[U-Boot] [PATCH 0/9] bootstage: TPL and SPL improvements
At present bootstage cannot be fully used on x86 since it violates a few U-Boot rules, mostly accessing pre-relocation memory after relocation. This series corrects this and adds better support for using bootstage in TPL.
Simon Glass (9): tiny-printf: Reduce size by removing ctype tiny-printf: Add print_grouped_ull() bloblist: Reserve an aligned base bootstage: Store the next ID in the stash bootstage: Fix counting of entries in stash bootstage: Avoid conflicts between stash/unstash bootstage: Correct relocation algorithm bootstage: Mark the start/end of TPL and SPL separately bootstage: Allow SPL to obtain bootstage info from TPL
common/board_f.c | 2 ++ common/board_r.c | 1 - common/bootstage.c | 53 ++++++++++++++++++++++++++++++--------------- common/spl/spl.c | 25 +++++++++++++++++---- include/bootstage.h | 2 ++ lib/tiny-printf.c | 13 +++++++++++ 6 files changed, 73 insertions(+), 23 deletions(-)
The ctype array is brought into the image, adding 256 bytes, when it is unlikely to be needed. The extra code for %p is only present when DEBUG is defined, so let's drop ctype as well unless DEBUG is defined.
lib/tiny-printf.c | 7 +++++++ 1 file changed, 7 insertions(+)
diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index ebef92fc9f6..632b4249142 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -289,8 +289,15 @@ static int _vprintf(struct printf_info *info, const char *fmt, va_list va) break; case 'p': pointer(info, fmt, va_arg(va, void *)); + /* + * Skip this because it pulls in _ctype which is + * 256 bytes, and we don't generally implement + * pointer anyway + */ +#ifdef DEBUG while (isalnum(fmt[0])) fmt++; +#endif break; case '%': out(info, '%');
This function is used in the bootstage report which may be triggered in sPL or TPL. Add a very basic implication of this function so that it builds. There is no attempt to get the formatting right, since this would add too much to code size.
lib/tiny-printf.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/lib/tiny-printf.c b/lib/tiny-printf.c index 632b4249142..430c3255bc5 100644 --- a/lib/tiny-printf.c +++ b/lib/tiny-printf.c @@ -389,3 +389,9 @@ int snprintf(char *buf, size_t size, const char *fmt, ...)
return ret; } + +void print_grouped_ull(unsigned long long int_val, int digits) +{ + /* Don't try to ptint the upper 32-bits */ + printf("%ld ", (ulong)int_val); +}
Make sure that the bloblist starts on an aligned boundary. This protects against one of the earlier allocations causing the alignment to be lost.
common/board_f.c | 1 + 1 file changed, 1 insertion(+)
diff --git a/common/board_f.c b/common/board_f.c index 591f18f391e..4852a3b0d84 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -588,6 +588,7 @@ static int reserve_stacks(void) static int reserve_bloblist(void) { #ifdef CONFIG_BLOBLIST + gd->start_addr_sp &= ~0xf; gd->start_addr_sp -= CONFIG_BLOBLIST_SIZE; gd->new_bloblist = map_sysmem(gd->start_addr_sp, CONFIG_BLOBLIST_SIZE); #endif
When stashing bootstage info, store the next ID so that it can be used when the stash is restored. This avoids the ID starting at zero and potentially overwriting existing entries.
