkctrl OMAP5_WD_TIMER2_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x4000 0x1000>; + + wdt2: wdt@0 { + compatible = "ti,omap5-wdt", "ti,omap3-wdt"; + reg = <0x0 0x80>; + interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; + }; + }; + + target-module@8000 { /* 0x4ae18000, ap 9 18.0 */ + compatible = "ti,sysc-omap4-timer", "ti,sysc"; + ti,hwmods = "timer1"; + reg = <0x8000 0x4>, + <0x8010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP4_FREEEMU | + SYSC_OMAP4_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + /* Domains (V, P, C): wkup, wkupaon_pwrdm, wkupaon_clkdm */ + clocks = <&wkupaon_clkctrl OMAP5_TIMER1_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x8000 0x1000>; + + timer1: timer@0 { + compatible = "ti,omap5430-timer"; + reg = <0x0 0x80>; + clocks = <&wkupaon_clkctrl OMAP5_TIMER1_CLKCTRL 24>; + clock-names = "fck"; + interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; + ti,timer-alwon; + }; + }; + + target-module@c000 { /* 0x4ae1c000, ap 11 1c.0 */ + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0xc000 0x4>, + <0xc010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-mask = <(SYSC_OMAP2_EMUFREE | + SYSC_OMAP2_SOFTRESET)>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + /* Domains (V, P, C): wkup, wkupaon_pwrdm, wkupaon_clkdm */ + clocks = <&wkupaon_clkctrl OMAP5_KBD_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0xc000 0x1000>; + + keypad: keypad@0 { + compatible = "ti,omap4-keypad"; + reg = <0x0 0x400>; + }; + }; + }; + + segment@20000 { /* 0x4ae20000 */ + compatible = "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00006000 0x00026000 0x001000>, /* ap 13 */ + <0x0000a000 0x0002a000 0x001000>, /* ap 14 */ + <0x00000000 0x00020000 0x001000>, /* ap 21 */ + <0x00001000 0x00021000 0x001000>, /* ap 22 */ + <0x00002000 0x00022000 0x001000>, /* ap 23 */ + <0x00003000 0x00023000 0x001000>, /* ap 24 */ + <0x00007000 0x00027000 0x000400>, /* ap 25 */ + <0x00008000 0x00028000 0x000800>, /* ap 26 */ + <0x00009000 0x00029000 0x000100>, /* ap 27 */ + <0x00008800 0x00028800 0x000200>, /* ap 28 */ + <0x00008a00 0x00028a00 0x000100>; /* ap 29 */ + + target-module@0 { /* 0x4ae20000, ap 21 04.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x0 0x1000>; + }; + + target-module@2000 { /* 0x4ae22000, ap 23 0c.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x0 0x2000 0x1000>; + }; + + target-module@6000 { /* 0x4ae26000, ap 13 24.0 */ + compatible = "ti,sysc"; + status = "disabled"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0x00000000 0x00006000 0x00001000>, + <0x00001000 0x00007000 0x00000400>, + <0x00002000 0x00008000 0x00000800>, + <0x00002800 0x00008800 0x00000200>, + <0x00002a00 0x00008a00 0x00000100>, + <0x00003000 0x00009000 0x00000100>; + }; + }; +}; + diff --git a/arch/arm/dts/omap5-uevm.dts b/arch/arm/dts/omap5-uevm.dts new file mode 100644 index 0000000000..9441e9a572 --- /dev/null +++ b/arch/arm/dts/omap5-uevm.dts @@ -0,0 +1,200 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ + */ +/dts-v1/; + +#include "omap5-board-common.dtsi" + +/ { + model = "TI OMAP5 uEVM board"; + compatible = "ti,omap5-uevm", "ti,omap5"; + + memory@80000000 { + device_type = "memory"; + reg = <0 0x80000000 0 0x7f000000>; /* 2032 MB */ + }; + + aliases { + ethernet = ðernet; + }; + + leds { + compatible = "gpio-leds"; + led1 { + label = "omap5:blue:usr1"; + gpios = <&gpio5 25 GPIO_ACTIVE_HIGH>; /* gpio5_153 D1 LED */ + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + }; + + evm_keys { + compatible = "gpio-keys"; + + pinctrl-names = "default"; + pinctrl-0 = <&evm_keys_pins>; + + #address-cells = <7>; + #size-cells = <0>; + + btn1 { + label = "BTN1"; + linux,code = <169>; + gpios = <&gpio3 19 GPIO_ACTIVE_LOW>; /* gpio3_83 */ + wakeup-source; + autorepeat; + debounce-interval = <50>; + }; + }; + + evm_leds { + compatible = "gpio-leds"; + + led1 { + label = "omap5:red:led"; + gpios = <&gpio9 17 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc0"; + default-state = "off"; + }; + + led2 { + label = "omap5:green:led"; + gpios = <&gpio9 18 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc1"; + default-state = "off"; + }; + + led3 { + label = "omap5:blue:led"; + gpios = <&gpio9 19 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "mmc2"; + default-state = "off"; + }; + + led4 { + label = "omap5:green:led1"; + gpios = <&gpio9 2 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led5 { + label = "omap5:green:led2"; + gpios = <&gpio9 3 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "default-on"; + default-state = "off"; + }; + + led6 { + label = "omap5:green:led3"; + gpios = <&gpio9 4 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + + led7 { + label = "omap5:green:led4"; + gpios = <&gpio9 5 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "default-on"; + default-state = "off"; + }; + + led8 { + label = "omap5:green:led5"; + gpios = <&gpio9 6 GPIO_ACTIVE_HIGH>; + linux,default-trigger = "heartbeat"; + default-state = "off"; + }; + }; +}; + +&hdmi { + vdda-supply = <&ldo4_reg>; +}; + +&i2c1 { + eeprom@50 { + compatible = "atmel,24c02"; + reg = <0x50>; + }; +}; + +&i2c5 { + pinctrl-names = "default"; + pinctrl-0 = <&i2c5_pins>; + + clock-frequency = <400000>; + + gpio9: gpio@22 { + compatible = "ti,tca6424"; + reg = <0x22>; + gpio-controller; + #gpio-cells = <2>; + }; +}; + +&mmc1 { + pinctrl-names = "default"; + pinctrl-0 = <&mmc1_pins>; + + cd-gpios = <&gpio5 24 GPIO_ACTIVE_LOW>; /* gpio5_152 */ +}; + +&omap5_pmx_core { + evm_keys_pins: pinmux_evm_keys_gpio_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x0b6, PIN_INPUT | MUX_MODE6) /* gpio3_83 */ + >; + }; + + i2c5_pins: pinmux_i2c5_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1c6, PIN_INPUT | MUX_MODE0) /* i2c5_scl */ + OMAP5_IOPAD(0x1c8, PIN_INPUT | MUX_MODE0) /* i2c5_sda */ + >; + }; + + mmc1_pins: pinmux_mmc1_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1d4, PIN_INPUT_PULLUP | MUX_MODE6) /* gpio5_152 */ + >; + }; +}; + +&tpd12s015 { + gpios = <&gpio9 0 GPIO_ACTIVE_HIGH>, /* TCA6424A P01, CT CP HPD */ + <&gpio9 1 GPIO_ACTIVE_HIGH>, /* TCA6424A P00, LS OE */ + <&gpio7 1 GPIO_ACTIVE_HIGH>; /* GPIO 193, HPD */ +}; + +&twl6040 { + ti,audpwron-gpio = <&gpio5 13 GPIO_ACTIVE_HIGH>; /* gpio line 141 */ +}; + +&twl6040_pins { + pinctrl-single,pins = < + OMAP5_IOPAD(0x1be, PIN_OUTPUT | MUX_MODE6) /* mcspi1_somi.gpio5_141 */ + >; +}; + +&usbhsehci { + #address-cells = <1>; + #size-cells = <0>; + + hub@2 { + compatible = "usb424,3503"; + reg = <2>; + #address-cells = <1>; + #size-cells = <0>; + }; + + ethernet: usbether@3 { + compatible = "usb424,9730"; + reg = <3>; + }; +}; + +&wlcore { + compatible = "ti,wl1837"; +}; diff --git a/arch/arm/dts/omap5.dtsi b/arch/arm/dts/omap5.dtsi new file mode 100644 index 0000000000..2ac7f021c2 --- /dev/null +++ b/arch/arm/dts/omap5.dtsi @@ -0,0 +1,583 