[U-Boot] [PATCH v3 0/3] board: at91sam9x5ek: Convert to support DM and DT
The purpose of the patch set is to convert the board to support the driver model and device tree. It is based on the patch set: [PATCH v8 0/2] pinctrl: at91: Add pinctrl driver https://lists.denx.de/pipermail/u-boot/2017-March/284577.html
Changes in v3: - Convert Atmel mci driver to support the driver model. - Remain the SPI_SPEED macro. - Add the support of Atmel uart device be used in the board_init_f stage. - Disable the SPL for nand config. - Improve the commit log. - Remove Atmel mci related code. - Use CONFIG_DEBUG_UART_CLOCK as the input clock for the early debug UART. - Drop [PATCH 4/5] configs: at91sam9x5ek: move SYS_NO_FLASH to defconfig.
Changes in v2: - Rebase on the patch set: [RESEND PATCH v2] ARM: at91: add default config file for sama5d36ek CMP board http://lists.denx.de/pipermail/u-boot/2017-February/280525.html
Wenyou Yang (3): configs: at91sam9x5ek: Update to support DM/DT board: at91sam9x5ek: Clean up code board: at91sam9x5ek: Enable early debug UART
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 82 ++++---------------------------- configs/at91sam9x5ek_dataflash_defconfig | 29 ++++++++++- configs/at91sam9x5ek_mmc_defconfig | 29 ++++++++++- configs/at91sam9x5ek_nandflash_defconfig | 35 +++++++++++--- configs/at91sam9x5ek_spiflash_defconfig | 36 ++++++++++---- include/configs/at91sam9x5ek.h | 25 +--------- 6 files changed, 123 insertions(+), 113 deletions(-)
Update the configuration files to support the device tree and driver model. The device clock and pins configuration are handled by the clock and the pinctrl drivers respectively.
Because the limitation of internal SRAM size, the SPL with driver model can't be supported, disable the SPL option.
Signed-off-by: Wenyou Yang wenyou.yang@atmel.com Reviewed-by: Simon Glass sjg@chromium.org ---
Changes in v2: None
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 2 ++ configs/at91sam9x5ek_dataflash_defconfig | 23 ++++++++++++++++++++++- configs/at91sam9x5ek_mmc_defconfig | 23 ++++++++++++++++++++++- configs/at91sam9x5ek_nandflash_defconfig | 29 ++++++++++++++++++++++------- configs/at91sam9x5ek_spiflash_defconfig | 30 ++++++++++++++++++++++-------- include/configs/at91sam9x5ek.h | 25 ++----------------------- 6 files changed, 92 insertions(+), 40 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index cc81776f9b..0ae42dd158 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -205,6 +205,7 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_LCD */
+#ifndef CONFIG_DM_SPI /* SPI chip select control */ #ifdef CONFIG_ATMEL_SPI int spi_cs_is_valid(unsigned int bus, unsigned int cs) @@ -238,6 +239,7 @@ void spi_cs_deactivate(struct spi_slave *slave) } } #endif /* CONFIG_ATMEL_SPI */ +#endif