common/bootstage.c | 11 +++++++---- 1 file changed, 7 insertions(+), 4 deletions(-)
diff --git a/common/bootstage.c b/common/bootstage.c index 56ef91ad859..257dc5d402f 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -41,10 +41,11 @@ enum { };
struct bootstage_hdr { - uint32_t version; /* BOOTSTAGE_VERSION */ - uint32_t count; /* Number of records */ - uint32_t size; /* Total data size (non-zero if valid) */ - uint32_t magic; /* Unused */ + u32 version; /* BOOTSTAGE_VERSION */ + u32 count; /* Number of records */ + u32 size; /* Total data size (non-zero if valid) */ + u32 magic; /* Magic number */ + u32 next_id; /* Next ID to use for bootstage */ };
int bootstage_relocate(void) @@ -392,6 +393,7 @@ int bootstage_stash(void *base, int size) hdr->count = count; hdr->size = 0; hdr->magic = BOOTSTAGE_MAGIC; + hdr->next_id = data->next_id; ptr += sizeof(*hdr);
/* Write the records, silently stopping when we run out of space */ @@ -485,6 +487,7 @@ int bootstage_unstash(const void *base, int size)
/* Mark the records as read */ data->rec_count += hdr->count; + data->next_id = hdr->next_id; debug("Unstashed %d records\n", hdr->count);
The current code searches for empty records but these do not exist with bootstage now. This used to be needed when bootstage records were stored in a sparse array.
Drop the unnecessary code and fix a code-style nit at the same time.
common/bootstage.c | 12 ++---------- 1 file changed, 2 insertions(+), 10 deletions(-)
diff --git a/common/bootstage.c b/common/bootstage.c index 257dc5d402f..fe36bac0474 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -373,7 +373,6 @@ int bootstage_stash(void *base, int size) const struct bootstage_record *rec; char buf[20]; char *ptr = base, *end = ptr + size; - uint32_t count; int i;
if (hdr + 1 > (struct bootstage_hdr *)end) { @@ -384,22 +383,15 @@ int bootstage_stash(void *base, int size) /* Write an arbitrary version number */ hdr->version = BOOTSTAGE_VERSION;
- /* Count the number of records, and write that value first */ - for (rec = data->record, i = count = 0; i < data->rec_count; - i++, rec++) { - if (rec->id != 0) - count++; - } - hdr->count = count; + hdr->count = data->rec_count; hdr->size = 0; hdr->magic = BOOTSTAGE_MAGIC; hdr->next_id = data->next_id; ptr += sizeof(*hdr);
/* Write the records, silently stopping when we run out of space */ - for (rec = data->record, i = 0; i < data->rec_count; i++, rec++) { + for (rec = data->record, i = 0; i < data->rec_count; i++, rec++) append_data(&ptr, end, rec, sizeof(*rec)); - }
/* Write the name strings */ for (rec = data->record, i = 0; i < data->rec_count; i++, rec++) {
At present there is a single shared address for bootstage data in both TPL and SPL. If SPL unstashs TPL bootstage info and then stashes it again to pass it to U-Boot, the new stash overwrites the strings of the old stash.
Fix this by duplicating the strings into the malloc() region. This should be a small cost in terms of space. Fix the header-file order at the same time.
This problem doesn't happen at the next stage (SPL->U-Boot) since U-Boot relocates the boostage data.
common/bootstage.c | 5 ++++- 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/common/bootstage.c b/common/bootstage.c index fe36bac0474..4557ed4508c 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -10,9 +10,10 @@ */
#include <common.h> -#include <linux/libfdt.h> #include <malloc.h> +#include <spl.h> #include <linux/compiler.h> +#include <linux/libfdt.h>
DECLARE_GLOBAL_DATA_PTR;
@@ -472,6 +473,8 @@ int bootstage_unstash(const void *base, int size) for (rec = data->record + data->next_id, i = 0; i < hdr->count; i++, rec++) { rec->name = ptr; + if (spl_phase() == PHASE_SPL) + rec->name = strdup(ptr);
/* Assume no data corruption here */ ptr += strlen(ptr) + 1;
At present bootstage relocation assumes that it is possible to point back to memory available before relocation, so it does not relocate the strings. However this is not the case on some platforms, such as x86 which uses the cache as RAM and loses access to this when the cache is enabled.
Move the relocation step to before U-Boot relocates, expand the allocated region to include space for the strings and relocate the strings at the same time as the bootstage records.
