[U-Boot] [PATCH v5] mmc: gen_atmel_mci: add driver model support for mci
Add the driver model support for Atmel mci while retaining the existing legacy code. This allows the driver to support boards that have converted to driver model as well as those that have not.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com ---
Changes in v5: - Rebase on v2017.03.
Changes in v4: - Remove unneeded #ifdef CONFIG_DM_MMC.
Changes in v3: - Use unified #ifdef CONFIG_DM_MMC #else...#endif, instead of #ifndef CONFIG_DM_MMC #else...#endif.
Changes in v2: - Change the return type of atmel_mci_setup_cfg() from int to void. - Add comments on the features depends on the IP version. - Add the error handle path of clock. - Fix the missing use priv->bus_clk_rate. - Return from mmc_bind() directly, instead of checking its return.
drivers/mmc/Kconfig | 9 +++ drivers/mmc/gen_atmel_mci.c | 158 +++++++++++++++++++++++++++++++++++++++++++- 2 files changed, 166 insertions(+), 1 deletion(-)
diff --git a/drivers/mmc/Kconfig b/drivers/mmc/Kconfig index 01d1dbfb1b..cb9937b4eb 100644 --- a/drivers/mmc/Kconfig +++ b/drivers/mmc/Kconfig @@ -336,6 +336,15 @@ config MMC_SUNXI This selects support for the SD/MMC Host Controller on Allwinner sunxi SoCs.
+config GENERIC_ATMEL_MCI + bool "Atmel Multimedia Card Interface support" + depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91 + help + This enables support for Atmel High Speed Multimedia Card Interface + (HSMCI), which supports the MultiMedia Card (MMC) Specification V4.3, + the SD Memory Card Specification V2.0, the SDIO V2.0 specification + and CE-ATA V1.1. + endif
endmenu diff --git a/drivers/mmc/gen_atmel_mci.c b/drivers/mmc/gen_atmel_mci.c index 7dc4a5de74..c25d9ed96e 100644 --- a/drivers/mmc/gen_atmel_mci.c +++ b/drivers/mmc/gen_atmel_mci.c @@ -10,6 +10,7 @@ */
#include <common.h> +#include <clk.h> #include <mmc.h> #include <part.h> #include <malloc.h> @@ -18,8 +19,11 @@ #include <asm/byteorder.h> #include <asm/arch/clk.h> #include <asm/arch/hardware.h> +#include <dm/device.h> #include "atmel_mci.h"
+DECLARE_GLOBAL_DATA_PTR; + #ifndef CONFIG_SYS_MMC_CLK_OD # define CONFIG_SYS_MMC_CLK_OD 150000 #endif @@ -37,6 +41,10 @@ struct atmel_mci_priv { struct atmel_mci *mci; unsigned int initialized:1; unsigned int curr_clk; +#ifdef CONFIG_DM_MMC + struct mmc mmc; + ulong bus_clk_rate; +#endif };
/* Read Atmel MCI IP version */ @@ -58,11 +66,19 @@ static void dump_cmd(u32 cmdr, u32 arg, u32 status, const char* msg) }
/* Setup for MCI Clock and Block Size */ +#ifdef CONFIG_DM_MMC +static void mci_set_mode(struct atmel_mci_priv *priv, u32 hz, u32 blklen) +{ + struct mmc *mmc = &priv->mmc; + u32 bus_hz = priv->bus_clk_rate; +#else static void mci_set_mode(struct mmc *mmc, u32 hz, u32 blklen) { struct atmel_mci_priv *priv = mmc->priv; - atmel_mci_t *mci = priv->mci; u32 bus_hz = get_mci_clk_rate(); +#endif + + atmel_mci_t *mci = priv->mci; u32 clkdiv = 255; unsigned int version = atmel_mci_get_version(mci); u32 clkodd = 0; @@ -202,10 +218,18 @@ io_fail: * Sends a command out on the bus and deals with the block data. * Takes the mmc pointer, a command pointer, and an optional data pointer. */ +#ifdef CONFIG_DM_MMC +static int atmel_mci_send_cmd(struct udevice *dev, struct mmc_cmd *cmd, + struct mmc_data *data) +{ + struct atmel_mci_priv *priv = dev_get_priv(dev); + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else static int mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) { struct atmel_mci_priv *priv = mmc->priv; +#endif atmel_mci_t *mci = priv->mci; u32 cmdr; u32 error_flags = 0; @@ -335,17 +359,28 @@ mci_send_cmd(struct mmc *mmc, struct mmc_cmd *cmd, struct mmc_data *data) return 0; }
