As this is now the stable release, move to using that now for our tests.
Signed-off-by: Tom Rini trini@konsulko.com --- .azure-pipelines.yml | 6 +++--- .gitlab-ci.yml | 4 ++-- tools/docker/Dockerfile | 4 ++-- 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/.azure-pipelines.yml b/.azure-pipelines.yml index 61ada4d681f9..e5068fecf2fb 100644 --- a/.azure-pipelines.yml +++ b/.azure-pipelines.yml @@ -2,7 +2,7 @@ variables: windows_vm: windows-2019 ubuntu_vm: ubuntu-22.04 macos_vm: macOS-12 - ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230126-17Feb2023 + ci_runner_image: trini/u-boot-gitlab-ci-runner:jammy-20230126-21Mar2023 # Add '-u 0' options for Azure pipelines, otherwise we get "permission # denied" error when it tries to "useradd -m -u 1001 vsts_azpcontainer", # since our $(ci_runner_image) user is not root. @@ -254,7 +254,7 @@ stages: TEST_PY_BD: "sandbox" sandbox_clang: TEST_PY_BD: "sandbox" - OVERRIDE: "-O clang-14" + OVERRIDE: "-O clang-16" sandbox_nolto: TEST_PY_BD: "sandbox" BUILD_ENV: "NO_LTO=1" @@ -508,7 +508,7 @@ stages: OVERRIDE: "-a ASAN" sandbox_clang_asan: BUILDMAN: "sandbox" - OVERRIDE: "-O clang-14 -a ASAN" + OVERRIDE: "-O clang-16 -a ASAN" samsung_socfpga: BUILDMAN: "samsung socfpga" sun4i: diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml index a89138701dcf..75a8270bc31b 100644 --- a/.gitlab-ci.yml +++ b/.gitlab-ci.yml @@ -2,7 +2,7 @@
# Grab our configured image. The source for this is found # in the u-boot tree at tools/docker/Dockerfile -image: trini/u-boot-gitlab-ci-runner:jammy-20230126-17Feb2023 +image: trini/u-boot-gitlab-ci-runner:jammy-20230126-21Mar2023
# We run some tests in different order, to catch some failures quicker. stages: @@ -266,7 +266,7 @@ sandbox test.py: sandbox with clang test.py: variables: TEST_PY_BD: "sandbox" - OVERRIDE: "-O clang-14" + OVERRIDE: "-O clang-16" <<: *buildman_and_testpy_dfn
sandbox without LTO test.py: diff --git a/tools/docker/Dockerfile b/tools/docker/Dockerfile index fdcb0c7f3d29..109b033c4c99 100644 --- a/tools/docker/Dockerfile +++ b/tools/docker/Dockerfile @@ -12,7 +12,7 @@ ENV DEBIAN_FRONTEND=noninteractive # Add LLVM repository RUN apt-get update && apt-get install -y gnupg2 wget xz-utils && rm -rf /var/lib/apt/lists/* RUN wget -O - https://apt.llvm.org/llvm-snapshot.gpg.key | apt-key add - -RUN echo deb http://apt.llvm.org/jammy/ llvm-toolchain-jammy-14 main | tee /etc/apt/sources.list.d/llvm.list +RUN echo deb http://apt.llvm.org/jammy/ llvm-toolchain-jammy-16 main | tee /etc/apt/sources.list.d/llvm.list
# Manually install the kernel.org "Crosstool" based toolchains for gcc-12.2.0 RUN wget -O - https://mirrors.edge.kernel.org/pub/tools/crosstool/files/bin/x86_64/12.2.0/... | tar -C /opt -xJ @@ -39,7 +39,7 @@ RUN apt-get update && apt-get install -y \ binutils-dev \ bison \ build-essential \ - clang-14 \ + clang-16 \ coreutils \ cpio \ cppcheck \
Hi Tom,
I haven't figured out the linker_list problem yet though.
Signed-off-by: Tom Rini trini@konsulko.com Reviewed-by: Simon Glass sjg@chromium.org