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/ + * + * Based on "omap4.dtsi" + */ + +#include <dt-bindings/bus/ti-sysc.h> +#include <dt-bindings/gpio/gpio.h> +#include <dt-bindings/interrupt-controller/arm-gic.h> +#include <dt-bindings/pinctrl/omap.h> +#include <dt-bindings/clock/omap5.h> + +/ { + #address-cells = <2>; + #size-cells = <2>; + + compatible = "ti,omap5"; + interrupt-parent = <&wakeupgen>; + chosen { }; + + aliases { + i2c0 = &i2c1; + i2c1 = &i2c2; + i2c2 = &i2c3; + i2c3 = &i2c4; + i2c4 = &i2c5; + serial0 = &uart1; + serial1 = &uart2; + serial2 = &uart3; + serial3 = &uart4; + serial4 = &uart5; + serial5 = &uart6; + }; + + cpus { + #address-cells = <1>; + #size-cells = <0>; + + cpu0: cpu@0 { + device_type = "cpu"; + compatible = "arm,cortex-a15"; + reg = <0x0>; + + operating-points = < + /* kHz uV */ + 1000000 1060000 + 1500000 1250000 + >; + + clocks = <&dpll_mpu_ck>; + clock-names = "cpu"; + + clock-latency = <300000>; /* From omap-cpufreq driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + cpu@1 { + device_type = "cpu"; + compatible = "arm,cortex-a15"; + reg = <0x1>; + + operating-points = < + /* kHz uV */ + 1000000 1060000 + 1500000 1250000 + >; + + clocks = <&dpll_mpu_ck>; + clock-names = "cpu"; + + clock-latency = <300000>; /* From omap-cpufreq driver */ + + /* cooling options */ + #cooling-cells = <2>; /* min followed by max */ + }; + }; + + thermal-zones { + #include "omap4-cpu-thermal.dtsi" + #include "omap5-gpu-thermal.dtsi" + #include "omap5-core-thermal.dtsi" + }; + + timer { + compatible = "arm,armv7-timer"; + /* PPI secure/nonsecure IRQ */ + interrupts = <GIC_PPI 13 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 14 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 11 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_LOW)>, + <GIC_PPI 10 (GIC_CPU_MASK_RAW(3) | IRQ_TYPE_LEVEL_LOW)>; + interrupt-parent = <&gic>; + }; + + pmu { + compatible = "arm,cortex-a15-pmu"; + interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH>; + }; + + gic: interrupt-controller@48211000 { + compatible = "arm,cortex-a15-gic"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0 0x48211000 0 0x1000>, + <0 0x48212000 0 0x2000>, + <0 0x48214000 0 0x2000>, + <0 0x48216000 0 0x2000>; + interrupt-parent = <&gic>; + }; + + wakeupgen: interrupt-controller@48281000 { + compatible = "ti,omap5-wugen-mpu", "ti,omap4-wugen-mpu"; + interrupt-controller; + #interrupt-cells = <3>; + reg = <0 0x48281000 0 0x1000>; + interrupt-parent = <&gic>; + }; + + /* + * The soc node represents the soc top level view. It is used for IPs + * that are not memory mapped in the MPU view or for the MPU itself. + */ + soc { + compatible = "ti,omap-infra"; + mpu { + compatible = "ti,omap4-mpu"; + ti,hwmods = "mpu"; + sram = <&ocmcram>; + }; + }; + + /* + * XXX: Use a flat representation of the OMAP3 interconnect. + * The real OMAP interconnect network is quite complex. + * Since it will not bring real advantage to represent that in DT for + * the moment, just use a fake OCP bus entry to represent the whole bus + * hierarchy. + */ + ocp { + compatible = "ti,omap5-l3-noc", "simple-bus"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0 0xc0000000>; + dma-ranges = <0x80000000 0x0 0x80000000 0x80000000>; + ti,hwmods = "l3_main_1", "l3_main_2", "l3_main_3"; + reg = <0 0x44000000 0 0x2000>, + <0 0x44800000 0 0x3000>, + <0 0x45000000 0 0x4000>; + interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>, + <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; + + l4_wkup: interconnect@4ae00000 { + }; + + l4_cfg: interconnect@4a000000 { + }; + + l4_per: interconnect@48000000 { + }; + + l4_abe: interconnect@40100000 { + }; + + ocmcram: sram@40300000 { + compatible = "mmio-sram"; + reg = <0x40300000 0x20000>; /* 128k */ + }; + + gpmc: gpmc@50000000 { + compatible = "ti,omap4430-gpmc"; + reg = <0x50000000 0x1000>; + #address-cells = <2>; + #size-cells = <1>; + interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; + dmas = <&sdma 4>; + dma-names = "rxtx"; + gpmc,num-cs = <8>; + gpmc,num-waitpins = <4>; + ti,hwmods = "gpmc"; + clocks = <&l3_iclk_div>; + clock-names = "fck"; + interrupt-controller; + #interrupt-cells = <2>; + gpio-controller; + #gpio-cells = <2>; + }; + + target-module@55082000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x55082000 0x4>, + <0x55082010 0x4>, + <0x55082014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + clocks = <&ipu_clkctrl OMAP5_MMU_IPU_CLKCTRL 0>; + clock-names = "fck"; + resets = <&prm_core 2>; + reset-names = "rstctrl"; + ranges = <0x0 0x55082000 0x100>; + #size-cells = <1>; + #address-cells = <1>; + + mmu_ipu: mmu@0 { + compatible = "ti,omap4-iommu"; + reg = <0x0 0x100>; + interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; + #iommu-cells = <0>; + ti,iommu-bus-err-back; + }; + }; + + dmm@4e000000 { + compatible = "ti,omap5-dmm"; + reg = <0x4e000000 0x800>; + interrupts = <0 113 0x4>; + ti,hwmods = "dmm"; + }; + + emif1: emif@4c000000 { + compatible = "ti,emif-4d5"; + ti,hwmods = "emif1"; + ti,no-idle-on-init; + phy-type = <2>; /* DDR PHY type: Intelli PHY */ + reg = <0x4c000000 0x400>; + interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + emif2: emif@4d000000 { + compatible = "ti,emif-4d5"; + ti,hwmods = "emif2"; + ti,no-idle-on-init; + phy-type = <2>; /* DDR PHY type: Intelli PHY */ + reg = <0x4d000000 0x400>; + interrupts = <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH>; + hw-caps-read-idle-ctrl; + hw-caps-ll-interface; + hw-caps-temp-alert; + }; + + bandgap: bandgap@4a0021e0 { + reg = <0x4a0021e0 0xc + 0x4a00232c 0xc + 0x4a002380 0x2c + 0x4a0023C0 0x3c>; + interrupts = <GIC_SPI 126 IRQ_TYPE_LEVEL_HIGH>; + compatible = "ti,omap5430-bandgap"; + + #thermal-sensor-cells = <1>; + }; + + /* OCP2SCP3 */ + sata: sata@4a141100 { + compatible = "snps,dwc-ahci"; + reg = <0x4a140000 0x1100>, <0x4a141100 0x7>; + interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; + phys = <&sata_phy>; + phy-names = "sata-phy"; + clocks = <&l3init_clkctrl OMAP5_SATA_CLKCTRL 8>; + ti,hwmods = "sata"; + ports-implemented = <0x1>; + }; + + target-module@56000000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x5600fe00 0x4>, + <0x5600fe10 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + clocks = <&gpu_clkctrl OMAP5_GPU_CLKCTRL 0>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x56000000 0x2000000>; + + /* + * Closed source PowerVR driver, no child device + * binding or driver in mainline + */ + }; + + target-module@58000000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x58000000 4>, + <0x58000014 4>; + reg-names = "rev", "syss"; + ti,syss-mask = <1>; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 0>, + <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 9>, + <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 10>, + <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 11>; + clock-names = "fck", "hdmi_clk", "sys_clk", "tv_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x58000000 0x1000000>; + + dss: dss@0 { + compatible = "ti,omap5-dss"; + reg = <0 0x80>; + status = "disabled"; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0 0x1000000>; + + target-module@1000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x1000 0x4>, + <0x1010 0x4>, + <0x1014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-midle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x1000>; + + dispc@0 { + compatible = "ti,omap5-dispc"; + reg = <0 0x1000>; + interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + }; + }; + + target-module@2000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x2000 0x4>, + <0x2010 0x4>, + <0x2014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x2000 0x1000>; + + rfbi: encoder@0 { + compatible = "ti,omap5-rfbi"; + reg = <0 0x100>; + status = "disabled"; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>, <&l3_iclk_div>; + clock-names = "fck", "ick"; + }; + }; + + target-module@5000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x5000 0x4>, + <0x5010 0x4>, + <0x5014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x5000 0x1000>; + + dsi1: encoder@0 { + compatible = "ti,omap5-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x40>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + }; + }; + + target-module@9000 { + compatible = "ti,sysc-omap2", "ti,sysc"; + reg = <0x9000 0x4>, + <0x9010 0x4>, + <0x9014 0x4>; + reg-names = "rev", "sysc", "syss"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>; + ti,sysc-mask = <(SYSC_OMAP2_CLOCKACTIVITY | + SYSC_OMAP2_ENAWAKEUP | + SYSC_OMAP2_SOFTRESET | + SYSC_OMAP2_AUTOIDLE)>; + ti,syss-mask = <1>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x9000 0x1000>; + + dsi2: encoder@0 { + compatible = "ti,omap5-dsi"; + reg = <0 0x200>, + <0x200 0x40>, + <0x300 0x40>; + reg-names = "proto", "phy", "pll"; + interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck"; + }; + }; + + target-module@40000 { + compatible = "ti,sysc-omap4", "ti,sysc"; + reg = <0x40000 0x4>, + <0x40010 0x4>; + reg-names = "rev", "sysc"; + ti,sysc-sidle = <SYSC_IDLE_FORCE>, + <SYSC_IDLE_NO>, + <SYSC_IDLE_SMART>, + <SYSC_IDLE_SMART_WKUP>; + ti,sysc-mask = <(SYSC_OMAP4_SOFTRESET)>; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 9>, + <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 8>; + clock-names = "fck", "dss_clk"; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x40000 0x40000>; + + hdmi: encoder@0 { + compatible = "ti,omap5-hdmi"; + reg = <0 0x200>, + <0x200 0x80>, + <0x300 0x80>, + <0x20000 0x19000>; + reg-names = "wp", "pll", "phy", "core"; + interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; + status = "disabled"; + clocks = <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 9>, + <&dss_clkctrl OMAP5_DSS_CORE_CLKCTRL 10>; + clock-names = "fck", "sys_clk"; + dmas = <&sdma 76>; + dma-names = "audio_tx"; + }; + }; + }; + }; + + abb_mpu: regulator-abb-mpu { + compatible = "ti,abb-v2"; + regulator-name = "abb_mpu"; + #address-cells = <0>; + #size-cells = <0>; + clocks = <&sys_clkin>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + reg = <0x4ae07cdc 0x8>, <0x4ae06014 0x4>, + <0x4a0021c4 0x8>, <0x4ae0c318 0x4>; + reg-names = "base-address", "int-address", + "efuse-address", "ldo-address"; + ti,tranxdone-status-mask = <0x80>; + /* LDOVBBMPU_MUX_CTRL */ + ti,ldovbb-override-mask = <0x400>; + /* LDOVBBMPU_VSET_OUT */ + ti,ldovbb-vset-mask = <0x1F>; + + /* + * NOTE: only FBB mode used but actual vset will + * determine final biasing + */ + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1060000 0 0x0 0 0x02000000 0x01F00000 + 1250000 0 0x4 0 0x02000000 0x01F00000 + >; + }; + + abb_mm: regulator-abb-mm { + compatible = "ti,abb-v2"; + regulator-name = "abb_mm"; + #address-cells = <0>; + #size-cells = <0>; + clocks = <&sys_clkin>; + ti,settling-time = <50>; + ti,clock-cycles = <16>; + + reg = <0x4ae07ce4 0x8>, <0x4ae06010 0x4>, + <0x4a0021a4 0x8>, <0x4ae0c314 0x4>; + reg-names = "base-address", "int-address", + "efuse-address", "ldo-address"; + ti,tranxdone-status-mask = <0x80000000>; + /* LDOVBBMM_MUX_CTRL */ + ti,ldovbb-override-mask = <0x400>; + /* LDOVBBMM_VSET_OUT */ + ti,ldovbb-vset-mask = <0x1F>; + + /* + * NOTE: only FBB mode used but actual vset will + * determine final biasing + */ + ti,abb_info = < + /*uV ABB efuse rbb_m fbb_m vset_m*/ + 1025000 0 0x0 0 0x02000000 0x01F00000 + 1120000 0 0x4 0 0x02000000 0x01F00000 + >; + }; + }; +}; + +&cpu_thermal { + polling-delay = <500>; /* milliseconds */ + coefficients = <65 (-1791)>; +}; + +#include "omap5-l4.dtsi" +#include "omap54xx-clocks.dtsi" + +&gpu_thermal { + coefficients = <117 (-2992)>; +}; + +&core_thermal { + coefficients = <0 2000>; +}; + +#include "omap5-l4-abe.dtsi" +#include "omap54xx-clocks.dtsi" + +&prm { + prm_dsp: prm@400 { + compatible = "ti,omap5-prm-inst", "ti,omap-prm-inst"; + reg = <0x400 0x100>; + #reset-cells = <1>; + }; + + prm_core: prm@700 { + compatible = "ti,omap5-prm-inst", "ti,omap-prm-inst"; + reg = <0x700 0x100>; + #reset-cells = <1>; + }; + + prm_iva: prm@1200 { + compatible = "ti,omap5-prm-inst", "ti,omap-prm-inst"; + reg = <0x1200 0x100>; + #reset-cells = <1>; + }; + + prm_device: prm@1c00 { + compatible = "ti,omap5-prm-inst", "ti,omap-prm-inst"; + reg = <0x1c00 0x100>; + #reset-cells = <1>; + }; +}; diff --git a/arch/arm/dts/omap54xx-clocks.dtsi b/arch/arm/dts/omap54xx-clocks.dtsi new file mode 100644 index 0000000000..42f2c44772 --- /dev/null +++ b/arch/arm/dts/omap54xx-clocks.dtsi @@ -0,0 +1,1208 @@ +// SPDX-License-Identifier: GPL-2.0-only +/* + * Device Tree Source for OMAP5 clock data + * + * Copyright (C) 2013 Texas Instruments, Inc. + */ +&cm_core_aon_clocks { + pad_clks_src_ck: pad_clks_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + pad_clks_ck: pad_clks_ck@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&pad_clks_src_ck>; + ti,bit-shift = <8>; + reg = <0x0108>; + }; + + secure_32k_clk_src_ck: secure_32k_clk_src_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + slimbus_src_clk: slimbus_src_clk { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + slimbus_clk: slimbus_clk@108 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&slimbus_src_clk>; + ti,bit-shift = <10>; + reg = <0x0108>; + }; + + sys_32k_ck: sys_32k_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <32768>; + }; + + virt_12000000_ck: virt_12000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <12000000>; + }; + + virt_13000000_ck: virt_13000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <13000000>; + }; + + virt_16800000_ck: virt_16800000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <16800000>; + }; + + virt_19200000_ck: virt_19200000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <19200000>; + }; + + virt_26000000_ck: virt_26000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <26000000>; + }; + + virt_27000000_ck: virt_27000000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <27000000>; + }; + + virt_38400000_ck: virt_38400000_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <38400000>; + }; + + xclk60mhsp1_ck: xclk60mhsp1_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + xclk60mhsp2_ck: xclk60mhsp2_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <60000000>; + }; + + dpll_abe_ck: dpll_abe_ck@1e0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-m4xen-clock"; + clocks = <&abe_dpll_clk_mux>, <&abe_dpll_bypass_clk_mux>; + reg = <0x01e0>, <0x01e4>, <0x01ec>, <0x01e8>; + }; + + dpll_abe_x2_ck: dpll_abe_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_abe_ck>; + }; + + dpll_abe_m2x2_ck: dpll_abe_m2x2_ck@1f0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + reg = <0x01f0>; + ti,index-starts-at-one; + }; + + abe_24m_fclk: abe_24m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <8>; + }; + + abe_clk: abe_clk@108 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_m2x2_ck>; + ti,max-div = <4>; + reg = <0x0108>; + ti,index-power-of-two; + }; + + abe_iclk: abe_iclk@528 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&aess_fclk>; + ti,bit-shift = <24>; + reg = <0x0528>; + ti,dividers = <2>, <1>; + }; + + abe_lp_clk_div: abe_lp_clk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + dpll_abe_m3x2_ck: dpll_abe_m3x2_ck@1f4 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_abe_x2_ck>; + ti,max-div = <31>; + reg = <0x01f4>; + ti,index-starts-at-one; + }; + + dpll_core_byp_mux: dpll_core_byp_mux@12c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&dpll_abe_m3x2_ck>; + ti,bit-shift = <23>; + reg = <0x012c>; + }; + + dpll_core_ck: dpll_core_ck@120 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-core-clock"; + clocks = <&sys_clkin>, <&dpll_core_byp_mux>; + reg = <0x0120>, <0x0124>, <0x012c>, <0x0128>; + }; + + dpll_core_x2_ck: dpll_core_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_core_ck>; + }; + + dpll_core_h21x2_ck: dpll_core_h21x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0150>; + ti,index-starts-at-one; + }; + + c2c_fclk: c2c_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_h21x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + c2c_iclk: c2c_iclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&c2c_fclk>; + clock-mult = <1>; + clock-div = <2>; + }; + + dpll_core_h11x2_ck: dpll_core_h11x2_ck@138 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0138>; + ti,index-starts-at-one; + }; + + dpll_core_h12x2_ck: dpll_core_h12x2_ck@13c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x013c>; + ti,index-starts-at-one; + }; + + dpll_core_h13x2_ck: dpll_core_h13x2_ck@140 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0140>; + ti,index-starts-at-one; + }; + + dpll_core_h14x2_ck: dpll_core_h14x2_ck@144 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0144>; + ti,index-starts-at-one; + }; + + dpll_core_h22x2_ck: dpll_core_h22x2_ck@154 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0154>; + ti,index-starts-at-one; + }; + + dpll_core_h23x2_ck: dpll_core_h23x2_ck@158 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x0158>; + ti,index-starts-at-one; + }; + + dpll_core_h24x2_ck: dpll_core_h24x2_ck@15c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <63>; + reg = <0x015c>; + ti,index-starts-at-one; + }; + + dpll_core_m2_ck: dpll_core_m2_ck@130 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_ck>; + ti,max-div = <31>; + reg = <0x0130>; + ti,index-starts-at-one; + }; + + dpll_core_m3x2_ck: dpll_core_m3x2_ck@134 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_core_x2_ck>; + ti,max-div = <31>; + reg = <0x0134>; + ti,index-starts-at-one; + }; + + iva_dpll_hs_clk_div: iva_dpll_hs_clk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_h12x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll_iva_byp_mux: dpll_iva_byp_mux@1ac { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&iva_dpll_hs_clk_div>; + ti,bit-shift = <23>; + reg = <0x01ac>; + }; + + dpll_iva_ck: dpll_iva_ck@1a0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin>, <&dpll_iva_byp_mux>; + reg = <0x01a0>, <0x01a4>, <0x01ac>, <0x01a8>; + assigned-clocks = <&dpll_iva_ck>; + assigned-clock-rates = <1165000000>; + }; + + dpll_iva_x2_ck: dpll_iva_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_iva_ck>; + }; + + dpll_iva_h11x2_ck: dpll_iva_h11x2_ck@1b8 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <63>; + reg = <0x01b8>; + ti,index-starts-at-one; + assigned-clocks = <&dpll_iva_h11x2_ck>; + assigned-clock-rates = <465920000>; + }; + + dpll_iva_h12x2_ck: dpll_iva_h12x2_ck@1bc { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_iva_x2_ck>; + ti,max-div = <63>; + reg = <0x01bc>; + ti,index-starts-at-one; + assigned-clocks = <&dpll_iva_h12x2_ck>; + assigned-clock-rates = <388300000>; + }; + + mpu_dpll_hs_clk_div: mpu_dpll_hs_clk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_core_h12x2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll_mpu_ck: dpll_mpu_ck@160 { + #clock-cells = <0>; + compatible = "ti,omap5-mpu-dpll-clock"; + clocks = <&sys_clkin>, <&mpu_dpll_hs_clk_div>; + reg = <0x0160>, <0x0164>, <0x016c>, <0x0168>; + }; + + dpll_mpu_m2_ck: dpll_mpu_m2_ck@170 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_mpu_ck>; + ti,max-div = <31>; + reg = <0x0170>; + ti,index-starts-at-one; + }; + + per_dpll_hs_clk_div: per_dpll_hs_clk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + usb_dpll_hs_clk_div: usb_dpll_hs_clk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_abe_m3x2_ck>; + clock-mult = <1>; + clock-div = <3>; + }; + + l3_iclk_div: l3_iclk_div@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + ti,max-div = <2>; + ti,bit-shift = <4>; + reg = <0x100>; + clocks = <&dpll_core_h12x2_ck>; + ti,index-power-of-two; + }; + + gpu_l3_iclk: gpu_l3_iclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&l3_iclk_div>; + clock-mult = <1>; + clock-div = <1>; + }; + + l4_root_clk_div: l4_root_clk_div@100 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + ti,max-div = <2>; + ti,bit-shift = <8>; + reg = <0x100>; + clocks = <&l3_iclk_div>; + ti,index-power-of-two; + }; + + slimbus1_slimbus_clk: slimbus1_slimbus_clk@560 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&slimbus_clk>; + ti,bit-shift = <11>; + reg = <0x0560>; + }; + + aess_fclk: aess_fclk@528 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&abe_clk>; + ti,bit-shift = <24>; + ti,max-div = <2>; + reg = <0x0528>; + }; + + mcasp_sync_mux_ck: mcasp_sync_mux_ck@540 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&abe_24m_fclk>, <&dss_syc_gfclk_div>, <&func_24m_clk>; + ti,bit-shift = <26>; + reg = <0x0540>; + }; + + mcasp_gfclk: mcasp_gfclk@540 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&mcasp_sync_mux_ck>, <&pad_clks_ck>, <&slimbus_clk>; + ti,bit-shift = <24>; + reg = <0x0540>; + }; + + dummy_ck: dummy_ck { + #clock-cells = <0>; + compatible = "fixed-clock"; + clock-frequency = <0>; + }; +}; +&prm_clocks { + sys_clkin: sys_clkin@110 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&virt_12000000_ck>, <&virt_13000000_ck>, <&virt_16800000_ck>, <&virt_19200000_ck>, <&virt_26000000_ck>, <&virt_27000000_ck>, <&virt_38400000_ck>; + reg = <0x0110>; + ti,index-starts-at-one; + }; + + abe_dpll_bypass_clk_mux: abe_dpll_bypass_clk_mux@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&sys_32k_ck>; + reg = <0x0108>; + }; + + abe_dpll_clk_mux: abe_dpll_clk_mux@10c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&sys_32k_ck>; + reg = <0x010c>; + }; + + custefuse_sys_gfclk_div: custefuse_sys_gfclk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_clkin>; + clock-mult = <1>; + clock-div = <2>; + }; + + dss_syc_gfclk_div: dss_syc_gfclk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&sys_clkin>; + clock-mult = <1>; + clock-div = <1>; + }; + + wkupaon_iclk_mux: wkupaon_iclk_mux@108 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&abe_lp_clk_div>; + reg = <0x0108>; + }; + + l3instr_ts_gclk_div: l3instr_ts_gclk_div { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&wkupaon_iclk_mux>; + clock-mult = <1>; + clock-div = <1>; + }; +}; + +&cm_core_clocks { + + dpll_per_byp_mux: dpll_per_byp_mux@14c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&per_dpll_hs_clk_div>; + ti,bit-shift = <23>; + reg = <0x014c>; + }; + + dpll_per_ck: dpll_per_ck@140 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin>, <&dpll_per_byp_mux>; + reg = <0x0140>, <0x0144>, <0x014c>, <0x0148>; + }; + + dpll_per_x2_ck: dpll_per_x2_ck { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-x2-clock"; + clocks = <&dpll_per_ck>; + }; + + dpll_per_h11x2_ck: dpll_per_h11x2_ck@158 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <63>; + reg = <0x0158>; + ti,index-starts-at-one; + }; + + dpll_per_h12x2_ck: dpll_per_h12x2_ck@15c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <63>; + reg = <0x015c>; + ti,index-starts-at-one; + }; + + dpll_per_h14x2_ck: dpll_per_h14x2_ck@164 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <63>; + reg = <0x0164>; + ti,index-starts-at-one; + }; + + dpll_per_m2_ck: dpll_per_m2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_ck>; + ti,max-div = <31>; + reg = <0x0150>; + ti,index-starts-at-one; + }; + + dpll_per_m2x2_ck: dpll_per_m2x2_ck@150 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + reg = <0x0150>; + ti,index-starts-at-one; + }; + + dpll_per_m3x2_ck: dpll_per_m3x2_ck@154 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_x2_ck>; + ti,max-div = <31>; + reg = <0x0154>; + ti,index-starts-at-one; + }; + + dpll_unipro1_ck: dpll_unipro1_ck@200 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin>, <&sys_clkin>; + reg = <0x0200>, <0x0204>, <0x020c>, <0x0208>; + }; + + dpll_unipro1_clkdcoldo: dpll_unipro1_clkdcoldo { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_unipro1_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll_unipro1_m2_ck: dpll_unipro1_m2_ck@210 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_unipro1_ck>; + ti,max-div = <127>; + reg = <0x0210>; + ti,index-starts-at-one; + }; + + dpll_unipro2_ck: dpll_unipro2_ck@1c0 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-clock"; + clocks = <&sys_clkin>, <&sys_clkin>; + reg = <0x01c0>, <0x01c4>, <0x01cc>, <0x01c8>; + }; + + dpll_unipro2_clkdcoldo: dpll_unipro2_clkdcoldo { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_unipro2_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll_unipro2_m2_ck: dpll_unipro2_m2_ck@1d0 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_unipro2_ck>; + ti,max-div = <127>; + reg = <0x01d0>; + ti,index-starts-at-one; + }; + + dpll_usb_byp_mux: dpll_usb_byp_mux@18c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&sys_clkin>, <&usb_dpll_hs_clk_div>; + ti,bit-shift = <23>; + reg = <0x018c>; + }; + + dpll_usb_ck: dpll_usb_ck@180 { + #clock-cells = <0>; + compatible = "ti,omap4-dpll-j-type-clock"; + clocks = <&sys_clkin>, <&dpll_usb_byp_mux>; + reg = <0x0180>, <0x0184>, <0x018c>, <0x0188>; + }; + + dpll_usb_clkdcoldo: dpll_usb_clkdcoldo { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_usb_ck>; + clock-mult = <1>; + clock-div = <1>; + }; + + dpll_usb_m2_ck: dpll_usb_m2_ck@190 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_ck>; + ti,max-div = <127>; + reg = <0x0190>; + ti,index-starts-at-one; + }; + + func_128m_clk: func_128m_clk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_h11x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + func_12m_fclk: func_12m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <16>; + }; + + func_24m_clk: func_24m_clk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_48m_fclk: func_48m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <4>; + }; + + func_96m_fclk: func_96m_fclk { + #clock-cells = <0>; + compatible = "fixed-factor-clock"; + clocks = <&dpll_per_m2x2_ck>; + clock-mult = <1>; + clock-div = <2>; + }; + + l3init_60m_fclk: l3init_60m_fclk@104 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_usb_m2_ck>; + reg = <0x0104>; + ti,dividers = <1>, <8>; + }; + + iss_ctrlclk: iss_ctrlclk@1320 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&func_96m_fclk>; + ti,bit-shift = <8>; + reg = <0x1320>; + }; + + lli_txphy_clk: lli_txphy_clk@f20 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll_unipro1_clkdcoldo>; + ti,bit-shift = <8>; + reg = <0x0f20>; + }; + + lli_txphy_ls_clk: lli_txphy_ls_clk@f20 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&dpll_unipro1_m2_ck>; + ti,bit-shift = <9>; + reg = <0x0f20>; + }; + + usb_phy_cm_clk32k: usb_phy_cm_clk32k@640 { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_32k_ck>; + ti,bit-shift = <8>; + reg = <0x0640>; + }; + + fdif_fclk: fdif_fclk@1328 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_h11x2_ck>; + ti,bit-shift = <24>; + ti,max-div = <2>; + reg = <0x1328>; + }; + + gpu_core_gclk_mux: gpu_core_gclk_mux@1520 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>; + ti,bit-shift = <24>; + reg = <0x1520>; + }; + + gpu_hyd_gclk_mux: gpu_hyd_gclk_mux@1520 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&dpll_core_h14x2_ck>, <&dpll_per_h14x2_ck>; + ti,bit-shift = <25>; + reg = <0x1520>; + }; + + hsi_fclk: hsi_fclk@1638 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&dpll_per_m2x2_ck>; + ti,bit-shift = <24>; + ti,max-div = <2>; + reg = <0x1638>; + }; +}; + +&cm_core_clockdomains { + l3init_clkdm: l3init_clkdm { + compatible = "ti,clockdomain"; + clocks = <&dpll_usb_ck>; + }; +}; + +&scrm_clocks { + auxclk0_src_gate_ck: auxclk0_src_gate_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0310>; + }; + + auxclk0_src_mux_ck: auxclk0_src_mux_ck@310 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0310>; + }; + + auxclk0_src_ck: auxclk0_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk0_src_gate_ck>, <&auxclk0_src_mux_ck>; + }; + + auxclk0_ck: auxclk0_ck@310 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk0_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0310>; + }; + + auxclk1_src_gate_ck: auxclk1_src_gate_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0314>; + }; + + auxclk1_src_mux_ck: auxclk1_src_mux_ck@314 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0314>; + }; + + auxclk1_src_ck: auxclk1_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk1_src_gate_ck>, <&auxclk1_src_mux_ck>; + }; + + auxclk1_ck: auxclk1_ck@314 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk1_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0314>; + }; + + auxclk2_src_gate_ck: auxclk2_src_gate_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0318>; + }; + + auxclk2_src_mux_ck: auxclk2_src_mux_ck@318 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0318>; + }; + + auxclk2_src_ck: auxclk2_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk2_src_gate_ck>, <&auxclk2_src_mux_ck>; + }; + + auxclk2_ck: auxclk2_ck@318 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk2_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0318>; + }; + + auxclk3_src_gate_ck: auxclk3_src_gate_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x031c>; + }; + + auxclk3_src_mux_ck: auxclk3_src_mux_ck@31c { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x031c>; + }; + + auxclk3_src_ck: auxclk3_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk3_src_gate_ck>, <&auxclk3_src_mux_ck>; + }; + + auxclk3_ck: auxclk3_ck@31c { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk3_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x031c>; + }; + + auxclk4_src_gate_ck: auxclk4_src_gate_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-no-wait-gate-clock"; + clocks = <&dpll_core_m3x2_ck>; + ti,bit-shift = <8>; + reg = <0x0320>; + }; + + auxclk4_src_mux_ck: auxclk4_src_mux_ck@320 { + #clock-cells = <0>; + compatible = "ti,composite-mux-clock"; + clocks = <&sys_clkin>, <&dpll_core_m3x2_ck>, <&dpll_per_m3x2_ck>; + ti,bit-shift = <1>; + reg = <0x0320>; + }; + + auxclk4_src_ck: auxclk4_src_ck { + #clock-cells = <0>; + compatible = "ti,composite-clock"; + clocks = <&auxclk4_src_gate_ck>, <&auxclk4_src_mux_ck>; + }; + + auxclk4_ck: auxclk4_ck@320 { + #clock-cells = <0>; + compatible = "ti,divider-clock"; + clocks = <&auxclk4_src_ck>; + ti,bit-shift = <16>; + ti,max-div = <16>; + reg = <0x0320>; + }; + + auxclkreq0_ck: auxclkreq0_ck@210 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>; + ti,bit-shift = <2>; + reg = <0x0210>; + }; + + auxclkreq1_ck: auxclkreq1_ck@214 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>; + ti,bit-shift = <2>; + reg = <0x0214>; + }; + + auxclkreq2_ck: auxclkreq2_ck@218 { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>; + ti,bit-shift = <2>; + reg = <0x0218>; + }; + + auxclkreq3_ck: auxclkreq3_ck@21c { + #clock-cells = <0>; + compatible = "ti,mux-clock"; + clocks = <&auxclk0_ck>, <&auxclk1_ck>, <&auxclk2_ck>, <&auxclk3_ck>, <&auxclk4_ck>; + ti,bit-shift = <2>; + reg = <0x021c>; + }; +}; + +&cm_core_aon { + mpu_cm: mpu_cm@300 { + compatible = "ti,omap4-cm"; + reg = <0x300 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x300 0x100>; + + mpu_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + dsp_cm: dsp_cm@400 { + compatible = "ti,omap4-cm"; + reg = <0x400 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x400 0x100>; + + dsp_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + abe_cm: abe_cm@500 { + compatible = "ti,omap4-cm"; + reg = <0x500 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x500 0x100>; + + abe_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x64>; + #clock-cells = <2>; + }; + }; + +}; + +&cm_core { + l3main1_cm: l3main1_cm@700 { + compatible = "ti,omap4-cm"; + reg = <0x700 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x700 0x100>; + + l3main1_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3main2_cm: l3main2_cm@800 { + compatible = "ti,omap4-cm"; + reg = <0x800 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x800 0x100>; + + l3main2_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + ipu_cm: ipu_cm@900 { + compatible = "ti,omap4-cm"; + reg = <0x900 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x900 0x100>; + + ipu_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + dma_cm: dma_cm@a00 { + compatible = "ti,omap4-cm"; + reg = <0xa00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xa00 0x100>; + + dma_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + emif_cm: emif_cm@b00 { + compatible = "ti,omap4-cm"; + reg = <0xb00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xb00 0x100>; + + emif_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x1c>; + #clock-cells = <2>; + }; + }; + + l4cfg_cm: l4cfg_cm@d00 { + compatible = "ti,omap4-cm"; + reg = <0xd00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xd00 0x100>; + + l4cfg_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x14>; + #clock-cells = <2>; + }; + }; + + l3instr_cm: l3instr_cm@e00 { + compatible = "ti,omap4-cm"; + reg = <0xe00 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0xe00 0x100>; + + l3instr_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xc>; + #clock-cells = <2>; + }; + }; + + l4per_cm: l4per_cm@1000 { + compatible = "ti,omap4-cm"; + reg = <0x1000 0x200>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1000 0x200>; + + l4per_clkctrl: clock@20 { + compatible = "ti,clkctrl-l4per", "ti,clkctrl"; + reg = <0x20 0x15c>; + #clock-cells = <2>; + }; + + l4sec_clkctrl: clock@1a0 { + compatible = "ti,clkctrl-l4sec", "ti,clkctrl"; + reg = <0x1a0 0x3c>; + #clock-cells = <2>; + }; + }; + + dss_cm: dss_cm@1400 { + compatible = "ti,omap4-cm"; + reg = <0x1400 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1400 0x100>; + + dss_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + gpu_cm: gpu_cm@1500 { + compatible = "ti,omap4-cm"; + reg = <0x1500 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1500 0x100>; + + gpu_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x4>; + #clock-cells = <2>; + }; + }; + + l3init_cm: l3init_cm@1600 { + compatible = "ti,omap4-cm"; + reg = <0x1600 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1600 0x100>; + + l3init_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0xd4>; + #clock-cells = <2>; + }; + }; +}; + +&prm { + wkupaon_cm: wkupaon_cm@1900 { + compatible = "ti,omap4-cm"; + reg = <0x1900 0x100>; + #address-cells = <1>; + #size-cells = <1>; + ranges = <0 0x1900 0x100>; + + wkupaon_clkctrl: clk@20 { + compatible = "ti,clkctrl"; + reg = <0x20 0x5c>; + #clock-cells = <2>; + }; + }; +}; + +&scm_wkup_pad_conf_clocks { + fref_xtal_ck: fref_xtal_ck { + #clock-cells = <0>; + compatible = "ti,gate-clock"; + clocks = <&sys_clkin>; + ti,bit-shift = <28>; + reg = <0x14>; + }; +}; diff --git a/include/dt-bindings/clock/omap5.h b/include/dt-bindings/clock/omap5.h new file mode 100644 index 0000000000..41775272fd --- /dev/null +++ b/include/dt-bindings/clock/omap5.h @@ -0,0 +1,129 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ +/* + * Copyright 2017 Texas Instruments, Inc. + */ +#ifndef __DT_BINDINGS_CLK_OMAP5_H +#define __DT_BINDINGS_CLK_OMAP5_H + +#define OMAP5_CLKCTRL_OFFSET 0x20 +#define OMAP5_CLKCTRL_INDEX(offset) ((offset) - OMAP5_CLKCTRL_OFFSET) + +/* mpu clocks */ +#define OMAP5_MPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* dsp clocks */ +#define OMAP5_MMU_DSP_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* abe clocks */ +#define OMAP5_L4_ABE_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_AESS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) +#define OMAP5_MCPDM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) +#define OMAP5_DMIC_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) +#define OMAP5_MCBSP1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x48) +#define OMAP5_MCBSP2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) +#define OMAP5_MCBSP3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x58) +#define OMAP5_TIMER5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) +#define OMAP5_TIMER6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x70) +#define OMAP5_TIMER7_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) +#define OMAP5_TIMER8_CLKCTRL OMAP5_CLKCTRL_INDEX(0x80) + +/* l3main1 clocks */ +#define OMAP5_L3_MAIN_1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* l3main2 clocks */ +#define OMAP5_L3_MAIN_2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* ipu clocks */ +#define OMAP5_MMU_IPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* dma clocks */ +#define OMAP5_DMA_SYSTEM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* emif clocks */ +#define OMAP5_DMM_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_EMIF1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) +#define OMAP5_EMIF2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) + +/* l4cfg clocks */ +#define OMAP5_L4_CFG_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_SPINLOCK_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) +#define OMAP5_MAILBOX_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) + +/* l3instr clocks */ +#define OMAP5_L3_MAIN_3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_L3_INSTR_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) + +/* l4per clocks */ +#define OMAP5_TIMER10_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) +#define OMAP5_TIMER11_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) +#define OMAP5_TIMER2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) +#define OMAP5_TIMER3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x40) +#define OMAP5_TIMER4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x48) +#define OMAP5_TIMER9_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) +#define OMAP5_GPIO2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x60) +#define OMAP5_GPIO3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) +#define OMAP5_GPIO4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x70) +#define OMAP5_GPIO5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) +#define OMAP5_GPIO6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x80) +#define OMAP5_I2C1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xa0) +#define OMAP5_I2C2_CLKCTRL OMAP5_CLKCTRL_INDEX(0xa8) +#define OMAP5_I2C3_CLKCTRL OMAP5_CLKCTRL_INDEX(0xb0) +#define OMAP5_I2C4_CLKCTRL OMAP5_CLKCTRL_INDEX(0xb8) +#define OMAP5_L4_PER_CLKCTRL OMAP5_CLKCTRL_INDEX(0xc0) +#define OMAP5_MCSPI1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf0) +#define OMAP5_MCSPI2_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf8) +#define OMAP5_MCSPI3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x100) +#define OMAP5_MCSPI4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x108) +#define OMAP5_GPIO7_CLKCTRL OMAP5_CLKCTRL_INDEX(0x110) +#define OMAP5_GPIO8_CLKCTRL OMAP5_CLKCTRL_INDEX(0x118) +#define OMAP5_MMC3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x120) +#define OMAP5_MMC4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x128) +#define OMAP5_UART1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x140) +#define OMAP5_UART2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x148) +#define OMAP5_UART3_CLKCTRL OMAP5_CLKCTRL_INDEX(0x150) +#define OMAP5_UART4_CLKCTRL OMAP5_CLKCTRL_INDEX(0x158) +#define OMAP5_MMC5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x160) +#define OMAP5_I2C5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x168) +#define OMAP5_UART5_CLKCTRL OMAP5_CLKCTRL_INDEX(0x170) +#define OMAP5_UART6_CLKCTRL OMAP5_CLKCTRL_INDEX(0x178) + +/* l4_secure clocks */ +#define OMAP5_L4_SECURE_CLKCTRL_OFFSET 0x1a0 +#define OMAP5_L4_SECURE_CLKCTRL_INDEX(offset) ((offset) - OMAP5_L4_SECURE_CLKCTRL_OFFSET) +#define OMAP5_AES1_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1a0) +#define OMAP5_AES2_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1a8) +#define OMAP5_DES3DES_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1b0) +#define OMAP5_FPKA_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1b8) +#define OMAP5_RNG_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1c0) +#define OMAP5_SHA2MD5_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1c8) +#define OMAP5_DMA_CRYPTO_CLKCTRL OMAP5_L4_SECURE_CLKCTRL_INDEX(0x1d8) + +/* iva clocks */ +#define OMAP5_IVA_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_SL2IF_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) + +/* dss clocks */ +#define OMAP5_DSS_CORE_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* gpu clocks */ +#define OMAP5_GPU_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) + +/* l3init clocks */ +#define OMAP5_MMC1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x28) +#define OMAP5_MMC2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) +#define OMAP5_USB_HOST_HS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x58) +#define OMAP5_USB_TLL_HS_CLKCTRL OMAP5_CLKCTRL_INDEX(0x68) +#define OMAP5_SATA_CLKCTRL OMAP5_CLKCTRL_INDEX(0x88) +#define OMAP5_OCP2SCP1_CLKCTRL OMAP5_CLKCTRL_INDEX(0xe0) +#define OMAP5_OCP2SCP3_CLKCTRL OMAP5_CLKCTRL_INDEX(0xe8) +#define OMAP5_USB_OTG_SS_CLKCTRL OMAP5_CLKCTRL_INDEX(0xf0) + +/* wkupaon clocks */ +#define OMAP5_L4_WKUP_CLKCTRL OMAP5_CLKCTRL_INDEX(0x20) +#define OMAP5_WD_TIMER2_CLKCTRL OMAP5_CLKCTRL_INDEX(0x30) +#define OMAP5_GPIO1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x38) +#define OMAP5_TIMER1_CLKCTRL OMAP5_CLKCTRL_INDEX(0x40) +#define OMAP5_COUNTER_32K_CLKCTRL OMAP5_CLKCTRL_INDEX(0x50) +#define OMAP5_KBD_CLKCTRL OMAP5_CLKCTRL_INDEX(0x78) + +#endif
Convert omap5 uevm board to device model.