#ifdef CONFIG_GENERIC_ATMEL_MCI int board_mmc_init(bd_t *bd) diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index e07e2175e0..7850b994d5 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_DATAFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -21,9 +23,28 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 9a95a0496a..5990778ada 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -1,6 +1,8 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_MMC" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set @@ -21,9 +23,28 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index d93f687508..816fe69834 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -1,17 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_NAND_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_NANDFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y @@ -27,9 +23,28 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 5fc512b998..8574525bc2 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -1,18 +1,13 @@ CONFIG_ARM=y CONFIG_ARCH_AT91=y CONFIG_TARGET_AT91SAM9X5EK=y -CONFIG_SPL_GPIO_SUPPORT=y -CONFIG_SPL_LIBCOMMON_SUPPORT=y -CONFIG_SPL_LIBGENERIC_SUPPORT=y -CONFIG_SPL_SERIAL_SUPPORT=y -CONFIG_SPL_SPI_FLASH_SUPPORT=y -CONFIG_SPL_SPI_SUPPORT=y +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_DEFAULT_DEVICE_TREE="at91sam9g35ek" CONFIG_SYS_EXTRA_OPTIONS="AT91SAM9X5,SYS_USE_SPIFLASH" CONFIG_BOOTDELAY=3 # CONFIG_CONSOLE_MUX is not set CONFIG_SYS_CONSOLE_IS_IN_ENV=y # CONFIG_DISPLAY_BOARDINFO is not set -CONFIG_SPL=y CONFIG_HUSH_PARSER=y CONFIG_SYS_PROMPT="U-Boot> " CONFIG_CMD_BOOTZ=y @@ -28,9 +23,28 @@ CONFIG_CMD_DHCP=y CONFIG_CMD_PING=y CONFIG_CMD_FAT=y CONFIG_CMD_UBI=y +CONFIG_OF_CONTROL=y +CONFIG_DM=y +CONFIG_CLK=y +CONFIG_CLK_AT91=y +CONFIG_AT91_UTMI=y +CONFIG_DM_GPIO=y +CONFIG_AT91_GPIO=y +CONFIG_DM_MMC=y +CONFIG_GENERIC_ATMEL_MCI=y +CONFIG_DM_SPI_FLASH=y CONFIG_SPI_FLASH=y CONFIG_SPI_FLASH_ATMEL=y +CONFIG_DM_ETH=y +CONFIG_MACB=y +CONFIG_PINCTRL=y +CONFIG_PINCTRL_AT91=y +CONFIG_DM_SERIAL=y +CONFIG_ATMEL_USART=y +CONFIG_DM_SPI=y +CONFIG_ATMEL_SPI=y CONFIG_USB=y +CONFIG_DM_USB=y +CONFIG_USB_EHCI_HCD=y CONFIG_USB_STORAGE=y CONFIG_LCD=y -CONFIG_OF_LIBFDT=y diff --git a/include/configs/at91sam9x5ek.h b/include/configs/at91sam9x5ek.h index c81003e311..f03b8320d3 100644 --- a/include/configs/at91sam9x5ek.h +++ b/include/configs/at91sam9x5ek.h @@ -26,12 +26,6 @@
/* general purpose I/O */ #define CONFIG_ATMEL_LEGACY /* required until (g)pio is fixed */ -#define CONFIG_AT91_GPIO - -/* serial console */ -#define CONFIG_ATMEL_USART -#define CONFIG_USART_BASE ATMEL_BASE_DBGU -#define CONFIG_USART_ID ATMEL_ID_SYS
/* LCD */ #define LCD_BPP LCD_COLOR16 @@ -68,11 +62,10 @@ #define CONFIG_SYS_SDRAM_SIZE 0x08000000 /* 128 megs */
#define CONFIG_SYS_INIT_SP_ADDR \ - (CONFIG_SYS_SDRAM_BASE + 4 * 1024 - GENERATED_GBL_DATA_SIZE) + (CONFIG_SYS_SDRAM_BASE + 16 * 1024 - GENERATED_GBL_DATA_SIZE)
/* DataFlash */ #ifdef CONFIG_CMD_SF -#define CONFIG_ATMEL_SPI #define CONFIG_SF_DEFAULT_SPEED 30000000 #endif
@@ -105,23 +98,9 @@ #define CONFIG_CMD_UBIFS #endif
-/* MMC */ -#ifdef CONFIG_CMD_MMC -#define CONFIG_GENERIC_ATMEL_MCI -#endif - -/* Ethernet */ -#define CONFIG_MACB -#define CONFIG_RMII -#define CONFIG_NET_RETRY_COUNT 20 -#define CONFIG_MACB_SEARCH_PHY - /* USB */ #ifdef CONFIG_CMD_USB -#ifdef CONFIG_USB_EHCI -#define CONFIG_USB_EHCI_ATMEL -#define CONFIG_SYS_USB_EHCI_MAX_ROOT_PORTS 2 -#else +#ifndef CONFIG_USB_EHCI #define CONFIG_USB_ATMEL #define CONFIG_USB_ATMEL_CLK_SEL_UPLL #define CONFIG_USB_OHCI_NEW
Since the introduction of the pinctrl and clock driver and the device tree files, remove unneeded hard coded related code from the board file.
