[U-Boot] [PATCH] [v4] powerpc/85xx: fix compatible property for the L2 cache node
The compatible property for the L2 cache node (on 85xx systems that don't have a CPC) was using a value for the property length that did not match the actual length of the property.
Signed-off-by: Timur Tabi timur@freescale.com --- arch/powerpc/cpu/mpc85xx/fdt.c | 20 ++++++++++++-------- 1 files changed, 12 insertions(+), 8 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/fdt.c b/arch/powerpc/cpu/mpc85xx/fdt.c index 642f6c5..121db5f 100644 --- a/arch/powerpc/cpu/mpc85xx/fdt.c +++ b/arch/powerpc/cpu/mpc85xx/fdt.c @@ -165,7 +165,6 @@ static inline void ft_fixup_l2cache(void *blob) int len, off; u32 *ph; struct cpu_type *cpu = identify_cpu(SVR_SOC_VER(get_svr())); - char compat_buf[38];
const u32 line_size = 32; const u32 num_ways = 8; @@ -192,22 +191,27 @@ static inline void ft_fixup_l2cache(void *blob) }
if (cpu) { + char buf[40]; + if (isdigit(cpu->name[0])) - len = sprintf(compat_buf, - "fsl,mpc%s-l2-cache-controller", cpu->name); + /* MPCxxxx, where xxxx == 4-digit number */ + len = sprintf(buf, "fsl,mpc%s-l2-cache-controller", + cpu->name) + 1; else - len = sprintf(compat_buf, - "fsl,%c%s-l2-cache-controller", - tolower(cpu->name[0]), cpu->name + 1); + /* Pxxxx or Txxxx, where xxxx == 4-digit number */ + len = sprintf(buf, "fsl,%c%s-l2-cache-controller", + tolower(cpu->name[0]), cpu->name + 1) + 1; + + /* append "cache" to the string */ + len += sprintf(buf + len, "cache") + 1;
- sprintf(&compat_buf[len + 1], "cache"); + fdt_setprop(blob, off, "compatible", buf, len); } fdt_setprop(blob, off, "cache-unified", NULL, 0); fdt_setprop_cell(blob, off, "cache-block-size", line_size); fdt_setprop_cell(blob, off, "cache-size", size); fdt_setprop_cell(blob, off, "cache-sets", num_sets); fdt_setprop_cell(blob, off, "cache-level", 2); - fdt_setprop(blob, off, "compatible", compat_buf, sizeof(compat_buf));
/* we dont bother w/L3 since no platform of this type has one */ }
Dear Timur Tabi,
if (cpu) {
char buf[40];
- if (isdigit(cpu->name[0]))
elsecpu->name) + 1;
Why do we need this "if" at all? tolower() on a digit is a nop, so you can omit the first branch.
This is wrong and misleading. This is not an operation on a C string. You do not "append" (or concatenate) the string cache. You build a specifically structured data set, which is not a C string. So please don't call it a string.
Because cpu->name looks like one of two ways:
8578
or P4080
In the case of "8578", we want to convert that to "mpc8578". In the case of "P4080", we want to convert that to "p4080".
The "if" is need to determine whether to prepend the "mpc".
Ok.
Dear Tabi Timur-B04825,
8578
or
P4080
In the case of "8578", we want to convert that to "mpc8578". In the case o f "P4080", we want to convert that to "p4080".
This gets lost in the code.
If you keep the if / else, you have to add braces for the multiline statements.
That's why I added the comments:
Ok.
Tabi Timur-B04825
Timur Tabi