This ensures that bootstage data can remain accessible from TPL through SPL to U-Boot before/after relocation.
common/board_f.c | 1 + common/board_r.c | 1 - common/bootstage.c | 25 ++++++++++++++++++++++--- 3 files changed, 23 insertions(+), 4 deletions(-)
diff --git a/common/board_f.c b/common/board_f.c index 4852a3b0d84..e3591cbaebd 100644 --- a/common/board_f.c +++ b/common/board_f.c @@ -696,6 +696,7 @@ static int reloc_bootstage(void) gd->bootstage, gd->new_bootstage, size); memcpy(gd->new_bootstage, gd->bootstage, size); gd->bootstage = gd->new_bootstage; + bootstage_relocate(); } #endif
diff --git a/common/board_r.c b/common/board_r.c index d6fb5047a26..c1ecb06b743 100644 --- a/common/board_r.c +++ b/common/board_r.c @@ -670,7 +670,6 @@ static init_fnc_t init_sequence_r[] = { #ifdef CONFIG_SYS_NONCACHED_MEMORY initr_noncached, #endif - bootstage_relocate, #ifdef CONFIG_OF_LIVE initr_of_live, #endif diff --git a/common/bootstage.c b/common/bootstage.c index 4557ed4508c..e8b7bbf81a6 100644 --- a/common/bootstage.c +++ b/common/bootstage.c @@ -53,14 +53,23 @@ int bootstage_relocate(void) { struct bootstage_data *data = gd->bootstage; int i; + char *ptr; + + /* Figure out where to relocate the strings to */ + ptr = (char *)(data + 1);
/* * Duplicate all strings. They may point to an old location in the * program .text section that can eventually get trashed. */ debug("Relocating %d records\n", data->rec_count); - for (i = 0; i < data->rec_count; i++) - data->record[i].name = strdup(data->record[i].name); + for (i = 0; i < data->rec_count; i++) { + const char *from = data->record[i].name; + + strcpy(ptr, from); + data->record[i].name = ptr; + ptr += strlen(ptr) + 1; + }
return 0; } @@ -490,7 +499,17 @@ int bootstage_unstash(const void *base, int size)
int bootstage_get_size(void) { - return sizeof(struct bootstage_data); + struct bootstage_data *data = gd->bootstage; + struct bootstage_record *rec; + int size; + int i; + + size = sizeof(struct bootstage_data); + for (rec = data->record, i = 0; i < data->rec_count; + i++, rec++) + size += strlen(rec->name) + 1; + + return size; }
int bootstage_init(bool first)
At present bootstage in TPL and SPL use the same ID so it is not possible to see the timing of each. Separate out the IDs and use the correct one depending on which phase we are at.
Example output:
Timer summary in microseconds (14 records): Mark Elapsed Stage 0 0 reset 224,787 224,787 TPL 282,248 57,461 end TPL 341,067 58,819 SPL 925,436 584,369 end SPL 931,710 6,274 board_init_f 1,035,482 103,772 board_init_r 1,387,852 352,370 main_loop 1,387,911 59 id=175
Accumulated time: 196 dm_r 8,300 dm_spl 14,139 dm_f 229,121 fsp-m 262,992 fsp-s