Changes in v3: - Remove Atmel mci related code.
Changes in v2: None
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 78 --------------------------------- 1 file changed, 78 deletions(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 0ae42dd158..235b33725d 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -14,18 +14,10 @@ #include <asm/arch/gpio.h> #include <lcd.h> #include <atmel_hlcdc.h> -#include <atmel_mci.h> -#ifdef CONFIG_MACB -#include <net.h> -#endif -#include <netdev.h> #ifdef CONFIG_LCD_INFO #include <nand.h> #include <version.h> #endif -#ifdef CONFIG_ATMEL_SPI -#include <spi.h> -#endif
DECLARE_GLOBAL_DATA_PTR;
@@ -92,21 +84,6 @@ static void at91sam9x5ek_nand_hw_init(void) } #endif
-int board_eth_init(bd_t *bis) -{ - int rc = 0; - -#ifdef CONFIG_MACB - if (has_emac0()) - rc = macb_eth_initialize(0, - (void *)ATMEL_BASE_EMAC0, 0x00); - if (has_emac1()) - rc = macb_eth_initialize(1, - (void *)ATMEL_BASE_EMAC1, 0x00); -#endif - return rc; -} - #ifdef CONFIG_LCD vidinfo_t panel_info = { .vl_col = 800, @@ -205,51 +182,6 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_LCD */
-#ifndef CONFIG_DM_SPI -/* SPI chip select control */ -#ifdef CONFIG_ATMEL_SPI -int spi_cs_is_valid(unsigned int bus, unsigned int cs) -{ - return bus == 0 && cs < 2; -} - -void spi_cs_activate(struct spi_slave *slave) -{ - switch (slave->cs) { - case 1: - at91_set_pio_output(AT91_PIO_PORTA, 7, 0); - break; - case 0: - default: - at91_set_pio_output(AT91_PIO_PORTA, 14, 0); - break; - } -} - -void spi_cs_deactivate(struct spi_slave *slave) -{ - switch (slave->cs) { - case 1: - at91_set_pio_output(AT91_PIO_PORTA, 7, 1); - break; - case 0: - default: - at91_set_pio_output(AT91_PIO_PORTA, 14, 1); - break; - } -} -#endif /* CONFIG_ATMEL_SPI */ -#endif - -#ifdef CONFIG_GENERIC_ATMEL_MCI -int board_mmc_init(bd_t *bd) -{ - at91_mci_hw_init(); - - return atmel_mci_init((void *)ATMEL_BASE_HSMCI0); -} -#endif - int board_early_init_f(void) { at91_seriald_hw_init(); @@ -268,14 +200,6 @@ int board_init(void) at91sam9x5ek_nand_hw_init(); #endif
-#ifdef CONFIG_ATMEL_SPI - at91_spi0_hw_init(1 << 4); -#endif - -#ifdef CONFIG_MACB - at91_macb_hw_init(); -#endif - #if defined(CONFIG_USB_OHCI_NEW) || defined(CONFIG_USB_EHCI) at91_uhp_hw_init(); #endif @@ -302,8 +226,6 @@ void at91_spl_board_init(void) at91_mci_hw_init(); #elif CONFIG_SYS_USE_NANDFLASH at91sam9x5ek_nand_hw_init(); -#elif CONFIG_SYS_USE_SPIFLASH - at91_spi0_hw_init(1 << 4); #endif }
Enable the early debug UART to debug problems when an ICE or other debug mechanism is not available.