+#ifdef CONFIG_DM_MMC +static int atmel_mci_set_ios(struct udevice *dev) +{ + struct atmel_mci_priv *priv = dev_get_priv(dev); + struct mmc *mmc = mmc_get_mmc_dev(dev); +#else /* Entered into mmc structure during driver init */ static int mci_set_ios(struct mmc *mmc) { struct atmel_mci_priv *priv = mmc->priv; +#endif atmel_mci_t *mci = priv->mci; int bus_width = mmc->bus_width; unsigned int version = atmel_mci_get_version(mci); int busw;
/* Set the clock speed */ +#ifdef CONFIG_DM_MMC + mci_set_mode(priv, mmc->clock, MMC_DEFAULT_BLKLEN); +#else mci_set_mode(mmc, mmc->clock, MMC_DEFAULT_BLKLEN); +#endif
/* * set the bus width and select slot for this interface @@ -374,10 +409,15 @@ static int mci_set_ios(struct mmc *mmc) return 0; }
+#ifdef CONFIG_DM_MMC +static int atmel_mci_hw_init(struct atmel_mci_priv *priv) +{ +#else /* Entered into mmc structure during driver init */ static int mci_init(struct mmc *mmc) { struct atmel_mci_priv *priv = mmc->priv; +#endif atmel_mci_t *mci = priv->mci;
/* Initialize controller */ @@ -392,11 +432,16 @@ static int mci_init(struct mmc *mmc) writel(~0UL, &mci->idr);
/* Set default clocks and blocklen */ +#ifdef CONFIG_DM_MMC + mci_set_mode(priv, CONFIG_SYS_MMC_CLK_OD, MMC_DEFAULT_BLKLEN); +#else mci_set_mode(mmc, CONFIG_SYS_MMC_CLK_OD, MMC_DEFAULT_BLKLEN); +#endif
return 0; }
+#ifndef CONFIG_DM_MMC static const struct mmc_ops atmel_mci_ops = { .send_cmd = mci_send_cmd, .set_ios = mci_set_ios, @@ -456,3 +501,114 @@ int atmel_mci_init(void *regs)
return 0; } +#endif + +#ifdef CONFIG_DM_MMC +static const struct dm_mmc_ops atmel_mci_mmc_ops = { + .send_cmd = atmel_mci_send_cmd, + .set_ios = atmel_mci_set_ios, +}; + +static void atmel_mci_setup_cfg(struct atmel_mci_priv *priv) +{ + struct mmc_config *cfg; + u32 version; + + cfg = &priv->cfg; + cfg->name = "Atmel mci"; + cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34; + + /* + * If the version is above 3.0, the capabilities of the 8-bit + * bus width and high speed are supported. + */ + version = atmel_mci_get_version(priv->mci); + if ((version & 0xf00) >= 0x300) { + cfg->host_caps = MMC_MODE_8BIT | + MMC_MODE_HS | MMC_MODE_HS_52MHz; + } + + cfg->host_caps |= MMC_MODE_4BIT; + cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT; + cfg->f_min = priv->bus_clk_rate / (2 * 256); + cfg->f_max = priv->bus_clk_rate / 2; +} + +static int atmel_mci_enable_clk(struct udevice *dev) +{ + struct atmel_mci_priv *priv = dev_get_priv(dev); + struct clk clk; + ulong clk_rate; + int ret = 0; + + ret = clk_get_by_index(dev, 0, &clk); + if (ret) { + ret = -EINVAL; + goto failed; + } + + ret = clk_enable(&clk); + if (ret) + goto failed; + + clk_rate = clk_get_rate(&clk); + if (!clk_rate) { + ret = -EINVAL; + goto failed; + } + + priv->bus_clk_rate = clk_rate; + +failed: + clk_free(&clk); + + return ret; +} + +static int atmel_mci_probe(struct udevice *dev) +{ + struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev); + struct atmel_mci_priv *priv = dev_get_priv(dev); + struct mmc *mmc; + int ret; + + ret = atmel_mci_enable_clk(dev); + if (ret) + return ret; + + priv->mci = (struct atmel_mci *)dev_get_addr_ptr(dev); + + atmel_mci_setup_cfg(priv); + + mmc = &priv->mmc; + mmc->cfg = &priv->cfg; + mmc->dev = dev; + upriv->mmc = mmc; + + atmel_mci_hw_init(priv); + + return 0; +} + +static int atmel_mci_bind(struct udevice *dev) +{ + struct atmel_mci_priv *priv = dev_get_priv(dev); + + return mmc_bind(dev, &priv->mmc, &priv->cfg); +} + +static const struct udevice_id atmel_mci_ids[] = { + { .compatible = "atmel,hsmci" }, + { } +}; + +U_BOOT_DRIVER(atmel_mci) = { + .name = "atmel-mci", + .id = UCLASS_MMC, + .of_match = atmel_mci_ids, + .bind = atmel_mci_bind, + .probe = atmel_mci_probe, + .priv_auto_alloc_size = sizeof(struct atmel_mci_priv), + .ops = &atmel_mci_mmc_ops, +}; +#endif
Hi Wenyou,
If Andreas is ok, i will pick this. Otherwise, pick this with my ack. Let me know, plz.
