Re: [U-Boot] [PATCH 1/3] USB: Armada100: Add UTMI PHY interface driver
----- "Prafulla Wadaskar" prafulla@marvell.com wrote:
+/* MPMU Clocks */ +#define MPMU_EN_ALL_CLKS 0x1EFFFF
Turning on all clocks is not logical to enable this support, only relevant clock necessary for this components SHOULD BE enabled.
Enabling clocks for unused peripherals/components may result in unnecessarily extra power consumption
Otherwise ack for rest of the patch
Regards.. Prafulla . . .
I followed programming guidlines as per Armada_16x software manual. section: 20.4.3.1 snip of pseudo code from Programming guidlines section: [...snip...] print "******main PMU turn on all clocks\n" set val *(unsigned long *)PMUM_ACGR=0x001EFFFF print "******PMUap USBCLK Reset Control\n" set val *(unsigned long *)PMUA_USB_CLK_RES_CTRL=0x1B print "******UTMI ID\n" eval /hex *(unsigned long *)UTMI_REVISION [...snip...]
There is nothing mentioned in specific which clock is used/required by USB host controller.
Regards, Ajay Bhargav
Dear Ajay Bhargav,
In message 1978582266.117750.1327647714615.JavaMail.root@ahm.einfochips.com you wrote:
This is a deficiency of this specific document then. Prafulla is right: please enable only the really needed clocks. I guess there is better documentation that that pseudo code.
----- "Wolfgang Denk" wd@denx.de wrote:
Dear Ajay Bhargav,
Thanks for feedback... I will look for better documentation then..
Ajay Bhargav
