[U-Boot] Pull request: u-boot-arm/master
Hello Tom,
The following changes since commit 5b3ee386fde82a1ba42ff09b95247842c9a1585e:
kbuild: clear VENDOR variable to fix build error on tcsh (2014-10-23 16:35:12 -0400)
git://git.denx.de/u-boot-arm master
for you to fetch changes up to 59a9cfdd16ad7ab14f22697bf1e049c6bea0d3e2:
gic: fixed compilation error in GICv2 wait for interrupt macro (2014-10-28 07:57:31 +0100)
---------------------------------------------------------------- Masahiro Yamada (4): arm: debug: import debug files from Linux 3.16 arm: debug: replace license blocks with SPDX arm: debug: add Kconfig entries for lowlevel debug arm: debug: adjust for U-Boot
Yehuda Yitschak (1): gic: fixed compilation error in GICv2 wait for interrupt macro
arch/arm/Kconfig | 2 + arch/arm/Kconfig.debug | 64 +++++++++++++++++++++++ arch/arm/include/asm/macro.h | 2 +- arch/arm/include/debug/8250.S | 52 ++++++++++++++++++ arch/arm/lib/Makefile | 2 + arch/arm/lib/debug.S | 136 +++++++++++++++++++++++++++++++++++++++++++++++ include/linux/serial_reg.h | 388 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 7 files changed, 645 insertions(+), 1 deletion(-) create mode 100644 arch/arm/Kconfig.debug create mode 100644 arch/arm/include/debug/8250.S create mode 100644 arch/arm/lib/debug.S create mode 100644 include/linux/serial_reg.h
Amicalement,
On Sat, Nov 08, 2014 at 01:07:56AM +0100, Albert ARIBAUD wrote:
Hello Tom,
Albert ARIBAUD