Signed-off-by: Tero Kristo t-kristo@ti.com --- v3: * dropped SPI support
arch/arm/dts/omap5-u-boot.dtsi | 42 ++++++++++++++++++ board/ti/omap5_uevm/evm.c | 78 +++++----------------------------- configs/omap5_uevm_defconfig | 13 ++++-- 3 files changed, 62 insertions(+), 71 deletions(-)
diff --git a/arch/arm/dts/omap5-u-boot.dtsi b/arch/arm/dts/omap5-u-boot.dtsi index 39071e223d..5a1c7bc9fe 100644 --- a/arch/arm/dts/omap5-u-boot.dtsi +++ b/arch/arm/dts/omap5-u-boot.dtsi @@ -7,6 +7,7 @@ * Based on "dra7.dtsi" */
+#ifdef CONFIG_DRA7XX /{ chosen { tick-timer = &timer2; @@ -105,3 +106,44 @@ &i2c1 { u-boot,dm-spl; }; + +#else /* OMAP54XX */ +&l4_cfg { + segment@0 { + /* SCM Core */ + target-module@2000 { + compatible = "simple-bus"; + }; + + /* USB HS */ + target-module@64000 { + compatible = "simple-bus"; + }; + }; +}; + +&l4_per { + segment@0 { + /* UART3 */ + target-module@20000 { + compatible = "simple-bus"; + }; + + /* I2C1 */ + target-module@70000 { + compatible = "simple-bus"; + }; + + /* MMC1 */ + target-module@9c000 { + compatible = "simple-bus"; + }; + + /* MMC2 */ + target-module@b4000 { + compatible = "simple-bus"; + }; + }; +}; + +#endif diff --git a/board/ti/omap5_uevm/evm.c b/board/ti/omap5_uevm/evm.c index e35f319b46..319bb6aa64 100644 --- a/board/ti/omap5_uevm/evm.c +++ b/board/ti/omap5_uevm/evm.c @@ -12,6 +12,7 @@ #include <asm/arch/omap.h> #include <asm/arch/sys_proto.h> #include <asm/arch/mmc_host_def.h> +#include <serial.h> #include <tca642x.h> #include <usb.h> #include <linux/delay.h> @@ -149,39 +150,21 @@ int board_init(void) return 0; }
-int board_eth_init(bd_t *bis) +#if defined(CONFIG_SPL_OS_BOOT) +int spl_start_uboot(void) { + /* break into full u-boot on 'c' */ + if (serial_tstc() && serial_getc() == 'c') + return 1; + return 0; } +#endif /* CONFIG_SPL_OS_BOOT */
-#if defined(CONFIG_USB_EHCI_HCD) || defined(CONFIG_USB_XHCI_OMAP) -static void enable_host_clocks(void) +int board_eth_init(bd_t *bis) { - int auxclk; - int hs_clk_ctrl_val = (OPTFCLKEN_HSIC60M_P3_CLK | - OPTFCLKEN_HSIC480M_P3_CLK | - OPTFCLKEN_HSIC60M_P2_CLK | - OPTFCLKEN_HSIC480M_P2_CLK | - OPTFCLKEN_UTMI_P3_CLK | OPTFCLKEN_UTMI_P2_CLK); - - /* Enable port 2 and 3 clocks*/ - setbits_le32((*prcm)->cm_l3init_hsusbhost_clkctrl, hs_clk_ctrl_val); - - /* Enable port 2 and 3 usb host ports tll clocks*/ - setbits_le32((*prcm)->cm_l3init_hsusbtll_clkctrl, - (OPTFCLKEN_USB_CH1_CLK_ENABLE | OPTFCLKEN_USB_CH2_CLK_ENABLE)); -#ifdef CONFIG_USB_XHCI_OMAP - /* Enable the USB OTG Super speed clocks */ - setbits_le32((*prcm)->cm_l3init_usb_otg_ss_clkctrl, - (OPTFCLKEN_REFCLK960M | OTG_SS_CLKCTRL_MODULEMODE_HW)); -#endif - - auxclk = readl((*prcm)->scrm_auxclk1); - /* Request auxilary clock */ - auxclk |= AUXCLK_ENABLE_MASK; - writel(auxclk, (*prcm)->scrm_auxclk1); + return 0; } -#endif
/** * @brief misc_init_r - Configure EVM board specific configurations @@ -223,45 +206,6 @@ int board_mmc_init(bd_t *bis) } #endif
-#ifdef CONFIG_USB_EHCI_HCD -static struct omap_usbhs_board_data usbhs_bdata = { - .port_mode[0] = OMAP_USBHS_PORT_MODE_UNUSED, - .port_mode[1] = OMAP_EHCI_PORT_MODE_HSIC, - .port_mode[2] = OMAP_EHCI_PORT_MODE_HSIC, -}; - -int ehci_hcd_init(int index, enum usb_init_type init, - struct ehci_hccr **hccr, struct ehci_hcor **hcor) -{ - int ret; - - enable_host_clocks(); - - ret = omap_ehci_hcd_init(index, &usbhs_bdata, hccr, hcor); - if (ret < 0) { - puts("Failed to initialize ehci\n"); - return ret; - } - - return 0; -} - -int ehci_hcd_stop(void) -{ - return omap_ehci_hcd_stop(); -} - -void usb_hub_reset_devices(struct usb_hub_device *hub, int port) -{ - /* The LAN9730 needs to be reset after the port power has been set. */ - if (port == 3) { - gpio_direction_output(CONFIG_OMAP_EHCI_PHY3_RESET_GPIO, 0); - udelay(10); - gpio_direction_output(CONFIG_OMAP_EHCI_PHY3_RESET_GPIO, 1); - } -} -#endif - #ifdef CONFIG_USB_XHCI_OMAP /** * @brief board_usb_init - Configure EVM board specific configurations @@ -276,8 +220,6 @@ int board_usb_init(int index, enum usb_init_type init) ret = palmas_enable_ss_ldo(); #endif
- enable_host_clocks(); - return 0; } #endif diff --git a/configs/omap5_uevm_defconfig b/configs/omap5_uevm_defconfig index 487f7f305c..0029e70439 100644 --- a/configs/omap5_uevm_defconfig +++ b/configs/omap5_uevm_defconfig @@ -2,6 +2,7 @@ CONFIG_ARM=y CONFIG_ARCH_OMAP2PLUS=y CONFIG_OMAP54XX=y CONFIG_TARGET_OMAP5_UEVM=y +CONFIG_DEFAULT_DEVICE_TREE="omap5-uevm" CONFIG_OMAP_PLATFORM_RESET_TIME_MAX_USEC=16296 CONFIG_SPL=y CONFIG_ENV_OFFSET_REDUND=0x280000 @@ -10,6 +11,7 @@ CONFIG_SPL_TEXT_BASE=0x40300000 CONFIG_DISTRO_DEFAULTS=y # CONFIG_USE_BOOTCOMMAND is not set CONFIG_SYS_CONSOLE_INFO_QUIET=y +CONFIG_DEFAULT_FDT_FILE="omap5-uevm.dtb" CONFIG_VERSION_VARIABLE=y # CONFIG_SPL_NAND_SUPPORT is not set CONFIG_SPL_OS_BOOT=y @@ -20,14 +22,17 @@ CONFIG_CMD_GPIO=y CONFIG_CMD_GPT=y CONFIG_CMD_I2C=y CONFIG_CMD_MMC=y -CONFIG_CMD_SPI=y CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_EXT4_WRITE=y +CONFIG_OF_CONTROL=y CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_REDUNDAND_ENVIRONMENT=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y +CONFIG_DM=y +CONFIG_DM_MMC=y +CONFIG_AHCI=y CONFIG_SCSI_AHCI=y CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y @@ -37,9 +42,9 @@ CONFIG_MMC_OMAP_HS=y CONFIG_SCSI=y CONFIG_CONS_INDEX=3 CONFIG_SYS_NS16550=y -CONFIG_SPI=y -CONFIG_OMAP3_SPI=y +# CONFIG_SPI is not set CONFIG_USB=y +CONFIG_DM_USB=y CONFIG_USB_EHCI_HCD=y CONFIG_USB_DWC3=y CONFIG_USB_DWC3_OMAP=y @@ -53,3 +58,5 @@ CONFIG_USB_HOST_ETHER=y CONFIG_USB_ETHER_SMSC95XX=y CONFIG_FAT_WRITE=y CONFIG_OF_LIBFDT=y +CONFIG_SYS_MALLOC_F_LEN=0x4000 +CONFIG_DM_ETH=y
On 16/06/20 1:33 pm, Tero Kristo wrote:
This is a combined series of both omap4/omap5 DM conversion in one. The main change across all the boards in this version is to drop SPI support completely. SPI is only available on expansion headers on the omap4 panda / omap5 uevm boards, and it is impossible for the authors of the patches in this series to both complete the SPI conversion to DM model, and test it, so it was deemed better to drop it completely.
Again, if someone from community needs the SPI support later, it should be relatively straightforward to add it back with proper expertise / tools.
Applied to u-boot-ti next.
Thanks and regards, Lokesh
Lokesh Vutla
Tero Kristo
