[U-Boot] [PATCH 1/3] ppc4xx: Update CPCI405 variants handling
From: Matthias Fuchs matthias.fuchs@esd-electronics.com
This patch replaces the BOARD_REVISION variable in include/config.mk by a using a temporary include file in the platform directory.
The former way does not work anymore and the latter is alos used by some other boards.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- Makefile | 8 +++++--- board/esd/cpci405/config.mk | 16 ++-------------- 2 files changed, 7 insertions(+), 17 deletions(-)
diff --git a/Makefile b/Makefile index 8d82ef5..73421db 100644 --- a/Makefile +++ b/Makefile @@ -1242,12 +1242,14 @@ CMS700_config: unconfig CPCI2DP_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci2dp esd
-CPCI405_config \ -CPCI4052_config \ +CPCI405_config: unconfig + @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci405 esd + +CPCI4052_config \ CPCI405DT_config \ CPCI405AB_config: unconfig + @echo "TEXT_BASE = 0xFFFC0000" > $(obj)board/esd/cpci405/config.tmp @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpci405 esd - @echo "BOARD_REVISION = $(@:_config=)" >> $(obj)include/config.mk
CPCIISER4_config: unconfig @$(MKCONFIG) $(@:_config=) ppc ppc4xx cpciiser4 esd diff --git a/board/esd/cpci405/config.mk b/board/esd/cpci405/config.mk index 0be45c7..6cfb891 100644 --- a/board/esd/cpci405/config.mk +++ b/board/esd/cpci405/config.mk @@ -21,20 +21,8 @@ # MA 02111-1307 USA #
-# -# esd CPCI405 boards -# +sinclude $(OBJTREE)/board/$(BOARDDIR)/config.tmp
-ifeq ($(BOARD_REVISION),CPCI4052) -TEXT_BASE = 0xFFFC0000 -else -ifeq ($(BOARD_REVISION),CPCI405DT) -TEXT_BASE = 0xFFFC0000 -else -ifeq ($(BOARD_REVISION),CPCI405AB) -TEXT_BASE = 0xFFFC0000 -else +ifndef TEXT_BASE TEXT_BASE = 0xFFFD0000 endif -endif -endif
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- board/esd/cpci405/u-boot.lds | 15 --------------- 1 files changed, 0 insertions(+), 15 deletions(-)
diff --git a/board/esd/cpci405/u-boot.lds b/board/esd/cpci405/u-boot.lds index 21547ac..2a1fc31 100644 --- a/board/esd/cpci405/u-boot.lds +++ b/board/esd/cpci405/u-boot.lds @@ -57,22 +57,7 @@ SECTIONS .plt : { *(.plt) } .text : { - /* WARNING - the following is hand-optimized to fit within */ - /* the sector layout of our flash chips! XXX FIXME XXX */ - cpu/ppc4xx/start.o (.text) - cpu/ppc4xx/traps.o (.text) - cpu/ppc4xx/interrupts.o (.text) - cpu/ppc4xx/4xx_uart.o (.text) - cpu/ppc4xx/cpu_init.o (.text) - cpu/ppc4xx/speed.o (.text) - common/dlmalloc.o (.text) - lib_generic/crc32.o (.text) - lib_ppc/extable.o (.text) - lib_generic/zlib.o (.text) - -/* . = env_offset;*/ -/* common/environment.o(.text)*/
*(.text) *(.fixup)
This patch add FDT support and command line editing capabilities for CPCI405 and CPCI405AB boards.
Signed-off-by: Matthias Fuchs matthias.fuchs@esd-electronics.com --- include/configs/CPCI4052.h | 6 ++++++ include/configs/CPCI405AB.h | 6 ++++++ 2 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/include/configs/CPCI4052.h b/include/configs/CPCI4052.h index fd49f56..9ec1721 100644 --- a/include/configs/CPCI4052.h +++ b/include/configs/CPCI4052.h @@ -146,6 +146,8 @@
#define CFG_HZ 1000 /* decrementer freq: 1 ms ticks */
+#define CONFIG_CMDLINE_EDITING /* add command line history */ + #define CONFIG_LOOPW 1 /* enable loopw command */
#define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */ @@ -219,6 +221,10 @@ * the maximum mapped by the Linux kernel during initialization. */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP + /*----------------------------------------------------------------------- * FLASH organization */ diff --git a/include/configs/CPCI405AB.h b/include/configs/CPCI405AB.h index 55dd629..7899598 100644 --- a/include/configs/CPCI405AB.h +++ b/include/configs/CPCI405AB.h @@ -144,6 +144,8 @@
+#define CONFIG_CMDLINE_EDITING /* add command line history */ + #define CONFIG_ZERO_BOOTDELAY_CHECK /* check for keypress on bootdelay==0 */
#define CONFIG_VERSION_VARIABLE 1 /* include version env variable */ @@ -215,6 +217,10 @@ * the maximum mapped by the Linux kernel during initialization. */ #define CFG_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ + +#define CONFIG_OF_LIBFDT +#define CONFIG_OF_BOARD_SETUP + /*----------------------------------------------------------------------- * FLASH organization */
Applied to u-boot-ppc4xx (all 3 patches from this series). Thanks.
Best regards, Stefan
Stefan Roese