common/spl/spl.c | 9 ++++++--- include/bootstage.h | 2 ++ 2 files changed, 8 insertions(+), 3 deletions(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index a9d3e847af5..eabb1fbc138 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -402,7 +402,8 @@ static int spl_common_init(bool setup_malloc) ret); return ret; } - bootstage_mark_name(BOOTSTAGE_ID_START_SPL, "spl"); + bootstage_mark_name(spl_phase() == PHASE_TPL ? BOOTSTAGE_ID_START_TPL : + BOOTSTAGE_ID_START_SPL, SPL_TPL_NAME); #if CONFIG_IS_ENABLED(LOG) ret = log_init(); if (ret) { @@ -418,7 +419,8 @@ static int spl_common_init(bool setup_malloc) } } if (CONFIG_IS_ENABLED(DM)) { - bootstage_start(BOOTSTATE_ID_ACCUM_DM_SPL, "dm_spl"); + bootstage_start(BOOTSTATE_ID_ACCUM_DM_SPL, + spl_phase() == PHASE_TPL ? "dm tpl" : "dm_spl"); /* With CONFIG_SPL_OF_PLATDATA, bring in all devices */ ret = dm_init_and_scan(!CONFIG_IS_ENABLED(OF_PLATDATA)); bootstage_accum(BOOTSTATE_ID_ACCUM_DM_SPL); @@ -704,8 +706,9 @@ void board_init_r(gd_t *dummy1, ulong dummy2) debug("SPL malloc() used 0x%lx bytes (%ld KB)\n", gd->malloc_ptr, gd->malloc_ptr / 1024); #endif + bootstage_mark_name(spl_phase() == PHASE_TPL ? BOOTSTAGE_ID_END_TPL : + BOOTSTAGE_ID_END_SPL, "end " SPL_TPL_NAME); #ifdef CONFIG_BOOTSTAGE_STASH - bootstage_mark_name(BOOTSTAGE_ID_END_SPL, "end_spl"); ret = bootstage_stash((void *)CONFIG_BOOTSTAGE_STASH_ADDR, CONFIG_BOOTSTAGE_STASH_SIZE); if (ret) diff --git a/include/bootstage.h b/include/bootstage.h index 5e7e242b834..d105ae01813 100644 --- a/include/bootstage.h +++ b/include/bootstage.h @@ -170,6 +170,8 @@ enum bootstage_id { * rough boot timing information. */ BOOTSTAGE_ID_AWAKE, + BOOTSTAGE_ID_START_TPL, + BOOTSTAGE_ID_END_TPL, BOOTSTAGE_ID_START_SPL, BOOTSTAGE_ID_END_SPL, BOOTSTAGE_ID_START_UBOOT_F,
It is possible to enable bootstage in TPL. TPL can stash the info for SPL. But at present this information is then lost because SPL does not read from the stash.
Add support for SPL not being the first phase to enable bootstage. Signed-off-by: Simon Glass sjg@chromium.org ---
common/spl/spl.c | 16 +++++++++++++++- 1 file changed, 15 insertions(+), 1 deletion(-)
diff --git a/common/spl/spl.c b/common/spl/spl.c index eabb1fbc138..5fac3cbea2b 100644 --- a/common/spl/spl.c +++ b/common/spl/spl.c @@ -18,6 +18,7 @@ #include <version.h> #include <image.h> #include <malloc.h> +#include <mapmem.h> #include <dm/root.h> #include <linux/compiler.h> #include <fdt_support.h> @@ -396,12 +397,25 @@ static int spl_common_init(bool setup_malloc) gd->malloc_ptr = 0; } #endif - ret = bootstage_init(true); + ret = bootstage_init(u_boot_first_phase()); if (ret) { debug("%s: Failed to set up bootstage: ret=%d\n", __func__, ret); return ret; } +#ifdef CONFIG_BOOTSTAGE_STASH + if (!u_boot_first_phase()) { + const void *stash = map_sysmem(CONFIG_BOOTSTAGE_STASH_ADDR, + CONFIG_BOOTSTAGE_STASH_SIZE); + + ret = bootstage_unstash(stash, CONFIG_BOOTSTAGE_STASH_SIZE); + if (ret) { + debug("%s: Failed to unstash bootstage: ret=%d\n", + __func__, ret); + return ret; + } + } +#endif /* CONFIG_BOOTSTAGE_STASH */ bootstage_mark_name(spl_phase() == PHASE_TPL ? BOOTSTAGE_ID_START_TPL : BOOTSTAGE_ID_START_SPL, SPL_TPL_NAME); #if CONFIG_IS_ENABLED(LOG)