Changes in v3: - Use CONFIG_DEBUG_UART_CLOCK as the input clock for the early debug UART. - Drop [PATCH 4/5] configs: at91sam9x5ek: move SYS_NO_FLASH to defconfig.
board/atmel/at91sam9x5ek/at91sam9x5ek.c | 14 +++++++++++++- configs/at91sam9x5ek_dataflash_defconfig | 6 ++++++ configs/at91sam9x5ek_mmc_defconfig | 6 ++++++ configs/at91sam9x5ek_nandflash_defconfig | 6 ++++++ configs/at91sam9x5ek_spiflash_defconfig | 6 ++++++ 5 files changed, 37 insertions(+), 1 deletion(-)
diff --git a/board/atmel/at91sam9x5ek/at91sam9x5ek.c b/board/atmel/at91sam9x5ek/at91sam9x5ek.c index 235b33725d..c661c77f83 100644 --- a/board/atmel/at91sam9x5ek/at91sam9x5ek.c +++ b/board/atmel/at91sam9x5ek/at91sam9x5ek.c @@ -12,6 +12,7 @@ #include <asm/arch/at91_rstc.h> #include <asm/arch/clk.h> #include <asm/arch/gpio.h> +#include <debug_uart.h> #include <lcd.h> #include <atmel_hlcdc.h> #ifdef CONFIG_LCD_INFO @@ -182,11 +183,22 @@ void lcd_show_board_info(void) #endif /* CONFIG_LCD_INFO */ #endif /* CONFIG_LCD */
-int board_early_init_f(void) +#ifdef CONFIG_DEBUG_UART_BOARD_INIT +void board_debug_uart_init(void) { at91_seriald_hw_init(); +} +#endif + +#ifdef CONFIG_BOARD_EARLY_INIT_F +int board_early_init_f(void) +{ +#ifdef CONFIG_DEBUG_UART + debug_uart_init(); +#endif return 0; } +#endif
int board_init(void) { diff --git a/configs/at91sam9x5ek_dataflash_defconfig b/configs/at91sam9x5ek_dataflash_defconfig index 7850b994d5..64707dbdaa 100644 --- a/configs/at91sam9x5ek_dataflash_defconfig +++ b/configs/at91sam9x5ek_dataflash_defconfig @@ -40,6 +40,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y diff --git a/configs/at91sam9x5ek_mmc_defconfig b/configs/at91sam9x5ek_mmc_defconfig index 5990778ada..ddeeeefa1e 100644 --- a/configs/at91sam9x5ek_mmc_defconfig +++ b/configs/at91sam9x5ek_mmc_defconfig @@ -40,6 +40,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y diff --git a/configs/at91sam9x5ek_nandflash_defconfig b/configs/at91sam9x5ek_nandflash_defconfig index 816fe69834..a26b38f330 100644 --- a/configs/at91sam9x5ek_nandflash_defconfig +++ b/configs/at91sam9x5ek_nandflash_defconfig @@ -40,6 +40,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y diff --git a/configs/at91sam9x5ek_spiflash_defconfig b/configs/at91sam9x5ek_spiflash_defconfig index 8574525bc2..75d25d8e61 100644 --- a/configs/at91sam9x5ek_spiflash_defconfig +++ b/configs/at91sam9x5ek_spiflash_defconfig @@ -40,6 +40,12 @@ CONFIG_MACB=y CONFIG_PINCTRL=y CONFIG_PINCTRL_AT91=y CONFIG_DM_SERIAL=y +CONFIG_DEBUG_UART=y +CONFIG_DEBUG_UART_ATMEL=y +CONFIG_DEBUG_UART_BASE=0xfffff200 +CONFIG_DEBUG_UART_CLOCK=132000000 +CONFIG_DEBUG_UART_BOARD_INIT=y +CONFIG_DEBUG_UART_ANNOUNCE=y CONFIG_ATMEL_USART=y CONFIG_DM_SPI=y CONFIG_ATMEL_SPI=y
Wenyou Yang