Acked-by: Jaehoon Chung jh80.chung@samsung.com
Best Regards, Jaehoon Chung
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
- bool "Atmel Multimedia Card Interface support"
- depends on DM_MMC && BLK && DM_MMC_OPS && ARCH_AT91
- help
and CE-ATA V1.1.
endif
- struct mmc mmc;
- ulong bus_clk_rate;
+#endif };
- struct mmc *mmc = &priv->mmc;
- u32 bus_hz = priv->bus_clk_rate;
- atmel_mci_t *mci = priv->mci; u32 clkdiv = 255; unsigned int version = atmel_mci_get_version(mci); u32 clkodd = 0;
- Sends a command out on the bus and deals with the block data.
- Takes the mmc pointer, a command pointer, and an optional data pointer.
- struct atmel_mci_priv *priv = dev_get_priv(dev);
- struct mmc *mmc = mmc_get_mmc_dev(dev);
- mci_set_mode(priv, mmc->clock, MMC_DEFAULT_BLKLEN);
- mci_set_mode(priv, CONFIG_SYS_MMC_CLK_OD, MMC_DEFAULT_BLKLEN);
return 0; }
return 0; } +#endif
- .send_cmd = atmel_mci_send_cmd,
- .set_ios = atmel_mci_set_ios,
- struct mmc_config *cfg;
- u32 version;
- cfg = &priv->cfg;
- cfg->name = "Atmel mci";
- cfg->voltages = MMC_VDD_32_33 | MMC_VDD_33_34;
- version = atmel_mci_get_version(priv->mci);
- if ((version & 0xf00) >= 0x300) {
- cfg->host_caps |= MMC_MODE_4BIT;
- cfg->b_max = CONFIG_SYS_MMC_MAX_BLK_COUNT;
- cfg->f_min = priv->bus_clk_rate / (2 * 256);
- cfg->f_max = priv->bus_clk_rate / 2;
- struct clk clk;
- ulong clk_rate;
- int ret = 0;
- ret = clk_get_by_index(dev, 0, &clk);
- if (ret) {
ret = -EINVAL;
goto failed;
- ret = clk_enable(&clk);
- if (ret)
goto failed;
- clk_rate = clk_get_rate(&clk);
- if (!clk_rate) {
ret = -EINVAL;
goto failed;
- priv->bus_clk_rate = clk_rate;
+failed:
- clk_free(&clk);
- return ret;
- struct mmc_uclass_priv *upriv = dev_get_uclass_priv(dev);
- struct mmc *mmc;
- int ret;
- ret = atmel_mci_enable_clk(dev);
- if (ret)
return ret;
- priv->mci = (struct atmel_mci *)dev_get_addr_ptr(dev);
- atmel_mci_setup_cfg(priv);
- mmc = &priv->mmc;
- mmc->cfg = &priv->cfg;
- mmc->dev = dev;
- upriv->mmc = mmc;
- atmel_mci_hw_init(priv);
- return mmc_bind(dev, &priv->mmc, &priv->cfg);
- { .compatible = "atmel,hsmci" },
- .name = "atmel-mci",
- .id = UCLASS_MMC,
- .of_match = atmel_mci_ids,
- .bind = atmel_mci_bind,
- .probe = atmel_mci_probe,
- .priv_auto_alloc_size = sizeof(struct atmel_mci_priv),
- .ops = &atmel_mci_mmc_ops,
+}; +#endif
Hi Jaehoon,
On 2017/3/30 12:30, Jaehoon Chung wrote:
Hi Wenyou,
Andreas, are you okay?
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
help
and CE-ATA V1.1.
endif
endmenu
- #ifndef CONFIG_SYS_MMC_CLK_OD # define CONFIG_SYS_MMC_CLK_OD 150000 #endif
- struct mmc mmc;
+#endif };
return 0; }
return 0; } +#endif
- u32 version;
- cfg = &priv->cfg;
- struct clk clk;
- ulong clk_rate;
- int ret = 0;
- if (ret) {
ret = -EINVAL;
goto failed;
- if (ret)
goto failed;
- if (!clk_rate) {
ret = -EINVAL;
goto failed;
+failed:
- clk_free(&clk);
- return ret;
- struct mmc *mmc;
- int ret;
- if (ret)
return ret;
- mmc = &priv->mmc;
- mmc->dev = dev;
- upriv->mmc = mmc;
- .id = UCLASS_MMC,
+}; +#endif
Best Regards, Wenyou Yang
Changes in v5:
Changes in v4:
Changes in v3:
Changes in v2:
Jaehoon Chung
Wenyou Yang
Yang, Wenyou
